    4. Raspberry Pi4 friert ein
      Thomas Braun Most Active @jwerlsdf last edited by
      @jwerlsdf
      Bitte statt spoiler codetags verwenden.
        jwerlsdf @Thomas Braun last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.6.20+rpt-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         22:10:24 up  6:58,  4 users,  load average: 1.45, 1.15, 0.87
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        ~ Under-voltage has occurred
        ~ Arm frequency capping has occurred
        ~ Throttling has occurred
        ~ Soft temperature limit has occurred
        *** Time and Time Zones ***
                       Local time: Sun 2024-03-31 22:10:25 CEST
                   Universal time: Sun 2024-03-31 20:10:25 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.0G        3.2G        281M         39M        656M        819M
        Swap:           104M        104M        4.1K
        Total:          4.1G        3.3G        281M
                 3791 M total memory
                 3010 M used memory
                 2144 M active memory
                 1166 M inactive memory
                  268 M free memory
                   58 M buffer memory
                  568 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                        Type      Size  Used Avail Use% Mounted on
        udev                              devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs                             tmpfs     380M  1.5M  378M   1% /run
        /dev/sda2                         ext4       55G  7.1G   45G  14% /
        tmpfs                             tmpfs     1.9G  412K  1.9G   1% /dev/shm
        tmpfs                             tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/sda1                         vfat      510M   74M  437M  15% /boot/firmware
        //192.168.178.39/Küche           cifs       15T   12T  3.2T  79% /Kueche
        //192.168.178.39/Sicherungskopien cifs       15T   12T  3.2T  79% /Sicherungskopien
        //192.168.178.39/music            cifs       15T   12T  3.2T  79% /music
        //192.168.178.39/video            cifs       15T   12T  3.2T  79% /video
        tmpfs                             tmpfs     380M   36K  380M   1% /run/user/1000
        /dev/sdb1                         ext4       15G   56M   14G   1% /media/pi/0a009aa4-c38d-4337-97c2-5f76980f7f10
        [Sun Mar 31 15:12:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:49:11:09 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=9527ef1a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Sun Mar 31 15:12:14 2024] EXT4-fs (sda2): mounted filesystem b29e303a-703b-457f-a7e3-d7c4590e8b8c ro with ordered data mode. Quota mode: none.
        [Sun Mar 31 15:12:15 2024] EXT4-fs (sda2): re-mounted b29e303a-703b-457f-a7e3-d7c4590e8b8c r/w. Quota mode: none.
        [Sun Mar 31 15:12:36 2024] EXT4-fs (sdb1): recovery complete
        [Sun Mar 31 15:12:36 2024] EXT4-fs (sdb1): mounted filesystem 0a009aa4-c38d-4337-97c2-5f76980f7f10 r/w with ordered data mode. Quota mode: none.
        TARGET                                           SOURCE                            FSTYPE      OPTIONS
        /                                                /dev/sda2                         ext4        rw,noatime
        |-/run/user/1000/doc                             portal                            fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot/firmware                                 /dev/sda1                         vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/Kueche                                        //192.168.178.39/K\xc3\xbcche     cifs        rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,noforceuid,gid=1000,noforcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
        |-/Sicherungskopien                              //192.168.178.39/Sicherungskopien cifs        rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,noforceuid,gid=1000,noforcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
        |-/music                                         //192.168.178.39/music            cifs        rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,noforceuid,gid=1000,noforcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
        |-/video                                         //192.168.178.39/video            cifs        rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,noforceuid,gid=1000,noforcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
        `-/media/pi/0a009aa4-c38d-4337-97c2-5f76980f7f10 /dev/sdb1                         ext4        rw,nosuid,nodev,relatime,errors=remount-ro
        /var:
        626M    /var/
        197M    /var/lib
        182M    /var/cache
        175M    /var/cache/apt
        145M    /var/log/journal/6b2ba0c331f7402fad09e682c0dc2464
        Archived and active journals take up 144.0M in the file system.
