    4. Zigbee Probleme
    Zigbee Probleme
    • manuxi
      manuxi @Thomas Braun last edited by
      @thomas-braun Docker dauert noch was, hab grad keine Zeit. Hier die iob diag Ausgabe:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor : Synology Inc.
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.0.1
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       17:46:26 up 10 days, 18:25,  0 users,  load average: 3.24, 3.59, 3.66
      CPU threads: 4
      *** Time and Time Zones ***
      Wed Mar  6 16:46:26 UTC 2024
      Wed Mar  6 17:46:26 CET 2024
      CET +0100
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             19G         10G        1.1G        629M        7.9G        7.9G
      Swap:            14G        4.5G        9.6G
      Total:           34G         15G         10G
              19974 M total memory
              10990 M used memory
               8856 M active memory
               6477 M inactive memory
               1132 M free memory
                 73 M buffer memory
               7778 M swap cache
              14035 M total swap
               4467 M used swap
               9568 M free swap
      *** FILESYSTEM ***
      Filesystem             Type   Size  Used Avail Use% Mounted on
      /dev/mapper/cachedev_0 btrfs  214G  126G   88G  60% /
      tmpfs                  tmpfs   64M     0   64M   0% /dev
      tmpfs                  tmpfs  9.8G     0  9.8G   0% /sys/fs/cgroup
      shm                    tmpfs   64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev_0 btrfs  214G  126G   88G  60% /opt/iobroker
      /dev/mapper/cachedev_0 btrfs  214G  126G   88G  60% /etc/hosts
      sudo: unable to resolve host iobroker-v8: Name or service not known
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/bf0c59a675385d6269dbb83490810a1a4adb8c1bfb2b933357f738a870a23f2f]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=1238,subvol=/@syno/@docker/btrfs/subvolumes/bf0c59a675385d6269dbb83490810a1a4adb8c1bfb2b933357f738a870a23f2f
      |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker/data]        btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=258,subvol=/@syno/docker
      |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/54d552e5c72586629f085e0fba7641d05ff15e9d404b852905805f9af2c535ab/resolv.conf] btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/54d552e5c72586629f085e0fba7641d05ff15e9d404b852905805f9af2c535ab/hostname]    btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/54d552e5c72586629f085e0fba7641d05ff15e9d404b852905805f9af2c535ab/hosts]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      /var:
      33M     /var/
      31M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      1.4G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      573M    /opt/iobroker/iobroker-data/
      500M    /opt/iobroker/iobroker-data/files
      90M     /opt/iobroker/iobroker-data/files/echarts.admin
      69M     /opt/iobroker/iobroker-data/files/vis.0
      58M     /opt/iobroker/iobroker-data/files/echarts
      51M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-v8                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker-v8                              -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-v8                              -  enabled
      + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-v8                              -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker-v8                              -  enabled
        system.adapter.devices.0                : devices               : iobroker-v8                              - disabled
      + system.adapter.discovery.0              : discovery             : iobroker-v8                              - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker-v8                              -  enabled
        system.adapter.echarts.0                : echarts               : iobroker-v8                              - disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-v8                              -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker-v8                              -  enabled
        system.adapter.firetv.0                 : firetv                : iobroker-v8                              - disabled
      + system.adapter.followthesun.0           : followthesun          : iobroker-v8                              -  enabled
        system.adapter.ford.0                   : ford                  : iobroker-v8                              - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-v8                              -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker-v8                              - disabled
      + system.adapter.history.0                : history               : iobroker-v8                              -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : iobroker-v8                              -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker-v8                              -  enabled, port: 443
      + system.adapter.hue.1                    : hue                   : iobroker-v8                              -  enabled, port: 443
      + system.adapter.hue.2                    : hue                   : iobroker-v8                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.1                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.2                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.3                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.ical.4                   : ical                  : iobroker-v8                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker-v8                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-v8                              - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-v8                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker-v8                              -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-v8                              -  enabled
      + system.adapter.logparser.0              : logparser             : iobroker-v8                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-v8                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.musiccast.0              : musiccast             : iobroker-v8                              - disabled
