Blocky variable
Im Moment mach ich es auf diese Weise wie im Code zu sehen. Dafür habe ich unter enum die variablen angelegt.
Momentan versuche ich aber noch rauszufinden ob "state" oder "nummer" für mich besser funktioniert.
! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
! <block type="comment" id="dSPKkOyhX}?G~[J2mE2]" x="-1112" y="-788"><field name="COMMENT">MODE_OFF = 0</field>
! <next><block type="comment" id="0S0Djo%,r7#k#X5l0HDx"><field name="COMMENT">MODE_STANDBY = 1</field>
! <next><block type="comment" id="pLA/1T=%jR7=^DFLstDJ"><field name="COMMENT">MODE_ACTIVE = 2</field>
! <next><block type="comment" id="9d(yu6o[H2Q418yB_I06"><field name="COMMENT">MODE_FINISHED = 3</field>
! <next><block type="on_ext" id=":sAVuX[w}R/PP[=SJUT2"><mutation items="1"></mutation>
! <field name="CONDITION">any</field>
! <value name="OID0"><shadow type="field_oid" id="!]M!#3VKGcI3W;k9+9DP"><field name="oid">default</field></shadow>
! <block type="field_oid" id="j/|i)|3M(,}FC%D;l=b+"><field name="oid">fritzdect.0.DECT200_087610322462.power</field></block></value>
! <statement name="STATEMENT"><block type="controls_if" id="t}E2eO70~q;%8]7nvhq/"><mutation elseif="2"></mutation>
! <value name="IF0"><block type="logic_compare" id="7zF5#!E,7f3w@}U~?YMi"><field name="OP">LT</field>
! <value name="A"><block type="get_value" id=":@3z=%Ry8X+=Q61lYCz}"><field name="ATTR">val</field>
! <field name="OID">fritzdect.0.DECT200_087610322462.power</field></block></value>
! <value name="B"><block type="math_number" id="TR|e:8:CS1q,tr([3V#"><field name="NUM">0.4</field></block></value></block></value>
! <statement name="DO0"><block type="update" id="+WIg0(Gfx6tzU=V^umAS"><mutation delay_input="false"></mutation>
! <field name="OID">enum.variables.waschmaschine_op.state</field>
! <field name="WITH_DELAY">FALSE</field>
! <value name="VALUE"><block type="math_number" id="MUNN3sf/Gz!N:8/AfiLA"><field name="NUM">0</field></block></value>
! <next><block type="control" id="[]{76vXag]HR3Q@iYTi/"><mutation delay_input="false"></mutation>
! <field name="OID">enum.variables.waschmaschine_op.number</field>
! <value name="VALUE"><block type="math_number" id="[EE.b7Hi8tc|baG6PI."><field name="NUM">0</field></block></value> ! <next><block type="comment" id="8{wRH2_LR;FE-?p5e-cJ"><field name="COMMENT">Mode Off</field></block></next></block></next></block></statement> ! <value name="IF1"><block type="logic_compare" id="5IA9)|M?W;pHnu/Y?(vn"><field name="OP">GT</field> ! <value name="A"><block type="get_value" id="9WqzmQ;x?k[?mNFN3d"><field name="ATTR">val</field>
! <value name="B"><block type="math_number" id="Y~3KYaH|091xFsC6zoR"><field name="NUM">4.5</field></block></value></block></value>
! <statement name="DO1"><block type="update" id="sN|K6jYB6u]/)J#3O,34"><mutation delay_input="false"></mutation>
! <value name="VALUE"><block type="math_number" id="PKCq3pIqe:JdUXF4@FsK"><field name="NUM">2</field></block></value>
! <next><block type="control" id="zLuQ1~SzhN1i[nR}m-2Q"><mutation delay_input="false"></mutation>
! <value name="VALUE"><block type="math_number" id="=Qjt9Qqf~mS:8wk(iU.V"><field name="NUM">2</field></block></value>
! <next><block type="comment" id="{d8S;K6ICF?Je:sn+{Zl"><field name="COMMENT">Mode Active</field></block></next></block></next></block></statement>
! <value name="IF2"><block type="logic_compare" id="=c|A#3Oi!P0Ge^3ApMb6"><field name="OP">LT</field>
! <value name="A"><block type="get_value" id="9F/03XdLM^Zw(CpclOqj"><field name="ATTR">val</field>
