    4. npm Error bei mihome-vacuum Adapter Installation
      Redbeard_81 @Guest last edited by
      @ilovegym
      ein "iob fix" habe ich durchgeführt aber ohne erfolg.
      Die Ausgabe vom "iob diag" ergibt folgendes:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi-4-2
             Icon name: computer
                Kernel: Linux 6.6.22-v8+
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       11:19:24 up 12 min,  2 users,  load average: 0.33, 0.30, 0.17
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-04-06 11:19:24 CEST
                 Universal time: Sat 2024-04-06 09:19:24 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.2G        497M        7.5G        1.2M        333M        7.7G
      Swap:           104M          0B        104M
      Total:          8.3G        497M        7.6G
               7808 M total memory
                474 M used memory
                518 M active memory
                 77 M inactive memory
               7125 M free memory
                 28 M buffer memory
                289 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     781M  1.2M  780M   1% /run
      /dev/sda2      ext4      117G  2.9G  109G   3% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/sda1      vfat      510M   63M  448M  13% /boot/firmware
      tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
      [Sat Apr  6 11:07:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:A5:E3:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=12eef1ae-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Apr  6 11:07:17 2024] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
      [Sat Apr  6 11:07:19 2024] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      541M    /var/
      207M    /var/cache
      201M    /var/cache/apt
      169M    /var/lib
      140M    /var/lib/apt/lists
      Archived and active journals take up 64.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      19M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.5M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.1
      /usr/bin/node           v18.20.1
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.1-1nodesource1
        Candidate: 18.20.1-1nodesource1
        Version table:
       *** 18.20.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi-4-2                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi-4-2                          -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi-4-2                          -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Objects and States
      Objects:        143
      States:         103
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7327       701/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5564       668/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5557       668/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5663       743/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7329       701/sshd: /usr/sbin
      udp        0      0 0.0.0.0:52312           0.0.0.0:*                           104        5386       541/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5384       541/avahi-daemon: r
      udp6       0      0 fe80::9d36:65c3:850:546 :::*                                0          4797       602/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        5385       541/avahi-daemon: r
      udp6       0      0 :::50605                :::*                                104        5387       541/avahi-daemon: r
      2024-04-06 11:07:09.145  - info: host.raspberrypi-4-2 Delete state "system.host.raspberrypi-4-2.versions.nodeNewest"
      2024-04-06 11:07:09.163  - info: host.raspberrypi-4-2 instance system.adapter.admin.0 started with pid 743
      2024-04-06 11:07:09.195  - info: host.raspberrypi-4-2 Delete state "system.host.raspberrypi-4-2.versions.nodeNewestNext"
      2024-04-06 11:07:09.203  - info: host.raspberrypi-4-2 Delete state "system.host.raspberrypi-4-2.versions.npmCurrent"
      2024-04-06 11:07:09.211  - info: host.raspberrypi-4-2 Delete state "system.host.raspberrypi-4-2.versions.npmNewest"
      2024-04-06 11:07:09.218  - info: host.raspberrypi-4-2 Delete state "system.host.raspberrypi-4-2.versions.npmNewestNext"
      2024-04-06 11:07:09.225  - info: host.raspberrypi-4-2 Some obsolete host states deleted.
      2024-04-06 11:07:11.857  - info: admin.0 (743) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.1, js-controller: 5.0.19
      2024-04-06 11:07:11.910  - info: admin.0 (743) requesting all objects
      2024-04-06 11:07:12.355  - info: admin.0 (743) received all objects
      2024-04-06 11:07:12.811  - info: admin.0 (743) socket.io server listening on port 8081
      2024-04-06 11:07:12.817  - info: admin.0 (743) http server listening on port 8081
      2024-04-06 11:07:12.818  - info: admin.0 (743) Use link "http://127.0.0.1:8081" to configure.
