    4. Javascript Adapter 7.8.0 stuerzt ab
      Thomas Braun Most Active @Hawkiobroker 0 last edited by
      @hawkiobroker-0 sagte in Javascript Adapter 7.8.0 stuerzt ab:
      Log-Ausschitt mitgeliefert
      Was ist das für ein Log?
      Und als Screenshot kann man damit auch nix anfangen.
        Hawkiobroker 0 @DJMarc75 last edited by
        @djmarc75 hier ist das Log aus iobroker und der output aus iob diag. Beides habe ich erstellt nach einem iobroker Neustart (davor javascript instance ausgeschaltet) und danach javascript Instanz wieder aktiviert.
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Hardware Vendor : Synology
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.1
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         20:22:29 up 2 days,  6:03,  0 user,  load average: 3.04, 1.87, 1.65
        CPU threads: 4
        *** Time and Time Zones ***
        Mon Mar 11 19:22:29 UTC 2024
        Mon Mar 11 20:22:29 CET 2024
        CET +0100
        Etc/UTC
        *** User and Groups ***
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             16G        8.8G        1.8G        151M        6.6G        7.9G
        Swap:            12G        351M         11G
        Total:           28G        9.1G         13G
                15854 M total memory
                 8359 M used memory
                 9125 M active memory
                 3649 M inactive memory
                 1681 M free memory
                   39 M buffer memory
                 6246 M swap cache
                11563 M total swap
                  334 M used swap
                11229 M free swap
        *** FILESYSTEM ***
        Filesystem             Type   Size  Used Avail Use% Mounted on
        /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /
        tmpfs                  tmpfs   64M     0   64M   0% /dev
        tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
        shm                    tmpfs   64M     0   64M   0% /dev/shm
        /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /opt/iobroker
        /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /etc/hosts
        sudo: unable to resolve host iobrokerSchozach01: Name or service not known
        [Sat Mar  9 14:19:51 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
        [Sat Mar  9 14:19:51 2024] EXT4-fs (md0): mounted filesystem with ordered data m
        [Sat Mar  9 14:19:53 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
        [Sat Mar  9 14:19:53 2024] EXT4-fs (md0): mounted filesystem with ordered data m
        [Sat Mar  9 14:19:53 2024] EXT4-fs (loop0): couldn't mount as ext3 due to featur
        [Sat Mar  9 14:19:53 2024] EXT4-fs (loop0): mounted filesystem with ordered data
        [Sat Mar  9 14:19:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
        [Sat Mar  9 14:19:57 2024] EXT4-fs (md0): mounted filesystem with ordered data m
        [Sat Mar  9 14:19:58 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
        [Sat Mar  9 14:19:58 2024] EXT4-fs (md0): mounted filesystem with ordered data m
        [Sat Mar  9 14:20:25 2024] EXT4-fs (loop0): mounted filesystem with ordered data
        TARGET             SOURCE
        IONS
        /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/7fc7ee
        nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,s
        606484219300d6f0f94a804c3a4ccf9de8fa57950133361b70e104e
        |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobrokerSchozach01]
        |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
        0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/resolv.conf
        |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
        0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/hostname
        `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
        0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/hosts
        /var:
        34M     /var/
        32M     /var/lib
        19M     /var/lib/apt/lists
        19M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        14G     /opt/iobroker/backups/
        0       /opt/iobroker/backups/redistmp
        /opt/iobroker/iobroker-data:
        16G     /opt/iobroker/iobroker-data/
        15G     /opt/iobroker/iobroker-data/history
        295M    /opt/iobroker/iobroker-data/files
        97M     /opt/iobroker/iobroker-data/backup-objects
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        130M    /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.m
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 1001
               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 P
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobrokerScho
        n as: admin
        + system.adapter.backitup.0               : backitup              : iobrokerScho
        + system.adapter.bydhvs.0                 : bydhvs                : iobrokerScho
        + system.adapter.daikin.1                 : daikin                : iobrokerScho
        + system.adapter.daikin.2                 : daikin                : iobrokerScho
        + system.adapter.daikin.3                 : daikin                : iobrokerScho
          system.adapter.daswetter.1              : daswetter             : iobrokerScho
