    4. [gelöst] Nach Neuinstallation Fehler im Zigbee Adapter
    • Klarie
      Klarie last edited by Klarie
      @thomas-braun sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
      Danke für Deine schnelle Antwort.
      Steck den Stick mal um/aus-ein.
      ls -la /dev/serial/by-id/
      sagt?
      klaus@raspi4iobroker:~ $ ls -la /dev/serial/by-id/
      -bash: ls: command not found
      Befehl falsch? 🙄
      [Edit] - Hat nach Neustart funktioniert
      • Klarie
        Klarie @Thomas Braun last edited by
        Nach einem Neustart klappt es
        USB2, oben
        total 0
        drwxr-xr-x 2 root root 60 Mar 26 02:12 .
        drwxr-xr-x 4 root root 80 Mar 26 02:12 ..
        lrwxrwxrwx 1 root root 13 Mar 26 02:12 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CD41868-if00 -> ../../ttyACM0
        USB2, unten
        total 0
        drwxr-xr-x 2 root root 60 Mar 26 02:15 .
        drwxr-xr-x 4 root root 80 Mar 26 02:15 ..
        lrwxrwxrwx 1 root root 13 Mar 26 02:15 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CD41868-if00 -> ../../ttyACM0
        USB3, unten
        total 0
        drwxr-xr-x 2 root root 60 Mar 26 02:17 .
        drwxr-xr-x 4 root root 80 Mar 26 02:17 ..
        lrwxrwxrwx 1 root root 13 Mar 26 02:17 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CD41868-if00 -> ../../ttyACM0
        ohne Stick
        ls: cannot access '/dev/serial/by-id/': No such file or directory
        Am oberen USB3 Port ist eine SSD angeschlossen.
        Klarie arteck 2 Replies Last reply Reply Quote 0
        • Klarie
          Klarie @Klarie last edited by
          ...und hier die komplette System-Info aus
          iob diag
          Linux raspi4iobroker 6.6.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.20-1+rpt1 (2024-03-07) aarch64
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Wed Mar 27 01:11:23 2024 from 192.168.178.24
          *** ioBroker Diagnosis ***
          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
          https://forum.iobroker.net
          Just copy and paste the Summary Page, including the ``` characters at start and end.
          It helps us to help you!
          Press any key to continue
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspi4iobroker
                 Icon name: computer
                    Kernel: Linux 6.6.20+rpt-rpi-v8
              Architecture: arm64
          Model		: Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           01:16:54 up  3:33,  2 users,  load average: 0.64, 1.06, 1.13
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          *** Time and Time Zones ***
                         Local time: Wed 2024-03-27 01:16:55 CET
                     Universal time: Wed 2024-03-27 00:16:55 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          klaus
          /home/klaus
          klaus adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	multi-user.target
          *** MEMORY ***
          Mem:            4.0G        1.7G        1.6G        1.2M        741M        2.2G
          Swap:           104M          0B        104M
          Total:          4.1G        1.7G        1.7G
                   3791 M total memory
                   1655 M used memory
                   1645 M active memory
                    497 M inactive memory
                   1505 M free memory
                     99 M buffer memory
                    607 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.2M  378M   1% /run
          /dev/sda2      ext4      117G  4.1G  107G   4% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          /dev/sda1      vfat      510M   63M  448M  13% /boot/firmware
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Tue Mar 26 21:43:06 2024] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,noatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          562M	/var/
          203M	/var/cache
          197M	/var/cache/apt
          161M	/var/lib
          133M	/var/lib/apt/lists
          Archived and active journals take up 96.0M in the file system.