      2024-04-06 11:07:13.104  - info: host.raspberrypi-4-2 instance system.adapter.backitup.0 started with pid 819
      2024-04-06 11:07:15.324  - info: backitup.0 (819) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.1, js-controller: 5.0.19
      2024-04-06 11:07:15.390  - info: backitup.0 (819) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2024-04-06 11:07:17.096  - info: host.raspberrypi-4-2 instance system.adapter.discovery.0 started with pid 838
      2024-04-06 11:07:18.897  - info: discovery.0 (838) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.1, js-controller: 5.0.19
      2024-04-06 11:15:14.954  - info: admin.0 (743) ==> Connected system.user.admin from ::ffff:192.168.178.24
      2024-04-06 11:15:23.956  - info: host.raspberrypi-4-2 iobroker add mihome-vacuum --host raspberrypi-4-2
      2024-04-06 11:15:26.901  - info: host.raspberrypi-4-2 iobroker NPM version: 10.5.0
      2024-04-06 11:15:26.904  - info: host.raspberrypi-4-2 iobroker Installing iobroker.mihome-vacuum@4.1.1... (System call)
      2024-04-06 11:15:33.044  - error: host.raspberrypi-4-2 iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-06T09_15_27_623Z-debug-0.log
      2024-04-06 11:15:33.045  - error: host.raspberrypi-4-2 iobroker host.raspberrypi-4-2 Cannot install iobroker.mihome-vacuum@4.1.1: 127
      2024-04-06 11:15:34.120  - info: host.raspberrypi-4-2 iobroker exit 25
        Thomas Braun Most Active @Redbeard_81 last edited by
        @redbeard_81
        Hast du jetzt die Beta des Adapters eingespielt?
          Redbeard_81 @Thomas Braun last edited by
          nein noch nicht, muss noch gucken wie das geht. Habe noch nie eine BETA installiert.
            @redbeard_81
              Danke, habe ich installiert.
              Die Installation konnte durchgeführt werden, die Verfügbare Version ist 4.1.1 und Installiert ist 4.2.0.
              Unter den Objekten wird mir auch ein Ordner angezeigt, nur unter den Instanzen wird dieser nicht aufgeführt.
              Daraufhin habe ich den Adapter über den normalen Weg installiert und siehe da es funktioniert.
              Kann das eventuell was mit den 64-bit zu tun haben? Denn auf einem anderen Raspberrypi 4 läuft ein 32-bit System und dort funktioniert der Adapter normal.
                @redbeard_81 sagte in npm Error bei mihome-vacuum Adapter Installation:
                Ich kann dir mit der schwammigen Beschreibung nicht folgen.
                iob update
                iob upgrade
                sagt?
                  @thomas-braun said in npm Error bei mihome-vacuum Adapter Installation:
                  iob update
                  iob upgrade
                  sagt?
                  Sorry, damit kann ich jetzt nichts Anfangen, wo stand das?
                    @redbeard_81
                    Das sollst du in dein Terminal hacken. Ausgabe dann wieder hier rein, in CodeeTags eingebettet.
