    4. ioBroker Admin-GUI lässt sich nicht mehr öffnen
      Homoran Global Moderator Administrators @danielos last edited by Homoran
      @danielos sagte in ioBroker Admin-GUI lässt sich nicht mehr öffnen:
      Abbruch ohne genauere Informationen...
      hast du mit --debug gestartet?
      was steht im Admin?
      so etwas?
        Thomas Braun Most Active @danielos last edited by
        @danielos
        Und jetzt die Langfassung von
        iob diag
          danielos @Homoran last edited by danielos
          pi@raspberrypi:~ $ iobroker upgrade admin --debug
          node:internal/modules/cjs/loader:1137
            throw err;
          Error: Cannot find module 'readdirp'
          Require stack:
          - /opt/iobroker/node_modules/chokidar/index.js
          - /opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js
          - /opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
              at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              at Module._load (node:internal/modules/cjs/loader:975:27)
              at Module.require (node:internal/modules/cjs/loader:1225:19)
              at require (node:internal/modules/helpers:177:18)
              at Object.<anonymous> (/opt/iobroker/node_modules/chokidar/index.js:7:18)
              at Module._compile (node:internal/modules/cjs/loader:1356:14)
              at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              at Module.load (node:internal/modules/cjs/loader:1197:32)
              at Module._load (node:internal/modules/cjs/loader:1013:12)
              at Module.require (node:internal/modules/cjs/loader:1225:19) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/opt/iobroker/node_modules/chokidar/index.js',
              '/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js',
              '/opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          Node.js v18.19.1
            @danielos
            Da ist der js-controller nicht richtig installiert/kaputt.
            Richtig sollte das so aussehen:
            echad@chet:/opt/iobroker $ npm ls readdirp
            iobroker.inst@3.0.0 /opt/iobroker
            `-- iobroker.js-controller@5.0.19
              `-- @iobroker/js-controller-cli@5.0.19
                `-- chokidar@3.5.3
                  `-- readdirp@3.6.0
              danielos @Thomas Braun last edited by
              Einige Dinge werden nun angezeigt....
              			v.2023-10-10
                 Static hostname: raspberrypi
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 10 (buster)
                          Kernel: Linux 5.10.103-v7l+
                    Architecture: arm
              Installation: 		native
              Kernel: 		armv7l
              Userland: 		armhf
              Timezone: 		Europe/Berlin (CET, +0100)
              User-ID: 		1000
              X-Server: 		false
              Boot Target: 		graphical.target
              Pending OS-Updates: 	0
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              Pending iob updates: 	0
              Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
              			/usr/bin/node 		v18.19.1
              			/usr/bin/npm 		10.2.4
              			/usr/bin/npx 		10.2.4
              			/usr/bin/corepack 	0.22.0
              Recommended versions are nodejs  and npm
              MEMORY:
              Mem:           3.8G        152M        3.0G        8.0M        658M        3.5G
              Swap:           99M          0B         99M
              Total:         3.9G        152M        3.1G
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              Active iob-Instances: 	0
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              ioBroker Core: 		js-controller
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              			admin
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              ioBroker Status:
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              Objects: 		0
              States: 		0
              Size of iob-Database:
              23M	/opt/iobroker/iobroker-data/objects.jsonl
              16M	/opt/iobroker/iobroker-data/objects.json.migrated
              16M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
              6.7M	/opt/iobroker/iobroker-data/states.jsonl
              4.4M	/opt/iobroker/iobroker-data/states.json.migrated
              4.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
              0	/opt/iobroker/iobroker-data/states.json.broken
              Und ja, js-controller scheint nicht richtig zu laufen...
              pi@raspberrypi:~ $ npm ls readdirp
              pi@ /home/pi
              └── (empty)
              Thomas Braun D 2 Replies Last reply Reply Quote 0
                Du stehst nicht im richtigen Verzeichnis...
                cd /opt/iobroker
                npm ls readdirp
                Und die SUMMARY ist nicht die Langfassung. Das ist der Kram davor in der Ausgabe.
                  danielos @danielos last edited by
                  @danielos
                  pi@raspberrypi:~ $ iob start admin.0
                    throw err;
                  Require stack:
                    requireStack: [
                  Entsprechend lässt sich admin nicht mehr starten...
                    @danielos
                    iob stop
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iob start
                      @thomas-braun Mein Terminal zeigt nicht mehr bis ganz oben an... zu viele Fehler. 😉
                      npm ERR! extraneous: @alcalzone/release-script@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
                      npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
                      npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
                      npm ERR! extraneous: @eslint/eslintrc@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
                      npm ERR! extraneous: @eslint/js@8.57.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
                      npm ERR! extraneous: @humanwhocodes/config-array@0.11.14 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
                      npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
                      npm ERR! extraneous: @humanwhocodes/object-schema@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
                      npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
                      npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
                      npm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
                      npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
                      npm ERR! extraneous: @types/vinyl@2.0.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
                      npm ERR! extraneous: @ungap/promise-all-settled@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/promise-all-settled
                      npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
                      npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
                      npm ERR! extraneous: acorn@8.11.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
                      npm ERR! extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aggregate-error
                      npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
                      npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
                      npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
                      npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
                      npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
                      npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
                      npm ERR! extraneous: anymatch@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
                      npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
                      npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
                      npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                      npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
                      npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
                      npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
                      npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
                      npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
                      npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
                      npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
                      npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
                      npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
                      npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
                      npm ERR! extraneous: array-union@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-union
                      npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
                      npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
                      npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
                      npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
                      npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
                      npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
                      npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
                      npm ERR! extraneous: axios@1.6.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios
                      npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
                      npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
                      npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
                      npm ERR! extraneous: binary-extensions@1.13.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
                      npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
                      npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
                      npm ERR! extraneous: braces@2.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
                      npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
                      npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
                      npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
                      npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
                      npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
                      npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
                      npm ERR! extraneous: chai@4.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
                      npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
                      npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
                      npm ERR! extraneous: chokidar@2.1.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
                      npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
                      npm ERR! extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clean-stack
                      npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
                      npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
                      npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
                      npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
                      npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
                      npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
                      npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
                      npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
                      npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
                      npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
                      npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
                      npm ERR! extraneous: component-emitter@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
                      npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
                      npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
                      npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
                      npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
                      npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
                      npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
                      npm ERR! extraneous: d@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                      npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
                      npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
                      npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
                      npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
                      npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
                      npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
                      npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
                      npm ERR! extraneous: del@6.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/del
                      npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
                      npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
                      npm ERR! extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dir-glob
                      npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
                      npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
                      npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
                      npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
                      npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
                      npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
                      npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
                      npm ERR! extraneous: es5-ext@0.10.64 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
                      npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
                      npm ERR! extraneous: es6-symbol@3.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
                      npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
                      npm ERR! extraneous: escalade@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
                      npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
                      npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
                      npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
                      npm ERR! extraneous: eslint@8.57.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
                      npm ERR! extraneous: esniff@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esniff
                      npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
                      npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
                      npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
                      npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
