    4. Vis 1 zeigt nach Neuinstallation nichts an
    • peterk34
      peterk34 @DJMarc75 last edited by peterk34
      @djmarc75 alles oder einen bestimmten Bereich?
      			v.2023-10-10
       Static hostname: IOB-KEP
             Icon name: computer
                Kernel: Linux 6.6.20+rpt-rpi-v8
          Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		arm64
      Timezone: 		Europe/Vienna (CET, +0100)
      User-ID: 		1000
      X-Server: 		false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
      			/usr/bin/node 		v18.19.1
      			/usr/bin/npm 		10.2.4
      			/usr/bin/npx 		10.2.4
      			/usr/bin/corepack 	0.22.0
      Recommended versions are nodejs 18.19.1 and npm 10.2.4
      MEMORY:
      Mem:            4.0G        3.1G        159M         24K        743M        827M
      Swap:           104M        104M         65K
      Total:          4.1G        3.3G        159M
      Active iob-Instances: 	30
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.19
      			admin 			6.13.16
      ioBroker Status: 	iobroker is running on this host.
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      + system.adapter.admin.0                  : admin                 : IOB-KEP                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : IOB-KEP                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		44245
      States: 		38986
      Size of iob-Database:
      4.4M	/opt/iobroker/iobroker-data/objects.jsonl
      104K	/opt/iobroker/iobroker-data/states.jsonl
      • DJMarc75
        DJMarc75 @peterk34 last edited by DJMarc75
        @peterk34 um helfen zu können natürlich alles bitte - und in Codetags hier einstellen 😉
        Edit: die Langfassung
        peterk34 1 Reply Last reply Reply Quote 0
        • peterk34
          @djmarc75
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Model		: Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           14:13:24 up  3:29,  2 users,  load average: 1.61, 1.17, 0.93
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2024-03-18 14:13:24 CET
                     Universal time: Mon 2024-03-18 13:13:24 UTC
                           RTC time: n/a
                          Time zone: Europe/Vienna (CET, +0100)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Mem:            4.0G        3.2G        179M         16K        709M        814M
          Swap:           104M        104M        225K
          Total:          4.1G        3.3G        179M
                   3791 M total memory
                   3014 M used memory
                   2040 M active memory
                   1452 M inactive memory
                    170 M free memory
                     14 M buffer memory
                    662 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.2M  378M   1% /run
          /dev/sda2      ext4      939G  6.1G  885G   1% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          /dev/sda1      vfat      510M   63M  448M  13% /boot/firmware
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Mon Mar 18 10:43:44 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:36:E3:17 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=8e935de8-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon Mar 18 10:43:50 2024] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
          [Mon Mar 18 10:43:51 2024] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,noatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.3G	/var/
          832M	/var/lib
          629M	/var/lib/redis
          224M	/var/cache
          218M	/var/cache/apt
          Archived and active journals take up 168.0M in the file system.
          /opt/iobroker/backups:
          21M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          19M	/opt/iobroker/iobroker-data/
          15M	/opt/iobroker/iobroker-data/files
          13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
          1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
          652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/npm 		10.2.4
          /usr/bin/npx 		10.2.4
          nodejs:
            Installed: 18.19.1-1nodesource1
            Candidate: 18.19.1-1nodesource1
            Version table:
           *** 18.19.1-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.19.0+dfsg-6~deb12u1 500
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: redis
          States  type: redis
          Core adapters versions
          js-controller: 	5.0.19
          admin: 		6.13.16
          javascript: 	7.8.0
          Adapters from github: 	1
          Adapter State
          + system.adapter.alexa2.0                 : alexa2                : IOB-KEP                                  -  enabled
          + system.adapter.backitup.0               : backitup              : IOB-KEP                                  -  enabled
          + system.adapter.bluelink.0               : bluelink              : IOB-KEP                                  -  enabled
          + system.adapter.cloud.0                  : cloud                 : IOB-KEP                                  -  enabled
          + system.adapter.deconz.1                 : deconz                : IOB-KEP                                  -  enabled, port: 80
            system.adapter.devices.0                : devices               : IOB-KEP                                  - disabled
            system.adapter.discovery.0              : discovery             : IOB-KEP                                  - disabled
          + system.adapter.e3dc-rscp.0              : e3dc-rscp             : IOB-KEP                                  -  enabled
          + system.adapter.ekey.0                   : ekey                  : IOB-KEP                                  -  enabled, port: 5555, bind: 0.0.0.0
          + system.adapter.g-homa.0                 : g-homa                : IOB-KEP                                  -  enabled
          + system.adapter.geofency.0               : geofency              : IOB-KEP                                  -  enabled, port: 7999, bind: 0.0.0.0
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : IOB-KEP                                  - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOB-KEP                                  - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: IOB-KEP                                  - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IOB-KEP                                  - disabled
