    4. ioBroker Admin-GUI lässt sich nicht mehr öffnen
      Thomas Braun Most Active @danielos last edited by
      @danielos
      sudo apt update
      sudo apt upgrade
        danielos @Thomas Braun last edited by
        @thomas-braun Gemacht und dann wieder stop / fix ... Resultat leider immer noch unverändert, wie es scheint.
        			v.2023-10-10
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.4.79-v7l+
              Architecture: arm
        Installation: 		native
        Kernel: 		armv7l
        Userland: 		armhf
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        X-Server: 		false
        Boot Target: 		graphical.target
        Pending OS-Updates: 	0
        node:internal/modules/cjs/loader:1137
          throw err;
        Error: Cannot find module 'graceful-fs'
        Require stack:
        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/fs/index.js
        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/index.js
        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
            at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
            at Module._load (node:internal/modules/cjs/loader:975:27)
            at Module.require (node:internal/modules/cjs/loader:1225:19)
            at require (node:internal/modules/helpers:177:18)
            at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/fs/index.js:5:12)
            at Module._compile (node:internal/modules/cjs/loader:1356:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            at Module.load (node:internal/modules/cjs/loader:1197:32)
            at Module._load (node:internal/modules/cjs/loader:1013:12)
            at Module.require (node:internal/modules/cjs/loader:1225:19) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/fs/index.js',
            '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/index.js',
            '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
            '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        Node.js v18.19.1
        Pending iob updates: 	0
        This system needs to be REBOOTED NOW!
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
        			/usr/bin/node 		v18.19.1
        			/usr/bin/npm 		10.2.4
        			/usr/bin/npx 		10.2.4
        			/usr/bin/corepack 	0.22.0
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:           3.8G        174M        2.9G         80M        780M        3.4G
        Swap:           99M          0B         99M
        Total:         3.9G        174M        3.0G
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        Active iob-Instances: 	0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        ioBroker Core: 		js-controller
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        			admin
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        ioBroker Status:
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        Objects: 		0
        States: 		0
        Size of iob-Database:
        23M	/opt/iobroker/iobroker-data/objects.jsonl
        16M	/opt/iobroker/iobroker-data/objects.json.migrated
        16M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
        6.6M	/opt/iobroker/iobroker-data/states.jsonl
        4.4M	/opt/iobroker/iobroker-data/states.json.migrated
        4.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
        0	/opt/iobroker/iobroker-data/states.json.broken
          @danielos sagte in ioBroker Admin-GUI lässt sich nicht mehr öffnen:
          Bitte auch mal lesen was das Tool dir sagt.
            @thomas-braun Ja, wirklich übersehen. Geändert hat sich aber auch nach einem Neustart leider nichts. Alle pakete scheinen nun aktuell zu sein aber einfach das graceful-fs wird noch immer vermisst.
              @danielos
              Versuche
              iob stop
              sudo -H -u iobroker npm cache clean --force
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
              iob start
                Das ist nicht richtig. Dein Betriebssystem ist jetzt auf dem letzten Stand.
                Abgekündigt ist es aber immer noch.
                  @thomas-braun Ja, das stimmt natürlich. Ich meinte mehr die Fehlermeldung ist noch identisch. Die Befehle habe ich ausgeführt...und juhuu, es scheint wieder zu klappen. Das admin-Update läuft zwar immer noch nicht durch wenn ich's klicke, aber das Interface ist mal wieder aufrufbar. Danke vielmals für deine Geduld und deine Unterstützung. Sehr geschätzt!!
                    Homoran Global Moderator Administrators @danielos last edited by
                    @danielos und welche Bedingungen für das Update erfüllen deine veralteten Versionen nicht?
                      danielos @Homoran last edited by
                      Gute Frage...
                      Would you like to upgrade admin from @6.2.23 to @6.13.16 now? [(y)es, (n)o]: y
                      Update admin from @6.2.23 to @6.13.16
                      host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                      NPM version: 10.2.4
                      Installing iobroker.admin@6.13.16... (System call)
                      host.raspberrypi Cannot install iobroker.admin@6.13.16: 217
                      Abbruch ohne genauere Informationen...