        /opt/iobroker/backups:
        226M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        536M    /opt/iobroker/iobroker-data/
        262M    /opt/iobroker/iobroker-data/files
        127M    /opt/iobroker/iobroker-data/backup-objects
        100M    /opt/iobroker/iobroker-data/sonosCache
        79M     /opt/iobroker/iobroker-data/files/vis.0
        37M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        11M     /opt/iobroker/iobroker-data/states.jsonl
        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.0
        /usr/bin/node           v18.20.0
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        /usr/bin/corepack       0.25.2
        nodejs:
          Installed: 18.20.0-1nodesource1
          Candidate: 18.20.0-1nodesource1
          Version table:
         *** 18.20.0-1nodesource1 600
                100 /var/lib/dpkg/status
             18.19.1-1nodesource1 600
             18.19.0+dfsg-6~deb12u1 500
             18.19.0-1nodesource1 600
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.15.2
        javascript:     7.11.1
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 8080
        + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
        + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
          system.adapter.history.0                : history               : raspberrypi                              - disabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
          system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
          system.adapter.ical.3                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
        + system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
        + system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
        + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
        + system.adapter.synochat.0               : synochat              : raspberrypi                              -  enabled
        + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
        + system.adapter.synology.1               : synology              : raspberrypi                              -  enabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.time-switch.0            : time-switch           : raspberrypi                              -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.trashschedule.1          : trashschedule         : raspberrypi                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.15.2   , installed 6.15.2
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "deconz"       : 1.4.0    , installed 1.4.0
        Adapter    "denon"        : 1.15.5   , installed 1.15.5
        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
        Adapter    "eusec"        : 1.2.1    , installed 1.2.1
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "firetv"       : 2.0.2    , installed 2.0.2
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "heos"         : 2.2.1    , installed 2.2.1
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "ical"         : 1.14.3   , installed 1.14.3
        Adapter    "javascript"   : 7.11.1   , installed 7.11.1
        Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
        Adapter    "nina"         : 0.0.26   , installed 0.0.26
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "radar2"       : 2.1.0    , installed 2.1.0
        Adapter    "roborock"     : 0.5.4    , installed 0.5.4
        Adapter    "rssfeed"      : 2.8.1    , installed 2.8.1
        Adapter    "shelly"       : 6.9.0    , installed 6.9.0
        Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "synochat"     : 1.3.1    , installed 1.3.1
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
        Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Objects and States
        Objects:        25935
        States:         22690
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8844       885/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          6804       815/node
        tcp        0      0 192.168.178.28:2001     0.0.0.0:*               LISTEN      1001       14460      2301/io.hm-rpc.0
        tcp        0      0 192.168.178.28:2010     0.0.0.0:*               LISTEN      1001       12105      2331/io.hm-rpc.1
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13606      2465/io.shelly.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10347      813/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7681       813/iobroker.js-con
        tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       13788      2769/adb
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6691       812/cupsd
        tcp6       0      0 :::8554                 :::*                    LISTEN      1001       16516      3101/go2rtc
        tcp6       0      0 :::8555                 :::*                    LISTEN      1001       16517      3101/go2rtc
        tcp6       0      0 :::22                   :::*                    LISTEN      0          8846       885/sshd: /usr/sbin
