    4. Admin Weboberfläche - nicht mehr erreichbar
    • O
      okifet96 last edited by
      das steht im vorletzten Log:
      ` > 2017-12-19 01:17:20.086 - ^[[32minfo^[[39m: host.raspiIObroker Delete log file iobroker.2017-12-12.log
      2017-12-19 16:17:57.375 - ^[[32minfo^[[39m: admin.0 Request actual repository…
      2017-12-19 16:17:57.437 - ^[[32minfo^[[39m: host.raspiIObroker Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2017-12-19 16:17:57.581 - ^[[33mwarn^[[39m: host.raspiIObroker warning: Cannot read "http://download.iobroker.net/sources-dist.json"
      2017-12-19 16:17:57.585 - ^[[32minfo^[[39m: admin.0 Repository received successfully. `
      das letzte Log ist sehr sehr lang, hier die ersten Zeilen:
      `2017-12-20 01:17:20.221  - ^[[32minfo^[[39m: host.raspiIObroker Delete log file iobroker.2017-12-13.log
      2017-12-20 05:27:13.193  - ^[[32minfo^[[39m: sonoff.0 Client [Sonoff_bridge_1] connected
      2017-12-20 05:32:14.218  - ^[[32minfo^[[39m: sonoff.0 Client [Sonoff_bridge_1] connected
      2017-12-20 05:33:26.823  - ^[[32minfo^[[39m: sonoff.0 Client [undefined] closed
      2017-12-20 05:34:17.142  - ^[[32minfo^[[39m: host.raspiIObroker received SIGTERM
      2017-12-20 05:34:17.157  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.admin.0
      2017-12-20 05:34:17.158  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.admin.0 killing pid 630
      2017-12-20 05:34:17.160  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.discovery.0
      2017-12-20 05:34:17.160  - ^[[33mwarn^[[39m: host.raspiIObroker stopInstance system.adapter.discovery.0 not running
      2017-12-20 05:34:17.161  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.hm-rpc.0
      2017-12-20 05:34:17.161  - ^[[33mwarn^[[39m: host.raspiIObroker stopInstance system.adapter.hm-rpc.0 not running
      2017-12-20 05:34:17.162  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.hm-rega.0
      2017-12-20 05:34:17.162  - ^[[33mwarn^[[39m: host.raspiIObroker stopInstance system.adapter.hm-rega.0 not running
      2017-12-20 05:34:17.162  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.web.0
      2017-12-20 05:34:17.163  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.web.0 killing pid 640
      2017-12-20 05:34:17.167  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.vis.0
      2017-12-20 05:34:17.168  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.history.0
      2017-12-20 05:34:17.168  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.history.0 killing pid 650
      2017-12-20 05:34:17.169  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.javascript.0
      2017-12-20 05:34:17.170  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.javascript.0 killing pid 660
      2017-12-20 05:34:17.170  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.mobile.0
      2017-12-20 05:34:17.171  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.socketio.0
      2017-12-20 05:34:17.172  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.socketio.0 killing pid 670
      2017-12-20 05:34:17.172  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.cloud.0
      2017-12-20 05:34:17.173  - ^[[33mwarn^[[39m: host.raspiIObroker stopInstance system.adapter.cloud.0 not running
      2017-12-20 05:34:17.173  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.rpi2.0
      2017-12-20 05:34:17.174  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.rpi2.0 killing pid 680
      2017-12-20 05:34:17.179  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.sonoff.0
      2017-12-20 05:34:17.180  - ^[[32minfo^[[39m: host.raspiIObroker stopInstance system.adapter.sonoff.0 killing pid 726
      2017-12-20 05:34:17.166  - ^[[32minfo^[[39m: web.0 terminating http server on port 8082
      2017-12-20 05:34:17.179  - ^[[32minfo^[[39m: web.0 terminated http server on port 8082
      2017-12-20 05:34:17.163  - ^[[32minfo^[[39m: admin.0 terminating http server on port 8081
      2017-12-20 05:34:17.176  - ^[[32minfo^[[39m: socketio.0 terminating http server on port 8084
      2017-12-20 05:34:18.673  - ^[[32minfo^[[39m: admin.0 terminating with timeout
      2017-12-20 05:34:18.690  - ^[[32minfo^[[39m: sonoff.0 terminating with timeout
      2017-12-20 05:34:18.752  - ^[[32minfo^[[39m: host.raspiIObroker instance system.adapter.admin.0 terminated with code 0 (OK)
      2017-12-20 05:34:18.753  - ^[[32minfo^[[39m: host.raspiIObroker All instances are stopped.
