    4. ioBroker admin nicht mehr erreichbar
    • haselchen
      haselchen Most Active @BlindyBlinds last edited by haselchen
      @blindyblinds
      Im Terminal eingeben
      iobroker start admin.0
      Edit1:
      Wenns irgendwie möglich ist
      iob diag
      posten.
        BlindyBlinds @haselchen last edited by BlindyBlinds
        @haselchen Super, das ging schnell mit der Antwort
        2024-03-24 17:12:44.389  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
        2024-03-24 17:13:14.455  - info: host.fujiki instance system.adapter.admin.0 started with pid 8171
        2024-03-24 17:13:15.329  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
        2024-03-24 17:13:15.330  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:                           ^
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
        2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        2024-03-24 17:13:15.332  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:23:47
        2024-03-24 17:13:15.332  - error: host.fujiki Caught by controller[0]: Node.js v18.17.1
        2024-03-24 17:13:15.332  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        Ergebnis leider gleich (Zeit ist in UTC, also -1 )
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: fujiki
               Icon name: computer-desktop
                 Chassis: desktop
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 5.15.0-101-generic
            Architecture: x86-64
         Hardware Vendor: FUJITSU
          Hardware Model: FUTRO S740
        model name	: Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         17:16:28 up  1:54,  2 users,  load average: 0.66, 0.41, 0.32
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Sun 2024-03-24 17:16:29 UTC
                   Universal time: Sun 2024-03-24 17:16:29 UTC
                         RTC time: Sun 2024-03-24 17:16:29
                        Time zone: Etc/UTC (UTC, +0000)
                      NTP service: n/a
                  RTC in local TZ: no
        *** User and Groups ***
        iUser
        /home/iUser
        iUser adm cdrom sudo dip plugdev lxd
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            3.7G        1.1G        899M        5.0M        1.7G        2.3G
        Swap:            16G          0B         16G
        Total:           20G        1.1G         17G
                 3681 M total memory
                 1103 M used memory
                  530 M active memory
                 1905 M inactive memory
                  899 M free memory
                  111 M buffer memory
                 1566 M swap cache
                16383 M total swap
                    0 M used swap
                16383 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem            Type   Size  Used Avail Use% Mounted on
        tmpfs                 tmpfs  369M  1.7M  367M   1% /run
        /dev/sda2             ext4    49G   24G   23G  52% /
        tmpfs                 tmpfs  1.8G  736K  1.8G   1% /dev/shm
        tmpfs                 tmpfs  5.0M     0  5.0M   0% /run/lock
        /dev/sda1             vfat   1.1G  6.1M  1.1G   1% /boot/efi
        tmpfs                 tmpfs  369M  4.0K  369M   1% /run/user/1000
        /dev/mapper/cryptdisk ext4   153G   82G   64G  56% /mnt/cdisk
        [Sun Mar 24 15:21:39 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sun Mar 24 15:21:42 2024] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
        [Sun Mar 24 15:25:13 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        TARGET              SOURCE                FSTYPE   OPTIONS
        /                   /dev/sda2             ext4     rw,relatime
        |-/snap/core20/2182 /dev/loop2            squashfs ro,nodev,relatime,errors=continue
        |-/snap/core20/2105 /dev/loop3            squashfs ro,nodev,relatime,errors=continue
        |-/snap/core18/2812 /dev/loop1            squashfs ro,nodev,relatime,errors=continue
        |-/snap/core18/2796 /dev/loop0            squashfs ro,nodev,relatime,errors=continue
        |-/snap/core22/1033 /dev/loop4            squashfs ro,nodev,relatime,errors=continue
        |-/snap/core22/1122 /dev/loop5            squashfs ro,nodev,relatime,errors=continue
        |-/snap/docker/2915 /dev/loop7            squashfs ro,nodev,relatime,errors=continue
        |-/snap/docker/2904 /dev/loop6            squashfs ro,nodev,relatime,errors=continue
        |-/snap/lxd/27037   /dev/loop8            squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/20671 /dev/loop10           squashfs ro,nodev,relatime,errors=continue
        |-/snap/lxd/27428   /dev/loop9            squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/21184 /dev/loop11           squashfs ro,nodev,relatime,errors=continue
        |-/boot/efi         /dev/sda1             vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        `-/mnt/cdisk        /dev/mapper/cryptdisk ext4     rw,relatime
        /var:
        3.3G	/var/
        2.1G	/var/lib
        1.5G	/var/lib/snapd
        901M	/var/lib/snapd/snaps
        751M	/var/log
        Archived and active journals take up 744.0M in the file system.