          /opt/iobroker/backups:
          6.5M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          250M	/opt/iobroker/iobroker-data/
          198M	/opt/iobroker/iobroker-data/files
          57M	/opt/iobroker/iobroker-data/files/javascript.admin
          43M	/opt/iobroker/iobroker-data/files/iot.admin
          42M	/opt/iobroker/iobroker-data/files/iot.admin/static/js
          33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          23M	/opt/iobroker/iobroker-data/objects.jsonl
          22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          13M	/opt/iobroker/iobroker-data/states.jsonl
          8.5M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CD41868-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.19.1
          /usr/bin/node 		v18.19.1
          /usr/bin/npm 		10.2.4
          /usr/bin/npx 		10.2.4
          /usr/bin/corepack 	0.22.0
          nodejs:
            Installed: 18.19.1-1nodesource1
            Candidate: 18.20.0-1nodesource1
            Version table:
               18.20.0-1nodesource1 1001
           *** 18.19.1-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.19.0+dfsg-6~deb12u1 500
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	5.0.19
          admin: 		6.13.16
          javascript: 	7.8.0
          Adapters from github: 	1
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspi4iobroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspi4iobroker                           -  enabled
          + system.adapter.backitup.0               : backitup              : raspi4iobroker                           -  enabled
          + system.adapter.discovery.0              : discovery             : raspi4iobroker                           -  enabled
          + system.adapter.email.0                  : email                 : raspi4iobroker                           -  enabled
            system.adapter.flot.0                   : flot                  : raspi4iobroker                           - disabled
          + system.adapter.harmony.0                : harmony               : raspi4iobroker                           -  enabled
          + system.adapter.history.0                : history               : raspi4iobroker                           -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspi4iobroker                           - disabled
            system.adapter.info.0                   : info                  : raspi4iobroker                           - disabled
          + system.adapter.iot.1                    : iot                   : raspi4iobroker                           -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspi4iobroker                           -  enabled
          + system.adapter.javascript.0             : javascript            : raspi4iobroker                           -  enabled
          + system.adapter.net-tools.0              : net-tools             : raspi4iobroker                           -  enabled
            system.adapter.openweathermap.0         : openweathermap        : raspi4iobroker                           -  enabled
          + system.adapter.operating-hours.0        : operating-hours       : raspi4iobroker                           -  enabled
          + system.adapter.ping.0                   : ping                  : raspi4iobroker                           -  enabled
          + system.adapter.pushover.0               : pushover              : raspi4iobroker                           -  enabled
            system.adapter.radar2.0                 : radar2                : raspi4iobroker                           - disabled
            system.adapter.rpi2.0                   : rpi2                  : raspi4iobroker                           - disabled
          + system.adapter.shelly.0                 : shelly                : raspi4iobroker                           -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspi4iobroker                           -  enabled
          + system.adapter.statistics.0             : statistics            : raspi4iobroker                           -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspi4iobroker                           -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspi4iobroker                           -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi4iobroker                           - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspi4iobroker                           - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspi4iobroker                           -  enabled
            system.adapter.vis.0                    : vis                   : raspi4iobroker                           -  enabled
          + system.adapter.web.0                    : web                   : raspi4iobroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi4iobroker                           -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspi4iobroker                           -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Active repo(s): Stable (default)
          Installed ioBroker-Instances
          Used repository: Stable (default)
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "harmony"      : 1.3.0    , installed 1.3.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Adapter    "net-tools"    : 1.0.6    , installed 1.0.6
          Adapter    "openweathermap": 1.0.4   , installed 1.0.4
          Adapter    "operating-hours": 1.0.6  , installed 1.0.6
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "radar2"       : 2.1.0    , installed 2.1.0
          Adapter    "shelly"       : 6.8.0    , installed 6.8.0
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Objects and States
          Objects: 	11816
          States: 	10069
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 1
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       43346      4252/io.shelly.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42166      4031/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       39754      4031/iobroker.js-co
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          562        687/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       44376      4385/io.jarvis.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       43648      4496/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41258      4050/io.admin.0
