    4. Yahka nach Stromausfall nicht mehr einbindbar
    • DJMarc75
      DJMarc75 @f0rd42 last edited by
      @f0rd42 bitte die Langfassung von
      iob diag
      mal zeigen - und in CODETAGS posten 😉
        f0rd42 @DJMarc75 last edited by
        @djmarc75 your wish is my command 🙂
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: s01
               Icon name: computer-desktop
                 Chassis: desktop
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 5.15.0-101-generic
            Architecture: x86-64
         Hardware Vendor: Lenovo
          Hardware Model: ThinkCentre M910q
        model name	: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         18:00:55 up 5 days,  6:22,  2 users,  load average: 0.27, 0.32, 0.30
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Fri 2024-03-29 18:00:55 CET
                   Universal time: Fri 2024-03-29 17:00:55 UTC
                         RTC time: Fri 2024-03-29 17:00:55
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        adieball
        /home/adieball
        adieball adm cdrom sudo dip plugdev lxd iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:             15G        4.6G        6.5G        1.0M        4.7G         11G
        Swap:           4.1G          0B        4.1G
        Total:           19G        4.6G         10G
                15877 M total memory
                 4621 M used memory
                 2014 M active memory
                 6723 M inactive memory
                 6546 M free memory
                  638 M buffer memory
                 4070 M swap cache
                 4095 M total swap
                    0 M used swap
                 4095 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                        Type   Size  Used Avail Use% Mounted on
        tmpfs                             tmpfs  1.6G  1.5M  1.6G   1% /run
        /dev/mapper/ubuntu--vg-ubuntu--lv ext4   232G   37G  185G  17% /
        tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
        tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
        /dev/sda2                         ext4   2.0G  252M  1.6G  14% /boot
        /dev/sda1                         vfat   1.1G  6.1M  1.1G   1% /boot/efi
        tmpfs                             tmpfs  1.6G  4.0K  1.6G   1% /run/user/1000
        [Sun Mar 24 11:38:53 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sun Mar 24 11:38:54 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
        [Sun Mar 24 11:38:55 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        TARGET              SOURCE                            FSTYPE   OPTIONS
        /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
        |-/snap/core20/2105 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/core20/2182 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/lxd/27428   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/20671 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/21184 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
        |-/boot             /dev/sda2                         ext4     rw,relatime
        | `-/boot/efi       /dev/sda1                         vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        `-/snap/lxd/27948   /dev/loop6                        squashfs ro,nodev,relatime,errors=continue
        /var:
        6.3G	/var/
        4.4G	/var/log
        4.0G	/var/log/journal/cc86b7ff95fe4abc81b83c0d9e43cc98
        1.3G	/var/lib
        Archived and active journals take up 3.9G in the file system.
        /opt/iobroker/backups:
        17G	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        542M	/opt/iobroker/iobroker-data/
        363M	/opt/iobroker/iobroker-data/files
        144M	/opt/iobroker/iobroker-data/files/vis-2
        100M	/opt/iobroker/iobroker-data/backup-objects
        82M	/opt/iobroker/iobroker-data/files/vis-2/static
        43M	/opt/iobroker/iobroker-data/states.jsonl
        37M	/opt/iobroker/iobroker-data/objects.jsonl
        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        19M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.b4e310b6.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH0648CG-if00-port0
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7ac8b1b9ae19ec11a49b39cc47486eb0-if00-port0
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH0648CX-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.19.1
        /usr/bin/node 		v18.19.1
        /usr/bin/npm 		10.2.4
        /usr/bin/npx 		10.2.4
        /usr/bin/corepack 	0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.20.0-1nodesource1
          Version table:
             18.20.0-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         *** 18.19.1-1nodesource1 500
                100 /var/lib/dpkg/status
             18.19.0-1nodesource1 500
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.9~dfsg-1ubuntu3.4 500
                500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.19
        admin: 		6.15.2
        javascript: 	7.9.4
        Adapters from github: 	4
        Adapter State
        + system.adapter.admin.0                  : admin                 : s01                                      -  enabled, port: 8081, bind: 192.168.119.121 (SSL), run as: admin
        + system.adapter.admin.1                  : admin                 : s01                                      -  enabled, port: 8090, bind: 192.168.119.121, run as: admin
        + system.adapter.alarm.0                  : alarm                 : s01                                      -  enabled
        + system.adapter.backitup.0               : backitup              : s01                                      -  enabled
        + system.adapter.cloud.0                  : cloud                 : s01                                      -  enabled
          system.adapter.daswetter.0              : daswetter             : s01                                      -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : s01                                      -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : s01                                      -  enabled
        + system.adapter.discovery.0              : discovery             : s01                                      -  enabled
        + system.adapter.doorbird.0               : doorbird              : s01                                      -  enabled
          system.adapter.dwd.0                    : dwd                   : s01                                      -  enabled
          system.adapter.dysonairpurifier.0       : dysonairpurifier      : s01                                      - disabled
          system.adapter.feiertage.0              : feiertage             : s01                                      -  enabled
          system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : s01                                      - disabled
        + system.adapter.geofency.0               : geofency              : s01                                      -  enabled, port: 7999, bind: 192.168.119.121
        + system.adapter.go-e.0                   : go-e                  : s01                                      -  enabled
        + system.adapter.gruenbeck.0              : gruenbeck             : s01                                      -  enabled
        + system.adapter.harmony.0                : harmony               : s01                                      -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : s01                                      -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : s01                                      -  enabled, port: 0
        + system.adapter.homeconnect.0            : homeconnect           : s01                                      -  enabled
          system.adapter.homekit-controller.0     : homekit-controller    : s01                                      - disabled
        + system.adapter.homepilot20.0            : homepilot20           : s01                                      -  enabled
        + system.adapter.hue.0                    : hue                   : s01                                      -  enabled, port: 80
        + system.adapter.influxdb.0               : influxdb              : s01                                      -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : s01                                      -  enabled
        + system.adapter.iot.0                    : iot                   : s01                                      -  enabled
        + system.adapter.javascript.0             : javascript            : s01                                      -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : s01                                      -  enabled, port: 1884, bind: 192.168.119.121
        + system.adapter.nuki-extended.0          : nuki-extended         : s01                                      -  enabled
          system.adapter.odl.0                    : odl                   : s01                                      -  enabled
        + system.adapter.ping.0                   : ping                  : s01                                      -  enabled
        + system.adapter.pushover.0               : pushover              : s01                                      -  enabled
          system.adapter.roomba.0                 : roomba                : s01                                      - disabled
        + system.adapter.shelly.0                 : shelly                : s01                                      -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartcontrol.0           : smartcontrol          : s01                                      -  enabled
        + system.adapter.smartmeter.0             : smartmeter            : s01                                      -  enabled
        + system.adapter.smartmeter.1             : smartmeter            : s01                                      -  enabled
        + system.adapter.sonoff.0                 : sonoff                : s01                                      -  enabled, port: 1883, bind: 192.168.119.121
        + system.adapter.sourceanalytix.0         : sourceanalytix        : s01                                      -  enabled
          system.adapter.sprinklecontrol.0        : sprinklecontrol       : s01                                      - disabled
        + system.adapter.sql.0                    : sql                   : s01                                      -  enabled, port: 3306
        + system.adapter.telegram.0               : telegram              : s01                                      -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.tesla-motors.0           : tesla-motors          : s01                                      - disabled
        + system.adapter.tibberlink.0             : tibberlink            : s01                                      -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : s01                                      -  enabled
        + system.adapter.web.0                    : web                   : s01                                      -  enabled, port: 8082, bind: 192.168.119.121 (SSL), run as: admin
        + system.adapter.web.1                    : web                   : s01                                      -  enabled, port: 8083, bind: 192.168.119.121, run as: admin
        + system.adapter.wiffi-wz.0               : wiffi-wz              : s01                                      -  enabled
        + system.adapter.withings.0               : withings              : s01                                      -  enabled
        + system.adapter.worx.0                   : worx                  : s01                                      -  enabled
        + system.adapter.yahka.0                  : yahka                 : s01                                      -  enabled
        + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : s01                                      -  enabled
        + system.adapter.zigbee.0                 : zigbee                : s01                                      -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7ac8b1b9ae19ec11a49b39cc47486eb0-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.15.2   , installed 6.15.2
        Adapter    "alarm"        : 3.6.0    , installed 3.6.0
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.11.0  , installed 2.11.0
        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
        Adapter    "doorbird"     : 1.5.0    , installed 1.5.0
        Adapter    "dysonairpurifier": 3.1.4 , installed 3.1.3  [Updatable]
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
        Adapter    "go-e"         : 1.0.29   , installed 1.0.29
        Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
        Adapter    "harmony"      : 1.3.0    , installed 1.3.0
        Adapter    "hid-community": 0.3.0    , installed 0.3.0
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "homekit-controller": 0.5.10, installed 0.5.10
        Adapter    "homepilot"    : 1.1.6    , installed 1.1.6
        Adapter    "hue"          : 3.11.0   , installed 3.10.2 [Updatable]
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.11.1   , installed 7.9.4  [Updatable]
        Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "odl"          : 3.0.1    , installed 3.0.1
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "roomba"       : 1.2.2    , installed 1.2.2
        Adapter    "shelly"       : 6.9.0    , installed 6.9.0
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
        Adapter    "tesla-motors" : 1.4.2    , installed 1.4.2
        Adapter    "tibberlink"   : 2.3.2    , installed 2.3.2
        Adapter    "vis-2"        : 2.9.47   , installed 2.9.47
        Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
        Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "yahoo-stock-market": 0.0.5, installed 0.0.5
        Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
        Objects and States
        Objects: 	37142
        States: 	32329
        W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: GPG error: https://apt.grafana.com beta InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
        E: The repository 'https://apt.grafana.com beta InRelease' is not signed.