                        Homoran Global Moderator Administrators @danielos last edited by Homoran
                        hast du mit --debug gestartet?
                        was steht im Admin?
                        so etwas?
                          @danielos
                          Und jetzt die Langfassung von
                          iob diag
                            danielos @Homoran last edited by danielos
                            pi@raspberrypi:~ $ iobroker upgrade admin --debug
                              throw err;
                            Error: Cannot find module 'readdirp'
                            Require stack:
                            - /opt/iobroker/node_modules/chokidar/index.js
                            - /opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js
                            - /opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js
                            - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                at Object.<anonymous> (/opt/iobroker/node_modules/chokidar/index.js:7:18)
                              requireStack: [
                                '/opt/iobroker/node_modules/chokidar/index.js',
                                '/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js',
                                '/opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js',
                                '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                            Node.js v18.19.1
                              @danielos
                              Da ist der js-controller nicht richtig installiert/kaputt.
                              Richtig sollte das so aussehen:
                              echad@chet:/opt/iobroker $ npm ls readdirp
                              iobroker.inst@3.0.0 /opt/iobroker
                              `-- iobroker.js-controller@5.0.19
                                `-- @iobroker/js-controller-cli@5.0.19
                                  `-- chokidar@3.5.3
                                    `-- readdirp@3.6.0
                                Einige Dinge werden nun angezeigt....
                                			v.2023-10-10
                                         Icon name: computer
                                            Kernel: Linux 5.10.103-v7l+
                                      Architecture: arm
                                Kernel: 		armv7l
                                Userland: 		armhf
                                User-ID: 		1000
                                X-Server: 		false
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.19.1
                                			/usr/bin/npm 		10.2.4
                                			/usr/bin/npx 		10.2.4
                                MEMORY:
                                Mem:           3.8G        152M        3.0G        8.0M        658M        3.5G
                                Swap:           99M          0B         99M
                                Total:         3.9G        152M        3.1G
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.19.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.19.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.19.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.19.1
                                			admin
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.19.1
                                ioBroker Status:
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.19.1
                                Objects: 		0
                                States: 		0
                                6.7M	/opt/iobroker/iobroker-data/states.jsonl
                                Und ja, js-controller scheint nicht richtig zu laufen...
                                pi@raspberrypi:~ $ npm ls readdirp
                                pi@ /home/pi
                                └── (empty)
                                Thomas Braun D 2 Replies Last reply Reply Quote 0
                                  Du stehst nicht im richtigen Verzeichnis...
                                  cd /opt/iobroker
                                  npm ls readdirp
                                  Und die SUMMARY ist nicht die Langfassung. Das ist der Kram davor in der Ausgabe.
                                    danielos @danielos last edited by
                                    @danielos
                                    pi@raspberrypi:~ $ iob start admin.0
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Entsprechend lässt sich admin nicht mehr starten...