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       41641      4331/io.harmony.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          564        687/sshd: /usr/sbin
          udp        0      0 0.0.0.0:57773           0.0.0.0:*                           104        6324       531/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       42489      4282/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       42490      4282/io.tuya.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       41642      4331/io.harmony.0
          udp        0      0 192.168.178.50:5353     0.0.0.0:*                           1001       44173      4269/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6322       531/avahi-daemon: r
          udp6       0      0 fe80::d7cd:e0da:ee2:546 :::*                                0          612        588/NetworkManager
          udp6       0      0 :::56216                :::*                                104        6325       531/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        6323       531/avahi-daemon: r
          2024-03-27 00:00:00.545  - info: sourceanalytix.0 (4437) Current value of state : {"val":10,"ack":true,"ts":1711407600705,"q":0,"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","lc":1695841908883}
          2024-03-27 00:00:00.596  - info: sourceanalytix.0 (4437) Reset start values for : zigbee.0.b4e3f9fffe19ec83.load_power
          2024-03-27 00:00:00.596  - info: sourceanalytix.0 (4437) Memory values before reset : {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"zigbee__0__b4e3f9fffe19ec83__load_power","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Load power","stateType":"ElectricityDay","stateUnit":"W","useUnit":"kWh"},"calcValues":{"cumulativeValue":58.41205343694452,"start_day":58.41205343694452,"start_month":52.299631099444476,"start_quarter":39.54854906805555,"start_week":58.161048594722295,"start_year":35.311280301111104,"valueAtDeviceReset":null,"valueAtDeviceInit":null,"previousReadingWatt":0,"previousReadingWattTs":1711407600821},"prices":{"basicPrice":"8,25","unitPrice":"0.3510"}}
          2024-03-27 00:00:00.657  - info: sourceanalytix.0 (4437) Memory values after reset : {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"zigbee__0__b4e3f9fffe19ec83__load_power","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Load power","stateType":"ElectricityDay","stateUnit":"W","useUnit":"kWh"},"calcValues":{"start_day":58.41205343694452,"start_month":52.299631099444476,"start_quarter":39.54854906805555,"start_week":58.161048594722295,"start_year":35.311280301111104,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":58.41205343694452},"prices":{"basicPrice":"8,25","unitPrice":"0.3510"}}
          2024-03-27 00:00:00.657  - info: sourceanalytix.0 (4437) Current value of state : {"val":0,"ack":true,"ts":1711407600821,"q":0,"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","lc":1695689209492}
          2024-03-27 00:00:00.672  - info: sourceanalytix.0 (4437) Reset start values for : zigbee.0.b4e3f9fffe19ec94.load_power
          2024-03-27 00:00:00.673  - info: sourceanalytix.0 (4437) Memory values before reset : {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"zigbee__0__b4e3f9fffe19ec94__load_power","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Load power","stateType":"ElectricityDay","stateUnit":"W","useUnit":"kWh"},"calcValues":{"cumulativeValue":10.853776449166693,"start_day":10.853776449166693,"start_month":9.876937217500014,"start_quarter":9.296843275833346,"start_week":10.716346880555577,"start_year":8.130855415000001,"valueAtDeviceReset":null,"valueAtDeviceInit":null,"previousReadingWatt":0,"previousReadingWattTs":1711407600913},"prices":{"basicPrice":"8,25","unitPrice":"0.3510"}}
          2024-03-27 00:00:00.724  - info: sourceanalytix.0 (4437) Memory values after reset : {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"zigbee__0__b4e3f9fffe19ec94__load_power","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Load power","stateType":"ElectricityDay","stateUnit":"W","useUnit":"kWh"},"calcValues":{"start_day":10.853776449166693,"start_month":9.876937217500014,"start_quarter":9.296843275833346,"start_week":10.716346880555577,"start_year":8.130855415000001,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":10.853776449166693},"prices":{"basicPrice":"8,25","unitPrice":"0.3510"}}
          2024-03-27 00:00:00.724  - info: sourceanalytix.0 (4437) Current value of state : {"val":0,"ack":true,"ts":1711407600913,"q":0,"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","lc":1695818259397}
          2024-03-27 00:17:00.274  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 started with pid 6179
          2024-03-27 00:17:03.089  - info: openweathermap.0 (6179) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.1, js-controller: 5.0.19
          2024-03-27 00:17:16.562  - info: openweathermap.0 (6179) Terminated (NO_ERROR): Without reason
          2024-03-27 00:17:17.095  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2024-03-27 00:37:00.223  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 started with pid 6781
          2024-03-27 00:37:05.371  - info: openweathermap.0 (6781) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.1, js-controller: 5.0.19
          2024-03-27 00:37:22.505  - info: openweathermap.0 (6781) Terminated (NO_ERROR): Without reason
          2024-03-27 00:37:23.035  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2024-03-27 00:57:00.262  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 started with pid 7444
          2024-03-27 00:57:05.673  - info: openweathermap.0 (7444) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.1, js-controller: 5.0.19
          2024-03-27 00:57:39.681  - info: openweathermap.0 (7444) Terminated (NO_ERROR): Without reason
          2024-03-27 00:57:40.244  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2024-03-27 01:17:00.380  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 started with pid 10815
          2024-03-27 01:17:04.331  - info: openweathermap.0 (10815) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.1, js-controller: 5.0.19
          2024-03-27 01:17:25.645  - info: openweathermap.0 (10815) Terminated (NO_ERROR): Without reason
          2024-03-27 01:17:26.217  - info: host.raspi4iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          iob diag has finished.
