    4. [Gelöst Blockly] Javascript Adapter hängt sich bei Skript auf
      @Dutchman:
      @RappiRN
      Hat du logs wen der Fehler Auftritt? `
      Na klar 😄 :
      2017-12-19 08:19:51.574 - [31merror[39m: Caught by controller[0]: ReferenceError: e is not defined 2017-12-19 08:19:51.580 - [31merror[39m: Caught by controller[0]: at Request. <anonymous>(script.js.Komfort-Steuerungen.Display_Tablets:24:113) 2017-12-19 08:19:51.581 - [31merror[39m: Caught by controller[0]: at emitOne (events.js:96:13) 2017-12-19 08:19:51.581 - [31merror[39m: Caught by controller[0]: at Request.emit (events.js:188:7) 2017-12-19 08:19:51.582 - [31merror[39m: Caught by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:884:8) 2017-12-19 08:19:51.582 - [31merror[39m: Caught by controller[0]: at emitOne (events.js:96:13) 2017-12-19 08:19:51.582 - [31merror[39m: Caught by controller[0]: at ClientRequest.emit (events.js:188:7) 2017-12-19 08:19:51.582 - [31merror[39m: Caught by controller[0]: at Socket.socketErrorListener (_http_client.js:310:9) 2017-12-19 08:19:51.583 - [31merror[39m: Caught by controller[0]: at emitOne (events.js:96:13) 2017-12-19 08:19:51.583 - [31merror[39m: Caught by controller[0]: at Socket.emit (events.js:188:7) 2017-12-19 08:19:51.583 - [31merror[39m: Caught by controller[0]: at emitErrorNT (net.js:1281:8) 2017-12-19 08:19:51.583 - [31merror[39m: Caught by controller[1]: ReferenceError: e is not defined 2017-12-19 08:19:51.584 - [31merror[39m: Caught by controller[1]: at Request. <anonymous>(script.js.Komfort-Steuerungen.Display_Tablets:24:113) 2017-12-19 08:19:51.584 - [31merror[39m: Caught by controller[1]: at emitOne (events.js:96:13) 2017-12-19 08:19:51.584 - [31merror[39m: Caught by controller[1]: at Request.emit (events.js:188:7) 2017-12-19 08:19:51.584 - [31merror[39m: Caught by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:884:8) 2017-12-19 08:19:51.584 - [31merror[39m: Caught by controller[1]: at emitOne (events.js:96:13) 2017-12-19 08:19:51.584 - [31merror[39m: Caught by controller[1]: at ClientRequest.emit (events.js:188:7) 2017-12-19 08:19:51.585 - [31merror[39m: Caught by controller[1]: at Socket.socketCloseListener (_http_client.js:286:9) 2017-12-19 08:19:51.585 - [31merror[39m: Caught by controller[1]: at emitOne (events.js:101:20) 2017-12-19 08:19:51.585 - [31merror[39m: Caught by controller[1]: at Socket.emit (events.js:188:7) 2017-12-19 08:19:51.585 - [31merror[39m: Caught by controller[1]: at TCP._handle.close [as _onclose] (net.js:497:12) 2017-12-19 08:19:51.585 - [31merror[39m: host.SMARTHOME-PC instance system.adapter.javascript.1 terminated with code 0 (OK) 2017-12-19 08:19:51.585 - [32minfo[39m: host.SMARTHOME-PC Restart adapter system.adapter.javascript.1 because enabled 2017-12-19 08:20:21.631 - [32minfo[39m: host.SMARTHOME-PC instance system.adapter.javascript.1 started with pid 16524 2017-12-19 08:20:23.753 - [32minfo[39m: javascript.1 starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.12.0 2017-12-19 08:20:23.770 - [32minfo[39m: javascript.1 requesting all states 2017-12-19 08:20:23.774 - [32minfo[39m: javascript.1 requesting all objects 2017-12-19 08:20:26.281 - [32minfo[39m: javascript.1 received all states 2017-12-19 08:20:28.070 - [32minfo[39m: javascript.1 received all objects 2017-12-19 08:20:28.357 - [32minfo[39m: javascript.1 Start javascript script.js.Anwesenheit.Anwesenheit_Familie/Zustaende 2017-12-19 08:20:28.428 - [32minfo[39m: javascript.1 script.js.Anwesenheit.Anwesenheit_Familie/Zustaende: registered 9 subscriptions and 1 schedule 2017-12-19 08:20:28.430 - [32minfo[39m: javascript.1 Start javascript script.js.Komfort-Steuerungen.Display_Tablets 2017-12-19 08:20:28.448 - [32minfo[39m: javascript.1 script.js.Komfort-Steuerungen.Display_Tablets: registered 1 subscription and 2 schedules[/code]</anonymous></anonymous>
      ! Und hier noch das Script:
      ! Den Javascript-Absturz habe ich erst seitdem ich diesen Teil aus der CCU2 in ein Script übernommen habe.
      ! Enrico
      ! Edit: Das wäre der Code-Teil zu diesem Blockly-Abschnitt:
      ! >! [spoiler]~~[code]~~}); // Anwesenheit Tasker on({id: "hm-rega.0.4879"/*Anwesenheit_allgemein_neu_Var*/, change: "ne"}, function (obj) { var value = obj.state.val; var oldValue = obj.oldState.val; if (getState("hm-rega.0.4879").val == true) { try { require("request")('http://192.168.178.46:50000/tasker=Anwesenheit').on("error", function () {console.error(e);}); } catch (e) { console.error(e); } console.log("request: " + 'http://192.168.178.46:50000/tasker=Anwesenheit'); } else { try { require("request")('http://192.168.178.46:50000/tasker=Abwesenheit').on("error", function () {console.error(e);}); } catch (e) { console.error(e); } console.log("request: " + 'http://192.168.178.46:50000/tasker=Abwesenheit'); } }); [/code][/spoiler]
      • Dutchman
        Poste das Script Mal bitte als Java Code (Knopf oben rechts) ich möchte gerne wissen wie der Code aussieht der generiert wird nicht die Blöcke 😉
        Send from mobile device
          Is das nicht das im Edit??