                      npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
                      npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-emitter
                      npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
                      npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
                      npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
                      npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
                      npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
                      npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
                      npm ERR! extraneous: fast-glob@3.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
                      npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
                      npm ERR! extraneous: fastq@1.17.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
                      npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
                      npm ERR! extraneous: fill-range@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
                      npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
                      npm ERR! extraneous: findup-sync@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
                      npm ERR! extraneous: fined@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
                      npm ERR! extraneous: flagged-respawn@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
                      npm ERR! extraneous: flat-cache@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
                      npm ERR! extraneous: flat@5.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
                      npm ERR! extraneous: flatted@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
                      npm ERR! extraneous: flush-write-stream@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
                      npm ERR! extraneous: follow-redirects@1.15.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects
                      npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
                      npm ERR! extraneous: for-own@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
                      npm ERR! extraneous: fragment-cache@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
                      npm ERR! extraneous: fs-extra@10.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
                      npm ERR! extraneous: fs-mkdirp-stream@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
                      npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
                      npm ERR! extraneous: get-caller-file@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
                      npm ERR! extraneous: get-func-name@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
                      npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
                      npm ERR! extraneous: get-value@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
                      npm ERR! extraneous: glob-parent@6.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
                      npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
                      npm ERR! extraneous: glob-watcher@5.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
                      npm ERR! extraneous: glob@7.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
                      npm ERR! extraneous: global-modules@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
                      npm ERR! extraneous: global-prefix@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
                      npm ERR! extraneous: globals@13.24.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
                      npm ERR! extraneous: globalyzer@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
                      npm ERR! extraneous: globby@11.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globby
                      npm ERR! extraneous: globrex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
                      npm ERR! extraneous: glogg@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
                      npm ERR! extraneous: graceful-fs@4.2.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
                      npm ERR! extraneous: graphemer@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
                      npm ERR! extraneous: growl@1.10.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/growl
                      npm ERR! extraneous: gulp-cli@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
                      npm ERR! extraneous: gulp-rename@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
                      npm ERR! extraneous: gulp-replace@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
                      npm ERR! extraneous: gulp@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
                      npm ERR! extraneous: gulplog@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
                      npm ERR! extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
                      npm ERR! extraneous: has-value@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
                      npm ERR! extraneous: has-values@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
                      npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
                      npm ERR! extraneous: homedir-polyfill@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
                      npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
                      npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
                      npm ERR! extraneous: ignore@5.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
                      npm ERR! extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
                      npm ERR! extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
                      npm ERR! extraneous: indent-string@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/indent-string
                      npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
                      npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
                      npm ERR! extraneous: interpret@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
                      npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
                      npm ERR! extraneous: is-absolute@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
                      npm ERR! extraneous: is-accessor-descriptor@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
                      npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
                      npm ERR! extraneous: is-binary-path@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
                      npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
                      npm ERR! extraneous: is-core-module@2.13.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
                      npm ERR! extraneous: is-data-descriptor@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
                      npm ERR! extraneous: is-descriptor@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
                      npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
                      npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
                      npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
                      npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
                      npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
                      npm ERR! extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-cwd
                      npm ERR! extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
                      npm ERR! extraneous: is-plain-obj@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
                      npm ERR! extraneous: is-plain-object@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
                      npm ERR! extraneous: is-relative@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
                      npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-stream
                      npm ERR! extraneous: is-unc-path@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
                      npm ERR! extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
                      npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
                      npm ERR! extraneous: is-valid-glob@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
                      npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
                      npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
                      npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
                      npm ERR! extraneous: istextorbinary@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
                      npm ERR! extraneous: js-yaml@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
                      npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
                      npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
                      npm ERR! extraneous: jsonfile@6.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
                      npm ERR! extraneous: just-debounce@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
                      npm ERR! extraneous: keyv@4.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
                      npm ERR! extraneous: kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
                      npm ERR! extraneous: last-run@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
                      npm ERR! extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
                      npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
                      npm ERR! extraneous: lead@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
                      npm ERR! extraneous: levn@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
                      npm ERR! extraneous: liftoff@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
                      npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
                      npm ERR! extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
                      npm ERR! extraneous: lodash.merge@4.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
                      npm ERR! extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
                      npm ERR! extraneous: loupe@2.3.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
                      npm ERR! extraneous: make-iterator@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
                      npm ERR! extraneous: map-cache@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
                      npm ERR! extraneous: map-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
                      npm ERR! extraneous: matchdep@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
                      npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
                      npm ERR! extraneous: merge2@1.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
                      npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
                      npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
                      npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
                      npm ERR! extraneous: mixin-deep@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
                      npm ERR! extraneous: mocha@9.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
                      npm ERR! extraneous: mute-stdout@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
                      npm ERR! extraneous: nanoid@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
                      npm ERR! extraneous: nanomatch@1.2.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
                      npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
                      npm ERR! extraneous: next-tick@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
                      npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
                      npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
                      npm ERR! extraneous: now-and-later@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
                      npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
                      npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
                      npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
                      npm ERR! extraneous: object-copy@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
                      npm ERR! extraneous: object-visit@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
                      npm ERR! extraneous: object.assign@4.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
                      npm ERR! extraneous: object.defaults@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
                      npm ERR! extraneous: object.map@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
                      npm ERR! extraneous: object.pick@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
                      npm ERR! extraneous: object.reduce@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
                      npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
                      npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
                      npm ERR! extraneous: optionator@0.9.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
                      npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
                      npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
                      npm ERR! extraneous: p-limit@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
                      npm ERR! extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
                      npm ERR! extraneous: p-map@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-map
                      npm ERR! extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
                      npm ERR! extraneous: parse-filepath@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
                      npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
                      npm ERR! extraneous: parse-node-version@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
                      npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
                      npm ERR! extraneous: pascalcase@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
                      npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
                      npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
                      npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
                      npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
                      npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
                      npm ERR! extraneous: path-root-regex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
                      npm ERR! extraneous: path-root@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
