    4. Salamiofen Steuerung mit Blockly
      tom2964 last edited by
      <xml xmlns="http://www.w3.org/1999/xhtml"><block id="wt98!c{)0[EZgQ@A5/" type="controls_if" y="2337" x="-163"><value name="IF0"><block id="0.yK)l#MIICze4x?eyLL" type="logic_operation"><field name="OP">AND</field>
      <value name="A"><block id=",mNccc/RCbxq5j=WVbg2" type="logic_compare"><field name="OP">GTE</field>
      <value name="A"><block id="udPlwYM[ove.TGrFRuh" type="variables_get"><field name="VAR">CountTage</field></block></value>
      <value name="B"><block id="[z%VP~F6M{kEf(oSm^#B" type="math_number"><field name="NUM">16</field></block></value></block></value>
      <value name="B"><block id="#bJV!}zY.k;St^?8ZxD%" type="logic_compare"><field name="OP">LTE</field>
      <value name="A"><block id="]WB+)i1/lB@?8+;|4wJW" type="variables_get"><field name="VAR">CountTage</field></block></value>
      <value name="B"><block id="jX9E#5b3b,(:t]R5W_5i" type="math_number"><field name="NUM">22</field></block></value></block></value></block></value>
      <statement name="DO0"><block id="sELv[sy-MWir:6G|gswX" type="variables_set"><field name="VAR">TempNiedrig</field>
      <value name="VALUE"><block id="R#A2)xen2/k,qO+.ZXv:" type="lists_getIndex"><mutation statement="false" at="true"></mutation>
      <value name="VALUE"><block id="eSqK0I9k2E%kR~J_D6g" type="variables_get"><field name="VAR">Tag_16_17_18_19_20_21_22</field></block></value> <value name="AT"><block id=")t,:|UYcel!,cc6;j2Z(" type="math_number"><field name="NUM">1</field></block></value></block></value> <next><block id=",[i}aLnwT}JzN%l^.p8Z" type="variables_set"><field name="VAR">TempHoch</field> <value name="VALUE"><block id="8)tH[lRN4c^~:Cdk?M!o" type="lists_getIndex"><mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_START</field> <value name="VALUE"><block id="R/*S6AoZJA%tZ-3_FJb" type="variables_get"><field name="VAR">Tag_16_17_18_19_20_21_22</field></block></value>
      <value name="AT"><block id="?YpMP0IU(u8WM:CWP
      m9" type="math_number"><field name="NUM">2</field></block></value></block></value>
      <next><block id="Mqwh]VbY8blTD7ifaz}" type="variables_set"><field name="VAR">LF</field>
      <value name="VALUE"><block id=",@MC.{#ftYm4vJ{#K#;P" type="lists_getIndex"><mutation statement="false" at="true"></mutation>
      <value name="VALUE"><block id="s_-XE0dIFI?94{!DBrx6" type="variables_get"><field name="VAR">Tag_16_17_18_19_20_21_22</field></block></value>
      <value name="AT"><block id="_iI|.@;bVlpapdLA
      wPd" type="math_number"><field name="NUM">3</field></block></value></block></value></block></next></block></next></block></statement></block></xml>
      ist das jetzt richtig so
      • rantanplan
        rantanplan last edited by
        Jepp, richtig.
        Jetzt wäre es schön, wenn ich Deine Version als Export bekommen könnte.
        Dann könnte ich dort mit den Timeouts weiter machen.
        Möchtest Du eine Benachrichtigung erhalten, wenn der Vorgang fertig ist?
        Wenn Ja, was für einen Adapter hat Du installiert? (Mail, Telegramm….)
          Also der Export geht nicht zu groß und ja ich habe telegramm
          • rantanplan
            @tom2964:
            Also der Export geht nicht zu groß und ja ich habe telegramm `
            Das kann ich mir nicht vorstellen.
            Wie schon geschrieben, mein Export hat etwas mehr als 46.000 Zeichen.
            Da kannst Du nicht schon mehr als 100.000 haben.
            Aber als .txt Datei sollte es gehen.
            Export ctrg+c
            Windows Editor starten. ctrg+v.
            Datei speichern und hier reinstellen.