      2017-12-20 05:34:18.759  - ^[[32minfo^[[39m: host.raspiIObroker instance system.adapter.sonoff.0 terminated with code 0 (OK)
      2017-12-20 05:34:18.760  - ^[[32minfo^[[39m: host.raspiIObroker All instances are stopped.[/code]`
      und steht dann ein wenig später:
      `~~[code]~~2017-12-20 10:44:41.269  - ^[[32minfo^[[39m: iobroker exit 0
      2017-12-20 10:44:43.508  - ^[[32minfo^[[39m: host.raspiIObroker iobroker.js-controller version 1.2.1 js-controller starting
      2017-12-20 10:44:43.524  - ^[[32minfo^[[39m: host.raspiIObroker Copyright (c) 2014-2017 bluefox, 2014 hobbyquaker
      2017-12-20 10:44:43.526  - ^[[32minfo^[[39m: host.raspiIObroker hostname: raspiIObroker, node: v6.12.0
      2017-12-20 10:44:43.528  - ^[[32minfo^[[39m: host.raspiIObroker ip addresses: 192.168.1.130 fe80::ce93:7be5:963f:7f87
      2017-12-20 10:44:43.791  - ^[[32minfo^[[39m: host.raspiIObroker  inMem-objects listening on port 9001
      2017-12-20 10:44:43.827  - ^[[31merror^[[39m: Another instance is running or some application uses port!
      2017-12-20 10:44:43.828  - ^[[31merror^[[39m: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
      2017-12-20 10:44:43.848  - ^[[32minfo^[[39m: iobroker _restart[/code]`[/code]
      • AlCalzone
        @okifet96:
        Ich habe dann testweise eine neue Admin Instanz hinzugefügt:
        iobroker add admin --port 8089
        nun kann ich die AdminWeboberfläche auf ip:8089 wieder aufrufen,
        jedoch läuft jetzt noch eine weitere auf 8081 die nicht funktioniert….. `
        Läuft die erste Instanz möglicherweise mit SSL/Authentifizierung?
        Wenn ja, die könntest du mal deaktivieren:
        iobroker set admin.0 --ssl false
        iobroker set admin.0 --auth false
        Wenn das auch nicht hilft, könntest du mal probieren den Admin-Adapter komplett zu löschen und neu zu installieren.
        cd /opt/iobroker
        sudo iobroker stop
        sudo iobroker del admin
        sudo npm install iobroker.admin --production
        sudo iobroker add admin
        sudo iobroker start
        • O
          Hallo Al Calzone,
          habe deinen Vorschlag probiert:
          hier die Terminal ausgabe - und vorweg, geht noch immer nicht:
          ! pi@raspiIObroker:/opt/iobroker $ iobroker set admin.0 –ssl false
          ! Adapter "admin.0" has no setting "ssl".
          ! No parameters set.
          ! pi@raspiIObroker:/opt/iobroker $ cd /opt/iobroker
          ! pi@raspiIObroker:/opt/iobroker $ sudo iobroker stop
          ! Stopping iobroker controller daemon...
          ! iobroker controller daemon stopped.
          ! Exit code for "killall.sh": 123
          ! pi@raspiIObroker:/opt/iobroker $ sudo iobroker del admin
          ! host.raspiIObroker Counted 2 instances of admin
          ! host.raspiIObroker Deleting 2 object(s).
          ! host.raspiIObroker Deleting 1 object(s).
          ! host.raspiIObroker delete /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../iobroker.admin
          ! host.raspiIObroker Counted 1 adapters for admin
          ! host.raspiIObroker Counted 2 channels of admin
          ! host.raspiIObroker Counted 21 states of admin
          ! host.raspiIObroker Deleting 22 object(s).
          ! Delete file admin.admin/_data.json
          ! Delete file admin.admin/admin.png
          ! Delete file admin.admin/index.html
          ! Delete file admin.admin/words.js
          ! host.raspiIObroker Deleting 0 state(s).
          ! pi@raspiIObroker:/opt/iobroker $ sudo npm install iobroker.admin --production
          ! iobroker@1.0.0 /opt/iobroker
          ! `-- (empty)
          ! npm ERR! code 1
          ! pi@raspiIObroker:/opt/iobroker $ sudo iobroker add admin
          ! host.raspiIObroker install adapter admin
          ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.admin"
          ! got /opt/iobroker/node_modules/iobroker.admin/admin
          ! upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
          ! upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
          ! upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
          ! host.raspiIObroker object system.adapter.admin created
          ! host.raspiIObroker create instance admin
          ! host.raspiIObroker object admin.0.info created
          ! host.raspiIObroker object system.adapter.admin.upload created
          ! host.raspiIObroker object system.adapter.admin.0.outputCount created
          ! host.raspiIObroker object system.adapter.admin.0.inputCount created
          ! host.raspiIObroker object system.adapter.admin.0.uptime created
          ! host.raspiIObroker object system.adapter.admin.0.memRss created
          ! host.raspiIObroker object system.adapter.admin.0.memHeapTotal created
          ! host.raspiIObroker object system.adapter.admin.0.memHeapUsed created
          ! host.raspiIObroker object system.adapter.admin.0.connected created
          ! host.raspiIObroker object system.adapter.admin.0.alive created
          ! host.raspiIObroker object system.adapter.admin.0 created
          ! pi@raspiIObroker:/opt/iobroker $ sudo iobroker start
          ! Starting iobroker controller daemon…
          ! iobroker controller daemon started. PID: 2185
            Hattest du redis laufen?
