    4. iob diag - Skript
    iob diag - Skript
      Hc-Yami @Thomas Braun last edited by Hc-Yami
      @thomas-braun wieder etwas gelernt, vielen Dank dafür. Leider löst das mein Update Problem noch nicht, weil iob diag eigentlichr echt gut aussieht:
                              v.2023-10-10
         Static hostname: ioBroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: microsoft
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-19-amd64
            Architecture: x86-64
      Installation:           microsoft
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     133
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/node           v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              /usr/bin/corepack       0.18.0
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem:            3.9G        2.3G        911M        0.0K        675M        1.3G
      Swap:           974M          0B        974M
      Total:          4.9G        2.3G        1.9G
      Active iob-Instances:   30
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                9722
      States:                 7869
      Size of iob-Database:
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      8.3M    /opt/iobroker/iobroker-data/objects.json.migrated
      8.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      2.5M    /opt/iobroker/iobroker-data/states.jsonl
      1020K   /opt/iobroker/iobroker-data/states.json.migrated
      1020K   /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
        Thomas Braun Most Active @Hc-Yami last edited by Thomas Braun
        @hc-yami sagte in iob diag - Skript:
        HUST
        Das ist auch ein Update-Problem...
        sudo apt update
        sudo apt full-upgrade
        iob stop
        iob fix
        iob nodejs-update
        sudo systemctl set-default multi-user.target
        sudo reboot
          @thomas-braun hatte tatsächlich nie manuell apt upgrade ausgeführt. Habe das nun nachgeholt. Irgendwie hatte ich im Kopf, dass man das nicht tun sollte, weil ioBroker das für einen erledigt. Faktisch praktisch ist aber apt update / upgrade und full-upgrade im ioBroker Umfeld okay?
          Gehe gerade die Befehle durch. Nach apt upgrad ehabe ich schonmal keine Updates mehr. Jetzt möchte er aber gerade einen Neustart. 🙂
            Quatsch. Das wurde noch nie von einer Anwendung übernommen, die dafür gar nicht gedacht ist.
            Das hat mit dem Umfeld nix zu tun, das ist eine reine Sache des Betriebssystems.
            Natürlich. Deswegen hatte ich den oben schon vorweggenommen.
            H Thomas Braun 2 Replies Last reply Reply Quote 0
              @thomas-braun läuft wie ein Länderspiel, dankeschön. 🙂
              Wo findet man die obligatorische Kaffeedose?
                Thomas Braun Most Active @Thomas Braun last edited by
                Könnte mal einer der Raspberry 5 User einen vollständigen Lauf zeigen?
                Ich glaube das hakelt da noch an ein paar Stellen. Die würde ich gerne noch ausbügeln.
                  Lucky_ESA Developer Most Active @Thomas Braun last edited by
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer
                            Kernel: Linux 6.6.20+rpt-rpi-2712
                      Architecture: arm64
                  Model           : Raspberry Pi 5 Model B Rev 1.0
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   23:01:51 up 4 days,  8:55,  1 user,  load average: 0.22, 0.38, 0.34
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Mon 2024-04-01 23:01:51 CEST
                             Universal time: Mon 2024-04-01 21:01:51 UTC
                                   RTC time: Mon 2024-04-01 21:01:51
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            8.4G        5.5G        1.5G        5.5M        1.5G        2.9G
                  Swap:           104M          0B        104M
                  Total:          8.5G        5.5G        1.6G
                           8052 M total memory
                           5246 M used memory
                           4928 M active memory
                           1077 M inactive memory
                           1431 M free memory
                            161 M buffer memory
                           1314 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  vc_gencmd_read_response returned -1
                  error=1 error_msg="Command not registered"
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  Filesystem                     Type      Size  Used Avail Use% Mounted on
                  udev                           devtmpfs  3.8G     0  3.8G   0% /dev
                  tmpfs                          tmpfs     806M  5.2M  801M   1% /run
                  /dev/mmcblk0p2                 ext4      117G  9.3G  102G   9% /
                  tmpfs                          tmpfs     4.0G     0  4.0G   0% /dev/shm
                  tmpfs                          tmpfs     5.0M   48K  5.0M   1% /run/lock
                  /dev/mmcblk0p1                 vfat      510M   63M  448M  13% /boot/firmware
                  192.168.2.56:/volume1/iobroker nfs       3.5T  2.8T  776G  79% /opt/iobroker/backups
                  tmpfs                          tmpfs     806M     0  806M   0% /run/user/1000
                  [Thu Mar 28 13:06:18 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Thu Mar 28 13:06:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
                  [Thu Mar 28 13:06:22 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
                  TARGET                  SOURCE                         FSTYPE OPTIONS
                  /                       /dev/mmcblk0p2                 ext4   rw,noatime
                  |-/boot/firmware        /dev/mmcblk0p1                 vfat   rw,relatime,fmask=
                  `-/opt/iobroker/backups 192.168.2.56:/volume1/iobroker nfs    rw,relatime,vers=3
                  /var:
                  2.0G    /var/
                  1.4G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
                  1.4G    /var/log
                  343M    /var/cache
                  Archived and active journals take up 1.3G in the file system.