      + system.adapter.net-tools.0              : net-tools             : iobroker-v8                              -  enabled
      + system.adapter.nina.0                   : nina                  : iobroker-v8                              -  enabled
      + system.adapter.nut.0                    : nut                   : iobroker-v8                              -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker-v8                              - disabled
        system.adapter.parcel.0                 : parcel                : iobroker-v8                              - disabled
      + system.adapter.pi-hole.0                : pi-hole               : iobroker-v8                              -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker-v8                              -  enabled
        system.adapter.plex.0                   : plex                  : iobroker-v8                              - disabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker-v8                              -  enabled
        system.adapter.pushover.0               : pushover              : iobroker-v8                              - disabled
      + system.adapter.ring.0                   : ring                  : iobroker-v8                              -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : iobroker-v8                              -  enabled, port: 45000, bind: 0.0.0.0
      + system.adapter.sayit.0                  : sayit                 : iobroker-v8                              -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker-v8                              -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-v8                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker-v8                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.slideshow.0              : slideshow             : iobroker-v8                              -  enabled
      + system.adapter.snmp.0                   : snmp                  : iobroker-v8                              -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker-v8                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sony-bravia.0            : sony-bravia           : iobroker-v8                              - disabled
      + system.adapter.spotify-premium.0        : spotify-premium       : iobroker-v8                              -  enabled
      + system.adapter.statistics.0             : statistics            : iobroker-v8                              -  enabled
      + system.adapter.synology.0               : synology              : iobroker-v8                              -  enabled, port: 5441
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-v8                              -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker-v8                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker-v8                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker-v8                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker-v8                              -  enabled
      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-v8                              -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker-v8                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-v8                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-v8                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-v8                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-v8                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-v8                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-v8                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-v8                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-v8                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-v8                              - disabled
        system.adapter.vis.0                    : vis                   : iobroker-v8                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-v8                              -  enabled
      + system.adapter.web.0                    : web                   : iobroker-v8                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : iobroker-v8                              -  enabled, port: 9082, bind: 0.0.0.0 (SSL), run as: ft
      + system.adapter.web.2                    : web                   : iobroker-v8                              -  enabled, port: 9084, bind: 0.0.0.0 (SSL), run as: gt
      + system.adapter.yamaha.0                 : yamaha                : iobroker-v8                              - disabled
        system.adapter.yr.0                     : yr                    : iobroker-v8                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker-v8                              -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "bosch-ebike"  : 0.0.3    , installed 0.1.5
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.3  [Updatable]
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "firetv"       : 2.0.2    , installed 2.0.2
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "ford"         : 0.0.14   , installed 0.0.14
      Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "hue"          : 3.10.2   , installed 3.10.2
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "plex"         : 1.1.4    , installed 1.1.4
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "ring"         : 5.0.10   , installed 5.0.10
      Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "snmp"         : 3.1.0    , installed 3.1.0
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.36
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        42133
      States:         43627
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 28
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:16509         0.0.0.0:*               LISTEN      0          146594     -
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          51894      -
      tcp        0      0 0.0.0.0:4190            0.0.0.0:*               LISTEN      0          218602357  -
      tcp        0      0 0.0.0.0:9086            0.0.0.0:*               LISTEN      0          108235     -
      tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          127574     -