                      npm ERR! extraneous: path-type@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
                      npm ERR! extraneous: pathval@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
                      npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
                      npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
                      npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
                      npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
                      npm ERR! extraneous: posix-character-classes@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
                      npm ERR! extraneous: prelude-ls@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
                      npm ERR! extraneous: pretty-hrtime@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
                      npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env
                      npm ERR! extraneous: pump@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
                      npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
                      npm ERR! extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
                      npm ERR! extraneous: randombytes@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
                      npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
                      npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
                      npm ERR! extraneous: readdirp@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
                      npm ERR! extraneous: rechoir@0.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
                      npm ERR! extraneous: regex-not@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
                      npm ERR! extraneous: remove-bom-buffer@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
                      npm ERR! extraneous: remove-bom-stream@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
                      npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
                      npm ERR! extraneous: repeat-element@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
                      npm ERR! extraneous: repeat-string@1.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
                      npm ERR! extraneous: replace-ext@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
                      npm ERR! extraneous: replace-homedir@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
                      npm ERR! extraneous: replacestream@4.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
                      npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
                      npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
                      npm ERR! extraneous: resolve-dir@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
                      npm ERR! extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
                      npm ERR! extraneous: resolve-options@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
                      npm ERR! extraneous: resolve-url@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
                      npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
                      npm ERR! extraneous: ret@0.1.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
                      npm ERR! extraneous: reusify@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
                      npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
                      npm ERR! extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
                      npm ERR! extraneous: safe-regex@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
                      npm ERR! extraneous: semver-greatest-satisfied-range@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
                      npm ERR! extraneous: serialize-javascript@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
                      npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
                      npm ERR! extraneous: set-value@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
                      npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
                      npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
                      npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
                      npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/slash
                      npm ERR! extraneous: snapdragon-node@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
                      npm ERR! extraneous: snapdragon-util@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
                      npm ERR! extraneous: snapdragon@0.8.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
                      npm ERR! extraneous: source-map-resolve@0.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
                      npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
                      npm ERR! extraneous: source-map-url@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
                      npm ERR! extraneous: source-map@0.5.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map
                      npm ERR! extraneous: sparkles@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
                      npm ERR! extraneous: spdx-correct@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
                      npm ERR! extraneous: spdx-exceptions@2.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
                      npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
                      npm ERR! extraneous: spdx-license-ids@3.0.17 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
                      npm ERR! extraneous: split-string@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
                      npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
                      npm ERR! extraneous: static-extend@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
                      npm ERR! extraneous: stream-exhaust@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
                      npm ERR! extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
                      npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
                      npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
                      npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
                      npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
                      npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
                      npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
                      npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
                      npm ERR! extraneous: sver-compat@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
                      npm ERR! extraneous: text-table@0.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
                      npm ERR! extraneous: textextensions@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
                      npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
                      npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
                      npm ERR! extraneous: time-stamp@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
                      npm ERR! extraneous: timekeeper@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
                      npm ERR! extraneous: tiny-glob@0.2.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
                      npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
                      npm ERR! extraneous: to-object-path@0.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
                      npm ERR! extraneous: to-regex-range@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
                      npm ERR! extraneous: to-regex@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
                      npm ERR! extraneous: to-through@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
                      npm ERR! extraneous: type-check@0.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
                      npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
                      npm ERR! extraneous: type-fest@0.20.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
                      npm ERR! extraneous: type@2.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
                      npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
                      npm ERR! extraneous: unc-path-regex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
                      npm ERR! extraneous: undertaker-registry@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
                      npm ERR! extraneous: undertaker@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
                      npm ERR! extraneous: union-value@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
                      npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
                      npm ERR! extraneous: universalify@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
                      npm ERR! extraneous: unset-value@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
                      npm ERR! extraneous: upath@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
                      npm ERR! extraneous: urix@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
                      npm ERR! extraneous: use@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
                      npm ERR! extraneous: v8flags@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
                      npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
                      npm ERR! extraneous: value-or-function@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
                      npm ERR! extraneous: vinyl-fs@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
                      npm ERR! extraneous: vinyl-sourcemap@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
                      npm ERR! extraneous: vinyl@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
                      npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
                      npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
                      npm ERR! extraneous: workerpool@6.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
                      npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
                      npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
                      npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend
                      npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
                      npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
                      npm ERR! extraneous: yargs-unparser@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
                      npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
                      npm ERR! extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
                      npm ERR! invalid: syno@3.0.0 /opt/iobroker/node_modules/syno
                      npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                      npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
                      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                      npm ERR! invalid: raw-body@ /opt/iobroker/node_modules/raw-body
                      npm ERR! invalid: querystring@ /opt/iobroker/node_modules/querystring
                      npm ERR! extraneous: execa@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/execa
                      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/extend-shallow
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/is-plain-object
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/kind-of
                      npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/micromatch
                      npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch/node_modules/normalize-path
                      npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
                      npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
                      npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/node_modules/form-data
                      npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/is-descriptor
                      npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar/node_modules/glob-parent
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
                      npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-descriptor
                      npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob/node_modules/glob-parent
                      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/extend-shallow
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-plain-object
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
                      npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
                      npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
                      npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
                      npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
                      npm ERR! extraneous: ansi-colors@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
                      npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
                      npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
                      npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
                      npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
                      npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
                      npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
                      npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
                      npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
                      npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
                      npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
                      npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
                      npm ERR! extraneous: yargs@7.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
                      npm ERR! extraneous: kind-of@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number/node_modules/kind-of
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
                      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/extend-shallow
                      npm ERR! extraneous: findup-sync@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
                      npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-plain-object
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
                      npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
                      npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/braces
                      npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/fill-range
                      npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/is-number