                  /opt/iobroker/backups:
                  9.9G    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  951M    /opt/iobroker/iobroker-data/
                  595M    /opt/iobroker/iobroker-data/files
                  266M    /opt/iobroker/iobroker-data/backup-objects
                  166M    /opt/iobroker/iobroker-data/files/vis-2
                  82M     /opt/iobroker/iobroker-data/files/vis-2/static
                  78M     /opt/iobroker/iobroker-data/objects.jsonl
                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.3c875f4c.js.map
                  19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.b4e310b6.js.map
                  19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.6aba9d5c.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.20.0
                  /usr/bin/node           v18.20.0
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  /usr/bin/corepack       0.25.2
                  nodejs:
                    Installed: 18.20.0-1nodesource1
                    Candidate: 18.20.0-1nodesource1
                    Version table:
                   *** 18.20.0-1nodesource1 1001
                          100 /var/lib/dpkg/status
                       18.19.1-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u1 500
                       18.19.0-1nodesource1 1001
                       18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0+dfsg1-1 500
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          6.15.2
                  javascript:     7.11.1
                  Adapters from github:   9
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
                  + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                  + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                  + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                  + system.adapter.hekr.0                   : hekr                  : iobroker                                 -  enabled
                  + system.adapter.hiob.0                   : hiob                  : iobroker                                 -  enabled, port: 8097
                  + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                  + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                  + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                  + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
                    system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
                  + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
                  + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                  + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                  + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                    system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                  + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): beta
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "admin"        : 6.15.2   , installed 6.15.2
                  Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                  Adapter    "email"        : 1.2.2    , installed 1.2.2
                  Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                  Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                  Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                  Adapter    "hekr"         : 0.0.6    , installed 0.0.6
                  Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                  Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                  Adapter    "ical"         : 1.14.3   , installed 1.14.3
                  Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                  Adapter    "imap"         : 0.1.3    , installed 0.1.3
                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                  Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                  Adapter    "javascript"   : 7.11.1   , installed 7.11.1
                  Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
                  Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                  Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "onvif"        : 1.1.3    , installed 1.1.3
                  Adapter    "parcel"       : 0.2.7    , installed 0.2.7
                  Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                  Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                  Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                  Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                  Adapter    "vis-2"        : 2.9.48   , installed 2.9.47 [Updatable]
                  Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                  Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                  Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                  Adapter    "web"          : 6.2.5    , installed 6.2.4  [Updatable]
                  Adapter    "worx"         : 2.3.4    , installed 2.3.4
                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                  Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                  Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
                  Objects and States
                  Objects:        29996
                  States:         25284
                  Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists... Done
                  Pending Updates: 16
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:38893           0.0.0.0:*               LISTEN      103        6574       1059/rpc.statd
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7524       1181/io.mqtt.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3950       815/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6370       815/iobroker.js-con
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8253       1/init
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6304       828/sshd: /usr/sbin
                  tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       4583563    939275/io.hm-rpc.1
                  tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       4583690    939361/io.hm-rpc.2
                  tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       4578722    938471/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:35019           0.0.0.0:*               LISTEN      0          7907678    -
                  tcp6       0      0 :::45649                :::*                    LISTEN      0          7907680    -
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          7274       1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          6306       828/sshd: /usr/sbin
                  tcp6       0      0 :::8095                 :::*                    LISTEN      1001       10781      2307/io.hiobs.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9186       1977/io.simple-api.
