    4. iobroker exit 25 bei Adapter-Update
      Thomas Braun Most Active @Siggi0904 last edited by
      @siggi0904
      npm prune
      npm ls
      S 3 Replies Last reply Reply Quote 0
        Siggi0904 @Thomas Braun last edited by
        mario@iobroker:/opt/iobroker$ npm ls zlib
        iobroker.inst@2.0.3 /opt/iobroker
        └─┬ iobroker.mihome-vacuum@4.1.1
          └── zlib@1.0.5
        mario@iobroker:/opt/iobroker$ npm prune
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
        npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated @azure/msal-node@1.18.4: A newer major version of this library is available. Please upgrade to the latest available version.
        npm ERR! code 127
        npm ERR! path /opt/iobroker/node_modules/zlib
        npm ERR! command failed
        npm ERR! command sh -c node-waf clean || true; node-waf configure build
        npm ERR! sh: 1: node-waf: not found
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_48_34_023Z-debug-0.log
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
          ├── @types/caseless@0.12.5 extraneous
          ├── @types/request@2.48.12 extraneous
          ├── @types/tough-cookie@4.0.5 extraneous
          ├── coffeescript@2.7.0 extraneous
          ├── colors@1.4.0
          ├── fs-extra@7.0.1
          ├── iobroker.admin@6.13.16
          ├── iobroker.alarm@3.6.0
          ├── iobroker.alexa-timer-vis@0.3.0
          ├── iobroker.alexa2@3.26.4
          ├── iobroker.awtrix-light@0.16.0
          ├── iobroker.backitup@2.10.11
          ├── iobroker.cloud@4.4.1
          ├── iobroker.daswetter@3.1.13
          ├── iobroker.deconz@1.4.0
          ├── iobroker.discovery@4.4.0
          ├── iobroker.dwd@2.8.5
          ├── iobroker.email@1.2.2
          ├── iobroker.feiertage@1.1.4
          ├── iobroker.flot@1.12.0
          ├── iobroker.heatingcontrol@2.12.5
          ├── iobroker.hm-rega@4.0.0
          ├── iobroker.hm-rpc@1.16.0
          ├── iobroker.ical@1.13.3
          ├── iobroker.icons-mfd-svg@1.2.0
          ├── iobroker.iot@2.0.11
          ├── iobroker.javascript@7.8.0
          ├── iobroker.js-controller@5.0.19
          ├── iobroker.mihome-vacuum@4.1.1
          ├── iobroker.openweathermap@1.0.4
          ├── iobroker.ping@1.6.2
          ├── iobroker.scenes@2.3.9
          ├── iobroker.shelly@6.8.0
          ├── iobroker.simple-api@2.7.2
          ├── iobroker.socketio@6.6.0
          ├── iobroker.sonoff@3.0.3
          ├── iobroker.sql@2.2.0
          ├── iobroker.tankerkoenig@3.3.7
          ├── iobroker.tr-064@4.2.18
          ├── iobroker.trashschedule@3.2.0
          ├── iobroker.vis@1.5.4
          ├── iobroker.web@6.2.3
          ├── iobroker.ws@2.5.10
          ├── iobroker@2.0.3
          ├── jsonata@2.0.4 extraneous
          ├── node-inspect@2.0.0 extraneous
          ├── picocolors@1.0.0 extraneous
          ├── semver@5.7.2
          ├── typescript@5.3.3 extraneous
          ├── virtual-tsc@0.6.2 extraneous
          ├── wake_on_lan@1.0.0 extraneous
          └── yargs@7.1.2
            In der Datei /opt/iobroker/node_modules/zlib/configure steht node-waf configure
            Also ist zlib schuld?
              @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
              node-waf configure
              Möglich. Auf meinem System schaut es so aus:
              echad@chet:/opt/iobroker $ grep -r node-waf
              node_modules/reinterval/.npmignore:# node-waf configuration
              node_modules/bindings/bindings.js:      // node-waf and gyp_addon (a.k.a node-gyp)
              node_modules/bindings/bindings.js:      // Legacy from node-waf, node <= 0.4.x
              node_modules/zlib/configure:node-waf configure
              node_modules/zlib/Makefile:     node-waf build
              node_modules/zlib/Makefile:     node-waf clean
              Ich habe aber keine Fehler, wenn npm loslegt.
