    4. OpenKNX Adapter startet nicht mehr nach System-Update
      rsw2004 @Thomas Braun last edited by
      wie gesagt, hatte bereits eine neue Instanz installiert, brachte aber den gleichen Fehler.
        Thomas Braun Most Active @rsw2004 last edited by
        @rsw2004
        Den ganzen Adapter, keine Instanz installieren.
          also wie folgt?
          cd /opt/iobroker
          iobroker stop adapterName
          npm install iobroker.adapterName
          iobroker upload adapterName
          iobroker start adapterName
          Ändert sich nix
            @rsw2004
            Jein
            iobroker update
            iobroker upgrade openknx@0.7.2
            Rückmeldungen im Terminal hier bekannt machen.
              robin@raspberrypi4:~ $ iobroker update
              Used repository: stable
              Adapter    "backitup"     : 2.10.11  , installed 2.10.11
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
              Adapter    "openknx"      : 0.7.2    , installed 0.7.2
              Adapter    "pushover"     : 3.0.6    , installed 3.0.6
              Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
              Adapter    "socketio"     : 6.6.1    , installed 6.6.1
              Adapter    "solax"        : 0.9.6    , installed 0.9.6
              Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
              Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
              Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
              Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.2.3    , installed 6.2.3
              Adapter    "ws"           : 2.5.11   , installed 2.5.11
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
              Would you like to reinstall version 0.7.2 of openknx now? [(y)es, (n)o]: y
              Update openknx from @0.7.2 to @0.7.2
              NPM version: 10.5.0
              Installing iobroker.openknx@0.7.2... (System call)
              up to date in 7s
              102 packages are looking for funding
                run `npm fund` for details
              upload [16] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/busload.png busload.png image/png
              upload [15] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
              upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
              upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
              upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
              upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
              upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
              upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
              upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
                rsw2004 @rsw2004 last edited by
                @rsw2004
                Also ich denke, das hat mit dem Update des Adapter angefangen, unabhängig von JS oder NPM oder was auch immer.
                Kann ich einfach die ältere Version das drüberbügeln?
                Einfach die Versionsnummer ändern?
                  @rsw2004 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
                  Dann mach ein Issue dazu auf, wenn du dir sicher bist.
                  Wie schaut denn ein Adapter-Neustart im Log nun aus? Immer noch ein rebuild im Gange?
                    @rsw2004
                    Wobei das auf meinem System direkt durchläuft:
                    echad@chet:~ $ iob add openknx
                    NPM version: 10.5.0
                    Installing iobroker.openknx@0.7.3... (System call)
                    added 15 packages in 12s
                    117 packages are looking for funding
                    host.chet install adapter openknx
                    host.chet object system.adapter.openknx created/updated
                    host.chet create instance openknx
                    host.chet object system.adapter.openknx.0.alive created
                    host.chet object system.adapter.openknx.0.connected created
                    host.chet object system.adapter.openknx.0.compactMode created
                    host.chet object system.adapter.openknx.0.cpu created
                    host.chet object system.adapter.openknx.0.cputime created
                    host.chet object system.adapter.openknx.0.memHeapUsed created
                    host.chet object system.adapter.openknx.0.memHeapTotal created
                    host.chet object system.adapter.openknx.0.memRss created
                    host.chet object system.adapter.openknx.0.uptime created
                    host.chet object system.adapter.openknx.0.inputCount created
                    host.chet object system.adapter.openknx.0.outputCount created
                    host.chet object system.adapter.openknx.0.eventLoopLag created
                    host.chet object system.adapter.openknx.0.sigKill created
                    host.chet object system.adapter.openknx.0.logLevel created
                    host.chet object openknx.0.info created
                    host.chet object openknx.0.info.connection created
                    host.chet object openknx.0.info.busload created
                    host.chet object openknx.0.info.messagecount created
                    host.chet Set default value of openknx.0.info.connection: false
                    host.chet Set default value of openknx.0.info.busload: 0
                    host.chet Set default value of openknx.0.info.messagecount: 0
                    host.chet object system.adapter.openknx.0 created
                    echad@chet:~ $
                      es hat sich meiner Meinung nach nix geändert.
                      host.raspberrypi4
                      2024-03-30 15:59:27.700	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi4
                      2024-03-30 15:59:27.700	error	Caught by controller[0]: Node.js v18.20.0
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: }
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: ]
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: requireStack: [
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                      host.raspberrypi4
                      2024-03-30 15:59:27.699	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      host.raspberrypi4
                      2024-03-30 15:59:27.698	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                      host.raspberrypi4
                      2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                      host.raspberrypi4
                      2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                      host.raspberrypi4
                      2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
                      host.raspberrypi4
                      2024-03-30 15:59:27.697	error	Caught by controller[0]: Require stack:
                      host.raspberrypi4
                      2024-03-30 15:59:27.697	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
                      host.raspberrypi4
                      2024-03-30 15:59:27.697	error	Caught by controller[0]: ^
                      host.raspberrypi4
                      2024-03-30 15:59:27.697	error	Caught by controller[0]: throw err;
                      host.raspberrypi4
                      2024-03-30 15:59:27.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      host.raspberrypi4
                      2024-03-30 15:59:26.615	info	instance system.adapter.openknx.0 started with pid 5921
                        bei dir wurde die 0.7.3 installiert.
                        Habe das nun auch mal manuell geupdatet.
                        Der Log bleibt gleich.
                          Ich fahre auch ein 'bleeding edge'-Betasystem hier.
                            	Rebuild for adapter system.adapter.openknx.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            Könnte das weiterhelfen?
                            Welches Verzeichnis wäre denn hier das richtige?
                            /opt/iobroker/iobroker-data/files/openknx.admin ?
                              @rsw2004
                              cd /opt/iobroker/node_modules/iobroker.openknx
                              npm install --omit=dev
                              müsste das sein. Der Befehl mit --production ist veraltet.
                                Habe zumindest fürs Erste eine Lösung gefunden, damit alles wieder läuft.
                                Erst Downgrade auf die ursprüngliche Version (laut LOG)
                                iobroker update
                                iobroker upgrade openknx@0.6.3
                                danach
                                Mit der aktuellen 0.7.2 funktioniert das nicht.
                                Ich danke dir für deine Mühe
                                  Meldungen?
                                  869
