    3. Einsteigerfragen
    4. Instanzen sind teilweise nicht zu finden
      maximinus last edited by
      Ich habe das merkwürdige Phänomen dass einige installierte Adapter neuerdings in den Instanzen nicht aufzufinden sind. z.B die mit den Pfeilen markierten
      Browser Cache gelöscht, ioBroker neu gestartet, RasPi neu gebootet.
      keine Änderung.
      iobroker fix
      keine Änderung
      Hier die iobroker diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: pivpn
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       20:48:50 up  1:58,  1 user,  load average: 1.38, 0.62, 0.56
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-03-24 20:48:51 WET
                 Universal time: Sun 2024-03-24 20:48:51 UTC
                       RTC time: n/a
                      Time zone: Atlantic/Canary (WET, +0000)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            1.8G        662M        825M        3.0M        361M        1.1G
      Swap:            99M         99M        0.0K
      Total:          1.9G        762M        825M
               1849 M total memory
                662 M used memory
                403 M active memory
                470 M inactive memory
                825 M free memory
                  5 M buffer memory
                355 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * hciuart.service  loaded failed failed Configure Bluetooth Modems connected by UART
      * iobroker.service loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  8.5G   20G  31% /
      devtmpfs       devtmpfs  667M     0  667M   0% /dev
      tmpfs          tmpfs     925M  1.8M  923M   1% /dev/shm
      tmpfs          tmpfs     370M  1.1M  369M   1% /run
      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
      [Sun Mar 24 18:50:14 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:20:8D:54 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bd727156-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=AT
      [Sun Mar 24 18:50:15 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Sun Mar 24 18:50:15 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Sun Mar 24 18:50:16 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Sun Mar 24 18:50:16 2024] EXT4-fs (mmcblk0p2): 3 orphan inodes deleted
      [Sun Mar 24 18:50:16 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Sun Mar 24 18:50:16 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Mar 24 18:50:16 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Mar 24 18:50:18 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.4G    /var/
      1.4G    /var/log
      1.2G    /var/log/journal/8f8800bc2dd742ba810579339a904aaf
      540M    /var/cache
      Archived and active journals take up 1.1G in the file system.
      /opt/iobroker/backups:
      2.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      134M    /opt/iobroker/iobroker-data/
      82M     /opt/iobroker/iobroker-data/files
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      6.0M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      No iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
        system.adapter.admin.0                  : admin                 : pivpn                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : pivpn                                    -  enabled
        system.adapter.alias-manager.0          : alias-manager         : pivpn                                    -  enabled
        system.adapter.backitup.0               : backitup              : pivpn                                    -  enabled
        system.adapter.devices.0                : devices               : pivpn                                    -  enabled
        system.adapter.discovery.0              : discovery             : pivpn                                    -  enabled
        system.adapter.flot.0                   : flot                  : pivpn                                    -  enabled
        system.adapter.fritzdect.0              : fritzdect             : pivpn                                    - disabled
        system.adapter.habpanel.0               : habpanel              : pivpn                                    -  enabled
        system.adapter.influxdb.0               : influxdb              : pivpn                                    -  enabled, port: 8086
        system.adapter.javascript.0             : javascript            : pivpn                                    -  enabled
        system.adapter.mqtt.0                   : mqtt                  : pivpn                                    - disabled, port: 1886, bind: 192.168.1.9
        system.adapter.node-red.0               : node-red              : pivpn                                    -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.parser.0                 : parser                : pivpn                                    - disabled
        system.adapter.rpi2.0                   : rpi2                  : pivpn                                    -  enabled
        system.adapter.shelly.0                 : shelly                : pivpn                                    - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.0                 : sonoff                : pivpn                                    -  enabled, port: 1500, bind: 0.0.0.0
        system.adapter.tapo.0                   : tapo                  : pivpn                                    - disabled
        system.adapter.telegram.0               : telegram              : pivpn                                    -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tuya.0                   : tuya                  : pivpn                                    -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : pivpn                                    -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : pivpn                                    -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: pivpn                                    -  enabled
        system.adapter.vis-2.0                  : vis-2                 : pivpn                                    -  enabled
        system.adapter.vis.0                    : vis                   : pivpn                                    -  enabled
        system.adapter.web.0                    : web                   : pivpn                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
      Adapter    "parser"       : 2.1.0    , installed 2.1.0
      Adapter    "shelly"       : 6.6.1    , installed 6.7.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "tapo"         : 0.0.8    , installed 0.0.8
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-2-widgets-energy": 0.3.9, installed 0.3.9
      Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-jaeger-design": 1.1.10, installed 1.1.10
      Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects:        2384
      States:         1740
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://packages.grafana.com/oss/deb stable InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 https://repos.influxdata.com/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        13214      835/pihole-FTL
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        15441      803/influxd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1799       547/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          15445      899/lighttpd
