    4. Node und JS-Controller Udpate im Docker
    • Minor js-controller 7.0.7 Update in latest repo
    • Save The Date: ioBroker@Smart Living Forum Solingen, 14.06.
      Sali84 last edited by Sali84
      Habe nun das 7.X Image im neuen Container zum Laufen gebracht. Habe den Mount Ordner (opt/iobroker) vorher kopiert und auf den Kopie Ordner verwiesen. So kann ich probieren.
      Es scheint zu laufen, allerdings erreiche ich die Admin Oberfläche (Err connection refused) nicht mehr. Adapter sehen wie folgt aus, einzelne Adapter habe ich bereits geupdated. Habt ihr eine Idee?
      Adapter "admin" : 6.13.16 , installed 6.13.16
      Adapter "alexa2" : 3.26.4 , installed 3.23.2 [Updatable]
      Adapter "backitup" : 2.10.11 , installed 2.5.4 [Updatable]
      Adapter "discovery" : 4.4.0 , installed 2.8.0 [Updatable]
      Adapter "history" : 3.0.1 , installed 1.11.1 [Updatable]
      Adapter "hm-rega" : 4.0.0 , installed 3.0.47 [Updatable]
      Adapter "hm-rpc" : 1.16.0 , installed 1.17.0
      Adapter "iot" : 2.0.11 , installed 1.11.9 [Updatable]
      Adapter "javascript" : 7.8.0 , installed 5.8.10 [Updatable]
      Controller "js-controller": 5.0.19 , installed 4.0.24 [Updatable]
      Adapter "knx" : 2.0.24 , installed 1.0.45 [Updatable]
      Adapter "mihome-vacuum": 4.1.1 , installed 3.11.0 [Updatable]
      Adapter "radar2" : 2.1.0 , installed 1.2.5 [Updatable]
      Adapter "scenes" : 2.3.9 , installed 2.4.2
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "socketio" : 6.6.1 , installed 3.1.5 [Updatable]
      Adapter "sonos" : 3.0.0 , installed 2.3.3 [Updatable]
      Adapter "telegram" : 3.1.0 , installed 1.15.2 [Updatable]
      Adapter "text2command" : 3.0.3 , installed 2.2.2 [Updatable]
      Adapter "tuya" : 3.15.0 , installed 3.13.1 [Updatable]
      Adapter "vis" : 1.5.4 , installed 1.5.4
      Adapter "weatherunderground": 3.6.0, installed 3.4.2 [Updatable]
      Adapter "web" : 6.2.3 , installed 5.4.0 [Updatable]
      Adapter "ws" : 2.5.11 , installed 2.3.3 [Updatable]
      • haselchen
        haselchen Most Active @Sali84 last edited by
        @sali84
        Versuch per Konsole die Adapter upzudaten.
        Den JSController zuerst.
        Aber das Image ist alt , wieso hast du es installiert ?
          @haselchen weil ich sicherstellen wollte, dass sich die JS Controller Versionen nicht "beisen". Daher der Zwischenschritt. Bin am updaten. JS Controller ist nun updated. Leider keine Verbesserung ....
            Inzwischen bin ich soweit, dass folgende Meldung kommt:
            Diese Website kann keine sichere Verbindung bereitstellen192.168.x.x erfüllt die Sicherheitsstandards nicht.
            ERR_SSL_SERVER_CERT_BAD_FORMAT
            Certificate habe ich mit dem create Befehl bereits erzeugt.
            Schon sehr spannend, wie viele Probleme man so haben kann...... Danke für eure Hilfe
              Nach einigen "Probieren" konnte dann der Container nicht mehr gestartet werden. Also so komme ich da nicht wirklich weiter, da fehlt mir einfach das Wissen. Wäre dankbar, wenn mir jemand helfen könnte....
              • haselchen
                haselchen Most Active @Sali84 last edited by haselchen
                @sali84
                Vielleicht solltest Du mal Schritt für Schritt zeigen wie Du Deinen Container mit welchen Einstellungen installierst .
                  @haselchen klar gerne. Bin ja um jede Hilfe dankbar.
                  Hier die Screenshots.
                  Screenshot_20240331_132458_Chrome.jpg Screenshot_20240331_132441_Chrome.jpg Screenshot_20240331_132433_Chrome.jpg
                  • OliverIO
                    OliverIO @Sali84 last edited by
                    @sali84
                    Das wäre das rumdoktern
                    • haselchen
                      haselchen Most Active last edited by
                      @sali84
                      Wo sind denn aktuell noch Probleme?
                      Log Einträge bitte dann in CodeTags.
                        Jetzt scheint es zu funktionieren.
                        Für alle die über mehrere Image Versionen hinweg Udpaten möchten und dabei den Mount Ordner bestehen lassen wollen ---> lasst es lieber sein. Es hat mich Stunden gekostet und es läuft einfach unheimlich instabil.
                        Lösung ist, das Image mit dem Mount irgendwie kurz zum Laufen zu bringen und dann asap Backitup zu nutzen und dann ein ganz neues Image mit neuem Mount anlegen.
