      lustig29 @Armilar last edited by
      @armilar
      Aber die stehen doch drin?
      • Armilar
        Armilar Most Active Forum Testing @lustig29 last edited by
        @lustig29
        Klassiker...
        die sind in der falschen Zeile. --> Nicht unter Syntaxhilfe, sondern unter zusätzliche NPM Module eintragen 😊
          @armilar
          Ahh.🤦‍♂️
            lustig29 @lustig29 last edited by lustig29
            Ich bekomme den Abfallkalender nicht angezeigt. Woran kann das liegen?
            let Abfall: PageType =
                "type": "cardEntities",
                "heading": "Abfallkalender",
                "useColor": true,
                "subPage": false,
                "parent": undefined,
                "items": [
                    { id: AliasPath + '0_userdata.0.Abfallkalender.1.event',icon: 'trash-can'},
                    { id: AliasPath + '0_userdata.0.Abfallkalender.2.event',icon: 'trash-can'},
                    { id: AliasPath + '0_userdata.0.Abfallkalender.3.event',icon: 'trash-can'},
                    { id: AliasPath + '0_userdata.0.Abfallkalender.4.event',icon: 'trash-can'}
              <variables>
                <variable id="h}CE-n1l`S|gRf(0K%./">i</variable>
                <variable id="j5C=K+Z.E:im1#q:;A=6">Muell_JSON</variable>
                <variable id="^:v=Yb?;aM;Z[}4jCF3-">Event</variable>
                <variable id="9^)S?J=tLkC7cUWc-u9w">Color</variable>
              </variables>
              <block type="on_ext" id="aFeZac36,?)=rfMg%3T|" x="38" y="-287">
                <value name="OID0">
                  <shadow type="field_oid" id="GSzQ}epUa))me3m8yyuD">
                    <field name="oid">ical.0.data.table</field>
                  <block type="controls_for" id="wduAM(OBPzLJ@bfYAK5%">
                    <field name="VAR" id="h}CE-n1l`S|gRf(0K%./">i</field>
                    <value name="FROM">
                      <shadow type="math_number" id="HK~R2U|`xb$U5W+tsHpN">
                        <field name="NUM">0</field>
                    <value name="TO">
                      <shadow type="math_number" id="Ed[L/:1e9-cwxrRaZiIv">
                        <field name="NUM">3</field>
                    <value name="BY">
                      <shadow type="math_number" id="o@5kngFiPpvl5dGo@Q$9">
                        <field name="NUM">1</field>
                    <statement name="DO">
                      <block type="variables_set" id="0T)vK0k8aikvg7mF6XHo">
                        <field name="VAR" id="j5C=K+Z.E:im1#q:;A=6">Muell_JSON</field>
                          <block type="get_value" id="1~kG;UHn$nw2zzbfOIT]">
                            <field name="OID">ical.1.data.table</field>
                          <block type="control_ex" id="UAu,2OBRJp9~Nzyxouyu">
                            <value name="OID">
                              <shadow type="field_oid" id="J_|uu;{e44n5Z-;qE+hP">
                                <field name="oid">Object ID</field>
                              <block type="text_join" id="8/|eHqk))j9Po-O*mK`e">
                                <value name="ADD0">
                                  <block type="text" id="Zp8GRfdfXujkeM41=PeZ">
                                    <field name="TEXT">0_userdata.0.Abfallkalender.</field>
                                <value name="ADD1">
                                  <block type="math_arithmetic" id="$!!l@[eJ~4Kdb5/Imo.X">
                                    <field name="OP">ADD</field>
                                      <shadow type="math_number" id="zaU15{yD43xkuY@?)RY(">
                                      <block type="variables_get" id="o3pJ(+3KE~Co%u-dy.:W">
                                      <shadow type="math_number" id="_LBb[#z%M$n0~1Y}~8w+">
                                <value name="ADD2">
                                  <block type="text" id="Vt#-b{iDzusQQx]#0%0,">
                                    <field name="TEXT">.date</field>
                              <shadow type="logic_boolean" id="/y1w}eely@o.gl$]#)o=">
                              <block type="get_attr" id="p~0A1{eb$lD~.9`9R4K)">
                                <value name="PATH">
                                  <shadow type="text" id="kC1+sgB#n4jkZjaeCAi:">
                                    <field name="TEXT">0.date</field>
                                  <block type="text_join" id="DDs!.^n(V7=A_TK}DFQt">
                                    <value name="ADD0">
                                      <block type="variables_get" id="k1+Dybgb:u2y9v57OrCg">
                                    <value name="ADD1">
                                      <block type="text" id="EXgB=?B}IKiUdQ.2tKoa">
                                <value name="OBJECT">
                                  <block type="variables_get" id="dzLb1f^T!(MM,d=cYU9y">
                            <value name="DELAY_MS">
                              <shadow type="math_number" id="f8q~r@+q|8Kov#3EufsI">
                              <block type="variables_set" id="E[W-)N[vKeufX{v$B[]p">
                                <field name="VAR" id="^:v=Yb?;aM;Z[}4jCF3-">Event</field>
