    4. iobroker exit 25 bei Adapter-Update
      Siggi0904 @Thomas Braun last edited by
      @thomas-braun yeah, das hat geholfen. Javascript ist wieder da.
      Da hat sich wohl jemand verschluckt.
        Thomas Braun Most Active @Siggi0904 last edited by
        @siggi0904
        Zeig mal das Gesamtkunstwerk...
        iob diag
        in der Langfassung.
          @thomas-braun sollst du bekommen:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-vm
                   Chassis: vm 🖴
            Virtualization: kvm
                    Kernel: Linux 6.1.0-18-amd64
              Architecture: x86-64
           Hardware Vendor: QEMU
            Hardware Model: Standard PC _i440FX + PIIX, 1996_
          Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           21:21:58 up 34 min,  2 users,  load average: 0.18, 0.30, 0.43
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Wed 2024-04-03 21:21:58 CEST
                     Universal time: Wed 2024-04-03 19:21:58 UTC
                           RTC time: Wed 2024-04-03 19:21:58
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          mario
          /home/mario
          mario adm sudo iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.1G        2.8G        607M        499K        960M        1.3G
          Swap:           4.3G         59M        4.2G
          Total:          8.4G        2.9G        4.8G
                   3915 M total memory
                   2664 M used memory
                    480 M active memory
                   2539 M inactive memory
                    579 M free memory
                     91 M buffer memory
                    824 M swap cache
                   4092 M total swap
                     56 M used swap
                   4036 M free swap
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.9G     0  1.9G   0% /dev
          tmpfs          tmpfs     392M  552K  392M   1% /run
          /dev/sda1      ext4       45G  9.7G   34G  23% /
          tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     392M     0  392M   0% /run/user/1001
          [Wed Apr  3 20:47:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Apr  3 20:47:28 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          3.7G    /var/
          3.5G    /var/log
          3.4G    /var/log/journal/06882d2afcc64e848dd2d19ddcda7ca8
          192M    /var/lib
          Archived and active journals take up 3.3G in the file system.
          /opt/iobroker/backups:
          1.4M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          435M    /opt/iobroker/iobroker-data/
          253M    /opt/iobroker/iobroker-data/files
          121M    /opt/iobroker/iobroker-data/backup-objects
          58M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          30M     /opt/iobroker/iobroker-data/objects.jsonl
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          9.7M    /opt/iobroker/iobroker-data/states.jsonl
          9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2139836-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.1
          /usr/bin/node           v18.20.1
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          nodejs:
            Installed: 18.20.1-1nodesource1
            Candidate: 18.20.1-1nodesource1
            Version table:
           *** 18.20.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0+dfsg-6~deb12u1 500
                  500 https://deb.debian.org/debian-security bookworm-security/main amd64 Packages
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
          npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
          npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
          npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
          npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
          npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
          npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
          npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
          npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
          npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
          npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
          npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
          npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
          npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
          npm ERR! A complete log of this run can be found in: /home/mario/.npm/_logs/2024-04-03T19_22_04_172Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.13.16
          javascript:     7.8.0
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
          + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
          + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
          + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "alarm"        : 3.6.0    , installed 3.6.0
          Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "awtrix-light" : 0.16.0   , installed 0.16.0
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "deconz"       : 1.4.0    , installed 1.4.0
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
          Adapter    "ical"         : 1.14.3   , installed 1.14.3
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Adapter    "mihome-vacuum": 4.1.1    , installed 4.2.0
          Adapter    "openweathermap": 1.0.4   , installed 1.0.4
          Adapter    "shelly"       : 6.8.0    , installed 6.8.0
          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "trashschedule": 3.2.0    , installed 3.2.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.11   , installed 2.5.11
          Objects and States
          Objects:        11202
          States:         9365
          Hit:1 http://phoscon.de/apt/deconz bookworm InRelease
          Hit:2 https://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       16341      443/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       16349      443/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15846      475/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13256      1/init
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16050      437/deCONZ
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16294      437/deCONZ
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16268      770/exim4
          tcp        0      0 192.168.178.64:2001     0.0.0.0:*               LISTEN      1000       16918      908/io.hm-rpc.1
          tcp        0      0 192.168.178.64:2010     0.0.0.0:*               LISTEN      1000       16864      893/io.hm-rpc.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       18353      1026/io.sonoff.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15863      475/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          13262      1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16269      770/exim4
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       19722      1191/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       16491      797/io.admin.0
          udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1000       18887      1057/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15766      430/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       19228      1107/io.shelly.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       19979      1243/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16330      437/deCONZ
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15482      405/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13259      1/init
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       19325      1139/io.mihome-vacu
          udp        0      0 0.0.0.0:59854           0.0.0.0:*                           107        15768      430/avahi-daemon: r
          udp        0      0 0.0.0.0:47686           0.0.0.0:*                           1000       41292      2805/io.javascript.