                                      @danielos
                                      iob stop
                                      cd /opt/iobroker
                                      iob start
                                        @thomas-braun Mein Terminal zeigt nicht mehr bis ganz oben an... zu viele Fehler. 😉
                                        npm ERR! extraneous: @alcalzone/release-script@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
                                        npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
                                        npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
                                        npm ERR! extraneous: @eslint/eslintrc@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
                                        npm ERR! extraneous: @eslint/js@8.57.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
                                        npm ERR! extraneous: @humanwhocodes/config-array@0.11.14 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
                                        npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
                                        npm ERR! extraneous: @humanwhocodes/object-schema@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
                                        npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
                                        npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
                                        npm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
                                        npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
                                        npm ERR! extraneous: @types/vinyl@2.0.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
                                        npm ERR! extraneous: @ungap/promise-all-settled@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/promise-all-settled
                                        npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
                                        npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
                                        npm ERR! extraneous: acorn@8.11.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
                                        npm ERR! extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aggregate-error
                                        npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
                                        npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
                                        npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
                                        npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
                                        npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
                                        npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
                                        npm ERR! extraneous: anymatch@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
                                        npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
                                        npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
                                        npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                                        npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
                                        npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
                                        npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
                                        npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
                                        npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
                                        npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
                                        npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
                                        npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
                                        npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
                                        npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
                                        npm ERR! extraneous: array-union@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-union
                                        npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
                                        npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
                                        npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
                                        npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
                                        npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
                                        npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
                                        npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
                                        npm ERR! extraneous: axios@1.6.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios
                                        npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
                                        npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
                                        npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
                                        npm ERR! extraneous: binary-extensions@1.13.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
                                        npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
                                        npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
                                        npm ERR! extraneous: braces@2.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
                                        npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
                                        npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
                                        npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
                                        npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
                                        npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
                                        npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
                                        npm ERR! extraneous: chai@4.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
                                        npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
                                        npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
                                        npm ERR! extraneous: chokidar@2.1.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
                                        npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
                                        npm ERR! extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clean-stack
                                        npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
                                        npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
                                        npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
                                        npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
                                        npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
                                        npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
                                        npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
                                        npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
                                        npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
                                        npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
                                        npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
                                        npm ERR! extraneous: component-emitter@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
                                        npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
                                        npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
                                        npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
                                        npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
                                        npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
                                        npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
                                        npm ERR! extraneous: d@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                                        npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
                                        npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
                                        npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
                                        npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
                                        npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
                                        npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
                                        npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
                                        npm ERR! extraneous: del@6.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/del
                                        npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
                                        npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
                                        npm ERR! extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dir-glob
                                        npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
                                        npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
                                        npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
                                        npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
                                        npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
                                        npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
                                        npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
                                        npm ERR! extraneous: es5-ext@0.10.64 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
                                        npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
                                        npm ERR! extraneous: es6-symbol@3.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
                                        npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
                                        npm ERR! extraneous: escalade@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
