    4. Lösung für GPS-Koordinaten nach Ortsnamen aufschlüsseln?
      lemuba @fastfoot last edited by lemuba
      @fastfoot
      Vielen Dank erstmal für Deine schnelle Rückmeldung, aber ich scheitere aktuell mal wieder daran, dass JS nicht wirklich meins ist, ich Dein Script und Blockly Vorlage nicht zum Laufen bekomme:
      javascript.0
         2021-06-11 09:41:00.440	error	at processImmediate (internal/timers.js:463:21)
      javascript.0
         2021-06-11 09:41:00.440	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1281:17)
      javascript.0
         2021-06-11 09:41:00.440	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:1791:17
      javascript.0
         2021-06-11 09:41:00.439	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1690:37)
      javascript.0
         2021-06-11 09:41:00.439	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1443:28)
      javascript.0
         2021-06-11 09:41:00.439	error	at Object.createScript (vm.js:261:10)
      javascript.0
         2021-06-11 09:41:00.439	error	at new Script (vm.js:88:7)
      javascript.0
         2021-06-11 09:41:00.439	error	SyntaxError: Unexpected token '<'
      javascript.0
         2021-06-11 09:41:00.439	error	^
      javascript.0
         2021-06-11 09:41:00.439	error	<xml xmlns="https://developers.google.com/blockly/xml">
      javascript.0
         2021-06-11 09:41:00.438	error	script.js.common.Twingo_Position compile failed: at script.js.common.Twingo_Position:5
      javascript.0
         2021-06-11 09:41:00.438	info	Start javascript script.js.common.Twingo_Position
      <variables>
        <variable id="2]3hGy$Na|L2qX#+=;E8">lat</variable>
        <variable id=".hv$JjjT(QY(0c2!/tuc">lon</variable>
        <variable id="InM51wH+hhRZ1K}Uo6R:">result</variable>
      </variables>
      <block type="procedures_defcustomreturn" id="?;wMWdJ!vB8:m#;$39f@" x="38" y="13">
        <mutation statements="false">
          <arg name="lat" varid="2]3hGy$Na|L2qX#+=;E8"></arg>
          <arg name="lon" varid=".hv$JjjT(QY(0c2!/tuc"></arg>
        </mutation>
        <field name="NAME">OSM</field>
        <field name="SCRIPT">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</field>
      <block type="variables_set" id="wR~~7^?!0{b~ZWJW2z2Y" x="37" y="38">
        <field name="VAR" id="2]3hGy$Na|L2qX#+=;E8">lat</field>
          <block type="math_number" id="v8.pty,webLT%vmOMImD">
            <field name="NUM">52.1</field>
          <block type="variables_set" id="|i,e7-xsVZtwL,YE9Pns">
            <field name="VAR" id=".hv$JjjT(QY(0c2!/tuc">lon</field>
              <block type="math_number" id="F%,]J2e:+Px%t}H3@a{E">
                <field name="NUM">13.3291</field>
              <block type="variables_set" id="_]-UxYH%D~}#l6DWPyqA">
                <field name="VAR" id="InM51wH+hhRZ1K}Uo6R:">result</field>
                  <block type="procedures_callcustomreturn" id="E6q6k3RA-DSW4n:wbmt5" inline="true">
                    <mutation name="OSM">
                      <arg name="lat"></arg>
                      <arg name="lon"></arg>
                    </mutation>
                    <value name="ARG0">
                      <block type="variables_get" id="O~3vjlaQApGabQ#KZ_Np">
                    <value name="ARG1">
                      <block type="variables_get" id=";6In%LVgU8c~ZW=V^#!+">
                  <block type="debug" id="=kG9Q3BHtv,N12i)o/cd">
                    <value name="TEXT">
                      <shadow type="text" id="ik1UI0{#imdw4QxI,wuq">
                      <block type="variables_get" id="ZJbVSK}WTjai..N)v+^}">
                      <block type="debug" id="bXiZr_w6h{,9I,J|QFQm">
                        <value name="TEXT">
                          <shadow type="text" id="29,6%MJ)T!m#9$n(HA(,">
                          <block type="get_attr" id="4BRp8)RL(Z,ya1V7L%,k">
                            <value name="PATH">
                              <shadow type="text" id="@+Kn.LF%vkB35cm%To%G">
                                <field name="TEXT">address.road</field>
                            <value name="OBJECT">
                              <block type="variables_get" id="/rsi@S]q*[hct$N@3[U^">
                          <block type="debug" id="dAc9;C;}EM{;795yOx+x">
                            <value name="TEXT">
                              <shadow type="text">
                              <block type="get_attr" id="LpeSM|-_`@#YwXXZj!J@">
                                <value name="PATH">
                                  <shadow type="text" id="Z^$s~_s3A]lS:_m9AjB(">
                                    <field name="TEXT">display_name</field>
                                  <block type="variables_get" id="O[`[O5l$sBBY(*B]Rh9U">
      </xml>return 0;
      Hmm? Komme da gerade nicht wirklich weiter...