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9713       1325/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6447       912/io.admin.0
                  tcp6       0      0 :::8097                 :::*                    LISTEN      1001       562465     120279/io.hiob.0
                  tcp6       0      0 :::35675                :::*                    LISTEN      103        6578       1059/rpc.statd
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9289       1/init
                  udp        0      0 127.0.0.1:811           0.0.0.0:*                           0          8263       1059/rpc.statd
                  udp        0      0 0.0.0.0:42082           0.0.0.0:*                           104        6217       687/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6215       687/avahi-daemon: r
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       8520       1212/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       8521       1212/io.tuya.0
                  udp        0      0 0.0.0.0:35386           0.0.0.0:*                           0          7907677    -
                  udp        0      0 0.0.0.0:44296           0.0.0.0:*                           103        6572       1059/rpc.statd
                  udp6       0      0 :::40946                :::*                                103        6576       1059/rpc.statd
                  udp6       0      0 :::111                  :::*                                0          7276       1/init
                  udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          9281930    788/NetworkManager
                  udp6       0      0 :::5353                 :::*                                104        6216       687/avahi-daemon: r
                  udp6       0      0 :::47552                :::*                                0          7907679    -
                  udp6       0      0 :::43790                :::*                                104        6218       687/avahi-daemon: r
                  2024-04-01 22:57:59.799  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
                  2024-04-01 22:57:59.836  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
                  2024-04-01 23:00:00.006  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Gartenbeleuchtung: Gartenbeleuchtung
                  2024-04-01 23:00:00.009  - info: javascript.0 (960) script.js.Scripts.Allgemein.Prüfung_Regen: Start Regen Check
                  2024-04-01 23:00:00.024  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 2030238
                  2024-04-01 23:00:00.049  - info: javascript.0 (960) script.js.Scripts.Allgemein.Astro: Astro: Gültige Zeiten: [aktueller Tag: 0] | [nächster Tag: 14] | [Aktualisiert: 0] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht
                  2024-04-01 23:00:00.891  - info: javascript.0 (960) script.js.Scripts.Allgemein.Dachfenster_automatisch: Der Server Karte ist Online!!!
                  2024-04-01 23:00:01.531  - info: daswetter.0 (2030238) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.0, js-controller: 5.0.19
                  2024-04-01 23:00:04.032  - info: host.iobroker instance system.adapter.ical.0 started with pid 2030479
                  2024-04-01 23:00:05.135  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
                  2024-04-01 23:00:05.560  - info: ical.0 (2030479) starting. Version 1.14.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.0, js-controller: 5.0.19
                  2024-04-01 23:00:06.323  - info: ical.0 (2030479) processing URL: Muell https://calendar.google.com/calendar/ical/c241cf4fcd482c213a45430df0868c1653d1e8d1b854ece0b0863fdc99bb146b%40group.calendar.google.com/public/basic.ics
                  2024-04-01 23:00:06.428  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
                  2024-04-01 23:00:11.538  - info: ical.0 (2030479) Terminated (NO_ERROR): Without reason
                  2024-04-01 23:00:12.062  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2024-04-01 23:00:12.071  - info: daswetter.0 (2030238) still wrong data structure from server received! repaired...
                  2024-04-01 23:00:14.767  - info: daswetter.0 (2030238) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2024-04-01 23:00:15.272  - info: daswetter.0 (2030238) cleaned everything up...
                  2024-04-01 23:00:15.278  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-04-01 23:00:21.417  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Klingenarbeitszeit wurde aktualisiert:  531.9
                  2024-04-01 23:00:21.440  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Temperatur Akku hat sich geändert: 11.6
                  2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Worx: HTML Aktualisierung: worx.0.202130266301009363E0.mower.status - 1
                  2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Trigger Aktualisierung Worx!1
                  2024-04-01 23:00:21.463  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
                  2024-04-01 23:00:21.498  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
                  iob diag has finished.
