    3. Off Topic
    4. Proxmox
    5. ioBroker Umzug von PI4 auf mini PC
      Altersrentner @crunchip last edited by Altersrentner
      habe den Beitrag entfernt
      MfG Michael
        Altersrentner @Altersrentner last edited by Altersrentner
        @altersrentner Frohe Ostern.
        nachdem mir gestern mein LXC influx abgestürzt ist habe ich ihn heute neu aufgesetzt.
        michael@influxdbv1:~$ sudo rm /etc/apt/sources.list.d/influ*
        michael@influxdbv1:~$ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        michael@influxdbv1:~$ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        influxdata-archive_compat.key: OK
        michael@influxdbv1:~$ echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        michael@influxdbv1:~$ rm influxdata-archive_compat.key
        michael@influxdbv1:~$ sudo apt-get update && sudo apt-get install influxdb
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://deb.nodesource.com/node_14.x bookworm InRelease
        Reading package lists... Done
        Building dependency tree... Done
        influxdb is already the newest version (1.8.10-1).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        michael@influxdbv1:~$ sudo service influxdb start
        michael@influxdbv1:~$ sudo service influxdb status
        * influxdb.service - InfluxDB is an open-source, distributed, time series database
             Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enabled)
             Active: active (running) since Sun 2024-03-31 10:12:07 CEST; 28min ago
               Docs: https://docs.influxdata.com/influxdb/
            Process: 11736 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
           Main PID: 11737 (influxd)
              Tasks: 10 (limit: 18969)
             Memory: 12.7M
                CPU: 1.036s
             CGroup: /system.slice/influxdb.service
                     `-11737 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
        Mar 31 10:40:21 influxdbv1 influxd-systemd-start.sh[11737]: [httpd] 192.168.178.140 - - [31/Mar/2024:10:40:21 +0200] "POS>
        Mar 31 10:40:31 influxdbv1 influxd-systemd-start.sh[11737]: [httpd] 192.168.178.140 - - [31/Mar/2024:10:40:31 +0200] "POS>
        Mar 31 10:40:41 influxdbv1 influxd-systemd-start.sh[11737]: [httpd] 192.168.178.140 - - [31/Mar/2024:10:40:41 +0200] "POS>
        Mar 31 10:40:51 influxdbv1 influxd-systemd-start.sh[11737]: [httpd] 192.168.178.140 - - [31/Mar/2024:10:40:51 +0200] "POS>
        Der Status sagt mir das er läuft.
        Wenn ich Influx aber unter der IP aufrufe, kommt folgender Fehler:
        404 page not found
        Wie kann ich das Osterei ausbrüten, so das Influx erreichbar ist
        Mit freundlichen Ostergrüßen
        Michael
        Im ioBroker ist die Instanz verbunden und Grafana ist auch verbunden .
        Dort im Explorer unter Query /select measurement werden die geloggten Daten angezeigt.
        komisch😕
        Meister Mopper crunchip 2 Replies Last reply Reply Quote 0
        • Meister Mopper
          Meister Mopper @Altersrentner last edited by
          @altersrentner sagte in ioBroker Umzug von PI4 auf mini PC:
          Wie rufst du den im Browser auf?
            crunchip Forum Testing Most Active @Altersrentner last edited by
            dann dürfte sowas eigentlich gar nicht kommen
            aus welchem Grund?
              Altersrentner @Meister Mopper last edited by
              @meister-mopper sagte in ioBroker Umzug von PI4 auf mini PC:
              Guten Morgen.
              Ich rufe ihn unter
              http://192.xxx.xxx.51:8086
              auf
              @crunchip sagte in ioBroker Umzug von PI4 auf mini PC:
              aus welchem Grund?
              Der PC hatte nicht mehr reagiert, somit musste ich ihn hart runterfahren.
              Selbiges war auch bei dem Server. ioBroker und Grafana waren zu dem Zeitpunkt aber gestoppt.
              Nach der Neuinstallation war wie gesagt die ioBroker influx.0 verbunden und der Verbindungstest zeigte OK.
              Bei Grafana sind die geloggten Werte wie zu sehen vorhanden.
              Ist alles komisch.
              [Link Text](bafc9716-9392-44d8-aa53-a39a6999a4b3-image.png Link Adresse)
              Wünsche noch einen schönen Ostermontag
              Michael
                crunchip Forum Testing Most Active @Altersrentner last edited by crunchip
                Was möchtest du damit aufrufen?
                Du hast doch influxdb v1. X
                Und der Grund des nicht mehr reagieren deines Rechners?
                  Oha, ja V1 ist nicht über den Browser aufrufbar.
                  Kann ich nicht sagen, habe keine Erklärung.
                  crunchip arteck 2 Replies Last reply Reply Quote 0
                    @altersrentner ohne zu wissen warum kann dies ja jederzeit wieder auftreten.
                    Logmeldungen im proxmox beobachten, bzw nachsehen ob da etwas verdächtiges zu finden ist.
                    ansonsten
                    wie sieht deine Verteilung an LXC`s im Bezug auf Plattengröße und Ram aus?
                    auch die Proxmox Oberfläche gibt ja erste Anhaltspunkte über CPU, Serverlast und Speicher(Filtern oben rechts, Std Tag Woche)
                      arteck Developer Most Active @Altersrentner last edited by
                      dann schau im LOG nach...
                        Stimme ich dir zu. Ist eben geschehen. Werde auf die Logmeldungen achten.
                        Ihr meint doch die ?!
                        [Link Text](32456969-ed42-4aa7-84d7-93a9355ecc72-image.png Link Adresse)
                        [Link Text](43b1ceae-040d-4b27-9c48-e8a07db06dac-image.png Link Adresse)
                        [Link Text](3d1da14b-d905-4a41-a894-e0ffb8733d7f-image.png Link Adresse)
                        [Link Text](d98c570d-5623-407a-82f4-3b55a88c5ddb-image.png Link Adresse)
                        reichen die Angaben? Oder werden andere benötigt?
                          Ihr meint doch die
                          unter anderem ja
                          dein metric server musst du anpassen, deine IP ist wohl noch falsch(hast ja eine neue influxdb IP
                          der einzelnen LXC und
                            Verstehe ich nicht, aber hier ist doch die IP für influx i.O
                              @altersrentner dann klick mal drauf und dann auf bearbeiten und zeig die Einstellung
                                dann klick mal drauf und dann auf bearbeiten und zeig die Einstellunge
                                d448fc65-a42c-46a7-9bac-327f428127ee-image.png Link Adresse
                                  @altersrentner da hast du wohl mal was falsch eingestellt, sollte so aussehen
                                  lösch doch mal den ganzen Eintrag und leg ihn neu an
                                    Deine Einstellung ist doch wie meine nur Organisation und Bucket
                                    hast du oder habe ich andere Namen vergeben.
                                    Bei mir die IP ist die von dem LXC
                                      eben, das muss proxmox heissen bei influxdb v1.x
                                        OK;
                                        woher der admin kommt ist mir unklar.
                                        Habe nur in der Anmeldung bei Grafana admin vergeben.
                                        Iobroker wurde nur bei Database vergeben.
                                        Komisch.
                                        Wenn das so sein muss wie bei dir, wie kann ich das umstellen?
                                          und dann neu Hinzufügen
                                          da musst du nur nen Namen, IP und Port vergeben
                                          steht auch in der Beschreibung
                                            unter welchem Reiter
                                            Rechenzentrum/?????
                                            soll ich löschen?
                                            Wenn Zone, da steht nichts.
                                            1.2k
                                            81.1k
                                            iobroker proxmox vms
                                            10
                                            172
                                            18759