        fastfoot @lemuba last edited by
        @lemuba es braucht keine Kenntnisse, importieren und laufen lassen. Evtl. kopierst du nochmal neu, sonst fällt mir nichts ein
          @fastfoot
          😁: Das war Zu Einfach! 😂 Ich hatte nicht geschnallt, das der ganze Code das Blockly Script zum Import ist...läuft!
          Vielen Dank nochmal!
          Gruß,
          Matthias
            lemuba @lemuba last edited by lemuba
            @fastfoot
            So, nun sabbelt auch Alexa...Super!:
             <variables>
               <variable id=",v4l/N^bA;j*N;f.7`GF">text</variable>
             </variables>
             <block type="procedures_defcustomreturn" id="?;wMWdJ!vB8:m#;$39f@" x="-337" y="-212">
               </mutation>
             <block type="variables_set" id="wR~~7^?!0{b~ZWJW2z2Y" x="-337" y="-187">
                 <block type="get_value" id="!@Mxm]aCD#|[2(1,`7LA">
                   <field name="OID">zoe2.0.VF1AH000867277927.gpsLatitude</field>
                     <block type="get_value" id="6)]4V(MA}[}Y#gCg?g7^">
                       <field name="OID">zoe2.0.VF1AH000867277927.gpsLongitude</field>
                           </mutation>
                           <value name="ARG0">
                           <value name="ARG1">
                           <value name="TEXT">
                               <value name="TEXT">
                                   <value name="PATH">
                                   <value name="TEXT">
                                       <value name="PATH">
                                     <block type="variables_set" id=":iDZr5UyCe,ivtP9v0(}">
                                       <field name="VAR" id=",v4l/N^bA;j*N;f.7`GF">text</field>
                                         <block type="text_join" id="XSLUXB!wN!-ae:pl;O8B">
                                           <value name="ADD0">
                                             <block type="text" id=")D7vowpY0M+s6mmej`e~">
                                               <field name="TEXT">Die letzte bekannte Position vom Twingo ist</field>
                                           <value name="ADD1">
                                             <block type="get_attr" id="7)#yq0v]M`9Jq`m0cy7S">
                                               <value name="PATH">
                                                 <shadow type="text" id="MhmHkgxcrvue.(%x_);=">
                                                 <block type="variables_get" id="fALiXhV.H^AKH}ayNLG:">
                                         <block type="control_ex" id="3.b7x=Y=}_7C/tkVNgYx">
                                           <value name="OID">
                                             <shadow type="field_oid" id="~-7qx26`v]-Z|K~6?:mY">
                                               <field name="oid">alexa2.0.Echo-Devices.G0918309043207MF.Commands.speak</field>
                                             <shadow type="logic_boolean" id="`CrJ%d8H%,cuK!(!(eVz">
                                             <block type="variables_get" id="_v]kAoW%5JX#tzQE[8S^">
                                           <value name="DELAY_MS">
                                             <shadow type="math_number" id="u$3PdNKAuZEltUgrA:}#">
                                               <field name="NUM">1000</field>
                                             <block type="control" id="T#!W2tOCAiMZT)Do_^[%">
                                               <field name="OID">javascript.0.scriptEnabled.Twingo_Position</field>
                                               <field name="DELAY_MS">2</field>
                                                 <block type="logic_boolean" id="]yXqp^C@1w9a^uyTmw}6">
              Hier noch ein kleines Update, welches ohne das lästige wait() auskommt. request() wird in eine Funktion gepackt, welche ein Promise zurück gibt auf das man mit await warten kann.