          Press any key for a summary
          Active iob-Instances: 	24
          ioBroker Core: 		js-controller 		5.0.19
          			admin 			6.13.16
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		11816
          States: 		10069
          Size of iob-Database:
          === Mark text until here for copying ===
          Ich hoffe, dass Euch die Infos weiterhelfen
            arteck Developer Most Active @Klarie last edited by
            @klarie wie währe es mit neuer Hardware..der cc2531 ist urlalt und hat so seine schmakazien ( wie du siehst)
            • Winni
              Winni last edited by Winni
              Was mir noch auffällt:
              Vielleicht die SSD separat mit Strom versorgen und evtl. neues, orginal Raspi-Netzteil besorgen. Der Raspberry 4 ist da sehr empfindlich.
              • Klarie
                @arteck sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
                Da habe gestern auch schon dran gedacht und den "SONOFF Zigbee 3.0 USB Plus" mit dem CC2652P ins Auge gefasst.
                Hast Du eine Empfehlung für mich?
                @winni sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
                An "seinem Platz" hängt er an einem original Netzteil. Im Versuchsaufbau hatte ich ihn an einem 65 W Ladeadapter. Der scheint nicht sonderlich stabil zu sein. Danke für den Hinweis. 👍
                Thomas Braun L 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @Klarie last edited by
                  @klarie
                  Einen von dieser Liste:
                  https://www.zigbee2mqtt.io/guide/adapters/
                  Hier im Forum gibt es aber auch Anbieter, ich glaube @dimaiv hat da was im Angebot.
                    legro @Klarie last edited by
                    @klarie sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
                    Nach langem Suchen hatte ich mich vor Jahren für den CC26X2R1 von TI entschieden und bin damit äußerst zufrieden. Beim Kauf galt es nur Rauchmelder und Außensirene von BITRON zu versorgen. Es war - mangels Repeater - eine gut Reichweite vonnöten, welche dieser Coordinator klaglos bereitstellt. Auch bot er damals schon ZigBee 3.0 und wird wohl noch immer bestens mit Updates versorgt.
                    Er hat wohl nur einen Nachteil: sein Preis.
                    • Klarie
                      Ich habe einen "SONOFF Zigbee 3.0 USB Plus" (CC2652P ) bestellt. Er kommt in der Woche nach Ostern.
                      Danach werde ich den Raspi noch mal (mit dem originalen Netzgerät) neu aufsetzen und im Anschluss berichten.
                      Ich danke Euch für den Support und wünsche schöne Feiertage.
                      Viele Grüße
                      Klaus
                      • Klarie
                        So, da bin ich wieder.
                        Ich bin am Ende mit meinem Latein...
                        Raspi und ioBroker habe ich mehrfach mit Backups und dem neuen "SONOFF Zigbee 3.0 USB Plus" (CC2652P ) neu aufgesetzt. Keine Chance..
                        Jetzt habe ich ein jungfräuliches System mit dem ioBroker in der Minimalausstattung.
                        Installiert sind lediglich Admin, backitup und Discovery aus der Grundinstallation - und eben der Zigbee-Adapter.
                        Die verschiedenen Einstellungen habe ich durchprobiert, im Moment ist die lange Link "by-id" hinterlegt.
                        Trotzdem bleibt der Zigbee-Adapter gelb.
                        Ich hoffe weiterhin auf Eure Hilfe. 🙏
                        iob diag
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         01:17:53 up 26 min,  2 users,  load average: 0.19, 0.19, 0.18
                        CPU threads: 4
                        Current issues:
                                       Local time: Sun 2024-04-07 01:17:53 CEST
                                   Universal time: Sat 2024-04-06 23:17:53 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        klaus
                        /home/klaus
                        X-Server: 	false
                        Desktop:
                        Terminal: 	tty
                        *** MEMORY ***
                        Mem:            4.0G        580M        2.9G        1.2M        550M        3.4G
                        Swap:           104M          0B        104M
                        Total:          4.1G        580M        3.0G
                                 3791 M total memory
                                  554 M used memory
                                  561 M active memory
                                  349 M inactive memory
                                 2784 M free memory
                                   35 M buffer memory
                                  489 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/sda2      ext4      117G  2.9G  109G   3% /
                        [Sun Apr  7 00:51:11 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:67:30 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=2fd6c37d-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Sun Apr  7 00:51:16 2024] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                        [Sun Apr  7 00:51:18 2024] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                        /var:
                        513M	/var/
                        203M	/var/cache
                        197M	/var/cache/apt
                        161M	/var/lib
                        Archived and active journals take up 48.0M in the file system.