! <value name="B"><block type="math_number" id="K1LE4SSO|glxOI}vPm+p"><field name="NUM">1.5</field></block></value></block></value>
! <statement name="DO2"><block type="controls_if" id="G,F-R%qcd^Vq;bx;1_3|"><mutation elseif="1"></mutation>
! <value name="IF0"><block type="logic_compare" id="=kDan7Ln)9vw~7Mu-NQ^"><field name="OP">EQ</field>
! <value name="A"><block type="get_value" id="ynt@[YBT3f|Xi.jRwp2"><field name="ATTR">val</field>
! <field name="OID">enum.variables.waschmaschine_op.state</field></block></value>
! <value name="B"><block type="math_number" id=":A^VDVi:tB]gqWb:ud{I"><field name="NUM">0</field></block></value></block></value>
! <statement name="DO0"><block type="update" id="+{;s{i.N3~C[7}Hs.?1"><mutation delay_input="false"></mutation> ! <field name="OID">enum.variables.waschmaschine_op.state</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="math_number" id="0wcd~9j-{U!50L1/W!b*"><field name="NUM">1</field></block></value> ! <next><block type="control" id="{xEX=qRT9ZvVL5W,a31R"><mutation delay_input="false"></mutation> ! <field name="OID">enum.variables.waschmaschine_op.number</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="math_number" id="z1]yqC^jxy;:Lfma4{lh"><field name="NUM">1</field></block></value> ! <next><block type="comment" id="8-)uyIeko_2M5KNc!esi"><field name="COMMENT">Mode Standby</field></block></next></block></next></block></statement> ! <value name="IF1"><block type="logic_compare" id="z^n*.sK4S9wlmjoyS]/k"><field name="OP">EQ</field> ! <value name="A"><block type="get_value" id="2@%fd*xOjAOG4NkbB/Gb"><field name="ATTR">val</field> ! <field name="OID">enum.variables.waschmaschine_op.state</field></block></value> ! <value name="B"><block type="math_number" id="wDYmioBTedF|c76.+I3t"><field name="NUM">1</field> ! <comment pinned="false" h="80" w="160">Mode Active</comment></block></value></block></value> ! <statement name="DO1"><block type="timeouts_settimeout" id="/=^2CceB!FZr=5PA6Lr"><field name="NAME">timeout</field>
! <field name="DELAY">10</field>
! <field name="UNIT">sec</field>
! <statement name="STATEMENT"><block type="controls_if" id="#hH2Di[K~CM(]u~A!8B."><value name="IF0"><block type="logic_compare" id="XN6{]Tmi{3,VC}mh4]G"><field name="OP">LT</field> ! <value name="A"><block type="get_value" id=":7i[1HVgfeB;[ob6G].g"><field name="ATTR">val</field> ! <field name="OID">fritzdect.0.DECT200_087610322462.power</field></block></value> ! <value name="B"><block type="math_number" id="NDw_^~E3Dnkn)ZoA?6Cs"><field name="NUM">1.5</field></block></value></block></value> ! <statement name="DO0"><block type="update" id="pyk*G.5@g?Ou)Ir%@apQ"><mutation delay_input="false"></mutation> ! <field name="OID">enum.variables.waschmaschine_op.state</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="math_number" id="SJhyy6*u_{1VYlD/UP|["><field name="NUM">3</field></block></value> ! <next><block type="control" id="q,p-%[o@1Jy9p]6U#s_"><mutation delay_input="false"></mutation>
! <value name="VALUE"><block type="math_number" id="=5w~t)+JV4xOE{DRA_nO"><field name="NUM">3</field></block></value>
! <next><block type="comment" id="0TgNhvF+-Veuy,HeIj4e"><field name="COMMENT">Mode Finish</field></block></next></block></next></block></statement></block></statement>
! <next><block type="timeouts_cleartimeout" id="Byr}O[P;2=ZhEYvr_k2H"><field name="NAME">timeout</field></block></next></block></statement></block></statement></block></statement></block></next></block></next></block></next></block></next></block>
