    4. IOBroker hängt sich nach Crash und Neuinstallation oft auf
      Greenhorn @crunchip last edited by
      @crunchip updates habe ich gerade gemacht.
      iob fix bringt folgendes. Wie kann ich alle stoppen?
      simon@iobroker:~ $ iob fix
      library: loaded
      Library version=2024-01-04
      ioBroker or some processes are still running:
      io.admin.0
      io.backitup.0
      io.hmip.0
      io.mqtt.0
      io.shelly.0
      io.sonoff.0
      io.zigbee.0
      io.discovery.0
      io.iqontrol.0
      io.midea.0
      io.web.0
      Please stop them first and try again!
        Homoran Global Moderator Administrators @Greenhorn last edited by
        @greenhorn
        iob stop
        iob fix
        iob start
        G crunchip 2 Replies Last reply Reply Quote 0
          Greenhorn @Homoran last edited by Homoran
          Gemacht...
          library: loaded
              Welcome to the ioBroker installation fixer!
              Script version: 2024-01-04
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists... Done
              Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          simon@iobroker:~ $
            crunchip Forum Testing Most Active @Homoran last edited by
            @homoran aber die 127.0.0.1 ist doch falsch, oder?
              Homoran Global Moderator Administrators @crunchip last edited by
              @crunchip sagte in IOBroker hängt sich nach Crash und Neuinstallation oft auf:
              wo?
                crunchip Forum Testing Most Active @Greenhorn last edited by
                @greenhorn sagte in IOBroker hängt sich nach Crash und Neuinstallation oft auf:
                Vor dem Crash lief alles einwandfrei, seitdem wurde nichts geändert.
                du hast 2 Adapter auf gleichem Port
                  Hier ein neues iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer
                            Kernel: Linux 6.1.0-rpi8-rpi-v8
                      Architecture: arm64
                  Model		: Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   20:04:44 up 33 min,  4 users,  load average: 3.18, 1.98, 1.30
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Sun 2024-03-10 20:04:44 CET
                             Universal time: Sun 2024-03-10 19:04:44 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  simon
                  /home/simon
                  simon adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  Boot Target: 	graphical.target
                  *** MEMORY ***
                  Mem:            4.0G        3.4G        489M         14M        265M        603M
                  Swap:           104M        104M        249K
                  Total:          4.1G        3.5G        489M
                           3793 M total memory
                           3217 M used memory
                           2880 M active memory
                            210 M inactive memory
                            466 M free memory
                              1 M buffer memory
                            252 M swap cache
                             99 M total swap
                             99 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  1.3M  379M   1% /run
                  /dev/mmcblk0p2 ext4      117G  6.6G  105G   6% /
                  tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
                  /dev/mmcblk0p1 vfat      510M   74M  437M  15% /boot/firmware
                  tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
                  [Sun Mar 10 19:31:39 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ccc359c3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                  [Sun Mar 10 19:31:42 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sun Mar 10 19:31:44 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  TARGET               SOURCE         FSTYPE      OPTIONS
                  /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
                  |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  774M	/var/
                  285M	/var/log
                  284M	/var/log/journal/8ec53d3bc1c549d5b36274323c1b8255
                  195M	/var/lib
                  Archived and active journals take up 283.8M in the file system.
