    4. Bose Soundtouch steuern
    • N
      Nanouk last edited by
      Schau mal auf Deinem Screenshot unter den Preset Ordnern.
      Da steht "key"
      Den Datenpunkt musst Du auswählen.
      Über vis nun mit einem widget den entsprechenden Preset Wert schreiben.
      Probier mal das widget:
      [{"tpl":"tplJquiRadioList","data":{"oid":"bosesoundtouch.0.key","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"PRESET_1","texts":"Preset 1","signals-cond-0":"consist","signals-val-0":"","signals-icon-0":"","signals-icon-size-0":"76","signals-blink-0":true,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"not consist","signals-val-1":"radioffh","signals-icon-1":"/vis/img/radiobuttons/ffh.jpg","signals-icon-size-1":"75","signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"signals-oid-0":"","signals-oid-1":"javascript.0.RadioURL","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"629px","top":"245px","border-width":"","width":"76px","height":"76px","z-index":"4"},"widgetSet":"jqui"}]
      Der vis Button ist jetzt nur quick'n'dirty, aber funktionieren sollte er.
      Nanouk
      PS:
      Die Punkte in den Preset Ordnern helfen Dir evtl. beim optischen Gestalten in vis.
      Für die Funktion "Preset 1" abspielen sind sie aber nicht nötig.
      Das wird über den Wert in "key" gesteuert.
        apollon77 last edited by
        @SwedishChef. Schon das neue Bose-Developer Portalund das letzte API update gesten?
        API kann jetzt bei Lifestyles auch die echten EIngänge Switchen. UND es gibt eine "Audio Notification API" wo man Notofy-Sounds (custom mp3-File/Stream oder so) angeben kann und "Texte" das wird dann abgespielt und danach der normale stream fortgesetzt …
        Welcome "sayit" in besser als Sonos ;-))
        • SwedishChef
          SwedishChef last edited by
          @apollon77:
          @SwedishChef. Schon das neue Bose-Developer Portalund das letzte API update gesten? `
          Ja, hab mir das Portal und die neue Doku kurz angesehen. Leider komme ich aktuell nicht dazu, den Adapter zu erweitern. Meine ersten Versuche, ein Play-everywhere zu realisieren, scheiterten am Zusammensammeln der jeweiligen states - alles asynchron 😞
          Wie kann ich mehrere states abfragen, die Ergebnisse sammeln und - wenn alles beisammen ist - eine Aktion starten? Die einzelnen Instanzen bekomme ich mit getObjectView(), aber der Rest ist mühsam… Und wie gesagt, es fehlt aktuell ein wenig die Zeit. In den Weihnachtsferien gehts hoffentlich weiter.
            Solche "schleifen" kann man asynchron grob (pseudocode) so machen:
            Am besten ein Array definieren mit dem was man abfragen will.
            function doIt(thingsToDoArray, callback) {
            -> Wenn thingsToDoArray.length === 0 dann callback() und return
            -> mit thingsToDoArray.shift das erste Array-Element holen, rest-Array wird automatisch verkürzt
            -> Array element verarbeiten, ggf asynchron und für nächsten Schritt wieder "doIt(thingsToDoArray, callback)" aufrufen
            und ausserhalb rufst Du einmal doIt(thingsToDoArray,callBackFunctionFürNachEnde) auf
            Damit wird die "doIt" so lange aufgerufen bis dann abzuarbeitende Array leer ist und danach wird die "callBackFunctionFürNachEnde" aufgerufen.
            Die Ergebnisse kann man in einer globalen Variable ablegen oder schiebst noch ein arameter durch der dann am Ende ans das callback übergeben wird.
            • SwedishChef
              Danke, das werde ich demnächst probieren. Vielleicht gibt es ja eine erste Version für play-everywhere als Weihnachtsgeschenk 😉
              Gesendet von meinem A0001 mit Tapatalk
                Falls das oben zu abstrakt war kann ich gern mal ein echtes Code-beispiel raussuchen 🙂
                • SwedishChef
                  Hallo Leute.