        Pending Updates: 6
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:46333           0.0.0.0:*               LISTEN      1001       6324005    211228/io.yahka.0
        tcp        0      0 192.168.119.121:1883    0.0.0.0:*               LISTEN      1001       96613      5416/io.sonoff.0
        tcp        0      0 192.168.119.121:1884    0.0.0.0:*               LISTEN      1001       94986      5303/io.mqtt.0
        tcp        0      0 192.168.119.121:2010    0.0.0.0:*               LISTEN      1001       97361      5218/io.hm-rpc.0
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        24315      773/influxd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93978      5028/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       94574      5028/iobroker.js-co
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       97480      5365/io.shelly.0
        tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          24337      880/perl
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15636      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22523      788/sshd: /usr/sbin
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        24035      692/systemd-resolve
        tcp        0      0 192.168.119.121:7999    0.0.0.0:*               LISTEN      1001       95508      5251/io.geofency.0
        tcp        0      0 192.168.119.121:8100    0.0.0.0:*               LISTEN      1001       95832      5531/io.doorbird.0
        tcp        0      0 192.168.119.121:8082    0.0.0.0:*               LISTEN      1001       96687      5465/io.web.0
        tcp        0      0 192.168.119.121:8083    0.0.0.0:*               LISTEN      1001       96725      5483/io.web.1
        tcp        0      0 192.168.119.121:8081    0.0.0.0:*               LISTEN      1001       92148      5050/io.admin.0
        tcp        0      0 192.168.119.121:8090    0.0.0.0:*               LISTEN      1001       95250      5077/io.admin.1
        tcp        0      0 192.168.119.121:8181    0.0.0.0:*               LISTEN      1001       96165      6085/io.wiffi-wz.0
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       100403     6169/io.harmony.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      998        16312      773/influxd
        tcp6       0      0 :::8581                 :::*                    LISTEN      997        29984      855/hb-service
        tcp6       0      0 :::111                  :::*                    LISTEN      0          20665      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          22525      788/sshd: /usr/sbin
        tcp6       0      0 :::51989                :::*                    LISTEN      1001       95595      5320/io.nuki-extend
        tcp6       0      0 :::51523                :::*                    LISTEN      997        29488      1320/homebridge
        udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          24338      880/perl
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       100404     6169/io.harmony.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           997        29951      855/hb-service
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           117        22473      702/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           102        24029      692/systemd-resolve
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        24034      692/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15637      1/init
        udp        0      0 0.0.0.0:50383           0.0.0.0:*                           117        22475      702/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                102        24031      692/systemd-resolve
        udp6       0      0 :::5353                 :::*                                117        22474      702/avahi-daemon: r
        udp6       0      0 :::57066                :::*                                117        22476      702/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          21505      1/init
        2024-03-29 18:00:56.735  - debug: yahka.0 (211228) [Gefrierschrank.CurrentTemperature] got a set event, hkValue: -15.899999999999977
        2024-03-29 18:00:56.735  - debug: yahka.0 (211228) [Gefrierschrank.CurrentTemperature] set was initiated from ioBroker - exiting here
        2024-03-29 18:01:00.008  - info: javascript.0 (5110) script.js.common.PublicIP_Check: request: http://v4.ipv6-test.com/api/myip.php
        2024-03-29 18:01:00.132  - info: javascript.0 (5110) script.js.common.UWZ: []
        2024-03-29 18:01:00.244  - info: javascript.0 (5110) script.js.common.Raumklima: **Änderung:Wohnzimmer-Wiffi: wiffi-wz.0.root.192_168_119_70.aa_feuchte: 39.2**
        2024-03-29 18:01:04.245  - info: javascript.0 (5110) script.js.common.Raumklima: =========================================================
        2024-03-29 18:01:04.245  - info: javascript.0 (5110) script.js.common.Raumklima: Erzeugung JSON Start
        2024-03-29 18:01:04.246  - info: javascript.0 (5110) script.js.common.Raumklima: strJSONfinal = [{"Raum":"Garten","Feuchtegehalt_Absolut":"0.00","relative_Luftfeuchtigkeit":"0.00","Taupunkt":"NaN","Temperatur":"0.00","DETAILS.Enthalpie":"0.00","DETAILS.Sättigungsdampfdruck":"6.11","DETAILS.Dampfdruck":"0.00","Dampfgewicht":"0.00","DETAILS.Dampfgewicht_maximal":"NaN","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"weatherunderground","Feuchtegehalt_Absolut":"0.00","relative_Luftfeuchtigkeit":"0.00","Taupunkt":"NaN","Temperatur":"0.00","DETAILS.Enthalpie":"0.00","DETAILS.Sättigungsdampfdruck":"6.11","DETAILS.Dampfdruck":"0.00","Dampfgewicht":"0.00","DETAILS.Dampfgewicht_maximal":"NaN","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Wohnzimmer","Feuchtegehalt_Absolut":"6.11","relative_Luftfeuchtigkeit":"36.56","Taupunkt":"6.70","Temperatur":"22.28","DETAILS.Enthalpie":"37.94","DETAILS.Sättigungsdampfdruck":"26.89","DETAILS.Dampfdruck":"9.83","Dampfgewicht":"7.21","DETAILS.Dampfgewicht_maximal":"19.72","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Büro","Feuchtegehalt_Absolut":"5.90","relative_Luftfeuchtigkeit":"38.43","Taupunkt":"6.20","Temperatur":"20.89","DETAILS.Enthalpie":"35.99","DETAILS.Sättigungsdampfdruck":"24.70","DETAILS.Dampfdruck":"9.49","Dampfgewicht":"7.00","DETAILS.Dampfgewicht_maximal":"18.20","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Schlafzimmer","Feuchtegehalt_Absolut":"6.14","relative_Luftfeuchtigkeit":"39.74","Taupunkt":"6.80","Temperatur":"20.99","DETAILS.Enthalpie":"36.70","DETAILS.Sättigungsdampfdruck":"24.85","DETAILS.Dampfdruck":"9.88","Dampfgewicht":"7.28","DETAILS.Dampfgewicht_maximal":"18.31","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Wohnzimmer-Wiffi","Feuchtegehalt_Absolut":"6.90","relative_Luftfeuchtigkeit":"39.20","Taupunkt":"8.50","Temperatur":"23.10","DETAILS.Enthalpie":"40.77","DETAILS.Sättigungsdampfdruck":"28.26","DETAILS.Dampfdruck":"11.08","Dampfgewicht":"8.10","DETAILS.Dampfgewicht_maximal":"20.67","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Dachboden","Feuchtegehalt_Absolut":"7.03","relative_Luftfeuchtigkeit":"53.00","Taupunkt":"8.70","Temperatur":"18.50","DETAILS.Enthalpie":"36.42","DETAILS.Sättigungsdampfdruck":"21.30","DETAILS.Dampfdruck":"11.29","Dampfgewicht":"8.39","DETAILS.Dampfgewicht_maximal":"15.82","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"}]
        2024-03-29 18:01:04.247  - info: javascript.0 (5110) script.js.common.Raumklima: anyLueften = false, Anzahl Lüftungsempfehlungen: 0
        2024-03-29 18:01:04.247  - info: javascript.0 (5110) script.js.common.Raumklima: =========================================================
        2024-03-29 18:01:04.247  - info: javascript.0 (5110) script.js.common.Raumklima: Erzeugung JSON Ende
        2024-03-29 18:01:13.714  - info: smartmeter.1 (5398) Error: No or too long answer from Serial Device after last request.
        2024-03-29 18:01:13.714  - warn: smartmeter.1 (5398) No or too long answer from Serial Device after last request.
        2024-03-29 18:01:30.939  - info: javascript.0 (5110) script.js.common.Raumklima: **Änderung:Wohnzimmer-Wiffi: wiffi-wz.0.root.192_168_119_70.aa_feuchte: 39.3**
        2024-03-29 18:01:34.610  - info: smartmeter.0 (5380) Received 11 values, 1 updated
        2024-03-29 18:01:34.940  - info: javascript.0 (5110) script.js.common.Raumklima: =========================================================
        2024-03-29 18:01:34.940  - info: javascript.0 (5110) script.js.common.Raumklima: Erzeugung JSON Start
        2024-03-29 18:01:34.941  - info: javascript.0 (5110) script.js.common.Raumklima: strJSONfinal = [{"Raum":"Garten","Feuchtegehalt_Absolut":"0.00","relative_Luftfeuchtigkeit":"0.00","Taupunkt":"NaN","Temperatur":"0.00","DETAILS.Enthalpie":"0.00","DETAILS.Sättigungsdampfdruck":"6.11","DETAILS.Dampfdruck":"0.00","Dampfgewicht":"0.00","DETAILS.Dampfgewicht_maximal":"NaN","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"weatherunderground","Feuchtegehalt_Absolut":"0.00","relative_Luftfeuchtigkeit":"0.00","Taupunkt":"NaN","Temperatur":"0.00","DETAILS.Enthalpie":"0.00","DETAILS.Sättigungsdampfdruck":"6.11","DETAILS.Dampfdruck":"0.00","Dampfgewicht":"0.00","DETAILS.Dampfgewicht_maximal":"NaN","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Wohnzimmer","Feuchtegehalt_Absolut":"6.11","relative_Luftfeuchtigkeit":"36.56","Taupunkt":"6.70","Temperatur":"22.28","DETAILS.Enthalpie":"37.94","DETAILS.Sättigungsdampfdruck":"26.89","DETAILS.Dampfdruck":"9.83","Dampfgewicht":"7.21","DETAILS.Dampfgewicht_maximal":"19.72","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Büro","Feuchtegehalt_Absolut":"5.90","relative_Luftfeuchtigkeit":"38.43","Taupunkt":"6.20","Temperatur":"20.89","DETAILS.Enthalpie":"35.99","DETAILS.Sättigungsdampfdruck":"24.70","DETAILS.Dampfdruck":"9.49","Dampfgewicht":"7.00","DETAILS.Dampfgewicht_maximal":"18.20","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Schlafzimmer","Feuchtegehalt_Absolut":"6.14","relative_Luftfeuchtigkeit":"39.74","Taupunkt":"6.80","Temperatur":"20.99","DETAILS.Enthalpie":"36.70","DETAILS.Sättigungsdampfdruck":"24.85","DETAILS.Dampfdruck":"9.88","Dampfgewicht":"7.28","DETAILS.Dampfgewicht_maximal":"18.31","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Wohnzimmer-Wiffi","Feuchtegehalt_Absolut":"6.92","relative_Luftfeuchtigkeit":"39.30","Taupunkt":"8.50","Temperatur":"23.10","DETAILS.Enthalpie":"40.82","DETAILS.Sättigungsdampfdruck":"28.26","DETAILS.Dampfdruck":"11.11","Dampfgewicht":"8.12","DETAILS.Dampfgewicht_maximal":"20.67","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Dachboden","Feuchtegehalt_Absolut":"7.03","relative_Luftfeuchtigkeit":"53.00","Taupunkt":"8.70","Temperatur":"18.50","DETAILS.Enthalpie":"36.42","DETAILS.Sättigungsdampfdruck":"21.30","DETAILS.Dampfdruck":"11.29","Dampfgewicht":"8.39","DETAILS.Dampfgewicht_maximal":"15.82","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"NaN","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"NaN","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"NaN","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"}]
        2024-03-29 18:01:34.941  - info: javascript.0 (5110) script.js.common.Raumklima: anyLueften = false, Anzahl Lüftungsempfehlungen: 0
        2024-03-29 18:01:34.941  - info: javascript.0 (5110) script.js.common.Raumklima: =========================================================
        2024-03-29 18:01:34.941  - info: javascript.0 (5110) script.js.common.Raumklima: Erzeugung JSON Ende
        • wendy2702
          wendy2702 last edited by
          Setz mal hier den Haken und teste
            f0rd42 @wendy2702 last edited by
            @wendy2702 Hatte ich vorher auch nicht.