            @okifet96:
            tcp 0 0 127.0.0.1:6379 127.0.0.1:37260 ESTABLISHED - `
            Dann gibt es auch kein :9000
            Rainer
            • O
              @Homoran:
              @okifet96:
              Rainer `
              ne,
              ich weis aber auch nicht was das ist 😞 ,
              wie geschrieben, ein fertiges image von iobroker geladen,
              ein paar sonoffs installiert und das wars, sonst keinerlei Modifikationen vom Image.
              a, doch, die swap datei hab ich deaktiviert da ich scheinbar genug speicher frei hab und ich die sd karte schonen möchte.
                @okifet96:
                wie geschrieben, ein fertiges image von iobroker geladen, `
                Dann hast du redis 😉
                Rainer
                  > Failed to write pidfile (EACCES)
                  das richt doch nach SD voll
                  mach mal
                  df -h
                  und poste die Ausgabe
                  • O
                    @arteck:
                    mach mal
                    df -h
                    und poste die Ausgabe `
                    pi@raspiIObroker:~ $ df -h
                    Filesystem Size Used Avail Use% Mounted on
                    /dev/root 15G 1.5G 13G 11% /
                    devtmpfs 460M 0 460M 0% /dev
                    tmpfs 464M 0 464M 0% /dev/shm
                    tmpfs 464M 6.2M 458M 2% /run
                    tmpfs 5.0M 4.0K 5.0M 1% /run/lock
                    tmpfs 464M 0 464M 0% /sys/fs/cgroup
                    /dev/mmcblk0p1 42M 21M 21M 51% /boot
                    tmpfs 93M 0 93M 0% /run/user/1000
                      @okifet96:
                      Über ssh hab ich dann versucht den iobroker zu stoppen und zu starten, da kam mal die Fehlermeldung das er nicht läuft, starten ging aber auch nicht. Es kam die Fehlermeldung:
                      pi@raspiIObroker:~ $ iobroker start
                      iobroker controller daemon failed to start: Failed to write pidfile (EACCES)
                      Error: Failed to write pidfile (EACCES) `
                      das liegt am fehlenden sudo.
                      Rainer
                        @Homoran:
                        @okifet96:
                        Rainer `
                        jo jetzt auch gemerkt :oops:
                        • AlCalzone
                          Also die Installation sieht normal aus. Wenn du jetzt doch wieder einen zweiten Admin installierst, kommst du dann rein?
                          Dann poste mal Screenshots von der Instanzen-Liste und den Einstellungen von admin.0 und admin.1, eventuell kommen wir dann dem Fehler auf die Schliche.
                          • O
                            Ja, mit der 2. Admin Instanz komm ich rein.
                            hier die Screenshots:
                            • AlCalzone
                              Beide laufen anscheinend, ich sehe keinen Unterschied. Da bin ich ehrlich gesagt überfragt. @Bluefox, Ideen?
                              Btw, du kann hier im Forum Bilder hochladen und direkt in Posts einfügen. Bitte in Zukunft so machen anstatt über externe Quellen.
                              • O
                                @AlCalzone:
                                Btw, du kann hier im Forum Bilder hochladen und direkt in Posts einfügen. Bitte in Zukunft so machen anstatt über externe Quellen. `
                                alles klar, hab gleich mal die Bilder ausgetauscht :oops:
                                Danke vorerst mal!!
                                • AlCalzone
                                  Was steht im Log? Der ist rot!
                                  • O
                                    jetzt ist der nicht mehr rot,
                                    da steht nix besonderes drin
                                    Logdatei:
                                    ! web.0 2017-12-21 14:48:43.675 info 2017-12-21T13:48:43.675Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:48:30.121 info 2017-12-21T13:48:30.121Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:48:16.984 info 2017-12-21T13:48:16.984Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:48:07.001 info 2017-12-21T13:48:07.000Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:57.025 info 2017-12-21T13:47:57.025Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:47.036 info 2017-12-21T13:47:47.036Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:40.464 info 2017-12-21T13:47:40.464Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:39.439 info 2017-12-21T13:47:39.438Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:39.110 info 2017-12-21T13:47:39.109Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:39.068 info 2017-12-21T13:47:39.067Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:38.505 info 2017-12-21T13:47:38.505Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:38.458 info 2017-12-21T13:47:38.457Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:47:12.107 info 2017-12-21T13:47:12.107Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:43:11.168 info 2017-12-21T13:43:11.168Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:43:10.811 info 2017-12-21T13:43:10.811Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:40:58.577 info 2017-12-21T13:40:58.577Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:36:55.383 info 2017-12-21T13:36:55.382Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:36:41.276 info 2017-12-21T13:36:41.275Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:34:55.478 info 2017-12-21T13:34:55.478Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:30:31.452 info 2017-12-21T13:30:31.451Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:30:18.627 info 2017-12-21T13:30:18.627Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:28:27.925 info 2017-12-21T13:28:27.925Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:24:12.716 info 2017-12-21T13:24:12.716Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:24:02.718 info 2017-12-21T13:24:02.718Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:22:01.512 info 2017-12-21T13:22:01.512Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:17:55.280 info 2017-12-21T13:17:55.280Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:17:46.997 info 2017-12-21T13:17:46.996Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:15:35.602 info 2017-12-21T13:15:35.602Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:11:32.505 info 2017-12-21T13:11:32.505Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:11:26.758 info 2017-12-21T13:11:26.757Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:09:33.759 info 2017-12-21T13:09:33.759Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:05:11.774 info 2017-12-21T13:05:11.773Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:05:06.669 info 2017-12-21T13:05:06.668Z Connected system.user.admin