          + system.adapter.influxdb.0               : influxdb              : IOB-KEP                                  -  enabled, port: 8086
            system.adapter.info.0                   : info                  : IOB-KEP                                  - disabled
          + system.adapter.iot.0                    : iot                   : IOB-KEP                                  -  enabled
          + system.adapter.javascript.0             : javascript            : IOB-KEP                                  -  enabled
            system.adapter.javascript.1             : javascript            : IOB-KEP                                  - disabled
          + system.adapter.modbus.0                 : modbus                : IOB-KEP                                  -  enabled
          + system.adapter.modbus.1                 : modbus                : IOB-KEP                                  -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : IOB-KEP                                  -  enabled, port: 1884, bind: 192.168.8.164
          + system.adapter.nuki-extended.0          : nuki-extended         : IOB-KEP                                  -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : IOB-KEP                                  -  enabled
          + system.adapter.scenes.0                 : scenes                : IOB-KEP                                  -  enabled
          + system.adapter.shelly.1                 : shelly                : IOB-KEP                                  -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : IOB-KEP                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.telegram.8               : telegram              : IOB-KEP                                  -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.terminal.0               : terminal              : IOB-KEP                                  - disabled, port: 8089, bind: 0.0.0.0, run as: admin
          + system.adapter.tesla-motors.0           : tesla-motors          : IOB-KEP                                  -  enabled
          + system.adapter.text2command.0           : text2command          : IOB-KEP                                  -  enabled
            system.adapter.tronity.0                : tronity               : IOB-KEP                                  - disabled
            system.adapter.tuya.5                   : tuya                  : IOB-KEP                                  - disabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IOB-KEP                                  -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : IOB-KEP                                  -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : IOB-KEP                                  - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IOB-KEP                                  - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOB-KEP                                  - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : IOB-KEP                                  - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : IOB-KEP                                  - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOB-KEP                                  - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : IOB-KEP                                  - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : IOB-KEP                                  - disabled
            system.adapter.vis-metro.0              : vis-metro             : IOB-KEP                                  - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : IOB-KEP                                  - disabled
            system.adapter.vis.0                    : vis                   : IOB-KEP                                  -  enabled
          + system.adapter.ws.0                     : ws                    : IOB-KEP                                  -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.0                  : yahka                 : IOB-KEP                                  -  enabled
            system.adapter.yr.0                     : yr                    : IOB-KEP                                  -  enabled
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
          Adapter    "deconz"       : 1.4.0    , installed 1.4.0
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "e3dc-rscp"    : 1.2.5    , installed 1.2.5
          Adapter    "ekey"         : 1.2.3    , installed 1.2.3
          Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
          Adapter    "shelly"       : 6.6.1    , installed 6.7.0
          Adapter    "telegram"     : 3.1.0    , installed 3.1.0
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "tesla-motors" : 1.3.2    , installed 1.3.5
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tronity"      : 1.1.1    , installed 1.1.1
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
          Adapter    "vis-2-widgets-energy": 0.3.9, installed 0.3.9
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Objects and States
          Objects: 	44245
          States: 	38986
          W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://phoscon.de/apt/deconz bookworm InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:6 https://repos.influxdata.com/debian stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Get:8 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
          Fetched 5127 B in 2s (2141 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      106        957        750/mosquitto
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       6817       1072/io.shelly.1
          tcp        0      0 192.168.8.164:502       0.0.0.0:*               LISTEN      1001       8614       1115/io.modbus.0
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        5644       739/redis-server 12
          tcp        0      0 0.0.0.0:41481           0.0.0.0:*               LISTEN      1001       9382       1364/io.yahka.0
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       4090       545/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4055       751/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       5520       545/deCONZ
          tcp6       0      0 :::1884                 :::*                    LISTEN      106        958        750/mosquitto
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        8261       835/influxd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       7835       1289/io.simple-api.
