    4. Zigbee Adapter Error Send Command failed with no error code
      Stefan 3 @arteck last edited by
      @arteck So, System wie gesagt neu aufgesetzt, FHEM und IOB installiert. RAM war am Anschlag, so dass ich eine 2GB Swap-Datei eingerichtet hab. Der Zigbee-Fehler ist unverändert da
      Zusatzinfo: Jetziges Ergebnis von iob diag:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi8-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       18:10:05 up 23 min,  2 users,  load average: 0.26, 0.21, 0.33
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      *** Time and Time Zones ***
                     Local time: Fri 2024-03-08 18:10:05 CET
                 Universal time: Fri 2024-03-08 17:10:05 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            952M        747M        112M        188K        153M        205M
      Swap:           2.3G        252M        2.0G
      Total:          3.2G        1.0G        2.1G
                908 M total memory
                712 M used memory
                455 M active memory
                253 M inactive memory
                107 M free memory
                 10 M buffer memory
                135 M swap cache
               2147 M total swap
                241 M used swap
               1906 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  319M     0  319M   0% /dev
      tmpfs          tmpfs      91M  1.1M   90M   2% /run
      /dev/mmcblk0p2 ext4       29G  5.9G   22G  22% /
      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      [Fri Mar  8 17:46:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=d46b09f2-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Mar  8 17:46:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Mar  8 17:46:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      753M    /var/
      285M    /var/log/journal/b97363623a9b4bc5bc8e5d0296596227
      285M    /var/log
      203M    /var/cache
      Archived and active journals take up 284.0M in the file system.
      /opt/iobroker/backups:
      8.4M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      199M    /opt/iobroker/iobroker-data/
      186M    /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/files/iot.admin
      42M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
        system.adapter.history.0                : history               : raspberrypi                              - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fhem"         : 2.0.5    , installed 2.0.5
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        3724
      States:         2904
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://debian.fhem.de/nightly  InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12870      629/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13810      629/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13768      686/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        12858      770/perl
      tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        15825      770/perl
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13770      686/sshd: /usr/sbin
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       15988      857/io.sonos.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14048      931/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15899      788/io.admin.0
      udp        0      0 0.0.0.0:56381           0.0.0.0:*                           104        12601      491/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12599      491/avahi-daemon: r
      udp6       0      0 fe80::2157:f17c:c3f:546 :::*                                0          15821      582/NetworkManager
      udp6       0      0 :::44614                :::*                                104        12602      491/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        12600      491/avahi-daemon: r
      2024-03-08 18:00:33.396  - error: zigbee.0 (880) Send command to 0x00124b0018d534f5 failed with no error code (undefined)
      2024-03-08 18:01:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
      2024-03-08 18:02:55.680  - info: fhem.0 (840) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
      2024-03-08 18:04:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
      2024-03-08 18:05:00.133  - info: javascript.0 (795) script.js.common.V1a_Beregnung: Nächste Beregnung Programm 1a aktualisiert auf: 03/09/2024 18:00
      2024-03-08 18:06:00.096  - info: host.raspberrypi instance system.adapter.solarmanpv.0 started with pid 1082
      2024-03-08 18:06:04.154  - info: solarmanpv.0 (1082) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.1, js-controller: 5.0.19
      2024-03-08 18:06:06.251  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.DEV_TYP1" has to be type "number" but received type "string"
      2024-03-08 18:06:06.339  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.COMM_PTC_v1" has to be type "string" but received type "number"
      2024-03-08 18:06:06.398  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.HWv1" has to be type "string" but received type "number"
      2024-03-08 18:06:06.933  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.NOP" has to be type "number" but received type "string"
      2024-03-08 18:06:07.622  - info: solarmanpv.0 (1082) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-03-08 18:06:08.190  - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-03-08 18:07:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
      2024-03-08 18:07:55.641  - info: fhem.0 (840) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
      2024-03-08 18:10:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
      2024-03-08 18:12:00.092  - info: host.raspberrypi instance system.adapter.solarmanpv.0 started with pid 1908
      2024-03-08 18:12:04.893  - info: solarmanpv.0 (1908) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.1, js-controller: 5.0.19
      2024-03-08 18:12:14.391  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.DEV_TYP1" has to be type "number" but received type "string"
      2024-03-08 18:12:14.500  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.COMM_PTC_v1" has to be type "string" but received type "number"
      2024-03-08 18:12:14.572  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.HWv1" has to be type "string" but received type "number"
      2024-03-08 18:12:15.297  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.NOP" has to be type "number" but received type "string"
      2024-03-08 18:12:16.099  - info: solarmanpv.0 (1908) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-03-08 18:12:16.702  - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        Thomas Braun Most Active @Stefan 3 last edited by
        @stefan-3
        1GB RAM ist auch deutlich zu wenig.