                      npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch/node_modules/to-regex-range
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep/node_modules/is-plain-object
                      npm ERR! extraneous: ansi-colors@4.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
                      npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/anymatch
                      npm ERR! extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/binary-extensions
                      npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/braces
                      npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/chokidar
                      npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
                      npm ERR! extraneous: debug@4.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/debug
                      npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/fill-range
                      npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/glob-parent
                      npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/is-binary-path
                      npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/is-number
                      npm ERR! extraneous: minimatch@4.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
                      npm ERR! extraneous: ms@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
                      npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/readdirp
                      npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
                      npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/to-regex-range
                      npm ERR! extraneous: yargs-parser@20.2.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
                      npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
                      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/extend-shallow
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/is-plain-object
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
                      npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
                      npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
                      npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
                      npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg/node_modules/path-type
                      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/extend-shallow
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/is-plain-object
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/kind-of
                      npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp/node_modules/micromatch
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not/node_modules/extend-shallow
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not/node_modules/is-plain-object
                      npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
                      npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/is-descriptor
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
                      npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string/node_modules/extend-shallow
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string/node_modules/is-plain-object
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
                      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/extend-shallow
                      npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex/node_modules/is-plain-object
                      npm ERR! extraneous: fast-levenshtein@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
                      npm ERR! extraneous: has-value@0.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
                      npm ERR! extraneous: has-values@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
                      npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
                      npm ERR! extraneous: jwa@ /opt/iobroker/node_modules/jsonwebtoken/node_modules/jwa
                      npm ERR! invalid: jws@ /opt/iobroker/node_modules/jsonwebtoken/node_modules/jws
                      npm ERR! invalid: ms@ /opt/iobroker/node_modules/jsonwebtoken/node_modules/ms
                      npm ERR! invalid: randomatic@ /opt/iobroker/node_modules/randomatic
                      npm ERR! invalid: random-bytes@ /opt/iobroker/node_modules/random-bytes
                      npm ERR! invalid: querystringify@ /opt/iobroker/node_modules/querystringify
                      npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar/node_modules/glob-parent/node_modules/is-glob
                      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/debug/node_modules/ms
                      npm ERR! extraneous: isobject@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
                      npm ERR! invalid: readdirp@ /opt/iobroker/node_modules/readdirp
                      npm ERR! invalid: postgres-date@ /opt/iobroker/node_modules/postgres-date
                      npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
                      npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
                      npm ERR! missing: ultron@1.0.x, required by ws@1.1.5
                      npm ERR! invalid: quick-lru@ /opt/iobroker/node_modules/quick-lru
                      npm ERR! invalid: queue-microtask@ /opt/iobroker/node_modules/queue-microtask
                      npm ERR! missing: url-parse-lax@^3.0.0, required by got@9.6.0
                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-16T16_23_27_586Z-debug-0.log
                      *** ioBroker-Installation ***
                      ioBroker Status
                      node:internal/modules/cjs/loader:1137
                        throw err;
                      Error: Cannot find module 'readdirp'
                      Require stack:
                      - /opt/iobroker/node_modules/chokidar/index.js
                      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js
                      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js
                      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                          at Module._load (node:internal/modules/cjs/loader:975:27)
                          at Module.require (node:internal/modules/cjs/loader:1225:19)
                          at require (node:internal/modules/helpers:177:18)
                          at Object.<anonymous> (/opt/iobroker/node_modules/chokidar/index.js:7:18)
                          at Module._compile (node:internal/modules/cjs/loader:1356:14)
                          at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                          at Module.load (node:internal/modules/cjs/loader:1197:32)
                          at Module._load (node:internal/modules/cjs/loader:1013:12)
                          at Module.require (node:internal/modules/cjs/loader:1225:19) {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: [
                          '/opt/iobroker/node_modules/chokidar/index.js',
                          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js',
                          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js',
                          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      Node.js v18.19.1
                      Core adapters versions
                        throw err;
                      Require stack:
                        requireStack: [
                      Node.js v18.19.1
                      js-controller:
                        throw err;
                      Require stack:
                        requireStack: [
                      Node.js v18.19.1
                      admin:
                        throw err;
                      Require stack:
                        requireStack: [
                      Node.js v18.19.1
                      javascript:
                      npm ERR! code ELSPROBLEMS
                      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                      npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                      npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                      npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
                      npm ERR! invalid: iobroker.samsung2016@0.0.2 /opt/iobroker/node_modules/iobroker.samsung2016
                      npm ERR! invalid: iobroker.sayit@4.0.0 /opt/iobroker/node_modules/iobroker.sayit
                      npm ERR! invalid: iobroker.solaredge@0.2.0 /opt/iobroker/node_modules/iobroker.solaredge
                      npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/is-number
                      npm ERR! extraneous: jsonata@1.8.7 /opt/iobroker/node_modules/jsonata
                      npm ERR! extraneous: math-random@1.0.4 /opt/iobroker/node_modules/math-random
                      npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                      npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                      npm ERR! extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                      npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                      npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                      npm ERR! extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-16T16_23_53_793Z-debug-0.log
                      Adapters from github: 	3
                      Adapter State
                        throw err;
                      Require stack:
                        requireStack: [
                      Node.js v18.19.1
                        throw err;
                      Require stack:
                        requireStack: [
                      Node.js v18.19.1
                      ioBroker-Repositories
                        throw err;
                      Require stack:
                        requireStack: [
                      Node.js v18.19.1
                      Installed ioBroker-Instances
                        throw err;
                      Require stack:
                        requireStack: [
                      Node.js v18.19.1
                      Objects and States
                      Objects: 	0
                      States: 	0
                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16266      584/sshd
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        17565      570/influxd
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       222138     26487/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       222134     26487/iobroker.js-c
                      tcp6       0      0 :::8086                 :::*                    LISTEN      110        19642      570/influxd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          16268      584/sshd
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       234853     27570/io.simple-api
                      tcp6       0      0 :::38327                :::*                    LISTEN      1001       228217     26762/io.ham.0
                      tcp6       0      0 :::10555                :::*                    LISTEN      1001       228278     26894/io.geofency.0
                      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       228527     26686/io.sonos.0
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       230555     26913/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       230556     26913/io.tuya.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16972      567/dhcpcd
                      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       228279     26873/io.mihome.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       228218     26762/io.ham.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16875      390/avahi-daemon: r
                      udp        0      0 0.0.0.0:40769           0.0.0.0:*                           108        16877      390/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        16876      390/avahi-daemon: r
                      udp6       0      0 :::59704                :::*                                108        16878      390/avahi-daemon: r
                      2024-03-16 17:24:35.805  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:35.853  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:35.871  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:35.903  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:35.922  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:36.254  - info: zwave2.0 (27354) The driver is ready. Found 1 nodes.
                      2024-03-16 17:24:36.463  - info: swiss-weather-api.0 (27432) Getting forecast for GeolocationId: 47.4106,9.3322
                      2024-03-16 17:24:36.263  - info: zwave2.0 (27354) All nodes are ready to use
                      2024-03-16 17:24:36.265  - info: zwave2.0 (27354) Updating broadcast/multicast node states
                      2024-03-16 17:24:37.225  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                      2024-03-16 17:24:37.255  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                      2024-03-16 17:24:37.273  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:37.292  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:37.333  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:37.376  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:37.404  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:37.424  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:38.644  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                      2024-03-16 17:24:38.665  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":4,"message":"SLAVE DEVICE FAILURE"}
                      2024-03-16 17:24:38.685  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:38.706  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:38.725  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:38.745  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:38.765  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      2024-03-16 17:24:38.799  - error: modbus.0 (26950) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                      Und hier im richtigen Verzeichnis readdirp-Output:
                      pi@raspberrypi:/opt/iobroker $ npm ls readdirp
                      iobroker.inst@2.0.3 /opt/iobroker
                      ├─┬ iobroker.javascript@6.0.3
                      │ ├─┬ chokidar@2.1.8 extraneous
                      │ │ └── readdirp@2.2.1 deduped
                      │ ├─┬ mocha@9.2.2 extraneous
                      │ │ ├─┬ chokidar@3.5.3 extraneous
                      │ │ │ └── readdirp@3.6.0 deduped
                      │ │ └── readdirp@3.6.0 extraneous
                      │ └── readdirp@2.2.1 extraneous
                      └─┬ iobroker.js-controller@4.0.24
                        └─┬ @iobroker/js-controller-cli@4.0.24
                          └─┬ chokidar@3.6.0
                            └── readdirp@ invalid: "~3.6.0" from node_modules/chokidar
                        Thomas Braun Most Active @danielos last edited by
                        @danielos sagte in ioBroker Admin-GUI lässt sich nicht mehr öffnen:
                        Ist ja auch nicht der aktuelle controller...