                  Press any key for a summary
                                          v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                  Installation:           native
                  Kernel:                 aarch64
                  Userland:               arm64
                  Timezone:               Europe/Berlin (CEST, +0200)
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     16
                  Pending iob updates:    2
                  Nodejs-Installation:    /usr/bin/nodejs         v18.20.0
                                          /usr/bin/npm            10.5.0
                                          /usr/bin/npx            10.5.0
                  Recommended versions are nodejs 18.20.0 and npm 10.5.0
                  MEMORY:
                  Mem:            8.4G        5.4G        1.4G        5.5M        1.8G        3.1G
                  Swap:           104M          0B        104M
                  Total:          8.5G        5.4G        1.5G
                  Active iob-Instances:   47
                  ioBroker Core:          js-controller           5.0.19
                                          admin                   6.15.2
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                29996
                  States:                 25284
                  87M     /opt/iobroker/iobroker-data/objects.jsonl
                  15M     /opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===
                  pi@iobroker:~ $
                    Thomas Braun Most Active @Lucky_ESA last edited by
                    @lucky_esa
                    Das kommt vermutlich bei dir mit Fehler um die Ecke, oder?
                    vcgencmd mem_oom
                      @thomas-braun Natürlich.
                      pi@iobroker:~ $ vcgencmd mem_oom
                      pi@iobroker:~ $ ^C
                      pi@iobroker:~ $ vcgencmd commands
                      commands="commands, set_logging, bootloader_config, bootloader_version, cache_flush, codec_enabled, get_mem, get_rsts, measure_clock, measure_temp, measure_volts, get_hvs_asserts, get_config, get_throttled, pmicrd, pmicwr, read_ring_osc, version, readmr, otp_dump, pmic_read_adc, power_monitor"
                      pi@iobroker:~ $
                      Verwende doch get_throttled.
                      Gruß//Lucky
                        @lucky_esa
                        Dann ist 'mem_oom' wohl aus der Firmware für den RPi5 geflogen. Ich hab den Code jetzt aus dem Skript herausgenommen, die Info war eh nicht so wirklich aussagekräftig.
                        'get_throttled' wird an anderer Stelle natürlich abgefragt.
                          Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                          Neuer Diagnosepunkt
                          'Life Cycle Status'
                          ist drin. Können bitte User von Dockern und LXCs da mal schauen ob und mit welchen Meldungen da im Langtext und in der Zusammenfassung da sowas erscheint?
                          (Bitte wie im ersten Eröffungsposting in diesem Thread gezeigt direkt vom github laden).
                          *** LIFE CYCLE STATUS ***
                          Your Operating System codenamed 'trixie' is a testing release! Please use it only for testing purposes!
                          Gleiche Meldung dann in der Summary.
                          Danke schön!
                          S Feuersturm 2 Replies Last reply Reply Quote 3
                            Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
                            LXCs
                            Gerne:
                            Your Operating System is the current Debian stable version 'bookworm'!
                            Und Summery am Ende:
                            Dolomiti 1 Reply Last reply Reply Quote 0
                            • Dolomiti
                              Dolomiti @Shadowhunter23 last edited by
                              LXCs
                              Weder im Langtext noch in der Zusammenfassung wir etwas angezeigt. Egal ob über iob diag oder dem direktem Skritpaufruf aus deiner Signatur.
                              js-controller: 6.0.10
                              admin:7.0.24
                              npm: 20.16.0
                                Homoran Global Moderator Administrators @Dolomiti last edited by
                                @dolomiti sagte in iob diag - Skript:
                                du sollst ja auch den Testaufruf aus dem ersten Post ausführen, damit das neue Skript nach Testung freigeschaltet werden kann.
                                • Dolomiti
                                  Dolomiti @Homoran last edited by Dolomiti
                                  @homoran sagte in iob diag - Skript:
                                  Dann hätte Thomas evtl. ein Hinweis schreiben sollen, dass man das Skript aus dem ersten Post nehmen soll. Das geht aus der Meldung von vor 5 Stunden nicht hervor.
                                  @Thomas-Braun
                                  Davon abgesehehn kommt bei mir nix im Langtext und folgendes in der Zusammenfassung
                                    Homoran Global Moderator Administrators @Dolomiti last edited by Homoran
                                    das soll ja getestet werden.