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       16555      2883/io.fullybrowse
        tcp6       0      0 :::6824                 :::*                    LISTEN      1001       22816      3168/io.roborock.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      0          6807       815/node
        tcp6       0      0 :::3501                 :::*                    LISTEN      1001       12736      2472/io.sonos.0
        tcp6       0      0 :::5900                 :::*                    LISTEN      992        7445       843/wayvnc
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6690       812/cupsd
        tcp6       0      0 :::1984                 :::*                    LISTEN      1001       15333      3101/go2rtc
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16618      3112/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13316      2194/io.admin.0
        tcp6       0      0 :::7906                 :::*                    LISTEN      1001       22817      3168/io.roborock.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       14915      2731/io.deconz.0
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       12700      2458/io.radar2.0
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15680      2649/io.mihome-vacu
        udp        0      0 0.0.0.0:47530           0.0.0.0:*                           104        5971       637/avahi-daemon: r
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          6826       1037/cups-browsed
        udp        0      0 0.0.0.0:35548           0.0.0.0:*                           1001       16150      2844/io.eusec.0
        udp        0      0 0.0.0.0:36041           0.0.0.0:*                           1001       16380      3146/io.heos.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17446      3131/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5969       637/avahi-daemon: r
        udp6       0      0 :::1900                 :::*                                1001       14917      2731/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       14916      2731/io.deconz.0
        udp6       0      0 :::8555                 :::*                                1001       16518      3101/go2rtc
        udp6       0      0 fe80::9080:d303:9bc:546 :::*                                0          3816       731/NetworkManager
        udp6       0      0 :::35797                :::*                                104        5972       637/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        5970       637/avahi-daemon: r
        2024-03-31 22:10:21.761  - info: radar2.0 (2458) debug: ChangeState ack:true of Michael._nHere = 553
        2024-03-31 22:10:21.771  - info: radar2.0 (2458) debug: ChangeState ack:true of Tina._nHere = 462
        2024-03-31 22:10:21.771  - info: radar2.0 (2458) debug: radar2 found here (Michael, Tina)
        2024-03-31 22:10:21.771  - info: radar2.0 (2458) debug: and who here (Michael, Tina)
        2024-03-31 22:10:21.772  - info: radar2.0 (2458) debug: and not here ()
        2024-03-31 22:10:21.772  - info: radar2.0 (2458) debug: radar2 found uBT's: []
        2024-03-31 22:10:21.772  - info: radar2.0 (2458) debug: radar2 found uIP's: []
        2024-03-31 22:10:51.195  - info: radar2.0 (2458) debug: ChangeState ack:true of Michael._lastHere = 2024-03-31@22:10:51
        2024-03-31 22:10:51.240  - info: radar2.0 (2458) debug: ChangeState ack:true of Tina._lastHere = 2024-03-31@22:10:51
        2024-03-31 22:10:51.254  - info: radar2.0 (2458) debug: ChangeState ack:true of Michael._nHere = 554
        2024-03-31 22:10:51.263  - info: radar2.0 (2458) debug: ChangeState ack:true of Tina._nHere = 463
        2024-03-31 22:10:51.265  - info: radar2.0 (2458) debug: radar2 found here (Michael, Tina)
        2024-03-31 22:10:51.265  - info: radar2.0 (2458) debug: and who here (Michael, Tina)
        2024-03-31 22:10:51.266  - info: radar2.0 (2458) debug: and not here ()
        2024-03-31 22:10:51.267  - info: radar2.0 (2458) debug: radar2 found uBT's: []
        2024-03-31 22:10:51.267  - info: radar2.0 (2458) debug: radar2 found uIP's: []
        2024-03-31 22:11:21.931  - info: radar2.0 (2458) debug: ChangeState ack:true of Michael._lastHere = 2024-03-31@22:11:21
        2024-03-31 22:11:22.009  - info: radar2.0 (2458) debug: ChangeState ack:true of Tina._lastHere = 2024-03-31@22:11:22
        2024-03-31 22:11:22.019  - info: radar2.0 (2458) debug: ChangeState ack:true of Michael._nHere = 555
        2024-03-31 22:11:22.027  - info: radar2.0 (2458) debug: ChangeState ack:true of Tina._nHere = 464
        2024-03-31 22:11:22.029  - info: radar2.0 (2458) debug: radar2 found here (Michael, Tina)
        2024-03-31 22:11:22.029  - info: radar2.0 (2458) debug: and who here (Michael, Tina)
        2024-03-31 22:11:22.030  - info: radar2.0 (2458) debug: and not here ()
        2024-03-31 22:11:22.030  - info: radar2.0 (2458) debug: radar2 found uBT's: []
        2024-03-31 22:11:22.030  - info: radar2.0 (2458) debug: radar2 found uIP's: []
        iob diag has finished.