                                  <block type="text_getSubstring" id="YU_Q05y^+I.IzV[c9h9B" inline="false">
                                    <mutation at1="true" at2="false"></mutation>
                                    <field name="WHERE1">FROM_START</field>
                                    <field name="WHERE2">LAST</field>
                                    <value name="STRING">
                                      <block type="get_attr" id=":/^m9o]3:=L%$4[9$f]7">
                                        <value name="PATH">
                                          <shadow type="text" id="MU-+yX*B5FZDno+$EU{S">
                                            <field name="TEXT">0.event</field>
                                          <block type="text_join" id="*MaT-W83R/Y5`?QCQNec">
                                            <value name="ADD0">
                                              <block type="variables_get" id="l5d$/glqMm3~+YA`5]wg">
                                            <value name="ADD1">
                                              <block type="text" id="$+g0XH}$`2`+{B}s3ID@">
                                                <field name="TEXT">.event</field>
                                          <block type="variables_get" id="nSDdx_!gO45lc4.$`wI`">
                                    <value name="AT1">
                                      <block type="math_number" id="ic:P:#_w68q^w]#/;w+K">
                                        <field name="NUM">9</field>
                                  <block type="control_ex" id="^[032{A//-EpUE6lh7ml">
                                    <value name="OID">
                                      <shadow type="field_oid" id="^DV3eb94-na)vn;h1?K)">
                                      <block type="text_join" id="`@U%x4KdNV~Y0I`#+,BB">
                                        <value name="ADD0">
                                          <block type="text" id="Rk[N`gae|lr/9FXmY!no">
                                        <value name="ADD1">
                                          <block type="math_arithmetic" id="=RY5pU%/0M!J;{^z81qr">
                                              <shadow type="math_number" id="e_P.rgX|_vD-$%(:T-|I">
                                              <block type="variables_get" id="TbkkwM2BKh^+;KTQY3C]">
                                              <shadow type="math_number" id="e,-Pz1Hy!V:=8S,tHo`:">
                                        <value name="ADD2">
                                          <block type="text" id="SApnes6}k9wDi243W2xp">
                                      <shadow type="logic_boolean" id="70uxCt~?y`hOTCs:tJ^~">
                                      <block type="variables_get" id="}@7(YP=fmA0l@:FJS$v#">
                                      <shadow type="math_number" id="@JEhP_3fysDQ6a_x:ILm">
                                      <block type="controls_if" id="r,.`4GPI|(([[.76Cft~">
                                        <mutation elseif="3"></mutation>
                                          <block type="logic_compare" id="d4g.Ts.`^;_R!bu)T_~|">
                                            <field name="OP">EQ</field>
                                              <block type="variables_get" id="tC!eDI_BV-hGgDc@kuPc">
                                              <block type="text" id="?3tZotX[hHq9HGFsA(x|">
                                                <field name="TEXT">Restmüll</field>
                                          <block type="variables_set" id="FXPSk]#;ZliNOBw7bVC8">
                                            <field name="VAR" id="9^)S?J=tLkC7cUWc-u9w">Color</field>
                                              <block type="math_number" id="-6AJ8U932(j5LuWN@Sp,">
                                                <field name="NUM">33840</field>
                                        <value name="IF1">
                                          <block type="logic_compare" id=":{8uXg8tzuFNCxedDJ:F">
                                              <block type="variables_get" id="0A}m@W~711B2u){_B8uP">
                                              <block type="text" id="x,Cz(O2e|co^a7rJEdO7">
                                                <field name="TEXT">Biomüll</field>
                                        <statement name="DO1">
                                          <block type="variables_set" id="Y#|WXlt|w+`5h3B`VI]*">
                                              <block type="math_number" id="BVnWo|iSfirB?Vw*M7;o">
                                                <field name="NUM">2016</field>
                                        <value name="IF2">
                                          <block type="logic_compare" id="Q0ejJ+ovU#35l7SaPd`7">
                                              <block type="variables_get" id="/EhoIt{trOOc3*+k5m4C">
                                              <block type="text" id="BVzI8#S#S*Yqk5v;$?kD">
                                                <field name="TEXT">Altpapier</field>
                                        <statement name="DO2">