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       6964       1207/io.ws.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       183049     2217/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8441       966/io.admin.0
          tcp6       0      0 ::1:6379                :::*                    LISTEN      108        5645       739/redis-server 12
          tcp6       0      0 :::51989                :::*                    LISTEN      1001       6823       1100/io.nuki-extend
          tcp6       0      0 :::50000                :::*                    LISTEN      1001       7773       1263/io.g-homa.0
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        6525       883/grafana
          tcp6       0      0 :::7070                 :::*                    LISTEN      107        8296       831/evcc
          tcp6       0      0 :::22                   :::*                    LISTEN      0          4057       751/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        6443       831/evcc
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3947       529/avahi-daemon: r
          udp        0      0 0.0.0.0:5555            0.0.0.0:*                           1001       8796       1233/io.ekey.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       9018       1330/io.deconz.1
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6293       545/deCONZ
          udp        0      0 0.0.0.0:51053           0.0.0.0:*                           104        3949       529/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                107        6444       831/evcc
          udp6       0      0 :::5353                 :::*                                104        3948       529/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       9020       1330/io.deconz.1
          udp6       0      0 :::1900                 :::*                                1001       9019       1330/io.deconz.1
          udp6    2752      0 fe80::1acb:6848:903:546 :::*                                0          7188       662/NetworkManager
          udp6       0      0 :::52019                :::*                                104        3950       529/avahi-daemon: r
          2024-03-18 14:03:41.725  - info: javascript.0 (1040) script.js.common.Heizung.Heizungen_Loggen: 0_meine_Daten.0.Logging.Waermepumpe_LogFile
          2024-03-18 14:03:41.729  - info: javascript.0 (1040) script.js.common.Heizung.Heizungen_Loggen: Logging für Waermepumpe: Wärmepumpe wurde nach 02:57:02 wieder ausgeschaltet
          2024-03-18 14:03:41.731  - info: javascript.0 (1040) script.js.common.Heizung.Steuere_Heizkreisventile: Alle Zeitpläne gestoppt
          2024-03-18 14:03:41.732  - info: javascript.0 (1040) script.js.common.Heizung.Steuere_Heizkreisventile: Ventil Lisa geöffnet
          2024-03-18 14:03:41.732  - info: javascript.0 (1040) script.js.common.Heizung.Steuere_Heizkreisventile: Ventil Niklas geöffnet
          2024-03-18 14:03:41.733  - info: javascript.0 (1040) script.js.common.Heizung.Steuere_Heizkreisventile: Ventil David geschlossen
          2024-03-18 14:06:02.427  - info: admin.0 (966) <== Disconnect system.user.admin from ::ffff:192.168.8.131 web
          2024-03-18 14:06:51.192  - info: admin.0 (966) ==> Connected system.user.admin from ::ffff:192.168.8.131
          2024-03-18 14:06:56.937  - info: host.IOB-KEP stopInstance system.adapter.web.0 (force=false, process=true)
          2024-03-18 14:06:56.957  - info: host.IOB-KEP stopInstance system.adapter.web.0 send kill signal
          2024-03-18 14:06:56.977  - info: web.0 (1484) Got terminate signal TERMINATE_YOURSELF
          2024-03-18 14:06:57.049  - info: web.0 (1484) terminated http server on port 8082
          2024-03-18 14:06:57.050  - info: web.0 (1484) terminating
          2024-03-18 14:06:57.053  - info: web.0 (1484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-03-18 14:06:57.223  - info: admin.0 (966) <== Disconnect system.user.admin from ::ffff:192.168.8.131 web
          2024-03-18 14:06:57.495  - info: web.0 (1484) terminating
          2024-03-18 14:06:57.685  - info: host.IOB-KEP instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-03-18 14:07:00.110  - info: host.IOB-KEP instance system.adapter.web.0 started with pid 2217
          2024-03-18 14:07:04.064  - info: web.0 (2217) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.1, js-controller: 5.0.19
          2024-03-18 14:07:04.270  - info: web.0 (2217) http server listening on port 8082
          2024-03-18 14:07:16.872  - info: ws.0 (1207) ==> Connected system.user.admin from ::ffff:192.168.8.131
          2024-03-18 14:10:28.014  - info: javascript.0 (1040) script.js.common.Systemscripts.Ueberwache_Shellys: 0_meine_Daten.0.Logging.Shelly_LogFile
          2024-03-18 14:12:52.319  - info: shelly.1 (1072) [MQTT] Device with client id "shellyswitch25-C4BD59" connected!