                                    ! web.0 2017-12-21 14:03:07.439 info 2017-12-21T13:03:07.439Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:58:55.185 info 2017-12-21T12:58:55.184Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:58:45.985 info 2017-12-21T12:58:45.985Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:56:40.843 info 2017-12-21T12:56:40.842Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:52:31.808 info 2017-12-21T12:52:31.808Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:50:38.807 info 2017-12-21T12:50:38.806Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:46:14.477 info 2017-12-21T12:46:14.477Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:46:04.802 info 2017-12-21T12:46:04.801Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:44:12.476 info 2017-12-21T12:44:12.475Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:39:51.894 info 2017-12-21T12:39:51.894Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:39:45.799 info 2017-12-21T12:39:45.798Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:37:46.443 info 2017-12-21T12:37:46.443Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:33:34.906 info 2017-12-21T12:33:34.905Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:33:26.804 info 2017-12-21T12:33:26.804Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:31:20.313 info 2017-12-21T12:31:20.313Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:27:14.402 info 2017-12-21T12:27:14.402Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:27:01.551 info 2017-12-21T12:27:01.551Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:25:17.441 info 2017-12-21T12:25:17.441Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:20:52.560 info 2017-12-21T12:20:52.560Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:20:45.156 info 2017-12-21T12:20:45.156Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:18:51.210 info 2017-12-21T12:18:51.210Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:14:33.030 info 2017-12-21T12:14:33.030Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:14:29.766 info 2017-12-21T12:14:29.766Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:12:24.715 info 2017-12-21T12:12:24.714Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:08:14.168 info 2017-12-21T12:08:14.168Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:08:09.911 info 2017-12-21T12:08:09.911Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:05:56.769 info 2017-12-21T12:05:56.768Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:01:53.834 info 2017-12-21T12:01:53.834Z Connected system.user.admin
                                    ! web.0 2017-12-21 13:01:44.985 info 2017-12-21T12:01:44.984Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:59:55.797 info 2017-12-21T11:59:55.797Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:55:34.344 info 2017-12-21T11:55:34.343Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:55:25.299 info 2017-12-21T11:55:25.299Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:53:30.112 info 2017-12-21T11:53:30.112Z Connected system.user.admin
                                    ! admin.1 2017-12-21 12:50:13.968 info Repository received successfully.
                                    ! host.raspiIObroker 2017-12-21 12:50:13.481 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                    ! admin.1 2017-12-21 12:50:13.296 info Request actual repository…
                                    ! web.0 2017-12-21 12:49:11.470 info 2017-12-21T11:49:11.470Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:49:07.866 info 2017-12-21T11:49:07.866Z Connected system.user.admin
                                    ! admin.0 2017-12-21 12:47:33.344 info Repository received successfully.
                                    ! host.raspiIObroker 2017-12-21 12:47:32.810 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                    ! admin.0 2017-12-21 12:47:32.645 info Request actual repository...
                                    ! web.0 2017-12-21 12:47:03.875 info 2017-12-21T11:47:03.874Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:42:51.885 info 2017-12-21T11:42:51.884Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:42:51.544 info 2017-12-21T11:42:51.544Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:40:36.802 info 2017-12-21T11:40:36.802Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:36:33.501 info 2017-12-21T11:36:33.501Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:34:35.125 info 2017-12-21T11:34:35.125Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:30:13.377 info 2017-12-21T11:30:13.377Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:29:59.333 info 2017-12-21T11:29:59.332Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:28:08.829 info 2017-12-21T11:28:08.829Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:23:52.143 info 2017-12-21T11:23:52.143Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:23:43.191 info 2017-12-21T11:23:43.191Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:21:42.199 info 2017-12-21T11:21:42.199Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:17:32.967 info 2017-12-21T11:17:32.966Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:17:28.700 info 2017-12-21T11:17:28.697Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:15:39.577 info 2017-12-21T11:15:39.577Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:11:13.077 info 2017-12-21T11:11:13.077Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:11:06.227 info 2017-12-21T11:11:06.226Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:09:13.136 info 2017-12-21T11:09:13.135Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:04:51.793 info 2017-12-21T11:04:51.793Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:04:50.937 info 2017-12-21T11:04:50.937Z Connected system.user.admin