                                    Müsste im oberen Drittel stehen, und bei dir ebenfalls grün sein
                                    EDIT:
                                    siehe Post von @Meister-Mopper
                                    • Meister Mopper
                                      Meister Mopper last edited by
                                      Hier das Ergebnis meines Master-LXC (trixie habe ich aber auf keinem lxc laufen).
                                      bash
                                      Skript v.2024-08-18
                                      *** BASE SYSTEM ***
                                            Icon name: computer-container
                                              Chassis: container ☐
                                       Virtualization: lxc
                                               Kernel: Linux 6.8.12-1-pve
                                      OS is similar to:
                                      model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
                                      Docker          : false
                                      Virtualization  : lxc
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      18:04:19 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
                                      CPU threads: 2
                                                    Local time: Sun 2024-08-18 18:04:19 CEST
                                                Universal time: Sun 2024-08-18 16:04:19 UTC
                                                      RTC time: n/a
                                                   NTP service: inactive
                                               RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      thomas
                                      HOME=/home/thomas
                                      GROUPS=thomas adm dialout sudo systemd-journal redis iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video redis
                                      *** Display-Server-Setup ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            6.4G        3.2G        3.1G        126K        161M        3.3G
                                      Swap:             0B          0B          0B
                                      Total:          6.4G        3.2G        3.1G
                                      Active iob-Instances:   54
                                              6144 M total memory
                                              3022 M used memory
                                              2280 M active memory
                                               781 M inactive memory
                                              2967 M free memory
                                                 0 M buffer memory
                                               154 M swap cache
                                                 0 M total swap
                                                 0 M used swap
                                                 0 M free swap
                                      top - 18:04:20 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
                                      Tasks:  63 total,   2 running,  61 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   6144.0 total,   2966.1 free,   3023.8 used,    154.2 buff/cache
                                      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   3120.2 avail Mem
                                       UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                                      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                                      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                      * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                                      LOAD   = Reflects whether the unit definition was properly loaded.
                                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                      SUB    = The low-level unit activation state, values depend on unit type.
                                      3 loaded units listed.
                                      *** FILESYSTEM ***
                                      rpool/data/subvol-100-disk-1 zfs        32G  8.5G   24G  27% /
                                      none                         tmpfs     492K  4.0K  488K   1% /dev
                                      udev                         devtmpfs   16G     0   16G   0% /dev/tty
                                      tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
                                      tmpfs                        tmpfs     6.3G  120K  6.3G   1% /run
                                      tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
                                      tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1000
                                      dmesg: read kernel buffer failed: Operation not permitted
                                      Show mounted filesystems:
                                      /      rpool/data/subvol-100-disk-1 zfs    rw,noatime,xattr,posixacl,casesensitive
                                      /var:
                                      872M    /var/
                                      544M    /var/cache
                                      541M    /var/cache/apt
                                      494M    /var/cache/apt/archives
                                      212M    /var/log
                                      Archived and active journals take up 200.2M in the file system.
                                      138M    /opt/iobroker/backups/
                                      832M    /opt/iobroker/iobroker-data/
                                      518M    /opt/iobroker/iobroker-data/files
                                      276M    /opt/iobroker/iobroker-data/backup-objects
                                      185M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      169M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                      15M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                      11M     /opt/iobroker/iobroker-data/objects.jsonl
                                      11M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                                      8.4M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
                                      USB-Devices by-id:
                                      No Devices found 'by-id'
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
                                      /usr/bin/nodejs         v20.16.0
                                      /usr/bin/node           v20.16.0
                                      /usr/bin/npm            10.8.1
                                      /usr/bin/npx            10.8.1
                                      /usr/bin/corepack       0.28.2
                                      nodejs:
                                       Installed: 20.16.0-1nodesource1
                                       Candidate: 20.16.0-1nodesource1
                                       Version table:
                                      *** 20.16.0-1nodesource1 1001
                                             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                          20.15.1-1nodesource1 1001
                                          20.15.0-1nodesource1 1001
                                          20.14.0-1nodesource1 1001
                                          20.13.1-1nodesource1 1001
                                          20.13.0-1nodesource1 1001
                                          20.12.2-1nodesource1 1001
                                          20.12.1-1nodesource1 1001
                                          20.12.0-1nodesource1 1001
                                          20.11.1-1nodesource1 1001
                                          20.11.0-1nodesource1 1001
                                          20.10.0-1nodesource1 1001
                                          20.9.0-1nodesource1 1001
                                          20.8.1-1nodesource1 1001
                                          20.8.0-1nodesource1 1001
                                          20.7.0-1nodesource1 1001
                                          20.6.1-1nodesource1 1001
                                          20.6.0-1nodesource1 1001
                                          20.5.1-1nodesource1 1001
                                          20.5.0-1nodesource1 1001
                                          20.4.0-1nodesource1 1001
                                          20.3.1-1nodesource1 1001
                                          20.3.0-1nodesource1 1001
                                          20.2.0-1nodesource1 1001
                                          20.1.0-1nodesource1 1001
                                          20.0.0-1nodesource1 1001
                                          18.19.0+dfsg-6~deb12u2 500
                                             500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                             500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: redis
                                      js-controller:  6.0.9
                                      admin:          7.0.22
                                      javascript:     8.7.6
                                      nodejs modules from github:     4
                                      +-- iobroker.bluelink@2.3.6 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#cfdb728c50b2373f05766dba34797a220302d309)
                                      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                      +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#fcdfef2d5daac95190d5ab2ba2ab5e213f937a41)
