    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Worx Adapter läuft nicht mehr
      RaWa @Lucky_ESA last edited by
      @lucky_esa Vielen Dank! Ich mach mich mal dran.
        RaWa @sigi234 last edited by
        @sigi234 Danke dir. Mal gespannt ob ich es hinbekomme.
        Schöne Ostern!
          RaWa @RaWa last edited by RaWa
          @Lucky_ESA so, ich denke ich habe alles erledigt (hoffentlich)
          Dummerweise läuft der worx adapter immer noch nicht.
          host.IOBrokerPC
          2024-04-01 16:50:02.175	info	Restart adapter system.adapter.worx.0 because enabled
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: Node.js v18.20.0
          host.IOBrokerPC
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: }
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12) {
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\aws-crt\dist\native\binding.js:104:19)
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          host.IOBrokerPC
          host.IOBrokerPC
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1460:18)
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: \\?\C:\ioBroker\node_modules\aws-crt\dist\bin\win32-x64-cruntime\aws-crt-nodejs.node
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: Error: Das angegebene Modul wurde nicht gefunden.
          host.IOBrokerPC
          host.IOBrokerPC
          2024-04-01 16:50:02.175	error	Caught by controller[0]: ^
          host.IOBrokerPC
          2024-04-01 16:50:02.174	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
          host.IOBrokerPC
          2024-04-01 16:50:02.174	error	Caught by controller[0]: node:internal/modules/cjs/loader:1460
          host.IOBrokerPC
          2024-04-01 16:50:01.521	info	instance system.adapter.worx.0 started with pid 5088
          Windows 10
          Node.js: v18.20.0
          js controller 5.0.19
          worx Version 2.3.4
          hab ich was falsch gemacht bzw. vergessen ?
          Viele Grüße
            Lucky_ESA Developer Most Active @RaWa last edited by
            @rawa Hast du den iob fix ausgeführt?
              Lucky_ESA Developer Most Active @RaWa last edited by Lucky_ESA
              @rawa Habe heute mal versucht auf Windows 11 diesen Fehler zu simulieren. Egal was ich versucht habe um so eine Schiefe installation hinzubekommen, habe ich es einfach nicht geschafft. Der Adapter wird sauber installiert und funktioniert einwandfrei. Aus purer Verzweifelung habe ich dann die aws-crt-nodejs.node gelöscht. Das zeigt mit zumindest ein ähnliches Fehlerbild an.
              Schau mal bitte ob du diesen Ordner hast.
              Wenn nein, bis wohin kommst du? Wenn ja, dann entzippe den Anhang (aws-crt-nodejs.node) und lade diese Datei in den Ordner C:\ioBroker\node_modules\aws-crt\dist\bin\win32-x64-cruntime\
              Der Adapter kann nun mit diesem Fehler umgehen und verwendet dann die alte Verbindung. Muss das morgen noch testen und dann lade ich es auf GIT hoch. Dann musst du von GIT installieren. Du musst aber vorher unter Adapter die Instanz deinstallieren.
              aws-crt-nodejs.zip
              Vision User dürfen auf keinen Fall derzeit von GIT laden. @hsteinme und ich implementieren derzeit komplett den Vision und Kress. Es werden sonst ungewünschte Datenpunkte erstellt.
              Gruß//Lucky
                @lucky_esa ja, habe ich
                  @rawa sagte in Worx Adapter läuft nicht mehr:
                  Dann versuche mal mein nächsten Post umzusetzen. Habe die alte Verbindung bereits auf GIT. Aber bitte erst die Datei mal bei dir einfügen und schauen ob es funktioniert.
                  Gruß//Lucky
                    @lucky_esa Worx Adapter deinstalliert, Pfad war vorhanden. IoBroker gestoppt.
                    aws-crt-nodejs.node in .bak umbenannt, deine Datei entzipt und in das Verzeichnis kopiert. Worx installiert - gleiches Ergebnis, leider. Keine Verbindung mit Host.
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	info	Restart adapter system.adapter.worx.0 because enabled
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: Node.js v18.20.0
                    host.IOBrokerPC
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: }
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12) {
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.321	error	Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\aws-crt\dist\native\binding.js:104:19)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1460:18)
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: \\?\C:\ioBroker\node_modules\aws-crt\dist\bin\win32-x64-cruntime\aws-crt-nodejs.node
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: Error: Das angegebene Modul wurde nicht gefunden.
                    host.IOBrokerPC
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: ^
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                    host.IOBrokerPC
                    2024-04-03 22:22:37.320	error	Caught by controller[0]: node:internal/modules/cjs/loader:1460
                    host.IOBrokerPC
                    2024-04-03 22:22:35.757	info	instance system.adapter.worx.0 started with pid 6488
                    modbus.0
                    8396	2024-04-03 22:22:08.806	warn	On error: {"errno":-4078,"code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                    modbus.0
                    8396	2024-04-03 22:22:08.806	error	Client in error state.
                    modbus.0
                    8396	2024-04-03 22:22:08.806	error	Socket Error
                      RaWa @Lucky_ESA last edited by RaWa
                      @lucky_esa habe das Gleiche noch einmal versucht. Nach dem deinstallieren des Worx Adapters hört der Pfad hier auf: C:\ioBroker\node_modules
                      Adapter installiert, Pfad wieder kompeltt da, die Datei gegen deine getauscht, dann den Adapter eingerichtet - leider auch negativ
                        @rawa
                        Irgendwas stimmt mit deinem Sytem nicht.
                        Als Workaround kannst du vom Git laden aber das löst eigentlich dein Problem nicht. Wenn die Datei vorhanden ist aber nicht geladen werden kann, ist leider ein Problem wobei ich dir nicht helfen kann.
                        Gruß//Lucky
                        1.0k
                        1069