                                    ! web.0 2017-12-21 12:02:43.905 info 2017-12-21T11:02:43.905Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:58:32.664 info 2017-12-21T10:58:32.664Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:58:24.961 info 2017-12-21T10:58:24.961Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:56:38.898 info 2017-12-21T10:56:38.898Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:52:12.329 info 2017-12-21T10:52:12.329Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:52:04.445 info 2017-12-21T10:52:04.445Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:50:13.130 info 2017-12-21T10:50:13.129Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:45:52.489 info 2017-12-21T10:45:52.489Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:45:50.078 info 2017-12-21T10:45:50.078Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:43:44.467 info 2017-12-21T10:43:44.467Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:39:32.347 info 2017-12-21T10:39:32.347Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:39:26.574 info 2017-12-21T10:39:26.574Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:37:18.384 info 2017-12-21T10:37:18.384Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:33:11.683 info 2017-12-21T10:33:11.683Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:32:57.853 info 2017-12-21T10:32:57.853Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:31:15.794 info 2017-12-21T10:31:15.794Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:26:51.678 info 2017-12-21T10:26:51.678Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:26:47.797 info 2017-12-21T10:26:47.797Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:24:49.944 info 2017-12-21T10:24:49.944Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:20:31.969 info 2017-12-21T10:20:31.969Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:20:25.828 info 2017-12-21T10:20:25.827Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:16:42.367 info 2017-12-21T10:16:42.367Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:14:12.927 info 2017-12-21T10:14:12.927Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:14:09.293 info 2017-12-21T10:14:09.293Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:12:20.447 info 2017-12-21T10:12:20.447Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:07:51.756 info 2017-12-21T10:07:51.756Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:07:47.530 info 2017-12-21T10:07:47.530Z Connected system.user.admin
                                    ! web.0 2017-12-21 11:01:32.563 info 2017-12-21T10:01:32.563Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:57:35.839 info 2017-12-21T09:57:35.839Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:51:35.929 info 2017-12-21T09:51:35.929Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:36.559 info 2017-12-21T09:45:36.559Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:36.072 info 2017-12-21T09:45:36.072Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:33.997 info 2017-12-21T09:45:33.997Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:27.301 info 2017-12-21T09:45:27.301Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:20.169 info 2017-12-21T09:45:20.169Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:07.946 info 2017-12-21T09:45:07.946Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:02.367 info 2017-12-21T09:45:02.367Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:45:01.626 info 2017-12-21T09:45:01.626Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:52.938 info 2017-12-21T09:44:52.937Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:51.926 info 2017-12-21T09:44:51.926Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:47.000 info 2017-12-21T09:44:46.998Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:28.416 info 2017-12-21T09:44:28.416Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:26.393 info 2017-12-21T09:44:26.393Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:18.616 info 2017-12-21T09:44:18.616Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:10.851 info 2017-12-21T09:44:10.851Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:10.040 info 2017-12-21T09:44:10.040Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:44:02.076 info 2017-12-21T09:44:02.076Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:43:47.960 info 2017-12-21T09:43:47.959Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:43:38.082 info 2017-12-21T09:43:38.082Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:43:29.982 info 2017-12-21T09:43:29.982Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:43:07.253 info 2017-12-21T09:43:07.253Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:39:35.971 info 2017-12-21T09:39:35.971Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:37:36.203 info 2017-12-21T09:37:36.203Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:33:35.956 info 2017-12-21T09:33:35.956Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:31:33.276 info 2017-12-21T09:31:33.275Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:27:36.001 info 2017-12-21T09:27:36.001Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:25:31.660 info 2017-12-21T09:25:31.660Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:21:35.982 info 2017-12-21T09:21:35.982Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:19:54.106 info 2017-12-21T09:19:54.105Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:15:35.556 info 2017-12-21T09:15:35.556Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:13:53.456 info 2017-12-21T09:13:53.456Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:09:35.547 info 2017-12-21T09:09:35.547Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:07:52.709 info 2017-12-21T09:07:52.709Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:03:35.566 info 2017-12-21T09:03:35.566Z Connected system.user.admin
                                    ! web.0 2017-12-21 10:01:51.350 info 2017-12-21T09:01:51.350Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:57:36.095 info 2017-12-21T08:57:36.095Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:55:48.983 info 2017-12-21T08:55:48.983Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:51:35.576 info 2017-12-21T08:51:35.576Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:49:48.064 info 2017-12-21T08:49:48.064Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:45:36.213 info 2017-12-21T08:45:36.213Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:43:47.259 info 2017-12-21T08:43:47.259Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:39:36.143 info 2017-12-21T08:39:36.142Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:37:46.401 info 2017-12-21T08:37:46.401Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:33:36.147 info 2017-12-21T08:33:36.147Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:31:45.592 info 2017-12-21T08:31:45.592Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:27:36.147 info 2017-12-21T08:27:36.147Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:25:44.846 info 2017-12-21T08:25:44.846Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:21:36.227 info 2017-12-21T08:21:36.227Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:19:43.740 info 2017-12-21T08:19:43.739Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:15:35.718 info 2017-12-21T08:15:35.717Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:13:37.158 info 2017-12-21T08:13:37.158Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:09:35.940 info 2017-12-21T08:09:35.940Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:07:30.507 info 2017-12-21T08:07:30.507Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:03:36.219 info 2017-12-21T08:03:36.219Z Connected system.user.admin