                        Never change a running system, ich weiß...
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller@5.0.19
                          danielos @Thomas Braun last edited by
                          @thomas-braun Hmmm, komisch... denn das habe ich ja schon mal ausgeführt. Aber scheinbar ging was schief. Let's give it another try.
                            Homoran Global Moderator Administrators @danielos last edited by
                            exakt so?
                            im richtigen Verzeichnis?
                            Was kam als output?
                              danielos @Homoran last edited by
                              @homoran Hmm, eigentlich ja, aber ich hatte einen ganz kurzen Verbindungsunterbruch, allenfalls war das das Problem.
                              Jetzt scheint das zu stimmen:
                              └─┬ iobroker.js-controller@5.0.19 invalid: "^4.0.23" from the root project
                                └─┬ @iobroker/js-controller-cli@5.0.19
                                  └─┬ chokidar@3.6.0
                                    └── readdirp@3.6.0
                                cd /opt/iobroker
                                npm ls | grep invalid
                                  @thomas-braun sagte in ioBroker Admin-GUI lässt sich nicht mehr öffnen:
                                  cd /opt/iobroker
                                  Da heisst's folgendes:
                                  pi@raspberrypi:/opt/iobroker $ npm ls | grep invalid
                                  npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-11 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                                  npm ERR! extraneous: @abandonware/noble@1.9.2-23 /opt/iobroker/node_modules/@abandonware/noble
                                  npm ERR! extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                  npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                                  npm ERR! extraneous: @aws-crypto/crc32@3.0.0 /opt/iobroker/node_modules/@aws-crypto/crc32
                                  npm ERR! extraneous: @aws-crypto/ie11-detection@3.0.0 /opt/iobroker/node_modules/@aws-crypto/ie11-detection
                                  npm ERR! extraneous: @aws-crypto/sha256-browser@3.0.0 /opt/iobroker/node_modules/@aws-crypto/sha256-browser
                                  npm ERR! extraneous: @aws-crypto/sha256-js@3.0.0 /opt/iobroker/node_modules/@aws-crypto/sha256-js
                                  npm ERR! extraneous: @aws-crypto/supports-web-crypto@3.0.0 /opt/iobroker/node_modules/@aws-crypto/supports-web-crypto
                                  npm ERR! extraneous: @aws-crypto/util@3.0.0 /opt/iobroker/node_modules/@aws-crypto/util
                                  npm ERR! extraneous: @aws-sdk/client-polly@3.535.0 /opt/iobroker/node_modules/@aws-sdk/client-polly
                                  npm ERR! extraneous: @aws-sdk/client-sso-oidc@3.535.0 /opt/iobroker/node_modules/@aws-sdk/client-sso-oidc
                                  npm ERR! extraneous: @aws-sdk/client-sso@3.535.0 /opt/iobroker/node_modules/@aws-sdk/client-sso
                                  npm ERR! extraneous: @aws-sdk/client-sts@3.535.0 /opt/iobroker/node_modules/@aws-sdk/client-sts
                                  npm ERR! extraneous: @aws-sdk/core@3.535.0 /opt/iobroker/node_modules/@aws-sdk/core
                                  npm ERR! extraneous: @aws-sdk/credential-provider-env@3.535.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-env
                                  npm ERR! extraneous: @aws-sdk/credential-provider-http@3.535.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-http
                                  npm ERR! extraneous: @aws-sdk/credential-provider-ini@3.535.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-ini
                                  npm ERR! extraneous: @aws-sdk/credential-provider-node@3.535.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-node
                                  npm ERR! extraneous: @aws-sdk/credential-provider-process@3.535.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-process
                                  npm ERR! extraneous: @aws-sdk/credential-provider-sso@3.535.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-sso
                                  npm ERR! extraneous: @aws-sdk/credential-provider-web-identity@3.535.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity
                                  npm ERR! extraneous: @aws-sdk/middleware-host-header@3.535.0 /opt/iobroker/node_modules/@aws-sdk/middleware-host-header
                                  npm ERR! extraneous: @aws-sdk/middleware-logger@3.535.0 /opt/iobroker/node_modules/@aws-sdk/middleware-logger
                                  npm ERR! extraneous: @aws-sdk/middleware-recursion-detection@3.535.0 /opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection
                                  npm ERR! extraneous: @aws-sdk/middleware-user-agent@3.535.0 /opt/iobroker/node_modules/@aws-sdk/middleware-user-agent
                                  npm ERR! extraneous: @aws-sdk/region-config-resolver@3.535.0 /opt/iobroker/node_modules/@aws-sdk/region-config-resolver
                                  npm ERR! extraneous: @aws-sdk/token-providers@3.535.0 /opt/iobroker/node_modules/@aws-sdk/token-providers
                                  npm ERR! extraneous: @aws-sdk/types@3.535.0 /opt/iobroker/node_modules/@aws-sdk/types
                                  npm ERR! extraneous: @aws-sdk/util-endpoints@3.535.0 /opt/iobroker/node_modules/@aws-sdk/util-endpoints
                                  npm ERR! extraneous: @aws-sdk/util-locate-window@3.535.0 /opt/iobroker/node_modules/@aws-sdk/util-locate-window
                                  npm ERR! extraneous: @aws-sdk/util-user-agent-browser@3.535.0 /opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser
                                  npm ERR! extraneous: @aws-sdk/util-user-agent-node@3.535.0 /opt/iobroker/node_modules/@aws-sdk/util-user-agent-node
                                  npm ERR! extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                                  npm ERR! extraneous: @azure/core-auth@1.7.0 /opt/iobroker/node_modules/@azure/core-auth
                                  npm ERR! extraneous: @azure/core-client@1.9.0 /opt/iobroker/node_modules/@azure/core-client
                                  npm ERR! extraneous: @azure/core-http-compat@2.1.0 /opt/iobroker/node_modules/@azure/core-http-compat
                                  npm ERR! extraneous: @azure/core-lro@2.7.0 /opt/iobroker/node_modules/@azure/core-lro
                                  npm ERR! extraneous: @azure/core-paging@1.6.0 /opt/iobroker/node_modules/@azure/core-paging
                                  npm ERR! extraneous: @azure/core-rest-pipeline@1.15.0 /opt/iobroker/node_modules/@azure/core-rest-pipeline
                                  npm ERR! extraneous: @azure/core-tracing@1.1.0 /opt/iobroker/node_modules/@azure/core-tracing
                                  npm ERR! extraneous: @azure/core-util@1.8.0 /opt/iobroker/node_modules/@azure/core-util
                                  npm ERR! extraneous: @azure/identity@2.1.0 /opt/iobroker/node_modules/@azure/identity
                                  npm ERR! extraneous: @azure/logger@1.1.0 /opt/iobroker/node_modules/@azure/logger
                                  npm ERR! extraneous: @azure/msal-browser@2.38.3 /opt/iobroker/node_modules/@azure/msal-browser
                                  npm ERR! extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                                  npm ERR! extraneous: @babel/code-frame@7.23.5 /opt/iobroker/node_modules/@babel/code-frame
                                  npm ERR! extraneous: @babel/highlight@7.23.4 /opt/iobroker/node_modules/@babel/highlight
                                  npm ERR! extraneous: @eslint/eslintrc@2.1.4 /opt/iobroker/node_modules/@eslint/eslintrc
                                  npm ERR! extraneous: @humanwhocodes/config-array@0.11.14 /opt/iobroker/node_modules/@humanwhocodes/config-array
                                  npm ERR! extraneous: @iobroker/db-base@5.0.19 /opt/iobroker/node_modules/@iobroker/db-base
                                  npm ERR! extraneous: @iobroker/db-objects-file@5.0.19 /opt/iobroker/node_modules/@iobroker/db-objects-file
                                  npm ERR! extraneous: @iobroker/db-objects-jsonl@5.0.19 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                  npm ERR! extraneous: @iobroker/db-objects-redis@5.0.19 /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                  npm ERR! extraneous: @iobroker/js-controller-adapter@5.0.19 /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                  npm ERR! extraneous: @iobroker/js-controller-cli@5.0.19 /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                  npm ERR! extraneous: @iobroker/js-controller-common-db@5.0.19 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                  npm ERR! extraneous: @iobroker/js-controller-common@5.0.19 /opt/iobroker/node_modules/@iobroker/js-controller-common