      tcp        0      0 0.0.0.0:8800            0.0.0.0:*               LISTEN      0          112762     -
      tcp        0      0 0.0.0.0:5440            0.0.0.0:*               LISTEN      0          45392      -
      tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      0          218602431  -
      tcp        0      0 0.0.0.0:7777            0.0.0.0:*               LISTEN      0          134249     -
      tcp        0      0 0.0.0.0:5441            0.0.0.0:*               LISTEN      0          45394      -
      tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          43736      -
      tcp        0      0 0.0.0.0:20002           0.0.0.0:*               LISTEN      0          140358273  -
      tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          189967     -
      tcp        0      0 0.0.0.0:3010            0.0.0.0:*               LISTEN      0          113523     -
      tcp        0      0 0.0.0.0:7010            0.0.0.0:*               LISTEN      0          100791     -
      tcp        0      0 0.0.0.0:20003           0.0.0.0:*               LISTEN      0          140358275  -
      tcp        0      0 0.0.0.0:7011            0.0.0.0:*               LISTEN      0          100793     -
      tcp        0      0 127.0.0.1:37316         0.0.0.0:*               LISTEN      297536     47407154   -
      tcp        0      0 127.0.0.1:11332         0.0.0.0:*               LISTEN      0          397322     -
      tcp        0      0 0.0.0.0:2020            0.0.0.0:*               LISTEN      0          134251     -
      tcp        0      0 127.0.0.1:11333         0.0.0.0:*               LISTEN      0          397335     -
      tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          36874      -
      tcp        0      0 127.0.0.1:11334         0.0.0.0:*               LISTEN      0          397330     -
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      0          219838045  -
      tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1000       103592157  1721/io.sainlogic.0
      tcp        0      0 127.0.0.1:46632         0.0.0.0:*               LISTEN      297536     47417515   -
      tcp        0      0 0.0.0.0:9800            0.0.0.0:*               LISTEN      0          109849     -
      tcp        0      0 0.0.0.0:2249            0.0.0.0:*               LISTEN      0          287500594  -
      tcp        0      0 127.0.0.1:33833         0.0.0.0:*               LISTEN      297536     47418857   -
      tcp        0      0 0.0.0.0:9353            0.0.0.0:*               LISTEN      0          134247     -
      tcp        0      0 0.0.0.0:8010            0.0.0.0:*               LISTEN      0          106925     -
      tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      0          140358271  -
      tcp        0      0 0.0.0.0:587             0.0.0.0:*               LISTEN      0          303744     -
      tcp        0      0 0.0.0.0:3307            0.0.0.0:*               LISTEN      66         121959     -
      tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      0          109887     -
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          51895      -
      tcp        0      0 127.0.0.1:2380          0.0.0.0:*               LISTEN      0          105477     -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          167240     -
      tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      0          218602430  -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          45396      -
      tcp        0      0 0.0.0.0:31313           0.0.0.0:*               LISTEN      0          287500590  -
      tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      297536     47395761   -
      tcp        0      0 0.0.0.0:465             0.0.0.0:*               LISTEN      0          303738     -
      tcp        0      0 127.0.0.1:2385          0.0.0.0:*               LISTEN      0          154472     -
      tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN      0          182337     -
      tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          143463     -
      tcp        0      0 0.0.0.0:12340           0.0.0.0:*               LISTEN      0          218605575  -
      tcp        0      0 0.0.0.0:8500            0.0.0.0:*               LISTEN      259775     149142     -
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          219838039  -
      tcp        0      0 127.0.0.1:8181          0.0.0.0:*               LISTEN      0          219839124  -
      tcp        0      0 192.168.178.10:8181     0.0.0.0:*               LISTEN      0          219839123  -
      tcp        0      0 0.0.0.0:24245           0.0.0.0:*               LISTEN      0          218602440  -
      tcp        0      0 0.0.0.0:9526            0.0.0.0:*               LISTEN      1          388633     -
      tcp        0      0 0.0.0.0:5590            0.0.0.0:*               LISTEN      0          178510     -
      tcp        0      0 0.0.0.0:8502            0.0.0.0:*               LISTEN      259775     151634     -
      tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          110435     -
      tcp        0      0 0.0.0.0:5591            0.0.0.0:*               LISTEN      0          178512     -
      tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN      0          140358269  -
      tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      297536     47407209   -
      tcp        0      0 0.0.0.0:8088            0.0.0.0:*               LISTEN      0          108906     -
      tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         93671      -
      tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          34828      -
      tcp        0      0 127.0.0.1:8505          0.0.0.0:*               LISTEN      259775     390672     -
      tcp        0      0 0.0.0.0:9529            0.0.0.0:*               LISTEN      1          388634     -
      tcp        0      0 0.0.0.0:25              0.0.0.0:*               LISTEN      0          303729     -
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       103557099  515/io.shelly.0
      tcp        0      0 0.0.0.0:9530            0.0.0.0:*               LISTEN      259775     389205     -
      tcp        0      0 127.0.0.1:8506          0.0.0.0:*               LISTEN      0          289683     -
