    4. iobroker exit 25 bei Adapter-Update
      Thomas Braun Most Active @Siggi0904 last edited by
      @siggi0904
      iob update
      iob upgrade hm-rpc@1.16.0
      iob upgrade all
        @thomas-braun oh, wie kommt das da hin?
        Wie kann ich iobroker.hm-rpc nochmal installieren?
          Siggi0904 @Thomas Braun last edited by
          @thomas-braun sagte in iobroker exit 25 bei Adapter-Update:
          hm, misst. Bleibt auch so erhalten, der Fehler.
          mario@iobroker:/opt/iobroker$ iob update
          Used repository: stable
          Adapter    "alarm"        : 3.6.0    , installed 3.6.0
          Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "awtrix-light" : 0.16.0   , installed 0.16.0
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "deconz"       : 1.4.0    , installed 1.4.0
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
          Adapter    "ical"         : 1.14.3   , installed 1.13.3 [Updatable]
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
          Adapter    "openweathermap": 1.0.4   , installed 1.0.4
          Adapter    "shelly"       : 6.8.0    , installed 6.8.0
          Adapter    "socketio"     : 6.6.1    , installed 6.6.0  [Updatable]
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "trashschedule": 3.2.0    , installed 3.2.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.11   , installed 2.5.10 [Updatable]
          mario@iobroker:/opt/iobroker$ iob upgrade hm-rpc@1.16.0
          Would you like to reinstall version 1.16.0 of hm-rpc now? [(y)es, (n)o]: y
          Update hm-rpc from @1.16.0 to @1.16.0
          NPM version: 10.5.0
          Installing iobroker.hm-rpc@1.16.0... (System call)
          npm ERR! code 127
          npm ERR! path /opt/iobroker/node_modules/zlib
          npm ERR! command failed
          npm ERR! command sh -c node-waf clean || true; node-waf configure build
          npm ERR! sh: 1: node-waf: not found
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_31_44_159Z-debug-0.log
          host.iobroker Cannot install iobroker.hm-rpc@1.16.0: 127
            @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
            zlib
            npm ls zlib
              mario@iobroker:/opt/iobroker$ npm ls zlib
              iobroker.inst@2.0.3 /opt/iobroker
              └─┬ iobroker.mihome-vacuum@4.1.1
                └── zlib@1.0.5
                @siggi0904
                npm prune
                npm ls
                S 3 Replies Last reply Reply Quote 0
                    └── zlib@1.0.5
                  mario@iobroker:/opt/iobroker$ npm prune
                  npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                  npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                  npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm WARN deprecated @azure/msal-node@1.18.4: A newer major version of this library is available. Please upgrade to the latest available version.
                  npm ERR! code 127
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_48_34_023Z-debug-0.log
                  Qix- created this issue in visionmedia/debug
                  closed ReDos Vulnerability Regression Visibility Notice #797
                  mikeal created this issue in request/request
                  open Request’s Past, Present and Future #3142
                    ├── @types/caseless@0.12.5 extraneous
                    ├── @types/request@2.48.12 extraneous
                    ├── @types/tough-cookie@4.0.5 extraneous
                    ├── coffeescript@2.7.0 extraneous
                    ├── colors@1.4.0
                    ├── fs-extra@7.0.1
                    ├── iobroker.admin@6.13.16
                    ├── iobroker.alarm@3.6.0
                    ├── iobroker.alexa-timer-vis@0.3.0
                    ├── iobroker.alexa2@3.26.4
                    ├── iobroker.awtrix-light@0.16.0
                    ├── iobroker.backitup@2.10.11
                    ├── iobroker.cloud@4.4.1
                    ├── iobroker.daswetter@3.1.13
                    ├── iobroker.deconz@1.4.0
                    ├── iobroker.discovery@4.4.0
                    ├── iobroker.dwd@2.8.5
                    ├── iobroker.email@1.2.2
                    ├── iobroker.feiertage@1.1.4
                    ├── iobroker.flot@1.12.0
                    ├── iobroker.heatingcontrol@2.12.5
                    ├── iobroker.hm-rega@4.0.0
                    ├── iobroker.hm-rpc@1.16.0
                    ├── iobroker.ical@1.13.3
                    ├── iobroker.icons-mfd-svg@1.2.0
                    ├── iobroker.iot@2.0.11
                    ├── iobroker.javascript@7.8.0
                    ├── iobroker.js-controller@5.0.19
                    ├── iobroker.mihome-vacuum@4.1.1
                    ├── iobroker.openweathermap@1.0.4
                    ├── iobroker.ping@1.6.2
                    ├── iobroker.scenes@2.3.9
                    ├── iobroker.shelly@6.8.0
                    ├── iobroker.simple-api@2.7.2
                    ├── iobroker.socketio@6.6.0
                    ├── iobroker.sonoff@3.0.3
                    ├── iobroker.sql@2.2.0
                    ├── iobroker.tankerkoenig@3.3.7
                    ├── iobroker.tr-064@4.2.18
                    ├── iobroker.trashschedule@3.2.0
                    ├── iobroker.vis@1.5.4
                    ├── iobroker.web@6.2.3
                    ├── iobroker.ws@2.5.10
                    ├── iobroker@2.0.3
                    ├── jsonata@2.0.4 extraneous
                    ├── node-inspect@2.0.0 extraneous
                    ├── picocolors@1.0.0 extraneous
                    ├── semver@5.7.2
                    ├── typescript@5.3.3 extraneous
                    ├── virtual-tsc@0.6.2 extraneous
                    ├── wake_on_lan@1.0.0 extraneous
                    └── yargs@7.1.2
                      In der Datei /opt/iobroker/node_modules/zlib/configure steht node-waf configure
                      Also ist zlib schuld?