                                  npm ERR! extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                                  npm ERR! extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                                  npm ERR! extraneous: @npmcli/agent@2.2.1 /opt/iobroker/node_modules/@npmcli/agent
                                  npm ERR! extraneous: @npmcli/fs@3.1.0 /opt/iobroker/node_modules/@npmcli/fs
                                  npm ERR! extraneous: @npmcli/move-file@1.1.2 /opt/iobroker/node_modules/@npmcli/move-file
                                  npm ERR! extraneous: @root/acme@3.1.0 /opt/iobroker/node_modules/@root/acme
                                  npm ERR! extraneous: @root/greenlock@4.0.5 /opt/iobroker/node_modules/@root/greenlock
                                  npm ERR! extraneous: @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
                                  npm ERR! extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                                  npm ERR! extraneous: @sentry/hub@6.19.7 /opt/iobroker/node_modules/@sentry/hub
                                  npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
                                  npm ERR! extraneous: @serialport/binding-abstract@9.2.3 /opt/iobroker/node_modules/@serialport/binding-abstract
                                  npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
                                  npm ERR! extraneous: @serialport/bindings-cpp@10.8.0 /opt/iobroker/node_modules/@serialport/bindings-cpp
                                  npm ERR! extraneous: @serialport/bindings@9.2.8 /opt/iobroker/node_modules/@serialport/bindings
                                  npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
                                  npm ERR! extraneous: @smithy/abort-controller@2.2.0 /opt/iobroker/node_modules/@smithy/abort-controller
                                  npm ERR! extraneous: @smithy/config-resolver@2.2.0 /opt/iobroker/node_modules/@smithy/config-resolver
                                  npm ERR! extraneous: @smithy/core@1.4.0 /opt/iobroker/node_modules/@smithy/core
                                  npm ERR! extraneous: @smithy/credential-provider-imds@2.3.0 /opt/iobroker/node_modules/@smithy/credential-provider-imds
                                  npm ERR! extraneous: @smithy/eventstream-codec@2.2.0 /opt/iobroker/node_modules/@smithy/eventstream-codec
                                  npm ERR! extraneous: @smithy/fetch-http-handler@2.5.0 /opt/iobroker/node_modules/@smithy/fetch-http-handler
                                  npm ERR! extraneous: @smithy/hash-node@2.2.0 /opt/iobroker/node_modules/@smithy/hash-node
                                  npm ERR! extraneous: @smithy/invalid-dependency@2.2.0 /opt/iobroker/node_modules/@smithy/invalid-dependency
                                  npm ERR! extraneous: @smithy/is-array-buffer@2.2.0 /opt/iobroker/node_modules/@smithy/is-array-buffer
                                  npm ERR! extraneous: @smithy/middleware-content-length@2.2.0 /opt/iobroker/node_modules/@smithy/middleware-content-length
                                  npm ERR! extraneous: @smithy/middleware-endpoint@2.5.0 /opt/iobroker/node_modules/@smithy/middleware-endpoint
                                  npm ERR! extraneous: @smithy/middleware-retry@2.2.0 /opt/iobroker/node_modules/@smithy/middleware-retry
                                  npm ERR! extraneous: @smithy/middleware-serde@2.3.0 /opt/iobroker/node_modules/@smithy/middleware-serde
                                  npm ERR! extraneous: @smithy/middleware-stack@2.2.0 /opt/iobroker/node_modules/@smithy/middleware-stack
                                  npm ERR! extraneous: @smithy/node-config-provider@2.3.0 /opt/iobroker/node_modules/@smithy/node-config-provider
                                  npm ERR! extraneous: @smithy/node-http-handler@2.5.0 /opt/iobroker/node_modules/@smithy/node-http-handler
                                  npm ERR! extraneous: @smithy/property-provider@2.2.0 /opt/iobroker/node_modules/@smithy/property-provider
                                  npm ERR! extraneous: @smithy/protocol-http@3.3.0 /opt/iobroker/node_modules/@smithy/protocol-http
                                  npm ERR! extraneous: @smithy/querystring-builder@2.2.0 /opt/iobroker/node_modules/@smithy/querystring-builder
                                  npm ERR! extraneous: @smithy/querystring-parser@2.2.0 /opt/iobroker/node_modules/@smithy/querystring-parser
                                  npm ERR! extraneous: @smithy/shared-ini-file-loader@2.4.0 /opt/iobroker/node_modules/@smithy/shared-ini-file-loader
                                  npm ERR! extraneous: @smithy/signature-v4@2.2.0 /opt/iobroker/node_modules/@smithy/signature-v4
                                  npm ERR! extraneous: @smithy/smithy-client@2.5.0 /opt/iobroker/node_modules/@smithy/smithy-client
                                  npm ERR! extraneous: @smithy/types@2.12.0 /opt/iobroker/node_modules/@smithy/types
                                  npm ERR! extraneous: @smithy/url-parser@2.2.0 /opt/iobroker/node_modules/@smithy/url-parser
                                  npm ERR! extraneous: @smithy/util-base64@2.3.0 /opt/iobroker/node_modules/@smithy/util-base64
                                  npm ERR! extraneous: @smithy/util-body-length-browser@2.2.0 /opt/iobroker/node_modules/@smithy/util-body-length-browser
                                  npm ERR! extraneous: @smithy/util-body-length-node@2.3.0 /opt/iobroker/node_modules/@smithy/util-body-length-node
                                  npm ERR! extraneous: @smithy/util-buffer-from@2.2.0 /opt/iobroker/node_modules/@smithy/util-buffer-from
                                  npm ERR! extraneous: @smithy/util-config-provider@2.3.0 /opt/iobroker/node_modules/@smithy/util-config-provider
                                  npm ERR! extraneous: @smithy/util-defaults-mode-browser@2.2.0 /opt/iobroker/node_modules/@smithy/util-defaults-mode-browser
                                  npm ERR! extraneous: @smithy/util-defaults-mode-node@2.3.0 /opt/iobroker/node_modules/@smithy/util-defaults-mode-node
                                  npm ERR! extraneous: @smithy/util-endpoints@1.2.0 /opt/iobroker/node_modules/@smithy/util-endpoints
                                  npm ERR! extraneous: @smithy/util-hex-encoding@2.2.0 /opt/iobroker/node_modules/@smithy/util-hex-encoding
                                  npm ERR! extraneous: @smithy/util-middleware@2.2.0 /opt/iobroker/node_modules/@smithy/util-middleware
                                  npm ERR! extraneous: @smithy/util-retry@2.2.0 /opt/iobroker/node_modules/@smithy/util-retry
                                  npm ERR! extraneous: @smithy/util-stream@2.2.0 /opt/iobroker/node_modules/@smithy/util-stream
                                  npm ERR! extraneous: @smithy/util-uri-escape@2.2.0 /opt/iobroker/node_modules/@smithy/util-uri-escape
                                  npm ERR! extraneous: @smithy/util-utf8@2.3.0 /opt/iobroker/node_modules/@smithy/util-utf8
                                  npm ERR! extraneous: @tuyapi/cloud@0.6.2 /opt/iobroker/node_modules/@tuyapi/cloud
                                  npm ERR! extraneous: @typescript-eslint/eslint-plugin@6.21.0 /opt/iobroker/node_modules/@typescript-eslint/eslint-plugin
                                  npm ERR! extraneous: @typescript-eslint/parser@6.21.0 /opt/iobroker/node_modules/@typescript-eslint/parser
                                  npm ERR! extraneous: @typescript-eslint/type-utils@6.21.0 /opt/iobroker/node_modules/@typescript-eslint/type-utils
                                  npm ERR! extraneous: @typescript-eslint/typescript-estree@6.21.0 /opt/iobroker/node_modules/@typescript-eslint/typescript-estree
                                  npm ERR! extraneous: @typescript-eslint/utils@6.21.0 /opt/iobroker/node_modules/@typescript-eslint/utils
                                  npm ERR! extraneous: @zwave-js/config@9.6.1 /opt/iobroker/node_modules/@zwave-js/config
                                  npm ERR! extraneous: @zwave-js/core@12.4.3 /opt/iobroker/node_modules/@zwave-js/core
                                  npm ERR! extraneous: @zwave-js/host@9.6.0 /opt/iobroker/node_modules/@zwave-js/host
                                  npm ERR! extraneous: @zwave-js/nvmedit@9.6.0 /opt/iobroker/node_modules/@zwave-js/nvmedit
                                  npm ERR! extraneous: @zwave-js/serial@9.6.0 /opt/iobroker/node_modules/@zwave-js/serial
                                  npm ERR! extraneous: @zwave-js/shared@12.2.3 /opt/iobroker/node_modules/@zwave-js/shared
                                  npm ERR! extraneous: cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
                                  npm ERR! missing: colors@^1.3.3, required by iobroker.inst@2.0.3
                                  npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/combined-stream
                                  npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/debug