                      Der mihome-vacuum Adapter wird nicht angezeigt
                      "iob update"
                      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                      Adapter    "discovery"    : 4.4.0    , installed 3.0.3  [Updatable]
                      Adapter    "ems-esp"      : 3.0.3    , installed 2.8.0  [Updatable]
                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                      Adapter    "node-red"     : 5.2.0    , installed 5.1.0  [Updatable]
                      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                      Adapter    "shelly"       : 6.8.0    , installed 6.6.1  [Updatable]
                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                      Adapter    "socketio"     : 6.6.1    , installed 4.2.0  [Updatable]
                      Adapter    "tado"         : 0.5.3    , installed 0.5.3
                      Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
                      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                      Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
                      Adapter    "ws"           : 2.5.11   , installed 1.3.0  [Updatable]
                      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                      "iob upgrade"
                      This upgrade of "ws" will at least introduce the following changes:
                      -> 2.5.11:
                      Some packages were updated
                      -> 2.5.10:
                      updated ws-server to increase file limit to 500 MB
                      -> 2.5.9:
                      Corrected the crash if authentication is enabled
                      -> 2.5.8:
                      Corrected adapter termination if the alias has no target
                      -> 2.5.7:
                      upgraded socket-classes to fix vis problems
                      -> 2.5.6:
                      upgraded socket-classes to correct the error by unsubscribing on client disconnect
                      -> 2.5.5:
                      upgraded socket-classes to fix crash cases
                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                      Would you like to upgrade ws from @1.3.0 to @2.5.11 now? [(y)es, (n)o]: Y
                      Update ws from @1.3.0 to @2.5.11
                      NPM version: 10.5.0
                      Installing iobroker.ws@2.5.11... (System call)
                      added 2 packages, removed 3 packages, and changed 1 package in 9s
                      134 packages are looking for funding
                        run `npm fund` for details
                      upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                      upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
                      This upgrade of "web" will at least introduce the following changes:
                      -> 6.2.3:
                      update websocket library to increase maximum file size from 100 MB to 500 MB
                      -> 6.2.2:
                      -> 6.2.1:
                      Added the user access list option
                      -> 6.1.10:
                      Corrected the start screen
                      -> 6.1.7:
                      Added the public accessibility check
                      -> 6.1.6:
                      Corrected socket.io connection
                      -> 6.1.4:
                      upgrade socketio and ws dependencies to fix vis subscribe problem
                      Would you like to upgrade web from @4.3.0 to @6.2.3 now? [(y)es, (n)o]: ^Y
                      No upgrade of "web" desired.
                      This upgrade of "tankerkoenig" will at least introduce the following changes:
                      -> 3.3.7:
                      added difference to jsonTable #116
                      added a log message for the error `parameter error`
                      set the name length to 34 characters
                      Added verification if the api key is encrypted
                      updated the Dependencies
                      -> 3.3.6:
                      corrected the position of the warning message in the user interface
                      Updated documentation and migration guide for stable version 3.3.6
                      -> 3.3.5:
                      fixed copy/paste bug in the UI
                      -> 3.3.4:
                      Fixed an issue where a zip code starting with 0 was displayed incorrectly [Issue #113].
                      -> 3.3.3:
                      fixed => adapter does not fetch data after a `requestData error` e.g. internet crash.
                      added adapter migration guide from 3.1.x to 3.3.x or 3.2.x to 3.3.x
                      Problem fixed [Problem #111]
                      -> 3.3.2:
                      Fixed TypeError: Cannot read property 'length' of undefined in addDiscount if value is `boolean / undefined`.
                      Fixed error: DB closed when adapter is stopped
                      Object creation optimized
                      changed query interval default value to 10 minutes and minimum value to 10 minutes
                      added check if station ID is already configured (in edit mode)
                      Added price difference to last price
                      added feature request cheapest station display [Issue #109]
                      -> 3.3.1:
                      Fixed TypeError: Cannot read properties of undefined Issue #104
                      added complete street datapoint for each station
                      Would you like to upgrade tankerkoenig from @2.1.1 to @3.3.7 now? [(y)es, (n)o]: Y
                      Update tankerkoenig from @2.1.1 to @3.3.7
                      host.raspberrypi-4-2 Adapter "system.adapter.tankerkoenig.0" is stopped.