          2024-03-18 14:13:39.905  - info: javascript.0 (1040) script.js.common.EAuto.Ueberwachung_Datenpunkte: 0_meine_Daten.0.Logging.Tesla_LogFile
          2024-03-18 14:13:39.912  - info: javascript.0 (1040) script.js.common.EAuto.Ueberwachung_Datenpunkte: Logging für Tesla: Tesla ist auf Standby
          • DJMarc75
            @peterk34 sieht recht gut aus.
            mach mal ein
            iob upload all
            peterk34 2 Replies Last reply Reply Quote 0
            • peterk34
              @djmarc75
              done und unverändert ...
              es gab soviel ich gesehen einen Error:
              Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/iobroker.png: Not exists
              starte gerade das System neu um zu sehen ob das was ändert ...
              • peterk34
                @djmarc75
                ich hab beim Starten einen Haufen Errors:
                host.IOB-KEP
                2024-03-18 14:36:05.152	error	iobroker npm-install: host.IOB-KEP Unknown packetName info. Please install packages from outside the repository using npm!
                host.IOB-KEP
                2024-03-18 14:34:36.436	error	Caught by controller[15]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.435	error	Caught by controller[15]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.435	error	Caught by controller[15]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.435	error	Caught by controller[15]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.434	error	Caught by controller[15]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.434	error	Caught by controller[15]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.434	error	Caught by controller[15]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.433	error	Caught by controller[14]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.433	error	Caught by controller[14]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.433	error	Caught by controller[14]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.432	error	Caught by controller[14]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.432	error	Caught by controller[14]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.432	error	Caught by controller[14]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.431	error	Caught by controller[14]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.431	error	Caught by controller[13]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.431	error	Caught by controller[13]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.430	error	Caught by controller[13]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.430	error	Caught by controller[13]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.430	error	Caught by controller[13]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.429	error	Caught by controller[13]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.429	error	Caught by controller[13]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.429	error	Caught by controller[12]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.428	error	Caught by controller[12]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.428	error	Caught by controller[12]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.427	error	Caught by controller[12]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.427	error	Caught by controller[12]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.427	error	Caught by controller[12]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.426	error	Caught by controller[12]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.425	error	Caught by controller[11]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.425	error	Caught by controller[11]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.424	error	Caught by controller[11]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.424	error	Caught by controller[11]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.423	error	Caught by controller[11]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.423	error	Caught by controller[11]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.415	error	Caught by controller[11]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.414	error	Caught by controller[10]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.414	error	Caught by controller[10]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.413	error	Caught by controller[10]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.413	error	Caught by controller[10]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.413	error	Caught by controller[10]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.412	error	Caught by controller[10]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.412	error	Caught by controller[10]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.412	error	Caught by controller[9]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.411	error	Caught by controller[9]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.411	error	Caught by controller[9]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.410	error	Caught by controller[9]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.410	error	Caught by controller[9]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.410	error	Caught by controller[9]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.409	error	Caught by controller[9]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.409	error	Caught by controller[8]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.408	error	Caught by controller[8]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.408	error	Caught by controller[8]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.408	error	Caught by controller[8]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.407	error	Caught by controller[8]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.407	error	Caught by controller[8]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.406	error	Caught by controller[8]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.406	error	Caught by controller[7]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.406	error	Caught by controller[7]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.405	error	Caught by controller[7]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.405	error	Caught by controller[7]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.404	error	Caught by controller[7]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.404	error	Caught by controller[7]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.404	error	Caught by controller[7]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.403	error	Caught by controller[6]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.403	error	Caught by controller[6]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.402	error	Caught by controller[6]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.402	error	Caught by controller[6]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.402	error	Caught by controller[6]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.401	error	Caught by controller[6]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.401	error	Caught by controller[6]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.400	error	Caught by controller[5]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.400	error	Caught by controller[5]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.400	error	Caught by controller[5]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.399	error	Caught by controller[5]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.399	error	Caught by controller[5]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.398	error	Caught by controller[5]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.398	error	Caught by controller[5]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.398	error	Caught by controller[4]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.397	error	Caught by controller[4]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.397	error	Caught by controller[4]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.396	error	Caught by controller[4]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.396	error	Caught by controller[4]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.395	error	Caught by controller[4]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.395	error	Caught by controller[4]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.394	error	Caught by controller[3]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.394	error	Caught by controller[3]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.393	error	Caught by controller[3]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.393	error	Caught by controller[3]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.393	error	Caught by controller[3]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.392	error	Caught by controller[3]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.391	error	Caught by controller[3]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.391	error	Caught by controller[2]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.390	error	Caught by controller[2]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.390	error	Caught by controller[2]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.389	error	Caught by controller[2]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.389	error	Caught by controller[2]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.389	error	Caught by controller[2]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.388	error	Caught by controller[2]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.388	error	Caught by controller[1]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.387	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.387	error	Caught by controller[1]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.386	error	Caught by controller[1]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.386	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.386	error	Caught by controller[1]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.385	error	Caught by controller[1]: Error: Connection is closed.