                                        npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
                                        npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
                                        npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
                                        npm ERR! extraneous: eslint@8.57.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
                                        npm ERR! extraneous: esniff@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esniff
                                        npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
                                        npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
                                        npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
                                        npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
                                        npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
                                        npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-emitter
                                        npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
                                        npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
                                        npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
                                        npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
                                        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
                                        npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
                                        npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
                                        npm ERR! extraneous: fast-glob@3.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
                                        npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
                                        npm ERR! extraneous: fastq@1.17.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
                                        npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
                                        npm ERR! extraneous: fill-range@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
                                        npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
                                        npm ERR! extraneous: findup-sync@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
                                        npm ERR! extraneous: fined@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
                                        npm ERR! extraneous: flagged-respawn@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
                                        npm ERR! extraneous: flat-cache@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
                                        npm ERR! extraneous: flat@5.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
                                        npm ERR! extraneous: flatted@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
                                        npm ERR! extraneous: flush-write-stream@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
                                        npm ERR! extraneous: follow-redirects@1.15.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects
                                        npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
                                        npm ERR! extraneous: for-own@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
                                        npm ERR! extraneous: fragment-cache@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
                                        npm ERR! extraneous: fs-extra@10.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
                                        npm ERR! extraneous: fs-mkdirp-stream@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
                                        npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
                                        npm ERR! extraneous: get-caller-file@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
                                        npm ERR! extraneous: get-func-name@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
                                        npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
                                        npm ERR! extraneous: get-value@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
                                        npm ERR! extraneous: glob-parent@6.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
                                        npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
                                        npm ERR! extraneous: glob-watcher@5.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
                                        npm ERR! extraneous: glob@7.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
                                        npm ERR! extraneous: global-modules@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
                                        npm ERR! extraneous: global-prefix@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
                                        npm ERR! extraneous: globals@13.24.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
                                        npm ERR! extraneous: globalyzer@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
                                        npm ERR! extraneous: globby@11.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globby
                                        npm ERR! extraneous: globrex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
                                        npm ERR! extraneous: glogg@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
                                        npm ERR! extraneous: graceful-fs@4.2.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
                                        npm ERR! extraneous: graphemer@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
                                        npm ERR! extraneous: growl@1.10.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/growl
                                        npm ERR! extraneous: gulp-cli@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
                                        npm ERR! extraneous: gulp-rename@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
                                        npm ERR! extraneous: gulp-replace@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
                                        npm ERR! extraneous: gulp@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
                                        npm ERR! extraneous: gulplog@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
                                        npm ERR! extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
                                        npm ERR! extraneous: has-value@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
                                        npm ERR! extraneous: has-values@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
                                        npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
                                        npm ERR! extraneous: homedir-polyfill@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
                                        npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
                                        npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
                                        npm ERR! extraneous: ignore@5.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
                                        npm ERR! extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
                                        npm ERR! extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
                                        npm ERR! extraneous: indent-string@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/indent-string
                                        npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
                                        npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
                                        npm ERR! extraneous: interpret@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
                                        npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
                                        npm ERR! extraneous: is-absolute@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
                                        npm ERR! extraneous: is-accessor-descriptor@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
                                        npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
                                        npm ERR! extraneous: is-binary-path@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
                                        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
                                        npm ERR! extraneous: is-core-module@2.13.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
                                        npm ERR! extraneous: is-data-descriptor@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
                                        npm ERR! extraneous: is-descriptor@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
                                        npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
                                        npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
                                        npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
                                        npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
                                        npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
                                        npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
                                        npm ERR! extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-cwd
                                        npm ERR! extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
                                        npm ERR! extraneous: is-plain-obj@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
                                        npm ERR! extraneous: is-plain-object@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
                                        npm ERR! extraneous: is-relative@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
                                        npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-stream
                                        npm ERR! extraneous: is-unc-path@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
                                        npm ERR! extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
                                        npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
                                        npm ERR! extraneous: is-valid-glob@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