! <block type="variables_set" id="=15IclI=P@lPxd26.pD" x="-437" y="-763"><field name="VAR">Light_ON</field>
! <value name="VALUE"><block type="math_number" id="sBKZm:SPObJMIUUV}nQS"><field name="NUM">254</field></block></value>
! <next><block type="variables_set" id="orP.=7Kv|CN~!V6ZrZx"><field name="VAR">Light_OFF</field>
! <value name="VALUE"><block type="math_number" id="H9QkV|Ug23Z2zkvS}n@h"><field name="NUM">0</field></block></value>
! <next><block type="variables_set" id="zToY@;-rR0G9Uxv#2rT^"><field name="VAR">RED</field>
! <value name="VALUE"><block type="math_number" id="VMmAf]Hz|OM/V{d4EmG"><field name="NUM">65338</field></block></value>
! <next><block type="variables_set" id="W0DR5=ov,?q2t-iK^M9"><field name="VAR">GREEN</field>
! <value name="VALUE"><block type="math_number" id="%RD6_1h;9mX1vDcPy2#E"><field name="NUM">22568</field></block></value>
! <next><block type="on_ext" id="P7/EY_dv(nXovf:L:3Z"><mutation items="1"></mutation>
! <value name="OID0"><shadow type="field_oid" id="}#[nVyp;4@jPMBH+%hx"><field name="oid">default</field></shadow>
! <block type="field_oid" id="3l.@,?db)[9h?^LG4j3z"><field name="oid">enum.variables.waschmaschine_op.state</field></block></value>
! <statement name="STATEMENT"><block type="controls_if" id="C;OINX!bjjd/Xs8C==3T"><value name="IF0"><block type="logic_compare" id="5zEz}QR6KIF39aBQbf4"><field name="OP">EQ</field>
! <value name="A"><block type="get_value" id="+5eb3_E,6l=2fIA)Z@5O"><field name="ATTR">val</field>
! <value name="B"><block type="math_number" id="!SGF4FmqsRp3Kf0,!m~)"><field name="NUM">3</field></block></value></block></value>
! <statement name="DO0"><block type="timeouts_settimeout" id="odd2)dLJ?EbP:5ySSjIk"><field name="NAME">timeout2</field>
! <field name="DELAY">60</field>
! <statement name="STATEMENT"><block type="timeouts_setinterval" id=".9b9Rs+2dDbTjDJB#U]C"><field name="NAME">interval</field>
! <field name="INTERVAL">120</field>
! <statement name="STATEMENT"><block type="control" id="u^6zMrmEci/(N4Y5,U@"><mutation delay_input="false"></mutation> ! <field name="OID">hue.0.Philips_hue.BueroHueStripeRGB.hue</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="variables_get" id="yqL09;[,K)u.tHmFy*_X"><field name="VAR">RED</field></block></value> ! <next><block type="control" id="[Eu{OccL!Ls~dKx:^e"><mutation delay_input="false"></mutation>
! <field name="OID">hue.0.Philips_hue.BueroHueStripeRGB.bri</field>
! <value name="VALUE"><block type="variables_get" id="CYc.?u%rEskT9,zK`i=9"><field name="VAR">Light_ON</field></block></value>
! <next><block type="control" id="HQ32t;s,||B@W}]uTNw)"><mutation delay_input="true"></mutation>
! <field name="WITH_DELAY">TRUE</field>
! <field name="DELAY_MS">10</field>
! <field name="CLEAR_RUNNING">FALSE</field>
! <value name="VALUE"><block type="variables_get" id="BvBn-8QJ;o2B847Npq^?"><field name="VAR">Light_OFF</field></block></value></block></next></block></next></block></statement></block></statement>
! <next><block type="timeouts_cleartimeout" id=",-mK,]C@7]LY!X{Yy~e}"><field name="NAME">timeout2</field></block></next></block></statement></block></statement></block></next></block></next></block></next></block></next></block></xml>Der code ist jedoch noch nicht getestet… ich warte auf den nächsten Waschdurchgang
, ja man könnte das mit anderen Verbrauchern simulieren...aber dazu fehlt mir die Zeit -
, ja man könnte das mit anderen Verbrauchern simulieren...aber dazu fehlt mir die Zeit `
Dann starte es bitte nicht.Dein Intervall von 120 Sek. wird NIE gestoppt.