        /opt/iobroker/backups:
        35M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        175M	/opt/iobroker/iobroker-data/
        132M	/opt/iobroker/iobroker-data/files
        57M	/opt/iobroker/iobroker-data/files/javascript.admin
        38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        37M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        6.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.17.1
        /usr/bin/node 		v18.17.1
        /usr/bin/npm 		9.6.7
        /usr/bin/npx 		9.6.7
        /usr/bin/corepack 	0.18.0
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.9~dfsg-1ubuntu3.4 500
                500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.19
        admin: 		6.13.16
        javascript: 	7.8.0
        Adapters from github: 	1
        Adapter State
          system.adapter.admin.0                  : admin                 : fujiki                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : fujiki                                   -  enabled
        + system.adapter.discovery.0              : discovery             : fujiki                                   -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : fujiki                                   -  enabled
        + system.adapter.mediola-gateway.0        : mediola-gateway       : fujiki                                   -  enabled
        + system.adapter.simple-api.0             : simple-api            : fujiki                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : fujiki                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.10.11  , installed 2.8.1  [Updatable]
        Adapter    "discovery"    : 4.4.0    , installed 3.1.0  [Updatable]
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "mediola-gateway": 1.1.0  , installed 1.0.1  [Updatable]
        Adapter    "socketio"     : 6.6.0    , installed 6.5.5  [Updatable]
        Adapter    "web"          : 6.2.3    , installed 6.1.2  [Updatable]
        Adapter    "ws"           : 2.5.10   , installed 2.5.5  [Updatable]
        Objects and States
        Objects: 	274
        States: 	179
        Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
        Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:5 https://deb.nodesource.com/node_18.x jammy InRelease
        Hit:6 https://deb.torproject.org/torproject.org jammy InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:5239            0.0.0.0:*               LISTEN      998        25851      716/python3
        tcp        0      0 0.0.0.0:5240            0.0.0.0:*               LISTEN      0          22398      840/nginx: master p
        tcp        0      0 127.0.0.1:32000         0.0.0.0:*               LISTEN      1001       28491      2125/java
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      997        25793      782/pihole-FTL
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      997        25787      782/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25720      793/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1004       73258      7728/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1004       73265      7728/iobroker.js-co
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21391      1/init
        tcp        0      0 0.0.0.0:90              0.0.0.0:*               LISTEN      0          22437      847/lighttpd
        tcp        0      0 0.0.0.0:51821           0.0.0.0:*               LISTEN      0          29046      1409/docker-proxy
        tcp6       0      0 :::7654                 :::*                    LISTEN      1001       29678      2125/java
        tcp6       0      0 ::1:4711                :::*                    LISTEN      997        25794      782/pihole-FTL
        tcp6       0      0 :::5239                 :::*                    LISTEN      998        25857      716/python3
        tcp6       0      0 :::8087                 :::*                    LISTEN      1004       69595      7804/io.simple-api.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1004       70561      7788/io.web.0
        tcp6       0      0 127.0.0.1:7659          :::*                    LISTEN      1001       30284      2125/java
        tcp6       0      0 127.0.0.1:7658          :::*                    LISTEN      1001       28672      2125/java
        tcp6       0      0 127.0.0.1:7660          :::*                    LISTEN      1001       32769      2125/java
        tcp6       0      0 172.17.0.1:7652         :::*                    LISTEN      1001       30217      2125/java
        tcp6       0      0 :::4445                 :::*                    LISTEN      1001       31799      2125/java
        tcp6       0      0 :::4444                 :::*                    LISTEN      1001       30882      2125/java
        tcp6       0      0 127.0.0.1:6668          :::*                    LISTEN      1001       30880      2125/java
        tcp6       0      0 :::53                   :::*                    LISTEN      997        25789      782/pihole-FTL
        tcp6       0      0 :::22                   :::*                    LISTEN      0          25722      793/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          384        1/init
        tcp6       0      0 :::90                   :::*                    LISTEN      0          22436      847/lighttpd
        tcp6       0      0 ::1:7657                :::*                    LISTEN      1001       30830      2125/java
        tcp6       0      0 192.168.0.97:7657       :::*                    LISTEN      1001       30831      2125/java
