[geklärt]Sonoff-Adapter plötzlich gelb
Oh-ha.... Ich weiß, System ist hoffnungslos veraltet. Die Bemühungen dienen schon, es wieder auf Vordermann zu bringen. Aber es gibt öfters solche Rückschläge und Verzögerungen.... Und ich kann es leider nicht kontinuierlich durchziehen.
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker4 Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 4.19.75-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 17:06:37 up 5 min, 1 user, load average: 6.83, 4.45, 1.90 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Thu 2024-03-21 17:06:38 CET Universal time: Thu 2024-03-21 16:06:38 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.9G 1.7G 1.7G 24M 502M 2.5G Swap: 99M 0B 99M Total: 4.0G 1.7G 1.8G 3906 M total memory 1676 M used memory 1311 M active memory 711 M inactive memory 1727 M free memory 63 M buffer memory 439 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * owftpd.service loaded failed failed Anonymous FTP server for 1-wire access LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 15G 5.9G 8.1G 43% / devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev tmpfs tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs tmpfs 2.0G 25M 1.9G 2% /run tmpfs tmpfs 5.0M 8.0K 5.0M 1% /run/lock tmpfs tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup tmpfs tmpfs 4.0M 96K 4.0M 3% /home/pi/ramdisk /dev/sda1 ext4 15G 7.8G 6.1G 56% /media/usbstick2 /dev/sdb1 fuseblk 60G 46G 15G 77% /media/pishrink /dev/mmcblk0p1 vfat 253M 52M 201M 21% /boot tmpfs tmpfs 391M 0 391M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Thu Mar 21 17:01:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M smsc95xx.macaddr=DC:A6:32:41:9D:C4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [Thu Mar 21 17:01:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Thu Mar 21 17:01:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Thu Mar 21 17:01:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [Thu Mar 21 17:01:38 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/run/owfs OWFS fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other |-/media/usbstick2 /dev/sda1 ext4 rw,relatime |-/media/pishrink /dev/sdb1 fuseblk rw,nosuid,nodev,noexec,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 668M /var/ 413M /var/cache 407M /var/cache/apt 348M /var/cache/apt/archives 140M /var/lib Archived and active journals take up 24.0M in the file system. /opt/iobroker/backups: 435M /opt/iobroker/backups/ 10M /opt/iobroker/backups/skripte 5.5M /opt/iobroker/backups/skripte/AllgemeinProgramme 2.5M /opt/iobroker/backups/skripte/VolkersÜbungen 2.5M /opt/iobroker/backups/skripte/AllgemeinProgramme/5_SOLAR /opt/iobroker/iobroker-data: 657M /opt/iobroker/iobroker-data/ 401M /opt/iobroker/iobroker-data/files 132M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png 65M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 36M /opt/iobroker/iobroker-data/objects.json.bak 36M /opt/iobroker/iobroker-data/objects.json 26M /opt/iobroker/iobroker-data/objects.json.old 18M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191391-if00 *** NodeJS-Installation *** /usr/bin/nodejs v12.18.2 /usr/bin/node v12.18.2 /usr/bin/npm 6.14.5 /usr/bin/npx 6.14.5 /home/iobroker/.diag.sh: line 281: corepack: command not found *** nodejs is NOT correctly installed *** nodejs: Installed: 12.18.2-1nodesource1 Candidate: 12.22.12-deb-1nodesource1 Version table: 12.22.12-deb-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages *** 12.18.2-1nodesource1 100 100 /var/lib/dpkg/status 10.21.0~dfsg-1~deb10u1+rpi1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! extraneous: @serialport/binding-mock /opt/iobroker/node_modules/@serialport/binding-mock npm ERR! error in /opt/iobroker/node_modules/@serialport/binding-mock: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@serialport/binding-mock/package.json' npm ERR! extraneous: serialport /opt/iobroker/node_modules/serialport npm ERR! error in /opt/iobroker/node_modules/serialport: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/serialport/package.json' npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload npm ERR! extraneous: fsevents@2.1.2 /opt/iobroker/node_modules/fsevents npm ERR! extraneous: iobroker.wetty@0.1.1 /opt/iobroker/node_modules/iobroker.wetty npm ERR! extraneous: soef@0.4.15 /opt/iobroker/node_modules/soef npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1 npm ERR! missing: @serialport/bindings-interface@1.2.2, required by @serialport/bindings-cpp@10.8.0 npm ERR! missing: @serialport/bindings-interface@1.2.2, required by @serialport/stream@10.5.0 npm ERR! missing: @serialport/bindings-interface@^1.2.1, required by @serialport/binding-mock@10.2.2 *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: file States type: file Core adapters versions js-controller: 3.2.16 admin: 4.2.1 javascript: 5.1.3 npm ERR! extraneous: @serialport/binding-mock /opt/iobroker/node_modules/@serialport/binding-mock npm ERR! error in /opt/iobroker/node_modules/@serialport/binding-mock: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@serialport/binding-mock/package.json' npm ERR! extraneous: serialport /opt/iobroker/node_modules/serialport npm ERR! error in /opt/iobroker/node_modules/serialport: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/serialport/package.json' npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload npm ERR! extraneous: fsevents@2.1.2 /opt/iobroker/node_modules/fsevents npm ERR! extraneous: iobroker.wetty@0.1.1 /opt/iobroker/node_modules/iobroker.wetty npm ERR! extraneous: soef@0.4.15 /opt/iobroker/node_modules/soef npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1 npm ERR! missing: @serialport/bindings-interface@1.2.2, required by @serialport/bindings-cpp@10.8.0 npm ERR! missing: @serialport/bindings-interface@1.2.2, required by @serialport/stream@10.5.0 npm ERR! missing: @serialport/bindings-interface@^1.2.1, required by @serialport/binding-mock@10.2.2 Adapters from github: 6 Adapter State + system.adapter.admin.0 : admin : iobroker4 - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker4 - enabled system.adapter.alias-manager.0 : alias-manager : iobroker4 - disabled system.adapter.awattar.0 : awattar : iobroker4 - enabled + system.adapter.backitup.0 : backitup : iobroker4 - enabled system.adapter.bluelink.0 : bluelink : iobroker4 - disabled system.adapter.bydbatt.0 : bydbatt : iobroker4 - disabled + system.adapter.bydhvs.0 : bydhvs : iobroker4 - enabled system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker4 - enabled system.adapter.daswetter.0 : daswetter : iobroker4 - enabled + system.adapter.deconz.0 : deconz : iobroker4 - enabled, port: 8090 system.adapter.devices.0 : devices : iobroker4 - disabled + system.adapter.discovery.0 : discovery : iobroker4 - enabled system.adapter.dwd.0 : dwd : iobroker4 - enabled system.adapter.feiertage.0 : feiertage : iobroker4 - enabled system.adapter.flot.0 : flot : iobroker4 - disabled + system.adapter.fritzdect.0 : fritzdect : iobroker4 - enabled system.adapter.fronius-solarweb.0 : fronius-solarweb : iobroker4 - disabled + system.adapter.fronius.0 : fronius : iobroker4 - enabled + system.adapter.fronius.1 : fronius : iobroker4 - enabled system.adapter.go-e-charger.0 : go-e-charger : iobroker4 - disabled + system.adapter.go-e.0 : go-e : iobroker4 - enabled + system.adapter.history.0 : history : iobroker4 - enabled system.adapter.ical.0 : ical : iobroker4 - enabled system.adapter.icons-material-svg.0 : icons-material-svg : iobroker4 - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker4 - disabled + system.adapter.info.0 : info : iobroker4 - enabled + system.adapter.javascript.0 : javascript : iobroker4 - enabled system.adapter.material.0 : material : iobroker4 - disabled system.adapter.mqtt.0 : mqtt : iobroker4 - disabled, port: 1883, bind: 0.0.0.0 system.adapter.netatmo-crawler.0 : netatmo-crawler : iobroker4 - enabled + system.adapter.node-red.0 : node-red : iobroker4 - enabled, port: 1881, bind: 0.0.0.0 system.adapter.openweathermap.0 : openweathermap : iobroker4 - enabled + system.adapter.owfs.0 : owfs : iobroker4 - enabled, port: 4304 + system.adapter.parser.0 : parser : iobroker4 - enabled + system.adapter.ping.0 : ping : iobroker4 - enabled + system.adapter.rpi2.0 : rpi2 : iobroker4 - enabled + system.adapter.scenes.0 : scenes : iobroker4 - enabled system.adapter.schoolfree.0 : schoolfree : iobroker4 - enabled + system.adapter.shelly.0 : shelly : iobroker4 - enabled, port: 1888, bind: 192.168.178.100 + system.adapter.shelly.1 : shelly : iobroker4 - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.simple-api.0 : simple-api : iobroker4 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker4 - enabled, port: 1888, bind: 192.168.178.100 system.adapter.sql.0 : sql : iobroker4 - disabled, port: 0 + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker4 - enabled + system.adapter.telegram.0 : telegram : iobroker4 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : iobroker4 - enabled + system.adapter.tr-064.0 : tr-064 : iobroker4 - enabled + system.adapter.tronity.0 : tronity : iobroker4 - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker4 - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker4 - disabled system.adapter.vis-history.0 : vis-history : iobroker4 - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker4 - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker4 - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobroker4 - enabled system.adapter.vis-keyboard.0 : vis-keyboard : iobroker4 - disabled system.adapter.vis-map.0 : vis-map : iobroker4 - disabled system.adapter.vis-material.0 : vis-material : iobroker4 - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker4 - disabled system.adapter.vis-metro.0 : vis-metro : iobroker4 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker4 - disabled system.adapter.vis-weather.0 : vis-weather : iobroker4 - disabled system.adapter.vis.0 : vis : iobroker4 - enabled system.adapter.weatherunderground.0 : weatherunderground : iobroker4 - enabled + system.adapter.web.0 : web : iobroker4 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.wetty.0 : wetty : iobroker4 - disabled, port: 8089, bind: 0.0.0.0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker4 - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.deconz.0 : deconz : iobroker4 - enabled, port: 8090 + system.adapter.node-red.0 : node-red : iobroker4 - enabled, port: 1881, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : iobroker4 - enabled, port: 4304 + system.adapter.shelly.0 : shelly : iobroker4 - enabled, port: 1888, bind: 192.168.178.100 + system.adapter.shelly.1 : shelly : iobroker4 - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.simple-api.0 : simple-api : iobroker4 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker4 - enabled, port: 1888, bind: 192.168.178.100 + system.adapter.telegram.0 : telegram : iobroker4 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker4 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo: stable Installed ioBroker-Instances Used repository: stable hash changed or no sources cached => force download of new sources Cannot get any information of "_repoInfo". Ignored. update done Adapter "admin" : 6.13.16 , installed 4.2.1 [Updateable] Adapter "alexa2" : 3.26.4 , installed 3.9.3 [Updateable] Adapter "alias-manager" : 1.2.6 , installed 1.2.6 Adapter "awattar" : 1.0.6 , installed 1.0.6 Adapter "backitup" : 2.10.11 , installed 2.1.13 [Updateable] Adapter "bluelink" : 2.3.6 , installed 2.3.6 Adapter "bydbatt" : 1.1.0 , installed 1.0.8 [Updateable] Adapter "bydhvs" : 1.5.0 , installed 1.4.0 [Updateable] Adapter "coronavirus-statistics": 0.9.0 , installed 0.8.7 [Updateable] Adapter "daswetter" : 3.1.13 , installed 3.1.10 [Updateable] Adapter "deconz" : 1.4.0 , installed 1.3.16 [Updateable] Adapter "devices" : 1.1.5 , installed 0.3.16 [Updateable] Adapter "discovery" : 4.4.0 , installed 3.1.0 [Updateable] Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "feiertage" : 1.1.4 , installed 1.1.0 [Updateable] Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.2.6 [Updateable] Adapter "fronius" : 2.0.2 , installed 1.1.3 [Updateable] Adapter "fronius-solarweb": 0.0.3 , installed 0.0.3 Adapter "go-e" : 1.0.29 , installed 1.0.27 [Updateable] Adapter "history" : 3.0.1 , installed 1.9.13 [Updateable] Adapter "ical" : 1.13.3 , installed 1.12.1 [Updateable] Adapter "icons-material-svg": 0.1.0 , installed 0.1.0 Adapter "icons-open-icon-library-png": 0.1.2 , installed 0.1.3 Adapter "javascript" : 7.8.0 , installed 5.1.3 [Updateable] Controller "js-controller" : 5.0.19 , installed 3.2.16 [Updateable] Adapter "material" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 5.2.0 , installed 2.4.0 [Updateable] Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "node-red" : 5.1.0 , installed 2.4.0 [Updateable] Adapter "openweathermap": 1.0.4 , installed 0.1.0 [Updateable] Adapter "owfs" : 0.7.0 , installed 0.7.0 Adapter "parser" : 2.1.0 , installed 1.3.2 [Updateable] Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "rpi2" : 1.3.2 , installed 1.3.1 [Updateable] Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "schoolfree" : 1.1.4 , installed 1.0.1 [Updateable] Adapter "shelly" : 6.6.1 , installed 4.0.7 [Updateable] Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.6.0 , installed 3.1.4 [Updateable] Adapter "sonoff" : 3.0.3 , installed 2.5.3 [Updateable] Adapter "sql" : 2.2.0 , installed 1.15.7 [Updateable] Adapter "tankerkoenig" : 3.3.7 , installed 2.1.1 [Updateable] Adapter "telegram" : 3.1.0 , installed 1.10.0 [Updateable] Adapter "text2command" : 3.0.3 , installed 3.0.2 [Updateable] Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tronity" : 1.1.1 , installed 1.1.1 Adapter "vis" : 1.5.4 , installed 1.4.16 [Updateable] Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets" : 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.5.0 , installed 0.90.0 [Updateable] Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-map" : 1.0.5 , installed 1.0.4 [Updateable] Adapter "vis-material" : 0.1.3 , installed 0.1.3 Adapter "vis-materialdesign": 0.5.9 , installed 0.3.19 [Updateable] Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2 , installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.6 [Updateable] Adapter "weatherunderground": 3.6.0 , installed 3.4.2 [Updateable] Adapter "web" : 6.2.3 , installed 3.4.1 [Updateable] Objects and States Please stand by - This may take a while Objects: 30637 States: 29813 *** OS-Repositories and Updates *** E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldoldstable' E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldoldstable' Pending Updates: 121 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1881 0.0.0.0:* LISTEN 1001 23252 2412/node-red tcp 0 0 0.0.0.0:8090 0.0.0.0:* LISTEN 1000 16568 339/deCONZ tcp 0 0 192.168.178.100:1883 0.0.0.0:* LISTEN 1001 26425 2524/io.shelly.1 tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 16570 339/deCONZ tcp 0 0 192.168.178.100:1888 0.0.0.0:* LISTEN 1001 25469 2413/io.shelly.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 17824 688/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 17817 688/iobroker.js-con tcp 0 0 0.0.0.0:2121 0.0.0.0:* LISTEN 109 14819 503/owhttpd tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18519 693/sshd tcp6 0 0 :::80 :::* LISTEN 1001 24932 2412/node-red tcp6 0 0 :::4304 :::* LISTEN 0 13623 1/init tcp6 0 0 :::8081 :::* LISTEN 1001 16658 830/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 29714 3144/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 18521 693/sshd tcp6 0 0 :::8087 :::* LISTEN 1001 26320 2537/io.simple-api. udp 0 0 192.168.178.100:5353 0.0.0.0:* 1001 29294 2830/io.tr-064.0 udp 0 0 192.168.178.100:5353 0.0.0.0:* 1001 29293 2830/io.tr-064.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14783 440/avahi-daemon: r udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 24933 2412/node-red udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 16944 1261/io.deconz.