                        1.5M	/opt/iobroker/backups/
                        19M	/opt/iobroker/iobroker-data/backup-objects
                        13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                        8.7M	/opt/iobroker/iobroker-data/objects.jsonl
                        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                        2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                        1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                        1.5M	/opt/iobroker/iobroker-data/backup-objects/2024-04-06_22-45_objects.jsonl.gz
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0
                        /usr/bin/nodejs 	v18.20.1
                        /usr/bin/node 		v18.20.1
                        /usr/bin/npm 		10.5.0
                        /usr/bin/npx 		10.5.0
                        /usr/bin/corepack 	0.25.2
                        nodejs:
                          Installed: 18.20.1-1nodesource1
                          Candidate: 18.20.1-1nodesource1
                          Version table:
                         *** 18.20.1-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin: 		6.13.16
                        javascript: 	"javascript" not found
                        Adapters from github: 	0
                        Adapter State
                        + system.adapter.zigbee.0                 : zigbee                : raspi4iobroker                           -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0
                        + instance is alive
                        Active repo(s): stable
                        Used repository: stable
                        Objects and States
                        Objects: 	172
                        States: 	127
                        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5645       694/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5652       694/iobroker.js-con
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7266       715/sshd: /usr/sbin
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       589        803/io.admin.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          7277       715/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6263       562/avahi-daemon: r
                        udp        0      0 0.0.0.0:54755           0.0.0.0:*                           104        6265       562/avahi-daemon: r
                        udp6       0      0 :::45488                :::*                                104        6266       562/avahi-daemon: r
                        udp6       0      0 fe80::a2e3:3846:8ea:546 :::*                                0          6490       621/NetworkManager
                        udp6       0      0 :::5353                 :::*                                104        6264       562/avahi-daemon: r
                        2024-04-07 00:59:30.977  - info: admin.0 (803) <== Disconnect system.user.admin from ::ffff:192.168.178.24
                        2024-04-07 00:59:30.868  - info: zigbee.0 (939) cleaned everything up...
                        2024-04-07 00:59:30.871  - info: zigbee.0 (939) Zigbee: disabling joining new devices.
                        2024-04-07 00:59:31.080  - warn: zigbee.0 (939) Failed to stop zigbee during startup
                        2024-04-07 00:59:31.081  - info: zigbee.0 (939) terminating
                        2024-04-07 00:59:31.083  - info: zigbee.0 (939) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-04-07 00:59:31.370  - info: zigbee.0 (939) terminating
                        2024-04-07 00:59:31.636  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-04-07 00:59:33.944  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 2034
                        2024-04-07 00:59:38.545  - info: zigbee.0 (2034) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                        2024-04-07 00:59:38.653  - info: zigbee.0 (2034) delete old Backup files. keep only last 10
                        2024-04-07 00:59:38.655  - info: zigbee.0 (2034) Starting Zigbee  npm ...
                        2024-04-07 00:59:38.975  - info: zigbee.0 (2034) Installed Version: iobroker.zigbee@1.10.1
                        2024-04-07 01:00:45.408  - error: zigbee.0 (2034) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                        2024-04-07 01:00:45.410  - error: zigbee.0 (2034) Failed to start Zigbee
                        2024-04-07 01:00:45.411  - error: zigbee.0 (2034) Error herdsman start
                        2024-04-07 01:00:55.416  - info: zigbee.0 (2034) Try to reconnect. 1 attempts left
                        2024-04-07 01:00:55.419  - info: zigbee.0 (2034) Starting Zigbee  npm ...