                @thomas-braun in den Releases zu node-js 18.20 ist aber auch viel zlib Zeug dabei.
                https://nodejs.org/en/blog/release/v18.20.0
                Bei mir auch so:
                mario@iobroker:/opt/iobroker$ grep -r node-waf
                log/iobroker.2024-03-29.log:2024-03-29 18:56:47.899  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T17_50_31_979Z-debug-0.log
                log/iobroker.2024-03-29.log:2024-03-29 19:09:10.732  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T18_03_29_073Z-debug-0.log
                log/iobroker.2024-03-29.log:2024-03-29 20:25:32.516  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_19_31_663Z-debug-0.log
                log/iobroker.2024-03-29.log:2024-03-29 20:58:12.865  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_52_59_224Z-debug-0.log
                node_modules/node-rest-client/readme.md:**NOTE:** _Since version 0.8.0 node does not contain node-waf anymore. The node-zlib package which node-rest-client make use of, depends on node-waf.Fortunately since version 0.8.0 zlib is a core dependency of node, so since version 1.0 of node-rest-client the explicit dependency to "zlib" has been removed from package.json. therefore if you are using a version below 0.8.0 of node please use a versión below 1.0.0 of "node-rest-client". _
                  @siggi0904
                  Kommt aus dem Modul:
                  https://github.com/kkaefer/DEPRECATED-node-zlib
                  Das ist aber wie gesagt seit Jahren überholt.
                    Siggi0904 @Thomas Braun last edited by Siggi0904
                    @thomas-braun ja.
                    Deine Reihenfolge in der grep Ausgabe ist aber anders.
                    das npmignore kommt bei mir am Ende, bei dir als erstes.
                    Kann man die Verwendung irgendwie deaktivieren, dass das sauber durchläuft?
                      Der mihome-vacuum schleppt wohl zlib an. Keine Ahnung, ob man die Dependency dort herausnehmen kann/soll/muss.
                        @thomas-braun wenn iobroker mich die deinstallation machen lassen würde, könnte ich den adapter auch testweise deinstallieren.
                        da hat einer einfach gyp nachinstalliert.
                        https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/904
                        Tja, wie nun weiter?
                        Ich habe beim mihome-adapter mal ein issue aufgemacht.
                        https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/940
                        Cr4zyM1K4 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                        closed Fehler bei der Installation - code 127 #904
                        Siggi0904 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                        closed dependency of zlib get error with node-js 18.20 #940
                          Da ging es aber auch um canvas. Und die Aktion da global irgendwas reinzuknüppeln war bestimmt auch nicht die eleganteste.
                            @thomas-braun Hallo Thomas, gibt es Ideen was ich noch machen könnte?
                            Ich steh irgendwie auf dem Schlauch.
                            Wie könnte man die Abhängigkeit aufheben?
                            Dank dir.
                              @siggi0904
                              Das müsste im Modul eingetragen werden. Vielleicht kann sich @mcm57 das mal anschauen. Nach meinem Dafürhalten könnte die Abhängigkeit da raus. Aber ich hab keine Ahnung vom Paketbau.
                                @thomas-braun dann hoffe ich, dass @mcm57 mir da recht kurzfristig helfen kann.
                                Ich habe auch schwer die Vermutung, dass ich den Adapter mihome-vacuum auch nicht einfach deinstallieren kann. Ich werde da wohl auch in den Fehler rennen.
                                Da bin ich irgendwie gefangen und brauch Hilfe bei der Reparatur.
                                Natürlich auch gern per PN und Teamviewer oder ähnliches.
                                • mcm1957
                                  mcm1957 @Siggi0904 last edited by
                                  @siggi0904
                                  Sorry damit du nicht umsonst wartest.
                                  Aber vor Di werd ich mur kaum was ansehen können.
                                    Siggi0904 @mcm1957 last edited by
                                    @mcm57 Kein Thema, dann warte ich. Läuft ja alles, nur updates gehen nicht.
                                      @Thomas-Braun irgendwie zerlege ich mir hier gerade mein IOBroker.
                                      Im Guthub wurde mit geschrieben, dass ich das zlib anheben soll.
                                      Habs in der package.json angepasst.
                                      Nun ist IOBroker komplett nicht mehr erreichbar.
                                      login as: mario
                                      mario@192.168.178.64's password:
                                      Linux iobroker 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64
                                      The programs included with the Debian GNU/Linux system are free software;
                                      the exact distribution terms for each program are described in the
                                      individual files in /usr/share/doc/*/copyright.
