    4. Test Alpha Homekit-Controller 0.0.x
      apollon77 @disaster123 last edited by
      @disaster123 Bitte Github issue mit vollem Debug log. Ja es gibt leider Geräte die nicht Homekit konform arbeiten 😞
      • Jey Cee
        Jey Cee Developer last edited by Jey Cee
        Jetzt bekomme ich Warnungen im Log:
        homekit-controller.0
        	2023-06-15 18:05:17.259	warn	IP-BD:C7:51:E0:4A:0A Could not initialize device: connect ECONNREFUSED 192.168.0.148:49171 Error: connect ECONNREFUSED 192.168.0.148:49171 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
        	2023-06-15 18:05:17.249	warn	Device IP-BD:C7:51:E0:4A:0A had too many errors, reinitialize connection
        	2023-06-15 18:05:17.248	info	Device IP-BD:C7:51:E0:4A:0A data polling failed (376): connect ECONNREFUSED 192.168.0.148:49171
        	2023-06-15 18:04:47.164	warn	IP-BD:C7:51:E0:4A:0A Could not initialize device: connect ECONNREFUSED 192.168.0.148:49171 Error: connect ECONNREFUSED 192.168.0.148:49171 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
        	2023-06-15 18:04:47.160	warn	Device IP-BD:C7:51:E0:4A:0A had too many errors, reinitialize connection
        	2023-06-15 18:04:47.160	info	Device IP-BD:C7:51:E0:4A:0A data polling failed (375): connect ECONNREFUSED 192.168.0.148:49171
        	2023-06-15 18:04:17.090	warn	IP-BD:C7:51:E0:4A:0A Could not initialize device: connect ECONNREFUSED 192.168.0.148:49171 Error: connect ECONNREFUSED 192.168.0.148:49171 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
        	2023-06-15 18:04:17.076	warn	Device IP-BD:C7:51:E0:4A:0A had too many errors, reinitialize connection
        	2023-06-15 18:04:17.075	info	Device IP-BD:C7:51:E0:4A:0A data polling failed (374): connect ECONNREFUSED 192.168.0.148:49171
        Versucht der Adapter selber die Verbindung neu zu Initialisieren?
        Von Hand ist es in diesem Zustand nicht möglich die Verbindung zu trennen, um den FP2 neu zu verbinden.
          disaster123 @apollon77 last edited by
          @apollon77 sagte in Test Alpha Homekit-Controller 0.0.x:
          Danke - erledigt: https://github.com/Apollon77/ioBroker.homekit-controller/issues/285
          disaster123 created this issue in Apollon77/ioBroker.homekit-controller
          closed IT4WIFI position-hold option not working #285
            apollon77 @Jey Cee last edited by
            @jey-cee istjetzt die Frage was die Ursache ist. Wenn Du aktuellste Beta vom Adapter nutzt sollte es nicht der Adapter sein - ggf ein Debug Log hilft nachzuschauen. In älteren Verisonen gabs da mal nen Bug. Oder Deice ist matschig
            • werner2000x
              werner2000x @Jey Cee last edited by werner2000x
              @jey-cee Ich habe auch den FP2 und der Adapter ist gelb und findet keine Geräte. Das ein-, ausschalten hilft nicht. Gibt es noch einen Tip?
              Hier der Debug-Log: homekit-controller.0
              2023-07-20 12:19:14.840 info starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v16.20.1, js-controller: 4.0.24
              • Jey Cee
                Jey Cee Developer @werner2000x last edited by
                @werner2000x ich hab leider keinen anderen Tipp für dich.
                Kann aber jetzt sagen das mein FP2 probleme mit der WLAN Verbindung hat und immer wieder aus dem Netz fliegt oder sich "schlafen" legt.
                werner2000x 1 Reply Last reply Reply Quote 0
                • werner2000x
                  @jey-cee Ich habe den FP2 zurückgeschickt.
                  Einfach noch nicht Marktreif.
                    Fatmax last edited by
                    ich versuche verzweifelt meine Velux Dachfenster in den Iobroker zu kommen.
                    Da ich das Gateway KIG300 von Velux verwende welches lt. Verpackung "works with Apple HomeKit" kann, habe ich nun den Adapter probiert.
                    Das Teil wird auch gefunden, pairing ist aber nicht möglich.
                    Im Log erscheint unter anderem folgendes:
                    homekit-controller.0 (3289156) IP-xx:xx:xx:xx:xx:xx(VELUX Gateway) found without known pairing data and already paired: ignoring
                    Hat das mit Velux und dem Homekit-Adapter schon jemand hinbekommen?
