    4. OpenKNX Adapter startet nicht mehr nach System-Update
      Thomas Braun Most Active @rsw2004 last edited by
      @rsw2004
      Jein
      iobroker update
      iobroker upgrade openknx@0.7.2
      Rückmeldungen im Terminal hier bekannt machen.
        rsw2004 @Thomas Braun last edited by
        robin@raspberrypi4:~ $ iobroker update
        Used repository: stable
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "openknx"      : 0.7.2    , installed 0.7.2
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "solax"        : 0.9.6    , installed 0.9.6
        Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
        Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Would you like to reinstall version 0.7.2 of openknx now? [(y)es, (n)o]: y
        Update openknx from @0.7.2 to @0.7.2
        NPM version: 10.5.0
        Installing iobroker.openknx@0.7.2... (System call)
        up to date in 7s
        102 packages are looking for funding
          run `npm fund` for details
        upload [16] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/busload.png busload.png image/png
        upload [15] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
        upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
        upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
        upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
        upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
          rsw2004 @rsw2004 last edited by
          @rsw2004
          Also ich denke, das hat mit dem Update des Adapter angefangen, unabhängig von JS oder NPM oder was auch immer.
          Kann ich einfach die ältere Version das drüberbügeln?
          Einfach die Versionsnummer ändern?
            @rsw2004 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
            Dann mach ein Issue dazu auf, wenn du dir sicher bist.
            Wie schaut denn ein Adapter-Neustart im Log nun aus? Immer noch ein rebuild im Gange?
              @rsw2004
              Wobei das auf meinem System direkt durchläuft:
              echad@chet:~ $ iob add openknx
              NPM version: 10.5.0
              Installing iobroker.openknx@0.7.3... (System call)
              added 15 packages in 12s
              117 packages are looking for funding
              host.chet install adapter openknx
              host.chet object system.adapter.openknx created/updated
              host.chet create instance openknx
              host.chet object system.adapter.openknx.0.alive created
              host.chet object system.adapter.openknx.0.connected created
              host.chet object system.adapter.openknx.0.compactMode created
              host.chet object system.adapter.openknx.0.cpu created
              host.chet object system.adapter.openknx.0.cputime created
              host.chet object system.adapter.openknx.0.memHeapUsed created
              host.chet object system.adapter.openknx.0.memHeapTotal created
              host.chet object system.adapter.openknx.0.memRss created
              host.chet object system.adapter.openknx.0.uptime created
              host.chet object system.adapter.openknx.0.inputCount created
              host.chet object system.adapter.openknx.0.outputCount created
              host.chet object system.adapter.openknx.0.eventLoopLag created
              host.chet object system.adapter.openknx.0.sigKill created
              host.chet object system.adapter.openknx.0.logLevel created
              host.chet object openknx.0.info created
              host.chet object openknx.0.info.connection created
              host.chet object openknx.0.info.busload created
              host.chet object openknx.0.info.messagecount created
              host.chet Set default value of openknx.0.info.connection: false
              host.chet Set default value of openknx.0.info.busload: 0
              host.chet Set default value of openknx.0.info.messagecount: 0
              host.chet object system.adapter.openknx.0 created
              echad@chet:~ $
                es hat sich meiner Meinung nach nix geändert.
                host.raspberrypi4
                2024-03-30 15:59:27.700	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi4
                2024-03-30 15:59:27.700	error	Caught by controller[0]: Node.js v18.20.0
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: }
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: ]
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: requireStack: [
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                host.raspberrypi4
                2024-03-30 15:59:27.699	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                host.raspberrypi4
                2024-03-30 15:59:27.698	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                host.raspberrypi4
                2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                host.raspberrypi4
                2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                host.raspberrypi4
                2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
                host.raspberrypi4
                2024-03-30 15:59:27.697	error	Caught by controller[0]: Require stack:
                host.raspberrypi4
                2024-03-30 15:59:27.697	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
                host.raspberrypi4
                2024-03-30 15:59:27.697	error	Caught by controller[0]: ^
                host.raspberrypi4
                2024-03-30 15:59:27.697	error	Caught by controller[0]: throw err;
                host.raspberrypi4
                2024-03-30 15:59:27.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
                host.raspberrypi4
                2024-03-30 15:59:26.615	info	instance system.adapter.openknx.0 started with pid 5921
                  bei dir wurde die 0.7.3 installiert.
                  Habe das nun auch mal manuell geupdatet.
                  Der Log bleibt gleich.
                    Ich fahre auch ein 'bleeding edge'-Betasystem hier.
                      	Rebuild for adapter system.adapter.openknx.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                      Könnte das weiterhelfen?
                      Welches Verzeichnis wäre denn hier das richtige?
                      /opt/iobroker/iobroker-data/files/openknx.admin ?
                        @rsw2004
                        cd /opt/iobroker/node_modules/iobroker.openknx
                        npm install --omit=dev
                        müsste das sein. Der Befehl mit --production ist veraltet.
                          Habe zumindest fürs Erste eine Lösung gefunden, damit alles wieder läuft.
                          Erst Downgrade auf die ursprüngliche Version (laut LOG)
                          iobroker update
                          iobroker upgrade openknx@0.6.3
                          danach
                          Mit der aktuellen 0.7.2 funktioniert das nicht.
                          Ich danke dir für deine Mühe
                            Meldungen?
                            869