                        2024-04-07 01:00:55.447  - info: zigbee.0 (2034) Installed Version: iobroker.zigbee@1.10.1
                        2024-04-07 01:02:00.838  - error: zigbee.0 (2034) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                        2024-04-07 01:02:00.841  - error: zigbee.0 (2034) Failed to start Zigbee
                        2024-04-07 01:02:00.843  - error: zigbee.0 (2034) Error herdsman start
                        2024-04-07 01:15:06.095  - info: admin.0 (803) ==> Connected system.user.admin from ::ffff:192.168.178.24
                        2024-04-07 01:15:06.211  - error: zigbee.0 (2034) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                        2024-04-07 01:15:06.353  - info: zigbee.0 (2034) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"f8e52e2daaa4ed11aa9081582981d5c7","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0","vendorId":"10c4","productId":"ea60"}]
                        Summary
                        			v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                        Installation: 		native
                        Kernel: 		aarch64
                        Userland: 		arm64
                        Timezone: 		Europe/Berlin (CEST, +0200)
                        User-ID: 		1000
                        X-Server: 		false
                        Pending OS-Updates: 	0
                        Pending iob updates: 	0
                        Nodejs-Installation: 	/usr/bin/nodejs 	v18.20.1
                        			/usr/bin/npm 		10.5.0
                        			/usr/bin/npx 		10.5.0
                        Recommended versions are nodejs 18.20.1 and npm 10.5.0
                        MEMORY:
                        Mem:            4.0G        588M        2.9G        1.2M        551M        3.4G
                        Swap:           104M          0B        104M
                        Total:          4.1G        588M        3.0G
                        Active iob-Instances: 	5
                        			admin 			6.13.16
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 		172
                        States: 		127
                        312K	/opt/iobroker/iobroker-data/states.jsonl
                        "iob logs --watch" sagt nach dem Neustart des Zigbee-Adapters
                        2024-04-07 01:32:59.945  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                        2024-04-07 01:32:59.959  - info: zigbee.0 (2034) Got terminate signal TERMINATE_YOURSELF
                        2024-04-07 01:32:59.962  - info: zigbee.0 (2034) cleaned everything up...
                        2024-04-07 01:32:59.968  - info: zigbee.0 (2034) Zigbee: disabling joining new devices.
                        2024-04-07 01:33:00.002  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 send kill signal
                        2024-04-07 01:33:00.464  - info: zigbee.0 (2034) terminating
                        2024-04-07 01:33:00.466  - info: zigbee.0 (2034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-04-07 01:33:01.006  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 killing pid 2034
                        2024-04-07 01:33:01.026  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-04-07 01:33:03.039  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 3505
                        2024-04-07 01:33:07.600  - info: zigbee.0 (3505) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                        2024-04-07 01:33:07.710  - info: zigbee.0 (3505) delete old Backup files. keep only last 10
                        2024-04-07 01:33:07.712  - info: zigbee.0 (3505) Starting Zigbee  npm ...
                        2024-04-07 01:33:08.032  - info: zigbee.0 (3505) Installed Version: iobroker.zigbee@1.10.1
                        2024-04-07 01:34:14.181  - error: zigbee.0 (3505) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                        2024-04-07 01:34:14.183  - error: zigbee.0 (3505) Failed to start Zigbee
                        2024-04-07 01:34:14.185  - error: zigbee.0 (3505) Error herdsman start
                        2024-04-07 01:34:24.191  - info: zigbee.0 (3505) Try to reconnect. 1 attempts left
                        2024-04-07 01:34:24.194  - info: zigbee.0 (3505) Starting Zigbee  npm ...
                        2024-04-07 01:34:24.224  - info: zigbee.0 (3505) Installed Version: iobroker.zigbee@1.10.1
                        2024-04-07 01:34:24.491  - error: zigbee.0 (3505) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                        2024-04-07 01:34:24.492  - error: zigbee.0 (3505) Failed to start Zigbee
                        2024-04-07 01:34:24.493  - error: zigbee.0 (3505) Error herdsman start
                        [edit]
                        Ist die Zeile 30/33 ein nachvollziehbares Szenario? 🙇‍♂️
                        Bis letzte Woche lief es über den alten Stick mit der gleichen panID problemlos...
                        [/edit]*
                        LG KLaus
                        • Asgothian
                          Asgothian Developer @Klarie last edited by
                          [edit]
                          [/edit]*
                          LG KLaus
                          Ist es. Der Stick beschwert sich das es ein aktives Netzwerk gibt welches die PanID nutzt mit der er ein neues aufmachen soll.
                          Es gibt 2 mögliche Lösungen:
                          • Andere PanID / Ext-PanID eintragen und alles neu anlernen
                          • zigbee Adapter starten nachdem alle Router devices vom Strom getrennt wurden.
                          A.
                          arteck Klarie 2 Replies Last reply Reply Quote 1
                            arteck Developer Most Active @Asgothian last edited by
                            @asgothian oder Antenne ab und in AluFolie einpacken..das geht auch..und wieder starten
                            • Klarie
                              Klarie @Asgothian last edited by
                              @asgothian sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
                              Die ganzen Router, die natürlich noch aktiv sind, hatte ich gar nicht auf dem Schirm. Danke für den Hinweis!