Wobei Deine Timeouts ja auch NIE ausgeführt werden.
Von daher wird auch der Intervall nie gestartet
Grüße `
so und jetzt brauch ich deine Hilfe…wo liegt der Fehler ? bzw wie könnte es richtig aussehen ? -
so und jetzt brauch ich deine Hilfe…wo liegt der Fehler ? bzw wie könnte es richtig aussehen ? `
Zum "umbauen" fehlt mir gerade die Zeit. Eventuell Später.Zu Timeout:
1.
Ein Timeout macht KEINE Programmpause. Die Aktionen in dem Timeout werden nur später ausgeführt.
Das Script führt den nächsten Baustein direkt danach aus.
Wird ein Timer gestoppt, werden die Aktionen in dem Timer NICHT ausgeführt.
Kommst Du schon jetzt drauf
Du startest einen Timer und direkt danach stoppst Du ihn wieder.
Wenn Du verhindern willst, dass ein Timer mehrfach gestartet wird, musst Du VOR dem Timer das Stop setzen.
Das Stoppen eines Timers der noch nicht aktiv ist, macht keinen Fehler.
2. Intervall
Ein einmal gestarteter Intervall wird IMMER ausgeführt, so lange das Script läuft.
Bei Dir würde bis in alle Ewigkeit alle 120 Sek. die LED angehen.
Um das zu verhindern gibt des den "stop zyklische Ausführung"
danke…. ganz hab ich es nicht verstanden, aber ich denke ich konnte eben den ersten Teil auflösen.
Den zweiten Teil setz ich einfach mit einer bestimmten anzahl an blinken um und dies sollte ja nur der fall sein wenn der Waschmaschine_op.state = 3 ist .
Den zweiten Teil setz ich einfach mit einer bestimmten anzahl an blinken um und dies sollte ja nur der fall sein wenn der Waschmaschine_op.state = 3 ist . `
Schon etwas besser.Nur das "Blinken" wirst Du wohl nicht wahrnehmen. 10x 1ms, da flackert es noch nicht mal.
Und die Aktoren werden das wohl auch nicht mitmachen.
[EDIT] Was hast Du denn nicht verstanden?
danke für deine Hilfe.
Mir fehlt noch das Verständnis für die Timeouts und den reset für die Timeouts. Verstanden habe ich das alles so lange innerhalb des Timeouts ausgeführt wird, bis die Zeit abgelaufen ist, und danach außerhalb vom Timeout weiter gemacht wird.
Zum Blicken, das sollte schon passen, das Einschalten wird kurz verzügert im ms bereich und dann kommt nach 1s der Ausschaltbefehl.
Mir fehlt noch das Verständnis für die Timeouts und den reset für die Timeouts. Verstanden habe ich das alles so lange innerhalb des Timeouts ausgeführt wird, bis die Zeit abgelaufen ist, und danach außerhalb vom Timeout weiter gemacht wird. `
So ist es eben nicht."Timeout in 1 Minute" bedeutet, dass die Befehle in dem Timeout NACH 1 Minute ausgeführt werden.
Ein Timeout kann mehrmals ausgeführt werden.
Jedes mal wenn ein Timeout gestartet wird, wird ein kleines "Unterprogramm" generiert, das nach der angegebenen Zeit abläuft.
Wenn ein Timeout, während er noch aktiv ist, 2x, 5x oder 5000x aufgerufen wird, gibt es eben 2,5 oder 5000 "Unterprogramme".