                                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                      permitted by applicable law.
                                      Last login: Fri Mar 29 20:47:18 2024 from 192.168.178.41
                                      mario@iobroker:~$ nano /opt/iobroker/node_modules/io
                                      iobroker/                 iobroker.flot/            iobroker.simple-api/
                                      iobroker.admin/           iobroker.heatingcontrol/  iobroker.socketio/
                                      iobroker.alarm/           iobroker.hm-rega/         iobroker.sonoff/
                                      iobroker.alexa2/          iobroker.hm-rpc/          iobroker.sql/
                                      iobroker.alexa-timer-vis/ iobroker.ical/            iobroker.tankerkoenig/
                                      iobroker.awtrix-light/    iobroker.icons-mfd-svg/   iobroker.tr-064/
                                      iobroker.backitup/        iobroker.iot/             iobroker.trashschedule/
                                      iobroker.cloud/           iobroker.javascript/      iobroker.type-detector/
                                      iobroker.daswetter/       iobroker.js-controller/   iobroker.vis/
                                      iobroker.deconz/          iobroker.mihome-vacuum/   iobroker.web/
                                      iobroker.discovery/       iobroker.openweathermap/  iobroker.ws/
                                      iobroker.dwd/             iobroker.ping/            ioredis/
                                      iobroker.email/           iobroker.scenes/
                                      iobroker.feiertage/       iobroker.shelly/
                                      mario@iobroker:~$ ls /opt/iobroker/node_modules/iobroker.mihome-vacuum/
                                      admin  io-package.json  lib  LICENSE  main.js  package.json  README.md
                                      mario@iobroker:~$ nano /opt/iobroker/node_modules/iobroker.mihome-vacuum/package.json
                                      mario@iobroker:~$ iob upgrade mihome-vacuum@4.1.1
                                      Would you like to reinstall version 4.1.1 of mihome-vacuum now? [(y)es, (n)o]: y
                                      Update mihome-vacuum from @4.1.1 to @4.1.1
                                      NPM version: 10.5.0
                                      Installing iobroker.mihome-vacuum@4.1.1... (System call)
                                      npm ERR! code 127
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-31T12_32_38_352Z-debug-0.log
                                      host.iobroker Cannot install iobroker.mihome-vacuum@4.1.1: 127
                                      mario@iobroker:~$ npm ls zlib
                                      /home/mario
                                      └── (empty)
                                      node:internal/modules/cjs/loader:1143
                                        throw err;
                                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                          at Module._load (node:internal/modules/cjs/loader:981:27)
                                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                          at node:internal/main/run_main_module:28:49 {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: []
                                      Node.js v18.20.0
                                      mario@iobroker:~$
                                      • mcm1957
                                        @siggi0904
                                        Wie ich schon im issue geschrieben habe ist
                                        • das Editieren der package.json keine tolle idee da bei der Installation das package.json des Paketsbund hiffentlich kuchtcdes Zielsystems verwendet wird
                                        • beim Ändern v package.json auch packaga-lock.json anzupassen ist.
                                        • ein Sprung vvzlib 1.x.x auf 3.x.x ohne check des Changelogs sehr mutigbust. Major Releases veinhaltennmeust knkompatible änderungen und sa muss ev der Adapter angepasst werden..
                                        Deinstallier mihome mal. Ich bezweifle dass der Adapter bzw zlib die primäre Fehlerursache ist. Es sind mit Sicherheit auchcschon zug andere User auf node 18. Wenn das Problem ohne mihome weg ist dann ibstalluer den Adapter neu. Und dann schau na bal was der Statzs ist.
                                          @mcm57 wie geschrieben geht aktuell garnichts mehr.
                                            So, ich habe nun mein Proxmox-Backup von vor der Hochrüstung von node-js wieder eingespielt.
                                            Zum Glück hatte ich das entsprechend des Tutorials von @haus-automatisierung alles so eingerichtet,
                                            dass das zurückrollen des Backups leicht ging.
                                            Nur musste ich alle Arbeiten, die ich die Woche über gemacht hatte, wiederholen.
                                            Zum aktuellen Stand:
                                            Ich habe alle Addons aktuell, mihome-vacuum adapter ist installiert und node-js steht bei Version 18.19.1.
                                            Ich müsste nun node-js hochrüsten.
                                            Aber wie?
                                            13054