          udp6       0      0 :::5353                 :::*                                107        15767      430/avahi-daemon: r
          udp6       0      0 :::38572                :::*                                107        15769      430/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1000       19981      1243/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1000       19980      1243/io.deconz.0
          udp6       0      0 :::111                  :::*                                0          13265      1/init
          2024-04-03 21:10:00.036  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2901
          2024-04-03 21:10:02.750  - info: dwd.0 (2901) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
          2024-04-03 21:10:05.230  - info: dwd.0 (2901) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-04-03 21:10:05.756  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-04-03 21:13:35.422  - info: admin.0 (797) ==> Connected system.user.admin from ::ffff:192.168.178.41
          2024-04-03 21:15:00.038  - info: javascript.0 (2805) script.js.Skripte.Wohnung.VerbrauchTasmota: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6
          2024-04-03 21:15:00.100  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3532
          2024-04-03 21:15:00.109  - info: javascript.0 (2805) script.js.Skripte.Wohnung.VerbrauchShelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
          2024-04-03 21:15:00.150  - info: javascript.0 (2805) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
          2024-04-03 21:15:02.595  - info: dwd.0 (3532) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
          2024-04-03 21:15:04.109  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 3548
          2024-04-03 21:15:05.029  - info: dwd.0 (3532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-04-03 21:15:05.673  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-04-03 21:15:08.349  - info: daswetter.0 (3548) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.1, js-controller: 5.0.19
          2024-04-03 21:15:14.554  - info: daswetter.0 (3548) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2024-04-03 21:15:15.073  - info: daswetter.0 (3548) cleaned everything up...
          2024-04-03 21:15:15.086  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-04-03 21:16:13.897  - info: javascript.0 (2805) Stop script script.js.Skripte.Außen.CarportLichtMorgensEin
          2024-04-03 21:16:13.921  - info: javascript.0 (2805) Start javascript script.js.Skripte.Außen.CarportLichtMorgensEin
          2024-04-03 21:16:13.936  - info: javascript.0 (2805) script.js.Skripte.Außen.CarportLichtMorgensEin: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
          2024-04-03 21:16:33.064  - info: admin.0 (797) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
          2024-04-03 21:20:00.019  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3775
          2024-04-03 21:20:02.273  - info: dwd.0 (3775) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
          2024-04-03 21:20:04.491  - info: dwd.0 (3775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-04-03 21:20:05.019  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          Der xmlbuilder Error sieht so aus:
          mario@iobroker:/opt/iobroker$ npm ls xmlbuilder
          iobroker.inst@2.0.3 /opt/iobroker
          ├─┬ iobroker.hm-rega@4.0.0
          │ └─┬ xml2js@0.6.2
          │   └── xmlbuilder@11.0.1
          ├─┬ iobroker.hm-rpc@1.16.0
          │ └─┬ homematic-xmlrpc@1.0.2
          │   └── xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
          ├─┬ iobroker.shelly@6.8.0
          │ └── xmlbuilder@15.1.1
          └─┬ iobroker.tr-064@4.2.18
            └─┬ xml2js@0.4.23
          Das ist aber auch noch im aktuellen Code so alt.
          Da gibt es evtl. schon eine Klärung.
          Ansonsten nochmal großes Danke.
            Thomas Braun Most Active @Siggi0904 last edited by Thomas Braun
            @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
            iob update
            iob upgrade hm-rpc@1.16.0
            Denn eigentlich will der "homematic-xmlrpc": "^1.0.2" haben und nicht den alten Kram.
            Edit: Falsch geschaut...
              @thomas-braun ne, der will die alte Version. Steht in der https://github.com/ioBroker/ioBroker.hm-rpc/blob/master/package-lock.json ab Zeile 3761.
              Beim Fritzox-Adapter tr-061 ist das auch so alt.
                @siggi0904
                Das muss geändert werden. Der Verweis geht ins Leere.
                S mcm1957 2 Replies Last reply Reply Quote 0
                  @thomas-braun Jo, liegt schon per Feature Request im Repo.