Und JEDES "Unterprogramm" wird dann auch abgearbeitet.
Mit einem VORHERIGEN "Stop Timeout" kann man das verhindern.
ok, ist dann mein Verständnis im Bezug auf das Bild richtig ?
Die 1 im Bild ist der Trigger für den Timeout
Die 2 ist der Code welcher durch den Timeout verzögert ausgeführt wird (wie eine Pause/wait)
Das Fragezeichen, ist meine noch immer unklarheit, wo müsste der clear timeout sitzen um den Code innerhalb vom Timeout nur einmal auszuführen ? vor dem Update "Waschmaschine_opState" ?
Sorry, aber liest Du auch was ich schreibe?
@booehmemaik:Die 1 im Bild ist der Trigger für den Timeout `
Das ist KEIN Trigger, sondern eine Bedingungsabfrage.Die 2 ist der Code welcher durch den Timeout verzögert ausgeführt wird (wie eine Pause/wait) `
Es gibt keine Pause/wait !!!!!!Zu Timeout:
1.
Wird ein Timer gestoppt, werden die Aktionen in dem Timer NICHT ausgeführt. `
Das Fragezeichen, ist meine noch immer unklarheit, wo müsste der clear timeout sitzen um den Code innerhalb vom Timeout nur einmal auszuführen ? vor dem Update "Waschmaschine_opState" ? `
Das Stoppen eines Timers der noch nicht aktiv ist, macht keinen Fehler. `
vielleicht liegt mein Verständnis problem darin, das ich einfach meine Regel nicht zum laufen bekomme und ich somit noch kein funktionierentes Beispiel gesehen habe.
vielleicht liegt mein Verständnis problem darin, das ich einfach meine Regel nicht zum laufen bekomme und ich somit noch kein funktionierentes Beispiel gesehen habe. `
Was ist den an dem Wort "VOR" so schwer zu verstehen? :roll:
Was ist den an dem Wort "VOR" so schwer zu verstehen? :roll:Beispiel.png `
daran nix… ich seh das nur im ganzen mit dem rest der regel. -
Habe gerade mal kurz drüber geschaut.
Tausche mal Deine "aktualisiere" Bausteine mit "steuere".
Und setze auch mal den "Debug" Baustein ein. Damit kannst Du den Ablauf kontrollieren.
Und setze auch mal den "Debug" Baustein ein. Damit kannst Du den Ablauf kontrollieren. `
ich hatte inzwischen "aktualisiere" und "steuere" schon eingebaut , einfach um zu sehen welche den State mir wirklich liefert.
Funktioniert auch beides…., debug werd ich noch einbauen.
! <value name="OID0"><shadow type="field_oid" id="v!+{Y#3p8koW_FgRiI6"><field name="oid">default</field></shadow>
! <field name="OID">javascript.0.waschmaschine_op.state</field>
! <field name="OID">javascript.0.scriptEnabled.global.2a_Wasch,aschine_OpNumber_new</field>
! <value name="VALUE"><block type="math_number" id="[EE.b7Hi8tc|baG6PI."><field name="NUM">0</field></block></value> ! <next><block type="comment" id="8{wRH2_LR;FE-?p5e-cJ"><field name="COMMENT">Mode Off</field> ! <next><block type="debug" id="},#H]%N1_lXvE(gp0*0e"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="3YWGLJ]h,P6J]@FI31N/"><field name="TEXT">Mode off</field></shadow></value></block></next></block></next></block></next></block></statement> ! <value name="IF1"><block type="logic_compare" id="5IA9)|M?W;pHnu/Y?(vn"><field name="OP">GT</field> ! <value name="A"><block type="get_value" id="9WqzmQ;x?k[?mNFN3d"><field name="ATTR">val</field>
! <next><block type="debug" id="wpKndF*i{uKM%K1oe^^"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id=":}{!K9X;!o2v_mD8]bp"><field name="TEXT">Mode active</field></shadow></value></block></next></block></next></block></next></block></statement>
! <field name="OID">javascript.0.waschmaschine_op.state</field></block></value>