              @tom2964:
              Also der Export geht nicht `
              @[url=http://www.iobroker.net/docu/?page_id=5319⟨=de#Das_Editorfenster:
              Doku"]<size size="150">Download des Codes</size>
              Mit dem Pfeil-nach-unten Button kann das Blockly als Code exportiert werden. Es erscheint ein PopUp in dem der Code mit Strg-C markiert und anderweitig eingefügt werden kann. Dies kann auch zur externen Sicherung benutzt werden. `
              gemeint ist der Pfeil über der Arbeitsfläche, nicht über dem Explorer
              Rainer
                Ok werde ich später probieren muss jetzt erstmal schnell zur Arbeit
                  ist das so richtig 2554_1.txt
                  • rantanplan
                    Jepp, habe ich importieren können.
                    (Tatsächlich über 100.000 Zeichen :shock: )
                    Wäre schön gewesen wenn Du die fehlen Objekt-IDs schon eingesetzt hättest.
                    Fehlen da nicht die Tage von 23 bis 30? Oder werden die nicht gebraucht.
                      die Schaltsteckdose sind zur zeit alle in gebrauch, und die restlichen tage müssen die schon mit rein , könnte ich doch später noch machen
                      • rantanplan
                        Hallo 2964
                        Es ist vollbracht 😉
                        Bevor ich mich in den Weihnachtsmodus schalte, wollte ich das Teil noch fertig machen.
                        Ist ein mächtiges Teil geworden. :shock:
                        Screenshots setze ich mal nicht rein (währen zu viele).
                        Der Export geht auch nur noch über eine Textdatei.
                        Testen konnte ich das Blockly nicht!
                        Fragen können natürlich gestellt werden.
                        ****Eine Bitte hätte ich noch.
                        Bitte ändere den Betreff Deines ERSTEN Beitrages.****
                        Schreib da was mit Blockly und Salamiofen rein.
                        Eventuell hat ja noch jemand anderes solch ein Teil.
                        Und nur mit "Bitte um Hilfe zu Blockly" würde derjenige das Blockly NIE finden.
                        Von einem Forum sollen halt mehrere was haben.
                        Eine Rückmeldung, ob es klappt wäre auch schön.
                        147_salamiblocklyexport.txt
                          Erstmal vielen Dank für Deine Mühe ,werde es auch erst nach Weinachten testen können. Melde mich dann wieder und der Export hatte geklappt.
                          Eine Frage hätte ich jetzt noch ,die Nachricht geht die über telegramm raus .
                          Ansonsten noch ein schönes Weihnachtsfest und noch mal vielen Dank.
                          M.f.g Thomas
                          • rantanplan
                            @tom2964:
                            Eine Frage hätte ich jetzt noch ,die Nachricht geht die über telegramm raus . `
                            Ja, jedesmal bei Tageswechsel und wenn fertig (sofern alles klappt 🙂 )
                            Prima, dass Du den Betreff geändert hast.
                            Auch Dir schöne Weihnachten!
                              Hallo ich bin es mal wieder.
                              Habe denn Skript mal ein paar Tage laufen lassen bekomme aber leider keine Nachricht bei Tageswechsel ln Telegramm an gezeigt .
                              M.f.g Thomas
                              • rantanplan
                                Werden die Geräte denn richtig geschaltet?
                                  Also die Geräte habe ich noch nicht verbunden ich dachte es läuft auch so
                                  • rantanplan
                                    @tom2964:
                                    Also die Geräte habe ich noch nicht verbunden ich dachte es läuft auch so `
                                    Hast Du die fehlenden Objekt-IDs eingesetzt?
                                    Hast Du schon mal aus Blockly ein Telegramm verschickt?
                                    Gibt es Meldungen im LOG?
                                    Wenn die Geräte woanders eingesetzt werden, müssten sie geschaltet werden.
                                    Ein Test würde ich machen, wenn die Geräte auch angeschlossen sind.
                                    Muss ja keine Salami im Ofen sein.
                                      Telegramm läuft bei mir ansonsten muss ich noch warten sind alle woanders im Einsatz
                                      • rantanplan
                                        @tom2964:
                                        Telegramm läuft bei mir ansonsten muss ich noch warten sind alle woanders im Einsatz `
                                        Dann müssten die aber geschaltet worden sein!?
                                        Den Steckdosen ist es egal wo sie gerade eingesetzt werden.
                                        Was ist mit den anderen Fragen die ich gestellt habe?
                                          Zu eins Nein
                                          Zu zwei ja
                                          • rantanplan
                                            Gibt's was neues vom Salamiofen?
                                            19504