                    Es gibt einen eigenen Velux-Thread dazu, dort schreibt ein User er hat es erfolgreich zusammengebracht.
                    Alle wollen wissen wie es geht, aber der User ist leider nicht mehr aktiv im Forum unterwegs. 😞
                    @apollon77 Mit was sind die Geräte gepaired wenn die Meldung erscheint? Mit der Home-App von Apple?
                    Ich habe nämlich kein IOS-Gerät, daher Frage ich mich mit was das gepaired ist.
                    Ich habe das Gateway lediglich direkt in der Velux Android App eingerichtet.
                    Ich kann es dort löschen, dann sind aber die ganzen Verknüpfungen für die angelegten Fenster und Rollläden-Fernbedienungen scheinbar nicht mehr vorhanden.
                      apollon77 @Fatmax last edited by
                      @fatmax Also die Meldung hier sagt das das Gerät bereits gepaired ist und HomeKit kann nur ein Pairing haben, also kann der Adapter damit nichts anfangen.
                      Ob eine Verbindung mit der Velux Android App quasi HomeKit abschaltet wird die ggf nur Velux beantworten können.
                      Für mich (und den Adapter) sagt die Meldung das das gerät bereits Verbunden ist und damit geht nichts zweites. Sorry
                        @apollon77 Danke für die Info.
                        Ich habe das Pairing des Velux Gateways KIG300 mittlerweile geschafft, nachdem ich es in der Velux Android App gelöscht hatte.
                        Das Gateway wurde als Bridge erkannt.
                        Nun habe ich aber das Problem, dass angelernte Fenster und Rollläden nicht unter den Objekten im Iobroker angezeigt werden.
                        Habe diese lt. offizieller Anleitung von Velux an das Gateway angelernt, diese müssten dann normalerweise in Homekit auftauchen, unter den Objekten erscheint aber nichts.
                        Muss ich das vom Adapter aus starten?
                        Ich habe das Pairing über den Knopf am Gateway gemacht, das Blinklicht darauf hat sich so verhalten wie in der Anleitung.
                        Geht das dann überhaupt Geräte an eine gepaarte Bridge anzulernen bzw. kann ich wo im Iobroker sehen was das Gateway macht?
                          @fatmax Gute Fragen, keine Ahnung ... Sowas sind Funktionen die über das reine HomeKit Protokoll hinaus gehen, von daher denke ich das Velux das mit Ihrer App tut ... wie das mit nem anderen Controller aussieht keine Ahnung ... Sorry ... Ich denke die haben das soweit nicht gedacht 😞
                            Fatmax @apollon77 last edited by Fatmax
                            Ich habe es mittlerweile dank Hilfe von @cobra09 hinbekommen die Velux-Produkte mit dem KIG300 Gateway anzusteuern, falls es jemanden interessiert.
                            Man muss die Fernbedienungen der Velux-Fenster bzw. Rollläden zurücksetzen, damit diese nicht mehr mit den Produkten verbunden sind.
                            Danach habe ich die Fernbedienungen wieder neu an die Produkte angelernt.
                            Anschließend wurde jede Fernbedienung nacheinander auf das Gateway kopiert. (das kann unter Umständen mehrere Minuten pro FB dauern, Geduld haben).
                            Der Kopiervorgang wurde wie folgt gestartet:
                            Auf Fernbedienung, entgegen der Anleitung im Netz, nur kurz den Zahnradbutton drücken -> danach beginnt das Fenster bzw. der Rollladen mit Hin-&Her-Bewegungen.
                            Auf dem Gateway den Zahnradbutton solange drücken bis die LED blau blinkt.
                            -> Danach die Fernbedienung auf das Gateway legen und warten bis die blau blinkende LED erlischt.
                            Nach ein paar Sekunden (je nach Intervall welches im Adapter eingestellt ist) erscheint dann das Produkt unter den Objekten im Iobroker.
                            Falls es gar nicht erscheint, habe ich zur Lösung das Gateway vom Strom genommen bzw. auch mal den Adapter neu gestartet, dann hatte es eigentlich funktioniert.
                            Mit dem Objekten Position-target kann durch Änderung des Wertes das Fenster bzw. der Rollladen von Velux gesteuert werden.
                            @apollon77 Danke für den Adapter. Das hat für mich und ich denke auch für viele andere das Thema mit den Velux-Produkten gelöst.
                            • mickemup
                              mickemup last edited by
                              Hallo Zusammen
                              Dank dem Adapter habe ich es geschafft den IKEA Dirigera Hub einzubinden.