                      NPM version: 10.5.0
                      Installing iobroker.tankerkoenig@3.3.7... (System call)
                      removed 1 package, and changed 1 package in 8s
                      Update "system.adapter.tankerkoenig.0"
                      upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
                      upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
                      upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                      upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
                      upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                      host.raspberrypi-4-2 Adapter "system.adapter.tankerkoenig.0" is started
                      This upgrade of "socketio" will at least introduce the following changes:
                      -> 6.6.1:
                      Just some packages were updated
                      -> 6.6.0:
                      -> 6.5.7:
                      upgrade socket-classes to fix error with vis subscriptions
                      -> 6.5.6:
                      -> 6.5.5:
                      upgrade socket-classes to fix crash cases
                      -> 6.5.4:
                      -> 6.5.3:
                      added missing node16 requirement
                      Would you like to upgrade socketio from @4.2.0 to @6.6.1 now? [(y)es, (n)o]: Y
                      Update socketio from @4.2.0 to @6.6.1
                      ,NPM version: 10.5.0
                      Installing iobroker.socketio@6.6.1... (System call)
                      added 25 packages, removed 3 packages, and changed 1 package in 10s
                      upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                      upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                      This upgrade of "shelly" will introduce the following changes:
                      -> 6.8.0:
                      Updated BLE script to 0.2 (new shelly motion firmware)
                      Updated Shelly i3 number limits
                      Added screenshots to instance configuration
                      -> 6.7.0:
                      Updated handling of ble payloads
                      Added Shelly Wall Display
                      Would you like to upgrade shelly from @6.6.1 to @6.8.0 now? [(y)es, (n)o]: Y
                      Update shelly from @6.6.1 to @6.8.0
                      NPM version: 10.5.0
                      Installing iobroker.shelly@6.8.0... (System call)
                      Update "system.adapter.shelly.0"
                      Update "system.adapter.shelly.1"
                      upload [17] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [16] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [15] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [14] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen1.png img/mqttGen1.png image/png
                      upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen2.png img/mqttGen2.png image/png
                      upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen1.png img/restrictedLoginGen1.png image/png
                      upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen2.png img/restrictedLoginGen2.png image/png
                      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                      This upgrade of "node-red" will introduce the following changes:
                      -> 5.2.0:
                      Added persistence of context data (filesystem)
                      Would you like to upgrade node-red from @5.1.0 to @5.2.0 now? [(y)es, (n)o]: Y
                      Update node-red from @5.1.0 to @5.2.0
                      host.raspberrypi-4-2 Adapter "system.adapter.node-red.0" is stopped.
                      NPM version: 10.5.0
                      Installing iobroker.node-red@5.2.0... (System call)
                      Update "system.adapter.node-red.0"
                      upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/jsonConfig.json jsonConfig.json application/json
                      upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
                      upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
                      host.raspberrypi-4-2 Adapter "system.adapter.node-red.0" is started
                      This upgrade of "ems-esp" will at least introduce the following changes:
                      -> 3.0.3:
                      improve km200 data read to avoid errors
                      -> 3.0.2:
                      improve km200 data read to avoid errors - try http get up to 3 times now - especially for recordings
                      -> 3.0.1:
                      change KM200 error messages for recordings
                      -> 3.0.0:
                      Node >= 18 required
                      update heatdemand weight changes to be effective during active instance
                      ems-esp gateway: Raw telegram search for EMS+ thermostats: switchPrograms and holidayModes (RC310/RC300)
                      create writable objects / states for switchPrograms and holidayModes
                      this function is only active when no km200 gateway is selected - ems-esp gateway only
                      improve error messages for km200 (wrong ip / passwords)
                      small changes within PDF adapter documentation
                      -> 3.0.0-alpha.2:
                      Node >= 18 required
                      -> 3.0.0-alpha.1:
                      -> 3.0.0-alpha.0:
                      Search for ems-esp states for EMS+ thermostats: switchTimes and holidayModes (RC310/RC300)
                      Implement raw telegram search for EMS+ entities and create writable objects / states
                      The search is only active when no km200 gateway is selected
                      Would you like to upgrade ems-esp from @2.8.0 to @3.0.3 now? [(y)es, (n)o]: Y
