    5. Umstellung request auf http get
      jwerlsdf last edited by
      Hallo, ich habe folgendes Blockly erstellt.
      <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="kc5hA8s]SzYlk[h=5CUF" x="13" y="63">
        <value name="OID0">
          <shadow type="field_oid" id="#Q2c:{hd~*/lrCttSF:w">
            <field name="oid">hm-rpc.1.00171BE9A4E37C.8.PRESS_SHORT</field>
        <value name="OID1">
          <shadow type="field_oid" id="hEV`dU[o,H+w#+U#2zRs">
            <field name="oid">hm-rpc.1.00171BE9A4E37C.8.PRESS_LONG</field>
          <block type="controls_if" id="DSogTIK`#vruS^KCon!a">
              <block type="time_compare_ex" id="_X-t6OAT{LkOTW7_9eqp">
                <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                <value name="START_TIME">
                  <shadow type="text" id="{RXUSqb821_vY.W#|klU">
                    <field name="TEXT">08:00</field>
                <value name="END_TIME">
                  <shadow type="text" id="WtCCDqL;g={e,eNE,|ch">
                    <field name="TEXT">19:30</field>
              <block type="http_get" id="#rGli9QJae`|yN|9-F(H">
                <value name="URL">
                  <shadow type="text" id="jI~|A)U=o^X1qb+~|8uR">
                    <field name="TEXT">http://</field>
                  <block type="text" id="y,WX5F,z_e{z8*py6y80">
                    <field name="TEXT">http://192.168.178.28:5005/clipall/Miss-Marple.mp3/24</field>
                  <block type="timeouts_wait" id="Z*$9pyFp!%bK#sHKAQ^L">
                    <field name="DELAY">12</field>
                      <block type="variables_set" id="uEv]M:CwW|{L4Id(|7,u">
                        <field name="VAR" id="qF^Dv{8_res2E03z3U@Y">Lautstärke</field>
                          <block type="math_number" id="/AKmeY={fGj?|@wu5lj%">
                            <field name="NUM">24</field>
                          <block type="controls_repeat_ext" id="-_pA=Wi7:9!3aP,KY67H">
                            <value name="TIMES">
                              <shadow type="math_number" id="6ar6?`^OUL@no8Tw~x9V">
                                <field name="NUM">8</field>
                            <statement name="DO">
                              <block type="variables_set" id="w.lPzP3b=?.Cn-.Np!A?">
                                  <block type="math_arithmetic" id=":FC/6IM8q}t-z*g%2^.j">
                                      <shadow type="math_number" id="w$n2??9k1FK8i*=Peet_">
                                        <field name="NUM">1</field>
                                      <block type="variables_get" id="`!{L^1wQ,G}_.@2LH/s+">
                                      <shadow type="math_number" id="`1O6QUZA-xcFx[n}]5R(">
                                        <field name="NUM">3</field>
                                  <block type="http_get" id="{mXmgCGP{_Go3tYnqQ78">
                                    <value name="URL">
                                      <block type="text_join" id="9X0%IV_#gw1us4$oWdeA">
                                        <value name="ADD0">
                                          <block type="text" id="T[^f#uGR{Mz/`33uf[__">
                                            <field name="TEXT">http://192.168.178.28:5005/clipall/</field>
                                        <value name="ADD1">
                                          <block type="text" id="k{#z8D2!fN-|S1u8fw6=">
                                            <field name="TEXT">volume/</field>
                                        <value name="ADD2">
                                          <block type="variables_get" id="f#S=?Pj5bWhYZBlnlrj*">
                                      <block type="timeouts_wait" id="1W(QO_yH8j?rgA.5@D7d">
                                        <field name="DELAY">1</field>
            <statement name="ELSE">
              <block type="variables_set" id=",[._kN9yTpY6#-;cX+H;">
                  <block type="math_number" id="S~IPfRBm{qcN(xwka5JA">
                  <block type="http_get" id="*wtQ|k?p;|M1AK8Dx_!I">
                    <value name="URL">
                      <shadow type="text" id="xJ}6pLSg%zoJda$C_0d`">
                      <block type="text" id="xh]W/O)u@f8R@T)p#~WP">
                        <field name="TEXT">http://192.168.178.28:5005/Kueche/volume/24</field>
                      <block type="http_get" id="6?9~gFe*P1R#PXOz`A~7">
                        <value name="URL">
                          <block type="text" id="$nuq(}%RPmSujZ/:o0_T">
                            <field name="TEXT">http://192.168.178.28:5005/Wohnzimmer/volume/24</field>
                          <block type="http_get" id="!!}_Yf.k.4`((d?Q8EVg">
                            <value name="URL">
                              <block type="text" id="uZq=9R7F72ufrSi-HnNW">
                                <field name="TEXT">http://192.168.178.28:5005/Kueche/join/Wohnzimmer</field>
                              <block type="http_get" id="FZUnV{nni0+wPXzK}Sg,">
                                <value name="URL">
                                  <block type="text" id="+x)tTA[F(].)X:p#wR^R">
                                    <field name="TEXT">http://192.168.178.28:5005/Wohnzimmer/clip/Miss-Marple.mp3/24</field>