                                        npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
                                        npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
                                        npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
                                        npm ERR! extraneous: istextorbinary@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
                                        npm ERR! extraneous: js-yaml@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
                                        npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
                                        npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
                                        npm ERR! extraneous: jsonfile@6.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
                                        npm ERR! extraneous: just-debounce@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
                                        npm ERR! extraneous: keyv@4.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
                                        npm ERR! extraneous: kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
                                        npm ERR! extraneous: last-run@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
                                        npm ERR! extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
                                        npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
                                        npm ERR! extraneous: lead@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
                                        npm ERR! extraneous: levn@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
                                        npm ERR! extraneous: liftoff@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
                                        npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
                                        npm ERR! extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
                                        npm ERR! extraneous: lodash.merge@4.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
                                        npm ERR! extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
                                        npm ERR! extraneous: loupe@2.3.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
                                        npm ERR! extraneous: make-iterator@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
                                        npm ERR! extraneous: map-cache@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
                                        npm ERR! extraneous: map-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
                                        npm ERR! extraneous: matchdep@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
                                        npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
                                        npm ERR! extraneous: merge2@1.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
                                        npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
                                        npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
                                        npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
                                        npm ERR! extraneous: mixin-deep@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
                                        npm ERR! extraneous: mocha@9.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
                                        npm ERR! extraneous: mute-stdout@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
                                        npm ERR! extraneous: nanoid@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
                                        npm ERR! extraneous: nanomatch@1.2.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
                                        npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
                                        npm ERR! extraneous: next-tick@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
                                        npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
                                        npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
                                        npm ERR! extraneous: now-and-later@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
                                        npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
                                        npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
                                        npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
                                        npm ERR! extraneous: object-copy@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
                                        npm ERR! extraneous: object-visit@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
                                        npm ERR! extraneous: object.assign@4.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
                                        npm ERR! extraneous: object.defaults@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
                                        npm ERR! extraneous: object.map@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
                                        npm ERR! extraneous: object.pick@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
                                        npm ERR! extraneous: object.reduce@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
                                        npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
                                        npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
                                        npm ERR! extraneous: optionator@0.9.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
                                        npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
                                        npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
                                        npm ERR! extraneous: p-limit@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
                                        npm ERR! extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
                                        npm ERR! extraneous: p-map@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-map
                                        npm ERR! extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
                                        npm ERR! extraneous: parse-filepath@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
                                        npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
                                        npm ERR! extraneous: parse-node-version@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
                                        npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
                                        npm ERR! extraneous: pascalcase@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
                                        npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
                                        npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
                                        npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
                                        npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
                                        npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
                                        npm ERR! extraneous: path-root-regex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
                                        npm ERR! extraneous: path-root@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
                                        npm ERR! extraneous: path-type@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
                                        npm ERR! extraneous: pathval@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
                                        npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
                                        npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
                                        npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
                                        npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
                                        npm ERR! extraneous: posix-character-classes@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
                                        npm ERR! extraneous: prelude-ls@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
                                        npm ERR! extraneous: pretty-hrtime@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
                                        npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env
                                        npm ERR! extraneous: pump@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
                                        npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
                                        npm ERR! extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
                                        npm ERR! extraneous: randombytes@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
                                        npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
                                        npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
                                        npm ERR! extraneous: readdirp@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
                                        npm ERR! extraneous: rechoir@0.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
                                        npm ERR! extraneous: regex-not@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
                                        npm ERR! extraneous: remove-bom-buffer@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
                                        npm ERR! extraneous: remove-bom-stream@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
                                        npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
                                        npm ERR! extraneous: repeat-element@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
                                        npm ERR! extraneous: repeat-string@1.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
                                        npm ERR! extraneous: replace-ext@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
                                        npm ERR! extraneous: replace-homedir@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
                                        npm ERR! extraneous: replacestream@4.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
                                        npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
                                        npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