          system.adapter.discovery.0              : discovery             : iobrokerScho
          system.adapter.echarts.0                : echarts               : iobrokerScho
        + system.adapter.email.0                  : email                 : iobrokerScho
          system.adapter.flot.0                   : flot                  : iobrokerScho
          system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobrokerScho
        + system.adapter.fronius.0                : fronius               : iobrokerScho
          system.adapter.gruenbeck.0              : gruenbeck             : iobrokerScho
        + system.adapter.history.0                : history               : iobrokerScho
        + system.adapter.hmip.0                   : hmip                  : iobrokerScho
          system.adapter.javascript.0             : javascript            : iobrokerScho
          system.adapter.javascript.1             : javascript            : iobrokerScho
        + system.adapter.modbus.0                 : modbus                : iobrokerScho
        + system.adapter.modbus.1                 : modbus                : iobrokerScho
        + system.adapter.modbus.2                 : modbus                : iobrokerScho
          system.adapter.modbus.3                 : modbus                : iobrokerScho
        + system.adapter.modbus.4                 : modbus                : iobrokerScho
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobrokerScho
          system.adapter.parser.0                 : parser                : iobrokerScho
          system.adapter.porsche.0                : porsche               : iobrokerScho
          system.adapter.pvforecast.0             : pvforecast            : iobrokerScho
        + system.adapter.sonoff.0                 : sonoff                : iobrokerScho
          system.adapter.statistics.0             : statistics            : iobrokerScho
          system.adapter.weatherunderground.0     : weatherunderground    : iobrokerScho
        + system.adapter.web.0                    : web                   : iobrokerScho
        iobrokerhawk
          system.adapter.wmswebcontrol.0          : wmswebcontrol         : iobrokerScho
        + instance is alive
        n as: admin
        iobrokerhawk
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "email"        : 1.2.2    , installed 1.2.2
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
        Adapter    "hmip"         : 1.22.0   , installed 1.22.0
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "parser"       : 2.1.0    , installed 2.1.0
        Adapter    "porsche"      : 0.0.3    , installed 0.2.0
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "wmswebcontrol": 0.0.5    , installed 0.0.5
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Objects and States
        Objects:        16479
        States:         13775
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address           Foreign Address         State
        tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN
        tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
        tcp        0      0 192.168.178.5:49160     0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:9900            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:9901            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
        tcp        0      0 192.168.178.5:50001     0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN
        tcp        0      0 192.168.178.5:49170     0.0.0.0:*               LISTEN
        tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN
        tcp        0      0 127.0.0.1:33300         0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:725             0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN
        tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN
        tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:6012            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:6013            0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
        tcp        0      0 0.0.0.0:6014            0.0.0.0:*               LISTEN
        tcp6       0      0 :::3264                 :::*                    LISTEN
        tcp6       0      0 :::3265                 :::*                    LISTEN
        tcp6       0      0 :::6690                 :::*                    LISTEN
        tcp6       0      0 :::5000                 :::*                    LISTEN
        tcp6       0      0 :::5001                 :::*                    LISTEN
        tcp6       0      0 :::139                  :::*                    LISTEN
        tcp6       0      0 :::9900                 :::*                    LISTEN
        tcp6       0      0 :::9901                 :::*                    LISTEN
        tcp6       0      0 :::5357                 :::*                    LISTEN
        tcp6       0      0 :::1935                 :::*                    LISTEN
        tcp6       0      0 :::80                   :::*                    LISTEN
        tcp6       0      0 :::8081                 :::*                    LISTEN
        tcp6       0      0 :::5201                 :::*                    LISTEN