                      Update ems-esp from @2.8.0 to @3.0.3
                      NPM version: 10.5.0
                      Installing iobroker.ems-esp@3.0.3... (System call)
                      Update "system.adapter.ems-esp.0"
                      upload [6] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/admin.d.ts admin.d.ts video/mp2t
                      upload [5] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/ems-esp.png ems-esp.png image/png
                      upload [4] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/index_m.html index_m.html text/html
                      upload [3] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/index_m.js index_m.js application/javascript
                      upload [2] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/km200.png km200.png image/png
                      upload [1] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/style.css style.css text/css
                      upload [0] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/words.js words.js application/javascript
                      This upgrade of "discovery" will at least introduce the following changes:
                      -> 4.4.0:
                      Added WLED
                      Added LaMetric
                      Removed net-tools from proposals
                      -> 4.3.0:
                      Replaced vis with vis-2
                      -> 4.2.0:
                      Changed detection of myvbus and resol
                      -> 4.1.0:
                      Added detection of myvbus and resol
                      -> 4.0.0:
                      Added: frontier_silicon, sma-em, and speedwire
                      Dropped node14 support, refactoring
                      -> 3.2.0:
                      Added iControl to the suggested adapters
                      -> 3.1.0:
                      Corrected syntax error in the german translation
                      Would you like to upgrade discovery from @3.0.3 to @4.4.0 now? [(y)es, (n)o]: Y
                      Update discovery from @3.0.3 to @4.4.0
                      NPM version: 10.5.0
                      Installing iobroker.discovery@4.4.0... (System call)
                      added 1 package, removed 16 packages, and changed 1 package in 8s
                      122 packages are looking for funding
                      Update "system.adapter.discovery.0"
                      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                        @redbeard_81
                        Wo ist denn der mihome-vacuum nun hin?
                          Der mihome-vacuum Adapter ist jetzt auch drin.
                          Habe jetzt mein Backup eingespielt den Adapter als Beta installiert und nun scheint alles zu funktionieren.
                          Danke für die Hilfe und geduld
                          Adapter    "ems-esp"      : 3.0.3    , installed 3.0.3
                          Adapter    "mihome-vacuum": 4.1.1    , installed 4.2.0
                          Adapter    "node-red"     : 5.2.0    , installed 5.2.0
                          Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                          Adapter    "ws"           : 2.5.11   , installed 2.5.11
                          Thomas Braun S 2 Replies Last reply Reply Quote 0
                            Heb das auch hoch.
                              Siggi0904 @Redbeard_81 last edited by
                              @redbeard_81 ja, das gleiche Problem hatte ich Anfang dieser Woche auch.
                              Schön zu sehen, dass dir erstens schnell geholfen wurde, zweitens ich nicht allein betroffen bin.
                              • Wintermute
                                Wintermute last edited by Wintermute
                                Ich habe gerade das Update auf die 4.2.0 und habe das Problem, dass die Installation offenbar sauber durchläuft, der Adapter aber nicht mehr startet ("Verbunden mit Gerät oder Dienst" ist grün, der Rest rot)
                                iob update und iob upgrade hab ich probiert, keine Resultate:
                                C:\ioBroker>iob update
                                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                Adapter    "deconz"       : 1.4.0    , installed 1.4.0
                                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                Adapter    "email"        : 1.2.2    , installed 1.2.2
                                Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                                Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                                Adapter    "ical"         : 1.14.3   , installed 1.14.3
                                Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
                                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                                Adapter    "vis"          : 1.5.4    , installed 1.5.1  [Updatable]
                                Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                C:\ioBroker>iob upgrade
                                This upgrade of "vis" will introduce the following changes:
                                -> 1.5.4:
                                added the new binding operation for getting property of JSON or object
                                Checked the initialization of the `local_` variables
                                fixed subscribeOidAtRuntime
                                Added dynamic web manifest
                                Optimization for basic-view in widget8
                                Changed binding regex to accept umlauts
                                Corrected first installation of vis
                                Would you like to upgrade vis from @1.5.1 to @1.5.4 now? [(y)es, (n)o]: n
                                No upgrade of "vis" desired.