! <statement name="DO0"><block type="update" id="+{;s{i.N3~C[7}Hs.?1"><mutation delay_input="false"></mutation> ! <field name="OID">javascript.0.waschmaschine_op.state</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="math_number" id="0wcd~9j-{U!50L1/W!b*"><field name="NUM">1</field></block></value> ! <next><block type="control" id="{xEX=qRT9ZvVL5W,a31R"><mutation delay_input="false"></mutation> ! <field name="OID">javascript.0.scriptEnabled.global.2a_Wasch,aschine_OpNumber_new</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="math_number" id="z1]yqC^jxy;:Lfma4{lh"><field name="NUM">1</field></block></value> ! <next><block type="comment" id="8-)uyIeko_2M5KNc!esi"><field name="COMMENT">Mode Standby</field> ! <next><block type="debug" id="j#Gofrw_7UD-Bo+%LA:q"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="X[Rxq4=tHecmfR+XWMG8"><field name="TEXT">Mode standby</field></shadow></value></block></next></block></next></block></next></block></statement> ! <value name="IF1"><block type="logic_compare" id="z^n*.sK4S9wlmjoyS]/k"><field name="OP">EQ</field> ! <value name="A"><block type="get_value" id="2@%fd*xOjAOG4NkbB/Gb"><field name="ATTR">val</field> ! <field name="OID">javascript.0.waschmaschine_op.state</field></block></value> ! <value name="B"><block type="math_number" id="wDYmioBTedF|c76.+I3t"><field name="NUM">1</field> ! <comment pinned="false" h="80" w="160">Mode Active</comment></block></value></block></value> ! <statement name="DO1"><block type="controls_if" id="#hH2Di[K~CM(]u~A!8B."><value name="IF0"><block type="logic_compare" id="XN6{]Tmi{3,VC}mh4]G"><field name="OP">LT</field>
! <statement name="DO0"><block type="update" id="pykG.5@g?Ou)Ir%@apQ"><mutation delay_input="false"></mutation>
! <value name="VALUE"><block type="math_number" id="SJhyy6u_{1VYlD/UP|["><field name="NUM">3</field></block></value>
! <next><block type="control" id="q,p-%[o@1Jy9p]6U#s_"><mutation delay_input="false"></mutation> ! <field name="OID">javascript.0.scriptEnabled.global.2a_Wasch,aschine_OpNumber_new</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="math_number" id="=5w~t)+JV4xOE{DRA_nO"><field name="NUM">3</field></block></value> ! <next><block type="comment" id="0TgNhvF+-Veuy,HeIj4e"><field name="COMMENT">Mode Finish</field> ! <next><block type="debug" id=":T?5M|Q!pn@n,R)y953i"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="Qp0R|]z{id,-Q20[A4-"><field name="TEXT">Mode finished check 2</field></shadow></value>
! <next><block type="controls_if" id="3A_(#Qm.ZuYYN@y@.5RK"><value name="IF0"><block type="logic_compare" id="LSkN)~vW#hc)Gc|R;#S"><field name="OP">LT</field>
! <value name="A"><block type="get_value" id="6}.qPR2fC{|gM-(c|rem"><field name="ATTR">val</field>
! <value name="B"><block type="math_number" id="gqB.YDSR(GVs%77uE7Eu"><field name="NUM">1.5</field></block></value></block></value>
! <statement name="DO0"><block type="timeouts_settimeout" id="/=^2CceB!FZr=5PA6Lr"><field name="NAME">timeout</field> ! <field name="DELAY">120</field> ! <field name="UNIT">sec</field> ! <statement name="STATEMENT"><block type="comment" id="jD)j(Jj*6TSQGoNmvxvL"><field name="COMMENT">checke again before setting to 3 (finished)</field> ! <next><block type="debug" id="-ibtS=Az#uwAI[|0D.r0"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="_)C96:eU!J0%CBLaF].K"><field name="TEXT">Mode finished check 1</field></shadow></value></block></next></block></statement></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement></block></statement></block></statement></block></statement></block></next></block></next></block></next></block></next></block> ! <block type="variables_set" id="=15IclI=P@_lPxd26.pD" x="-437" y="-763"><field name="VAR">Light_ON</field> ! <value name="VALUE"><block type="math_number" id="sBKZm:SPObJMIUUV}nQS"><field name="NUM">254</field></block></value> ! <next><block type="variables_set" id="orP.