                                    ! web.0 2017-12-21 09:01:54.372 info 2017-12-21T08:01:54.372Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:57:35.796 info 2017-12-21T07:57:35.796Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:55:53.049 info 2017-12-21T07:55:53.048Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:51:36.227 info 2017-12-21T07:51:36.226Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:49:52.003 info 2017-12-21T07:49:52.003Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:45:36.282 info 2017-12-21T07:45:36.282Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:43:48.829 info 2017-12-21T07:43:48.829Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:39:36.276 info 2017-12-21T07:39:36.276Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:37:48.071 info 2017-12-21T07:37:48.070Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:33:36.265 info 2017-12-21T07:33:36.265Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:31:46.973 info 2017-12-21T07:31:46.973Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:27:36.067 info 2017-12-21T07:27:36.067Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:25:36.788 info 2017-12-21T07:25:36.788Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:21:36.305 info 2017-12-21T07:21:36.305Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:19:36.850 info 2017-12-21T07:19:36.850Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:15:36.360 info 2017-12-21T07:15:36.360Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:13:35.973 info 2017-12-21T07:13:35.973Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:09:36.198 info 2017-12-21T07:09:36.198Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:07:36.295 info 2017-12-21T07:07:36.295Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:03:35.985 info 2017-12-21T07:03:35.985Z Connected system.user.admin
                                    ! web.0 2017-12-21 08:01:54.866 info 2017-12-21T07:01:54.866Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:57:36.456 info 2017-12-21T06:57:36.456Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:55:52.704 info 2017-12-21T06:55:52.703Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:51:36.423 info 2017-12-21T06:51:36.423Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:49:50.654 info 2017-12-21T06:49:50.654Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:45:36.462 info 2017-12-21T06:45:36.461Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:43:45.125 info 2017-12-21T06:43:45.123Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:39:36.480 info 2017-12-21T06:39:36.480Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:37:40.542 info 2017-12-21T06:37:40.541Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:33:36.473 info 2017-12-21T06:33:36.473Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:31:39.004 info 2017-12-21T06:31:39.003Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:27:36.486 info 2017-12-21T06:27:36.485Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:25:34.688 info 2017-12-21T06:25:34.688Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:21:36.333 info 2017-12-21T06:21:36.333Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:19:54.442 info 2017-12-21T06:19:54.442Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:15:36.233 info 2017-12-21T06:15:36.233Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:13:53.788 info 2017-12-21T06:13:53.788Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:09:36.590 info 2017-12-21T06:09:36.590Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:07:49.427 info 2017-12-21T06:07:49.426Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:03:36.575 info 2017-12-21T06:03:36.574Z Connected system.user.admin
                                    ! web.0 2017-12-21 07:01:47.995 info 2017-12-21T06:01:47.995Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:57:36.585 info 2017-12-21T05:57:36.585Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:55:45.178 info 2017-12-21T05:55:45.178Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:51:36.611 info 2017-12-21T05:51:36.611Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:49:44.045 info 2017-12-21T05:49:44.045Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:45:36.618 info 2017-12-21T05:45:36.617Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:43:43.126 info 2017-12-21T05:43:43.126Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:39:36.519 info 2017-12-21T05:39:36.519Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:37:39.870 info 2017-12-21T05:37:39.870Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:33:36.502 info 2017-12-21T05:33:36.502Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:31:38.548 info 2017-12-21T05:31:38.548Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:27:36.335 info 2017-12-21T05:27:36.334Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:25:36.997 info 2017-12-21T05:25:36.997Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:21:36.367 info 2017-12-21T05:21:36.367Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:19:34.500 info 2017-12-21T05:19:34.500Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:15:36.374 info 2017-12-21T05:15:36.373Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:13:31.824 info 2017-12-21T05:13:31.823Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:09:36.266 info 2017-12-21T05:09:36.266Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:07:55.344 info 2017-12-21T05:07:55.343Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:03:36.313 info 2017-12-21T05:03:36.313Z Connected system.user.admin
                                    ! web.0 2017-12-21 06:01:52.097 info 2017-12-21T05:01:52.096Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:57:36.828 info 2017-12-21T04:57:36.827Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:55:51.069 info 2017-12-21T04:55:51.068Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:51:36.791 info 2017-12-21T04:51:36.791Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:49:49.758 info 2017-12-21T04:49:49.758Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:45:36.881 info 2017-12-21T04:45:36.881Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:43:48.444 info 2017-12-21T04:43:48.444Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:39:36.874 info 2017-12-21T04:39:36.874Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:37:44.841 info 2017-12-21T04:37:44.841Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:33:36.918 info 2017-12-21T04:33:36.917Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:31:43.569 info 2017-12-21T04:31:43.569Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:27:36.895 info 2017-12-21T04:27:36.894Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:25:40.579 info 2017-12-21T04:25:40.579Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:21:36.886 info 2017-12-21T04:21:36.885Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:19:36.911 info 2017-12-21T04:19:36.911Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:15:36.932 info 2017-12-21T04:15:36.931Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:13:34.041 info 2017-12-21T04:13:34.040Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:09:36.926 info 2017-12-21T04:09:36.926Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:07:55.038 info 2017-12-21T04:07:55.037Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:03:36.598 info 2017-12-21T04:03:36.598Z Connected system.user.admin