        tcp6       0      0 :::8082                 :::*                    LISTEN
        tcp6       0      0 :::725                  :::*                    LISTEN
        tcp6       0      0 :::443                  :::*                    LISTEN
        tcp6       0      0 :::3261                 :::*                    LISTEN
        tcp6       0      0 :::445                  :::*                    LISTEN
        tcp6       0      0 :::3263                 :::*                    LISTEN
        udp        0      0 0.0.0.0:35136           0.0.0.0:*
        udp        0      0 127.0.0.1:60185         0.0.0.0:*
        udp        0      0 0.0.0.0:19996           0.0.0.0:*
        udp        0      0 0.0.0.0:19997           0.0.0.0:*
        udp        0      0 0.0.0.0:19998           0.0.0.0:*
        udp        0      0 0.0.0.0:3702            0.0.0.0:*
        udp        0      0 0.0.0.0:5353            0.0.0.0:*
        udp        0      0 192.168.178.5:55900     0.0.0.0:*
        udp        0      0 192.168.178.5:55901     0.0.0.0:*
        udp        0      0 192.168.178.5:55902     0.0.0.0:*
        udp        0      0 127.0.0.1:47750         0.0.0.0:*
        udp        0      0 172.17.0.1:123          0.0.0.0:*
        udp        0      0 192.168.178.10:123      0.0.0.0:*
        udp        0      0 192.168.178.5:123       0.0.0.0:*
        udp        0      0 127.0.0.1:123           0.0.0.0:*
        udp        0      0 0.0.0.0:123             0.0.0.0:*
        udp        0      0 192.168.178.255:137     0.0.0.0:*
        udp        0      0 192.168.178.5:137       0.0.0.0:*
        udp        0      0 192.168.178.10:137      0.0.0.0:*
        udp        0      0 0.0.0.0:137             0.0.0.0:*
        udp        0      0 192.168.178.255:138     0.0.0.0:*
        udp        0      0 192.168.178.5:138       0.0.0.0:*
        udp        0      0 192.168.178.10:138      0.0.0.0:*
        udp        0      0 0.0.0.0:138             0.0.0.0:*
        udp        0      0 127.0.0.1:161           0.0.0.0:*
        udp        0      0 127.0.0.1:58098         0.0.0.0:*
        udp        0      0 0.0.0.0:59087           0.0.0.0:*
        udp        0      0 0.0.0.0:9997            0.0.0.0:*
        udp        0      0 0.0.0.0:9998            0.0.0.0:*
        udp        0      0 0.0.0.0:9999            0.0.0.0:*
        udp        0      0 0.0.0.0:1900            0.0.0.0:*
        udp6       0      0 :::3702                 :::*
        udp6       0      0 :::5353                 :::*
        udp6       0      0 :::38969                :::*
        udp6       0      0 2003:c9:6f14:6200:2:123 :::*
        udp6       0      0 fe80::6006:26ff:fea:123 :::*
        udp6       0      0 fe80::48d5:c1ff:fec:123 :::*
        udp6       0      0 fe80::10c3:75ff:fe5:123 :::*
        udp6       0      0 fe80::42:97ff:fe5f::123 :::*
        udp6       0      0 fe80::211:32ff:fea6:123 :::*
        udp6       0      0 ::1:123                 :::*
        udp6       0      0 :::123                  :::*
        2024-03-11 20:23:25.222  - silly: javascript.0 (1530) writeFile(filename: "node_
        2024-03-11 20:23:25.222  - silly: javascript.0 (1530)   creating new file with v
        2024-03-11 20:23:25.240  - silly: javascript.0 (1530) writeFile(filename: "node_
        true
        2024-03-11 20:23:25.241  - silly: javascript.0 (1530)   creating new file with v
        2024-03-11 20:23:25.241  - silly: javascript.0 (1530) writeFile(filename: "node_
        e
        2024-03-11 20:23:25.245  - debug: javascript.0 (1530) Loaded TypeScript definiti
        types/request/index.d.ts"]
        2024-03-11 20:23:25.245  - silly: javascript.0 (1530) writeFile(filename: "node_
        2024-03-11 20:23:25.245  - silly: javascript.0 (1530)   creating new file with v
        2024-03-11 20:23:25.246  - silly: javascript.0 (1530) writeFile(filename: "node_
        2024-03-11 20:23:25.246  - silly: javascript.0 (1530)   creating new file with v
        2024-03-11 20:23:25.247  - silly: javascript.0 (1530) writeFile(filename: "node_
        2024-03-11 20:23:25.247  - silly: javascript.0 (1530)   creating new file with v
        2024-03-11 20:23:25.301  - silly: javascript.0 (1530) redis psubscribe cfg.o.*
        2024-03-11 20:23:25.306  - silly: javascript.0 (1530) States system redis pmessa
        :{"val":"silly","ack":true,"ts":1710185005251,"q":0,"from":"system.adapter.javas
        2024-03-11 20:23:25.410  - info: javascript.0 (1530) requesting all states
        2024-03-11 20:23:25.411  - info: javascript.0 (1530) requesting all objects
        2024-03-11 20:23:49.823  - silly: javascript.0 (1530) Objects user redis pmessag
        mmon":{"name":"Plugin States"},"native":{},"_id":"system.host.iobrokerSchozach01
        em.user.admin","ownerGroup":"system.group.administrator"}}
        2024-03-11 20:23:49.825  - silly: javascript.0 (1530) Objects user redis pmessag
        te","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":tru
        sentry.enabled","acl":{"object":1636,"state":1636,"file":1632,"owner":"system.us
          Hawkiobroker 0 @Hawkiobroker 0 last edited by
          @hawkiobroker-0 und hier der iobroker log Auszug von javascript nach Aktivierung.