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 16599 339/deCONZ udp 0 0 0.0.0.0:68 0.0.0.0:* 0 16561 685/dhcpcd udp 0 0 0.0.0.0:34930 0.0.0.0:* 108 14785 440/avahi-daemon: r udp6 0 0 :::46739 :::* 108 14786 440/avahi-daemon: r udp6 0 0 :::5353 :::* 108 14784 440/avahi-daemon: r udp6 0 0 :::1900 :::* 1001 16948 1261/io.deconz.0 udp6 0 0 :::1900 :::* 1001 16947 1261/io.deconz.0 udp6 0 0 :::1900 :::* 1001 16946 1261/io.deconz.0 udp6 0 0 :::1900 :::* 1001 16945 1261/io.deconz.0 udp6 0 0 :::546 :::* 0 15203 685/dhcpcd *** Log File - Last 25 Lines *** 2024-03-21 17:08:05.467 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.126 (Sonoff-Relais6-TV / Sonoff-Relais6-TV-Ecke / undefined#Ecke#1) for MQTT does not exist! 2024-03-21 17:08:05.679 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.156 (Sonoff / Sonoff-POW1_Waschmaschine / undefined#POW1_Waschmaschine#1) for MQTT does not exist! 2024-03-21 17:08:06.167 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.125 (Sonoff / Sonoff-Relais5 / undefined#Relais5#1) for MQTT does not exist! 2024-03-21 17:08:06.271 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.122 (Sonoff / Sonoff-Relais2 / undefined#Relais2#1) for MQTT does not exist! 2024-03-21 17:08:06.704 - warn: parser.0 (2076) Cannot read link "/home/pi/ramdisk/export-strom.txt": File does not exist 2024-03-21 17:08:07.072 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.177 (Gosund / Gosund-2 / undefined#2#1) for MQTT does not exist! 2024-03-21 17:08:08.437 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.121 (Sonoff / Sonoff-Relais1 / undefined#Relais1#1) for MQTT does not exist! 2024-03-21 17:08:09.409 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.178 (Gosund / Gosund-3 / undefined#3#1) for MQTT does not exist! 2024-03-21 17:08:15.060 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.123 (Sonoff / Sonoff-Relais3 / undefined#Relais3#1) for MQTT does not exist! 2024-03-21 17:08:16.044 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.173 (Sonoff / Sonoff-Basic03 / undefined#Basic03#1) for MQTT does not exist! 2024-03-21 17:08:16.449 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.126 (Sonoff-Relais6-TV / Sonoff-Relais6-TV-Ecke / undefined#Ecke#1) for MQTT does not exist! 2024-03-21 17:08:16.657 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.156 (Sonoff / Sonoff-POW1_Waschmaschine / undefined#POW1_Waschmaschine#1) for MQTT does not exist! 2024-03-21 17:08:16.705 - warn: parser.0 (2076) Cannot read link "/home/pi/ramdisk/export-strom.txt": File does not exist 2024-03-21 17:08:17.171 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.125 (Sonoff / Sonoff-Relais5 / undefined#Relais5#1) for MQTT does not exist! 2024-03-21 17:08:17.291 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.122 (Sonoff / Sonoff-Relais2 / undefined#Relais2#1) for MQTT does not exist! 2024-03-21 17:08:18.059 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.177 (Gosund / Gosund-2 / undefined#2#1) for MQTT does not exist! 2024-03-21 17:08:19.462 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.121 (Sonoff / Sonoff-Relais1 / undefined#Relais1#1) for MQTT does not exist! 2024-03-21 17:08:19.745 - error: javascript.0 (1806) script.js.AllgemeinProgramme.5_SOLAR.4_Stromabgabe-a: Oma aus 2024-03-21 17:08:19.893 - warn: sonoff.0 (2596) Client "Gosund-3" not connected 2024-03-21 17:08:20.427 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.178 (Gosund / Gosund-3 / undefined#3#1) for MQTT does not exist! 2024-03-21 17:08:26.073 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.123 (Sonoff / Sonoff-Relais3 / undefined#Relais3#1) for MQTT does not exist! 2024-03-21 17:08:26.706 - warn: parser.0 (2076) Cannot read link "/home/pi/ramdisk/export-strom.txt": File does not exist 2024-03-21 17:08:27.066 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.173 (Sonoff / Sonoff-Basic03 / undefined#Basic03#1) for MQTT does not exist! 2024-03-21 17:08:27.468 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.126 (Sonoff-Relais6-TV / Sonoff-Relais6-TV-Ecke / undefined#Ecke#1) for MQTT does not exist! 2024-03-21 17:08:27.670 - error: shelly.0 (2413) Shelly Device unknown, configuration for Shelly device 192.168.178.156 (Sonoff / Sonoff-POW1_Waschmaschine / undefined#POW1_Waschmaschine#1) for MQTT does not exist!
iob diag has finished.