=7Kv|CN~!V6ZrZx_"><field name="VAR">Light_OFF</field> ! <value name="VALUE"><block type="math_number" id="H9QkV|Ug23Z2zkvS}n@h"><field name="NUM">0</field></block></value> ! <next><block type="variables_set" id="zToY@;-rR0G9Uxv#2rT^"><field name="VAR">RED</field> ! <value name="VALUE"><block type="math_number" id="VMmAf]Hz|OM/V{d4E*mG"><field name="NUM">65338</field></block></value> ! <next><block type="variables_set" id="W0DR5=o*v,?q2t-iK^M9"><field name="VAR">GREEN</field> ! <value name="VALUE"><block type="math_number" id="%RD6_1h;9mX1vDcPy2#E"><field name="NUM">22568</field></block></value> ! <next><block type="on_ext" id="P7/EY_dv(nXovf:L:3*Z"><mutation items="1"></mutation> ! <field name="CONDITION">any</field> ! <value name="OID0"><shadow type="field_oid" id="lNnipdtFnT9LmUm)-1su"><field name="oid">default</field></shadow> ! <block type="field_oid" id="3l.@,?db)[9h?^LG4j3z"><field name="oid">javascript.0.waschmaschine_op.state</field></block></value> ! <statement name="STATEMENT"><block type="controls_if" id="C;OINX!bjjd/Xs8C==3T"><value name="IF0"><block type="logic_compare" id="5zEz}Q*R6KIF39aBQbf4"><field name="OP">EQ</field> ! <value name="A"><block type="get_value" id="+5eb3_E,6l=2fIA)Z@5O"><field name="ATTR">val</field> ! <field name="OID">javascript.0.waschmaschine_op.state</field></block></value> ! <value name="B"><block type="math_number" id="!SGF4FmqsRp3Kf0,!m~)"><field name="NUM">3</field></block></value></block></value> ! <statement name="DO0"><block type="controls_repeat_ext" id="c0uk,,hP~wq@OOqoK0ia"><value name="TIMES"><shadow type="math_number" id="vdPlQdck4V9V(nTlGOo"><field name="NUM">10</field></shadow></value>
! <statement name="DO"><block type="control" id="u^6zMrmEci/(N4Y5,U@"><mutation delay_input="false"></mutation> ! <field name="OID">hue.0.Philips_hue.BueroHueStripeRGB.hue</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="variables_get" id="yqL09;[,K)u.tHmFy*_X"><field name="VAR">RED</field></block></value> ! <next><block type="control" id="[Eu{OccL!Ls~dKx:^e"><mutation delay_input="true"></mutation>
! <field name="DELAY_MS">500</field>
! <field name="UNIT">ms</field>
! <field name="DELAY_MS">1</field>
! <next><block type="email" id="h?-f~!mQ}+I3=??qruJ9"><field name="INSTANCE">.0</field>
! <field name="IS_HTML">FALSE</field>
! <field name="LOG">log</field>
! <value name="TO</field></shadow></value>
! <value name="TEXT"><shadow type="text" id=".QCu]jvy~6#dTiJ]FP|W"></shadow></value>
! <value name="SUBJECT"><shadow type="text" id="TG%{4k;~DE0O{n^/r11"><field name="TEXT">Waschmaschine Fertig</field></shadow></value></block></next></block></statement></block></statement></block></next></block></next></block></next></block></next></block></xml> -
Nun, Probelauf kannst nur Du machen.
"steuere" ist sicherer als "aktualisiere".
Der "Stop" ist immer noch an der falschen Stelle.
Und Dein Problem passt nicht mehr zum Thema "Blockly variable".
