    4. iobroker exit 25 bei Adapter-Update
      Siggi0904 @Thomas Braun last edited by
      mario@iobroker:/opt/iobroker$ npm ls
      iobroker.inst@2.0.3 /opt/iobroker
      ├── @types/caseless@0.12.5 extraneous
      ├── @types/request@2.48.12 extraneous
      ├── @types/tough-cookie@4.0.5 extraneous
      ├── coffeescript@2.7.0 extraneous
      ├── colors@1.4.0
      ├── fs-extra@7.0.1
      ├── iobroker.admin@6.13.16
      ├── iobroker.alarm@3.6.0
      ├── iobroker.alexa-timer-vis@0.3.0
      ├── iobroker.alexa2@3.26.4
      ├── iobroker.awtrix-light@0.16.0
      ├── iobroker.backitup@2.10.11
      ├── iobroker.cloud@4.4.1
      ├── iobroker.daswetter@3.1.13
      ├── iobroker.deconz@1.4.0
      ├── iobroker.discovery@4.4.0
      ├── iobroker.dwd@2.8.5
      ├── iobroker.email@1.2.2
      ├── iobroker.feiertage@1.1.4
      ├── iobroker.flot@1.12.0
      ├── iobroker.heatingcontrol@2.12.5
      ├── iobroker.hm-rega@4.0.0
      ├── iobroker.hm-rpc@1.16.0
      ├── iobroker.ical@1.13.3
      ├── iobroker.icons-mfd-svg@1.2.0
      ├── iobroker.iot@2.0.11
      ├── iobroker.javascript@7.8.0
      ├── iobroker.js-controller@5.0.19
      ├── iobroker.mihome-vacuum@4.1.1
      ├── iobroker.openweathermap@1.0.4
      ├── iobroker.ping@1.6.2
      ├── iobroker.scenes@2.3.9
      ├── iobroker.shelly@6.8.0
      ├── iobroker.simple-api@2.7.2
      ├── iobroker.socketio@6.6.0
      ├── iobroker.sonoff@3.0.3
      ├── iobroker.sql@2.2.0
      ├── iobroker.tankerkoenig@3.3.7
      ├── iobroker.tr-064@4.2.18
      ├── iobroker.trashschedule@3.2.0
      ├── iobroker.vis@1.5.4
      ├── iobroker.web@6.2.3
      ├── iobroker.ws@2.5.10
      ├── iobroker@2.0.3
      ├── jsonata@2.0.4 extraneous
      ├── node-inspect@2.0.0 extraneous
      ├── picocolors@1.0.0 extraneous
      ├── semver@5.7.2
      ├── typescript@5.3.3 extraneous
      ├── virtual-tsc@0.6.2 extraneous
      ├── wake_on_lan@1.0.0 extraneous
      └── yargs@7.1.2
        In der Datei /opt/iobroker/node_modules/zlib/configure steht node-waf configure
        Also ist zlib schuld?
          Thomas Braun Most Active @Siggi0904 last edited by
          @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
          node-waf configure
          Möglich. Auf meinem System schaut es so aus:
          echad@chet:/opt/iobroker $ grep -r node-waf
          node_modules/reinterval/.npmignore:# node-waf configuration
          node_modules/bindings/bindings.js:      // node-waf and gyp_addon (a.k.a node-gyp)
          node_modules/bindings/bindings.js:      // Legacy from node-waf, node <= 0.4.x
          node_modules/zlib/configure:node-waf configure
          node_modules/zlib/Makefile:     node-waf build
          node_modules/zlib/Makefile:     node-waf clean
          Ich habe aber keine Fehler, wenn npm loslegt.