                                          <block type="variables_set" id="R7DF(c~|*~pR_D]JqW7c">
                                              <block type="math_number" id="#A]b|UX(@QPk*SM_q)RZ">
                                                <field name="NUM">31</field>
                                        <value name="IF3">
                                          <block type="logic_compare" id="MjEHt,7LG#}DST*Iuc.R">
                                              <block type="variables_get" id="(WzO?43I0:YSK;VgFmnX">
                                              <block type="text" id="![3nA.95iLG[3]m5%GYS">
                                                <field name="TEXT">Gelbe Tonne</field>
                                        <statement name="DO3">
                                          <block type="variables_set" id="959t9eG^*uj2c;pF^HGP">
                                              <block type="math_number" id="{*68t/i/Q7}6cb+0$`6Y">
                                                <field name="NUM">65504</field>
                                          <block type="control_ex" id="^c0LOh0WChe-1QNTGVAy">
                                            <value name="OID">
                                              <shadow type="field_oid" id="7gi,zaI;54L/Ek{e9,I@">
                                              <block type="text_join" id="J|nD$KZ,I6q=mt,xW@:X">
                                                <value name="ADD0">
                                                  <block type="text" id="kwm[DP}25YD]Te=}p`S0">
                                                <value name="ADD1">
                                                  <block type="math_arithmetic" id="pj~|`_~%6}=?B^fK4@;L">
                                                      <shadow type="math_number" id="z/gzD=CFU?L9V-DBj@n;">
                                                      <block type="variables_get" id="To0?Cg*f2pZ(Z`zK|=?M">
                                                      <shadow type="math_number" id="=Q|k5qeOIy1ya}{CVNF@">
                                                <value name="ADD2">
                                                  <block type="text" id="If6$$63npGW3OazEE^46">
                                                    <field name="TEXT">.color</field>
                                              <shadow type="logic_boolean" id=")+b01E8B2-c#vcsGmA+Y">
                                              <block type="variables_get" id="/5*6z@-R5w^1i2*XphN|">
                                              <shadow type="math_number" id="79qt?j;aoK%i)roQkfoE">
              TT-Tom @lustig29 last edited by
              @lustig29
              Der Pfad hinter id: ist falsch.
              Hier mal eine Beschreibung https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#4-abfallkalender
                Lokverführer last edited by
                ich bin neu im Thema und habe schon erfolgreich eine Abfallkalender-Seite eingebunden. Nun würde mich mich gerne an die cardPower wagen. Meine Skriptversion ist 4.3.3.43.
                Ich habe aus dem Wiki eine Beispielkarte kopiert und bei den pages hinzugefügt (mehr sollte für die Demo ja nicht notwendig sein?):
                let CardPowerExample: PageType =
                    'type': 'cardPower',
                    'heading': 'Energiefluss',
                    'useColor': true,
                    'items': [
                Beim Compilieren wird aber direkt dieser Fehler ausgegeben:
                [error]: javascript.0 (1572800) script.js.common.NSPanel.NSPanel1: TypeScript compilation failed: 'useColor': true,
                ERROR: Object literal may only specify known properties, and ''useColor'' does not exist in type 'PagePower'.
                Wird die Zeile 'useColor" entfernt, tritt der Fehler nicht mehr auf, es wird aber auch keine Karte angezeigt.
                  ticaki @Lokverführer last edited by ticaki
                  @lokverführer
                  hast du sie unten in pages aufgenommen? Btw. wie kommst du auf useColor - in der Wiki steht es ohne.
                  https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-‐-Typen_How-2_Beispiele#page-beispiele
                    @ticaki
                    Und hier steht es mit useColor :
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#cardpower-ab-ts-script-v341
                    In Pages habe ich die CardPowerExample mit aufgenommen
                      @lokverführer sagte in SONOFF NSPanel mit Lovelace UI:
                      @ticaki
                      Danke dann muß das noch korrigiert werden.
                      Beim eigentlichen Problem kann ich dir leider nicht helfen.
                      Armilar 1 Reply Last reply Reply Quote 2
                      • Armilar
                        Armilar Most Active Forum Testing @ticaki last edited by Armilar
                        @ticaki
                        @Lokverführer
                            'items': [
                        Habe das useColor bei der cardPower aus dem Wiki entfernt, da es sich mit den Types beißt und in der Card auch keinen Sinn macht...