        tcp6       0      0 192.168.0.97:7652       :::*                    LISTEN      1001       30218      2125/java
        tcp6       0      0 fdba:fa8:c75f:0:4e:7652 :::*                    LISTEN      1001       30219      2125/java
        tcp6       0      0 :::25418                :::*                    LISTEN      1001       28593      2125/java
        tcp6       0      0 :::51821                :::*                    LISTEN      0          27516      1415/docker-proxy
        udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1004       73390      7819/io.mediola-gat
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           997        25786      782/pihole-FTL
        udp        0      0 192.168.0.97:68         0.0.0.0:*                           101        20116      685/systemd-network
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          21392      1/init
        udp        0      0 172.17.0.1:123          0.0.0.0:*                           115        27643      802/ntpd
        udp        0      0 192.168.0.97:123        0.0.0.0:*                           0          20290      802/ntpd
        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          20288      802/ntpd
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          20284      802/ntpd
        udp        0      0 0.0.0.0:39319           0.0.0.0:*                           1004       73391      7819/io.mediola-gat
        udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          29055      1428/docker-proxy
        udp6       0      0 :::1900                 :::*                                1001       30225      2125/java
        udp6       0      0 :::1900                 :::*                                1001       30222      2125/java
        udp6       0      0 :::1900                 :::*                                1001       30750      2125/java
        udp6       0      0 :::53                   :::*                                997        25788      782/pihole-FTL
        udp6       0      0 :::111                  :::*                                0          21393      1/init
        udp6       0      0 fe80::f4d6:b7ff:fec:123 :::*                                115        29698      802/ntpd
        udp6       0      0 fe80::42:93ff:fee6::123 :::*                                115        27648      802/ntpd
        udp6       0      0 fe80::4e52:62ff:feb:123 :::*                                0          20296      802/ntpd
        udp6       0      0 fdba:fa8:c75f:0:4e5:123 :::*                                0          20294      802/ntpd
        udp6       0      0 ::1:123                 :::*                                0          20292      802/ntpd
        udp6       0      0 :::123                  :::*                                0          20281      802/ntpd
        udp6    1280      0 fe80::4e52:62ff:feb:546 :::*                                101        20139      685/systemd-network
        udp6       0      0 :::51820                :::*                                0          29057      1434/docker-proxy
        udp6       0      0 :::25417                :::*                                1001       30234      2125/java
        udp6       0      0 fdba:fa8:c75f:0:4e:7653 :::*                                1001       30230      2125/java
        udp6       0      0 192.168.0.97:7653       :::*                                1001       30229      2125/java
        udp6       0      0 172.17.0.1:7653         :::*                                1001       30228      2125/java
        2024-03-24 17:16:21.045  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
        2024-03-24 17:16:21.045  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
        2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
        2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:23:47
        2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]: Node.js v18.17.1
        2024-03-24 17:16:21.046  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-03-24 17:16:21.046  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
        2024-03-24 17:16:51.111  - info: host.fujiki instance system.adapter.admin.0 started with pid 8571
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:                           ^
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
        2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
        2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:23:47
        2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]: Node.js v18.17.1
        2024-03-24 17:16:52.023  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-03-24 17:16:52.023  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
          Thomas Braun Most Active @BlindyBlinds last edited by Thomas Braun
          @blindyblinds sagte in ioBroker admin nicht mehr erreichbar:
          Setz die Zeit richtig.
          sudo timedatectl set-timezone 'Europe/Berlin'
          Setz das boot target richtig.
          sudo systemctl set-default multi-user.target
          nodejs muss auch aktualisiert werden.
          iob stop
          iob fix
          iob nodejs-update
          Dann bring die ganzen Adapter auf Stand:
          iob update
          iob upgrade all
          Wenn das alles richtig eingestellt wurde:
          iob start admin
          • I
            iotowago last edited by Samson71
            Hallo, ich habe ein ähnliches Probelm bei ebenfalls heute stattgefundenem Update.
