    4. Zigbee iobroker Error while opening serialport
      flodirmann last edited by Samson71
      Hallo miteinander,
      ich habe ein scheinbar sehr ähnliches Problem mit meinem "Sonoff Zigbee 3.0 USB Dongle Plus" an einem Raspi 4B, jedoch haben mir die bisherigen Lösungsansätze nicht zu einer Lösung verholfen.
      Der genaue Pfad meines Dongles ist (mit PuTTY ausgelesen):
      /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00
      mit diesem Pfad in den Einstellungen funktioniert es aber nicht, der Adapter steht auf orange.
      Folgende Fehler sind im Log:
      2024-03-27 19:55:20.975 - error: zigbee.0 (1865) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-03-27 19:55:21.147 - info: zigbee.0 (1865) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA0"}]
      2024-03-27 19:55:30.426 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2024-03-27 19:55:30.434 - info: zigbee.0 (1865) Got terminate signal TERMINATE_YOURSELF
      2024-03-27 19:55:30.435 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
      2024-03-27 19:55:30.438 - info: zigbee.0 (1865) cleaned everything up...
      2024-03-27 19:55:30.446 - info: zigbee.0 (1865) Zigbee: disabling joining new devices.
      2024-03-27 19:55:30.500 - warn: zigbee.0 (1865) Failed to stop zigbee during startup
      2024-03-27 19:55:30.501 - info: zigbee.0 (1865) terminating
      2024-03-27 19:55:30.503 - info: zigbee.0 (1865) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-03-27 19:55:30.612 - info: admin.0 (1215) <== Disconnect system.user.admin from ::ffff:192.168.188.195
      2024-03-27 19:55:31.049 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-03-27 19:55:32.851 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1884
      2024-03-27 19:55:36.840 - info: zigbee.0 (1884) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.8.0, js-controller: 4.0.19
      2024-03-27 19:55:36.960 - info: zigbee.0 (1884) delete old Backup files. keep only last 10
      2024-03-27 19:55:36.962 - info: zigbee.0 (1884) Starting Zigbee npm ...
      2024-03-27 19:55:37.247 - error: zigbee.0 (1884) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
      2024-03-27 19:55:37.248 - error: zigbee.0 (1884) Failed to start Zigbee
      2024-03-27 19:55:37.248 - error: zigbee.0 (1884) Error herdsman start
      2024-03-27 19:55:37.631 - info: zigbee.0 (1884) Installed Version: iobroker.zigbee@1.10.1
      2024-03-27 19:55:47.252 - info: zigbee.0 (1884) Try to reconnect. 1 attempts left
      2024-03-27 19:55:47.254 - info: zigbee.0 (1884) Starting Zigbee npm ...
      2024-03-27 19:55:47.272 - error: zigbee.0 (1884) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
      2024-03-27 19:55:47.276 - error: zigbee.0 (1884) Failed to start Zigbee
      2024-03-27 19:55:47.278 - error: zigbee.0 (1884) Error herdsman start
      2024-03-27 19:55:47.310 - info: zigbee.0 (1884) Installed Version: iobroker.zigbee@1.10.1
      Hier noch meine Einstellungen:
      Könnt Ihr mir dabei weiterhelfen?
      Beste Grüße und Danke im Voraus,
      flo
      MOD-Edit: Logs in Code-Tags setzen
        Thomas Braun Most Active @flodirmann last edited by Thomas Braun
        @flodirmann sagte in Zigbee iobroker Error while opening serialport:
        Beides steinalt, beides aktualisieren.
        Und den Rest vom Fest auch auf Stand brigen.
        ...plagt euch doch nicht immer mit uralten Versionen herum...
        Auch 'running systems' müssen regelmäßig gewartet werden, damit sie eben weiter 'runnen'.
          Das funktioniert deswegen nicht, weil die Meldung
          volkommen korrekt ist. Die Datei heißt nämlich:
          "Ich kann aus dämlichen Screenshots nichts kopieren, deswegen darfst du den Fehler nun selber suchen"
            Danke für die schnelle Antwort.
            Auch nach den notwendigen Updates bleibt der Fehler bestehen (ich denke mal, innerhalb der Major-Version 18 zu bleiben zählt noch als aktuell?)