                  • mcm1957
                    mcm1957 @Thomas Braun last edited by mcm1957
                    Wieso geht der Verweis ins Leere?
                    Ich kann https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5 einwandfrei downloaden.
                    Abgesehen davon dass wir keine Kontrolle übder diese sub sub Abhängigkeit haben...
                    Das müsste in homematic-xmlrpc geändert werden. Nur das ist auch schon ewig in der Geriatrie ...
                      Thomas Braun Most Active @mcm1957 last edited by
                      @mcm57
                      Weil der invalid ist:
                      • mcm1957
                        Ja aber WARUM ist der invalid?
                        Wobei es eigentlich egal ist - der Adapter lebt von homematic-xmlrpc und da ist 1.0.2 die neueste Version un die verlangt xmlbuilder@0.4.2.
                        Und bei mir läßt sich der Adapter problemlos installieren:
                        pi@pi4:~ $ iob add iobroker.hm-rpc
                        NPM version: 10.2.4
                        Installing iobroker.hm-rpc@1.16.0... (System call)
                        added 12 packages in 17s
                        154 packages are looking for funding
                          run `npm fund` for details
                        host.pi4 install adapter hm-rpc
                        upload [281] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                        upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                        upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                        upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/204_hmip-drdi3_thumb.png icons/204_hmip-drdi3_thumb.png image/png
                        upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/43_hm-cc-vd_thumb.png icons/43_hm-cc-vd_thumb.png image/png
                        upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/52_hm-sec-sd-team_thumb.png icons/52_hm-sec-sd-team_thumb.png image/png
                        upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/5_hm-lc-sw2-fm_thumb.png icons/5_hm-lc-sw2-fm_thumb.png image/png
                        upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/6_hm-lc-bl1-sm_thumb.png icons/6_hm-lc-bl1-sm_thumb.png image/png
                        upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/80_hm-sen-mdir-o_thumb.png icons/80_hm-sen-mdir-o_thumb.png image/png
                        upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/88_hm-lc-sw4-ba-pcb_thumb.png icons/88_hm-lc-sw4-ba-pcb_thumb.png image/png
                        upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/9_hm-ws550-us_thumb.png icons/9_hm-ws550-us_thumb.png image/png
                        upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/OM55_DimmerSwitch_thumb.png icons/OM55_DimmerSwitch_thumb.png image/png
                        upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                        upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                        upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                        upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                        upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                        upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                        upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                        upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                        upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                        upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                        upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                        upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                        upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                        upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                        upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                        upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                        upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                        upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index.html index.html text/html
                        upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
                        upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                        upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                        host.pi4 object _design/hm-rpc created/updated
                        host.pi4 object system.adapter.hm-rpc created/updated
                        host.pi4 create instance hm-rpc
                        host.pi4 object system.adapter.hm-rpc.0.alive created
                        host.pi4 object system.adapter.hm-rpc.0.connected created
                        host.pi4 object system.adapter.hm-rpc.0.compactMode created
                        host.pi4 object system.adapter.hm-rpc.0.cpu created
                        host.pi4 object system.adapter.hm-rpc.0.cputime created
                        host.pi4 object system.adapter.hm-rpc.0.memHeapUsed created
                        host.pi4 object system.adapter.hm-rpc.0.memHeapTotal created
                        host.pi4 object system.adapter.hm-rpc.0.memRss created
                        host.pi4 object system.adapter.hm-rpc.0.uptime created
                        host.pi4 object system.adapter.hm-rpc.0.inputCount created
                        host.pi4 object system.adapter.hm-rpc.0.outputCount created
                        host.pi4 object system.adapter.hm-rpc.0.eventLoopLag created
                        host.pi4 object system.adapter.hm-rpc.0.sigKill created
                        host.pi4 object system.adapter.hm-rpc.0.logLevel created
                        host.pi4 object hm-rpc.0.updated created
                        host.pi4 object hm-rpc.0.info created
                        host.pi4 object hm-rpc.0.info.connection created
                        host.pi4 Set default value of hm-rpc.0.info.connection: false
                        host.pi4 object system.adapter.hm-rpc.0 created
                        pi@pi4:/opt/iobroker $ npm ls xmlbuilder
                        iobroker.inst@3.0.0 /opt/iobroker
                        ├─┬ iobroker.shelly@6.6.1
                        │ ├─┬ xml2js@0.6.2
                        │ │ └── xmlbuilder@11.0.1
                        ├─┬ iobroker.systeminfo@1.1.0
                        │ └─┬ xml2js@0.6.2
                          └─┬ xml2js@0.4.23
                        OK node v18.19.1
                        Check mal ob du https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5 vom ioBroker hist aus erreichen kannst. NIcht dass da new Firewall o.ä. Zugriffe auf Github blocket. Alles schon dagewesen...
