    4. Fullybrowser 3.0
    Fullybrowser 3.0
      Berny-K last edited by Berny-K
      @djmarc75 Hier jetzt das Ergebnis von iob diag in der Langform
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       11:27:24 up 2 days, 22:39,  2 users,  load average: 0.20, 0.50, 0.57
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-03-11 11:27:24 CET
                 Universal time: Mon 2024-03-11 10:27:24 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        1.8G        1.2G        0.0K        833M        2.0G
      Swap:            99M         41M         58M
      Total:          3.9G        1.8G        1.3G
               3837 M total memory
               1765 M used memory
                508 M active memory
               1952 M inactive memory
               1238 M free memory
                133 M buffer memory
                699 M swap cache
                 99 M total swap
                 41 M used swap
                 58 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      114G   12G   97G  12% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     768M  888K  767M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Fri Mar  8 12:48:10 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5F:01:F9 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=52bb65ab-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Fri Mar  8 12:48:12 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Mar  8 12:48:12 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Mar  8 12:48:14 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      [Sat Mar  9 04:00:03 2024] EXT4-fs (loop0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Mar  9 04:01:53 2024] EXT4-fs (loop0p2): unmounting filesystem.
      [Sun Mar 10 04:00:05 2024] EXT4-fs (loop0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Mar 10 04:01:50 2024] EXT4-fs (loop0p2): unmounting filesystem.
      [Mon Mar 11 04:00:05 2024] EXT4-fs (loop0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Mar 11 04:01:50 2024] EXT4-fs (loop0p2): unmounting filesystem.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      6.1G    /var/
      3.5G    /var/cache
      3.4G    /var/cache/apt/archives
      3.4G    /var/cache/apt
      1.8G    /var/log
      Archived and active journals take up 168.0M in the file system.
      /opt/iobroker/backups:
      203M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      602M    /opt/iobroker/iobroker-data/
      454M    /opt/iobroker/iobroker-data/files
      112M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a85366accbc9eb119d8f8b4f1d69213e-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a85366accbc9eb119d8f8b4f1d69213e-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
      Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "tibberlink"   : 2.2.2    , installed 2.2.1  [Updatable]
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        4308
      States:         3527
      Hit:1 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://repos.influxdata.com/debian stretch InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://apt.pivccu.de/piVCCU stable InRelease
      Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      Fetched 4586 B in 2s (2286 B/s)
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      109        14757      716/influxd
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          13808      809/dnsmasq
      tcp        0      0 192.168.178.67:2001     0.0.0.0:*               LISTEN      1001       19481      1969/io.hm-rpc.0
      tcp        0      0 192.168.178.67:2010     0.0.0.0:*               LISTEN      1001       17775      2061/io.hm-rpc.2
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16881      919/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17475      919/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14751      779/sshd: /usr/sbin
      tcp        0      0 192.168.178.67:9292     0.0.0.0:*               LISTEN      1001       20400      3068/io.hm-rpc.1
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       19635      2216/io.sonoff.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14753      779/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        14194      898/grafana
      tcp6       0      0 :::8086                 :::*                    LISTEN      109        13892      716/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16986      1608/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19016      2391/io.web.1
      udp        0      0 0.0.0.0:41384           0.0.0.0:*                           108        13577      421/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          13807      809/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          13804      809/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12767      639/dhclient
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13575      421/avahi-daemon: r
      udp6       0      0 :::39115                :::*                                108        13578      421/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13576      421/avahi-daemon: r
      2024-03-11 10:31:59.106  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 2 zugeschaltet -> LVN -176
      2024-03-11 10:32:29.107  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 zugeschaltet -> LVN -105
      2024-03-11 10:32:34.219  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 abgeschaltet -> LVN 20
      2024-03-11 10:33:30.102  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 2 abgeschaltet -> LVN 11