                  Es gibt zwei neue Versionen auf Github:
                  • 0.0.10 - erster Versuch von multi-room (zone) playEverywhere
                  [https://github.com/SwedishChef1/iobroke … ball/zones](https://github.com/SwedishChef1/iobroker.bosesoundtouch/tarball/zones)
                  Einfach den Status 'playEverywhere' im Master-Adapter auf TRUE setzen
                  • 0.1.1 - now playing: neuer Status 'art' (URL zum aktuellen Song/Album/Radiosender-Bild, falls vorhanden)
                    https://github.com/SwedishChef1/iobroke … all/master
                  Sobald playEverywhere grob funktioniert (bitte um euer Feedback, ich konnte das mit nur einer Box nicht wirklich testen), werde ich das auf 'master' mergen.
                  • N
                    Hallo und schönen 3 Advent euch allen.
                    Wie kann ich die playEverywhere Version installieren?
                    Ich bekomme immer 404 Fehler.
                    Wie muss der Link aussehen um es im Admin zu installieren?
                    Grüße,
                    Nanouk
                    • SwedishChef
                      Hallo Nanouk,
                      Sorry, ich hab die links einfach aus dem Browser kopiert. Sind in meinem vorigen Post korrigiert.
                        Wann stellst DU den Adapter den mal auf npm und ins ioBroker repo? Also für "latest" ist er allemal stabil genug!! das macht dann einiges einfacher
                        • SwedishChef
                          @apollon77:
                          Wann stellst DU den Adapter den mal auf npm und ins ioBroker repo? Also für "latest" ist er allemal stabil genug!! das macht dann einiges einfacher `
                          Was ist hier zu tun? Brauche hier Unterstützung, soll ja auch das repo laut einem GitHub issue auf ioBroker.bosesoundtouch (großes B) umbenennen. Möchte nichts kaputt machen…
                            Ok,
                            1.) Umbenennen: alles committen, lokal löschen, bei Github umbenennen, neu lokal auschecken
                            2.) npm … https://docs.npmjs.com/getting-started/ ... m-packages
                            3.) Repo: https://github.com/ioBroker/ioBroker.re ... positories
                            das github ioBroker.repositories forken auf Github, auschecken, Deinen Adapter eintragen (nimm einen der anderen als Blaupause), alphabetisch einsortieren und am besten erstmal nur ins "Latest" file. Dann Pull-Request stellen.
                            Vorher checke nochmal deine io-package.json (Authors sollte korrekt gefüllt sein) und package.json das da alles passt.
                            Und (falls nicht gemacht) Testing travis-ci.org/appveyor bei dir aktivieren
                              Ansonsten noch eine Idee: Macht es sinn die "presets" regelmäßig neu einzulesen? Einmal am Tag oder so?
                              Ich habe gestern bei mir was geändert und ioBroker kennt immer noch die Alten infos … Klar Adapter-Restart löst es, aber vllt so ein "Einmal am Tag" (oder in h konfigurierbar) wäre vllt sinnvoll.
                              Ingo
                                der_Auge last edited by
                                erst einmal ein Dank an den Entwickler und die Unterstützer.
                                Habe mir den Adapter auch über Github installiert.