        Press any key for a summary
          @jwerlsdf
          Nix wirklich wildes zu sehen.
          Aber schalt den debug-Mode für den radar2 aus.
            gemacht.
            Das ist eben mein Problem. Ich finde den Fehler nicht. Habe bereits bookworm komplett neu installiert und das Backup vom iobroker eingespielt. Keine Verbesserung.
            Ich habe einen weiteren Raspberry Pi4 laufen (dort ist nur deconz und Homematic IP) installiert und dort habe ich keine Probleme. Dieser läuft und läuft.
            Aber bei diesem tritt der Fehler im Schnitt jeden zweiten Tag auf. Meine Überlegung ist, dass ich mittlerweile zu viel darauf installiert habe und er somit an seine Grenzen kommt?
            Thomas Braun ? 2 Replies Last reply Reply Quote 0
              @jwerlsdf
              Der Kiste wird zwar nicht langweilig, sollte aber damit noch gut auskommen.
              • Winni
                Winni last edited by
                Ich würde mal testweise die Festplatte mit einem separaten Netzteil versorgen und beim Raspi für mehr Kühlung sorgen.
                  A Former User @jwerlsdf last edited by
                  @jwerlsdf
                  Da denkst Du in die richtige Richtung. 4 GB sind bei Deiner Anzahl an Instanzen etwas wenig.
                  Dein Swap ist nach ein paar Stunden aufgebraucht und der Raspi kann keinen weiteren Arbeitsspeicher adressieren.
                  Die 100 MB im Default sind da zu wenig.
                  Mach den mal größer, dann hast Du die Change, dass er länger online bleibt.
                  Über die Suchmaschine findest Du komplette Anleitungen. (Raspi swap size)
                  Hat das besondere Gründe, dass Du komplett im Beta-Repo arbeitest, für eine
                  Produktivumgebung ist das nicht ratsam!?
                    jwerlsdf @Winni last edited by
                    @winni
                    Die ssd hat bereits ein separates Netzteil. Es würde mich aber jetzt wundern, wenn das Netzteil zu schwach dimensioniert wäre....
                    Mein raspberry ist in einem Alu-Gehäuse. Normalerweise müsste die Wärme ja darüber abgegeben werden, besser als in einem Plastik Gehäuse.
                    Ich habe nun den raspberry im Keller freistehend positioniert. Die Temperatur lag vorher immer zwischen 68 und 71 Grad Celsius, jetzt bei 61-63.
                      @jwerlsdf sagte in Raspberry Pi4 friert ein:
                      Da sag ich nur:
                      echad@chet:~ $ vcgencmd measure_temp
                      temp=43.8'C
                      echad@chet:~ $
                        jwerlsdf @Guest last edited by
                        @rscsb
                        Da ich noch auf dritten raspberry go2rtc laufen habe, würde das was bringen, wenn ich auf diesem iobroker als slave laufen lassen würde und dann Instanzen auf diesen schiebe?
                        "Raspi swap size" schaue ich mir mal an.
                          Diese Temperatur habe ich auf dem anderen raspy auch 🙂 aber mit 60 Grad sollte er noch nicht die Leistung drosseln....
                            @jwerlsdf
                            Tut die Kiste aber laut Log.
                              Dann fassen ich kurz zusammen.
                              Ich habe ein temp Problem, welches ich nur lösen kann, wenn ich einen turmlüfter auf den pi draufbaue. Zweites Problem ist die fehlende Leistung (zu wenig ram).
                              Einmal blöd gefragt, macht es da noch Sinn, bei einem Raspberry pi4 zu bleiben oder auf den 5er mit aktiver Kühlung zu gehen oder etwas ganz anderes zu nehmen? Wie gesagt, da soll dann noch go2rtc laufen, was ein bisschen Ressourcen hungrig ist. Oder wie seht ihr das?
                                m4rgott last edited by
                                ich habe seit ein paar Wochen das selbe Problem.
                                Auf meine Frage dazu in der Facebook-Gruppe hat man mir empfohlen von der SD auf SSD umzustellen weil wahrscheinlich die SD defekt wäre.