                              Das werde ich heute Abend probieren! 👋
                              Klarie 1 Reply Last reply Reply Quote 0
                              • Klarie
                                Udate
                                Der Tipp von @arteck hat leider nicht funktioniert.
                                Trotz einer "halben Rolle" Alufolie entdeckte der Coordinator immer noch die gleiche PanID in der Nähe.
                                Ich habe vermutlich zu viele und "starke!" Router im Netz... 🤡
                                Also habe ich im ganzen Haus den Strom abgestellt und den Raspi über eine leistungsstarke Powerbank gestartet.
                                Der Zigbee-Adapter bleibt weiterhin gelb (kann nicht mit Gerät oder Dienst verbinden).
                                Logfile des Startvorganges
                                2024-04-07 14:21:52.062  - info: backitup.0 (860) cleaned everything up...
                                2024-04-07 14:21:52.066  - info: zigbee.0 (884) cleaned everything up...
                                2024-04-07 14:21:52.066  - info: host.raspi4iobroker received SIGTERM
                                2024-04-07 14:21:52.067  - info: admin.0 (763) terminating http server on port 8081
                                2024-04-07 14:21:52.080  - info: host.raspi4iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                                2024-04-07 14:21:52.081  - info: host.raspi4iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2024-04-07 14:21:52.082  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                2024-04-07 14:21:52.083  - info: host.raspi4iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                                2024-04-07 14:21:52.133  - info: discovery.0 (895) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.129  - info: admin.0 (763) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.139  - info: host.raspi4iobroker stopInstance system.adapter.admin.0 send kill signal
                                2024-04-07 14:21:52.135  - info: discovery.0 (895) terminating
                                2024-04-07 14:21:52.139  - info: discovery.0 (895) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.141  - info: host.raspi4iobroker stopInstance system.adapter.backitup.0 send kill signal
                                2024-04-07 14:21:52.142  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 send kill signal
                                2024-04-07 14:21:52.142  - info: host.raspi4iobroker stopInstance system.adapter.discovery.0 send kill signal
                                2024-04-07 14:21:52.130  - info: backitup.0 (860) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.145  - info: backitup.0 (860) terminating
                                2024-04-07 14:21:52.148  - info: admin.0 (763) terminating
                                2024-04-07 14:21:52.147  - info: backitup.0 (860) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.154  - info: admin.0 (763) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.087  - info: zigbee.0 (884) Zigbee: disabling joining new devices.
                                2024-04-07 14:21:52.180  - warn: zigbee.0 (884) Failed to stop zigbee during startup
                                2024-04-07 14:21:52.203  - info: zigbee.0 (884) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.248  - info: zigbee.0 (884) terminating
                                2024-04-07 14:21:52.250  - info: zigbee.0 (884) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.565  - info: discovery.0 (895) terminating
                                2024-04-07 14:21:52.570  - info: backitup.0 (860) terminating
                                2024-04-07 14:21:52.578  - info: zigbee.0 (884) terminating
                                2024-04-07 14:21:52.599  - info: admin.0 (763) terminating
                                2024-04-07 14:21:52.756  - info: host.raspi4iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.756  - info: host.raspi4iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.801  - info: host.raspi4iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.817  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.818  - info: host.raspi4iobroker All instances are stopped.
                                2024-04-07 14:21:52.950  - info: host.raspi4iobroker terminated
                                2024-04-07 14:22:02.703  - info: host.raspi4iobroker iobroker.js-controller version 5.0.19 js-controller starting
                                2024-04-07 14:22:02.710  - info: host.raspi4iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                2024-04-07 14:22:02.711  - info: host.raspi4iobroker hostname: raspi4iobroker, node: v18.20.1
                                2024-04-07 14:22:02.712  - info: host.raspi4iobroker ip addresses:
                                2024-04-07 14:22:04.614  - info: host.raspi4iobroker connected to Objects and States
                                2024-04-07 14:22:04.683  - info: host.raspi4iobroker added notifications configuration of host
                                2024-04-07 14:22:05.836  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeCurrent"
                                2024-04-07 14:22:05.841  - info: host.raspi4iobroker 4 instances found
                                2024-04-07 14:22:05.877  - info: host.raspi4iobroker starting 4 instances
                                2024-04-07 14:22:05.978  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeNewest"
                                2024-04-07 14:22:06.008  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeNewestNext"
                                2024-04-07 14:22:06.034  - info: host.raspi4iobroker instance system.adapter.admin.0 started with pid 800
                                2024-04-07 14:22:06.052  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmCurrent"
                                2024-04-07 14:22:06.112  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmNewest"
                                2024-04-07 14:22:06.127  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmNewestNext"
                                2024-04-07 14:22:06.141  - info: host.raspi4iobroker Some obsolete host states deleted.
