    4. Raspberry / iobroker absturz: Loading chunk 401 failed
    • Meister Mopper
      Meister Mopper @NFTVirus last edited by
      @nftvirus
      Was sagt iob diag ?
        Homoran Global Moderator Administrators @NFTVirus last edited by
        @nftvirus sagte in Raspberry / iobroker absturz: Loading chunk 401 failed:
        Please open the browser console (F12), copy error text from there
        und was hast du da gesehen?
        • N
          NFTVirus @Meister Mopper last edited by
          @meister-mopper ```
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 3 Model B Plus Rev 1.3
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           08:07:06 up 15:27,  1 user,  load average: 0.81, 1.06, 6.40
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          ~ Throttling has occurred
          ~ Soft temperature limit has occurred
          *** Time and Time Zones ***
                         Local time: Mon 2024-03-25 08:07:06 GMT
                     Universal time: Mon 2024-03-25 08:07:06 UTC
                           RTC time: n/a
                          Time zone: Europe/London (GMT, +0000)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            909M        653M        145M        0.0K        110M        197M
          Swap:            99M         99M        0.0K
          Total:          1.0G        753M        145M
                    909 M total memory
                    653 M used memory
                    253 M active memory
                    426 M inactive memory
                    144 M free memory
                      3 M buffer memory
                    107 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  3.1G   25G  12% /
          devtmpfs       devtmpfs  325M     0  325M   0% /dev
          tmpfs          tmpfs     455M     0  455M   0% /dev/shm
          tmpfs          tmpfs     182M 1000K  181M   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
          [Sun Mar 24 16:39:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=473cba6a-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Mar 24 16:39:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Sun Mar 24 16:39:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Sun Mar 24 16:39:36 2024] EXT4-fs (mmcblk0p2): recovery complete
          [Sun Mar 24 16:39:36 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Mar 24 16:39:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Sun Mar 24 16:39:39 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          517M    /var/
          179M    /var/cache
          175M    /var/cache/apt
          148M    /var/lib
          123M    /var/lib/apt/lists
          Archived and active journals take up 88.0M in the file system.
          /opt/iobroker/backups:
          1.6M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          163M    /opt/iobroker/iobroker-data/
          123M    /opt/iobroker/iobroker-data/files
          57M     /opt/iobroker/iobroker-data/files/javascript.admin
          45M     /opt/iobroker/iobroker-data/files/devices.admin/static
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          14M     /opt/iobroker/iobroker-data/objects.jsonl
          8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466692-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.1-1nodesource1
            Version table:
               18.19.1-1nodesource1 1001
           *** 18.19.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.13.16
          javascript:     7.8.0
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Objects and States
          Objects:        570
          States:         397
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 37
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       29659      4860/io.mqtt.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       34853      4843/node-red
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32848      4765/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29570      4765/iobroker.js-co
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12843      491/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32451      4783/io.admin.0
          tcp6       0      0 :::80                   :::*                    LISTEN      1001       34854      4843/node-red
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12845      491/sshd: /usr/sbin
          udp        0      0 0.0.0.0:41473           0.0.0.0:*                           108        12773      339/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12005      620/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33825      4890/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12771      339/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       33010      4843/node-red
          udp6       0      0 :::546                  :::*                                0          14918      620/dhcpcd
          udp6       0      0 :::53449                :::*                                108        12774      339/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        12772      339/avahi-daemon: r
          2024-03-25 07:45:56.639  - info: node-red.0 (4790) Node-RED: 25 Mar 07:45:56 - [info] Dashboard version 3.6.5 started at /ui
          2024-03-25 07:46:02.767  - info: node-red.0 (4790) Node-RED: 25 Mar 07:46:02 - [info] Settings file  : /opt/iobroker/iobroker-data/node-red/settings.js
          2024-03-25 07:46:02.775  - info: node-red.0 (4790) Node-RED: 25 Mar 07:46:02 - [info] Context store  : 'default' [module=memory]
          2024-03-25 07:46:02.782  - info: node-red.0 (4790) Node-RED: 25 Mar 07:46:02 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
          2024-03-25 07:46:02.786  - warn: node-red.0 (4790) Node-RED: 25 Mar 07:46:02 - [warn] Projects disabled : editorTheme.projects.enabled=false
          2024-03-25 07:46:02.796  - info: node-red.0 (4790) Node-RED: 25 Mar 07:46:02 - [info] Flows file     : /opt/iobroker/iobroker-data/node-red/flows.json
          2024-03-25 07:46:02.883  - warn: node-red.0 (4790) Node-RED: 25 Mar 07:46:02 - [warn] Encrypted credentials not found
          2024-03-25 07:46:02.964  - info: node-red.0 (4790) Node-RED: 25 Mar 07:46:02 - [info] Server now running at http://127.0.0.1:1880/
          2024-03-25 07:46:03.021  - info: node-red.0 (4790) Node-RED: 25 Mar 07:46:03 - [info] Starting flows
          2024-03-25 07:46:03.341  - info: wled.0 (4890) WLED initialisation finalized, ready to do my job have fun !