            Ändert aber nicht, wenn ich CIAO nutze, taucht Yahka noch nicht mal mehr im mDNS Discovery auf - und im Homekit auf dem iphone schon gar nicht mehr, was ja vorher wenigstens angezeigt wurde
            Meine auch mal irgendwo gelesen zu haben, dass unter Linux Avahi die richtige wahl ist ... mag mich aber täuschen
            • wendy2702
              Ich kann mich halt an Themen erinnern bei denen die Umstellung die Lösung war.
              Vielleicht postest du mal ein log vom Adapter start
                @wendy2702 gerne, aber auch hier nichts, was irgendwie auf einen Fehler schliessen lassen würde ....
                	2024-03-29 18:55:17.679	debug	[Gefrierschrank.CurrentTemperature] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.679	debug	[Gefrierschrank.CurrentTemperature] got a set event, hkValue: -18.299999999999983
                yahka.0
                2024-03-29 18:55:17.678	debug	[Gefrierschrank.CurrentTemperature] initializing homekit with value from ioBroker(-18.3) to homekit as (-18.3)
                yahka.0
                2024-03-29 18:55:17.678	debug	read state from ioBroker [zigbee.0.00124b00291ff16f.temperature]: {"val":-18.3,"ack":true,"ts":1711734748785,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734748785}
                yahka.0
                2024-03-29 18:55:17.673	debug	[Gefrierschrank.CurrentTemperature] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.673	debug	[Gefrierschrank.CurrentTemperature] got a set event, hkValue: -18.299999999999983
                yahka.0
                2024-03-29 18:55:17.673	debug	[Gefrierschrank.CurrentTemperature] forwarding value from ioBroker (-18.3) to homekit as (-18.3)
                yahka.0
                2024-03-29 18:55:17.672	debug	[Gefrierschrank.CurrentTemperature] got a change notify event, ioValue: -18.3
                yahka.0
                2024-03-29 18:55:17.672	debug	change event from ioBroker via [zigbee.0.00124b00291ff16f.temperature]{"val":-18.3,"ack":true,"ts":1711734748785,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734748785}
                yahka.0
                2024-03-29 18:55:17.672	debug	[Kühlschrank.CurrentTemperature] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.672	debug	[Kühlschrank.CurrentTemperature] got a set event, hkValue: 5.400000000000034
                yahka.0
                2024-03-29 18:55:17.672	debug	[Kühlschrank.CurrentTemperature] initializing homekit with value from ioBroker(5.39) to homekit as (5.39)
                yahka.0
                2024-03-29 18:55:17.672	debug	read state from ioBroker [zigbee.0.00124b002a65408c.temperature]: {"val":5.39,"ack":true,"ts":1711733644921,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711733644921}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.672	debug	[Kühlschrank.CurrentTemperature] forwarding value from ioBroker (5.39) to homekit as (5.39)
                yahka.0
                2024-03-29 18:55:17.672	debug	[Kühlschrank.CurrentTemperature] got a change notify event, ioValue: 5.39
                yahka.0
                2024-03-29 18:55:17.672	debug	change event from ioBroker via [zigbee.0.00124b002a65408c.temperature]{"val":5.39,"ack":true,"ts":1711733644921,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711733644921}
                yahka.0
                2024-03-29 18:55:17.672	debug	[Gästemodus.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.672	debug	[Gästemodus.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.672	debug	[Gästemodus.On] initializing homekit with value from ioBroker(false) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.671	debug	read state from ioBroker [javascript.0.Hilfsvariablen.Gast]: {"val":false,"ack":false,"ts":1704750103775,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1704750103775}
                yahka.0
                2024-03-29 18:55:17.671	debug	[Gästemodus.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.671	debug	[Gästemodus.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.671	debug	[Gästemodus.On] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.671	debug	[Gästemodus.On] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.671	debug	change event from ioBroker via [javascript.0.Hilfsvariablen.Gast]{"val":0,"ack":false,"ts":1704750103775,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1704750103775}
                yahka.0
                2024-03-29 18:55:17.671	debug	[Rolladen Büro West.TargetPosition] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.671	debug	[Rolladen Büro West.TargetPosition] got a set event, hkValue: 0
                yahka.0
                2024-03-29 18:55:17.671	debug	[Rolladen Büro West.TargetPosition] initializing homekit with value from ioBroker(0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.671	debug	read state from ioBroker [homepilot20.0.Actuator.1010013-36500572.Position_inverted]: {"val":0,"ack":false,"ts":1701067263265,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067263265}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.671	debug	[Rolladen Büro West.TargetPosition] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.TargetPosition] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.670	debug	change event from ioBroker via [homepilot20.0.Actuator.1010013-36500572.Position_inverted]{"val":0,"ack":false,"ts":1701067263265,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067263265}
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.PositionState] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.PositionState] got a set event, hkValue: 0
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.PositionState] initializing homekit with value from ioBroker(0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.670	debug	read state from ioBroker [homepilot20.0.Actuator.1010013-36500572.Position_inverted]: {"val":0,"ack":false,"ts":1701067263265,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067263265}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.PositionState] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.PositionState] got a change notify event, ioValue: 0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.CurrentPosition] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.CurrentPosition] got a set event, hkValue: 0
                yahka.0
                2024-03-29 18:55:17.670	debug	[Rolladen Büro West.CurrentPosition] initializing homekit with value from ioBroker(0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.669	debug	read state from ioBroker [homepilot20.0.Actuator.1010013-36500572.Position_inverted]: {"val":0,"ack":false,"ts":1701067263265,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067263265}
                yahka.0
                2024-03-29 18:55:17.669	debug	[Rolladen Büro West.CurrentPosition] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.669	debug	[Rolladen Büro West.CurrentPosition] got a set event, hkValue: 0
                yahka.0
                2024-03-29 18:55:17.669	debug	[Rolladen Büro West.CurrentPosition] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.669	debug	[Rolladen Büro West.CurrentPosition] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.669	debug	change event from ioBroker via [homepilot20.0.Actuator.1010013-36500572.Position_inverted]{"val":0,"ack":false,"ts":1701067263265,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067263265}
                yahka.0
                2024-03-29 18:55:17.669	debug	[.TargetPosition] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.669	debug	[.TargetPosition] got a set event, hkValue: 0
                yahka.0
                2024-03-29 18:55:17.669	debug	[.TargetPosition] initializing homekit with value from ioBroker(0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.669	debug	read state from ioBroker [homepilot20.0.Actuator.1010014-36500572.Position_inverted]: {"val":0,"ack":false,"ts":1701067264292,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067264292}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.668	debug	[.TargetPosition] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.668	debug	[.TargetPosition] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.668	debug	change event from ioBroker via [homepilot20.0.Actuator.1010014-36500572.Position_inverted]{"val":0,"ack":false,"ts":1701067264292,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067264292}
                yahka.0
                2024-03-29 18:55:17.668	debug	[.PositionState] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.668	debug	[.PositionState] got a set event, hkValue: 0
                yahka.0
                2024-03-29 18:55:17.668	debug	[.PositionState] initializing homekit with value from ioBroker(0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.668	debug	read state from ioBroker [homepilot20.0.Actuator.1010014-36500572.Position_inverted]: {"val":0,"ack":false,"ts":1701067264292,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067264292}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.668	debug	[.PositionState] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.668	debug	[.PositionState] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.667	debug	change event from ioBroker via [homepilot20.0.Actuator.1010014-36500572.Position_inverted]{"val":0,"ack":false,"ts":1701067264292,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067264292}
                yahka.0
                2024-03-29 18:55:17.667	debug	[.CurrentPosition] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.667	debug	[.CurrentPosition] got a set event, hkValue: 0
                yahka.0
                2024-03-29 18:55:17.667	debug	[.CurrentPosition] initializing homekit with value from ioBroker(0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.667	debug	read state from ioBroker [homepilot20.0.Actuator.1010014-36500572.Position_inverted]: {"val":0,"ack":false,"ts":1701067264292,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1701067264292}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.667	debug	[.CurrentPosition] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.667	debug	[.CurrentPosition] got a change notify event, ioValue: 0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.667	debug	[Hum Schuppen.CurrentRelativeHumidity] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.667	debug	[Hum Schuppen.CurrentRelativeHumidity] got a set event, hkValue: 65
                yahka.0