                          @mcm57 sagte in iobroker exit 25 bei Adapter-Update:
                          Keine Ahnung. Ich sowas schon mal bei Adaptern aus dem github. Die werden dann auch als invalid angezeigt.
                          Wenn dann irgendeiner der Adapter nochmal reingezogen wird sind auch die anderen Verweise wieder valide.
                          • mcm1957
                            OK - na dann halt nochmal instzallieren.
                            Im ioBroker Adapter seh ich wenig Chancen da was zu machen. Außer jemand hat Zeit und Lust den Basiscode (externe lib) zu froken, zu aktualisisern und zu testen - oder neu zu schreiben. Aber mal sehen.
                            • Z
                              ZeroQool @Siggi0904 last edited by
                              @siggi0904
                              Ich habe seit kurzem das gleiche Problem. Ich bekomme 5 Adapter Updates angezeigt und bei jedem kommt die gleiche Fehlermeldung.
                              $ iobroker upgrade socketio@6.6.1
                              Update socketio from @6.6.0 to @6.6.1
                              host.iobroker Adapter "system.adapter.socketio.0" is stopped.
                              NPM version: 10.5.0
                              Installing iobroker.socketio@6.6.1... (System call)
                              npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-06T09_30_24_064Z-debug-0.loghost.iobroker Cannot install iobroker.socketio@6.6.1: 127
                              ERROR: Process exited with code 25
                              iob nodejs-update
                              Habe ich bereits gemacht. Keine Veränderung. Da muss doch allgemein etwas passiert sein.
                                Siggi0904 @ZeroQool last edited by
                                @zeroqool hast du denn den mihome-vacuum Adapter installiert?
                                Der war, ich hoffe es, bei mir das Problem.
                                Wenn du davon die Beta installierst, oder auf die stable 4.2.0 wartest behebt es das zlib Problem.
                                Denn dann dürfte grep -r node-waf kein zlib mehr anzeigen.
                                Ansonsten zeig mal, was bei npm ls zlib rauskommt.
                                Z 2 Replies Last reply Reply Quote 0
                                • Z
                                  @siggi0904 Glaube habe ein allg. Problem. Es läßt sich kein Adapter mehr installieren, die gleiche Fehlermeldung wie beim Update. Habe letztens alles mit iob nodejs-update aktualisiert. Sieht auch von den Versionen sauber aus.
                                  • Z
                                    @siggi0904 said in iobroker exit 25 bei Adapter-Update:
                                    npm ls zlib
                                    root@iobroker:/opt/iobroker# npm ls zlib
                                    iobroker.inst@2.0.2 /opt/iobroker
                                    -- iobroker.mihome-vacuum@4.1.1 -- zlib@1.0.5
                                    • Z
                                      grep -r node-waf
                                      ist ein riesen Log aber mit Fehler:
                                        Thomas Braun Most Active @ZeroQool last edited by
                                        @zeroqool sagte in iobroker exit 25 bei Adapter-Update:
                                        NICHT als root herum hampeln. Und schon gar nicht im Verzeichnis von iobroker mit npm...
                                        Logs auch nicht als Screenshot sonder als Text in CodeTags.
                                        Als USER!
                                        iob stop
                                        iob fix
                                        iob update
                                        • Z
                                          ZeroQool @Thomas Braun last edited by ZeroQool
                                          @thomas-braun OK, aber muss zugeben, dass ich den Proxmox Container seit mehreren Jahren so laufen habe.
                                          iob stop && iob update && iob fix && iob upgrade self && iob start
                                          Habe ich auch schon ausgeführt. aber keine Verbesserung. hatte vorher node 14 oder so u nun 18.20.1
                                            Das heißt ja nix. Nur das du es dann halt seit Jahren falsch machst.
                                            Habe ich auch schon ausgeführt. aber keine Verbesserung. hatte vorher node 14 oder so u nun 16
                                            Zeigen. Und aktuell ist nodejs@18...
                                            Zeig am besten mal den ganzen Quark...
                                            iob stop
                                            iob fix
                                            iob diag
                                            13053