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                       system.adapter.alias-manager.0          : alias-manager         : rpizigbee                                -  enabled
                                      + system.adapter.backitup.1               : backitup              : rpizigbee                                -  enabled
                                      + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
                                      + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                       system.adapter.daswetter.0              : daswetter             : rpizigbee                                -  enabled
                                      + system.adapter.denon.0                  : denon                 : rpizigbee                                -  enabled
                                       system.adapter.dwd.0                    : dwd                   : rpizigbee                                -  enabled
                                      + system.adapter.enigma2.0                : enigma2               : rpizigbee                                -  enabled
                                      + system.adapter.enigma2.1                : enigma2               : rpizigbee                                -  enabled
                                      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                      + system.adapter.heos.0                   : heos                  : rpizigbee                                -  enabled
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
                                      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
                                      + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                       system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                       system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                                       system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                                       system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                       system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                                       system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                      + system.adapter.linux-control.0          : linux-control         : rpizigbee                                -  enabled
                                      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                      + system.adapter.nut.1                    : nut                   : iobroker                                 -  enabled
                                      + system.adapter.ocpp.0                   : ocpp                  : rpizigbee                                -  enabled, port: 9220
                                      + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
                                      + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                                      + system.adapter.pi-hole.1                : pi-hole               : rpizigbee                                -  enabled
                                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                                      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                      + system.adapter.rpi2.0                   : rpi2                  : rpizigbee                                -  enabled
                                      + system.adapter.samsung_tizen.0          : samsung_tizen         : rpizigbee                                -  enabled, port: 8002
                                      + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                      + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                                      + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                                      + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                                      + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
                                      + system.adapter.sayit.5                  : sayit                 : iobroker                                 -  enabled
                                      + system.adapter.smartmeter.0             : smartmeter            : rpizigbee                                -  enabled
                                      + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 8883, bind: 0.0.0.0
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : rpizigbee                                -  enabled
                                      + system.adapter.tuya.0                   : tuya                  : rpizigbee                                -  enabled
                                      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                      + system.adapter.vaillant.0               : vaillant              : rpizigbee                                -  enabled
                                       system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                       system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                                       system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                                       system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                                       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                       system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                       system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                                       system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                                       system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                      + system.adapter.yeelight-2.0             : yeelight-2            : rpizigbee                                -  enabled
                                      + system.adapter.zigbee.0                 : zigbee                : rpizigbee                                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
                                      + instance is alive
                                      │ (index) │ name            │ url                                                     │ auto upgrade │
                                      │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                      │ 1       │ '(beta) latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                      │ 2       │ 'stable-live'   │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                                      │ 3       │ 'latest-live'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                                      Upgrade policy: none
                                      Used repository: stable
                                      Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
                                      Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                                      Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                      Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                      Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
                                      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                      Adapter    "harmony"      : 1.4.0    , installed 1.4.0
                                      Adapter    "heos"         : 2.2.1    , installed 2.2.1
                                      Adapter    "hue"          : 3.11.0   , installed 3.11.0
                                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                      Controller "js-controller": 6.0.9    , installed 6.0.9
                                      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                      Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                      Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                                      Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
                                      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                                      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                                      Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                                      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                      Adapter    "solax"        : 0.9.9    , installed 0.9.9
                                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                      Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
                                      Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                      Adapter    "traccar"      : 1.1.4    , installed 1.1.4
                                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                      Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
                                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                      Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                      Objects and States
                                      Objects:        23058
                                      States:         24327
                                      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          35104      131/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32330      1/init
                                      tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      110        32536      124/redis-server 0.