                                    ! web.0 2017-12-21 05:01:54.217 info 2017-12-21T04:01:54.217Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:57:37.000 info 2017-12-21T03:57:36.999Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:55:52.773 info 2017-12-21T03:55:52.773Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:51:37.024 info 2017-12-21T03:51:37.024Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:49:51.910 info 2017-12-21T03:49:51.910Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:45:36.567 info 2017-12-21T03:45:36.566Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:43:49.852 info 2017-12-21T03:43:49.852Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:39:37.084 info 2017-12-21T03:39:37.084Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:37:49.214 info 2017-12-21T03:37:49.213Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:33:37.047 info 2017-12-21T03:33:37.047Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:31:48.276 info 2017-12-21T03:31:48.275Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:27:37.135 info 2017-12-21T03:27:37.135Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:25:47.455 info 2017-12-21T03:25:47.455Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:21:37.130 info 2017-12-21T03:21:37.129Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:19:45.952 info 2017-12-21T03:19:45.952Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:15:37.159 info 2017-12-21T03:15:37.159Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:13:45.021 info 2017-12-21T03:13:45.021Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:09:37.119 info 2017-12-21T03:09:37.119Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:07:43.715 info 2017-12-21T03:07:43.714Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:03:37.195 info 2017-12-21T03:03:37.195Z Connected system.user.admin
                                    ! web.0 2017-12-21 04:01:42.677 info 2017-12-21T03:01:42.677Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:57:37.141 info 2017-12-21T02:57:37.141Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:55:40.198 info 2017-12-21T02:55:40.198Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:51:37.198 info 2017-12-21T02:51:37.198Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:49:39.206 info 2017-12-21T02:49:39.206Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:45:37.233 info 2017-12-21T02:45:37.233Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:43:38.202 info 2017-12-21T02:43:38.202Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:39:37.180 info 2017-12-21T02:39:37.180Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:37:35.371 info 2017-12-21T02:37:35.371Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:33:36.940 info 2017-12-21T02:33:36.940Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:31:31.580 info 2017-12-21T02:31:31.580Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:27:36.793 info 2017-12-21T02:27:36.793Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:25:55.738 info 2017-12-21T02:25:55.738Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:21:37.362 info 2017-12-21T02:21:37.361Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:19:54.337 info 2017-12-21T02:19:54.337Z Connected system.user.admin
                                    ! web.0 2017-12-21 03:15:37.337 info 2017-12-21T02:15:37.336Z Connected system.user.admin
                                    • O
                                      update:
                                      da ich soweit mit meinen neuen erstellten Admin1 auf Port 8089 zugreifen konnte habe ich
                                      den Admin 0 gelöscht und soweit arbeiten können.
                                      Heute passierte es wieder das ich mit dem Admin1 die AdminOberfläche nicht mehr erreichbar war.
                                      Somit erstellte ich wieder einen neuen Admin Zugang, Admin2 auf Port 8081 (den alten Port von Admin0 den ich ja gelöscht habe)
                                      Damit konnte ich wieder auf die Weboberfläche zugreifen.
                                      Im Log habe ich dann folgendes gefunden (der letzte Auszug davon wo ich denke das relevante Information drinsteht):
                                      ! admin.2 2018-01-11 13:25:54.777 info system.adapter.admin.1: logging false
                                      ! iobroker 2018-01-11 13:25:54.798 info exit 0
                                      ! admin.2 2018-01-11 13:25:54.776 info system.adapter.admin.1: logging false
                                      ! mqtt.0 2018-01-11 13:25:54.773 info system.adapter.admin.1: logging false
                                      ! mqtt.0 2018-01-11 13:25:54.772 info system.adapter.admin.1: logging false
                                      ! javascript.0 2018-01-11 13:25:54.770 info system.adapter.admin.1: logging false
                                      ! history.0 2018-01-11 13:25:54.771 info system.adapter.admin.1: logging false
                                      ! socketio.0 2018-01-11 13:25:54.769 info system.adapter.admin.1: logging false
                                      ! sonoff.0 2018-01-11 13:25:54.769 info system.adapter.admin.1: logging false
                                      ! web.0 2018-01-11 13:25:54.769 info system.adapter.admin.1: logging false
                                      ! javascript.0 2018-01-11 13:25:54.769 info system.adapter.admin.1: logging false
                                      ! host.raspiIObroker 2018-01-11 13:25:54.703 info object deleted system.adapter.admin.1
                                      ! host.raspiIObroker 2018-01-11 13:25:54.702 info object change system.adapter.admin.1
                                      ! iobroker 2018-01-11 13:25:54.578 info host.raspiIObroker Deleting 12 object(s).