                2024-03-29 18:55:17.667	debug	[Hum Schuppen.CurrentRelativeHumidity] initializing homekit with value from ioBroker(65.13) to homekit as (65.13)
                yahka.0
                2024-03-29 18:55:17.666	debug	read state from ioBroker [zigbee.0.00124b0029100ce5.humidity]: {"val":65.13,"ack":true,"ts":1711734870409,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734870409}
                yahka.0
                2024-03-29 18:55:17.666	debug	[Hum Schuppen.CurrentRelativeHumidity] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.666	debug	[Hum Schuppen.CurrentRelativeHumidity] got a set event, hkValue: 65
                yahka.0
                2024-03-29 18:55:17.666	debug	[Hum Schuppen.CurrentRelativeHumidity] forwarding value from ioBroker (65.13) to homekit as (65.13)
                yahka.0
                2024-03-29 18:55:17.666	debug	[Hum Schuppen.CurrentRelativeHumidity] got a change notify event, ioValue: 65.13
                yahka.0
                2024-03-29 18:55:17.666	debug	change event from ioBroker via [zigbee.0.00124b0029100ce5.humidity]{"val":65.13,"ack":true,"ts":1711734870409,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734870409}
                yahka.0
                2024-03-29 18:55:17.666	debug	[Temp Schuppen.CurrentTemperature] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.666	debug	[Temp Schuppen.CurrentTemperature] got a set event, hkValue: 14
                yahka.0
                2024-03-29 18:55:17.666	debug	[Temp Schuppen.CurrentTemperature] initializing homekit with value from ioBroker(14.01) to homekit as (14.01)
                yahka.0
                2024-03-29 18:55:17.666	debug	read state from ioBroker [zigbee.0.00124b0029100ce5.temperature]: {"val":14.01,"ack":true,"ts":1711734840266,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734840266}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.666	debug	[Temp Schuppen.CurrentTemperature] forwarding value from ioBroker (14.01) to homekit as (14.01)
                yahka.0
                2024-03-29 18:55:17.665	debug	[Temp Schuppen.CurrentTemperature] got a change notify event, ioValue: 14.01
                yahka.0
                2024-03-29 18:55:17.665	debug	change event from ioBroker via [zigbee.0.00124b0029100ce5.temperature]{"val":14.01,"ack":true,"ts":1711734840266,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734840266}
                yahka.0
                2024-03-29 18:55:17.665	debug	[Hum WZ.CurrentRelativeHumidity] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.665	debug	[Hum WZ.CurrentRelativeHumidity] got a set event, hkValue: 38
                yahka.0
                2024-03-29 18:55:17.665	debug	[Hum WZ.CurrentRelativeHumidity] initializing homekit with value from ioBroker(37.76) to homekit as (37.76)
                yahka.0
                2024-03-29 18:55:17.665	debug	read state from ioBroker [zigbee.0.00158d000321f107.humidity]: {"val":37.76,"ack":true,"ts":1711734743706,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734743706}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.665	debug	[Hum WZ.CurrentRelativeHumidity] forwarding value from ioBroker (37.76) to homekit as (37.76)
                yahka.0
                2024-03-29 18:55:17.664	debug	[Hum WZ.CurrentRelativeHumidity] got a change notify event, ioValue: 37.76
                yahka.0
                2024-03-29 18:55:17.664	debug	change event from ioBroker via [zigbee.0.00158d000321f107.humidity]{"val":37.76,"ack":true,"ts":1711734743706,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734743706}
                yahka.0
                2024-03-29 18:55:17.664	debug	[Temp WZ.CurrentTemperature] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.664	debug	[Temp WZ.CurrentTemperature] got a set event, hkValue: 22.100000000000023
                yahka.0
                2024-03-29 18:55:17.664	debug	[Temp WZ.CurrentTemperature] initializing homekit with value from ioBroker(22.05) to homekit as (22.05)
                yahka.0
                2024-03-29 18:55:17.664	debug	read state from ioBroker [zigbee.0.00158d000321f107.temperature]: {"val":22.05,"ack":true,"ts":1711734743706,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734743706}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.664	debug	[Temp WZ.CurrentTemperature] forwarding value from ioBroker (22.05) to homekit as (22.05)
                yahka.0
                2024-03-29 18:55:17.664	debug	[Temp WZ.CurrentTemperature] got a change notify event, ioValue: 22.05
                yahka.0
                2024-03-29 18:55:17.664	debug	change event from ioBroker via [zigbee.0.00158d000321f107.temperature]{"val":22.05,"ack":true,"ts":1711734743706,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1711734743706}
                yahka.0
                2024-03-29 18:55:17.663	debug	[Gehflügel Dauerauf.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.663	debug	[Gehflügel Dauerauf.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.663	debug	[Gehflügel Dauerauf.On] initializing homekit with value from ioBroker(false) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.663	debug	read state from ioBroker [hm-rpc.0.001998A997F629.8.STATE]: {"val":false,"ack":true,"ts":1711731383232,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1711692904702}
                yahka.0
                2024-03-29 18:55:17.635	debug	[Gehflügel Dauerauf.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.635	debug	[Gehflügel Dauerauf.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.635	debug	[Gehflügel Dauerauf.On] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.635	debug	[Gehflügel Dauerauf.On] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.634	debug	change event from ioBroker via [hm-rpc.0.001998A997F629.8.STATE]{"val":0,"ack":true,"ts":1711731383232,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1711692904702}
                yahka.0
                2024-03-29 18:55:17.632	debug	[Tor Dauerauf.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.632	debug	[Tor Dauerauf.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.632	debug	[Tor Dauerauf.On] initializing homekit with value from ioBroker(false) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.632	debug	read state from ioBroker [hm-rpc.0.001998A997F629.4.STATE]: {"val":false,"ack":true,"ts":1711731383187,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1710499135575}
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.632	debug	[Tor Dauerauf.On] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.632	debug	[Tor Dauerauf.On] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.632	debug	change event from ioBroker via [hm-rpc.0.001998A997F629.4.STATE]{"val":0,"ack":true,"ts":1711731383187,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1710499135575}
                yahka.0
                2024-03-29 18:55:17.632	debug	[Aussenbeleuchtung.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.632	debug	[Aussenbeleuchtung.On] got a set event, hkValue: true
                yahka.0
                2024-03-29 18:55:17.632	debug	[Aussenbeleuchtung.On] initializing homekit with value from ioBroker(true) to homekit as (1)
                yahka.0
                2024-03-29 18:55:17.631	debug	read state from ioBroker [sonoff.0.DVES_520040.POWER]: {"val":true,"ack":true,"ts":1711734786719,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1711733863996}
                yahka.0
                2024-03-29 18:55:17.631	debug	[Aussenbeleuchtung.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.631	debug	[Aussenbeleuchtung.On] got a set event, hkValue: true
                yahka.0
                2024-03-29 18:55:17.631	debug	[Aussenbeleuchtung.On] forwarding value from ioBroker (1) to homekit as (1)
                yahka.0
                2024-03-29 18:55:17.631	debug	[Aussenbeleuchtung.On] got a change notify event, ioValue: 1
                yahka.0
                2024-03-29 18:55:17.631	debug	change event from ioBroker via [sonoff.0.DVES_520040.POWER]{"val":1,"ack":true,"ts":1711734786719,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1711733863996}
                yahka.0
                2024-03-29 18:55:17.631	debug	[Tor.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.631	debug	[Tor.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.631	debug	[Tor.On] initializing homekit with value from ioBroker(false) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.631	debug	read state from ioBroker [javascript.0.Hilfsvariablen.TasterTor]: {"val":false,"ack":false,"ts":1710499135577,"q":0,"c":"script.js.common.Auslösung_Gehflügel","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710499135577}
                yahka.0
                2024-03-29 18:55:17.630	debug	[Tor.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.630	debug	[Tor.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.630	debug	[Tor.On] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.630	debug	[Tor.On] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.630	debug	change event from ioBroker via [javascript.0.Hilfsvariablen.TasterTor]{"val":0,"ack":false,"ts":1710499135577,"q":0,"c":"script.js.common.Auslösung_Gehflügel","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710499135577}
                yahka.0
                2024-03-29 18:55:17.630	debug	[Gehflügel.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.630	debug	[Gehflügel.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.630	debug	[Gehflügel.On] initializing homekit with value from ioBroker(false) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.630	debug	read state from ioBroker [javascript.0.Hilfsvariablen.TasterGehflügel]: {"val":false,"ack":false,"ts":1711692904703,"q":0,"c":"script.js.common.Auslösung_Gehflügel","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711692904703}
                yahka.0
                2024-03-29 18:55:17.629	debug	[Gehflügel.On] set was initiated from ioBroker - exiting here
                yahka.0
                2024-03-29 18:55:17.629	debug	[Gehflügel.On] got a set event, hkValue: false
                yahka.0
                2024-03-29 18:55:17.629	debug	[Gehflügel.On] forwarding value from ioBroker (0) to homekit as (0)
                yahka.0
                2024-03-29 18:55:17.629	debug	[Gehflügel.On] got a change notify event, ioValue: 0
                yahka.0