            Obigen Lösungsweg habe ich bereits durchgeführt.
            Wo kann noch mein Fehler liegen?
            Das ist der Log aus Iobroker Diag:
            2024-03-24 19:19:06.050  - error: host.HP-ProDesk-600-G2-DM instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-03-24 19:19:06.050  - info: host.HP-ProDesk-600-G2-DM Restart adapter system.adapter.admin.0 because enabled
            2024-03-24 19:19:06.402  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: /opt/iobroker/node_modules/iobroker.node-red/main.js:44
            2024-03-24 19:19:06.402  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: class NodeRed extends utils.Adapter {
            2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:                             ^
            2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
            2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.node-red/main.js:44:29)
            2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at node:internal/main/run_main_module:28:49
            2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: Node.js v18.19.1
            2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM instance system.adapter.node-red.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-03-24 19:19:06.406  - info: host.HP-ProDesk-600-G2-DM Restart adapter system.adapter.node-red.0 because enabled
            2024-03-24 19:19:07.222  - warn: shelly.0 (31324) [authEnabled] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): This device is not protected via restricted login (see adapter documentation for details)
            2024-03-24 19:19:07.247  - warn: shelly.0 (31324) [authEnabled] 192.168.2.27 (shellyplus2pm / shellyplus2pm-d48afc768a84 / shellyplus2pm#d48afc768a84#1): This device is not protected via restricted login (see adapter documentation for details)
            2024-03-24 19:19:07.298  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): "General Status Notifications" are disabled (see adapter documentation for details)
            2024-03-24 19:19:07.322  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.27 (shellyplus2pm / shellyplus2pm-d48afc768a84 / shellyplus2pm#d48afc768a84#1): "General Status Notifications" are disabled (see adapter documentation for details)
            2024-03-24 19:19:07.833  - warn: shelly.0 (31324) [authEnabled] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): This device is not protected via restricted login (see adapter documentation for details)
            2024-03-24 19:19:08.036  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): "General Status Notifications" are disabled (see adapter documentation for details)
            2024-03-24 19:19:08.229  - warn: shelly.0 (31324) [authEnabled] 192.168.2.128 (shellyplus2pm / shellyplus2pm-d48afc76158c / shellyplus2pm#d48afc76158c#1): This device is not protected via restricted login (see adapter documentation for details)
            2024-03-24 19:19:08.377  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.128 (shellyplus2pm / shellyplus2pm-d48afc76158c / shellyplus2pm#d48afc76158c#1): "General Status Notifications" are disabled (see adapter documentation for details)
            2024-03-24 19:19:10.656  - warn: shelly.0 (31324) [authEnabled] 192.168.2.198 (shellyswitch25 / shellyswitch25-98CDAC2C6600 / SHSW-25#98CDAC2C6600#1): This device is not protected via restricted login (see adapter documentation for details)
            Mod-Edit: Code in Code-Tags posten
              Homoran Global Moderator Administrators @BlindyBlinds last edited by Homoran
              /home/iUser
              dein user ist nicht in der Gruppe iobroker
              wie hast du iobroker installiert?
                BlindyBlinds @Homoran last edited by
                @homoran said in ioBroker admin nicht mehr erreichbar:
                /home/iUser
                Keine Sorge, der User ist drin
                  BlindyBlinds @Thomas Braun last edited by
                  UTC ist ja richtig. Rest ist korrigiert, das mit nodejs sah schon vielversprechend aus. Hat auch etwas gebraucht
                  Ergebnis ist aber noch
                  2024-03-24 19:01:03.281  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
                  2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
                  2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:                           ^
                  2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
                  2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
                  2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                  2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                  2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
                  2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
                  2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                  2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                  2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]: Node.js v18.19.1
                  2024-03-24 19:01:03.283  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  Ich überleg mal wie die timezone einen TypeError auslöst, aber so weit bin ich noch nicht
                    sonst noch was in der Ausgabe verändert?