                                Dass der Raspi nicht von SSD booten will (Unsupported block sice 4096) ist wohl ein anderes Thema.
                                Die offene Frage von @jwerlsdf ob das Problem mit Vergrößerung des swap nur aufgeschoben ist stellt sich mir auch.
                                Gibt es dazu eine Lösung?
                                Ro75 haus-automatisierung 2 Replies Last reply Reply Quote 0
                                • Ro75
                                  Ro75 @m4rgott last edited by
                                  @m4rgott da ich nicht auf Facebook unterwegs bin kenne ich deine spezielle Thematik nicht.
                                  Vielleicht kannst du dein spezielles Anliegen hier mal bitte posten. Danke.
                                  Ro75.
                                  • haus-automatisierung
                                    haus-automatisierung Developer Most Active @m4rgott last edited by
                                    @m4rgott sagte in Raspberry Pi4 friert ein:
                                    Das ist leider die pauschale Antwort auf alle Fragen geworden, wenn man nicht weiter weiß... In den seltensten Fällen ist die SD-Karte wirklich defekt.
                                      m4rgott last edited by m4rgott
                                      Hi @Ro75 und @haus-automatisierung ,
                                      vielen Dank für die schnelle Antwort.
                                      Wie der Kollege auch schon geschrieben hatte, hängt sich auch bei mir der Raspi 4b (4 GB) inzwischen jeden tag auf. In den Logs vom iob kann ich nicht nachvollziehen woran es liegt und in den Logs vom Raspi kenne ich mich nicht gut genug aus um da etwas nachvollziehen zu können.
                                      Das Problem hatte ich dann auch schonmal in der FB Gruppe "IoBroker SmartHome und IoT" geschildert. Hier kam dann schnell der Hinweis, dass sich häufig die SD Karten verabschieden, weshalb ich ein Backup auf eine Neue SD gezogen habe. Leider hat das nicht geholfen. Nächster Tipp war, dass ich auf eine SSD umsteigen soll. Das ist aber eine Vollkatastrophe. Trotz rpi-eeprom-update bekomm ich das nicht zum laufen und bekomme die Fehlermeldung "Unsupported block sice 4096".
                                      Ich bin jetzt komplett verunsichert. Kann ich den Raspi weiter mit SD betreiben und der Fehler liegt irgendwo anders? Reicht es wenn ich es irgendewie schaffe das auf SSD zum Laufen zu bekommen?
                                      Oder muss ich kurzfristig alles auf einem Mini PC neu aufsetzen?
                                      Hier die komplette Ausgabe vom iob diag:
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                        Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                  Kernel: Linux 6.1.21-v8+
                                            Architecture: arm64
                                      Model           : Raspberry Pi 4 Model B Rev 1.2
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 32 bit
                                       11:27:11 up 41 min,  2 users,  load average: 1.30, 1.23, 1.19
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Mon 2024-06-10 11:27:12 CEST
                                                 Universal time: Mon 2024-06-10 09:27:12 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout sudo audio video bluetooth gpio i2c
                                      iobroker
                                      HOME=/home/iobroker
                                      *** Display-Server-Setup ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      Boot Target:    multi-user.target
                                      *** MEMORY ***
                                      Mem:            3.8G        1.5G        1.5G        0.0K        806M        2.3G
                                      Swap:           1.0G          0B        1.0G
                                      Total:          4.8G        1.5G        2.5G
                                      Active iob-Instances:   26
                                               3794 M total memory
                                               1515 M used memory
                                               1632 M active memory
                                                518 M inactive memory
                                               1471 M free memory
                                                127 M buffer memory
                                                678 M swap cache
                                               1023 M total swap
                                                  0 M used swap
                                               1023 M free swap
                                      top - 11:27:12 up 41 min,  2 users,  load average: 1.30, 1.23, 1.19
                                      Tasks: 190 total,   2 running, 188 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s): 12.9 us,  8.6 sy,  0.0 ni, 78.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3794.3 total,   1471.9 free,   1515.8 used,    806.7 buff/cache
                                      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   2292.5 avail Mem