Press any key for a summary
Gnadenlos veraltet.
Installier da NEU! ein aktuelles Raspberry OS 12 'Bookworm' in der 64Bit Lite Version.
Zuvor den ioBroker vollumfänglich auf einen aktuellen Stand bringen und dann mit einem Backup davon umziehen.
Diesen Ansatz hatte ich schon mal gestartet. Aber das Einspielen des Backups hing sich auf.
Manche Adapter lassen sich auch nicht mehr aktueller machen, als sie jetzt sind, da sie bereits ein aktuelleres ioB erwarten.
Leider muss ich zwischendurch immer wieder längere Pausen machen. Und dabei passierte mir jetzt das.
Wie gesagt, heute früh lief es noch. Bevor ich heute weitere Aktualisierungen vornehmen wollte, habe ich zur Sicherheit ein Image gezogen und nach dem Neustart läuft Sonoff nicht mehr.
Da ich nichts weiter gemacht hatte, hatte ich schon die Shellys im Verdacht und vorhin mit erwähnt. -
@docadams Wenn Du da nicht auf alles aktualisieren setzt, dann kann man leider auch nicht helfen.
Nicht falsch verstehen, aber wenn man das System nicht pflegt dann fällt Dir das auf die Füße.
Woran hängt es denn ?
@djmarc75 Keine Angst, ich verstehe hier nichts falsch
Ich lerne seit 1956 immer mehr dazu, war aber lange Zeit krank. Gehört aber nicht hierher.
Kann man in einem Ruck "alles aktualisieren"? Oder hab ich das falsch verstanden?
Jetzt kam im Terminal noch ein Nachschlag, weil ich vorhin nicht gleich eine Taste drückte.
Nur der Vollständigkeit halber hier der Rest:======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobroker4 Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 4.19.75-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: armhf Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 121 Pending iob updates: 38 Nodejs-Installation: /usr/bin/nodejs v12.18.2 /usr/bin/node v12.18.2 /usr/bin/npm 6.14.5 /usr/bin/npx 6.14.5 /home/iobroker/.diag.sh: line 490: corepack: command not found Recommended versions are nodejs Cannot load "custom": Connection is closed. Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed. Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected string in JSON at position 35953691. Try last Backup! No connection to databases possible ... and npm *** nodejs is NOT correctly installed *** Wrong installation path detected. This needs to be fixed Please check https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian for more information on how to fix these errors. MEMORY: total used free shared buff/cache available Mem: 3.9G 2.3G 727M 24M 855M 1.9G Swap: 99M 0B 99M Total: 4.0G 2.3G 827M Active iob-Instances: 31 Active repo: stable ioBroker Core: js-controller 3.2.16 admin 4.2.1 ioBroker Status: iobroker is running on this host. Objects type: file States type: file Status admin and web instance: + system.adapter.admin.0 : admin : iobroker4 - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.web.0 : web : iobroker4 - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 30637 States: 29813 Size of iob-Database: 36M /opt/iobroker/iobroker-data/objects.json.bak 36M /opt/iobroker/iobroker-data/objects.json 26M /opt/iobroker/iobroker-data/objects.json.old 6.2M /opt/iobroker/iobroker-data/states.json.bak 6.2M /opt/iobroker/iobroker-data/states.json 4.3M /opt/iobroker/iobroker-data/states.json.old =================== END OF SUMMARY ====================
@docadams sagte in Sonoff-Adapter plötzlich gelb:
Ja, kann man.
Es funktioniert mit Linux und dem ioBroker etwas kreativer. Die Systeme müssen regelmäßig gewartet werden!