            @thomas-braun in den Releases zu node-js 18.20 ist aber auch viel zlib Zeug dabei.
            https://nodejs.org/en/blog/release/v18.20.0
            Bei mir auch so:
            mario@iobroker:/opt/iobroker$ grep -r node-waf
            log/iobroker.2024-03-29.log:2024-03-29 18:56:47.899  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T17_50_31_979Z-debug-0.log
            log/iobroker.2024-03-29.log:2024-03-29 19:09:10.732  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T18_03_29_073Z-debug-0.log
            log/iobroker.2024-03-29.log:2024-03-29 20:25:32.516  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_19_31_663Z-debug-0.log
            log/iobroker.2024-03-29.log:2024-03-29 20:58:12.865  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T19_52_59_224Z-debug-0.log
            node_modules/node-rest-client/readme.md:**NOTE:** _Since version 0.8.0 node does not contain node-waf anymore. The node-zlib package which node-rest-client make use of, depends on node-waf.Fortunately since version 0.8.0 zlib is a core dependency of node, so since version 1.0 of node-rest-client the explicit dependency to "zlib" has been removed from package.json. therefore if you are using a version below 0.8.0 of node please use a versión below 1.0.0 of "node-rest-client". _
              @siggi0904
              Kommt aus dem Modul:
              https://github.com/kkaefer/DEPRECATED-node-zlib
              Das ist aber wie gesagt seit Jahren überholt.
                Siggi0904 @Thomas Braun last edited by Siggi0904
                @thomas-braun ja.
                Deine Reihenfolge in der grep Ausgabe ist aber anders.
                das npmignore kommt bei mir am Ende, bei dir als erstes.
                Kann man die Verwendung irgendwie deaktivieren, dass das sauber durchläuft?
                  Der mihome-vacuum schleppt wohl zlib an. Keine Ahnung, ob man die Dependency dort herausnehmen kann/soll/muss.
                    @thomas-braun wenn iobroker mich die deinstallation machen lassen würde, könnte ich den adapter auch testweise deinstallieren.
                    da hat einer einfach gyp nachinstalliert.
                    https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/904
                    Tja, wie nun weiter?
                    Ich habe beim mihome-adapter mal ein issue aufgemacht.
                    https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/940
                    Cr4zyM1K4 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                    closed Fehler bei der Installation - code 127 #904
                    Siggi0904 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                    closed dependency of zlib get error with node-js 18.20 #940
                      Da ging es aber auch um canvas. Und die Aktion da global irgendwas reinzuknüppeln war bestimmt auch nicht die eleganteste.
                        @thomas-braun Hallo Thomas, gibt es Ideen was ich noch machen könnte?
                        Ich steh irgendwie auf dem Schlauch.
                        Wie könnte man die Abhängigkeit aufheben?
                        Dank dir.
                          @siggi0904
                          Das müsste im Modul eingetragen werden. Vielleicht kann sich @mcm57 das mal anschauen. Nach meinem Dafürhalten könnte die Abhängigkeit da raus. Aber ich hab keine Ahnung vom Paketbau.
                            @thomas-braun dann hoffe ich, dass @mcm57 mir da recht kurzfristig helfen kann.
                            Ich habe auch schwer die Vermutung, dass ich den Adapter mihome-vacuum auch nicht einfach deinstallieren kann. Ich werde da wohl auch in den Fehler rennen.
                            Da bin ich irgendwie gefangen und brauch Hilfe bei der Reparatur.
                            Natürlich auch gern per PN und Teamviewer oder ähnliches.
                            • mcm1957
                              mcm1957 @Siggi0904 last edited by
                              @siggi0904
                              Sorry damit du nicht umsonst wartest.
                              Aber vor Di werd ich mur kaum was ansehen können.
                                Siggi0904 @mcm1957 last edited by
                                @mcm57 Kein Thema, dann warte ich. Läuft ja alles, nur updates gehen nicht.
                                  @Thomas-Braun irgendwie zerlege ich mir hier gerade mein IOBroker.
                                  Im Guthub wurde mit geschrieben, dass ich das zlib anheben soll.
                                  Habs in der package.json angepasst.
                                  Nun ist IOBroker komplett nicht mehr erreichbar.
                                  login as: mario
                                  mario@192.168.178.64's password:
                                  Linux iobroker 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64
                                  The programs included with the Debian GNU/Linux system are free software;
                                  the exact distribution terms for each program are described in the
                                  individual files in /usr/share/doc/*/copyright.
                                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                  permitted by applicable law.