                                      tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       39136      393/io.hm-rpc.1
                                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       34416      137/iobroker.js-con
                                      tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      1001       67265983   3623001/io.sonoff.0
                                      tcp        0      0 192.168.178.10:2001     0.0.0.0:*               LISTEN      1001       39803      568/io.hm-rpc.0
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       44592      880/io.fullybrowser
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          35115      131/sshd: /usr/sbin
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          32332      1/init
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       47625      1034/io.simple-api.
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9871275    531497/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34578      156/io.admin.0
                                      tcp6       0      0 :::6556                 :::*                    LISTEN      0          32456      1/init
                                      tcp6       0      0 ::1:6379                :::*                    LISTEN      110        32537      124/redis-server 0.
                                      tcp6       0      0 :::61991                :::*                    LISTEN      1001       39003      268/io.harmony.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       92149192   770498/io.chromecas
                                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       39004      268/io.harmony.0
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32331      1/init
                                      udp6       0      0 :::111                  :::*                                0          32333      1/init
                                      2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 10: Fenster Konferenzraum:0.LOW_BAT: false
                                      2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 11: Fenster Gästezimmer oben:0.LOW_BAT: false
                                      2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 12: Fenster Bad oben:0.LOW_BAT: false
                                      2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 13: Fenster Fitness:0.LOW_BAT: false
                                      2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 14: Fenster Gäste unten:0.LOW_BAT: false
                                      2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 15: Postkasten:0.LOW_BAT: false
                                      2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 16: Heizung Küche:0.LOW_BAT: false
                                      2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 17: Heizung Bad unten:0.LOW_BAT: false
                                      2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 18: Heizung Schlafzimmer:0.LOW_BAT: false
                                      2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 19: Heizung Wohnzimmer:0.LOW_BAT: false
                                      2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 20: Heizung Gästezimmer oben:0.LOW_BAT: false
                                      2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 21: Heizung Konferenzraum:0.LOW_BAT: false
                                      2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 22: Heizung Bad oben:0.LOW_BAT: false
                                      2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 23: Heizung Büro:0.LOW_BAT: false
                                      2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 24: Heizung Fitnessraum:0.LOW_BAT: false
                                      2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 25: Heizung Gästezimmer unten:0.LOW_BAT: false
                                      2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 26: Presence Kueche:0.LOW_BAT: false
                                      2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 27: Lichtsensor:0.LOW_BAT: false
                                      2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 28: Sensor Bad unten:0.LOW_BAT: false
                                      2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 29: Sensor Wohnzimmer:0.LOW_BAT: false
                                      2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 30: Außenthermometer:0.LOW_BAT: false
                                      2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 31: Wetterstation:0.LOW_BAT: true
                                      2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 32: Heizung Bad oben 2:0.LOW_BAT: false
                                      2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Text: Wetterstation:0.LOW_BAT
                                      2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Anzahl Geräte: 34 # davon LOWBAT erkannt: 1
                                      • Dolomiti
                                        @Thomas-Braun
                                        OK. In der Langfassung kommt der Text weiter oben.
                                        Bei mir also ok
                                          Thomas Braun Most Active @Meister Mopper last edited by
                                          @meister-mopper sagte in iob diag - Skript:
                                          Trixie ist ja auch eine Ausgabe von meinem System....
                                          • Meister Mopper
                                            Meister Mopper @Thomas Braun last edited by
                                            @thomas-braun sagte in iob diag - Skript:
                                            I know, es war nur eine Ergänzung für Mitleser.
                                            738
                                            151250