                                Folgendes steht im LOG:
                                ! 2017-12-18 07:21:01.699 - [32minfo[39m: iobroker url "https://github.com/SwedishChef1/iobroke … all/master" --debug
                                ! 2017-12-18 07:21:02.412 - [32minfo[39m: iobroker install https://github.com/SwedishChef1/iobroke ... all/master
                                ! 2017-12-18 07:21:02.626 - [32minfo[39m: iobroker npm install https://github.com/SwedishChef1/iobroke ... all/master --production --prefix "/opt/iobroker" (System call)
                                ! 2017-12-18 07:21:36.255 - [32minfo[39m: iobroker npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                                ! npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
                                ! npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                                ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                                ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                                ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                                ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
                                ! npm WARN addRemoteGit git://github.com/noopkat/browser-serialport.git#api-updates resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3 because of error: { Error: not found: git
                                ! npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                                ! 2017-12-18 07:21:36.268 - [32minfo[39m: iobroker at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                                ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
                                ! npm WARN addRemoteGit Error: not found: git
                                ! npm WARN addRemoteGit git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47 because of error: { Error: not found: git
                                ! 2017-12-18 07:21:36.299 - [32minfo[39m: iobroker npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
                                ! 2017-12-18 07:21:36.349 - [32minfo[39m: iobroker npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefined
                                ! 2017-12-18 07:22:00.040 - [32minfo[39m: host.NUC instance system.adapter.dwd.0 started with pid 21593
                                ! 2017-12-18 07:22:01.713 - [32minfo[39m: dwd.0 starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.dwd, node: v6.12.0
                                ! 2017-12-18 07:22:02.853 - [32minfo[39m: host.NUC instance system.adapter.dwd.0 terminated with code 0 (OK)
                                ! 2017-12-18 07:22:04.552 - [32minfo[39m: iobroker > usb@1.3.1 install /opt/iobroker/node_modules/usb
                                ! > node-pre-gyp install --fallback-to-build
                                ! 2017-12-18 07:22:06.288 - [32minfo[39m: iobroker node-pre-gyp
                                ! 2017-12-18 07:22:06.289 - [32minfo[39m: iobroker
                                ! 2017-12-18 07:22:06.293 - [32minfo[39m: iobroker ERR! Tried to download(404): https://github.com/tessel/node-usb/rele ... x64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@6.12.0 (node-v48 ABI, glibc) (falling back to source compile with node-gyp)
                                ! 2017-12-18 07:22:08.628 - [32minfo[39m: iobroker make: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird betreten
                                ! 2017-12-18 07:22:08.631 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/core.o
                                ! 2017-12-18 07:22:09.380 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
                                ! 2017-12-18 07:22:10.033 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
                                ! 2017-12-18 07:22:10.286 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/io.o
                                ! 2017-12-18 07:22:10.944 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
                                ! 2017-12-18 07:22:11.093 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
                                ! 2017-12-18 07:22:11.308 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
                                ! 2017-12-18 07:22:11.439 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
                                ! 2017-12-18 07:22:11.546 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
                                ! 2017-12-18 07:22:12.938 - [32minfo[39m: iobroker CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
                                ! 2017-12-18 07:22:13.031 - [32minfo[39m: iobroker ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefundencompilation terminated.
                                ! 2017-12-18 07:22:13.037 - [32minfo[39m: iobroker libusb.target.mk:133: die Regel für Ziel „Release/obj.target/libusb/libusb/libusb/os/linux_udev.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird verlassen
                                ! make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Fehler 1
                                ! 2017-12-18 07:22:13.042 - [32minfo[39m: iobroker gyp
                                ! 2017-12-18 07:22:13.046 - [32minfo[39m: iobroker ERR! build error
                                ! 2017-12-18 07:22:13.052 - [32minfo[39m: iobroker gyp
                                ! 2017-12-18 07:22:13.053 - [32minfo[39m: iobroker ERR! stack
                                ! 2017-12-18 07:22:13.056 - [32minfo[39m: iobroker Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                ! gyp ERR! stack at emitTwo (events.js:106:13)
                                ! 2017-12-18 07:22:13.057 - [32minfo[39m: iobroker gyp ERR! stack
                                ! 2017-12-18 07:22:13.058 - [32minfo[39m: iobroker at ChildProcess.emit (events.js:191:7)gyp
                                ! 2017-12-18 07:22:13.059 - [32minfo[39m: iobroker ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                                ! 2017-12-18 07:22:13.064 - [32minfo[39m: iobroker gyp ERR! System Linux 4.4.0-101-genericgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "–fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"
                                ! gyp ERR! cwd /opt/iobroker/node_modules/usb