                                Vis habe ich aus Gründen nicht aktualisiert, weil ansonsten einige ältere Tablets nicht mehr klarkommen.
                                Ein "Iob fix" bringt:
                                Need to install the following packages:
                                  @iobroker/fix@5.0.0
                                Ok to proceed? (y) y
                                "(" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
                                npm notice
                                npm notice New major version of npm available! 9.5.0 -> 10.5.2
                                npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.2
                                npm notice Run npm install -g npm@10.5.2 to update!
                                npm notice
                                Hat das Eine mit dem Anderen zu tun?
                                Wintermute ? 2 Replies Last reply Reply Quote 0
                                • Wintermute
                                  Wintermute @Wintermute last edited by
                                  @wintermute sagte in npm Error bei mihome-vacuum Adapter Installation:
                                  -> 1.5.4:
                                    @iobroker/fix@5.0.0
                                  npm notice
                                  npm notice
                                  Zusätzlich noch "iob info":
                                  C:\ioBroker>iob info
                                  Cannot get disk information: Command failed: df -k /
                                  Der Befehl "df" ist entweder falsch geschrieben oder
                                  konnte nicht gefunden werden.
                                  Platform       : Windows
                                  os             : win64
                                  Architecture   : x64
                                  CPUs           : 2
                                  Model          : Intel(R) Xeon(R) CPU 8460Y+ @ 2.0 GHz
                                  RAM            : 126 GB
                                  System uptime  : 2d. 20:25:52
                                  Node.js        : v18.15.0
                                  time           : 1713536349613
                                  timeOffset     : -120
                                  NPM            : 9.5.0
                                  adapters count : 538
                                    pusemuckel last edited by pusemuckel
                                    ich habe das gleiche Problem seit dem Update auf die neue Version
                                    host.iobroker
                                    	2024-04-19 16:31:31.427	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.iobroker
                                    	2024-04-19 16:31:31.426	error	Caught by controller[1]: Node.js v20.12.2
                                    host.iobroker
                                    	2024-04-19 16:31:31.426	error	Caught by controller[0]: }
                                    host.iobroker
                                    	2024-04-19 16:31:31.425	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
                                    host.iobroker
                                    	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
                                    host.iobroker
                                    	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
                                    host.iobroker
                                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                    host.iobroker
                                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                                    host.iobroker
                                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
                                    host.iobroker
                                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
                                    host.iobroker
                                    	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
                                    host.iobroker
                                    	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
                                    host.iobroker
                                    	2024-04-19 16:31:31.418	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
                                    host.iobroker
                                    	2024-04-19 16:31:31.418	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
                                    host.iobroker
                                    	2024-04-19 16:31:31.418	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
                                    host.iobroker
                                    	2024-04-19 16:31:31.417	error	Caught by controller[0]: ^
                                    host.iobroker
                                    	2024-04-19 16:31:31.417	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
                                    host.iobroker
                                    	2024-04-19 16:31:31.416	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
                                    Hat jemand eine Idee wo man schauen muss um das zu korrigieren ?
                                    Danke!
                                      A Former User @Wintermute last edited by
                                      @wintermute
                                      bei Windows bin ich raus..
                                      Wintermute 1 Reply Last reply Reply Quote 0
                                        A Former User @pusemuckel last edited by
                                        @pusemuckel
                                        ist nicht der gleiche Fehler, wie der TE hat, aber irgendein script scheint filename falsch deklariert zu haben.. sofern ich den Fehler richtig verstehe.. ist ja nur n Auschschnitt vom Ende des Fehlers.. man muesste da halt mal wissen:
                                        welches System?
                                        welche Version?
                                        Logfile von Begin an, wenn der Adapter startet...
                                        Dann natuerlich noch die Grundsaetzlichen infos aus iob diag.