                                  npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                  npm ERR! extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                  npm ERR! extraneous: eckles@1.4.1 /opt/iobroker/node_modules/eckles
                                  npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
                                  npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                  npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/extend
                                  npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                  npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
                                  npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                                  npm ERR! missing: iobroker.admin@6.2.23, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.alarm@3.1.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.alexa2@3.23.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.backitup@2.5.4, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.bring@^1.8.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.cloud@4.3.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.device-reminder@^1.2.9, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.devices@1.1.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.discovery@3.1.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.dysonairpurifier@^2.5.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.echarts@1.0.12, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.email@1.1.4, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.fahrplan@1.2.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.fb-checkpresence@1.1.20, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.flot@^1.11.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.fullcalendar@^1.2.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.geofency@1.2.4, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.ham@5.3.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.history@2.2.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.homekit-controller@^0.5.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.hue-extended@^2.0.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.hue@3.7.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.ical@1.13.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-addictive-flavour-png@^0.1.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-fatcow-hosting@^0.1.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-material-png@^0.1.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-material-svg@^0.1.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-mfd-png@^1.1.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-mfd-svg@^1.1.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-open-icon-library-png@^0.1.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.icons-ultimate-png@^1.0.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.influxdb@3.1.8, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.info@^1.9.19, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.iot@1.11.9, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.javascript@6.0.3, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.js-controller@^4.0.23, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.kecontact@1.5.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.mihome@1.4.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.mobile@^1.0.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.modbus@5.0.11, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.moma@^1.2.9, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.netatmo-crawler@0.8.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.netatmo@2.0.5, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.nuki-extended@^2.3.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.nuki@^1.6.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.parser@1.1.8, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.samsung2016@https://github.com/Stefan0875/iobroker.samsung2016/tarball/1cacc9041ea38eae6d55023dcc9c23d2921fc5f0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.sayit@github:ioBroker/ioBroker.sayit#master, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.scenes@2.3.9, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.simple-api@2.7.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.solaredge@github:92lleo/ioBroker.solaredge#189bb28347e0cfeffaa6b2b0b21c2534d827fbf9, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.sonos@2.2.3, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.spotify-premium@1.2.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.sql@2.1.8, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.swiss-weather-api@1.0.4, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.synology@2.1.13, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.tahoma@0.7.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.telegram@1.14.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.tesla-motors@1.3.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.traccar@0.0.12, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.tuya@3.9.4, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-bars@^0.1.4, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-history@^1.0.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-hqwidgets@1.3.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-icontwo@0.90.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-inventwo@3.3.1, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-keyboard@0.0.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-material-advanced@^1.7.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-players@^0.1.6, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-rgraph@0.0.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-timeandweather@1.2.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis-weather@2.5.6, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.vis@1.4.15, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.weatherunderground@3.4.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.web@4.3.0, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.whatsapp-cmb@0.2.2, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.zigbee@1.7.6, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.zwave2@2.5.0, required by iobroker.inst@2.0.3
                                  npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                  npm ERR! extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                  npm ERR! extraneous: keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
                                  npm ERR! extraneous: le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
                                  npm ERR! extraneous: le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
                                  npm ERR! extraneous: le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
                                  npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                  npm ERR! extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                  npm ERR! extraneous: mdns@ /opt/iobroker/node_modules/mdns
                                  npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                                  npm ERR! extraneous: oauth-sign@0.9.0 /opt/iobroker/node_modules/oauth-sign
                                  npm ERR! extraneous: object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
                                  npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
                                  npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
                                  npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                                  npm ERR! extraneous: pump@2.0.1 /opt/iobroker/node_modules/pump
                                  npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                                  npm ERR! extraneous: rasha@1.2.5 /opt/iobroker/node_modules/rasha
                                  npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                  npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer
                                  npm ERR! extraneous: safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
                                  npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                                  npm ERR! missing: semver@^5.6.0, required by iobroker.inst@2.0.3
                                  npm ERR! extraneous: sqlite3@ /opt/iobroker/node_modules/sqlite3
                                  npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                                  npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
                                  npm ERR! extraneous: ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
                                  npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                                  npm ERR! extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                  npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