                2024-03-29 18:55:17.629	debug	change event from ioBroker via [javascript.0.Hilfsvariablen.TasterGehflügel]{"val":0,"ack":false,"ts":1711692904703,"q":0,"c":"script.js.common.Auslösung_Gehflügel","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711692904703}
                yahka.0
                2024-03-29 18:55:17.598	info	publishing bridge HomekitServer on 0.0.0.0 using avahi
                yahka.0
                2024-03-29 18:55:17.598	debug	reading state from ioBroker [zigbee.0.00124b00291ff16f.temperature]
                yahka.0
                2024-03-29 18:55:17.598	debug	added subscription for: [state]zigbee.0.00124b00291ff16f.temperature
                yahka.0
                2024-03-29 18:55:17.598	debug	[Temp Gefrierschrank] adding Service Gefrierschrank
                yahka.0
                2024-03-29 18:55:17.598	info	adding Temp Gefrierschrank with UUID: 2e94157d-ebfe-4fd1-873a-aa40d0d5af9b
                yahka.0
                2024-03-29 18:55:17.598	debug	[Confirm_Temp_Alarm] adding Service Confirm_Temp_Alarm
                yahka.0
                2024-03-29 18:55:17.597	info	adding Confirm_Temp_Alarm with UUID: 26f2996d-f9ef-41f4-97f5-e1aee0bc225d
                yahka.0
                2024-03-29 18:55:17.597	debug	reading state from ioBroker [zigbee.0.00124b002a65408c.temperature]
                yahka.0
                2024-03-29 18:55:17.597	debug	added subscription for: [state]zigbee.0.00124b002a65408c.temperature
                yahka.0
                2024-03-29 18:55:17.597	debug	[Temp Kühlschrank] adding Service Kühlschrank
                yahka.0
                2024-03-29 18:55:17.597	info	adding Temp Kühlschrank with UUID: 924e4c1b-86dc-42ff-9ada-3d4e15b7caf3
                yahka.0
                2024-03-29 18:55:17.596	debug	reading state from ioBroker [javascript.0.Hilfsvariablen.Gast]
                yahka.0
                2024-03-29 18:55:17.596	debug	added subscription for: [state]javascript.0.Hilfsvariablen.Gast
                yahka.0
                2024-03-29 18:55:17.596	debug	[Gästemodus] adding Service Gästemodus
                yahka.0
                2024-03-29 18:55:17.596	info	adding Gästemodus with UUID: c0048ffd-fc6f-40f3-8be8-6fda96846af2
                yahka.0
                2024-03-29 18:55:17.596	debug	reading state from ioBroker [homepilot20.0.Actuator.1010013-36500572.Position_inverted]
                yahka.0
                2024-03-29 18:55:17.596	debug	added subscription for: [state]homepilot20.0.Actuator.1010013-36500572.Position_inverted
                yahka.0
                yahka.0
                yahka.0
                yahka.0
                2024-03-29 18:55:17.595	debug	added subscription for: [state]homepilot20.0.Actuator.1010013-36500572.Position_inverted
                yahka.0
                2024-03-29 18:55:17.595	debug	[Rolladen Büro West] adding Service Rolladen Büro West
                yahka.0
                2024-03-29 18:55:17.595	info	adding Rolladen Büro West with UUID: 3613a5ce-bd62-4442-b028-0f2e09101973
                yahka.0
                2024-03-29 18:55:17.595	debug	reading state from ioBroker [homepilot20.0.Actuator.1010014-36500572.Position_inverted]
                yahka.0
                2024-03-29 18:55:17.595	debug	added subscription for: [state]homepilot20.0.Actuator.1010014-36500572.Position_inverted
                yahka.0
                yahka.0
                2024-03-29 18:55:17.594	debug	added subscription for: [state]homepilot20.0.Actuator.1010014-36500572.Position_inverted
                yahka.0
                2024-03-29 18:55:17.594	debug	reading state from ioBroker [homepilot20.0.Actuator.1010014-36500572.Position_inverted]
                yahka.0
                yahka.0
                2024-03-29 18:55:17.593	debug	[Rolladen Büro Nord] adding Service
                yahka.0
                2024-03-29 18:55:17.593	info	adding Rolladen Büro Nord with UUID: 7f3a94e4-3eef-41e0-88f2-06020ea992ac
                yahka.0
                2024-03-29 18:55:17.593	debug	reading state from ioBroker [zigbee.0.00124b0029100ce5.humidity]
                yahka.0
                2024-03-29 18:55:17.592	debug	added subscription for: [state]zigbee.0.00124b0029100ce5.humidity
                yahka.0
                2024-03-29 18:55:17.592	debug	[Temp Schuppen] adding Service Hum Schuppen
                yahka.0
                2024-03-29 18:55:17.592	debug	reading state from ioBroker [zigbee.0.00124b0029100ce5.temperature]
                yahka.0
                2024-03-29 18:55:17.592	debug	added subscription for: [state]zigbee.0.00124b0029100ce5.temperature
                yahka.0
                2024-03-29 18:55:17.592	debug	[Temp Schuppen] adding Service Temp Schuppen
                yahka.0
                2024-03-29 18:55:17.591	info	adding Temp Schuppen with UUID: da4c264e-9360-4555-af99-43992b31b92e
                yahka.0
                2024-03-29 18:55:17.591	debug	reading state from ioBroker [zigbee.0.00158d000321f107.humidity]
                yahka.0
                2024-03-29 18:55:17.591	debug	added subscription for: [state]zigbee.0.00158d000321f107.humidity
                yahka.0
                2024-03-29 18:55:17.591	debug	[Temp WZ] adding Service Hum WZ
                yahka.0
                2024-03-29 18:55:17.591	debug	reading state from ioBroker [zigbee.0.00158d000321f107.temperature]
                yahka.0
                2024-03-29 18:55:17.591	debug	added subscription for: [state]zigbee.0.00158d000321f107.temperature
                yahka.0
                2024-03-29 18:55:17.590	debug	[Temp WZ] adding Service Temp WZ
                yahka.0
                2024-03-29 18:55:17.590	info	adding Temp WZ with UUID: 74a471f0-f6c7-43c9-b720-558bca44cc62
                yahka.0
                2024-03-29 18:55:17.589	debug	reading state from ioBroker [hm-rpc.0.001998A997F629.8.STATE]
                yahka.0
                2024-03-29 18:55:17.589	debug	added subscription for: [state]hm-rpc.0.001998A997F629.8.STATE
                yahka.0
                2024-03-29 18:55:17.589	debug	[Gehflügel Dauerauf] adding Service Gehflügel Dauerauf
                yahka.0
                2024-03-29 18:55:17.589	info	adding Gehflügel Dauerauf with UUID: 80caac62-f569-417d-acdc-e36079e404a9
                yahka.0
                2024-03-29 18:55:17.589	debug	reading state from ioBroker [hm-rpc.0.001998A997F629.4.STATE]
                yahka.0
                2024-03-29 18:55:17.588	debug	added subscription for: [state]hm-rpc.0.001998A997F629.4.STATE
                yahka.0
                2024-03-29 18:55:17.588	debug	[Tor Dauerauf] adding Service Tor Dauerauf
                yahka.0
                2024-03-29 18:55:17.588	info	adding Tor Dauerauf with UUID: 83768b4f-952b-4837-b8d0-87d41afe10ff
                yahka.0
                2024-03-29 18:55:17.588	debug	reading state from ioBroker [sonoff.0.DVES_520040.POWER]
                yahka.0
                2024-03-29 18:55:17.588	debug	added subscription for: [state]sonoff.0.DVES_520040.POWER
                yahka.0
                2024-03-29 18:55:17.587	debug	[Aussenbeleuchtung] adding Service Aussenbeleuchtung
                yahka.0
                2024-03-29 18:55:17.586	info	adding Aussenbeleuchtung with UUID: 6d6a8420-f10d-42c8-b307-fdd48577e716
                yahka.0
                2024-03-29 18:55:17.586	debug	reading state from ioBroker [javascript.0.Hilfsvariablen.TasterTor]
                yahka.0
                2024-03-29 18:55:17.586	debug	added subscription for: [state]javascript.0.Hilfsvariablen.TasterTor
                yahka.0
                2024-03-29 18:55:17.586	debug	[Tor] adding Service Tor
                yahka.0
                2024-03-29 18:55:17.585	info	adding Tor with UUID: 1b42b214-6c5b-4e63-a95d-170c521f2995
                yahka.0
                2024-03-29 18:55:17.585	debug	reading state from ioBroker [javascript.0.Hilfsvariablen.TasterGehflügel]
                yahka.0
                2024-03-29 18:55:17.584	debug	added subscription for: [state]javascript.0.Hilfsvariablen.TasterGehflügel
                yahka.0
                2024-03-29 18:55:17.582	debug	[Gehflügel] adding Service Gehflügel
                yahka.0
                2024-03-29 18:55:17.581	info	adding Gehflügel with UUID: 6d115b43-d9b8-49e8-9a41-561cf74a173e
                yahka.0
                2024-03-29 18:55:17.577	debug	creating bridge
                yahka.0
                2024-03-29 18:55:17.576	info	adapter ready, checking config
                yahka.0
                2024-03-29 18:55:17.568	info	starting. Version 1.0.3 (non-npm: jensweigele/ioBroker.yahka) in /opt/iobroker/node_modules/iobroker.yahka, node: v18.19.1, js-controller: 5.0.19
                yahka.0
                2024-03-29 18:55:14.080	info	terminating
                yahka.0
                2024-03-29 18:55:13.578	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                yahka.0
                2024-03-29 18:55:13.578	info	terminating
                yahka.0
                2024-03-29 18:55:13.577	info	cleaned up ...
                yahka.0
                2024-03-29 18:55:13.577	info	cleaning up ...
                yahka.0
                2024-03-29 18:55:13.575	info	Got terminate signal TERMINATE_YOURSELF
                  Thomas Braun Most Active @f0rd42 last edited by
                  @f0rd42 sagte in Yahka nach Stromausfall nicht mehr einbindbar:
                  Räum die Datei auf. Und kümmer dich um die Schlüssel. Updates einspielen...
                  F 3 Replies Last reply Reply Quote 0
                    f0rd42 @Thomas Braun last edited by
                    @thomas-braun Mach ich gerne. Kannst Du mir sagen, was genau du mit "Schlüssel" meinst und wie das mit Yahka zusammenhängen könnte?
                      @thomas-braun sagte in Yahka nach Stromausfall nicht mehr einbindbar:
                      so, habe ich gemacht und alle updates eingespielt.
                      Problem ist aber immer noch das Gleiche.
                        Ich "glaube" ich komme der Sache näher.
                        Wenn ich auf meinem Mac Client das Discovery laufen lasse, sehe ich Yahka, aber nur über IPv6 und nicht über IPv4 wie alle anderen Services.
                        Homebridge, was derzeit zum testen ebenfalls auf dem gleichen Server läuft, zeigt sich auch nur per IPv6.
                        ein ping s01.local geht also nicht, ping6 s01.local funktioniert.