                                  <block type="timeouts_wait" id="qf_9rwoDlFtqlkIPj}^J">
                                      <block type="controls_repeat_ext" id="s6S[DsT;.n30Wh*uy.IZ">
                                          <shadow type="math_number" id="BzSh,yOe47]rmU)zG,2=">
                                          <block type="variables_set" id="Q2`N%ie6NFN2U+g1/=U(">
                                              <block type="math_arithmetic" id="8~?!=c`EQ0`.Yi67v.]B">
                                                  <block type="variables_get" id="`9s7~mXXjubYhhONJ9ik">
                                                  <shadow type="math_number" id="UiVP(ivvX@}*KFd]PaM*">
                                              <block type="http_get" id="Jr;ed4uD*kHBWD3fr|B*">
                                                <value name="URL">
                                                  <shadow type="text" id="x[n8x(-[Dz}O|#z4lT3+">
                                                  <block type="text_join" id="YEI4fPgK47vDh4%KLYQ:">
                                                    <value name="ADD0">
                                                      <block type="text" id=",OpjB!,VbZHh808iGM@O">
                                                        <field name="TEXT">http://192.168.178.28:5005/Wohnzimmer/</field>
                                                    <value name="ADD1">
                                                      <block type="text" id="bx!zlgz8mh+#mSK}[F?g">
                                                        <field name="TEXT">groupVolume/</field>
                                                    <value name="ADD2">
                                                      <block type="variables_get" id="Bnmr8G~u}AMAf1k@w7Te">
                                                  <block type="timeouts_wait" id=",EFe1GLv?rOX.saLJ;18">
                                          <block type="http_get" id=")OC#sAK.]@jcZ2!^xyf5">
                                            <value name="URL">
                                              <shadow type="text" id="3$Q)wE346FqSN9eI@a,!">
                                              <block type="text" id="oYa|6?3[IL=9I[9^5F/#">
                                                <field name="TEXT">http://192.168.178.28:5005/Kueche/leave/Wohnzimmer</field>
      Dieses ging mit request ohne Fehler. Auch mit dem Block http get funktioniert das Skript so wie ich es möchte, ich bekomme aber folgenden Fehler:
      script.js.EG_Tuerklingel: timeout of 2000ms exceeded
      1. Jetzt zwei Fragen: Ich habe darin keinen Timeout erstellt, sondern lediglich Pausen eingebaut. Wie kann ich diesen Fehler beheben.
      2. Generell: Was kann ich in den Baustein vom "http get" einbauen (Debug?)? Was bringt mir das? Was ist der Unterschied zwischen http get und http post?
      • DJMarc75
        DJMarc75 @jwerlsdf last edited by
        @jwerlsdf Darf man das Blockly sehen ?
          jwerlsdf @DJMarc75 last edited by
          @djmarc75
          • DJMarc75
            @jwerlsdf und was erwartest Du in den ganzen GET Bausteinen als Ergebnis ? Da steht ja nix drin 😉
              jwerlsdf @DJMarc75 last edited by jwerlsdf
              @djmarc75
              Das ist ja meine Frage, was muss da rein?
              Wie gesagt, die Funktion ist für mich bereits gegeben und das skript funktioniert so wie es sein soll (so wie vorher mit request). Aber es kommt dieser Fehler.
              • DJMarc75
                @jwerlsdf sagte in Umstellung request auf http get:
                Naja, Du bist als BetaUser und quasi als Tester unterwegs, daher verstehe ich die Frage nicht.
                Hier wird Dir besser geholfen:
                https://forum.iobroker.net/topic/73439/javascript-7-9-0-neue-objekt-und-http-bausteine
                  @djmarc75
                  ich will nur diesen Fehler
                  rausbekommen, alles andere schiebe ich erst einmal auf.
                    Homoran Global Moderator Administrators @jwerlsdf last edited by Homoran
                    @jwerlsdf ich kann in dem Blockly kein timeout erkennen.
                    und auch nichts mit 2000 msec.
                      jwerlsdf @Homoran last edited by jwerlsdf
                      ich vermute, dass es mit dem http get block zu tun haben muss. In Javascript wird dies deutlich:
                      on({ id: [].concat(['hm-rpc.1.00171BE9A4E37C.8.PRESS_SHORT']).concat(['hm-rpc.1.00171BE9A4E37C.8.PRESS_LONG']), change: 'any' }, async (obj) => {
                        if (compareTime('08:00', '19:30', 'between', null)) {
                          httpGet('http://192.168.178.28:5005/clipall/Miss-Marple.mp3/24', { timeout: 2000 }, async (err, response) => {
                            if (err) {
                              console.error(err);
                        Na super!
                        danach hatte ich scjon im XML gesucht.
                        Dann solltest du im Tester Thread fragen, wie diese Bausteine zu verwenden sind.
                        von irgendeinem (ohne debug Bausteine nicht einzugrenzen) kommt wohl nichts zurück.
                        701