          2024-03-25 07:46:04.281  - info: node-red.0 (4790) Node-RED: 25 Mar 07:46:04 - [info] Started flows
          2024-03-25 07:46:06.282  - info: zigbee.0 (4854) Try to reconnect. 1 attempts left
          2024-03-25 07:46:06.285  - info: zigbee.0 (4854) Starting Zigbee  npm ...
          2024-03-25 07:46:06.327  - info: zigbee.0 (4854) Installed Version: iobroker.zigbee@1.10.1
          2024-03-25 07:46:06.728  - error: zigbee.0 (4854) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
          2024-03-25 07:46:06.730  - error: zigbee.0 (4854) Failed to start Zigbee
          2024-03-25 07:46:06.732  - error: zigbee.0 (4854) Error herdsman start
          2024-03-25 07:47:29.452  - info: mqtt.0 (4860) Client [Schildkroeten] connected with secret 1711352849445_4891
          2024-03-25 07:47:29.516  - info: mqtt.0 (4860) Client [Schildkroeten] subscribes on "cmnd/Schildkroeten/#" with regex /^cmnd\.Schildkroeten\..*/
          2024-03-25 07:47:29.518  - info: mqtt.0 (4860) Client [Schildkroeten] subscribes on "cmnd/Schildkroeten/#"  with regex /^mqtt\.0\.cmnd\.Schildkroeten\..*/
          2024-03-25 07:47:29.521  - info: mqtt.0 (4860) Client [Schildkroeten] subscribes on "cmnd/tasmotas/#" with regex /^cmnd\.tasmotas\..*/
          2024-03-25 07:47:29.523  - info: mqtt.0 (4860) Client [Schildkroeten] subscribes on "cmnd/tasmotas/#"  with regex /^mqtt\.0\.cmnd\.tasmotas\..*/
          2024-03-25 07:47:29.527  - info: mqtt.0 (4860) Client [Schildkroeten] subscribes on "cmnd/Schildkroeten_fb/#" with regex /^cmnd\.Schildkroeten_fb\..*/
          2024-03-25 07:47:29.529  - info: mqtt.0 (4860) Client [Schildkroeten] subscribes on "cmnd/Schildkroeten_fb/#"  with regex /^mqtt\.0\.cmnd\.Schildkroeten_fb\..*/
          2024-03-25 07:47:29.533  - info: mqtt.0 (4860) Client [Schildkroeten] unsubscribes on unknown topic "homeassistant/status"
            Thomas Braun Most Active @NFTVirus last edited by
            Nun habe ich in den letzten Tagen alles auf einer neuen SD Karte neu aufgesetzt
            Und warum nimmt man dann nicht auch das aktuelle Betriebssystem als Basis?
            N 2 Replies Last reply Reply Quote 0
            • N
              NFTVirus @Thomas Braun last edited by
              @thomas-braun dachte eigentlich dass es aktuell war. Habe mich aber gerade bei der Analyse auch gewundert
                @nftvirus
                Davon abgesehen ist vermutlich die Zeitzone falsch und nodejs/npm ist auch falsch.
                • Meister Mopper
                  Da ist wohl ein neues Netzteil fällig.
                  Spiel da auf eine neue SD-Karte ein 64bit bookworm Image drauf.
                  • N
                    @meister-mopper danke werde ich machen
                    • N
                      @thomas-braun werde nochmal neu aufsetzen und ein neues Netzteil nehmen. Danke!
                        @nftvirus
                        Und halte das Zeug auf Stand...
                        Pending Updates: 37
                        sind 37 Updates zu viel.
                        • N
                          @thomas-braun wie gesagt ist eigentlich vor ein paar tagen vielleicht zwei drei Wochen frisch installiert keine Ahnung was ich da vergeigt habe. Aber auf jeden Fall danke für die Hilfe!
                          • N
                            NFTVirus @Thomas Braun last edited by NFTVirus
                            @thomas-braun sehe gerade dass mir der RPI imager für den 3b+ nur Bullseye anbietet. Mache ich da was falsch? Oder läuft Bookworm auf dem 3B+ nicht?
                            [edit] hat sich erledigt nehme ein Image von der RPI Seite ist laut der Seite für 3B+ zugelassen. Keine Ahnung warum es nicht direkt über den Imager angeboten wird.
                            274