Interessanterweise beachten es alle, die einen Garten haben. Dort achtet man auf fortführende Pflege, aber im IT-Bereich tun sie es wesentlich seltener, obwohl sehr viele Parallelen zu beobachten sind.
Ich z. B. pflege täglich (wöchentlich reicht wahrscheinlich auch):
- Prüfung mit
apticron
, ob die Linux-Systeme noch up to date sind. Ansonsten werden sie aktualisiert. - Überwachung des eol von Linux-Distributionen => deutlich vor Ablauf mache ich ein Upgrade auf das neue (lts) System (manchmal ist ein Neuaufsetzten erforderlich - das bekomme ich hier im Forum mit den Beiträgen von @Thomas-Braun mit, der sich wirklich im Bereich Support den A... aufreißt - sorry für die Assoziation).
- Prüfung und Durchführung von vorhandenen (stable) Adapterupdates und dem js-controller
Auf diese Weise ist man immer mit der Nase und dem System vorne und für unangenehme Überraschungen weitestgehend gefeit.
- Prüfung mit
Verbunden mit Host und Lebenszeichen sind wahr, aber verbunden mit Sonoff ist falsch.
Außer Neustart habe ich nichts gemacht oder verändert.Na ja, du hast bind auf die IP und nutzt die falschen Ports
Folgt man der shelly Doku, Port 1882.
Der mqtt Adapter läuft in der Regel auf 1883.
Sonoff kannst daher auf z. B. 1885 legenDamit sich die Ports nicht in die Quere kommen, weil ja letztendlich alle drei Adapter mqtt nutzen
Natürlich musst du entsprechend die Ip:Port auch in den Jeweiligen Geräten hinterlegen
Und genau deswegen lässt man das Ding nämlich nicht so gnadenlos versumpfen.
iob stop iob fix iob nodejs-update sudo apt update sudo apt upgrade sudo reboot iob update iob upgrade iob stop iob upgrade-self iob start
sollte dich einigermaßen in die Gegenwart katapultieren.
mein längeres Schweigen bedeutete, dass ich mehrere Versuche gestartet hatte.
Zunächst einmal, mein eigentliches Problem bleibt"seltsam". Zunächst hatte ich wieder ein Image der SD gemacht und nach dem Neustrart ähnliches Phänomen, nur anders rum.
Warum auch immer, die Sonoffs lassen sich nach dem Neustart wieder ansprechen.Nun aber zu deiner Aufgabenliste.
Die Befehle 1 bis 6 liefen durch, allerdings tauchten bei iob fix auch diese Zeilen auf:... OK:4 https://deb.nodesource.com/node_12.x buster InRelease Paketlisten werden gelesen... Fertig E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wur de der »Suite«-Wert von »stable« in »oldoldstable« geändert. N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie we itere Informationen benötigen. E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldoldstable« geändert. N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie we itere Informationen benötigen. ...
Der Rest lief anstandslos durch.
Nach dem Reboot stehe ich aber weiterhin bei:cat /etc/os-release PRETTY_NAME="Raspbian GNU/Linux 10 (buster)" NAME="Raspbian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Ab Befehl 8 gibt es aber Probleme:
ar 24 14:56:07 2024 from 192.168.178.25 pi@iobroker4:~ $ iob update Cannot read system.config: undefined (OK when migrating or restoring) Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed. Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed. Error: Object "system.config" not found iob upgrade Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup! No connection to databases possible ... Cannot load "custom": Connection is closed. Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed. Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed. Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
Tja.... da bin ich am Ende....
Dein System leider auch...
OS veraltet und Node ebenso...
Bring das mal auf Stand, dann können wir weitermachen
Edit:
@Thomas-Braun hat Dir schon die Befehle gepostet. Ansonsten gibt das Forum und das Internet auch noch interessante Lösungsmöglichkeiten bezüglich Deiner Updates.
Edit 2:
Wenn ich das im Nachhinein so betrachte und Deine Logs so sehe, macht vielleicht doch ne Neuinstallation mit Backup mehr Sinn. -
buster
Komplett veraltet...
Installier das NEU!
Als Raspberry OS 12 'Bookworm' in der 64Bit Lite Version.