                      UTC ist ja richtig
                      Nein, UTC ist nicht richtig. Da muss eine Zeitzone gesetzt werden. UTC berücksichtigt natürlich (unter anderem) die Sommerzeit nicht.
                      iob diag
                      sagt nun? Und veränder an der Ausgabe NICHTS!
                        Hm, ich bin natürlich etwas paranoid, aber mein iobroker läuft in der Tat als User "iobroker"
                        Ausgabe ist
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Chassis: desktop
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                         17:28:16 up 3 min,  3 users,  load average: 0.28, 0.24, 0.10
                        CPU threads: 4
                                       Local time: Fri 2024-03-29 17:28:16 CET
                                   Universal time: Fri 2024-03-29 16:28:16 UTC
                                         RTC time: Fri 2024-03-29 16:28:16
                                        Time zone: Europe/Amsterdam (CET, +0100)
                                      NTP service: n/a
                                  RTC in local TZ: no
                        iobroker
                        /home/iobroker
                        iobroker tty dialout sudo audio video
                        X-Server: 	false
                        Desktop:
                        Terminal:
                        Boot Target: 	multi-user.target
                        *** MEMORY ***
                        Mem:            3.7G        649M        2.3G        5.0M        692M        2.8G
                        Swap:            16G          0B         16G
                        Total:           20G        649M         18G
                                 3681 M total memory
                                  649 M used memory
                                  196 M active memory
                                  893 M inactive memory
                                 2339 M free memory
                                   47 M buffer memory
                                  644 M swap cache
                                16383 M total swap
                                    0 M used swap
                                16383 M free swap
                        *** FILESYSTEM ***
                        /dev/sda2      ext4    49G   25G   23G  53% /
                        [sudo] password for iobroker:
                        [Fri Mar 29 17:24:29 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Fri Mar 29 17:24:31 2024] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                        |-/snap/lxd/27948   /dev/loop9  squashfs ro,nodev,relatime,errors=continue
                        |-/snap/lxd/27428   /dev/loop8  squashfs ro,nodev,relatime,errors=continue
                        `-/boot/efi         /dev/sda1   vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                        /var:
                        3.6G	/var/
                        2.1G	/var/lib
                        1.5G	/var/lib/snapd
                        899M	/var/log
                        Archived and active journals take up 184.0M in the file system.
                        27M	/opt/iobroker/backups/
                        179M	/opt/iobroker/iobroker-data/
                        133M	/opt/iobroker/iobroker-data/files
                        22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                        9.0M	/opt/iobroker/iobroker-data/objects.jsonl
                        8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                        USB-Devices by-id:
                        /usr/bin/nodejs 	v18.20.0
                        /usr/bin/node 		v18.20.0
                        /usr/bin/npm 		10.5.0
                        /usr/bin/npx 		10.5.0
                        /usr/bin/corepack 	0.25.2
                        nodejs:
                          Installed: 18.20.0-1nodesource1
                          Candidate: 18.20.0-1nodesource1
                          Version table:
                         *** 18.20.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                             18.19.1-1nodesource1 1001
                             18.19.0-1nodesource1 1001
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin: 		6.13.16
                        javascript: 	7.8.0
                        Adapters from github: 	0
                        Adapter State
                        + instance is alive
                        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                        Adapter    "mediola-gateway": 1.1.0  , installed 1.1.0
                        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                        Adapter    "web"          : 6.2.3    , installed 6.2.3
                        Adapter    "ws"           : 2.5.11   , installed 2.5.11
                        Objects and States
                        Objects: 	278
                        States: 	181
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      997        21470      778/pihole-FTL
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23309      785/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19309      1/init
                        tcp        0      0 0.0.0.0:90              0.0.0.0:*               LISTEN      0          25376      843/lighttpd
                        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      997        21476      778/pihole-FTL
                        tcp        0      0 0.0.0.0:51821           0.0.0.0:*               LISTEN      0          27074      1444/docker-proxy
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1004       25994      699/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1004       26002      699/iobroker.js-con
                        tcp        0      0 0.0.0.0:5240            0.0.0.0:*               LISTEN      0          25336      837/nginx: master p
                        tcp        0      0 0.0.0.0:5239            0.0.0.0:*               LISTEN      998        25891      709/python3
                        tcp6       0      0 :::53                   :::*                    LISTEN      997        21472      778/pihole-FTL
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          23311      785/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          484        1/init
                        tcp6       0      0 :::90                   :::*                    LISTEN      0          25375      843/lighttpd
                        tcp6       0      0 :::51821                :::*                    LISTEN      0          27077      1450/docker-proxy
                        tcp6       0      0 :::5239                 :::*                    LISTEN      998        25897      709/python3
                        tcp6       0      0 ::1:4711                :::*                    LISTEN      997        21477      778/pihole-FTL
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1004       29784      1675/io.simple-api.