               <variables>
                 <variable id="J3x^9.8?y5q~@YX!.0vq">zoom</variable>
               </variables>
                   <arg name="zoom" varid="J3x^9.8?y5q~@YX!.0vq"></arg>
                 </mutation>
                 <field name="NAME">OSM_Reverse</field>
                 <field name="SCRIPT">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</field>
                     <field name="NUM">48.1374622</field>
                         <field name="NUM">11.5802315</field>
                       <block type="variables_set" id="gV3k#TgOw[TwD3PggX_z">
                         <field name="VAR" id="J3x^9.8?y5q~@YX!.0vq">zoom</field>
                           <block type="math_number" id="RiaGr]H5DPjOiCLI$~+H">
                             <field name="NUM">18</field>
                                 <mutation name="OSM_Reverse">
                                   <arg name="zoom"></arg>
                                 </mutation>
                                 <value name="ARG0">
                                 <value name="ARG1">
                                 <value name="ARG2">
                                   <block type="variables_get" id="!Lp;DYb2Cg#%7WJ[ixj:">
                               <block type="debug" id="=kG9Q3BHtv,N12i)o/cd" inline="true">
                                 <value name="TEXT">
                                   <block type="debug" id="bXiZr_w6h{,9I,J|QFQm" inline="true" disabled="true">
                                     <value name="TEXT">
                                         <value name="PATH">
                                       <block type="debug" id="dAc9;C;}EM{;795yOx+x" inline="true">
                                         <value name="TEXT">
                                             <value name="PATH">
              • David G.
                Hey,
                läuft bei euch das Script noch?
                Seit heute bekomme ich
                20:12:05.729	error	javascript.0 (5273) script.js.Eigene_Scripte.Tests.Loschen: Cannot get address of undefined
                Im Log.
                (muss das Skript noch umbenennen ^^).
                Hab gestern ein Update des Javascript Adapters gemacht. Zusammen mit Admin 5.
                Die Koordinaten sind sauber.
                  fastfoot @David G. last edited by
                  @david-g läuft hier
                  • David G.
                    David G. @fastfoot last edited by David G.
                    @fastfoot
                    Komisch.
                    Hat OSM ein Limit für Anfragen?
                    Grage minütlich ab. Läuft aber bestimmt schon seit 3 Wochen ohne Probleme.....
                    Setzte die Adresse nochmal selber zusammen. OSM sendet die was komisch....
                    EDIT:
                    Hab grad mal das Internet neu verbunden um eine neue IP zu bekommen.
                    Siehe da, es klappt wieder.
                      Das Ganze läuft jetzt auch super mit dem Awtrix Adapter, bzw. Ausgabe auf dem Ulanzi Matrix Display:
                      Hier mal die Visualisierung der Adressdaten, plus aktuellen Geschwindigkeit - nun aber mit unserem Tesla M3.