                                      *** FILESYSTEM ***
                                      /dev/root                        ext4      117G   19G   94G  17% /
                                      devtmpfs                         devtmpfs  1.7G     0  1.7G   0% /dev
                                      tmpfs                            tmpfs     1.9G     0  1.9G   0% /dev/shm
                                      tmpfs                            tmpfs     759M  884K  759M   1% /run
                                      tmpfs                            tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                                      /dev/mmcblk0p1                   vfat      253M   51M  202M  20% /boot
                                      //192.168.188.1/FRITZ.NAS/Intern cifs      1.9T  137G  1.7T   8% /home/iobroker/nas
                                      tmpfs                            tmpfs     380M     0  380M   0% /run/user/1000
                                      tmpfs                            tmpfs     380M     0  380M   0% /run/user/1001
                                      [sudo] password for iobroker:
                                      [Mon Jun 10 10:45:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:11:73:1C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=79014aeb-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Mon Jun 10 10:45:23 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Mon Jun 10 10:45:23 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Mon Jun 10 10:45:26 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      Show mounted filesystems:
                                      /                            /dev/mmcblk0p2                   ext4       rw,noatime
                                      |-/dev                       devtmpfs                         devtmpfs   rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                                      | |-/dev/shm                 tmpfs                            tmpfs      rw,nosuid,nodev
                                      | |-/dev/pts                 devpts                           devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                      | `-/dev/mqueue              mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
                                      |-/proc                      proc                             proc       rw,relatime
                                      | `-/proc/sys/fs/binfmt_misc systemd-1                        autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                      |-/sys                       sysfs                            sysfs      rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/security     securityfs                       securityfs rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/cgroup           cgroup2                          cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                      | |-/sys/fs/pstore           pstore                           pstore     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/bpf              bpf                              bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/sys/kernel/debug        debugfs                          debugfs    rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/tracing      tracefs                          tracefs    rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/fuse/connections fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
                                      | `-/sys/kernel/config       configfs                         configfs   rw,nosuid,nodev,noexec,relatime
                                      |-/run                       tmpfs                            tmpfs      rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                                      | |-/run/lock                tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                                      | |-/run/rpc_pipefs          sunrpc                           rpc_pipefs rw,relatime
                                      | |-/run/user/1001           tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1001,gid=1001
                                      | `-/run/user/1000           tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                                      |-/boot                      /dev/mmcblk0p1                   vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                      `-/home/iobroker/nas         //192.168.188.1/FRITZ.NAS/Intern cifs       rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=markus,domain=WORKGROUP,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.188.1,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                                      /var:
                                      6.3G    /var/
                                      3.9G    /var/log
                                      3.5G    /var/log/journal/c2df7990107f4916961d78d0f5d95a53
                                      750M    /var/lib
                                      Archived and active journals take up 200.0M in the file system.
