    4. iobroker exit 25 bei Adapter-Update
    • mcm1957
      mcm1957 @Siggi0904 last edited by
      @siggi0904
      Sorry damit du nicht umsonst wartest.
      Aber vor Di werd ich mur kaum was ansehen können.
        Siggi0904 @mcm1957 last edited by
        @mcm57 Kein Thema, dann warte ich. Läuft ja alles, nur updates gehen nicht.
          @Thomas-Braun irgendwie zerlege ich mir hier gerade mein IOBroker.
          Im Guthub wurde mit geschrieben, dass ich das zlib anheben soll.
          Habs in der package.json angepasst.
          Nun ist IOBroker komplett nicht mehr erreichbar.
          login as: mario
          mario@192.168.178.64's password:
          Linux iobroker 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Fri Mar 29 20:47:18 2024 from 192.168.178.41
          mario@iobroker:~$ nano /opt/iobroker/node_modules/io
          iobroker/                 iobroker.flot/            iobroker.simple-api/
          iobroker.admin/           iobroker.heatingcontrol/  iobroker.socketio/
          iobroker.alarm/           iobroker.hm-rega/         iobroker.sonoff/
          iobroker.alexa2/          iobroker.hm-rpc/          iobroker.sql/
          iobroker.alexa-timer-vis/ iobroker.ical/            iobroker.tankerkoenig/
          iobroker.awtrix-light/    iobroker.icons-mfd-svg/   iobroker.tr-064/
          iobroker.backitup/        iobroker.iot/             iobroker.trashschedule/
          iobroker.cloud/           iobroker.javascript/      iobroker.type-detector/
          iobroker.daswetter/       iobroker.js-controller/   iobroker.vis/
          iobroker.deconz/          iobroker.mihome-vacuum/   iobroker.web/
          iobroker.discovery/       iobroker.openweathermap/  iobroker.ws/
          iobroker.dwd/             iobroker.ping/            ioredis/
          iobroker.email/           iobroker.scenes/
          iobroker.feiertage/       iobroker.shelly/
          mario@iobroker:~$ ls /opt/iobroker/node_modules/iobroker.mihome-vacuum/
          admin  io-package.json  lib  LICENSE  main.js  package.json  README.md
          mario@iobroker:~$ nano /opt/iobroker/node_modules/iobroker.mihome-vacuum/package.json
          mario@iobroker:~$ iob upgrade mihome-vacuum@4.1.1
          Would you like to reinstall version 4.1.1 of mihome-vacuum now? [(y)es, (n)o]: y
          Update mihome-vacuum from @4.1.1 to @4.1.1
          NPM version: 10.5.0
          Installing iobroker.mihome-vacuum@4.1.1... (System call)
          npm ERR! code 127
          npm ERR! path /opt/iobroker/node_modules/zlib
          npm ERR! command failed
          npm ERR! command sh -c node-waf clean || true; node-waf configure build
          npm ERR! sh: 1: node-waf: not found
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-31T12_32_38_352Z-debug-0.log
          host.iobroker Cannot install iobroker.mihome-vacuum@4.1.1: 127
          mario@iobroker:~$ npm ls zlib
          /home/mario
          └── (empty)
          node:internal/modules/cjs/loader:1143
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
              at Module._load (node:internal/modules/cjs/loader:981:27)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
              at node:internal/main/run_main_module:28:49 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          Node.js v18.20.0
          mario@iobroker:~$
          • mcm1957
            @siggi0904
            Wie ich schon im issue geschrieben habe ist
            • das Editieren der package.json keine tolle idee da bei der Installation das package.json des Paketsbund hiffentlich kuchtcdes Zielsystems verwendet wird
            • beim Ändern v package.json auch packaga-lock.json anzupassen ist.
            • ein Sprung vvzlib 1.x.x auf 3.x.x ohne check des Changelogs sehr mutigbust. Major Releases veinhaltennmeust knkompatible änderungen und sa muss ev der Adapter angepasst werden..
            Deinstallier mihome mal. Ich bezweifle dass der Adapter bzw zlib die primäre Fehlerursache ist. Es sind mit Sicherheit auchcschon zug andere User auf node 18. Wenn das Problem ohne mihome weg ist dann ibstalluer den Adapter neu. Und dann schau na bal was der Statzs ist.
              @mcm57 wie geschrieben geht aktuell garnichts mehr.
                So, ich habe nun mein Proxmox-Backup von vor der Hochrüstung von node-js wieder eingespielt.
                Zum Glück hatte ich das entsprechend des Tutorials von @haus-automatisierung alles so eingerichtet,
                dass das zurückrollen des Backups leicht ging.