            2024-03-27 21:15:58.928 - info: zigbee.0 (3067) terminating
            2024-03-27 21:15:58.929 - info: zigbee.0 (3067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-03-27 21:15:59.279 - info: zigbee.0 (3067) terminating
            2024-03-27 21:15:59.495 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-03-27 21:16:01.859 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 3142
            2024-03-27 21:16:06.599 - info: zigbee.0 (3142) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
            2024-03-27 21:16:06.701 - info: zigbee.0 (3142) delete old Backup files. keep only last 10
            2024-03-27 21:16:06.703 - info: zigbee.0 (3142) Starting Zigbee npm ...
            2024-03-27 21:16:07.105 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
            2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Failed to start Zigbee
            2024-03-27 21:16:07.107 - error: zigbee.0 (3142) Error herdsman start
            2024-03-27 21:16:07.113 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
            2024-03-27 21:16:17.113 - info: zigbee.0 (3142) Try to reconnect. 1 attempts left
            2024-03-27 21:16:17.114 - info: zigbee.0 (3142) Starting Zigbee npm ...
            2024-03-27 21:16:17.127 - error: zigbee.0 (3142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231314212123-if00'"
            2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Failed to start Zigbee
            2024-03-27 21:16:17.128 - error: zigbee.0 (3142) Error herdsman start
            2024-03-27 21:16:17.135 - info: zigbee.0 (3142) Installed Version: iobroker.zigbee@1.10.1
            @thomas-braun said in Zigbee iobroker Error while opening serialport:
            Warum eigentlich immer alles so passiv aggressiv?
            Ich habe doch oben den pfad, wie ihn PuTTY mir ausspuckt, in textform geschrieben:
            @flodirmann said in Zigbee iobroker Error while opening serialport:
            Oder was bräuchtest du genauer, um mir weiterhelfen zu können?
            Thomas Braun arteck 2 Replies Last reply Reply Quote 0
              Der steht aber nicht so in den Einstellungen des Adapters drin. Finde den Tippfehler.
              Sowas kopiert man auch aus dem Terminal und pinnt das nicht manuell ab.
                arteck Developer Most Active @flodirmann last edited by
                @flodirmann wenn du schon abschreibst dann machs richtig und kontrolliere es 5 mal
                  flodirmann @arteck last edited by
                  @arteck
                  Danke für den Hinweis auf meinen, zugegebenermaßen tatsächlich echt vermeidbaren, Fehler. 😖
                  Leider kann ich noch nicht vermelden, ob jetzt alles klappt, weil ich augenscheinlich nebenbei bei den Updates des raspis in den wohl im Forum schon bekannteren udev-Bug hineingelaufen bin, es gibt jetzt kein /by-id/ mehr...
                  Jetzt muss dabei erst mal eine Lösung her.
                    Aktuelles System verwenden, das hat den Fehler nicht.
                      flodirmann @Thomas Braun last edited by flodirmann
                      So. Auch nach komplettem Neuaufsetzen des Systems mit Debian 12 Bookworm und dem Korrigieren eigenverschuldeter Rechtschreibfehler (diesmal aus PuTTY direkt rauskopiert) funktioniert es noch nicht besser.
                      Egal ob ich in den Einstellungen den by-id path verwende "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00" oder die alternative Adresse "/dev/ttyACM0", in beiden Fällen tritt der identische Fehler auf:
                      2024-03-28 15:51:59.165 - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.188.23
                      2024-03-28 15:51:59.266 - error: zigbee.0 (2510) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                      2024-03-28 15:51:59.379 - info: zigbee.0 (2510) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214212123","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214212123-if00","vendorId":"1a86","productId":"55d4"}]
                      2024-03-28 15:52:38.919 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2024-03-28 15:52:38.926 - info: zigbee.0 (2510) Got terminate signal TERMINATE_YOURSELF
                      2024-03-28 15:52:38.930 - info: zigbee.0 (2510) cleaned everything up...
                      2024-03-28 15:52:38.934 - info: zigbee.0 (2510) Zigbee: disabling joining new devices.
                      2024-03-28 15:52:38.958 - warn: zigbee.0 (2510) Failed to stop zigbee during startup
                      2024-03-28 15:52:38.960 - info: zigbee.0 (2510) terminating
                      2024-03-28 15:52:38.963 - info: zigbee.0 (2510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-03-28 15:52:38.967 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                      2024-03-28 15:52:39.042 - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.188.23
                      2024-03-28 15:52:39.431 - info: zigbee.0 (2510) terminating
                      2024-03-28 15:52:39.519 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-03-28 15:52:42.016 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2586
                      2024-03-28 15:52:45.840 - info: zigbee.0 (2586) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.12.0, js-controller: 5.0.19
                      2024-03-28 15:52:45.922 - info: zigbee.0 (2586) delete old Backup files. keep only last 10
                      2024-03-28 15:52:45.925 - info: zigbee.0 (2586) Starting Zigbee npm ...