                        ein schneller ahavi daemon check auf s01 zeigt:
                        adieball@s01:~$ sudo systemctl status avahi-daemon.service
                        ● avahi-daemon.service - Avahi mDNS/DNS-SD Stack
                             Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled; vendor preset: enabled)
                             Active: active (running) since Sat 2024-03-30 10:02:20 CET; 11min ago
                        TriggeredBy: ○ avahi-daemon.socket
                           Main PID: 3600 (avahi-daemon)
                             Status: "avahi-daemon 0.8 starting up."
                              Tasks: 2 (limit: 18917)
                             Memory: 1.3M
                                CPU: 1.008s
                             CGroup: /system.slice/avahi-daemon.service
                                     ├─3600 "avahi-daemon: running [s01.local]"
                                     └─3601 "avahi-daemon: chroot helper"
                        Mar 30 10:02:20 s01 avahi-daemon[3600]: Joining mDNS multicast group on interface enp0s31f6.IPv4 with address 192.168.119.121.
                        Mar 30 10:02:20 s01 avahi-daemon[3600]: New relevant interface enp0s31f6.IPv4 for mDNS.
                        Mar 30 10:02:20 s01 avahi-daemon[3600]: Network interface enumeration completed.
                        Mar 30 10:02:20 s01 avahi-daemon[3600]: Registering new address record for fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770 on enp0s31f6.*.
                        Mar 30 10:02:20 s01 avahi-daemon[3600]: Registering new address record for 192.168.119.121 on enp0s31f6.IPv4.
                        Mar 30 10:02:21 s01 avahi-daemon[3600]: Server startup complete. Host name is s01.local. Local service cookie is 1032175040.
                        Mar 30 10:02:41 s01 avahi-daemon[3600]: Files changed, reloading.
                        Mar 30 10:02:41 s01 avahi-daemon[3600]: No service file found in /etc/avahi/services.
                        Mar 30 10:02:50 s01 avahi-daemon[3600]: Files changed, reloading.
                        Mar 30 10:02:50 s01 avahi-daemon[3600]: No service file found in /etc/avahi/services.
                        adieball@s01:~$
                        Avahi registriert sich also sehr wohl auch auf IPv4.
                        Avahi Browse auf s01 zeigt:
                        adieball@s01:~$ avahi-browse -v _hap._tcp
                        Server version: avahi 0.8; Host name: s01.local
                        E Ifce Prot Name                                          Type                 Domain
                        + enp0s31f6 IPv6 HomekitServer FAA3                            _hap._tcp            local
                        + enp0s31f6 IPv6 HomePodSensor 381340                          _hap._tcp            local
                        + enp0s31f6 IPv6 HomePodSensor 418146                          _hap._tcp            local
                        + enp0s31f6 IPv6 HomePodSensor 969802                          _hap._tcp            local
                        + enp0s31f6 IPv6 HomePodSensor 870291                          _hap._tcp            local
                        + enp0s31f6 IPv6 HomePodSensor 627075                          _hap._tcp            local
                        + enp0s31f6 IPv6 Philips Hue HomeKit                           _hap._tcp            local
                        + enp0s31f6 IPv6 Basestation 5GP18C7TA13E6                     _hap._tcp            local
                        + enp0s31f6 IPv4 Basestation 5GP18C7TA13E6                     _hap._tcp            local
                        + enp0s31f6 IPv4 HomekitServer FAA3                            _hap._tcp            local
                        + enp0s31f6 IPv4 HomePodSensor 627075                          _hap._tcp            local
                        + enp0s31f6 IPv4 Homebridge 42AF 5A20                          _hap._tcp            local
                        : Cache exhausted
                        : All for now
                        ^CGot SIGINT, quitting.
                        auf dem host selbst ist avahi also über ipv4 und ipv6 sichtbar.
                        Mein Mac (per WLAN) und mein iphone sind im gleichen Netz und erhalten auch beide eine IPv4 und eine IPv6.
                        Yahka ist auf dem Mac mit dem Discovery Tool ja auch sichtbar (siehe bild oben) und wenn cih auf dem iphone in Home ein neues Gerät hinzufügen will zeigt er Yahka ja auch als gefunden an, will ihn nur nicht hinzufügen.
                          f0rd42 @f0rd42 last edited by
                          Weitere Infos:
                          ein nmap bringt mir das hier, alles ok, verstehe nur nichts, warum "filtered"
                          adieball@s01:~$ sudo nmap -sU localhost
                          Starting Nmap 7.80 ( https://nmap.org ) at 2024-03-30 11:37 CET
                          Nmap scan report for localhost (127.0.0.1)
                          Host is up (0.000016s latency).
                          Not shown: 997 closed ports
                          PORT      STATE         SERVICE
                          111/udp   open          rpcbind
                          5353/udp  open|filtered zeroconf
                          10000/udp open          ndmp
                          Nmap done: 1 IP address (1 host up) scanned in 1.29 seconds
                          adieball@s01:~$
                          ein tcpdump auf Port 5353 während ich versuche Yahka zum Home hinzuzufügen zeigt interessanterweise gar nichts in diese Richtung
                          adieball@s01:~$ sudo tcpdump port 5353
                          tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
                          listening on enp0s31f6, link-type EN10MB (Ethernet), snapshot length 262144 bytes
                          11:37:55.906850 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0*- [0q] 7/0/0 PTR Homebridge 42AF 5A20._hap._tcp.local., (Cache flush) SRV 0E_A8_E9_26_6D_91.local.:51523 0 0, (Cache flush) TXT "c#=4" "ff=0" "id=0E:A8:E9:26:6D:91" "md=homebridge" "pv=1.1" "s#=1" "sf=1" "ci=2" "sh=ChwIcQ==", (Cache flush) A 192.168.119.121, (Cache flush) AAAA fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770, (Cache flush) AAAA fe80::6e4b:90ff:fe1c:8770, PTR _hap._tcp.local. (481)
                          11:37:58.909489 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0*- [0q] 7/0/0 PTR Homebridge 42AF 5A20._hap._tcp.local., (Cache flush) SRV 0E_A8_E9_26_6D_91.local.:51523 0 0, (Cache flush) TXT "c#=4" "ff=0" "id=0E:A8:E9:26:6D:91" "md=homebridge" "pv=1.1" "s#=1" "sf=1" "ci=2" "sh=ChwIcQ==", (Cache flush) A 192.168.119.121, (Cache flush) AAAA fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770, (Cache flush) AAAA fe80::6e4b:90ff:fe1c:8770, PTR _hap._tcp.local. (481)
                          11:38:01.912995 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0*- [0q] 7/0/0 PTR Homebridge 42AF 5A20._hap._tcp.local., (Cache flush) SRV 0E_A8_E9_26_6D_91.local.:51523 0 0, (Cache flush) TXT "c#=4" "ff=0" "id=0E:A8:E9:26:6D:91" "md=homebridge" "pv=1.1" "s#=1" "sf=1" "ci=2" "sh=ChwIcQ==", (Cache flush) A 192.168.119.121, (Cache flush) AAAA fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770, (Cache flush) AAAA fe80::6e4b:90ff:fe1c:8770, PTR _hap._tcp.local. (481)
                          11:38:02.540117 IP6 fe80::8c8:eb68:c6bd:50c7.mdns > ff02::fb.mdns: 0 [23q] PTR (QM)? lb._dns-sd._udp.f0rd42.local. TXT (QM)? BM-CM-<ro._srpl-tls._tcp.local. SRV (QM)? BM-CM-<ro._srpl-tls._tcp.local. AAAA (QM)? Buro.local. A (QM)? Buro.local. TXT (QM)? Wohnzimmer (3)._srpl-tls._tcp.local. SRV (QM)? Wohnzimmer (3)._srpl-tls._tcp.local. AAAA (QM)? Wohnzimmer-3.local. A (QM)? Wohnzimmer-3.local. TXT (QM)? Schlafzimmer._srpl-tls._tcp.local. SRV (QM)? Schlafzimmer._srpl-tls._tcp.local. AAAA (QM)? Schlafzimmer.local. A (QM)? Schlafzimmer.local. SRV (QM)? Ankleidezimmer._srpl-tls._tcp.local. AAAA (QM)? Ankleidezimmer.openthread.thread.home.arpa. A (QM)? Ankleidezimmer.openthread.thread.home.arpa. TXT (QM)? GM-CM-$ste WC._srpl-tls._tcp.local. SRV (QM)? GM-CM-$ste WC._srpl-tls._tcp.local. TXT (QM)? Ankleidezimmer._srpl-tls._tcp.local. AAAA (QM)? Ankleidezimmer.local. TXT (QM)? Badezimmer._srpl-tls._tcp.local. SRV (QM)? Badezimmer._srpl-tls._tcp.local. AAAA (QM)? Badezimmer.local. (362)
                          11:38:02.579863 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 1/0/0 (Cache flush) AAAA fdd6:e4c8:2592:da48:5a4c:1867:ea9a:e000 (60)
                          11:38:02.632264 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 1/0/0 (Cache flush) AAAA fdd6:e4c8:2592:da48:980a:4da0:220b:729 (60)