                              Die Parasoll Fenstersensoren funktionieren 1A und darum habe ich mir nun auch die INSPELNING Steckdose geholt um preiswert den Strom messen zu können.
                              Via Adapter taucht die Steckdose auch auf und ist schaltbar. Die aktuelle Leistung sehe ich aber nirgends.
                              Liegt das am Adapter oder an IKEA, welche die Daten nicht an Homekit weitergibt?
                              Grüsse
                                Robbi12 @mickemup last edited by Robbi12
                                Hallo. Nach update auf 0.5.11 wird der Adapter nicht mehr grün. Bekomme auch im host dann eine Fehlermeldung
                                host.IoBroker
                                2024-11-27 23:01:12.526	error	instance system.adapter.homekit-controller.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                host.IoBroker
                                2024-11-27 23:01:12.526	error	Caught by controller[1]: at HomekitController.onReady (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:199:31)
                                host.IoBroker
                                2024-11-27 23:01:12.526	error	Caught by controller[1]: at BLEDiscovery.start (/opt/iobroker/node_modules/hap-controller/src/transport/ble/ble-discovery.ts:176:19)
                                host.IoBroker
                                2024-11-27 23:01:12.526	error	Caught by controller[1]: Error: BLE could not be enabled or no device found
                                host.IoBroker
                                2024-11-27 23:01:12.525	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2024-11-27 23:01:11.974	error	BLE could not be enabled or no device found
                                2024-11-27 23:01:11.974	error	Error: BLE could not be enabled or no device found at BLEDiscovery.start (/opt/iobroker/node_modules/hap-controller/src/transport/ble/ble-discovery.ts:176:19) at HomekitController.onReady (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:199:31)
                                2024-11-27 23:01:11.965	error	unhandled promise rejection: BLE could not be enabled or no device found
                                2024-11-27 23:01:11.965	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                ? apollon77 2 Replies Last reply Reply Quote 0
                                  A Former User @Robbi12 last edited by
                                  @robbi12
                                  laut der Fehlermeldung wird dein ble device nicht mehr gefunden...
                                    Danny 1 last edited by
                                    @fatmax
                                    hast Du auch eine Möglichkeit gefunden, einen Vorgang zu stoppen?
                                    Ich nutze einen Shelly i4 Taster für Hochfahren -Runterfahren. Aber leider kann ich nur auf die programmierte „target position“ fahren. Ein „Stop“ habe ich nicht gefunden.
                                      apollon77 @Robbi12 last edited by
                                      @robbi12 EInfach BLE deaktivieren oder das mit dem BLE Adapter fixen. genau. Die neueste beta version sollte das aber auch besser behandeln
                                        Fatmax @Danny 1 last edited by
                                        @danny-1
                                        Mit dem Stoppen habe ich mich bisher nicht befasst, mir reichte es, für den Anfang die Position anfahren zu können.
                                        Mangels Zeit habe ich das aber noch nicht weiter verfolgt.
                                        Eventuell kannst du den Wert bei "position-state" während der Fahrt auf "Stopped" ändern?
                                          alemil @Fatmax last edited by
                                          @fatmax
                                          Hi, verstehe ich es richtig, dass Du jetzt die Fenster über den iobroker als auch weiterhin über die VELUX-FBs bedienen kannst?
                                          Das wäre ja großartig 👍
                                          VG
                                          Alex.
                                            Funbug last edited by
                                            Hallo Zusammen,
                                            Ich brauch Mal euer Fachwissen bei der Einbindung des KIG 300...
                                            Das Gerät habe ich zuerst mit dem iPhone in mein Netzwerk eingebunden, wird von der Dream Machine auch gefunden. Im iPhone habe ich das KIG 300 auch wieder aus Home Kit entfernt.
                                            Nun gelingt mir das Pairing mit dem ioBroker einfach nicht, egal was ich versuche.
                                            Der Pairing Mode (Taste Unterseite mehrere Sekunden drücken --> langsames weisses blinken der LED) ist aktiv.
                                            Im Log kommt folgende Meldung:
                                            "homekit-controller.0
                                            2025-09-24 17:35:05.859 info Use PairMethod 1 to pair IP-E9:3A:97:9F:7F:55"
                                            Nach dem Suchen in der Instanz kommt folgende Fehlermeldung:
                                            "connect EHOSTUNREACH"
                                            Hat jemand einen Tipp für mich?
                                            Gruss Thomas
                                            1.2k
                                            260
                                            41448