                                  Last login: Fri Mar 29 20:47:18 2024 from 192.168.178.41
                                  mario@iobroker:~$ nano /opt/iobroker/node_modules/io
                                  iobroker/                 iobroker.flot/            iobroker.simple-api/
                                  iobroker.admin/           iobroker.heatingcontrol/  iobroker.socketio/
                                  iobroker.alarm/           iobroker.hm-rega/         iobroker.sonoff/
                                  iobroker.alexa2/          iobroker.hm-rpc/          iobroker.sql/
                                  iobroker.alexa-timer-vis/ iobroker.ical/            iobroker.tankerkoenig/
                                  iobroker.awtrix-light/    iobroker.icons-mfd-svg/   iobroker.tr-064/
                                  iobroker.backitup/        iobroker.iot/             iobroker.trashschedule/
                                  iobroker.cloud/           iobroker.javascript/      iobroker.type-detector/
                                  iobroker.daswetter/       iobroker.js-controller/   iobroker.vis/
                                  iobroker.deconz/          iobroker.mihome-vacuum/   iobroker.web/
                                  iobroker.discovery/       iobroker.openweathermap/  iobroker.ws/
                                  iobroker.dwd/             iobroker.ping/            ioredis/
                                  iobroker.email/           iobroker.scenes/
                                  iobroker.feiertage/       iobroker.shelly/
                                  mario@iobroker:~$ ls /opt/iobroker/node_modules/iobroker.mihome-vacuum/
                                  admin  io-package.json  lib  LICENSE  main.js  package.json  README.md
                                  mario@iobroker:~$ nano /opt/iobroker/node_modules/iobroker.mihome-vacuum/package.json
                                  mario@iobroker:~$ iob upgrade mihome-vacuum@4.1.1
                                  Would you like to reinstall version 4.1.1 of mihome-vacuum now? [(y)es, (n)o]: y
                                  Update mihome-vacuum from @4.1.1 to @4.1.1
                                  NPM version: 10.5.0
                                  Installing iobroker.mihome-vacuum@4.1.1... (System call)
                                  npm ERR! code 127
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-31T12_32_38_352Z-debug-0.log
                                  host.iobroker Cannot install iobroker.mihome-vacuum@4.1.1: 127
                                  mario@iobroker:~$ npm ls zlib
                                  /home/mario
                                  └── (empty)
                                  node:internal/modules/cjs/loader:1143
                                    throw err;
                                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                      at Module._load (node:internal/modules/cjs/loader:981:27)
                                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      at node:internal/main/run_main_module:28:49 {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: []
                                  Node.js v18.20.0
                                  mario@iobroker:~$
                                  • mcm1957
                                    @siggi0904
                                    Wie ich schon im issue geschrieben habe ist
                                    • das Editieren der package.json keine tolle idee da bei der Installation das package.json des Paketsbund hiffentlich kuchtcdes Zielsystems verwendet wird
                                    • beim Ändern v package.json auch packaga-lock.json anzupassen ist.
                                    • ein Sprung vvzlib 1.x.x auf 3.x.x ohne check des Changelogs sehr mutigbust. Major Releases veinhaltennmeust knkompatible änderungen und sa muss ev der Adapter angepasst werden..
                                    Deinstallier mihome mal. Ich bezweifle dass der Adapter bzw zlib die primäre Fehlerursache ist. Es sind mit Sicherheit auchcschon zug andere User auf node 18. Wenn das Problem ohne mihome weg ist dann ibstalluer den Adapter neu. Und dann schau na bal was der Statzs ist.
                                      @mcm57 wie geschrieben geht aktuell garnichts mehr.
                                        So, ich habe nun mein Proxmox-Backup von vor der Hochrüstung von node-js wieder eingespielt.
                                        Zum Glück hatte ich das entsprechend des Tutorials von @haus-automatisierung alles so eingerichtet,
                                        dass das zurückrollen des Backups leicht ging.
                                        Nur musste ich alle Arbeiten, die ich die Woche über gemacht hatte, wiederholen.
                                        Zum aktuellen Stand:
                                        Ich habe alle Addons aktuell, mihome-vacuum adapter ist installiert und node-js steht bei Version 18.19.1.
                                        Ich müsste nun node-js hochrüsten.
                                        Aber wie?
                                          iob nodejs-update
                                            @thomas-braun ohne Angabe einer Version?
                                            Ein Update via apt nicht machen? Denn dort wird es ja auch gelistet.
                                            Sollte ich vorher den mihome-vacuum Adapter deinstallieren?
                                            Kann man vorher noch irgendwas checken?
                                            Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
                                            13053