                Nur musste ich alle Arbeiten, die ich die Woche über gemacht hatte, wiederholen.
                Zum aktuellen Stand:
                Ich habe alle Addons aktuell, mihome-vacuum adapter ist installiert und node-js steht bei Version 18.19.1.
                Ich müsste nun node-js hochrüsten.
                Aber wie?
                  Thomas Braun Most Active @Siggi0904 last edited by
                  @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
                  iob nodejs-update
                    Siggi0904 @Thomas Braun last edited by
                    @thomas-braun ohne Angabe einer Version?
                    Ein Update via apt nicht machen? Denn dort wird es ja auch gelistet.
                    Sollte ich vorher den mihome-vacuum Adapter deinstallieren?
                    Kann man vorher noch irgendwas checken?
                    Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @Siggi0904 last edited by Thomas Braun
                      Ohne Angabe einer Version wird die empfohlene Version installiert. Heute also die 18.20.0.
                      • haus-automatisierung
                        haus-automatisierung Developer Most Active @Siggi0904 last edited by
                        @siggi0904 Ohne Version = aktuell empfohlene Version wird installiert (nodejs 18).
                        Ansonsten läuft das natürlich über apt, aber der Befehl kontrolliert die aktuelle nodejs Installation und zieht sie ggf gerade. Es werden die entsprechenden apt Repositories angelegt und dann daraus installiert.
                        Am Ende ist ein Bash-Script, welches einfach nur viel Arbeit abnimmt und apt richtig konfiguriert
                          Tja, den Adapter mihome-vacuum vorher deinstallieren?
                          Ich lass erst einmal ein Backup laufen.
                            samsungfreak last edited by
                            Hallo.
                            ich habe genau das gleiche Problem wie @Siggi0904. Allerdings ist es mir aufgefallen, als ich den mihome-vacuum adapter installieren wollte. Updates von allen anderen Adaptern die bereits installiert sind laufen ohne Probleme durch.
                              Neue Adapter-Version vom mihome-vacuum ist auf dem Weg. Es wird der nodejs eigene zlib verwendet. Hoffentlich hilft es.
                              Ich lasse mein System nun erst einmal mit der node-js 18.19 Version, bis die neue Adapter-Version da ist. Leider bleiben dann auch einige andere Updates hängen, aber halb so wild.
                              Wär cool, wenn es das Thema löst.
                                @siggi0904
                                Also bei mir ist das zlib-Modul nun rausgeflogen:
                                echad@chet:/opt/iobroker $ grep -r node-waf
                                node_modules/reinterval/.npmignore:# node-waf configuration
                                node_modules/bindings/bindings.js:      // node-waf and gyp_addon (a.k.a node-gyp)
                                node_modules/bindings/bindings.js:      // Legacy from node-waf, node <= 0.4.x
                                  @thomas-braun hast du dir die neue Version aus dem npm gezogen?
                                  Wär cool, wenn es so das Problem beheben würde.
                                  Dann hoffe ich, dass die stable zeitnah kommt.
                                  Dann kann ich mein System wieder aktuell ziehen.
                                  Danke für die Info.
                                  mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
                                  • mcm1957
                                    mcm1957 @Siggi0904 last edited by mcm1957
                                    @siggi0904
                                    Da du ein System bei dem du via Container scheinbar recht rasch zurücksteigen kannst, wärs durchaus sinnvoll die latest Release zu testen, Ich bezweifle, dass sonst viele User gibt die dein Problem haben.
                                    Du kannst natürlich auch gerne auf die Stable warten und dann testen ob die Release dein Problem behebt - ist aber erst in ca 2 bis 3 Wochen zu erwarten wenn sich bis dahin keine neuen Fehler zeigen.
                                      @siggi0904
                                      Lag im Beta-Repo.
                                        @mcm57 Hi, naja ist eine VM unter Proxmox.
                                        Ich muss dann halt das Backup wieder zurückrollen.
                                        Kann immer nur hoffen, dass die Backups sauber laufen.
                                        Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                          @siggi0904
                                          Angel dir den einen Adapter doch aus dem Beta-Repo/npm.
                                          • mcm1957
                                            @siggi0904
                                            Na ja
                                            Variante 1: mit der neuen Version gehts - alles gut
                                            Varainate 2: Mit der neuen Version gehts nicht. Dann musst du eh auf deinem System suchen was da faul ist. Da der Adapter nunmehr zlib in der Uraltversion nicht mehr includiert, kann es daran nicht liegen.
                                            Das einzige was du mit zuwarten gewinnen kannst ist die Frage ob allenfalls die Uralt-zlib und nodes zlib doch irgendwo nicht 100% kompatibel sind und dass diese Problem wer anderer entdeckt ...
                                            13054
