    4. Zigbee Adapter bleibt seit JS Controller update rot
      Thomas Braun Most Active @Chris0680 last edited by
      @chris0680
      Kommt darauf an. Per apt?
      sudo apt update
      apt policy weewx
      Die Langfassung von
      iob diag
      darfst du aber trotzdem posten.
        Chris0680 @Meister Mopper last edited by Chris0680
        @meister-mopper
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         19:50:53 up  1:44,  3 users,  load average: 0.66, 0.56, 0.81
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-03-23 19:50:53 CET
                   Universal time: Sat 2024-03-23 18:50:53 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev weewx gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.2G        2.1G        3.7G        1.3M        2.5G        6.1G
        Swap:           104M          0B        104M
        Total:          8.3G        2.1G        3.8G
                 7812 M total memory
                 1978 M used memory
                 2125 M active memory
                 1805 M inactive memory
                 3547 M free memory
                  171 M buffer memory
                 2252 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      117G   11G  102G  10% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  924K  1.6G   1% /run
        /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
        /dev/sda1      vfat      7.5G   48M  7.5G   1% /mnt/usb0
        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
        [Sat Mar 23 18:06:39 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D7:DF:55 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4bad3edf-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sat Mar 23 18:06:40 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Mar 23 18:06:40 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sat Mar 23 18:06:45 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET      SOURCE         FSTYPE OPTIONS
        /           /dev/mmcblk0p2 ext4   rw,noatime
        |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        `-/mnt/usb0 /dev/sda1      vfat   rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.3G    /var/
        4.4G    /var/log
        4.0G    /var/log/journal/9c31795c88314e98b8e1f779f0d6e55b
        655M    /var/cache
        Archived and active journals take up 3.9G in the file system.
        /opt/iobroker/backups:
        48M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        384M    /opt/iobroker/iobroker-data/
        267M    /opt/iobroker/iobroker-data/files
        92M     /opt/iobroker/iobroker-data/backup-objects
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
        17M     /opt/iobroker/iobroker-data/objects.jsonl
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 600
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
             18.19.0-1nodesource1 600
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.bwt.0                    : bwt                   : ioBroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        + system.adapter.enigma2.0                : enigma2               : ioBroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
          system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        + system.adapter.hydrawise.0              : hydrawise             : ioBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.oekofen-json.0           : oekofen-json          : ioBroker                                 -  enabled
        + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
          system.adapter.pushover.0               : pushover              : ioBroker                                 - disabled
        + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "bwt"          : 0.0.5    , installed 0.0.5
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
        Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
        Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
        Adapter    "fuelpricemonitor": 0.4.0 , installed 0.4.0
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "oekofen-json" : 1.0.5    , installed 1.0.5
        Adapter    "parser"       : 2.1.0    , installed 2.1.0
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "telegram"     : 3.1.0    , installed 3.0.1  [Updatable]
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        14226
        States:         12982
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://weewx.com/apt/python3 buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E788768B9CB16E10
        W: Failed to fetch http://weewx.com/apt/python3/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E788768B9CB16E10
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://apt.grafana.com stable InRelease
        Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:6 https://repos.influxdata.com/debian stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Get:8 http://weewx.com/apt/python3 buster InRelease [4252 B]
        Err:8 http://weewx.com/apt/python3 buster InRelease
        Fetched 4252 B in 3s (1669 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        14317      636/mosquitto
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51268      8270/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       51275      8270/iobroker.js-co
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      651/sshd: /usr/sbin
        tcp        0      0 192.168.188.25:2001     0.0.0.0:*               LISTEN      1001       50803      8448/io.hm-rpc.0
        tcp6       0      0 :::1883                 :::*                    LISTEN      110        14318      636/mosquitto
        tcp6       0      0 :::80                   :::*                    LISTEN      0          15375      669/apache2
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      651/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51315      8288/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       52999      8953/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        15506      867/influxd
        tcp6       0      0 :::3000                 :::*                    LISTEN      109        16459      985/grafana
        udp        0      0 192.168.188.25:5353     0.0.0.0:*                           1001       52555      8497/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14096      414/avahi-daemon: r
        udp        0      0 0.0.0.0:44309           0.0.0.0:*                           108        14098      414/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13060      862/dhcpcd
        udp6       0      0 :::546                  :::*                                0          15421      862/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14097      414/avahi-daemon: r
        udp6       0      0 :::56916                :::*                                108        14099      414/avahi-daemon: r
        2024-03-23 19:49:05.154  - warn: bwt.0 (8523) Cannot receive local data updateDetails2 via: https://192.168.188.21/info/updateDetails2
        2024-03-23 19:49:05.175  - warn: bwt.0 (8523) Cannot receive local data actualizedata via: https://192.168.188.21/home/actualizedata
        2024-03-23 19:49:07.240  - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 11978
        2024-03-23 19:49:12.157  - info: zigbee.0 (11978) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.1, js-controller: 5.0.19
        2024-03-23 19:49:12.262  - info: zigbee.0 (11978) delete old Backup files. keep only last 10
        2024-03-23 19:49:12.265  - info: zigbee.0 (11978) Starting Zigbee  npm ...
        2024-03-23 19:49:12.599  - info: zigbee.0 (11978) Installed Version: iobroker.zigbee@1.10.1
        2024-03-23 19:49:13.255  - error: zigbee.0 (11978) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
        2024-03-23 19:49:13.256  - error: zigbee.0 (11978) Failed to start Zigbee
        2024-03-23 19:49:13.257  - error: zigbee.0 (11978) Error herdsman start
        2024-03-23 19:49:23.260  - info: zigbee.0 (11978) Try to reconnect. 1 attempts left
        2024-03-23 19:49:23.262  - info: zigbee.0 (11978) Starting Zigbee  npm ...