                                ! 2017-12-18 07:22:13.069 - [32minfo[39m: iobroker gyp ERR! node -v v6.12.0gyp ERR! node-gyp -v v3.4.0
                                ! gyp ERR! not ok
                                ! 2017-12-18 07:22:13.085 - [32minfo[39m: iobroker node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
                                ! node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                ! node-pre-gyp ERR! stack at emitTwo (events.js:106:13)
                                ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                                ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:920:16)
                                ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                                ! node-pre-gyp ERR! System Linux 4.4.0-101-generic
                                ! node-pre-gyp
                                ! 2017-12-18 07:22:13.092 - [32minfo[39m: iobroker ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                ! 2017-12-18 07:22:13.096 - [32minfo[39m: iobroker node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usbnode-pre-gyp ERR! node -v v6.12.0
                                ! node-pre-gyp ERR! node-pre-gyp -v v0.6.39
                                ! node-pre-gyp ERR! not ok
                                ! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
                                ! 2017-12-18 07:22:13.135 - [32minfo[39m: iobroker > mdns@2.3.4 install /opt/iobroker/node_modules/mdns
                                ! > node-gyp rebuild
                                ! 2017-12-18 07:22:14.595 - [32minfo[39m: iobroker make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird betreten
                                ! 2017-12-18 07:22:14.606 - [32minfo[39m: iobroker CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
                                ! 2017-12-18 07:22:14.852 - [32minfo[39m: iobroker In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                                ! compilation terminated.
                                ! 2017-12-18 07:22:14.855 - [32minfo[39m: iobroker dns_sd_bindings.target.mk:152: die Regel für Ziel „Release/obj.target/dns_sd_bindings/src/dns_sd.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird verlassen
                                ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                                ! 2017-12-18 07:22:14.863 - [32minfo[39m: iobroker gyp
                                ! 2017-12-18 07:22:14.866 - [32minfo[39m: iobroker ERR! build error
                                ! 2017-12-18 07:22:14.878 - [32minfo[39m: iobroker gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack
                                ! 2017-12-18 07:22:14.885 - [32minfo[39m: iobroker at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:106:13)
                                ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                                ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                                ! gyp ERR! System Linux 4.4.0-101-generic
                                ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                ! gyp ERR! cwd /opt/iobroker/node_modules/mdns
                                ! gyp ERR! node -v v6.12.0
                                ! gyp ERR! node-gyp -v v3.4.0
                                ! gyp ERR! not ok
                                ! > serialport@4.0.7 install /opt/iobroker/node_modules/serialport
                                ! > node-pre-gyp install –fallback-to-build
                                ! 2017-12-18 07:22:18.445 - [32minfo[39m: iobroker [serialport] Success: "/opt/iobroker/node_modules/serialport/build/Release/serialport.node" is installed via remote
                                ! 2017-12-18 07:22:30.111 - [32minfo[39m: iobroker iobroker.core@1.0.0 /opt/iobroker├── async@2.6.0 extraneous
                                ! ├── awty@0.1.0 extraneous
                                ! ├── chip.avr.avr109@1.1.0 extraneous
                                ! ├── colors@1.1.2 extraneous
                                ! ├─┬ iobroker.bosesoundtouch@0.1.0
                                ! │ ├── es6-promise@4.1.1
                                ! │ ├── string-format@0.5.0
                                ! │ ├─┬ ws@3.3.3
                                ! │ │ ├── async-limiter@1.0.0
                                ! │ │ └── ultron@1.1.1
                                ! │ └─┬ xml2js@0.4.19
                                ! │ ├── sax@1.2.4
                                ! │ └── xmlbuilder@9.0.4
                                ! ├── serialport@4.0.7 extraneous
                                ! └── stk500-v2@1.0.2 extraneous
                                ! 2017-12-18 07:22:30.118 - [32minfo[39m: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules/avrgirl-arduino/node_modules/browser-serialport):
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules/avrgirl-arduino/node_modules/stk500):
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install –fallback-to-build
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.4 (node_modules/mdns):
                                ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.4 install: node-gyp rebuild
                                ! 2017-12-18 07:22:30.226 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin
                                ! 2017-12-18 07:22:30.264 - [32minfo[39m: iobroker upload [2] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/words.js words.js application/javascript
                                ! 2017-12-18 07:22:30.341 - [32minfo[39m: iobroker upload [1] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/index.html index.html text/html
                                ! 2017-12-18 07:22:30.418 - [32minfo[39m: iobroker upload [0] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/bosesoundtouch.png bosesoundtouch.png image/png
                                ! 2017-12-18 07:22:30.533 - [32minfo[39m: iobroker exit 0
                                ! 2017-12-18 07:22:31.035 - [32minfo[39m: host.NUC Update repository "online" under "https://raw.githubusercontent.com/ioBro … -dist.json"[/spoiler]</anonymous>
                                Nach der Installation sind mir noch ein paar Kleinigkeiten aufgefallen.
