    2. English
    3. Scripting / Logic
    4. JavaScript
    5. [Question] restart causes empty values are written
    • BananaJoe
      BananaJoe Most Active last edited by
      i edit my post
        europe @BananaJoe last edited by europe
        @bananajoe Thanks... with empty entries I meant null values
        Once without Ack once with.
        I just want to understand it before commenting that part out...
        • BananaJoe
          You have a function haupt.
          Your function will started via scheduled timers and different parameter - ok.
          But in your function Haupt you also have an on Trigger-reaction in line 44
          So everytime (!) your function is called, a new(!) trigger instance is added. for cronH 24 on a day. If the value change, all 24 instances of the trigger will start. so the script will cause a slow death of the system ...
          so move the on part to a separete section an be sure it will be called only once.
          i did not now if this is the problem, but it is a problem
            europe last edited by
            @bananajoe ok, I'm completely stuck here now. I have like 10 of these crons running and the system is up and running sine more than 100 days on a simple TV box. So it might be a problem, but it didn't kill me yet...
            I just start the script once. If I modify it, I stop it and then start it again. You say while its running is it basically forking all the time?!
            Do you have a link to some basics that I can educate myself on this matter?
            "move the on part to a separate section", I have not the faintest clue how to implement that. Is there maybe a general function which implements what I want? A cron.tab like behaviour?
            BananaJoe Asgothian 2 Replies Last reply Reply Quote 0
            • BananaJoe
              BananaJoe Most Active @europe last edited by
              @europe sagte in [Question] restart causes empty values are written:
              if you stop the script, all "childs / sub-instances" are also stopped.
              separte section: remove the on expression from the function and create this for every datapoint separate.
              i am sorry, but i know no learning sites for this in english.
                @bananajoe okay, thanks, a link to a german one is fine as well 🙂
                Do you know a better script which implements this kind of cron tab like behaviour?
                • BananaJoe
                  @europe you could just use the "SourceAnalytix" Adapter. This Adapter will create all data you want with your script i think
                  I learned JavaScript / JavaScript with ioBroker/nodeJS and Blocky by 1.001 Websites and Examples from this forum.
                  I am sorry, but do not have "this one" site for learning this.
                  There are many videos on youtube for different themes (trigger, crontabs)
                  You don`t do it the wrong way. you wrote a script, you have problems and ask here. same as i do at the beginning.
                  • Asgothian
                    Asgothian Developer @europe last edited by
                    Actually, in your case the ’on’ construct is ok - due to the fast that once triggar is activated you unsubscribe from the triggar (line 46 in your code)
                    This does not get us closer to the null values, but explains why all is running fine.
                    • BananaJoe
                      @Asgothian
                      unsubscribe
                      damned, i missed the unsubscribe, so after the on is created it will immediately destroyed?
                      • Asgothian
                        Asgothian Developer @BananaJoe last edited by
                        @bananajoe sagte in [Question] restart causes empty values are written:
                        @Asgothian
                        unsubscribe
                        The first time the trigger fires, yes.
                          europe @Asgothian last edited by
                          @asgothian
                          Okay, I just found the history adapter writes null at start and stop. I deactivated that.
                          I still had all those null entries though, which messed up with certain plotting routines.
                          I also wrote a script which goes through all objects (incl. 3 level of nesting according to the doc) and removes items in a certain timeframe of 1 minute.
                          Here's the code:
                          // 21-10-2024. Works perfectly!!
                          // To see log entries, set log level of javascript instance to silly
                          var startTimestamp = new Date('2023-12-14T09:40:00.000');
                          var endTimestamp = new Date(startTimestamp.getTime() + 1*60000);
                          //log(startTimestamp.toISOString())
                          //log(endTimestamp.toISOString())
                          $('0_userdata.0.Haus.*').each(function(id) {
                              //log(id.toString())
                          //var currentElement = $(this);
                             //console.log(currentElement);
                            sendTo('history.0', 'deleteRange', [{ id: id.toString(), start: startTimestamp, end: endTimestamp }]);
                          javascript
                          973
