    4. OpenKNX Adapter startet nicht mehr nach System-Update
      Thomas Braun Most Active @rsw2004 last edited by
      @rsw2004
      Den ganzen Adapter, keine Instanz installieren.
        rsw2004 @Thomas Braun last edited by
        also wie folgt?
        cd /opt/iobroker
        iobroker stop adapterName
        npm install iobroker.adapterName
        iobroker upload adapterName
        iobroker start adapterName
        Ändert sich nix
          @rsw2004
          Jein
          iobroker update
          iobroker upgrade openknx@0.7.2
          Rückmeldungen im Terminal hier bekannt machen.
            robin@raspberrypi4:~ $ iobroker update
            Used repository: stable
            Adapter    "backitup"     : 2.10.11  , installed 2.10.11
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
            Adapter    "openknx"      : 0.7.2    , installed 0.7.2
            Adapter    "pushover"     : 3.0.6    , installed 3.0.6
            Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
            Adapter    "socketio"     : 6.6.1    , installed 6.6.1
            Adapter    "solax"        : 0.9.6    , installed 0.9.6
            Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
            Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
            Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
            Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.2.3    , installed 6.2.3
            Adapter    "ws"           : 2.5.11   , installed 2.5.11
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
            Would you like to reinstall version 0.7.2 of openknx now? [(y)es, (n)o]: y
            Update openknx from @0.7.2 to @0.7.2
            NPM version: 10.5.0
            Installing iobroker.openknx@0.7.2... (System call)
            up to date in 7s
            102 packages are looking for funding
              run `npm fund` for details
            upload [16] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/busload.png busload.png image/png
            upload [15] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
            upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
            upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
            upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
            upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
              rsw2004 @rsw2004 last edited by
              @rsw2004
              Also ich denke, das hat mit dem Update des Adapter angefangen, unabhängig von JS oder NPM oder was auch immer.
              Kann ich einfach die ältere Version das drüberbügeln?
              Einfach die Versionsnummer ändern?
                @rsw2004 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
                Dann mach ein Issue dazu auf, wenn du dir sicher bist.
                Wie schaut denn ein Adapter-Neustart im Log nun aus? Immer noch ein rebuild im Gange?
                  @rsw2004
                  Wobei das auf meinem System direkt durchläuft:
                  echad@chet:~ $ iob add openknx
                  NPM version: 10.5.0
                  Installing iobroker.openknx@0.7.3... (System call)
                  added 15 packages in 12s
                  117 packages are looking for funding
                  host.chet install adapter openknx
                  host.chet object system.adapter.openknx created/updated
                  host.chet create instance openknx
                  host.chet object system.adapter.openknx.0.alive created
                  host.chet object system.adapter.openknx.0.connected created
                  host.chet object system.adapter.openknx.0.compactMode created
                  host.chet object system.adapter.openknx.0.cpu created
                  host.chet object system.adapter.openknx.0.cputime created
                  host.chet object system.adapter.openknx.0.memHeapUsed created
                  host.chet object system.adapter.openknx.0.memHeapTotal created
                  host.chet object system.adapter.openknx.0.memRss created
                  host.chet object system.adapter.openknx.0.uptime created
                  host.chet object system.adapter.openknx.0.inputCount created
                  host.chet object system.adapter.openknx.0.outputCount created
                  host.chet object system.adapter.openknx.0.eventLoopLag created
                  host.chet object system.adapter.openknx.0.sigKill created
                  host.chet object system.adapter.openknx.0.logLevel created
                  host.chet object openknx.0.info created
                  host.chet object openknx.0.info.connection created
                  host.chet object openknx.0.info.busload created
                  host.chet object openknx.0.info.messagecount created
                  host.chet Set default value of openknx.0.info.connection: false
                  host.chet Set default value of openknx.0.info.busload: 0
                  host.chet Set default value of openknx.0.info.messagecount: 0
                  host.chet object system.adapter.openknx.0 created
                  echad@chet:~ $
                    es hat sich meiner Meinung nach nix geändert.
                    host.raspberrypi4
                    2024-03-30 15:59:27.700	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi4
                    2024-03-30 15:59:27.700	error	Caught by controller[0]: Node.js v18.20.0
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: }
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: ]
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: requireStack: [
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.raspberrypi4
                    2024-03-30 15:59:27.699	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                    host.raspberrypi4
                    2024-03-30 15:59:27.698	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                    host.raspberrypi4
                    2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                    host.raspberrypi4
                    2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                    host.raspberrypi4
                    2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
                    host.raspberrypi4
                    2024-03-30 15:59:27.697	error	Caught by controller[0]: Require stack:
                    host.raspberrypi4
                    2024-03-30 15:59:27.697	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
                    host.raspberrypi4
                    2024-03-30 15:59:27.697	error	Caught by controller[0]: ^
                    host.raspberrypi4
                    2024-03-30 15:59:27.697	error	Caught by controller[0]: throw err;
                    host.raspberrypi4
                    2024-03-30 15:59:27.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
                    host.raspberrypi4
                    2024-03-30 15:59:26.615	info	instance system.adapter.openknx.0 started with pid 5921
                      bei dir wurde die 0.7.3 installiert.
                      Habe das nun auch mal manuell geupdatet.
                      Der Log bleibt gleich.
                        Ich fahre auch ein 'bleeding edge'-Betasystem hier.
                          	Rebuild for adapter system.adapter.openknx.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          Könnte das weiterhelfen?
                          Welches Verzeichnis wäre denn hier das richtige?
                          /opt/iobroker/iobroker-data/files/openknx.admin ?
                            @rsw2004
                            cd /opt/iobroker/node_modules/iobroker.openknx
                            npm install --omit=dev
                            müsste das sein. Der Befehl mit --production ist veraltet.
                              Habe zumindest fürs Erste eine Lösung gefunden, damit alles wieder läuft.
                              Erst Downgrade auf die ursprüngliche Version (laut LOG)
                              iobroker update
                              iobroker upgrade openknx@0.6.3
                              danach
                              Mit der aktuellen 0.7.2 funktioniert das nicht.
                              Ich danke dir für deine Mühe
                                Meldungen?
                                869