                                        npm ERR! extraneous: resolve-dir@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
                                        npm ERR! extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
                                        npm ERR! extraneous: resolve-options@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
                                        npm ERR! extraneous: resolve-url@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
                                        npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
                                        npm ERR! extraneous: ret@0.1.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
                                        npm ERR! extraneous: reusify@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
                                        npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
                                        npm ERR! extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
                                        npm ERR! extraneous: safe-regex@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
                                        npm ERR! extraneous: semver-greatest-satisfied-range@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
                                        npm ERR! extraneous: serialize-javascript@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
                                        npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
                                        npm ERR! extraneous: set-value@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
                                        npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
                                        npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
                                        npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
                                        npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/slash
                                        npm ERR! extraneous: snapdragon-node@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
                                        npm ERR! extraneous: snapdragon-util@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
                                        npm ERR! extraneous: snapdragon@0.8.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
                                        npm ERR! extraneous: source-map-resolve@0.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
                                        npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
                                        npm ERR! extraneous: source-map-url@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
                                        npm ERR! extraneous: source-map@0.5.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map
                                        npm ERR! extraneous: sparkles@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
                                        npm ERR! extraneous: spdx-correct@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
                                        npm ERR! extraneous: spdx-exceptions@2.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
                                        npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
                                        npm ERR! extraneous: spdx-license-ids@3.0.17 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
                                        npm ERR! extraneous: split-string@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
                                        npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
                                        npm ERR! extraneous: static-extend@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
                                        npm ERR! extraneous: stream-exhaust@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
                                        npm ERR! extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
                                        npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
                                        npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
                                        npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
                                        npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
                                        npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
                                        npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
                                        npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
                                        npm ERR! extraneous: sver-compat@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
                                        npm ERR! extraneous: text-table@0.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
                                        npm ERR! extraneous: textextensions@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
                                        npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
                                        npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
                                        npm ERR! extraneous: time-stamp@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
                                        npm ERR! extraneous: timekeeper@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
                                        npm ERR! extraneous: tiny-glob@0.2.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
                                        npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
                                        npm ERR! extraneous: to-object-path@0.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
                                        npm ERR! extraneous: to-regex-range@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
                                        npm ERR! extraneous: to-regex@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
                                        npm ERR! extraneous: to-through@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
                                        npm ERR! extraneous: type-check@0.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
                                        npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
                                        npm ERR! extraneous: type-fest@0.20.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
                                        npm ERR! extraneous: type@2.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
                                        npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
                                        npm ERR! extraneous: unc-path-regex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
                                        npm ERR! extraneous: undertaker-registry@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
                                        npm ERR! extraneous: undertaker@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
                                        npm ERR! extraneous: union-value@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
                                        npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
                                        npm ERR! extraneous: universalify@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
                                        npm ERR! extraneous: unset-value@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
                                        npm ERR! extraneous: upath@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
                                        npm ERR! extraneous: urix@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
                                        npm ERR! extraneous: use@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
                                        npm ERR! extraneous: v8flags@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
                                        npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
                                        npm ERR! extraneous: value-or-function@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
                                        npm ERR! extraneous: vinyl-fs@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
                                        npm ERR! extraneous: vinyl-sourcemap@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
                                        npm ERR! extraneous: vinyl@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
                                        npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
                                        npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
                                        npm ERR! extraneous: workerpool@6.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
                                        npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
                                        npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
                                        npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend
                                        npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
                                        npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
                                        npm ERR! extraneous: yargs-unparser@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
                                        npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
                                        npm ERR! extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
                                        npm ERR! invalid: syno@3.0.0 /opt/iobroker/node_modules/syno
                                        npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                        npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
                                        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                                        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                                        npm ERR! invalid: raw-body@ /opt/iobroker/node_modules/raw-body
                                        npm ERR! invalid: querystring@ /opt/iobroker/node_modules/querystring
                                        npm ERR! extraneous: execa@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/execa
                                        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/define-property
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/extend-shallow
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/is-descriptor
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/is-plain-object
                                        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/kind-of
                                        npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/micromatch
                                        npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/normalize-path
                                        npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