                  /opt/iobroker/backups:
                  12M	/opt/iobroker/backups/
                  60K	/opt/iobroker/backups/tmpJavis0
                  4.0K	/opt/iobroker/backups/tmpJavis0/states
                  /opt/iobroker/iobroker-data:
                  333M	/opt/iobroker/iobroker-data/
                  163M	/opt/iobroker/iobroker-data/files
                  57M	/opt/iobroker/iobroker-data/files/javascript.admin
                  46M	/opt/iobroker/iobroker-data/backup-objects
                  38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                  124M	/opt/iobroker/iobroker-data/objects.jsonl
                  22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                  8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                  7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                  6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs 	v18.19.1
                  /usr/bin/node 		v18.19.1
                  /usr/bin/npm 		10.2.4
                  /usr/bin/npx 		10.2.4
                  /usr/bin/corepack 	0.22.0
                  nodejs:
                    Installed: 18.19.1-1nodesource1
                    Candidate: 18.19.1-1nodesource1
                    Version table:
                   *** 18.19.1-1nodesource1 1001
                          100 /var/lib/dpkg/status
                       18.19.0+dfsg-6~deb12u1 500
                       18.19.0-1nodesource1 1001
                       18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0+dfsg1-1 500
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller: 	5.0.19
                  admin: 		6.13.16
                  javascript: 	7.8.0
                  Adapters from github: 	0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                    system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                    system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                    system.adapter.link.0                   : link                  : iobroker                                 - disabled
                  + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                    system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                  Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                  Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Adapter    "link"         : 0.5.12   , installed 0.5.12
                  Adapter    "midea"        : 0.0.7    , installed 0.0.7
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "web"          : 6.2.3    , installed 6.2.3
                  Adapter    "ws"           : 2.5.10   , installed 2.5.10
                  Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                  Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
                  Objects and States
                  Objects: 	3979
                  States: 	3262
                  Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       51776      21179/io.shelly.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16115      800/sshd: /usr/sbin
                  tcp        0      0 192.168.178.96:1883     0.0.0.0:*               LISTEN      1001       53265      21197/io.sonoff.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48757      21090/iobroker.js-c
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52284      21090/iobroker.js-c
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17488      772/cupsd
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17487      772/cupsd
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48847      21108/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       48907      21273/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          16117      800/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16359      1078/cups-browsed
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13011      553/avahi-daemon: r
                  udp        0      0 0.0.0.0:44590           0.0.0.0:*                           104        13013      553/avahi-daemon: r
                  udp6       0      0 :::58315                :::*                                104        13014      553/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                104        13012      553/avahi-daemon: r
                  2024-03-10 20:04:12.912  - warn: zigbee.0 (21212) DeviceAvailability:Failed to ping 0xf0d1b8be2408284c B40 DIM T
                  2024-03-10 20:04:12.899  - info: shelly.0 (21179) [MQTT] Device with client id "shellypro1-30c6f781f3c8" connected!
                  2024-03-10 20:04:13.017  - warn: zigbee.0 (21212) DeviceAvailability:Failed to ping 0x001788010d3ec68f LWA024
                  2024-03-10 20:04:13.199  - warn: zigbee.0 (21212) DeviceAvailability:Failed to ping 0x001788010db790af LWU002
                  2024-03-10 20:04:13.326  - warn: zigbee.0 (21212) DeviceAvailability:Failed to ping 0x001788010d3fd6b1 LWA024
                  2024-03-10 20:04:19.152  - info: shelly.0 (21179) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-4855199d7590 / shellyplus1pm#4855199d7590#1) (false)
                  2024-03-10 20:04:20.066  - info: shelly.0 (21179) [MQTT] Device with client id "shellyplus1pm-b0b21c1b1e9c" connected!
                  2024-03-10 20:04:20.311  - info: shelly.0 (21179) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-b48a0a218644 / shellyplus1pm#b48a0a218644#1) (false)
                  2024-03-10 20:04:22.281  - info: shelly.0 (21179) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-b48a0a21c40c / shellyplus1pm#b48a0a21c40c#1) (false)
                  2024-03-10 20:04:22.339  - info: shelly.0 (21179) [MQTT] Client Close:  (shellypro1 / shellypro1-30c6f781f3c8 / shellypro1#30c6f781f3c8#1) (false)
                  2024-03-10 20:04:24.067  - info: hmip.0 (21131) hmip adapter connected and ready
                  2024-03-10 20:04:24.889  - error: shelly.0 (21179) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-b48a0a21c40c"
                  2024-03-10 20:04:24.937  - error: shelly.0 (21179) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-4855199d7590"
                  2024-03-10 20:04:24.939  - error: shelly.0 (21179) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-b48a0a218644"
                  2024-03-10 20:04:24.941  - error: shelly.0 (21179) [MQTT] Unable to get mqttprefix of client with id "shellypro1-30c6f781f3c8"
                  2024-03-10 20:05:16.854  - info: shelly.0 (21179) [MQTT] Device with client id "shellypro1-30c6f781f3c8" connected!
                  2024-03-10 20:05:17.119  - info: shelly.0 (21179) [MQTT] Device with client id "shellyplus1pm-4855199d7590" connected!
                  2024-03-10 20:05:19.052  - info: shelly.0 (21179) [MQTT] Device with client id "shellyplus1pm-b48a0a218644" connected!
                  2024-03-10 20:05:22.762  - info: shelly.0 (21179) [MQTT] Device with client id "shellyplus1pm-b48a0a21c40c" connected!