        Unter 4 macht es eigentlich kaum Sinn.
        MartinP S 2 Replies Last reply Reply Quote 0
        • MartinP
          MartinP @Thomas Braun last edited by
          @thomas-braun Wie schaut es eigentlich mit möglichst abgemagerten ioBroker Slaves aus? Wo ist da die untere sinnvolle RAM-Grenze?
          irgendein oller Pi, der über USB z. B. einen Smartmeter Lesekopf antreibt, und dieser wird in einen ioBroker Slave mit Smartmeter Adapter flugs an den Master ioBroker weitergeleitet?
            Thomas Braun Most Active @MartinP last edited by
            @martinp sagte in Zigbee Adapter Error Send Command failed with no error code:
            Da könntest du mit 1GB hinkommen. Aber da muss ja auch außer des etsprechenden Adapters auch nix mehr laufen, nichtmal ein admin. Hier ist aber ja auch deutlich mehr am Start, inkl. FHEM.
              Stefan 3 @Thomas Braun last edited by
              @thomas-braun Das Swap-File hat 2GB. Ergebnis:
              pi@raspberrypi:~ $ free -m
              Mem:             908         576          83           0         310         332
              Swap:           2147         467        1680
              Gut, ist nicht (mehr) die performanteste HW, aber muss ich Deiner Meinung nach nun echt eine neue HW kaufen? Das kann doch nicht Dein Ernst sein. Mal abgesehen davon glaub ich nicht dran, dass daher die Zigbee-Probleme herkommen.
                @stefan-3 sagte in Zigbee Adapter Error Send Command failed with no error code:
                Dann schlag dich weiter mit komischen Problemen herum. Jedenfalls ist 1GB für einen sinnvollen Betrieb mit einer handvoll Adapter zu wenig.
                S 1 Reply Last reply Reply Quote 2
                  @thomas-braun Sorry, wollte Dir nicht zu nahe treten. Zumindest testweise hab ich mal alle Adapter bis auf Zigbee deaktiviert > reboot > RAM Auslastung:
                  Mem:             908         458         258           1         249         449
                  Swap:           2147           0        2147
                  und dennoch, sobald ich die RGB brightness verändere, erhalte ich die Zigbee Fehlermeldung.
                  @arteck Hast Du (oder gerne auch jemand anderes) nicht noch eine Idee, wie ich den Fehler eingrenzen kann. Es sind ausschließlich alle (3 Stück bei mir) LED Dimmer vom Typ HOMA1001 betroffen, die bis ca. Jahreswechsel 2023/24 einwandfrei funktioniert hatten.
                  Zusatzinfo: Ein Original Netzteil hab ich inzwischen bestellt, da das frühere USB-Ladenetzteil tatsächlich eine gewisse Instabilität zur Folge hat, welche ich mit dem aktuellen Labornetzteil so nicht mehr sehe. Dass es aktuell also noch am Netzteil liegt schließe ich aus.
                    Stefan 3 @Stefan 3 last edited by
                    @arteck Hab inzwischen ein Original Raspi-Netzteil installiert. Das Verhalten bleibt jedoch unverändert (im Vergleich zu meinem Labornetzteil), d.h. Zigbee Fehler und einmalige undervoltage Meldung, sobald ich eine USB-Tastatur am Raspi anstecke, aber das schließe ich als Ursache für den Zigbee-Effekt aus.
                      mrjeschke @Stefan 3 last edited by
                      @stefan-3
                      Zum Thema zigbee hätte ich noch einen Schuß ins Blaue.