      2024-03-11 10:34:30.202  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 zugeschaltet -> LVN -203
      2024-03-11 10:35:46.200  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 1 zugeschaltet -> LVN -207
      2024-03-11 10:35:54.104  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 abgeschaltet -> LVN 32
      2024-03-11 10:36:48.101  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 1 abgeschaltet -> LVN 105
      2024-03-11 10:38:02.099  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 2 zugeschaltet -> LVN -223
      2024-03-11 10:40:34.562  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 zugeschaltet -> LVN -90
      2024-03-11 10:40:39.099  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 abgeschaltet -> LVN 76
      2024-03-11 10:40:50.094  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 2 abgeschaltet -> LVN 21
      2024-03-11 10:49:53.082  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 1 zugeschaltet -> LVN -229
      2024-03-11 11:02:43.062  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 1 abgeschaltet -> LVN 1333
      2024-03-11 11:08:10.055  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 1 zugeschaltet -> LVN -239
      2024-03-11 11:13:48.197  - info: admin.0 (1608) ==> Connected system.user.admin from ::ffff:192.168.178.22
      2024-03-11 11:13:52.806  - info: javascript.0 (1739) script.js.Kamera-Überwachung.Start_HaustuerKamera_Auzeichnung: Bewegung Haustür erkannt
      2024-03-11 11:14:34.642  - info: admin.0 (1608) <== Disconnect system.user.admin from ::ffff:192.168.178.22 admin
      2024-03-11 11:14:41.046  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 1 abgeschaltet -> LVN 34
      2024-03-11 11:14:57.078  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 zugeschaltet -> LVN -195
      2024-03-11 11:15:35.044  - info: javascript.0 (1739) script.js.Überwachung_Auswertung.Überschussverbraucher-Steuerung: Verbraucher 3 abgeschaltet -> LVN 81
      2024-03-11 11:17:13.056  - info: alexa2.0 (1984) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
      2024-03-11 11:17:14.493  - info: alexa2.0 (1984) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2024-03-11 11:23:59.030  - info: web.1 (2391) <== Disconnect system.user.admin from ::ffff:192.168.178.100 vis.0
      2024-03-11 11:24:11.879  - info: web.1 (2391) ==> Connected system.user.admin from ::ffff:192.168.178.100
      und hier das Summary
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         41M         58M
               3837 M total memory
               1765 M used memory
                508 M active memory
               1238 M free memory
                133 M buffer memory
                699 M swap cache
                 99 M total swap
                 41 M used swap
                 58 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      6.1G    /var/
      3.5G    /var/cache
      3.4G    /var/cache/apt
      1.8G    /var/log
      USB-Devices by-id:
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        4308
      States:         3527
      Pending Updates: 1
      Vielen Dank im Voraus für die Unterstützung!
      Ich habe die Adapter noch mal alle durchgeschaut, da finde ich keinen der den Port 3000 verwendet.
        Thomas Braun Most Active @Berny-K last edited by
        @berny-k sagte in Fullybrowser 3.0:
        Kernel : armv7l
        Bring das per NEUinstallation auf ein reines 64Bit-Lite-Bookworm / Raspberry OS 12
        Nicht aktuell.
        iob stop
        iob fix
        iob nodejs-update
        iob start
        Ran da.
        Repos:
        Beide rauswerfen.
        Grafana verwendet den über tcp6:
          Berny-K @Thomas Braun last edited by
          @thomas-braun Danke für die Infos!
          Da müsste ich schauen ob für Grafana auch ein anderer Port geht oder ginge bei Fullybrowser MQTT auch ein anderer Port?
            @thomas-braun die Repos aus Hit1 und Hit5 rauswerfen, wie geht das? Sorry ich bin da nicht so tief drin.
            Vor der Neuinstallation habe ich ziemlich Respekt, muss ich dann alles wieder von Grund auf neu installieren, iob etc.?
              Thomas Braun Most Active @Berny-K last edited by Thomas Braun
              Backup?
              Bei einer Neuinstallation erübrigt sich auch das herauswerfen der Repos, die sind nämlich da nicht aktiv.
              Um eine Neuinstallation kommst du nicht herum. Im Sommer läuft die Unterstützung von 'Debian 11 - Bullseye' aus und ein Dist-Upgrade auf 12 funktioniert nicht.
                A Former User @Berny-K last edited by
                Du kannst doch sowohl bei Grafana also auch bei MQTT eigene Ports waehlen... warum nimmst du fuer mqtt 3000?
                macht doch gar kein sinn, normal ist das der 1883 oder so, je nachdem was du noch nutzt auf deinem System.
                Nochmal zu den Ports, normal ist bei Fullykiosk der 2323 der Port, der auf dem Tablet angesprochen wird, fuer die Remoteadmin/Restapi, den kannst du natuerlich auch aendern, legst du dann in den Settings auf dem Tablet in Fully fest.
                Fuer mqtt, nimmst am besten einen freien, meist fuer mqtt 1883/4/5/6/7/8, der muss auf deinem Server mit iobroker vom Tablet erreichbar sein, denn dahin sendet das Tablet seine mqtt-requests.
                Standard fuer mqtt ist fuer den Sonoff/mqtt Adapter meist 1883 oder 1886, schau, was du alles an Adapter, die mqtt verwenden, damit sich da nichts in die quere kommt.
                  Berny-K @Guest last edited by
                  @ilovegym Super, danke für die tollen Tipps!