                                      2.7G    /opt/iobroker/backups/
                                      11M     /opt/iobroker/backups/influxDB_2024_05_20-14_17_02_backupiobroker
                                      611M    /opt/iobroker/iobroker-data/
                                      506M    /opt/iobroker/iobroker-data/files
                                      138M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                                      USB-Devices by-id:
                                      No Devices found 'by-id'
                                      /usr/bin/nodejs         v18.20.3
                                      /usr/bin/node           v18.20.3
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.0
                                      nodejs:
                                        Installed: 18.20.3-1nodesource1
                                        Candidate: 18.20.3-1nodesource1
                                        Version table:
                                       *** 18.20.3-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                           18.20.2-1nodesource1 1001
                                           18.20.1-1nodesource1 1001
                                           18.20.0-1nodesource1 1001
                                           18.19.1-1nodesource1 1001
                                           18.19.0-1nodesource1 1001
                                           18.18.2-1nodesource1 1001
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                           12.22.12~dfsg-1~deb11u4 500
                                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.13.16
                                      javascript:     8.3.1
                                      nodejs modules from github:     0
                                      Adapter State
                                      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                                        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                        system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
                                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                                      + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
                                        system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
                                        system.adapter.heos.0                   : heos                  : raspberrypi                              - disabled
                                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                                      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                        system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              - disabled
                                        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
                                      + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled, bind: 192.168.188.52
                                      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                                        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                      + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
                                      + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                                      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                                      + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
                                      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                                      + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
                                      + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                                        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                                      + instance is alive
                                      Active repo(s): stable
                                      Used repository: stable
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                                      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                                      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                      Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                                      Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
                                      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                                      Adapter    "knx"          : 2.0.28   , installed 2.0.28
                                      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                                      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                                      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
                                      Adapter    "ring"         : 5.0.10   , installed 5.0.10
                                      Adapter    "roborock"     : 0.6.4    , installed 0.6.4
                                      Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                                      Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                      Objects and States
                                      Objects:        15614
                                      States:         12683
                                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:3 https://repos.influxdata.com/debian stable InRelease
                                      Hit:4 https://apt.grafana.com stable InRelease
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18554      1508/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19837      1508/iobroker.js-co
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11886      523/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:25              0.0.0.0:*               LISTEN      0          19663      1484/master
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15217      787/influxd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          11888      523/sshd: /usr/sbin
                                      tcp6       0      0 :::25                   :::*                    LISTEN      0          19664      1484/master
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      109        16608      1507/grafana
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18249      1542/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23891      2211/io.web.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        18531      787/influxd
                                      udp        0      0 192.168.188.52:5353     0.0.0.0:*                           1001       20981      2054/io.tr-064.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14030      411/avahi-daemon: r
                                      udp        0      0 192.168.188.52:50964    0.0.0.0:*                           1001       22722      1792/io.knx.0
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14971      775/dhcpcd
                                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       19078      1804/io.mihome-vacu
                                      udp        0      0 0.0.0.0:41968           0.0.0.0:*                           108        14032      411/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        14031      411/avahi-daemon: r
                                      udp6       0      0 :::546                  :::*                                0          14982      775/dhcpcd
                                      udp6       0      0 :::50062                :::*                                108        14033      411/avahi-daemon: r
                                      2024-06-10 10:48:09.368  - info: ring.0 (2234) Daily sun parameter calculation scheduled for 00:00:31
                                      2024-06-10 10:48:13.648  - info: sourceanalytix.0 (2148) Initialization of modbus.0.inputRegisters.30513_Sum_Einspeisung_ges successfully
                                      2024-06-10 10:48:13.650  - info: sourceanalytix.0 (2148) Initialising (2 of 5) "smartmeter.0.1-0:1_8_0__255.value"
                                      2024-06-10 10:48:20.519  - info: openweathermap.0 (1831) Terminated (NO_ERROR): Without reason
                                      2024-06-10 10:48:21.256  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                                      2024-06-10 10:48:22.558  - info: sourceanalytix.0 (2148) Initialization of smartmeter.0.1-0:1_8_0__255.value successfully
                                      2024-06-10 10:48:22.560  - info: sourceanalytix.0 (2148) Initialising (3 of 5) "smartmeter.0.1-0:2_8_0__255.value"
                                      2024-06-10 10:48:25.282  - info: tankerkoenig.0 (2169) Start first request
                                      2024-06-10 10:48:28.475  - info: sourceanalytix.0 (2148) Initialization of smartmeter.0.1-0:2_8_0__255.value successfully
                                      2024-06-10 10:48:28.483  - info: sourceanalytix.0 (2148) Initialising (4 of 5) "smartmeter.1.1-0:1_8_0__255.value"
                                      2024-06-10 10:48:32.951  - info: sourceanalytix.0 (2148) Initialization of smartmeter.1.1-0:1_8_0__255.value successfully
                                      2024-06-10 10:48:32.951  - info: sourceanalytix.0 (2148) Initialising (5 of 5) "smartmeter.1.1-0:2_8_0__255.value"
                                      2024-06-10 10:48:36.802  - info: sourceanalytix.0 (2148) Initialization of smartmeter.1.1-0:2_8_0__255.value successfully
                                      2024-06-10 10:48:36.817  - info: sourceanalytix.0 (2148) Successfully activated SourceAnalytix for 5 of 5 states, will do my Job until you stop me!