                      Ich hatte vor längerer Zeit (ca. 1Jahr) das Problem das bei meinen
                      Hue-Lampen an/aus und Helligkeit funkionierten, bei Änderungen
                      der Farbe kam es zum gleichen Fehler.
                      Ursache war bei mir der dp hue_calibration.
                      Nachdem ich den Inhalt des dp gelöscht habe, klappte es wieder.
                      Vieleicht hast du ja ein ähnliches Problem.
                        Stefan 3 @mrjeschke last edited by
                        @mrjeschke Ich gehe davon aus, dass du mit dp = Datenpunkt meinst. Der dp zum Setzen der Helligkeit nennt sich bei mir brightness_rgb.
                        Hiervon kann ich den Wert ändern. Der LED Stripe ändert dann seine Helligkeit nicht und ich bekomme eine Fehlermeldung im iob Log.
                        Zum Löschen des Inhalts des dp hab ich den dp brightness_rgb (und später auch alle anderen dp des Geräts) als JSON-Datei exportiert und dabei "Keine Zustandswerte exportieren" angewählt, dann den dp gelöscht und danach die JSON-Datei wieder importiert. Meinst du das mit "Inhalt des dp löschen"?
                        Dieses Löschen hat leider keinen Einfluss auf das HW-Verhalten.
                          Ich hab nun Folgendes gemacht:
                          • Pairing eines HOMA1001 Dimmers aufgehoben
                          • State Cleanup durchgeführt
                          • Restart Zigbee-Adapter
                          • HOMA1001 Dimmer neu gepaired -> klappt fehlerfrei
                          • Leider ist der Dimmer ohne jegliche Funktion. Einträge im Error Log:
                          • Dann den Dimmer bei "Ausschliessen" ergänzt.
                          • Leider gleiches Verhalten wie zuvor (keine Funktion und die gleichen Log Einträge).
                          • In der Datei /opt/iobroker/iobroker-data/zigbee_0/shepherd.db wird der Dimmer ganz richtig aufgenommen:
                          {"id":20,"type":"Router","ieeeAddr":"0x00124b0018d52b59","nwkAddr":40982,"manufId":0,"manufName":"ShenZhen_Homa","powerSource":"Mains (single phase)","modelId":"HOMA1001","epList":[10,11,13],"endpoints":{"10":{"profId":260,"epId":10,"devId":256,"inClusterList":[0,3,4,5,6,8],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genBasic":{"attributes":{"zclVersion":1}}},"binds":[],"configuredReportings":[],"meta":{}},"11":{"profId":49246,"epId":11,"devId":528,"inClusterList":[0,3,4,5,6,8,768],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"13":{"profId":49246,"epId":13,"devId":57694,"inClusterList":[4096],"outClusterList":[4096],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20131206","swBuildId":"1.0.2","zclVersion":1,"interviewCompleted":true,"meta":{},"lastSeen":1711647347498}
                          • In der Datei /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/shenzhen_homa.js wird der HOMA1001-Dimmer auch richtig beschrieben:
                          const definitions = [
                                  fingerprint: [
                                      { modelID: 'HOMA1001', endpoints: [
                                              { ID: 10, profileID: 49246, deviceID: 256, inputClusters: [0, 3, 4, 5, 6, 8], outputClusters: [] },
                                              { ID: 11, profileID: 49246, deviceID: 528, inputClusters: [0, 3, 4, 5, 6, 8, 768], outputClusters: [] },
                                              { ID: 13, profileID: 49246, deviceID: 57694, inputClusters: [4096], outputClusters: [4096] },
                                  model: 'HOMA1001_RGBW',
                                  vendor: 'Shenzhen Homa',
                                  description: 'Smart LED driver RGBW',
                                  extend: extend_1.default.light_onoff_brightness_color(),
                                  exposes: [e.light_brightness().withEndpoint('white'), e.light_brightness_colorxy().withEndpoint('rgb')],
                                  meta: { multiEndpoint: true },
                                  endpoint: (device) => {
                                      return { white: 10, rgb: 11 };