                  Den Port 3000 für Fully MQTT hatte ich gewählt weil es in der Doku stand 😊 . Werde das dann heute Abend mal mit den von dir genannten Ports probieren 👍
                    @thomas-braun Danke für die Unterstützung 👍 !
                    Dann werde ich das mit der Neuinstallation mal einplanen müssen. Werde ich wohl erst Anfang Sommer dazu kommen, jetzt geht's dann erst mal 3 Monate auf Tour um die iberische Halbinsel 😊
                      @berny-k
                      Bullseye wird wohl irgendwann in 07/24 abgekündigt werden.
                      Wobei Raspberry da wohl etwas anders als die Mutter-Distribution verfährt. Die haben immer die aktuelle stable und die Vorversion 'oldstable' im Support.
                      • theknut
                        theknut last edited by theknut
                        Also die Frage kam jetzt ja schon öfter, aber es hat auch nie jemand geschrieben, dass es dann irgendwann funktioniert hat. Die RestAPI Abfrage funktioniert ohne Probleme, nur bei MQTT bleibt der Adapter gelb. Im Log steht nur, dass er den MQTT Server auf Port 3000 gestartet hat. ioBroker läuft bei mir im Docker, also habe ich Port 1885 an 3000 weitergeleitet.
                          iobroker:
                            container_name: iobroker
                            image: buanet/iobroker:latest
                            hostname: iobroker
                            restart: unless-stopped
                            ports:
                              - "1880:1880"  #node-red
                              - "1883:1883"  #mqtt
                              - "1884:1884"  #sonoff
                              - "8081:8081"  #iobroker admin
                              - "1885:3000"  #fully kiosk mqtt
                              - "8088:8088"  #terminal
                              - "8284:8284"  #socketIO
                              - "8070:8070"  #lovelace ui
                        dann im Adapter konfiguriert
                        und dann auf dem Tablet
                        Mit oder ohne Passwort spielt keine Rolle. Habe auch mqtt:, http: und ohne Prefix probiert. Funktioniert alles nicht. Hat jemand eine Idee?
                          arteck Developer Most Active @theknut last edited by
                          @theknut das ist kein http protokoll
                          mqtt muss da rein
                          • theknut
                            @arteck hab ich auch schon probiert, das geht auch nicht. Adapter bleibt gelb. Habe es eben auch noch mal getestet.
                            DJMarc75 ? 2 Replies Last reply Reply Quote 0
                            • DJMarc75
                              DJMarc75 @theknut last edited by
                              @theknut läuft bei Dir Grafana ?
                                A Former User @theknut last edited by
                                @theknut warum Port 3000? Nimm doch n anderen..
                                  arteck Developer Most Active @Guest last edited by arteck
                                  @ilovegym welcher ist egal. hauptsache der wird in den Container durchgegeben
                                  @DJMarc75 was hat das mit grafana zu tun.. wenn dann wird dieser in eigenen container laufen
                                  hast du mal mit tcp versucht statt http
                                  theknut 1 Reply Last reply Reply Quote 0
                                  • theknut
                                    theknut @arteck last edited by
                                    @arteck habe ich auch probiert. Leider auch kein Erfolg. Wie arteck schon richtig gesagt hat, Grafana läuft in einem separaten Container, von daher gibt es da keinen Konflikt.
                                      inzwischen habe ich die Umstellung auf MQTT auch soweit hin bekommen.
                                      Lediglich die folgende Warnung im Log ist noch etwas störend:
                                      192.168.178.100 is not alive! (MQTT: client did not send message for more than 70 seconds)
                                      Obwohl ich inzwischen beim MQTT Timeout auf 90 Sek umgestellt habe ändert sich das nicht.
                                      Jemand vielleicht ne Idee woran es liegen könnte, dass noch immer die Meldung mit 70 Sek kommt obwohl ich 90 Sek eingestellt habe?
                                        arteck Developer Most Active @Berny-K last edited by
                                        da ist noch ein Bug gewesen.. instalier die GIT version .. sollte behoben sein
                                          Berny-K @arteck last edited by
                                          @arteck Danke für den Tipp!
                                            @arteck Habe jetzt die v3.0.12 von GIT installiert, sieht soweit alles gut aus 👍 .
                                            Was ich noch nicht so recht verstanden habe ist der Sinn und Zweck der Datenpunkte im Ordner Events.
                                            Die Werte scheinen sich ja nicht zu ändern aber der Zeitstempel dahinter. Also wenn z.B. der Info DP screenOn = true wird, dann bleibt der Event DP auf false aber der Zeitstempel wird geschrieben.
                                            Sorry wenn das vielleicht ne doofe Frage ist aber ich habe dazu keine Erklärung gefunden.
                                            278
                                            67652