                  2024-03-10 20:05:26.887  - info: shelly.0 (21179) [MQTT] Client Close: 192.168.178.28 (shellypro1 / shellypro1-30c6f781f3c8 / shellypro1#30c6f781f3c8#1) (false)
                  2024-03-10 20:05:26.929  - error: shelly.0 (21179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                  2024-03-10 20:05:26.929  - error: shelly.0 (21179) [MQTT] Unable to get mqttprefix of client with id "shellypro1-30c6f781f3c8"
                  2024-03-10 20:05:27.133  - info: shelly.0 (21179) [MQTT] Client Close: 192.168.178.150 (shellyplus1pm / shellyplus1pm-4855199d7590 / shellyplus1pm#4855199d7590#1) (false)
                  2024-03-10 20:05:27.216  - error: shelly.0 (21179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                  2024-03-10 20:05:27.216  - error: shelly.0 (21179) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-4855199d7590"
                  			v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                  Installation: 		native
                  Kernel: 		aarch64
                  Userland: 		arm64
                  Timezone: 		Europe/Berlin (CET, +0100)
                  User-ID: 		1000
                  X-Server: 		false
                  Pending OS-Updates: 	0
                  Pending iob updates: 	0
                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                  			/usr/bin/npm 		10.2.4
                  			/usr/bin/npx 		10.2.4
                  Recommended versions are nodejs 18.19.1 and npm 10.2.4
                  MEMORY:
                  Mem:            4.0G        2.9G        596M         14M        621M        1.1G
                  Swap:           104M        104M        356K
                  Total:          4.1G        3.0G        596M
                  Active iob-Instances: 	12
                  ioBroker Core: 		js-controller 		5.0.19
                  			admin 			6.13.16
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		3979
                  States: 		3262
                  Size of iob-Database:
                  1.4M	/opt/iobroker/iobroker-data/states.jsonl
                    Greenhorn @crunchip last edited by Greenhorn
                    @crunchip
                    OK🤔 Welche?
                      @greenhorn dein mqtt und sonoff ist falsch
                        @crunchip Ja, beide nutzen den gleichen Port...
                          crunchip Forum Testing Most Active @Greenhorn last edited by crunchip
                          @greenhorn das darf nicht, die müssen unterschiedlich sein
                          @Homoran kannst du mir sagen warum man aus dem diag nicht einzelne Zeilen markieren/ zitieren kann? da passt doch das Format nicht?
                          G Homoran 2 Replies Last reply Reply Quote 0
                            @crunchip Klar, kann ich den Port in der Sonoff Instanz einfach ändern auf z.B. 1884 ?
                              @greenhorn ja und du hast beide instanzen fest an die IP gebunden
                              du musst aber bedenken, deine sonoff Geräte musst du entsprechend anpassen, zwecks port
                                Thomas Braun Most Active @Greenhorn last edited by
                                anschließenden Neuinstallation
                                Warum nimmt man da nicht gleich die 'Lite'-Version, ohne z. B. einem laufenden Drucker-Server wie cupsd?
                                sudo systemctl set-default multi-user.target
                                Sonoff und mqtt hast du auf den gleichen Port auf der gleichen IP laufen.
                                  Greenhorn @Thomas Braun last edited by
                                  @thomas-braun Wie ändere ich das jetzt?
                                    @crunchip muss sich @jey-Cee nochmal ansehen.
                                    er hatte was mit dem "alles markieren" optiiert, seitdem gibt es auf Android dieses Problem.
                                    Ich fürchte fast, dass genau deswegen vor Jahren das "alles markieren" verändert worden war
                                      @homoran sagte in IOBroker hängt sich nach Crash und Neuinstallation oft auf:
                                      ich sitz allerdings am PC, aber ja, alles markieren geht, aber einzelne Zeilen beginnt es zu flackern
                                        Man kann die Ports der mqtt-Broker ändern. Konkret beim sonoff? Keine Ahnung, hab den nicht im Einsatz.
                                          Greenhorn @Thomas Braun last edited by Greenhorn
                                          Also einfach im Adapter den Port ändern. Dann muss er aber in allen Geräten geändert werden. Das bedeutet vermutlich mehr Arbeit als beim Sonoff.
                                          Die IP-Adresse ist ja die des Raspis, die kann doch nicht einfach im Adapter geändert werden ?
                                          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @Greenhorn last edited by Thomas Braun
                                            @greenhorn
                                            Wobei ich auch nicht verstehe, warum man den sonoff ebenfalls als Broker konfiguriert, wenn da schon anderweitig ein mqtt-Broker läuft.
                                            6535