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       103554540  436/io.mqtt.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          45398      -
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       103554541  436/io.mqtt.0
      tcp        0      0 127.0.0.1:41980         0.0.0.0:*               LISTEN      297536     47417255   -
      tcp        0      0 127.0.0.1:41436         0.0.0.0:*               LISTEN      297536     47417242   -
      tcp        0      0 127.0.0.1:30300         0.0.0.0:*               LISTEN      0          158784     -
      tcp6       0      0 :::3261                 :::*                    LISTEN      0          49934      -
      tcp6       0      0 :::445                  :::*                    LISTEN      0          51892      -
      tcp6       0      0 :::4190                 :::*                    LISTEN      0          218602358  -
      tcp6       0      0 :::9086                 :::*                    LISTEN      0          108238     -
      tcp6       0      0 :::5566                 :::*                    LISTEN      0          78523      -
      tcp6       0      0 :::3263                 :::*                    LISTEN      0          49932      -
      tcp6       0      0 :::8000                 :::*                    LISTEN      1000       103607829  1902/io.upnp.0
      tcp6       0      0 :::8800                 :::*                    LISTEN      0          111717     -
      tcp6       0      0 :::3264                 :::*                    LISTEN      0          49935      -
      tcp6       0      0 :::5440                 :::*                    LISTEN      0          45393      -
      tcp6       0      0 :::3265                 :::*                    LISTEN      0          218579924  -
      tcp6       0      0 :::7777                 :::*                    LISTEN      0          134250     -
      tcp6       0      0 :::5441                 :::*                    LISTEN      0          45395      -
      tcp6       0      0 :::20002                :::*                    LISTEN      0          140358274  -
      tcp6       0      0 :::6690                 :::*                    LISTEN      0          189968     -
      tcp6       0      0 :::3010                 :::*                    LISTEN      0          114116     -
      tcp6       0      0 :::7010                 :::*                    LISTEN      0          100792     -
      tcp6       0      0 :::20003                :::*                    LISTEN      0          140358276  -
      tcp6       0      0 :::7011                 :::*                    LISTEN      0          100794     -
      tcp6       0      0 :::2020                 :::*                    LISTEN      0          134252     -
      tcp6       0      0 ::1:4711                :::*                    LISTEN      0          219838046  -
      tcp6       0      0 :::9800                 :::*                    LISTEN      0          112732     -
      tcp6       0      0 :::2249                 :::*                    LISTEN      0          287500596  -
      tcp6       0      0 :::6281                 :::*                    LISTEN      0          181331025  -
      tcp6       0      0 :::9353                 :::*                    LISTEN      0          134248     -
      tcp6       0      0 :::8010                 :::*                    LISTEN      0          105886     -
      tcp6       0      0 ::1:38443               :::*                    LISTEN      0          140358272  -
      tcp6       0      0 :::587                  :::*                    LISTEN      0          303745     -
      tcp6       0      0 :::6379                 :::*                    LISTEN      0          109888     -
      tcp6       0      0 :::139                  :::*                    LISTEN      0          51893      -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0          167241     -
      tcp6       0      0 :::32400                :::*                    LISTEN      297536     47395759   -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          45397      -
      tcp6       0      0 :::31313                :::*                    LISTEN      0          287500592  -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       103535165  151/io.admin.0
      tcp6       0      0 :::465                  :::*                    LISTEN      0          303739     -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       103608111  2014/io.web.0
      tcp6       0      0 :::12340                :::*                    LISTEN      0          218605576  -
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       103598522  1802/io.socketio.0
      tcp6       0      0 :::8500                 :::*                    LISTEN      259775     149143     -
      tcp6       0      0 :::53                   :::*                    LISTEN      0          219838041  -
      tcp6       0      0 :::8181                 :::*                    LISTEN      0          219839125  -
      tcp6       0      0 :::5590                 :::*                    LISTEN      0          178511     -
      tcp6       0      0 :::8502                 :::*                    LISTEN      259775     151635     -
      tcp6       0      0 :::8086                 :::*                    LISTEN      0          110440     -
      tcp6       0      0 :::5591                 :::*                    LISTEN      0          178513     -
      tcp6       0      0 ::1:38008               :::*                    LISTEN      0          140358270  -
      tcp6       0      0 :::8504                 :::*                    LISTEN      0          152312     -
      tcp6       0      0 :::8088                 :::*                    LISTEN      0          106933     -
      tcp6       0      0 :::25                   :::*                    LISTEN      0          303730     -
      tcp6       0      0 :::9082                 :::*                    LISTEN      1000       103611733  2032/io.web.1
      tcp6       0      0 :::8507                 :::*                    LISTEN      0          153880     -
      tcp6       0      0 :::443                  :::*                    LISTEN      0          45399      -
      tcp6       0      0 :::9084                 :::*                    LISTEN      1000       103614829  2049/io.web.2