                                      2024-06-10 10:48:54.805  - info: alexa2.0 (1697) Unknown Device, but enabling commands, Try it and report back if commands work.
                                      2024-06-10 10:48:54.806  - info: alexa2.0 (1697) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                      2024-06-10 10:48:54.808  - info: alexa2.0 (1697)     Device-type:A3TMFGFCIJD290 - Miriam's JBL LIVE660NC (JBL LIVE660NC) (TUNE_IN,SLEEP,TIMERS_AND_ALARMS,AUDIBLE,VOLUME_SETTING,TIDAL,HANDS_FREE,DEREGISTER_DEVICE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,PERSISTENT_CONNECTION,ADAPTIVE_LISTENING,MICROPHONE,CHANGE_NAME,SIRIUSXM,I_HEART_RADIO,APPLE_MUSIC,KINDLE_BOOKS,AMAZON_MUSIC,MUSIC_SKILL,DREAM_TRAINING,GOLDFISH,DEEZER,AUDIO_PLAYER)
                                      2024-06-10 10:49:23.128  - info: alexa2.0 (1697) Using cached smart home devices list from Mon Jun 10 2024 10:40:44 GMT+0200 (Mitteleuropäische Sommerzeit)
                                      2024-06-10 10:49:32.719  - info: alexa2.0 (1697) No smart home devices to query
                                      2024-06-10 10:49:39.341  - info: alexa2.0 (1697) Subscribing to states...
                                      2024-06-10 10:49:39.351  - info: alexa2.0 (1697) Deleting the following states: ["Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe","Smart-Home-Devices.3583ea70-fd69-4048-9edd-fac94de2e7b2.door-toggleState","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.#delete","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.#enabled","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.#includeInAllQuery","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.#query","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.Black Cartridge HP CF400X-level","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.Cyan Cartridge HP CF401X-level","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.Magenta Cartridge HP CF403X-level","Smart-Home-Devices.82ba897f-a7a6-46fc-9e7c-992e859ccdfe.Yellow Cartridge HP CF402X-level"]
                                      2024-06-10 10:49:41.413  - info: alexa2.0 (1697) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                      2024-06-10 10:50:08.922  - info: alexa2.0 (1697) Initialization Done ...
                                      2024-06-10 11:28:01.348  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 3908
                                      2024-06-10 11:28:05.883  - info: openweathermap.0 (3908) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.20.3, js-controller: 5.0.19
                                      Über alle Tipps bin ich sehr dankbar, da ich den iob inzwischen nicht nur zu Komfortzwecken, sondern auch sicherheitsrelevant im Einsatz habe.
                                      Herzlichen Gruß
                                      m4rgott
                                      Ro75 haus-automatisierung Thomas Braun 3 Replies Last reply Reply Quote 0
                                      • Ro75
                                        @m4rgott was für ein Netzteil nutzt du?
                                        Ro75.
                                        • mcm1957
                                          mcm1957 @haus-automatisierung last edited by
                                          @haus-automatisierung said in Raspberry Pi4 friert ein:
                                          Da hier nicht mal das Problem klar dokumentiert wurde ist diese Aussage auch nicht so wirklich hilfreich. Gerade bei SDs gibt es große Qualitätsunterschiede. Und es macht natürlich auch einen Unterschied ob man nur die Logs auf die SD schreibt oder historisierte Daten im Sekundenrythmus bis die SD als Herdplatte dienen kann.
                                          In jedem Fall ist die Aussage dass die SD defekt sein könnte nur mit Infos zum Problem und ggF Systemlogs bewertbar.
                                            Keine der Fragen kann man mit den Infos hier wirklich seriös beantworten. Aber ich bin da auch bei @Ro75 :
                                            32
                                            1509