                                  fingerprint: [
                                  model: 'HOMA1001_RGB',
                                  description: 'Smart LED driver RGB',
                                  extend: [(0, modernExtend_1.light)({ color: true })],
                                  fingerprint: [
                                              { ID: 11, profileID: 49246, deviceID: 544, inputClusters: [0, 3, 4, 5, 6, 8, 768], outputClusters: [] },
                                  model: 'HOMA1001_CT',
                                  description: 'Smart LED driver CT',
                                  extend: [(0, modernExtend_1.light)()],
                                  fingerprint: [
                                              { ID: 11, profileID: 49246, deviceID: 256, inputClusters: [0, 3, 4, 5, 6, 8], outputClusters: [] },
                                  model: 'HOMA1001_SC',
                                  description: 'Smart LED driver SC',
                          Aus mir nicht nachvollziehbaren Gründen hat er nun gänzlich verlernt wie der HOMA1001 Dimmer anzusteuern ist 😞
                            arteck Developer Most Active @Stefan 3 last edited by arteck
                            @stefan-3 zeigmal die angelegten Datenpunkte..die nach dem pairing entstanden sind
                              @arteck Über Nacht hatte ich den Dimmer stromlos. Beim wieder anklemmen erhalte ich im Log eine "announced itself"-Meldung:
                              Hier die zugehörigen Datenpunkte:
                              Asgothian 2 Replies Last reply Reply Quote 0
                              • Asgothian
                                Asgothian Developer @Stefan 3 last edited by
                                @stefan-3 das ist normal. Das Netz merkt sich das es sich da um ein bekanntes Gerät handelt.
                                • Asgothian
                                  Die Tatsache das die datenpunkte die in deiner Fehlermeldung angeblich fehlen doch vorhanden sind deuten darauf hin das es einen Fehler im Zeitablauf des anlernen gibt - das anlernen und aufbauen der States dauert (bei deinem System) länger als der herdsman und das gerät erwarten - die 3 Fehlermeldungen beim Anlernen darfst du also ignorieren.
                                  Ansonsten stellt sich die Frage was an Meldungen kommt wenn du
                                  • 52b95 in den state zigbee.0.info.debugmessages einträgst
                                  • danach den device-query DP triggered
                                  • danach versuchst einzelne states zu ändern.
                                  Durch den Eintrag für die debug messages sollte jeder Versuch da was zu ändern bis zu 4 warn Meldungen mit dem Schlüsselwort Elevated im log erscheinen.
                                  A.
                                    Stefan 3 @Asgothian last edited by
                                    @asgothian Als Log-Antwort auf device-query erhält man:
                                    Und wenn man z.B. die Helligkeit der weißen LEDs ändert:
                                    Meines Erachtens alles ganz normal bis auf die Tatsache, dass er das states-mapping vergessen hat.
                                    Ich hab das Device daraufhin nochmal entkoppelt -> state cleanup -> restart Zigbee Adapter -> Pairing. Ergebnis unverändert das fehlende states-mapping:
                                    Auch danach ist das Verhalten bei state-Änderungen unverändert.
                                    • Asgothian
                                      Asgothian Developer @Stefan 3 last edited by Asgothian
                                      Du hast schon gelesen was ich oben geschrieben habe ? der Adapter hat nichts vergessen, die Meldung das das Gerät nicht im states mapping drin steht ist erst einmal ok - die States werden angelegt, also ist da alles ok. Wenn da wirklich ‘states vergessen’ wurden dann gäb es die Datenpunkte nicht.
                                      Bitte poste die logs als Text (in code Tags (</>)), mit den Screenshots kann ich nichts anfangen.
                                      A.