                host.IOB-KEP
                2024-03-18 14:34:36.385	error	Caught by controller[0]: at TCP.<anonymous> (node:net:350:12)
                host.IOB-KEP
                2024-03-18 14:34:36.384	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                host.IOB-KEP
                2024-03-18 14:34:36.384	error	Caught by controller[0]: at Socket.emit (node:events:517:28)
                host.IOB-KEP
                2024-03-18 14:34:36.383	error	Caught by controller[0]: at Object.onceWrapper (node:events:632:26)
                host.IOB-KEP
                2024-03-18 14:34:36.383	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                host.IOB-KEP
                2024-03-18 14:34:36.383	error	Caught by controller[0]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                host.IOB-KEP
                2024-03-18 14:34:36.382	error	Caught by controller[0]: Error: Connection is closed.
                admin.0
                2024-03-18 14:34:36.283	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.282	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.282	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.280	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.279	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.279	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.276	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.276	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.275	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.272	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.271	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.271	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.269	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.269	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.268	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.266	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.265	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.265	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.263	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.263	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.262	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.260	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.259	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.259	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.256	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.256	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.255	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.254	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.252	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.252	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.250	error	Connection is closed.
                admin.0
                2024-03-18 14:34:36.249	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                admin.0
                2024-03-18 14:34:36.249	error	uncaught exception: Connection is closed.
                admin.0
                2024-03-18 14:34:36.247	error	Connection is closed.
                  sigi234 Forum Testing Most Active @peterk34 last edited by
                  @peterk34
                  Zeig mal deine Instanzen
                  • peterk34
                    peterk34 @sigi234 last edited by
                    @sigi234
                      Thomas Braun Most Active @peterk34 last edited by
                      @peterk34
                      Hat zwar nichts mit deinem Problem zu tun, aber leg das deconz-Repo nochmal neu an:
                      wget -qO- http://phoscon.de/apt/deconz.pub.key | sudo gpg --dearmor -o /usr/share/keyrings/deconz.gpg > /dev/null
                      sudo sh -c "echo 'deb [signed-by=/usr/share/keyrings/deconz.gpg] http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
                      Damit wirst du die nervige Meldung zu den alten Schlüsseln los.
                      • peterk34
                        peterk34 @Thomas Braun last edited by
                        @thomas-braun sagte in Vis 1 zeigt nach Neuinstallation nichts an:
                        cool Danke
                        • peterk34
                          peterk34 last edited by peterk34
                          Ich stelle die Seiten jetzt auf Vis2 um ... das geht soweit ganz gut, bei der Seite "Heizung" habe ich aber ein komisches Verhalten - vielleicht hängt es ja zusammen. Heizung wird im runtime fehlerfrei angezeigt. Bearbeiten lassen sich alle Seiten außer Heizung. Gehe ich auf Heizung im Editor, wird die Seite weiß und zeigt nichts mehr an. Wenn ich den Editor neu lade gehts ganz normal wieder. Kopieren des Blatts, Importieren in neues Blatt bringt auch nix.
                          Was könnte das sein?
                          Das ist das Blatt:
                          Heizung.json
                          und so siehts aus:
                            sigi234 Forum Testing Most Active @peterk34 last edited by sigi234
                            @peterk34
                            Dann hast du ein Widget was nicht mit Vis2 kompatibel ist. Oder ein Adapter.
                            Was kommt bei F12 wenn du die View aufrufst?
                            • peterk34
                              @sigi234
                                @peterk34
                                Grafana
                                • peterk34
                                  @sigi234 ist es leider nicht ... es funkt auf den anderen Seiten, hab dann manuell alle Widgets die auf grafana verweisen im Json rausgelöscht, neu importiert ... alles gleich geblieben ... bissi am verzweifeln - muss wohl diese Seite neu bauen
                                  1383