      udp        0      0 0.0.0.0:40969           0.0.0.0:*                           1000       103604655  1902/io.upnp.0
      udp        0      0 0.0.0.0:8502            0.0.0.0:*                           259775     151638     -
      udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          34128      -
      udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          34127      -
      udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          34126      -
      udp        0      0 0.0.0.0:42795           0.0.0.0:*                           1000       103604656  1902/io.upnp.0
      udp        0      0 169.254.115.203:43843   0.0.0.0:*                           297536     47407175   -
      udp        0      0 192.168.178.10:43878    0.0.0.0:*                           297536     47407173   -
      udp        0      0 10.0.1.3:60919          0.0.0.0:*                           297536     47407174   -
      udp        0      0 0.0.0.0:47530           0.0.0.0:*                           1000       103604654  1902/io.upnp.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          219838038  -
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          33126      -
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          39004      -
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          310033777  -
      udp        0      0 192.168.178.10:137      0.0.0.0:*                           0          310033776  -
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          310033680  -
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          310033779  -
      udp        0      0 192.168.178.10:138      0.0.0.0:*                           0          310033778  -
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          310033681  -
      udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          43735      -
      udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          39002      -
      udp        0      0 0.0.0.0:33772           0.0.0.0:*                           1000       103596159  1785/io.snmp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       103607792  1902/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       103607791  1902/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       103607790  1902/io.upnp.0
      udp        0      0 0.0.0.0:1901            0.0.0.0:*                           297536     47407172   -
      udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         163698     -
      udp        0      0 0.0.0.0:37219           0.0.0.0:*                           0          37205      -
      udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       103563491  642/io.tr-064.0
      udp        0      0 172.18.0.1:5353         0.0.0.0:*                           1000       103563490  642/io.tr-064.0
      udp        0      0 192.168.178.10:5353     0.0.0.0:*                           1000       103563489  642/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          37203      -
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       103559458  544/io.shelly.1
      udp6       0      0 :::55825                :::*                                0          37206      -
      udp6       0      0 :::8502                 :::*                                259775     151639     -
      udp6       0      0 :::8503                 :::*                                0          153861     -
      udp6       0      0 :::53                   :::*                                0          219838040  -
      udp6       0      0 :::123                  :::*                                0          39005      -
      udp6       0      0 ::1:323                 :::*                                0          39003      -
      udp6       0      0 fe80::211:32ff:fe9b:546 :::*                                0          310018732  -
      udp6       0      0 :::3702                 :::*                                99         163700     -
      udp6       0      0 :::5353                 :::*                                0          37204      -
      2024-03-06 17:46:52.261  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:46:57.346  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:00.277  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:03.178  - info: mqtt.0 (436) Client [SL3P_35972DE4] connected with secret 1709743623178_4207
      2024-03-06 17:47:04.325  - info: mqtt.0 (436) Client [SL3P_35972DE4] subscribes on "mqtt.0.nuki.35972DE4.lockAction"
      2024-03-06 17:47:04.436  - info: mqtt.0 (436) Client [SL3P_35972DE4] subscribes on "mqtt.0.nuki.35972DE4.lock"
      2024-03-06 17:47:04.525  - info: mqtt.0 (436) Client [SL3P_35972DE4] publishOnSubscribe
      2024-03-06 17:47:04.532  - info: mqtt.0 (436) Client [SL3P_35972DE4] subscribes on "mqtt.0.nuki.35972DE4.unlock"
      2024-03-06 17:47:04.636  - info: mqtt.0 (436) Client [SL3P_35972DE4] publishOnSubscribe
      2024-03-06 17:47:04.732  - info: mqtt.0 (436) Client [SL3P_35972DE4] publishOnSubscribe
      2024-03-06 17:47:05.357  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:08.283  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:13.369  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:15.204  - info: javascript.0 (3093) script.js.common.Status.device_power: Vis battery level set to 6.
      2024-03-06 17:47:15.205  - info: javascript.0 (3093) script.js.common.Status.device_power: Galaxy Note 10.1 2014 Edition: BatteryLevel: 28, PlugEnabled: true.
      2024-03-06 17:47:16.335  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:17.490  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:20.318  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:22.423  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:25.350  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:28.427  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:31.356  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
      2024-03-06 17:47:35.419  - info: web.2 (2049) ==> Connected system.user.gt from ::ffff:192.168.178.84
      2024-03-06 17:47:38.370  - info: web.2 (2049) <== Disconnect system.user.gt from ::ffff:192.168.178.84 vis-2
        Thomas Braun Most Active @manuxi last edited by
        @manuxi
        Ich hab Zeit.