                                        @asgothian Vielen Dank für Deine Geduld und Unterstützung. Hier die Log-Antwort auf device-query:
                                        zigbee.0
                                        2024-04-01 17:41:04.022	warn	ELEVATED publishToState: message received '{}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:04.005	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:04.004	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.961	warn	Failed to read state '"power_on_behavior"'of '0x00124b0018d52b59' after query with '{"code":134}'
                                        zigbee.0
                                        2024-04-01 17:41:03.950	warn	ELEVATED publishToState: value generated '116' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.949	warn	ELEVATED publishToState: message received '{"linkquality":116}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.869	warn	Failed to read state '"color_mode"'of '0x00124b0018d52b59' after query with '{"code":134}'
                                        zigbee.0
                                        2024-04-01 17:41:03.855	warn	ELEVATED publishToState: message received '{"color_options":{"execute_if_off":false},"color_mode":"xy"}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.829	warn	ELEVATED publishToState: value generated '105' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.827	warn	ELEVATED publishToState: message received '{"linkquality":105}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.794	warn	Failed to read state '"color_options"'of '0x00124b0018d52b59' after query with '{"code":134}'
                                        zigbee.0
                                        2024-04-01 17:41:03.779	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.778	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.662	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.661	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.601	warn	ELEVATED publishToState: value generated '105' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.600	warn	ELEVATED publishToState: message received '{"linkquality":105}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.488	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.487	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.442	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.441	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.331	warn	ELEVATED publishToState: value generated '105' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.329	warn	ELEVATED publishToState: message received '{"linkquality":105}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.275	warn	ELEVATED publishToState: message received '{}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.243	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.242	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.206	warn	Failed to read state '"color"'of '0x00124b0018d52b59' after query with '{"code":134}'
                                        zigbee.0
                                        2024-04-01 17:41:03.133	warn	ELEVATED publishToState: value generated '30' from device 00124b0018d52b59 for 'Brightness white'
                                        zigbee.0
                                        2024-04-01 17:41:03.132	warn	ELEVATED publishToState: message received '{"brightness_white":76}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:03.100	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:03.099	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:02.975	warn	ELEVATED publishToState: value generated 'true' from device 00124b0018d52b59 for 'Switch state white'
                                        zigbee.0
                                        2024-04-01 17:41:02.973	warn	ELEVATED publishToState: message received '{"state_white":"ON"}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:02.923	warn	ELEVATED publishToState: value generated '109' from device 00124b0018d52b59 for 'Link quality'
                                        zigbee.0
                                        2024-04-01 17:41:02.922	warn	ELEVATED publishToState: message received '{"linkquality":109}' from device 00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:02.806	warn	ELEVATED Change state 'device_query' at device 0x00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:41:02.696	warn	ELEVATED: User stateChange zigbee.0.00124b0018d52b59.device_query {"val":true,"ack":false,"ts":1711986062690,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1711986015954}
                                        Wenn man die RGB-LED ausschaltet, geht die RGB-LED auch tatsächlich aus und folgender Log-Eintrag erscheint:
                                        zigbee.0
                                        2024-04-01 17:44:24.706	warn	ELEVATED Change state 'state_rgb' at device 0x00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:44:24.594	warn	ELEVATED: User stateChange zigbee.0.00124b0018d52b59.state_rgb {"val":false,"ack":false,"ts":1711986264588,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1711986264588}
                                        Beim Ändern der RGB-Helligkeit passiert jedoch keine HW-Änderung und im Log erscheint ein Error:
                                        zigbee.0
                                        2024-04-01 17:46:11.397	error	Send command to 0x00124b0018d52b59 failed with no error code (undefined)
                                        zigbee.0
                                        2024-04-01 17:46:11.365	warn	ELEVATED Change state 'brightness_rgb' at device 0x00124b0018d52b59 type 'HOMA1001_RGBW'
                                        zigbee.0
                                        2024-04-01 17:46:11.293	warn	ELEVATED: User stateChange zigbee.0.00124b0018d52b59.brightness_rgb {"val":40,"ack":false,"ts":1711986371287,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1711986371287}
                                        • Asgothian
                                          @stefan-3 es ist davon auszugehen dass das device eine falsche / beschädigte Firmware hat. Beim abfragen der verschiedenen states kommt als Antwort ‘134’, welches der Code für “Operation Not supported”, sprich die Firmware sagt das sie keine Farbe kann.
                                          Das deckt sich dann auch damit das sie nicht antwortet wenn versucht wird die Farbe anzupassen.
                                          A.
                                            @asgothian Die FW der Dimmer habe ich nie geändert. Zum Test hab ich den HOMA1001-Dimmer mal mit einer Philips Hue Bridge gepaired und da kann ich alles uneingeschränkt einstellen (RGB und weiß, Farbe, Helligkeit). Und bis etwa Januar 2024 hatten die 3 Exemplare des HOMA1001 Dimmers ja auch noch uneingeschränkt mit dem Sonoff Zigbee USB-Stick zusammengespielt.
                                            3964