                          11:38:02.639708 IP6 Wohnzimmer-3.local.mdns > ff02::fb.mdns: 0*- [0q] 6/0/2 (Cache flush) AAAA fe80::1cc2:f979:4ea0:d5b9, (Cache flush) TXT "dn=openthread.thread.home.arpa." "pid=5b02ab422aaeb8f5" "did=4841ea0f85732d3b" "xpanid=d6e4c82592da4895", (Cache flush) SRV Wohnzimmer-3.local.:853 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:2:fd24:8eaf:5df0, (Cache flush) AAAA fdd6:e4c8:2592:da48:1c53:5347:9119:20ce, (Cache flush) A 192.168.119.194 (331)
                          11:38:02.645607 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 1/0/0 (Cache flush) AAAA fe80::7bff:8bd8:b72:e4fa (58)
                          11:38:02.663718 IP6 fe80::8c8:eb68:c6bd:50c7.mdns > ff02::fb.mdns: 0*- [0q] 5/0/3 (Cache flush) AAAA fe80::8c8:eb68:c6bd:50c7, (Cache flush) AAAA fdd6:e4c8:2592:da48:4b6:3cf:1560:d34e, (Cache flush) TXT "dn=openthread.thread.home.arpa." "pid=a508352c68cc1c03" "did=4841ea0f85732d3b" "xpanid=d6e4c82592da4895", (Cache flush) SRV Ankleidezimmer.local.:853 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:2:fd08:4c74:50ab (333)
                          11:38:02.720249 IP6 fe80::1c79:159e:d2ab:2f47.mdns > ff02::fb.mdns: 0*- [0q] 5/0/3 (Cache flush) AAAA fe80::1c79:159e:d2ab:2f47, (Cache flush) TXT "dn=openthread.thread.home.arpa." "pid=30b48af2c4bfd166" "did=4841ea0f85732d3b" "xpanid=d6e4c82592da4895", (Cache flush) SRV Badezimmer.local.:853 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:8e1:bc11:7cf3:5f2f, (Cache flush) AAAA fdd6:e4c8:2592:da48:7:fd42:e08a:f41e (325)
                          11:38:02.728076 IP6 fe80::8c6:4467:9d95:562d.mdns > ff02::fb.mdns: 0*- [0q] 2/0/6 (Cache flush) TXT "dn=openthread.thread.home.arpa." "pid=26a431ab4c6a96ad" "did=4841ea0f85732d3b" "xpanid=d6e4c82592da4895", (Cache flush) SRV Gaste-WC.local.:853 0 0 (322)
                          11:38:02.785901 IP6 fe80::62:974c:5350:2efa.mdns > ff02::fb.mdns: 0*- [0q] 6/0/2 (Cache flush) TXT "dn=openthread.thread.home.arpa." "pid=85fc681eb145852a" "did=4841ea0f85732d3b" "xpanid=d6e4c82592da4895", (Cache flush) SRV Buro.local.:853 0 0, (Cache flush) AAAA fe80::62:974c:5350:2efa, (Cache flush) A 192.168.119.201, (Cache flush) AAAA fdd6:e4c8:2592:da48:1c35:a07e:349c:bf60, (Cache flush) AAAA fdd6:e4c8:2592:da48:2:fd70:82d:d8e4 (314)
                          11:38:02.816053 IP6 fe80::477:f7d9:c921:b393.mdns > ff02::fb.mdns: 0 [11q] PTR (QU)? _hap._tcp.local. PTR (QU)? _hap._udp.local. PTR (QU)? _matter._tcp.local. PTR (QU)? _rdlink._tcp.local. PTR (QU)? _companion-link._tcp.local. PTR (QU)? _airplay-bds._tcp.local. PTR (QU)? _airplay._tcp.local. PTR (QU)? _airplay._tcp.local. PTR (QU)? _raop._tcp.local. PTR (QU)? _raop._tcp.local. PTR (QU)? _sleep-proxy._udp.local. (176)
                          11:38:02.843429 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 4/0/0 PTR 800a805cbdd8@DMP-A6._raop._tcp.local., (Cache flush) SRV DMP-A6-jmdns.local.:5500 0 0, (Cache flush) TXT "ss=16" "sv=false" "ch=2" "ek=1" "pw=false" "cn=1" "am=eversolo,1" "et=0,1" "fv=1.0" "txtvers=1" "sf=0x4" "md=0,1,2" "vn=65537" "tp=UDP" "vs=105.1" "da=true" "sr=44100", (Cache flush) AAAA fe80::7bff:8bd8:b72:e4fa (270)
                          11:38:02.880654 IP6 s01.mdns > ff02::fb.mdns: 0*- [0q] 4/0/0 PTR HomekitServer FAA3._hap._tcp.local., (Cache flush) TXT "c#=2" "ff=0" "id=6a:4b:91:1c:87:87" "md=iobroker" "pv=1.1" "s#=1" "sf=1" "ci=2" "sh=9gS7og==", (Cache flush) SRV s01.local.:39099 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770 (201)
                          11:38:02.892326 IP6 OpenWrt.local.mdns > ff02::fb.mdns: 0*- [0q] 5/0/0 PTR Basestation 5GP18C7TA13E6._hap._tcp.local., (Cache flush) TXT "c#=30" "ff=2" "id=D3:88:8C:35:DB:49" "md=VMB5000" "pv=1.1" "s#=415" "sf=0" "ci=2" "sh=bP0whA==", (Cache flush) SRV OpenWrt.local.:32813 0 0, (Cache flush) AAAA fe80::3e37:86ff:fe59:a005, (Cache flush) A 192.168.119.176 (230)
                          11:38:02.894341 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 4/0/0 PTR 800a805cbdd8@DMP-A6 (3)._raop._tcp.local., (Cache flush) SRV DMP-A6-jmdns-3.local.:5500 0 0, (Cache flush) TXT "ss=16" "sv=false" "ch=2" "ek=1" "pw=false" "cn=1" "am=eversolo,1" "et=0,1" "fv=1.0" "txtvers=1" "sf=0x4" "md=0,1,2" "vn=65537" "tp=UDP" "vs=105.1" "da=true" "sr=44100", (Cache flush) AAAA fdd6:e4c8:2592:da48:980a:4da0:220b:729 (276)
                          11:38:02.898979 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 4/0/0 PTR 800a805cbdd8@DMP-A6 (4)._raop._tcp.local., (Cache flush) TXT "ss=16" "sv=false" "ch=2" "ek=1" "pw=false" "cn=1" "am=eversolo,1" "et=0,1" "fv=1.0" "txtvers=1" "sf=0x4" "md=0,1,2" "vn=65537" "tp=UDP" "vs=105.1" "da=true" "sr=44100", (Cache flush) SRV DMP-A6-jmdns-2.local.:5500 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:5a4c:1867:ea9a:e000 (276)
                          11:38:02.972709 IP Schlafzimmer.f0rd42.local.mdns > mdns.mcast.net.mdns: 0*- [0q] 6/0/2 (Cache flush) AAAA fe80::105c:c34c:3b15:27d5, (Cache flush) A 192.168.119.175, (Cache flush) AAAA fdd6:e4c8:2592:da48:1cdb:dcb2:b151:4a1f, (Cache flush) TXT "dn=openthread.thread.home.arpa." "pid=f759b78f5e7127" "did=4841ea0f85732d3b" "xpanid=d6e4c82592da4895", (Cache flush) SRV Schlafzimmer.local.:853 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:2:fd91:fc47:69e6 (327)
                          11:38:02.972710 IP6 Schlafzimmer.local.mdns > ff02::fb.mdns: 0*- [0q] 6/0/2 (Cache flush) AAAA fe80::105c:c34c:3b15:27d5, (Cache flush) A 192.168.119.175, (Cache flush) AAAA fdd6:e4c8:2592:da48:1cdb:dcb2:b151:4a1f, (Cache flush) TXT "dn=openthread.thread.home.arpa." "pid=f759b78f5e7127" "did=4841ea0f85732d3b" "xpanid=d6e4c82592da4895", (Cache flush) SRV Schlafzimmer.local.:853 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:2:fd91:fc47:69e6 (327)
                          11:38:03.190233 IP6 fe80::8c8:eb68:c6bd:50c7.mdns > ff02::fb.mdns: 0*- [0q] 3/0/1 (Cache flush) AAAA fe80::8c8:eb68:c6bd:50c7, (Cache flush) AAAA fdd6:e4c8:2592:da48:4b6:3cf:1560:d34e, (Cache flush) AAAA fdd6:e4c8:2592:da48:2:fd08:4c74:50ab (136)
                          11:38:03.579902 IP6 fe80::367e:5cff:fef1:4d22.mdns > ff02::fb.mdns: 0*- [0q] 1/0/5 (Cache flush) SRV Sonos-347E5CF14D22.local.:7000 0 0 (206)
                          11:38:03.953480 IP6 fe80::477:f7d9:c921:b393.mdns > ff02::fb.mdns: 0 [5a] [10q] PTR (QM)? _hap._tcp.local. PTR (QM)? _hap._udp.local. PTR (QM)? _matter._tcp.local. PTR (QM)? _rdlink._tcp.local. PTR (QM)? _companion-link._tcp.local. PTR (QM)? _airplay-bds._tcp.local. PTR (QM)? _airplay._tcp.local. PTR (QM)? _airplay._tcp.local. PTR (QM)? _raop._tcp.local. PTR (QM)? _sleep-proxy._udp.local. (353)
                          11:38:04.026149 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 3/0/0 (Cache flush) SRV DMP-A6-jmdns-3.local.:5500 0 0, (Cache flush) TXT "ss=16" "sv=false" "ch=2" "ek=1" "pw=false" "cn=1" "am=eversolo,1" "et=0,1" "fv=1.0" "txtvers=1" "sf=0x4" "md=0,1,2" "vn=65537" "tp=UDP" "vs=105.1" "da=true" "sr=44100", (Cache flush) AAAA fdd6:e4c8:2592:da48:980a:4da0:220b:729 (262)
                          11:38:22.734619 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? a.f.4.e.2.7.b.0.8.d.b.8.f.f.b.7.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:38:22.740769 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 1/0/1 (Cache flush) PTR Android-2.local. (131)
                          11:38:22.926684 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0*- [0q] 7/0/0 PTR Homebridge 42AF 5A20._hap._tcp.local., (Cache flush) SRV 0E_A8_E9_26_6D_91.local.:51523 0 0, (Cache flush) TXT "c#=4" "ff=0" "id=0E:A8:E9:26:6D:91" "md=homebridge" "pv=1.1" "s#=1" "sf=1" "ci=2" "sh=ChwIcQ==", (Cache flush) A 192.168.119.121, (Cache flush) AAAA fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770, (Cache flush) AAAA fe80::6e4b:90ff:fe1c:8770, PTR _hap._tcp.local. (481)
                          11:38:22.985366 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? 7.4.f.2.b.a.2.d.e.9.5.1.9.7.c.1.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:38:42.982649 IP6 fe80::477:f7d9:c921:b393.mdns > ff02::fb.mdns: 0 [34a] [9q] PTR (QM)? _hap._udp.local. PTR (QM)? _matter._tcp.local. PTR (QM)? _rdlink._tcp.local. PTR (QM)? _companion-link._tcp.local. PTR (QM)? _airplay-bds._tcp.local. PTR (QM)? _airplay._tcp.local. PTR (QM)? _raop._tcp.local. PTR (QM)? _matterc._udp.local. A (QM)? s01.local. (1227)
                          11:38:42.982650 IP6 fe80::477:f7d9:c921:b393.mdns > ff02::fb.mdns: 0 [7a] PTR (QM)? _sleep-proxy._udp.local. (318)
                          11:38:43.048596 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 3/0/0 (Cache flush) SRV DMP-A6-jmdns-3.local.:5500 0 0, (Cache flush) TXT "ss=16" "sv=false" "ch=2" "ek=1" "pw=false" "cn=1" "am=eversolo,1" "et=0,1" "fv=1.0" "txtvers=1" "sf=0x4" "md=0,1,2" "vn=65537" "tp=UDP" "vs=105.1" "da=true" "sr=44100", (Cache flush) AAAA fdd6:e4c8:2592:da48:980a:4da0:220b:729 (262)