                        node-waf configure
                        Möglich. Auf meinem System schaut es so aus:
                        echad@chet:/opt/iobroker $ grep -r node-waf
                        node_modules/reinterval/.npmignore:# node-waf configuration
                        node_modules/bindings/bindings.js:      // node-waf and gyp_addon (a.k.a node-gyp)
                        node_modules/bindings/bindings.js:      // Legacy from node-waf, node <= 0.4.x
                        node_modules/zlib/configure:node-waf configure
                        node_modules/zlib/Makefile:     node-waf build
                        node_modules/zlib/Makefile:     node-waf clean
                        Ich habe aber keine Fehler, wenn npm loslegt.
                          @thomas-braun in den Releases zu node-js 18.20 ist aber auch viel zlib Zeug dabei.
                          https://nodejs.org/en/blog/release/v18.20.0
                          Bei mir auch so:
                          mario@iobroker:/opt/iobroker$ grep -r node-waf
                          log/iobroker.2024-03-29.log:2024-03-29 18:56:47.899  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T17_50_31_979Z-debug-0.log
                          log/iobroker.2024-03-29.log:2024-03-29 19:09:10.732  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T18_03_29_073Z-debug-0.log
                          log/iobroker.2024-03-29.log:2024-03-29 20:25:32.516  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_19_31_663Z-debug-0.log
                          log/iobroker.2024-03-29.log:2024-03-29 20:58:12.865  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_52_59_224Z-debug-0.log
                          node_modules/node-rest-client/readme.md:**NOTE:** _Since version 0.8.0 node does not contain node-waf anymore. The node-zlib package which node-rest-client make use of, depends on node-waf.Fortunately since version 0.8.0 zlib is a core dependency of node, so since version 1.0 of node-rest-client the explicit dependency to "zlib" has been removed from package.json. therefore if you are using a version below 0.8.0 of node please use a versión below 1.0.0 of "node-rest-client". _
                            @siggi0904
                            Kommt aus dem Modul:
                            https://github.com/kkaefer/DEPRECATED-node-zlib
                            Das ist aber wie gesagt seit Jahren überholt.
                              Siggi0904 @Thomas Braun last edited by Siggi0904
                              @thomas-braun ja.
                              Deine Reihenfolge in der grep Ausgabe ist aber anders.
                              das npmignore kommt bei mir am Ende, bei dir als erstes.
                              Kann man die Verwendung irgendwie deaktivieren, dass das sauber durchläuft?
                                Der mihome-vacuum schleppt wohl zlib an. Keine Ahnung, ob man die Dependency dort herausnehmen kann/soll/muss.
                                  @thomas-braun wenn iobroker mich die deinstallation machen lassen würde, könnte ich den adapter auch testweise deinstallieren.
                                  da hat einer einfach gyp nachinstalliert.
                                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/904
                                  Tja, wie nun weiter?
                                  Ich habe beim mihome-adapter mal ein issue aufgemacht.
                                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/940
                                  Cr4zyM1K4 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                                  closed Fehler bei der Installation - code 127 #904
                                  Siggi0904 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                                  closed dependency of zlib get error with node-js 18.20 #940
                                    Da ging es aber auch um canvas. Und die Aktion da global irgendwas reinzuknüppeln war bestimmt auch nicht die eleganteste.
                                      @thomas-braun Hallo Thomas, gibt es Ideen was ich noch machen könnte?
                                      Ich steh irgendwie auf dem Schlauch.
                                      Wie könnte man die Abhängigkeit aufheben?
                                      Dank dir.
                                        @siggi0904
                                        Das müsste im Modul eingetragen werden. Vielleicht kann sich @mcm57 das mal anschauen. Nach meinem Dafürhalten könnte die Abhängigkeit da raus. Aber ich hab keine Ahnung vom Paketbau.
                                          @thomas-braun dann hoffe ich, dass @mcm57 mir da recht kurzfristig helfen kann.
                                          Ich habe auch schwer die Vermutung, dass ich den Adapter mihome-vacuum auch nicht einfach deinstallieren kann. Ich werde da wohl auch in den Fehler rennen.
                                          Da bin ich irgendwie gefangen und brauch Hilfe bei der Reparatur.
                                          Natürlich auch gern per PN und Teamviewer oder ähnliches.
                                          • mcm1957
                                            mcm1957 @Siggi0904 last edited by
                                            @siggi0904
                                            Sorry damit du nicht umsonst wartest.
                                            Aber vor Di werd ich mur kaum was ansehen können.
                                            13045