                      Blockly Export/Import:
                        <variables>
                        </variables>
                          </mutation>
                          <field name="SCRIPT">dmFyIHJlcXVlc3QgPXJlcXVpcmUoJ3JlcXVlc3QnKTsNCmxldCByZXN1bHQ7DQpjb25zdCBvcHRpb25zID0gew0KICAgIHVybDogJ2h0dHBzOi8vbm9taW5hdGltLm9wZW5zdHJlZXRtYXAub3JnL3JldmVyc2UucGhwP2Zvcm1hdD1qc29uJmxhdD0nICsgbGF0ICsgJyZsb249JyArIGxvbiArICcmem9vbT0xOCcsDQogICAgbWV0aG9kOiAnR0VUJywNCiAgICBoZWFkZXJzOiB7DQogICAgICAgICdBY2NlcHQnOiAnYXBwbGljYXRpb24vanNvbicsDQogICAgICAgICdBY2NlcHQtQ2hhcnNldCc6ICd1dGYtOCcsDQogICAgICAgICdVc2VyLUFnZW50JzogJ2lvYnJva2VyIHNjcmlwdCcNCiAgICB9DQp9DQoNCnJlcXVlc3Qob3B0aW9ucywgZnVuY3Rpb24oZXJyLHJlc3BvbnNlLGJvZHkpew0KICAgIHJlc3VsdCA9IEpTT04ucGFyc2UoYm9keSk7DQp9KQ0KYXdhaXQgd2FpdCgyMDAwKTsNCnJldHVybiByZXN1bHQ7</field>
                              <field name="OID">tesla-motors.0.LRW3E7FS7PC682851.drive_state.latitude</field>
                                  <field name="OID">tesla-motors.0.LRW3E7FS7PC682851.drive_state.longitude</field>
                                      </mutation>
                                      <value name="ARG0">
                                      <value name="ARG1">
                                      <value name="TEXT">
                                          <value name="TEXT">
                                              <value name="PATH">
                                              <value name="TEXT">
                                                <shadow type="text" id="/40n%p9iOr{j;fjVE}z7">
                                                  <value name="PATH">
                                                      <mutation items="11"></mutation>
                                                      <value name="ADD0">
                                                          <field name="TEXT">Location: </field>
                                                      <value name="ADD1">
                                                        <block type="get_attr" id="g3uOcVu;z8aYAY7;8Kti">
                                                          <value name="PATH">
                                                            <shadow type="text" id="KArLdm/6uO2yf.]RJDW[">
                                                            <block type="text" id="DMfj]B1V*c^r*po?FozS">
                                                            <block type="variables_get" id="YOh=_SwF-z[BN^8PV(1:">
                                                      <value name="ADD2">
                                                        <block type="text" id="nOZuc!aD}_`wjoaU4!(#">
                                                          <field name="TEXT"> </field>
                                                      <value name="ADD3">
                                                        <block type="get_attr" id="eYJy`^;WpK9z`(0#QkYu">
                                                          <value name="PATH">
                                                            <block type="text" id="Faux=fGpEPkIBk=EH[=d">
                                                              <field name="TEXT">address.house_number</field>
                                                            <block type="variables_get" id="BQ6I:3SHB|S1AGrNGYIt">
                                                      <value name="ADD4">
                                                        <block type="text" id="A(Z{jjQopfoSud(d$_*C">
                                                          <field name="TEXT">, </field>
                                                      <value name="ADD5">
                                                        <block type="get_attr" id="G}a6d%(Qn2WrACG:Ch7|">
                                                          <value name="PATH">
                                                            <block type="text" id="fK{+kZLKFfv~KDF:GIcA">
                                                              <field name="TEXT">address.postcode</field>
                                                            <block type="variables_get" id="7!aEUv#yfH7G0qqNh{fh">
                                                      <value name="ADD6">
                                                        <block type="text" id="QDwYvut3T+?ypaI-Qc~q">
                                                      <value name="ADD7">
                                                        <block type="get_attr" id="#Qg=qhE{]!C9HFrHH#ER">
                                                          <value name="PATH">
                                                            <block type="text" id="/KcU}U$/=t_c2ob{O_}}">
                                                              <field name="TEXT">address.village</field>
                                                            <block type="variables_get" id="O_tQk;@av+BHgqb@VfHp">
                                                      <value name="ADD8">
                                                        <block type="text" id="NenM{G|=MkLu:Y3BXF7?">
                                                          <field name="TEXT">: </field>
                                                      <value name="ADD9">
                                                        <block type="get_value" id=":$dM7(mWFkX;dm?xlo_t">
                                                          <field name="OID">tesla-motors.0.LRW3E7FS7PC682851.drive_state.speed_km</field>
                                                      <value name="ADD10">
                                                        <block type="text" id="_WW=xep+.FfqH/kPAHHO">
                                                          <field name="TEXT"> km/h</field>