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1004       28355      1656/io.web.0
                        udp        0      0 0.0.0.0:57540           0.0.0.0:*                           1004       26567      1690/io.mediola-gat
                        udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          26402      1464/docker-proxy
                        udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1004       26566      1690/io.mediola-gat
                        udp        0      0 0.0.0.0:53              0.0.0.0:*                           997        21469      778/pihole-FTL
                        udp        0      0 192.168.0.97:68         0.0.0.0:*                           101        24518      678/systemd-network
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19310      1/init
                        udp        0      0 172.17.0.1:123          0.0.0.0:*                           115        29647      804/ntpd
                        udp        0      0 192.168.0.97:123        0.0.0.0:*                           0          25298      804/ntpd
                        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          25296      804/ntpd
                        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          25292      804/ntpd
                        udp6    1280      0 fe80::4e52:62ff:feb:546 :::*                                101        24513      678/systemd-network
                        udp6       0      0 :::51820                :::*                                0          27080      1472/docker-proxy
                        udp6       0      0 :::53                   :::*                                997        21471      778/pihole-FTL
                        udp6       0      0 :::111                  :::*                                0          18378      1/init
                        udp6       0      0 fe80::c02b:eff:fe0f:123 :::*                                115        29691      804/ntpd
                        udp6       0      0 fe80::42:36ff:fed7::123 :::*                                115        29689      804/ntpd
                        udp6       0      0 fe80::4e52:62ff:feb:123 :::*                                0          25304      804/ntpd
                        udp6       0      0 fdba:fa8:c75f:0:4e5:123 :::*                                0          25302      804/ntpd
                        udp6       0      0 ::1:123                 :::*                                0          25300      804/ntpd
                        udp6       0      0 :::123                  :::*                                0          25289      804/ntpd
                        2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
                        2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                        2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                        2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                        2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                        2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                        2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                        2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]: Node.js v18.20.0
                        2024-03-29 17:28:46.293  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-03-29 17:28:46.293  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
                        2024-03-29 17:29:16.319  - info: host.fujiki instance system.adapter.admin.0 started with pid 3110
                        2024-03-29 17:29:17.223  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
                        2024-03-29 17:29:17.223  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
                        2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:                           ^
                        2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
                        2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
                        2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                        2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                        2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                        2024-03-29 17:29:17.225  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                        2024-03-29 17:29:17.226  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                        2024-03-29 17:29:17.227  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                        2024-03-29 17:29:17.227  - error: host.fujiki Caught by controller[0]: Node.js v18.20.0
                        2024-03-29 17:29:17.227  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-03-29 17:29:17.227  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
                        System ist frisch durchgestartet und alle Module auf dem neuesten Stand. Schon verrückt worüber sich das admin-Modul beschwert, das noch funktionierende mediola-Modul extended auch den utils.Adapter
                        Installation hatte ich damals nach der Anleitung unter https://iobroker.readthedocs.io/de/latest/getting-started/installation.html ausgeführt.
                        @iotowago wie sieht es bei dir aus?
                        Frohe Ostern wünsche ich schon mal!
                          Um das hier zu updaten: Das Problem ist durch umstellen auf den Entwicklerzweig gelöst - die dort vorhandene Version des Adminadapters startet und ist auch wieder erreichbar
                          984