                                        npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
                                        npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/node_modules/form-data
                                        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/is-descriptor
                                        npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar/node_modules/glob-parent
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
                                        npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
                                        npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
                                        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-descriptor
                                        npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob/node_modules/glob-parent
                                        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/define-property
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/extend-shallow
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-descriptor
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-plain-object
                                        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
                                        npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
                                        npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
                                        npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
                                        npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
                                        npm ERR! extraneous: ansi-colors@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
                                        npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
                                        npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
                                        npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
                                        npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
                                        npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
                                        npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
                                        npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
                                        npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
                                        npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
                                        npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
                                        npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
                                        npm ERR! extraneous: yargs@7.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
                                        npm ERR! extraneous: kind-of@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
                                        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number/node_modules/kind-of
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
                                        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
                                        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/define-property
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/extend-shallow
                                        npm ERR! extraneous: findup-sync@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-descriptor
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
                                        npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-plain-object
                                        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
                                        npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
                                        npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/braces
                                        npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/fill-range
                                        npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/is-number
                                        npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/to-regex-range
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep/node_modules/is-plain-object
                                        npm ERR! extraneous: ansi-colors@4.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
                                        npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/anymatch
                                        npm ERR! extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/binary-extensions
                                        npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/braces
                                        npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/chokidar
                                        npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
                                        npm ERR! extraneous: debug@4.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/debug
                                        npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/fill-range
                                        npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/glob-parent
                                        npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/is-binary-path
                                        npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/is-number
                                        npm ERR! extraneous: minimatch@4.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
                                        npm ERR! extraneous: ms@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
                                        npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/readdirp
                                        npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
                                        npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/to-regex-range
                                        npm ERR! extraneous: yargs-parser@20.2.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
                                        npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
                                        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/define-property
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/extend-shallow
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/is-descriptor
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/is-plain-object
                                        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
                                        npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
                                        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
                                        npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
                                        npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
                                        npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg/node_modules/path-type
                                        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/define-property
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/extend-shallow
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/is-descriptor
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/is-plain-object
                                        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/kind-of
                                        npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/micromatch
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not/node_modules/extend-shallow
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not/node_modules/is-plain-object
                                        npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
                                        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/is-descriptor
                                        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
                                        npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
                                        npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
                                        npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string/node_modules/extend-shallow
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string/node_modules/is-plain-object
                                        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
                                        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/define-property
                                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/extend-shallow
                                        npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/is-descriptor
                                        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/is-extendable
                                        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/is-plain-object
                                        npm ERR! extraneous: fast-levenshtein@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
                                        npm ERR! extraneous: has-value@0.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
                                        npm ERR! extraneous: has-values@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
                                        npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
                                        npm ERR! extraneous: jwa@ /opt/iobroker/node_modules/jsonwebtoken/node_modules/jwa
                                        npm ERR! invalid: jws@ /opt/iobroker/node_modules/jsonwebtoken/node_modules/jws
                                        npm ERR! invalid: ms@ /opt/iobroker/node_modules/jsonwebtoken/node_modules/ms
                                        npm ERR! invalid: randomatic@ /opt/iobroker/node_modules/randomatic
                                        npm ERR! invalid: random-bytes@ /opt/iobroker/node_modules/random-bytes
                                        npm ERR! invalid: querystringify@ /opt/iobroker/node_modules/querystringify
                                        npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar/node_modules/glob-parent/node_modules/is-glob
                                        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/debug/node_modules/ms
                                        npm ERR! extraneous: isobject@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
                                        npm ERR! invalid: readdirp@ /opt/iobroker/node_modules/readdirp
                                        npm ERR! invalid: postgres-date@ /opt/iobroker/node_modules/postgres-date
                                        npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