                        Weiterhin schöne Ostern euch...
                        BernyR 1 Reply Last reply Reply Quote 0
                        • BernyR
                          BernyR @Sali84 last edited by
                          Einfacher Weg um Node.js im Docker auf den neuesten Stand zu bringen ohne alles neu aufsetzen zu müssen...
                          • Zuerstes ioBroker im Container stoppen und gegebenfalls npm updaten:
                          pkill -u iobroker
                          npm -i -g npm@latest
                          • falls noch nicht gemacht (!!!) den Versionsmanager installieren (kann später weggelassen werden):
                          npm install -g n
                          • dann Node.js upgraden (neueste Version):
                          n latest
                          • bzw. (gewünschte Versionsnummer):
                          n versionsnummer
                          • Zuletzt ioBroker neu starten...
                          iobroker start
                          Diesen Weg benutze ich immer und es funktioniert hervorragend!
                          Samson71 Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
                          • Samson71
                            Samson71 Global Moderator @BernyR last edited by
                            @bernd-röske
                            Liest Du eigentlich einen Thread durch bevor Du postest? Falls nein, empfehle ich mal den 2. Beitrag genau zu lesen.
                            @oliverio sagte in Node und JS-Controller Udpate im Docker:
                            Nur als kleiner Hinweis
                            Node im Container nicht über die üblichen Befehle aktualisieren.
                            Node und das Container Betriebssystem wird nur dirch die Verwendung eines aktuellen Containers aktualisiert.
                              Thomas Braun Most Active @BernyR last edited by
                              @bernd-röske
                              Das wird nicht per n gemacht. Und auch nicht per npm -i oder sonst wie an allem vorbei.
                              • OliverIO
                                OliverIO @BernyR last edited by
                                @bernd-röske
                                ein container ist nicht mit einer festplatte oder einer vm vergleichbar.
                                sobald du den container regenerierst, sind die änderungen weg.
                                änderungen am container überleben eine regeneration des containers nur, wenn sie sich in einem volume befinden. bei buanet ist der komplette iobroker (/opt/iobroker) in einem volume, alles andere nicht.
                                also einfach pull auf das container image durchführen (ggfs mit angabe der version des images) und container neu starten, fertig. damit hat man dann das (container)-betriebssystem und node aktualisiert, sofern es von buanet so vorgesehen ist.
                                • Samson71
                                  Samson71 Global Moderator @OliverIO last edited by
                                  Genau das macht er ja wohl nicht, bzw. sucht es zu vermeiden. Das verstehe ich zumindest unter
                                  @bernd-röske sagte in Node und JS-Controller Udpate im Docker:
                                  Ist so aber ja nicht richtig.
                                  • OliverIO
                                    OliverIO @Samson71 last edited by
                                    @samson71
                                    das wollte ich damit aussagen.
                                    viele verstehen das docker konzept leider nicht
                                    • BernyR
                                      BernyR @OliverIO last edited by
                                      Nunja, dann verstehe ich das Konzept eben nicht ... sorry, dass es trotzdem seit mehreren Updates funktioniert und ich seit dem immer auf dem neuesten (und erforderlichen) Stand bin. Falls mir ein Container-Update des QNAP alles wieder zurücksetzen sollte, führe ich die Schritte eben erneut aus - dauert nur einen kleinen Moment...
                                      OliverIO Thomas Braun 2 Replies Last reply Reply Quote 0
                                      • OliverIO
                                        OliverIO @BernyR last edited by OliverIO
                                        @bernd-röske
                                        das mag schon sein das es funktioniert., widerspricht halt dem docker konzept.
                                        da sollte man dann doch lieber eine vm machen.
                                        es können auch gerne andere so machen, aber ich wolle darauf hinweisen, nicht das es später beschwerden gibt, das das nicht zu erwarten war.
                                        docker ist applikations-absteraktion, alle notwendigen tools/programme sind im image definiert.
                                        nur veränderliche daten kommen in volumes. die volumes können optional in einem pfad geschrieben werden, ansonsten legt docker die intern ab.
                                        wenn du was aktuelleres haben willst, dann könntest du
                                        A) einen aktuelleren container von buanet nehmen, bei dem ein aktuelleres node und betriebssystem definiert ist?
                                        B) das dockerfile von buanet + installationsskript von iobroker nehmen, anpassen und ein eigenes image bauen.
                                        aktuell sieht man, das bookworm definiert ist (zeile1 dockerfile)
                                        und node wird im sinstallationsskript von iobroker mit v20 definiert (zeile 46 install.sh)
                                        https://github.com/buanet/ioBroker.docker/blob/main/debian12/Dockerfile
                                        https://iobroker.live/install.sh
                                          Glücklicher Zufall.
                                          Die nodesource-Version von nodejs ist anders gebaut als das was du dir da per 'n' reinklatschst.
                                          Kann gut gehen, tut es aber meist nicht.
                                          31.6k
                                          79.4k
                                          1110