                        Der Rest sollte so funktionieren... 😊
                        T 1 Reply Last reply Reply Quote 3
                          TT-Tom @Armilar last edited by
                          @armilar
                          @Lokverführer
                          der Demomodus wird nicht funktionieren. suche bitte im script diese Stelle
                          function GeneratePowerPage(page: NSPanel.PagePower): NSPanel.Payload[] {
                              try {
                                  if (!page.items[0].id) throw new Error ('Missing pageItem.id for PowerPage!');
                                  let obj:object = {};
                                  let demoMode = false;
                                  if (page.items[0].id == undefined){
                                      log('No PageItem defined - cardPower demo mode active', 'info');
                                      demoMode = true;
                          und lösche diese Zeile.
                          dann sollte der Demomodus laufen.
                            patricknitsch last edited by
                            Hallo, ich habe ein kleines Problem mit meinen Hardwaretasten. Ich habe Rule 1 eingefügt, um nach oben und auf Home springen zu können. Die Home Funktion auf Button 2 funktioniert problemlos. Bei Button 1 springt das Panel aber nicht in die übergeordnete Seite.
                            In Tasmota wird der Befehl richtig ausgegeben. Topic passt dabei auch:
                            21:18:20.859 RUL: BUTTON1#STATE performs "Publish Sonoff/NSPanelOG/tele/RESULT {"CustomRecv":"event,buttonPress1,hwbtn,bUp"}"
                            21:18:20.871 MQT: Sonoff/NSPanelOG/tele/RESULT = {"CustomRecv":"event,buttonPress1,hwbtn,bUp"}
                            In IOBroker erhalte ich aber folgende Fehlermeldung:
                            script.js.common.NSPanel_OG.NSPanel_OG_0_1: Please report to developer: Unknown NSPanel.EventMethod: buttonPress1
                            Hat hierzu jemand eine Idee, woran es liegen könnte?
                            • Armilar
                              Armilar Most Active Forum Testing @patricknitsch last edited by Armilar
                              @patricknitsch sagte in SONOFF NSPanel mit Lovelace UI:
                              ja - es gibt kein buttonPress1, sondern ausschließlich die Methode buttonPress2 und auch wenn man es vermutet, so gibt es keinen Zusammenhang mit den Hardware-Buttons
                              ein bUp wird ebenfalls per buttonPress2 gesendet:
                              https://github.com/joBr99/nspanel-lovelace-ui/tree/main/HMI#messages-from-nextion-display
                                patricknitsch @Armilar last edited by
                                @armilar Dann funktioniert die Anleitung Rule 1 mit den Hardware Buttons gar nicht mehr?
                                • Armilar
                                  @patricknitsch
                                  Doch klar funktioniert die noch... ist nur ein Fehler drin.
                                  dürfte eher so aussehen:
                                  Rule1 on Button1#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,buttonPress2,hwbtn,bUp"} endon on Button2#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,buttonPress2,hwbtn,bHome"} endon
                                  Rule1 1
                                  EDIT: Habe es im Wiki ebenfalls korrigiert.
                                    @armilar Funktioniert! Danke 🙂
                                      maik5066 last edited by
                                      Hallo Leute, ich würde gern WLED nutzen, ich habe mir alle Anleitungen durchgelesen leider funktioniert es bei mir nicht.
                                      Wenn es jemand, funktionierend umgesetzt hat, könnt ihr mir das Skript und die CARD zuschicken oder am besten posten.
                                      Vielen Dank
                                        TT-Tom last edited by
                                        @maik5066
                                        Was funktioniert denn nicht bei dir??
                                        Welche Fehlermeldungen hast du bekommen??
                                          maik5066 @TT-Tom last edited by
                                          @TT-Tom , danke für deine Rückmeldung. Ich habe das js Skript genutzt und die drei hilfsdatenpunkte angelegt. Wenn ich, wie in der Anleitung das Card Grip kopiere findet er die variable index01 nicht.
                                          Wäre es nicht möglich, direkt die Effekte datenpunkte des WLED Adapter zu nutzen z. Bsp. fx.
                                          Habt ihr ein funktionierendes bespiel was ich mir kopieren kann.
                                          • N
                                            nono87 last edited by
                                            Guten Morgen,
                                            ich habe meine Mähroboter wieder aus dem Winterschlaf geholt und wollte diesen gleich einbinden.
                                            Bisher klappt auch alles wie gewünscht nur leider stoße ich jetzt an meine Grenzen.
                                            Der Worx gibt als Status eine Zahl mit den States dahinter mit. Diese Zahlen kann ich mittels Info Alias anzeigen. Schöner wäre es natürlich wenn dort als Text steht was gerade passiert. Sei es als Wert oder als Text unter dem Wert.
                                            Ich hoffe dazu gibt es bereits eine Lösung
                                            lovelace ui nspanel sonoff
                                            270
                                            7695
                                            6535520