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        13220      835/pihole-FTL
      tcp        0      0 127.0.0.1:8953          0.0.0.0:*               LISTEN      0          15376      791/unbound
      tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN      0          12071      366/rsyslogd
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      112        1813       512/redis-server 12
      tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          15375      791/unbound
      tcp6       0      0 :::53                   :::*                    LISTEN      999        13216      835/pihole-FTL
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1801       547/sshd: /usr/sbin
      tcp6       0      0 :::80                   :::*                    LISTEN      0          15446      899/lighttpd
      tcp6       0      0 ::1:6379                :::*                    LISTEN      112        1814       512/redis-server 12
      tcp6       0      0 :::514                  :::*                    LISTEN      0          12072      366/rsyslogd
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        52927      6079/grafana
      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        13221      835/pihole-FTL
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        14976      803/influxd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14655      316/avahi-daemon: r
      udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          12066      366/rsyslogd
      udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          16387      -
      udp        0      0 0.0.0.0:34610           0.0.0.0:*                           108        14657      316/avahi-daemon: r
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        13213      835/pihole-FTL
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14778      796/dhcpcd
      udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          15374      791/unbound
      udp6       0      0 :::5353                 :::*                                108        14656      316/avahi-daemon: r
      udp6       0      0 :::514                  :::*                                0          12067      366/rsyslogd
      udp6       0      0 :::51820                :::*                                0          16388      -
      udp6       0      0 :::52110                :::*                                108        14658      316/avahi-daemon: r
      udp6       0      0 :::53                   :::*                                999        13215      835/pihole-FTL
      2024-03-24 20:48:19.983  - info: web.0 (8799) terminating
      2024-03-24 20:48:19.988  - info: backitup.0 (8770) terminating
      2024-03-24 20:48:19.995  - info: alexa2.0 (8662) terminating
      2024-03-24 20:48:20.015  - info: telegram.0 (8634) terminating
      2024-03-24 20:48:20.019  - info: telegram.0 (8634) Terminated (NO_ERROR): Without reason
      2024-03-24 20:48:20.020  - info: sonoff.0 (8755) terminating
      2024-03-24 20:48:20.031  - info: sonoff.0 (8755) Terminated (NO_ERROR): Without reason
      2024-03-24 20:48:20.057  - info: host.pivpn instance system.adapter.rpi2.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.099  - info: admin.0 (8563) terminating
      2024-03-24 20:48:20.106  - info: host.pivpn instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.151  - info: host.pivpn instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.153  - info: host.pivpn instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.173  - info: host.pivpn instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.226  - info: host.pivpn instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.227  - info: host.pivpn instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.227  - info: host.pivpn instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.228  - info: host.pivpn instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.280  - info: host.pivpn instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.586  - info: host.pivpn instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:20.620  - info: host.pivpn instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:22.473  - info: tuya.0 (8792) terminating
      2024-03-24 20:48:22.475  - info: tuya.0 (8792) Terminated (NO_ERROR): Without reason
      2024-03-24 20:48:23.014  - info: host.pivpn instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
      2024-03-24 20:48:23.014  - info: host.pivpn All instances are stopped.
      2024-03-24 20:48:23.168  - info: host.pivpn terminated
      Ich habe nachdem ich VIS-2 installiert hatte, in der Meinung es nicht mehr zu brauchen VIS deinstalliert. Da aber einige Widgets in VIS-2 noch nicht funktionieren habe ich VIS erneut installiert.
      Und dann gibt es noch diese Fehlermeldung.
      Wie bringe ich das wieder in Ordnung?
      LG Gerhard
      arteck Thomas Braun R 3 Replies Last reply Reply Quote 0
        arteck Developer Most Active @maximinus last edited by
        @maximinus irgendwelche Filter gesetzt
          Thomas Braun Most Active @maximinus last edited by Thomas Braun
          @maximinus sagte in Instanzen sind teilweise nicht zu finden:
          Da klemmt irgendwas.
          Starte den Service mal neu.
          sudo systemctl restart iobroker.service
          Dann nach dem Status schauen:
          systemctl status iobroker.service
            Radi @maximinus last edited by
            @maximinus Hallo Gerhard, ich bin zwar nicht der Fachmann für die Fehlersuche, speziell mit dem PI, aber meinst du nicht, dass du dem Kleinen mit so vielen Adaptern bei nur 2 GB RAM etwas viel zumutest?
              maximinus @Thomas Braun last edited by
              Danke hat geholfen. Jetzt ist wieder alles da.
              Ich wusste nicht dass der Server nicht auch mit dem restart des iobrokers neu gestartet wird.
              "sudo systemctl restart iobroker.service" kommt in meine Werkzeugkiste.
              @Radi
              Bis jetzt ist er noch nicht unangenehm aufgefallen aber es ist einer mit 4GB schon bestellt .
              LG Gerhard
                Sollte er eigentlich aber. Warum das bei dir nicht richtig funktioniert müsste man sich dann mal anschauen.
                  maximinus @Thomas Braun last edited by maximinus
                  Ich werde das beobachten. Der Raspi lief bis jetzt seit fast 6 Monaten ohne Probleme.
                  Eben sehe ich aber dass dieser Fehler immer noch besteht.
                  Was fehlt da?
                  Edit: Falsche Frage
                  Wie behebe ich das?
                  LG Gerhard
                    Homoran Global Moderator Administrators @maximinus last edited by Homoran
                    @maximinus logs und code immer als Text in code-tags! Nie als Screenshot
                    jetzt kann ich leider den Fehler für dich nicht in die Suche kopieren.
                    Bin mir sicher, dass dazu einiges kommt
                    EDIT:
                    sind anscheinend zwei verschiedene Meldungen.
                    Letztere deutet auf eine fehlende vis-Installation oder nagelneue die zum ersten mal bearbeitet wird