        manuxi 1 Reply Last reply Reply Quote 0
        • manuxi
          manuxi @Thomas Braun last edited by manuxi
          @thomas-braun Aktuelle Fehlermeldung
          zigbee.0
          2024-03-07 00:10:16.551	error	Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 18 - 61184 - 11 after 10000ms)
          zigbee.0
          2024-03-07 00:10:16.551	error	Error: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 18 - 61184 - 11 after 10000ms) at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:40:23) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:423:47) at async Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:20) at async Request.send (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/helpers/request.js:69:20) at async Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:572:28) at async Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js:101:13)
          zigbee.0
          2024-03-07 00:10:16.550	error	unhandled promise rejection: Command 0xa4c1387267ac600e/1 manuSpecificTuya.dataQuery({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 61457 - 1 - 18 - 61184 - 11 after 10000ms)
          zigbee.0
          2024-03-07 00:10:16.550	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          Scheint wohl der Tuya zu sein - bzw. die nicht gefangene Exception...
            arteck Developer Most Active @manuxi last edited by
            @manuxi installier mal die GIT version
            manuxi 2 Replies Last reply Reply Quote 0
            • manuxi
              manuxi @arteck last edited by manuxi
              @arteck Alles klar, werd ich machen (und berichten).
              • manuxi
                @arteck Hats leider nicht gebracht, eben wieder abgeschmiert. Meldung "Restart loop detected"
                • manuxi
                  manuxi @manuxi last edited by
                  Ich habe jetzt ein Script erstellt, was erkennen sollte, wenn die Instanz hängt und nach 20s erneut startet. Ich konnte noch nicht verifizieren, dass das auch klappt.
                  const idInst = 'system.adapter.zigbee.0';
                  const idAlive = idInst + '.alive';
                  on({id: idAlive, change: 'ne', val: false}, function() {
                      setTimeout(function() {
                          // Adapter nach 20 Sekunden starten
                          setState(idAlive, true);
                          sendTo("telegram", "send", {
                              text: 'Zigbee Instance has been restarted!'
                      }, 20000);
                  @Thomas-Braun mein ioBroker ist jetzt auf dem neuesten Stand. Werde iob diag posten, wenn das alles nix bringt.
                  Ralla66 1 Reply Last reply Reply Quote 0
                  • Ralla66
                    Ralla66 Most Active @manuxi last edited by Ralla66
                    @manuxi
                    Dann lösche den TuYa ZTH08_E aus dem Adapter und mache den Stromlos.
                    Dann weißte doch ob das der Fehler ist.
                    Einmal dabei, den ZP01 direkt mit weg.
                    • manuxi
                      manuxi @Ralla66 last edited by
                      So, das Script scheint zu laufen, alelrdings in sehr regelmäßigen Abständen - das kann kein Zufall sein. Telegram meldet seit heute Nacht im Abstand von genau einer Stunde jeweils, dass der Adapter neu gestartet wurde:
                      00:26 Zigbee Instance has been restarted!
                      01:26 Zigbee Instance has been restarted!
                      02:26 Zigbee Instance has been restarted!
                      0926 Zigbee Instance has been restarted!
                      @Ralla66 der ZP01 ist bereits abgeschaltet. Werde das wohl für den Tuya auch machen.
                      Allerdings bin ich der Meinung, dass das bereits im Code abgefangen werden müsste...
                      • Asgothian
                        Asgothian Developer @manuxi last edited by
                        @manuxi sagte in Zigbee Probleme:
                        Da hast du prinzipiell recht. Allerdings steht dem das Geschäftsmodell von TuYa entgegen:
                        Sie liefern Bausteine damit eine Firma eigene zigbee Geräte bauen kann. Dabei haben die zigbee Module gewisse Eigenschaften, von denen der OEM Hersteller einige anpassen muss. Das geschieht mal besser / mal schlechter und führt dazu das sich Geräte mit unterschiedlichen Fähigkeiten fast identisch bei Zigbee anmelden. Die meisten TuYa Zigbee Geräte nutzen zusätzlich leider nicht die fest vorgegebenen Zigbee Cluster sondern bilden identische Funktionen über einen TuYa spezifischen Cluster ab bei dem fast alles möglich ist.
                        An dieser Stelle entsteht auch dein Fehler - der Zigbee Adapter erwartet eine bestimmte Antwort vom Gerät, bekommt diese aber nicht.
                        Eigentlich müsste geprüft werden was an deinen Geräten anders ist als bei denen die eingebunden wurden. Das ist aber nicht trivial und benötigt Zugriff auf die Geräte.
                        A.
                        843
