    4. Test Adapter Weather-Warnings
      ticaki Developer last edited by ticaki
      Hey hat noch jemand das Problem:
      eine ausgehende Warnung, dann schreibt telegram das ins log
      2024-01-16 14:18:52.635 - error: telegram.0 (663) Failed sending [chatId - 995922549]: Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      2024-01-16 14:18:54.688 - error: telegram.0 (663) Failed sending [chatId - 995922549]: Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      2024-01-16 14:19:12.056 - error: telegram.0 (663) Failed sending [chatId - 995922549]: Error: ETELEGRAM: 429 Too Many Requests: retry after 11
      Und ich bekomme ca. 30 Nachrichten pro Sekunde. Bis ich den Telegram-Adapter neu starte?
      rtwl 1 Reply Last reply Reply Quote 0
      • rtwl
        rtwl @ticaki last edited by
        @ticaki
        ich nutze nur pushover und da klappt es einwandfrei
          ticaki Developer @rtwl last edited by
          @rtwl
          Hab oben vergessen zu erwähnen das ich den Telegram Adapter neustarte nicht diesen. Ich werfe mal alle sendToAsync() raus, die machen nur probleme.
            Neue Version ist auf dem Weg.
            • Reduziere die Anzahl Einträge bei History/Verlauf auf 80 Stück, hat gerade bei mir mit ca 120 geruckelt (6500 Zeilen)
              Wurzelfuchs last edited by
              • ich habe den Adapter installiert und bekomme folgende Fehlermeldung im Protokoll:
              weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_Additional_settings/items/silentTime/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","fileSelector","text","textSendTo","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid","timePicker","datePicker"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_Additional_settings","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
              kann mir da jemand helfen, was das bedeutet?
              • Ist es möglich, unter E-Mail einen Empfänger zu definieren?
                hab leider keine entsprechende Einstellung gefunden.
              mcm1957 T 3 Replies Last reply Reply Quote -1
              • mcm1957
                mcm1957 @Wurzelfuchs last edited by mcm1957
                @wurzelfuchs
                Bitte bei Problemen immer die entsprechenden Versionen angeben:
                Adapterversion?
                P.S: Du kannst die Warning ziemlich sicher mal ignorieren
                @ticaki
                Falls das ein json Schema Fehler ist, leg bitte ein Issue an sollte kein offenens existiereren. Foxriver hat eigentlich die bekannten mittlerweile gefixed
                  ticaki Developer @Wurzelfuchs last edited by ticaki
                  @wurzelfuchs
                  Den Fehler kannst du ignorieren, der kommt von einer fehlenden Definition im Admin.
                  https://github.com/ioBroker/adapter-react-v5/issues/195
                  Email Empfänger kann man aktuell nicht angeben, kannst du bitte auf Github eine entsprechende Feature Request aufmachen. Ich schaue dann mal wie ich das einbau, hab aktuell sehr wenig Zeit.
                  foxriver76 created this issue in ioBroker/adapter-react-v5
                  closed add component `accordion` to schema #195
                    @wurzelfuchs
                    ist vor ein paar Minuten gefixt worden. Wenn admin >v6.13.21 verfügbar ist, sollte der Fehler nicht mehr erscheinen.
                      Wurzelfuchs @ticaki last edited by
                      @ticaki Danke für die schnelle Rückmeldung!
                        spike2 last edited by spike2
                        @ticaki
                        Ich habe in der NewJson noch einige Parameter bei mir eingefügt, alle funktionieren bis auf die Handlungsanweisung (instruction).
                        So sieht der letze Teil der NewJson aus.
                        "Beschreibung": "${description}", "Handlungsanweisung": "${instruction"\}
                        Auszug der Json:
                        "Beschreibung":"Es tritt leichter Frost zwischen -3 °C und -5 °C auf.","Handlungsanweisung":"instruction"}]
                        Datenpunkt:
                        weather-warnings.0.provider.dwd.------------.formatedKeys.00.instruction
                        Hinweis auf mögliche Frostschäden.
                        Handlungsempfehlungen: ggf. Frostschutzmaßnahmen ergreifen
                        Hast du eine Idee, warum die Handlungsanweisung in der Json nicht gefüllt wird?
                        T T 2 Replies Last reply Reply Quote 0
                          TT-Tom @spike2 last edited by TT-Tom
                          @spike2
                          Würde sagen deine Anführungszeichen sind falsch gesetzt, siehe dir das mal bei Beschreibung an.
                            ticaki Developer @spike2 last edited by ticaki
                            @spike2
                            Wie Tom geschrieben hat. "${token}" das \} gehört zum Json und nicht zum Token.
                              Beide Varianten getestet, Fehlermeldung im Adapter:
                              [json] Json template has wrong formate. Conversion deactivated! template: NewJson
                              "Handlungsanweisung": "${instruction}" \}
                              "Handlungsanweisung": "${instruction}"\}
                              So steht es auch in der Doku drin 🙂
                                @spike2 sagte in Test Adapter Weather-Warnings:
                                bitte das ganze template
                                  spike2 @ticaki last edited by
                                  @ticaki
                                  { "action": "${status}", "startdatum": "${startdate}", "start": "${starttime}", "enddatum": "${enddate}", "ende": "${endtime}", "type": "${warntypename}", "Stufe": "${warnlevelnumber}", "Beschreibung": "${description}", "Handlungsanweisung": "${instruction}" \}
                                    @spike2 schon mal ohne \ probiert?
                                      @spike2
                                      Ich sehe keinen Fehler und bei mir geht es... mal alle "getauscht, bei mir waren da mal falsche drin. Wie auch immer die da hingekommen sind.
                                        ticaki Developer @TT-Tom last edited by
                                        @tt-tom sagte in Test Adapter Weather-Warnings:
                                        das \ muß da hin
                                          spike2 @ticaki last edited by spike2
                                          @ticaki echt komisch, ich hatte das Template schon eine Weile zu laufen, hat wunderbar funktioniert.
                                          Dann habe ich den Part hinten rangehangen...
                                          ... und seit dem funktioniert es nicht mehr. 😂
                                          Ich prüfe morgen nochmal die "Anführungszeichen"
                                            @spike2
                                            ok wenns echt nicht geht mache bitte ein issue auf.
                                            1077
                                            269104