          240311 iobroker javascript log.txt
          Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
            @hawkiobroker-0
            2024-03-11 20:41:05.745	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
            Da dürfte ein Skript schief sein.
            • DJMarc75
              DJMarc75 @Hawkiobroker 0 last edited by
              @hawkiobroker-0
              die ganzen SILLY musste mal weg machen, das macht Dein System platt.
              Stell das bitte auf mindestens INFO um 😉
                Hawkiobroker 0 @Thomas Braun last edited by
                @thomas-braun Danke! Warum habe ich Probleme, wenn ich alle Skripte deaktiviert habe?
                  @hawkiobroker-0
                  Die skripte werden beim Start des Adapters kompiliert. Wird da schon hängen.
                    @djmarc75 Danke! Erledigt!
                      @thomas-braun ok. D.h., alle "neuen" Skripte loeschen?
                        @hawkiobroker-0
                        Kannst du ja weg kopieren.
                          @thomas-braun ist das so richtig eingestellt?
                            @thomas-braun gibt es eine Moeglichkeit zu sehen, welches Skript das Problem verursacht? Besten Dank!
                              @hawkiobroker-0
                              Da bin ich überfragt. Vielleicht @paul53 mal fragen. 🙂
                                @thomas-braun said in Javascript Adapter 7.8.0 stuerzt ab:
                                @hawkiobroker-0
                                @paul53 Kannst Du bei meinem Problem helfen? Vielen Dank im Voraus!
                                  Wildbill @Hawkiobroker 0 last edited by
                                  Alle Skripte anhalten. Dann mal 50% davon starten. Tritt der Fehler auf, davon wieder die Hälfte anhalten und beobachten. Tritt der Fehler nicht auf, liegt er in einem der angehaltenen Skripte, dann eben davon mal 50% starten und beobachten.
                                  Beliebt sind Fehler in Verbindung mit Timeout- und Intervall-Blöcken. Nach denen kannst Du im JS-Editor mal gezielt suchen und schauen, ob da alles passt. Wenn da Timeouts nicht sauber beendet oder immer wieder neu zusätzlich gestartet werden, baut sich das auf, frisst RAM und führt letztendlich irgendwann zum Ende, da der Speicher ausgeht.
                                  Gruss, Jürgen
                                    Hawkiobroker 0 @Wildbill last edited by
                                    @wildbill der Fehler tritt immer auf, auch wenn alle Skripte angehalten sind. Ich bin da als Nicht-Experte ratlos. Hast Du noch eine Idee?
                                      @hawkiobroker-0 Wenn alle Skripte stehen, dann liegt es wohl nicht an einem Skript. Zur Sicherheit mal bei allen angehaltenen Skripten einen reboot machen, die Skripte nicht starten und dann mal beobachten. Nicht dass da im Hintergrund noch was läuft.
                                      Gruss, Jürgen
                                        @wildbill nochmals Danke! Auch das habe ich schon ausprobiert.
                                        Alle Skripte angehalten und iobroker und den Server neu gestartet.
                                          Habe nun alle Skripte geloescht und javascript Adapter deinstalliert. iobroker neu gestartet. Danach den javascript adapter wieder instaliert.
                                          => Das Problem besteht weiterhin.
                                          Good ideas welcome!
                                            knopers1 @Hawkiobroker 0 last edited by
                                            muss das Thema nach oben setzen....
                                            Javascript 7.8.0 läuft bei mir, allerdings stürzt der Adapter nach dem Update auf die 7.9.0
                                            Jemand Probleme noch außer mir?
                                            Thomas Braun sigi234 H haus-automatisierung C 5 Replies Last reply Reply Quote 0
                                            2560