                                          pusemuckel @Guest last edited by
                                          @ilovegym
                                          Danke für Deine Rückmeldung!
                                          			v.2023-10-10
                                          model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          Docker          : v9.1.2
                                          Installation: 		Docker
                                          Kernel: 		x86_64
                                          Userland: 		amd64
                                          Timezone: 		Etc/UTC
                                          User-ID: 		0
                                          X-Server: 		false
                                          Pending OS-Updates: 	0
                                          Pending iob updates: 	0
                                          Nodejs-Installation: 	/usr/bin/nodejs 	v20.12.2
                                          			/usr/bin/node 		v20.12.2
                                          			/usr/bin/npm 		10.5.0
                                          			/usr/bin/npx 		10.5.0
                                          Recommended versions are nodejs 18.20.2 and npm 10.5.0
                                          MEMORY:
                                          Mem:             12G        6.7G        822M        188M        5.4G        5.7G
                                          Swap:           9.6G         60M        9.5G
                                          Total:           21G        6.8G         10G
                                          Active iob-Instances: 	26
                                          ioBroker Core: 		js-controller 		5.0.19
                                          			admin 			6.13.16
                                          ioBroker Status: 	iobroker is running on this host.
                                          Objects type: jsonl
                                          States  type: redis
                                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          Objects: 		15173
                                          States: 		11749
                                          Size of iob-Database:
                                          16M	/opt/iobroker/iobroker-data/objects.jsonl
                                          13M	/opt/iobroker/iobroker-data/objects.json.migrated
                                          13M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          3.5M	/opt/iobroker/iobroker-data/states.json.bak
                                          Adapter Log:
                                          host.iobroker
                                          	2024-04-19 17:08:23.959	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                          host.iobroker
                                          	2024-04-19 17:08:23.959	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          host.iobroker
                                          	2024-04-19 17:08:23.959	error	Caught by controller[0]: Node.js v20.12.2
                                          host.iobroker
                                          	2024-04-19 17:08:23.959	error	Caught by controller[0]: }
                                          host.iobroker
                                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
                                          host.iobroker
                                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
                                          host.iobroker
                                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
                                          host.iobroker
                                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                          host.iobroker
                                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                                          host.iobroker
                                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
                                          host.iobroker
                                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
                                          host.iobroker
                                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
                                          host.iobroker
                                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
                                          host.iobroker
                                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
                                          host.iobroker
                                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
                                          host.iobroker
                                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
                                          host.iobroker
                                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: ^
                                          host.iobroker
                                          	2024-04-19 17:08:23.955	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
                                          host.iobroker
                                          	2024-04-19 17:08:23.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
                                          host.iobroker
                                          	2024-04-19 17:08:23.723	info	instance system.adapter.mihome-vacuum.0 started with pid 5691
                                          Mehr log habe ich bzw. wo kann ich mehr log des Adapters finden ?
                                          ? mcm1957 2 Replies Last reply Reply Quote 0
                                            A Former User @pusemuckel last edited by A Former User
                                            @pusemuckel
                                            mach mal in der Konsole des iobroker dockers ein "iob upload mihome-vacuum" und starte dann den Adapter nochmal.
                                            In die Konsole des Dockers kommst du im Terminal des Hosts (Synology? Proxmox? ) mit dem command
                                            sudo docker exec -tiu username containername /bin/bash
                                            bei mir ist das als user iobroker und der container heisst auch iobroker dann ein
                                            sudo docker exec -tiu iobroker iobroker /bin/bash
                                            danach bist du in /opt/iobroker und kannst als user iobroker die iob commands ausfuehren, ausser diejenigen, die ein iob maintenance brauchen..
                                            Ich gehe davon aus, dass du das buanet-docker-Image benutzt?
                                            edit:
                                            das Logfile bekommt man am schoensten, finde ich, in der Konsole mit dem command
                                            iob logs --watch
                                            1515
