    4. (gelöst) linux-control lxc host klappt nicht
      crunchip Forum Testing Most Active @HAL last edited by
      @hal ist dies korrekt?
      if its not possible to get connection to your linux client, check if iputils-ping is correct installed on client
      HAL 1 Reply Last reply Reply Quote 0
      • HAL
        HAL @crunchip last edited by
        @crunchip
        root@iobroker:~# ping 192.168.178.44
        PING 192.168.178.44 (192.168.178.44) 56(84) bytes of data.
        64 bytes from 192.168.178.44: icmp_seq=1 ttl=64 time=0.044 ms
        64 bytes from 192.168.178.44: icmp_seq=2 ttl=64 time=0.036 ms
        64 bytes from 192.168.178.44: icmp_seq=3 ttl=64 time=0.058 ms
        64 bytes from 192.168.178.44: icmp_seq=4 ttl=64 time=0.048 ms
        ^C
        --- 192.168.178.44 ping statistics ---
        4 packets transmitted, 4 received, 0% packet loss, time 3074ms
        rtt min/avg/max/mdev = 0.036/0.046/0.058/0.007 ms
        • Codierknecht
          Codierknecht Developer Most Active @HAL last edited by
          @hal
          Da wurschtelt man immer noch nicht als rootrum.
          HAL 1 Reply Last reply Reply Quote 1
          • HAL
            HAL @Codierknecht last edited by
            @codierknecht was hat das mit dem Adapter zu tun ?
            • Codierknecht
              @hal
              Die Ausgabe zeigt lediglich, dass ein ping als root funktioniert.
              Der Adapter läuft aber nicht als root.
              • HAL
                HAL @Codierknecht last edited by HAL
                @codierknecht
                uwe@iobroker:~$ sudo ping 192.168.178.44
                [sudo] password for uwe:
                64 bytes from 192.168.178.44: icmp_seq=1 ttl=64 time=0.047 ms
                64 bytes from 192.168.178.44: icmp_seq=2 ttl=64 time=0.037 ms
                64 bytes from 192.168.178.44: icmp_seq=3 ttl=64 time=0.044 ms
                64 bytes from 192.168.178.44: icmp_seq=4 ttl=64 time=0.043 ms
                ^C
                4 packets transmitted, 4 received, 0% packet loss, time 3068ms
                rtt min/avg/max/mdev = 0.037/0.042/0.047/0.003 ms
                linux-control.0
                2024-03-26 23:00:44.869	info	[getConnection] Host 'pve' (192.168.178.44:22) seems not to be online
                linux-control.0
                2024-03-26 23:00:44.851	info	getting data from pve (192.168.178.44:22, Adapter start)
                linux-control.0
                2024-03-26 23:00:44.799	info	starting. Version 1.1.6 (non-npm: Scrounger/ioBroker.linux-control) in /opt/iobroker/node_modules/iobroker.linux-control, node: v18.18.2, js-controller: 5.0.19
                Codierknecht crunchip Thomas Braun 3 Replies Last reply Reply Quote 0
                • Codierknecht
                  @hal
                  Also ich kann meinen LXC Container problemlos erreichen.
                  Ein grundsätzliches Problem beim Adapter würde ich demnach ausschließen.
                  Hätte vermutlich auch längst Geschrei gegeben.
                    crunchip Forum Testing Most Active @Codierknecht last edited by
                    @codierknecht habs bei mir ebenfalls gerade getestet, vom iobroker docker (anderer Server) zum Proxmox-Host, funktioniert ohne Probleme
                      crunchip Forum Testing Most Active @HAL last edited by crunchip
                      @hal sagte in linux-control lxc host klappt nicht:
                      node: v18.18.2
                      ist aber auch nicht der aktuelle Stand
                      auch schon mal Proxmox neu gestartet?
                      es gab Hier ein issue, hat sich aber scheinbar in Luft aufgelöst
                        Thomas Braun Most Active @HAL last edited by
                        @hal
                        apt policy iputils-ping ping
                        ping 192.168.178.44
                        sudo -H -u iobroker ping 192.168.178.44
                        sagt? Natürlich NICHT als root sondern als user ausgeführt.
                        Eigentlich logisch, da man sich ohnehin nie als root anmeldet.
                        HAL 2 Replies Last reply Reply Quote 0
                        • HAL
                          HAL @Thomas Braun last edited by
                          @thomas-braun ich bin am iobroker mit dem user Uwe angemeldet
                            Thomas Braun Most Active @HAL last edited by Thomas Braun
                            @hal
                            Mag ja sein. Mittels sudo setzt du da aber weiterhin auf root-Rechte. Bringt dir aber keine Erkenntnisse, weil Ping z.B. unter Umständen von Usern nicht ausgeführt werden darf. Deswegen halt als User agieren, weil man immer als user eingeloggt ist und nie als root.
                            Die Kommandos liefern nun was zurück?
                            • HAL
                              @crunchip mach ich heute abend, bin jetzt unterwegs
                              • HAL
                                @thomas-braun sorry war durch Ostern beschäftigt
                                iobroker login: uwe
                                Password:
                                Linux iobroker 6.5.13-1-pve #1 SMP PREEMPT_DYNAMIC PMX 6.5.13-1 (2024-02-05T13:50Z) x86_64
                                The programs included with the Debian GNU/Linux system are free software;
                                the exact distribution terms for each program are described in the
                                individual files in /usr/share/doc/*/copyright.
                                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                permitted by applicable law.
                                Last login: Mon Apr  1 14:43:10 CEST 2024 on tty1
                                uwe@iobroker:~$ apt policy iputils-ping ping
                                iputils-ping:
                                  Installed: 3:20210202-1
                                  Candidate: 3:20210202-1
                                  Version table:
                                 *** 3:20210202-1 500
                                        500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                ping:
                                  Installed: (none)
                                  Candidate: (none)
                                  Version table:
                                uwe@iobroker:~$ ping 192.168.178.44
                                ping: socket: Operation not permitted
                                uwe@iobroker:~$ sudo -H -u iobroker ping 192.168.178.44
                                uwe@iobroker:~$
                                  @hal
                                  Gib den usern die Rechte:
                                  sudo setcap cap_net_raw+p /bin/ping
                                  • HAL
                                    @thomas-braun OK, jetzt funktioniert auch die Abfrage der CPU Temperatur im Container. Danke für Deinen Support !
                                    1221