                                      ! iobroker 2018-01-11 13:25:54.575 info host.raspiIObroker Counted 10 objects of states of admin.1
                                      ! iobroker 2018-01-11 13:25:54.559 info host.raspiIObroker Counted 1 channels of admin.1
                                      ! iobroker 2018-01-11 13:25:54.553 info host.raspiIObroker Counted 12 objects of admin.1
                                      ! iobroker 2018-01-11 13:25:54.177 info host.raspiIObroker Counted 1 instances of admin.1
                                      ! iobroker 2018-01-11 13:25:54.139 info host.raspiIObroker Counted 9 states "system.adapter.admin.1*" from stateshost.raspiIObroker Counted 2 states "admin.1*" from states
                                      ! iobroker 2018-01-11 13:25:52.159 info del admin.1
                                      ! admin.2 2018-01-11 13:25:46.852 info system.adapter.admin.1: logging false
                                      ! admin.2 2018-01-11 13:25:46.851 info system.adapter.admin.1: logging false
                                      ! history.0 2018-01-11 13:25:46.848 info system.adapter.admin.1: logging false
                                      ! javascript.0 2018-01-11 13:25:46.848 info system.adapter.admin.1: logging false
                                      ! javascript.0 2018-01-11 13:25:46.847 info system.adapter.admin.1: logging false
                                      ! mqtt.0 2018-01-11 13:25:46.846 info system.adapter.admin.1: logging false
                                      ! mqtt.0 2018-01-11 13:25:46.844 info system.adapter.admin.1: logging false
                                      ! web.0 2018-01-11 13:25:46.845 info system.adapter.admin.1: logging false
                                      ! sonoff.0 2018-01-11 13:25:46.845 info system.adapter.admin.1: logging false
                                      ! socketio.0 2018-01-11 13:25:46.844 info system.adapter.admin.1: logging false
                                      ! host.raspiIObroker 2018-01-11 13:25:46.839 info instance system.adapter.admin.1 terminated with code 0 (OK)
                                      ! host.raspiIObroker 2018-01-11 13:25:46.791 info stopInstance system.adapter.admin.1 killing pid 734
                                      ! admin.1 2018-01-11 13:25:46.805 info terminating
                                      ! admin.1 2018-01-11 13:25:46.796 info terminating http server on port 8089
                                      ! host.raspiIObroker 2018-01-11 13:25:46.787 info object change system.adapter.admin.1
                                      ! admin.2 2018-01-11 13:25:39.036 info system.adapter.admin.2: logging true
                                      ! admin.1 2018-01-11 13:25:39.049 info system.adapter.admin.2: logging true
                                      ! admin.1 2018-01-11 13:25:39.046 info system.adapter.admin.2: logging true
                                      ! history.0 2018-01-11 13:25:39.039 info system.adapter.admin.2: logging true
                                      ! javascript.0 2018-01-11 13:25:39.035 info system.adapter.admin.2: logging true
                                      ! admin.2 2018-01-11 13:25:39.034 info system.adapter.admin.2: logging true
                                      ! javascript.0 2018-01-11 13:25:39.030 info system.adapter.admin.2: logging true
                                      ! sonoff.0 2018-01-11 13:25:39.029 info system.adapter.admin.2: logging true
                                      ! socketio.0 2018-01-11 13:25:39.028 info system.adapter.admin.2: logging true
                                      ! mqtt.0 2018-01-11 13:25:39.030 info system.adapter.admin.2: logging true
                                      ! web.0 2018-01-11 13:25:39.029 info system.adapter.admin.2: logging true
                                      ! mqtt.0 2018-01-11 13:25:39.028 info system.adapter.admin.2: logging true
                                      ! admin.2 2018-01-11 13:25:39.018 info Change log subscriber state: true
                                      ! admin.2 2018-01-11 13:25:33.725 info Repository received successfully.
                                      ! host.raspiIObroker 2018-01-11 13:25:33.262 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                      ! admin.2 2018-01-11 13:25:33.156 info Request actual repository…
                                      ! admin.2 2018-01-11 13:25:32.883 info Use link "http://localhost:8081" to configure.
                                      ! admin.2 2018-01-11 13:25:32.883 info http server listening on port 8081
                                      ! admin.2 2018-01-11 13:25:32.706 info received all objects
                                      ! admin.2 2018-01-11 13:25:32.273 info received all states
                                      ! admin.2 2018-01-11 13:25:31.745 info requesting all objects
                                      ! admin.2 2018-01-11 13:25:31.741 info requesting all states
                                      ! admin.2 2018-01-11 13:25:31.689 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.0
                                      ! admin.2 2018-01-11 13:25:31.605 info States connected to redis: 127.0.0.1:6379
                                      ! host.raspiIObroker 2018-01-11 13:25:28.583 info instance system.adapter.admin.2 started with pid 767
                                      ! host.raspiIObroker 2018-01-11 13:25:28.515 info object change system.adapter.admin.2
                                      ! admin.1 2018-01-11 13:24:25.184 info Repository received successfully.
                                      ! host.raspiIObroker 2018-01-11 13:24:24.777 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                      ! admin.1 2018-01-11 13:24:24.695 info Request actual repository...
                                      ! admin.1 2018-01-11 13:24:24.473 info Use link "http://localhost:8089" to configure.
                                      ! admin.1 2018-01-11 13:24:24.473 info http server listening on port 8089
                                      ! admin.1 2018-01-11 13:24:24.331 info received all objects
                                      ! admin.1 2018-01-11 13:24:23.888 info received all states
                                      ! admin.1 2018-01-11 13:24:23.439 info requesting all objects
                                      ! admin.1 2018-01-11 13:24:23.435 info requesting all states
                                      ! admin.1 2018-01-11 13:24:23.385 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.0
                                      Hat jemand eine Ahnung was da schiefläuft?
                                      34630