                      2024-03-28 15:52:46.171 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
                      2024-03-28 15:53:06.711 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                      2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Failed to start Zigbee
                      2024-03-28 15:53:06.712 - error: zigbee.0 (2586) Error herdsman start
                      2024-03-28 15:53:16.717 - info: zigbee.0 (2586) Try to reconnect. 1 attempts left
                      2024-03-28 15:53:16.721 - info: zigbee.0 (2586) Starting Zigbee npm ...
                      2024-03-28 15:53:16.751 - info: zigbee.0 (2586) Installed Version: iobroker.zigbee@1.10.1
                      2024-03-28 15:53:16.959 - error: zigbee.0 (2586) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      2024-03-28 15:53:16.960 - error: zigbee.0 (2586) Failed to start Zigbee
                      2024-03-28 15:53:16.961 - error: zigbee.0 (2586) Error herdsman start
                      Hier noch ein Screenshot der Adaptereinstellungen:
                      Könnt ihr mir da irgendwie weiterhelfen? Falls weitere Informationen benötigt werden, gerne Bescheid geben.
                      DJMarc75 Asgothian 2 Replies Last reply Reply Quote 0
                      • DJMarc75
                        DJMarc75 @flodirmann last edited by
                        node: v20.12.0
                        hmpf... da bist Du schon zu aktuell und hast Dein System wohl nicht korrekt aufgesetzt
                          flodirmann @DJMarc75 last edited by
                          @djmarc75
                          Mensch, na super. Da dachte ich, da 20 ja die aktuellste geradzahlige Major ist...
                          Also wieder zurück auf 18.x?
                          DJMarc75 Meister Mopper Thomas Braun 3 Replies Last reply Reply Quote 0
                          • DJMarc75
                            jawoll 🙂
                            • Meister Mopper
                              Meister Mopper @flodirmann last edited by
                              Mit dem "Einzeiler" aus der Doku wäre das auf einem neuen System nicht passiert.
                                iob nodejs-update 18
                                • Asgothian
                                  Asgothian Developer @flodirmann last edited by Asgothian
                                  Stell mal bitte die Firmware im zigbee-Adapter auf EZSP (oder ähnlich) um - der sonoff dongle V2 nutzt meines Wissens nach nicht den TI Chip Satz
                                  A.
                                    flodirmann @Asgothian last edited by
                                    @asgothian
                                    Danke danke danke!
                                    Das hat tatsächlich endlich geholfen. 👍
                                      stauber last edited by
                                      seit gestern läuft der Zigbee Adapter nicht mehr ich musste gestern Router und Rasp abstecken und seitdem wird er nur noch Orange.
                                      Bei mir stand die ganze Zeit das Node js v22.x empfohlen wird seit dem letzten Update wird nun die 18.x empfohlen im Forum wiederum die 20.x welche soll ich jetzt Installieren?
                                      Mit den Befehl iob Node js-update 18 bleibt er bei 22.x hab ich schon Probiert gibt es noch eine andere Möglichkeit?
                                      Hardware
                                      Raspberry4 und das CC26x02R1
                                      Ansonsten könntet ihr mir irgendwie weiterhelfen?
                                        Thomas Braun Most Active @stauber last edited by
                                        @stauber
                                        iob nodejs-update 20
                                        Und dann mal die Ausgabe von
                                        iob diag
                                        Da kannst du den Link 'by-id' herausnehmen und in den Einstellungen des Adapters statt /dev/ttyACM0 eintragen.
                                          stauber @Thomas Braun last edited by
                                          Hallo Thomas
                                          bleib weiterhin auf 22.4
                                          nochmal zur Verständnis ich Kopiere den Text danach y
                                          oder mach ich was Falsch?
                                            @stauber sagte in Zigbee iobroker Error while opening serialport:
                                            Ich weiß nicht was du machst...
                                            Du sollst
                                            in dein Terminal hacken.
                                            231
                                            42372