                          11:38:43.050168 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? a.f.e.2.0.5.3.5.c.4.7.9.2.6.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:38:43.083705 IP6 Android-2.local.mdns > ff02::fb.mdns: 0*- [0q] 3/0/0 (Cache flush) TXT "ss=16" "sv=false" "ch=2" "ek=1" "pw=false" "cn=1" "am=eversolo,1" "et=0,1" "fv=1.0" "txtvers=1" "sf=0x4" "md=0,1,2" "vn=65537" "tp=UDP" "vs=105.1" "da=true" "sr=44100", (Cache flush) SRV DMP-A6-jmdns-2.local.:5500 0 0, (Cache flush) AAAA fdd6:e4c8:2592:da48:5a4c:1867:ea9a:e000 (262)
                          11:39:03.124484 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? 5.0.0.a.9.5.e.f.f.f.6.8.7.3.e.3.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:39:03.847362 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? 2.2.d.4.1.f.e.f.f.f.c.5.e.7.6.3.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:39:04.209145 IP6 fe80::85c7:809c:a0dc:5ce4.mdns > ff02::fb.mdns: 0*- [0q] 1/0/0 PTR _spotify-connect._tcp.local. (76)
                          11:39:13.732128 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? 4.e.c.5.c.d.0.a.c.9.0.8.7.c.5.8.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:39:13.958429 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0*- [0q] 7/0/0 PTR Homebridge 42AF 5A20._hap._tcp.local., (Cache flush) SRV 0E_A8_E9_26_6D_91.local.:51523 0 0, (Cache flush) TXT "c#=4" "ff=0" "id=0E:A8:E9:26:6D:91" "md=homebridge" "pv=1.1" "s#=1" "sf=1" "ci=2" "sh=ChwIcQ==", (Cache flush) A 192.168.119.121, (Cache flush) AAAA fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770, (Cache flush) AAAA fe80::6e4b:90ff:fe1c:8770, PTR _hap._tcp.local. (481)
                          11:39:14.980776 IP6 f.a.1.7.2.2.e.f.f.f.e.0.4.a.a.6.8.4.a.d.2.9.5.2.8.c.4.e.6.d.d.f.ip6.arpa.mdns > ff02::fb.mdns: 0*- [0q] 9/0/0 (Cache flush) A 192.168.119.40, PTR SIEMENS-EX875KYW1E-68A40E2271AF.local., (Cache flush) AAAA fdd6:e4c8:2592:da48:6aa4:eff:fe22:71af, PTR SIEMENS-EX875KYW1E-68A40E2271AF.local., (Cache flush) AAAA fdd6:e4c8:2592:da48:6aa4:eff:fe22:71af, PTR SIEMENS-EX875KYW1E-68A40E2271AF.local., (Cache flush) AAAA fdd6:e4c8:2592:da48:6aa4:eff:fe22:71af, PTR SIEMENS-EX875KYW1E-68A40E2271AF.local., (Cache flush) AAAA fdd6:e4c8:2592:da48:6aa4:eff:fe22:71af (476)
                          11:39:14.980912 IP6 f.a.1.7.2.2.e.f.f.f.e.0.4.a.a.6.8.4.a.d.2.9.5.2.8.c.4.e.6.d.d.f.ip6.arpa.mdns > ff02::fb.mdns: 0*- [0q] 3/0/0 PTR SIEMENS-EX875KYW1E-68A40E2271AF.local., (Cache flush) AAAA fe80::6aa4:eff:fe22:71af, PTR f.a.1.7.2.2.e.f.f.f.e.0.4.a.a.6.8.4.a.d.2.9.5.2.8.c.4.e.6.d.d.f.IP6.ARPA. (249)
                          11:39:14.985745 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? 4.e.c.5.c.d.0.a.c.9.0.8.7.c.5.8.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:39:16.306480 IP6 fdd6:e4c8:2592:da48:1c14:df78:cf62:7de6.mdns > s01.mdns: 0 PTR (QU)? _hap._tcp.local. (33)
                          11:39:16.307380 IP6 fe80::477:f7d9:c921:b393.mdns > ff02::fb.mdns: 0 A (QU)? s01.local. (27)
                          11:39:16.961201 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0*- [0q] 7/0/0 PTR Homebridge 42AF 5A20._hap._tcp.local., (Cache flush) SRV 0E_A8_E9_26_6D_91.local.:51523 0 0, (Cache flush) TXT "c#=4" "ff=0" "id=0E:A8:E9:26:6D:91" "md=homebridge" "pv=1.1" "s#=1" "sf=1" "ci=2" "sh=ChwIcQ==", (Cache flush) A 192.168.119.121, (Cache flush) AAAA fdd6:e4c8:2592:da48:6e4b:90ff:fe1c:8770, (Cache flush) AAAA fe80::6e4b:90ff:fe1c:8770, PTR _hap._tcp.local. (481)
                          11:39:17.236316 IP s01.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 [20a] PTR (QM)? 4.e.c.5.c.d.0.a.c.9.0.8.7.c.5.8.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.arpa. (765)
                          11:39:17.309802 IP6 fe80::477:f7d9:c921:b393.mdns > ff02::fb.mdns: 0 A (QM)? s01.local. (27)
                          11:39:23.794195 IP go-e.f0rd42.local.mdns > mdns.mcast.net.mdns: 0 PTR (QM)? _go-e_controller._tcp.local. (45)
                          ^C
                          q
                          ^C^C^C^C^Y^X
                          11:39:23.795429 IP6 fe80::c6de:e2ff:fe4e:b320.mdns > ff02::fb.mdns: 0 PTR (QM)? _go-e_controller._tcp.local. (45)
                          48 packets captured
                          262 packets received by filter
                          196 packets dropped by kernel
                          adieball@s01:~$
                            OK, mein "discovery" tool zeigt zwar nur IPv6 an und nicht ipv4 aber der Port irritiert mich:
                            Ein netstat zeigt mir an, dass das direkt von Yahka kommt und nicht von avahi.
                            adieball@s01:~$ sudo netstat -tulpn
                            Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                            tcp        0      0 192.168.119.121:7999    0.0.0.0:*               LISTEN      2045/io.geofency.0
                            tcp        0      0 192.168.119.121:8100    0.0.0.0:*               LISTEN      2443/io.doorbird.0
                            tcp        0      0 192.168.119.121:8090    0.0.0.0:*               LISTEN      1851/io.admin.1
                            tcp        0      0 192.168.119.121:8083    0.0.0.0:*               LISTEN      2389/io.web.1
                            tcp        0      0 192.168.119.121:8082    0.0.0.0:*               LISTEN      2365/io.web.0
                            tcp        0      0 192.168.119.121:8081    0.0.0.0:*               LISTEN      1802/io.admin.0
                            tcp        0      0 192.168.119.121:8181    0.0.0.0:*               LISTEN      3023/io.wiffi-wz.0
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      697/systemd-resolve
                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      773/influxd
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      877/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      877/iobroker.js-con
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      2220/io.shelly.0
                            tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      885/perl
                            tcp        0      0 192.168.119.121:1883    0.0.0.0:*               LISTEN      2279/io.sonoff.0
                            tcp        0      0 192.168.119.121:1884    0.0.0.0:*               LISTEN      2101/io.mqtt.0
                            tcp        0      0 192.168.119.121:2010    0.0.0.0:*               LISTEN      2011/io.hm-rpc.0
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      796/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:33115           0.0.0.0:*               LISTEN      81913/io.yahka.0
                            tcp6       0      0 :::8086                 :::*                    LISTEN      773/influxd
                            tcp6       0      0 :::61991                :::*                    LISTEN      3140/io.harmony.0
                            tcp6       0      0 :::51989                :::*                    LISTEN      2154/io.nuki-extend
                            tcp6       0      0 :::51523                :::*                    LISTEN      979/homebridge
                            tcp6       0      0 :::111                  :::*                    LISTEN      1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      796/sshd: /usr/sbin
                            tcp6       0      0 :::8581                 :::*                    LISTEN      862/hb-service
                            udp        0      0 0.0.0.0:10000           0.0.0.0:*                           885/perl
                            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           3140/io.harmony.0
                            udp        0      0 0.0.0.0:54423           0.0.0.0:*                           3600/avahi-daemon:
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           3600/avahi-daemon:
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           979/homebridge
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           862/hb-service
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           697/systemd-resolve
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           697/systemd-resolve
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           1/init
                            udp6       0      0 :::5353                 :::*                                697/systemd-resolve
                            udp6       0      0 :::5353                 :::*                                3600/avahi-daemon:
                            udp6       0      0 :::55295                :::*                                3600/avahi-daemon:
                            udp6       0      0 :::111                  :::*                                1/init
                            adieball@s01:~$
                            Ich meine mich zu erinnern, dass ich avahi erst im Rahmen des Troubleshooting installiert hatte, was wohl unnötig gewesen ist.
                            Sollte ich avahi wieder entfernen (und Homebridge erstmal gleich mit)? Hatte ich probiert, aber dann taucht Yahka weder im Discovry tool noch in Homekit auf.
                            689