        2024-03-23 19:49:23.278  - info: zigbee.0 (11978) Installed Version: iobroker.zigbee@1.10.1
        2024-03-23 19:49:23.542  - error: zigbee.0 (11978) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
        2024-03-23 19:49:23.543  - error: zigbee.0 (11978) Failed to start Zigbee
        2024-03-23 19:49:23.544  - error: zigbee.0 (11978) Error herdsman start
        2024-03-23 19:50:05.201  - warn: bwt.0 (8523) Cannot receive local data actualizedata via: https://192.168.188.21/home/actualizedata
        2024-03-23 19:50:05.241  - warn: bwt.0 (8523) Cannot receive local data wasserverbrauch via: https://192.168.188.21/chart/update
        2024-03-23 19:50:05.255  - warn: bwt.0 (8523) Cannot receive local data updateDetails2 via: https://192.168.188.21/info/updateDetails2
        2024-03-23 19:51:05.237  - warn: bwt.0 (8523) Cannot receive local data actualizedata via: https://192.168.188.21/home/actualizedata
        2024-03-23 19:51:05.282  - warn: bwt.0 (8523) Cannot receive local data wasserverbrauch via: https://192.168.188.21/chart/update
        2024-03-23 19:51:05.328  - warn: bwt.0 (8523) Cannot receive local data updateDetails2 via: https://192.168.188.21/info/updateDetails2
        2024-03-23 19:52:05.149  - warn: bwt.0 (8523) Cannot receive local data actualizedata via: https://192.168.188.21/home/actualizedata
        2024-03-23 19:52:05.175  - warn: bwt.0 (8523) Cannot receive local data wasserverbrauch via: https://192.168.188.21/chart/update
        2024-03-23 19:52:05.194  - warn: bwt.0 (8523) Cannot receive local data updateDetails2 via: https://192.168.188.21/info/updateDetails2
          Chris0680 @Thomas Braun last edited by Chris0680
          @thomas-braun sudo apt update bringt folgende Meldung
          pi@ioBroker:~ $ sudo apt update
          OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:2 http://deb.debian.org/debian bookworm InRelease
          OK:3 http://security.debian.org/debian-security bookworm-security InRelease
          OK:4 http://deb.debian.org/debian bookworm-updates InRelease
          OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          OK:6 https://repos.influxdata.com/debian stable InRelease
          OK:7 https://apt.grafana.com stable InRelease
          Holen:8 http://weewx.com/apt/python3 buster InRelease [4.252 B]
          Fehl:8 http://weewx.com/apt/python3 buster InRelease
            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY E788768B9CB16E10
          Es wurden 4.252 B in 3 s geholt (1.605 B/s).
          Paketlisten werden gelesen… Fertig
          Abhängigkeitsbaum wird aufgebaut… Fertig
          Statusinformationen werden eingelesen… Fertig
          Alle Pakete sind aktuell.
          W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://weewx.com/apt/python3 buster InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY E788768B9CB16E10
          W: Fehlschlag beim Holen von http://weewx.com/apt/python3/dists/buster/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY E788768B9CB16E10
          W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
          N: Für das Depot »Debian bookworm« wurde der »non-free component«-Wert von »non-free« in »non-free non-free-firmware« geändert.
          N: Weitere Informationen hierzu finden Sie online in den Veröffentlichungshinweisen unter https://www.debian.org/releases/bookworm/arm64/release-notes/ch-information.html#non-free-split.
            @chris0680
            Da ist ein Bookworm nicht richtig installiert worden.
            Raspberry OS kann man nicht (ohne viele Fettnäpfchen mit zu nehmen) einfach per Dist-Upgrade auf Version 12 bringen.
            Installier es NEU von Grund auf.
              @thomas-braun Meinst du weewx oder das komplette System?
              Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
              • Meister Mopper
                Meister Mopper @Chris0680 last edited by
                @chris0680
                Alles!!!
                  @chris0680
                  Von Grund auf NEU: Alles neu. Von Grund auf.
                    @meister-mopper nicht dein ernst. Dann sind alle Daten weg. Kann ich die Backups aus dem Backup Adapter IOBroker dann irgendwie wieder herstellen?
                      @chris0680 sagte in Zigbee Adapter bleibt seit JS Controller update rot:
                      Warum sind dann alle Daten weg? Dazu hat man Backups der wichtigen Daten.
                        @thomas-braun die Vorgangsweise ist dann welche?
                          @chris0680
                          Frische Backups ziehen. Von allen Diensten, die da auf dem Ding laufen. Für den ioBroker mittels backitup-Adapter, für z. B. weeWX musste selber mal schauen, wie das da geht.
                          Frisches Raspberry OS 12 'Bookworm' in der 64Bit Lite Version installieren, Dienste installieren, Backups wieder reinjubeln, fertig.
                          C 1 Reply Last reply Reply Quote 1
                            @thomas-braun leider funktioniert jetzt der info adapter nicht mehr.
                              @chris0680
                              Der ist ja auch abgekündigt. Kannst du deinstallieren.
                                @thomas-braun bin jetzt auf ein Proxmox System umgezogen - ioBroker läuft jetzt in einen lxc Container und Backups sind leichter zu erstellen und wieder herzustellen. LG Chris
                                636