                                                    <block type="awtrix-light" id="1JNb12R1PMS^CFOxV:hZ">
                                                      <field name="RAINBOW">TRUE</field>
                                                      <field name="STACK">TRUE</field>
                                                      <field name="WAKEUP">TRUE</field>
                                                      <value name="MESSAGE">
                                                        <shadow type="text" id="Upc}*ndVB5vPx7%#%,f?">
                                                          <field name="TEXT">haus-automatisierung.com</field>
                                                        <block type="variables_get" id="4@]t:R3T*_K_fnc8;i+?">
                                                      <value name="COLOR">
                                                        <shadow type="colour_picker" id="ZO]ra7*|K.7]$apWfB4c">
                                                          <field name="COLOUR">#ffffff</field>
                                                      <value name="SOUND">
                                                        <shadow type="logic_null" id="dc-@fFGA7vT5Z[bTy@aO"></shadow>
                                                      <value name="ICON">
                                                        <shadow type="logic_null" id=",u10)OQ,z.E.;7+eAK9:"></shadow>
                                                        <block type="text" id="n1bTp(7]W[8#UVSbGQcl">
                                                          <field name="TEXT">54394</field>
                                                      <value name="REPEAT">
                                                        <shadow type="math_number" id="ldph$rS`hpmxt,B756f!">
                                                          <field name="NUM">2</field>
                                                      <value name="DURATION">
                                                        <shadow type="math_number" id="8Wgsv0!pZUT@Mg*n?w6y">
                                                          <field name="NUM">20</field>
                                                          <field name="OID">javascript.0.scriptEnabled.common.Tesla_Position</field>
                      • O
                        Oli @fastfoot last edited by
                        @fastfoot
                        ist es auch möglich über die API eine Adresse abzufragen und die Koordinate zu erhalten?
                        David G. Codierknecht 2 Replies Last reply Reply Quote 0
                        • David G.
                          David G. @Oli last edited by
                          @oli
                          Es geht, umsetzen kann ich es aber nicht ^^.
                          https://wiki.openstreetmap.org/wiki/DE:Nominatim
                          • Codierknecht
                            Codierknecht Developer Most Active @Oli last edited by Codierknecht
                            @oli
                            Das hier ist für die Richtung "Koordinaten => Adresse".
                            const axios = require('axios');
                            // Reverse-Geocoding anhand der aktuellen Koordinaten
                            async function getLocation(latitude, longitude) {
                                const url = `https://nominatim.openstreetmap.org/reverse?lat=${latitude}&lon=${longitude}&format=json`;
                                const response = await axios.get(url);
                                if (response.data && response.data.display_name) {
                                  log('Standort: ' + response.data.display_name);
                            • David G.
                              David G. @Codierknecht last edited by David G.
                              @codierknecht sagte in Lösung für GPS-Koordinaten nach Ortsnamen aufschlüsseln?:
                              Das ist doch das was wir schon können oder? Er wollte doch Adresse => Koordinaten oder?
                              • Marc Berg
                                Marc Berg Most Active last edited by Marc Berg
                                @oli
                                So z.B.
                                https://nominatim.openstreetmap.org/search?format=json&q=Berlin, Alexanderplatz 10
                                Du musst nur schauen, ob du das "Zentrum" der jeweiligen Adresse haben willst oder die Boundingbox.
                                • Codierknecht
                                  Codierknecht Developer Most Active @David G. last edited by
                                  @david-g sagte in Lösung für GPS-Koordinaten nach Ortsnamen aufschlüsseln?:
                                  Naja - wenn man Deinen Link und meinen Code kombiniert, könnte man auf sowas kommen:
                                  // Geocoding anhand einer gegebenen Adresse
                                  async function getLocation(address) {
                                      const url = `https://nominatim.openstreetmap.org/search?format=json&q=${encodeURI(address)}`;
                                      if (response.data && response.data.length > 0) {
                                        log(`Latitude: ${response.data[0].lat}, Longitude: ${response.data[0].lon}`);
                                  • O
                                    Oli @Codierknecht last edited by
                                    @codierknecht, @Marc-Berg , @David-G
                                    vielen Dank für eure Unterstützung es funktioniert
                                    gps ortsnamen
                                    1673