          Enrico
          • Dutchman
            @RappiRN:
            Enrico `
            Nope Lehrer Spoiler oder mein tapatalk v Spinnt
              Dann spinnt dein Tapatalk leider, is ja nicht das erste Mal, das es damit Probleme gibt, Da ist auf jeden Fall was drin! 😄
              Enrico
                Hier nochmal ohne Spoiler:
                    try {
                  } else {
                    try {
                Enrico
                • Dutchman
                  @RappiRN:
                  Enrico `
                  Grrr ja hab jetzt in Web geschaut und es ist da…
                  Ok meine Vermutung ist wieder legt, blockly erstellt einen "try" und "Catch Error" wie es sein soll also daran liegt es nicht.
                  Da muss dan jemand anders ran mit mehr Ahnung 😕
                  • AlCalzone
                    Da ist das Problem:
                    e ist hier nicht definiert.
                    Ist dein JS-Adapter aktuell? Ich dachte das Problem wäre bereits behoben.
                      Stefan1984 last edited by
                      @Dutchman:
                      @Stefan
                      Ich habe da eine Vermutung, nämlich das die url nicht erreichbar ist und dadurch die Instanz crasht.
                      In javascript könnte man das mit einen try/Catch abfangen.
                      Poste Mal bitte den Code der durch dieses blockly generiert wird `
                      Da ist er:
                      // Bewegung erkennen
                      on({id: 'hm-rpc.0.LEQ023XXXX.1.MOTION', change: "any"}, function (obj) {
                      // URL Befehl senden
                      try {
                      require("request")('http://192.168.178.29:50000/tasker=Einschalten').on("error", function () {console.error(e);});
                      Javascript Adapter läuft mit Version 3.5.1, ist also leider aktuell.
                      ****"e ist hier nicht definiert."**** Das passt also auch bei mir.
                      Jemand eine Idee, wie ich das umgehen kann?
                      Grüße,
                      Stefan
                      • Dutchman
                        Probier Mal eine Variable die e heißt im Script ein zu führen üppigen, der Fehler selber muss im Adapter gefixed werden, zur Erklärung:
                        Die Funktion try/Catch mit dem (e) tritt auf wenn irgendwas schief geht mir den http Befehl und sollte Dan einen Absturz des Adapters vermeiden ( try / cach = versuche und fange fehler ab wen einer auftritt) durch die fehlende definition sorgt er jetzt für einen Absturz
                          @Dutchman:
                          Probier Mal eine Variable die e heißt im Script ein zu führen üppigen, der Fehler selber muss im Adapter gefixed werden, `
                          Meinst Du so?
                          • Dutchman
                            Nope, nicht als object sondern Variable 😉
                              @Dutchman:
                              Nope, nicht als object sondern Variable 😉 `
                              So? Stehe wahrscheinlich auf dem Schlauch.
                              Hier noch der Code zur einfacheren Hilfe. 🙂
                              ! var e;
                              ! // Bewegung erkennen
                              ! on({id: 'hm-rpc.0.LEQ023XXXX.1.MOTION', change: "any"}, function (obj) {
                              ! var value = obj.state.val;
                              ! var oldValue = obj.oldState.val;
                              ! // URL Befehl senden
                              ! try {
                              ! require("request")('http://192.168.178.29:50000/tasker=Einschalten').on("error", function () {console.error(e);});
                              ! } catch (e) { console.error(e); }
                              ! e = 0;
                              ! 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
                              Danke.
                              • Dutchman
                                Genau! Hänge Aber bitte noch war das dran zB Textblock mit irgendwas drin das sollte dann erstmal Abhilfe schaffen
                                • Bluefox
                                  Bluefox last edited by
                                  @Stefan1984:
                                  @Dutchman:
                                  @Stefan
                                  Da ist er:
                                  try {
                                  Grüße,
                                  Stefan `
                                  Also 3.5.1 hat den fix. Man muss nur dieses Skript noch mal von Blockly generieren lassen.
                                  An dem Skrip was klein ändern und speichern. Dann soll es gehen.
                                    Dann hab ich es jetzt. :lol:
                                    Dankeschön. Werde testen.
                                    Grüße,
                                    Stefan
                                    • Bluefox
                                      Vielleicht bevor dann````
                                      iobroker u javascirpt
                                        @Bluefox:
                                        An dem Skrip was klein ändern und speichern. Dann soll es gehen. `
                                        Was kleines ändern und speichern? Probiere ich auch gern aus.
                                        Wahrscheinlich hilft auch eine Neuanlage des Skripts?
                                        Grüße,
                                        Stefan
                                        • Dutchman
                                          hat sich das problem jetzt damit erledigt Stefan ?
                                            Bis jetzt ist es nicht wieder aufgetreten, habe das Problem aber noch nichts of gelöst gesetzt, da es sonst auch nur sporadisch auftrat. Ich möchte gern noch 1-2 Tage testen.
                                            Ich habe im ersten Step das aktive Skript geändert, damit die Änderungen der neuen Version übernommen werden. Die von Dir empfohlene Variante ab ich als Duplikat gespeichert und setze es aktiv, wenn die erste Variante nicht funktioniert.
                                            Grüße,
                                            Stefan
                                            3230