                                  npm ERR! missing: yargs@^7.0.2, required by iobroker.inst@2.0.3
                                  ├── @smithy/invalid-dependency@2.2.0 extraneous
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-16T20_12_07_709Z-debug-0.log
                                  Und beim direkten Update vom Admin Adapter kommt folgendes:
                                  pi@raspberrypi:~ $ iobroker upgrade admin --debug
                                  This upgrade of "admin" will at least introduce the following changes:
                                  -> 6.13.16:
                                  allow to display and modify `ics` files
                                  redirect correctly when exiting json config with unsaved changes
                                  -> 6.13.15:
                                  fixed scrolling of Select ID dialogs
                                  -> 6.13.14:
                                  internal optimizations
                                  -> 6.13.13:
                                  -> 6.13.12:
                                  -> 6.13.11:
                                  -> 6.13.10:
                                  Would you like to upgrade admin from @6.2.23 to @6.13.16 now? [(y)es, (n)o]: y
                                  Update admin from @6.2.23 to @6.13.16
                                  host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                                  NPM version: 10.2.4
                                  Installing iobroker.admin@6.13.16... (System call)
                                  npm WARN skipping integrity check for git dependency ssh://git@github.com/92lleo/ioBroker.solaredge.git
                                  npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                                  npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                  npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                  npm WARN deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                  npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                                  npm WARN deprecated domexception@4.0.0: Use your platform's native DOMException instead
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated @azure/msal-node@1.18.4: A newer major version of this library is available. Please upgrade to the latest available version.
                                  npm WARN deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                                  npm WARN deprecated hafas-client@5.26.5: I don't have the capacity to maintain older versions of hafas-client, sorry. Please use hafas-client@latest.
                                  npm WARN deprecated @azure/msal-browser@2.38.3: A newer major version of this library is available. Please upgrade to the latest available version.
                                   Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                   States database error: connect ECONNREFUSED 127.0.0.1:9000
                                  npm WARN cleanup Failed to remove some directories [
                                  npm WARN cleanup   [
                                  npm WARN cleanup     '/opt/iobroker/node_modules/mdns',
                                  npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/mdns'] {
                                  npm WARN cleanup       errno: -39,
                                  npm WARN cleanup       code: 'ENOTEMPTY',
                                  npm WARN cleanup       syscall: 'rmdir',
                                  npm WARN cleanup       path: '/opt/iobroker/node_modules/mdns'
                                  npm WARN cleanup     }
                                  npm WARN cleanup   ],
                                  npm WARN cleanup   [
                                  npm WARN cleanup     }
                                  npm WARN cleanup   ],
                                  npm WARN cleanup   [
                                  npm WARN cleanup     '/opt/iobroker/node_modules/sqlite3',
                                  npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/sqlite3'] {
                                  npm WARN cleanup       path: '/opt/iobroker/node_modules/sqlite3'
                                  npm WARN cleanup     }
                                  npm WARN cleanup   ],
                                  npm WARN cleanup   [
                                  npm WARN cleanup     }
                                  npm WARN cleanup   ]
                                  npm WARN cleanup ]
                                  npm ERR! code 1
                                  npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                  npm ERR! command failed
                                  npm ERR! command sh -c node iobroker.js setup first
                                  npm ERR! /opt/iobroker/node_modules/string-width/index.js:2
                                  npm ERR! const stripAnsi = require('strip-ansi');
                                  npm ERR!                   ^
                                  npm ERR!
                                  npm ERR! Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/string-width/node_modules/strip-ansi/index.js from /opt/iobroker/node_modules/string-width/index.js not supported.
                                  npm ERR! Instead change the require of /opt/iobroker/node_modules/string-width/node_modules/strip-ansi/index.js in /opt/iobroker/node_modules/string-width/index.js to a dynamic import() which is available in all CommonJS modules.
                                  npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/string-width/index.js:2:19)
                                  npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/cliui/build/index.cjs:291:21)
                                  npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:60678)
                                  npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:5:30)
                                  npm ERR!     at initYargs (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:42:13)
                                  npm ERR!     at module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3305:20)
                                  npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24) {
                                  npm ERR!   code: 'ERR_REQUIRE_ESM'
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR! Node.js v18.19.1
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-16T19_29_57_336Z-debug-0.log
                                  Could not install iobroker.admin@6.13.16: Could not determine controller directory
                                  Cannot upgrade: Could not determine controller directory
                                  mikeal created this issue in request/request
                                  open Request’s Past, Present and Future #3142
                                  Qix- created this issue in visionmedia/debug
                                  closed ReDos Vulnerability Regression Visibility Notice #797
                                    danielos @danielos last edited by
                                    Und beim manuellen Start von admin klappt's nun auch nicht mehr.. hmm...
                                    pi@raspberrypi:~ $ iob start admin.0
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                        at node:internal/main/run_main_module:28:49 {
                                      requireStack: []
                                    Node.js v18.19.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.1
                                      Upsi ...
                                      pi@raspberrypi:/opt/iobroker $ iob stop
                                      pi@raspberrypi:/opt/iobroker $ iob fix
                                      library: loaded
                                      Library version=2024-01-04
                                      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                        @danielos
                                        iob status
                                        iob update
                                        iob add admin
                                          iob add admin
                                          überall der selbe Output:
                                          pi@raspberrypi:~ $ iob status
                                            throw err;
                                            requireStack: []
                                          Node.js v18.19.1
                                            @Thomas-Braun @Homoran
                                            Mit einem
                                            Und einem separaten Start von admin ist das Gui mal wieder da... und es scheint alles zu laufen. Halt immer noch auf dem Stand des alten Admin-Adapters, aber es läuft. Ich glaube, ich lass es im Moment mal lieber so, bis ich ein volles Update mache. 😉
                                            Danke vielmals für eure Hilfe!
                                            1991