                                Adapter-Seite:
                                • es fehle das kleine und das große Bild bei MousOver
                                • in der Beschreibung steht noch die Infos aus der Vorlage (Template)
                                Ansonsten bin ich Begeistert.
                                Nun werde ich einen weiteren Nutzer von ioBroker überzeugen können
                                Frage: Zum umschalten unter Objekte -> presents > key die Zahl 1 oder 2 oder…. eintragen?
                                Jürgen
                                  Master77 last edited by
                                  Hi
                                  Als Datenpunkt musst du Key auswählen und als Wert im Widget dann PRESET_1 beispielsweise eintragen.
                                  Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
                                    Alle aktuell möglichen "Key"-Werte sind auf der Github REDME.md aufgelistet
                                      @apollon77:
                                      Alle aktuell möglichen "Key"-Werte sind auf der Github REDME.md aufgelistet `
                                      Super
                                      nun habe ich es gefunden
                                      key
                                      One of the following keys to send:
                                      PLAY
                                      PAUSE
                                      STOP
                                      PREV_TRACK
                                      NEXT_TRACK
                                      THUMBS_UP
                                      THUMBS_DOWN
                                      BOOKMARK
                                      POWER
                                      MUTE
                                      VOLUME_UP
                                      VOLUME_DOWN
                                      PRESET_1
                                      PRESET_2
                                      PRESET_3
                                      PRESET_4
                                      PRESET_5
                                      PRESET_6
                                      AUX_INPUT
                                      SHUFFLE_OFF
                                      SHUFFLE_ON
                                      REPEAT_OFF
                                      REPEAT_ONE
                                      REPEAT_ALL
                                      PLAY_PAUSE
                                      ADD_FAVORITE
                                      REMOVE_FAVORITE
                                      INVALID_KEY
                                        kekel last edited by
                                        ich muss jetzt unbedingt ein ganz großes Lob an alle Beteiligten aussprechen.
                                        Ich hatte gestern den Gedanken, dass es doch schön wäre wenn meine Soundtouch-Geräte aufs Wort gehorchen würden … und stelle fest, Super, das gibt es ja schon.
                                        Danke!
                                        Besonders faszinierend finde ich die zukünftige Möglichkeit von PlayEverywhere (MultiRoom). Ganz hervorragend wäre es, wenn man dabei noch Gruppen bilden könnte.
                                        Frei nach dem Motto "Alle" ... also wirklich alle oder z.B "Wohnzimmer" ... also nur die Geräte im Wohnzimmer.
                                        Ich wünsche euch schöne und geruhsame Feiertage.
                                          @SwedishChef: siehe Github Pull-Request: Damit tut Testing dann. Musst nur noch im package.json den Author korrigieren 😉
                                          Und sobald Du es auch npm hast kann ich auch Discovery Adapter releasen wo das Soundtouch Erkennung drin ist
                                            Super Sache
                                            mein Zwischenstand im VIS
                                            nun müsste ich die Tasten (die über dem Bild liegen) noch transparent werden. :?:
                                            Jürgen
                                            286
                                            65311