                                        npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
                                        npm ERR! missing: ultron@1.0.x, required by ws@1.1.5
                                        npm ERR! invalid: quick-lru@ /opt/iobroker/node_modules/quick-lru
                                        npm ERR! invalid: queue-microtask@ /opt/iobroker/node_modules/queue-microtask
                                        npm ERR! missing: url-parse-lax@^3.0.0, required by got@9.6.0
                                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-16T16_23_27_586Z-debug-0.log
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        node:internal/modules/cjs/loader:1137
                                          throw err;
                                        Error: Cannot find module 'readdirp'
                                        Require stack:
                                        - /opt/iobroker/node_modules/chokidar/index.js
                                        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js
                                        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js
                                        - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                            at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                                            at Module._load (node:internal/modules/cjs/loader:975:27)
                                            at Module.require (node:internal/modules/cjs/loader:1225:19)
                                            at require (node:internal/modules/helpers:177:18)
                                            at Object.<anonymous> (/opt/iobroker/node_modules/chokidar/index.js:7:18)
                                            at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                            at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                            at Module.load (node:internal/modules/cjs/loader:1197:32)
                                            at Module._load (node:internal/modules/cjs/loader:1013:12)
                                            at Module.require (node:internal/modules/cjs/loader:1225:19) {
                                          code: 'MODULE_NOT_FOUND',
                                          requireStack: [
                                            '/opt/iobroker/node_modules/chokidar/index.js',
                                            '/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js',
                                            '/opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js',
                                            '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                            '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        Node.js v18.19.1
                                        Core adapters versions
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        js-controller:
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        admin:
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        javascript:
                                        npm ERR! code ELSPROBLEMS
                                        npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                        npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                        npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                        npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                        npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                        npm ERR! invalid: iobroker.samsung2016@0.0.2 /opt/iobroker/node_modules/iobroker.samsung2016
                                        npm ERR! invalid: iobroker.sayit@4.0.0 /opt/iobroker/node_modules/iobroker.sayit
                                        npm ERR! invalid: iobroker.solaredge@0.2.0 /opt/iobroker/node_modules/iobroker.solaredge
                                        npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/is-number
                                        npm ERR! extraneous: jsonata@1.8.7 /opt/iobroker/node_modules/jsonata
                                        npm ERR! extraneous: math-random@1.0.4 /opt/iobroker/node_modules/math-random
                                        npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                        npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                        npm ERR! extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                                        npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                                        npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                                        npm ERR! extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                                        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-16T16_23_53_793Z-debug-0.log
                                        Adapters from github: 	3
                                        Adapter State
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        ioBroker-Repositories
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        Installed ioBroker-Instances
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        Objects and States
                                        Objects: 	0
                                        States: 	0
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16266      584/sshd
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        17565      570/influxd
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       222138     26487/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       222134     26487/iobroker.js-c
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      110        19642      570/influxd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          16268      584/sshd
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       234853     27570/io.simple-api
                                        tcp6       0      0 :::38327                :::*                    LISTEN      1001       228217     26762/io.ham.0
                                        tcp6       0      0 :::10555                :::*                    LISTEN      1001       228278     26894/io.geofency.0
                                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       228527     26686/io.sonos.0
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       230555     26913/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       230556     26913/io.tuya.0
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16972      567/dhcpcd
                                        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       228279     26873/io.mihome.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       228218     26762/io.ham.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16875      390/avahi-daemon: r
                                        udp        0      0 0.0.0.0:40769           0.0.0.0:*                           108        16877      390/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        16876      390/avahi-daemon: r
                                        udp6       0      0 :::59704                :::*                                108        16878      390/avahi-daemon: r
                                        2024-03-16 17:24:35.805  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:35.853  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:35.871  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:35.903  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:35.922  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:36.254  - info: zwave2.0 (27354) The driver is ready. Found 1 nodes.
                                        2024-03-16 17:24:36.463  - info: swiss-weather-api.0 (27432) Getting forecast for GeolocationId: 47.4106,9.3322
                                        2024-03-16 17:24:36.263  - info: zwave2.0 (27354) All nodes are ready to use
                                        2024-03-16 17:24:36.265  - info: zwave2.0 (27354) Updating broadcast/multicast node states
                                        2024-03-16 17:24:37.225  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                                        2024-03-16 17:24:37.255  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                                        2024-03-16 17:24:37.273  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:37.292  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:37.333  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:37.376  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:37.404  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:37.424  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:38.644  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                                        2024-03-16 17:24:38.665  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                                        2024-03-16 17:24:38.685  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:38.706  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:38.725  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:38.745  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:38.765  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        2024-03-16 17:24:38.799  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                        Und hier im richtigen Verzeichnis readdirp-Output:
                                        pi@raspberrypi:/opt/iobroker $ npm ls readdirp
                                        iobroker.inst@2.0.3 /opt/iobroker
                                        ├─┬ iobroker.javascript@6.0.3
                                        │ ├─┬ chokidar@2.1.8 extraneous
                                        │ │ └── readdirp@2.2.1 deduped
                                        │ ├─┬ mocha@9.2.2 extraneous
                                        │ │ ├─┬ chokidar@3.5.3 extraneous
                                        │ │ │ └── readdirp@3.6.0 deduped
                                        │ │ └── readdirp@3.6.0 extraneous
                                        │ └── readdirp@2.2.1 extraneous
                                        └─┬ iobroker.js-controller@4.0.24
                                          └─┬ @iobroker/js-controller-cli@4.0.24
                                            └─┬ chokidar@3.6.0
                                              └── readdirp@ invalid: "~3.6.0" from node_modules/chokidar
                                          Thomas Braun Most Active @danielos last edited by
                                          @danielos sagte in ioBroker Admin-GUI lässt sich nicht mehr öffnen:
                                          Ist ja auch nicht der aktuelle controller...
                                          Never change a running system, ich weiß...
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install iobroker.js-controller@5.0.19
                                            danielos @Thomas Braun last edited by
                                            @thomas-braun Hmmm, komisch... denn das habe ich ja schon mal ausgeführt. Aber scheinbar ging was schief. Let's give it another try.
                                            1991