                                2024-04-07 14:22:09.937  - info: host.raspi4iobroker instance system.adapter.backitup.0 started with pid 810
                                2024-04-07 14:22:12.188  - info: admin.0 (800) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:12.293  - info: admin.0 (800) requesting all objects
                                2024-04-07 14:22:13.183  - warn: admin.0 (800) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
                                2024-04-07 14:22:14.038  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 829
                                2024-04-07 14:22:14.463  - info: admin.0 (800) received all objects
                                2024-04-07 14:22:15.278  - warn: admin.0 (800) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
                                2024-04-07 14:22:15.291  - info: admin.0 (800) Request actual repository...
                                2024-04-07 14:22:15.369  - info: admin.0 (800) socket.io server listening on port 8081
                                2024-04-07 14:22:15.381  - info: admin.0 (800) http server listening on port 8081
                                2024-04-07 14:22:15.384  - info: admin.0 (800) Use link "http://127.0.0.1:8081" to configure.
                                2024-04-07 14:22:16.527  - warn: admin.0 (800) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
                                2024-04-07 14:22:17.248  - info: host.raspi4iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2024-04-07 14:22:17.633  - error: host.raspi4iobroker Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": getaddrinfo EAI_AGAIN download.iobroker.net
                                2024-04-07 14:22:19.141  - info: host.raspi4iobroker instance system.adapter.discovery.0 started with pid 836
                                2024-04-07 14:22:19.533  - info: admin.0 (800) Repository received successfully.
                                2024-04-07 14:22:19.699  - info: backitup.0 (810) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:19.923  - info: backitup.0 (810) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                2024-04-07 14:22:23.509  - info: discovery.0 (836) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:24.766  - info: zigbee.0 (829) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:24.996  - info: zigbee.0 (829) delete old Backup files. keep only last 10
                                2024-04-07 14:22:25.001  - info: zigbee.0 (829) Starting Zigbee  npm ...
                                2024-04-07 14:22:25.824  - error: zigbee.0 (829) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
                                2024-04-07 14:22:25.826  - error: zigbee.0 (829) Failed to start Zigbee
                                2024-04-07 14:22:25.827  - error: zigbee.0 (829) Error herdsman start
                                2024-04-07 14:22:25.835  - info: zigbee.0 (829) Installed Version: iobroker.zigbee@1.10.1
                                2024-04-07 14:22:35.835  - info: zigbee.0 (829) Try to reconnect. 1 attempts left
                                2024-04-07 14:22:35.837  - info: zigbee.0 (829) Starting Zigbee  npm ...
                                2024-04-07 14:22:35.862  - error: zigbee.0 (829) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
                                2024-04-07 14:22:35.864  - error: zigbee.0 (829) Failed to start Zigbee
                                2024-04-07 14:22:35.866  - error: zigbee.0 (829) Error herdsman start
                                2024-04-07 14:22:35.893  - info: zigbee.0 (829) Installed Version: iobroker.zigbee@1.10.1
                                2024-04-07 14:26:05.943  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:26:05.945  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:26:05.946  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:26:05.947  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:35:28.526  - info: admin.0 (800) failed connection to socket.io from ::ffff:192.168.178.24: Passport was not initialized
                                2024-04-07 14:35:40.236  - info: admin.0 (800) ==> Connected system.user.admin from ::ffff:192.168.178.24
                                Asgothian Thomas Braun arteck 3 Replies Last reply Reply Quote 0
                                • Asgothian
                                  Udate
                                  Der usb Stick wird nicht erkannt - siehe Zeilen 75 und 81 im log.
                                  A.
                                    Kopier den Link von hier:
                                    USB-Devices by-id:
                                    • Klarie
                                      Der Link ist bereits in den Einstellungen hinterlegt.
                                      Thomas Braun W 2 Replies Last reply Reply Quote 0
                                        @klarie
                                        Auch keine Zahlendreher drin?
                                          Wildbill @Klarie last edited by
                                          @klarie Beim Kopieren vielleicht versehentlich vorne order hinten ein Leerzeichen angehängt?
                                          Einfach mal vorne das erste Zeichen löschen und nochmal neu manuell eingeben. Hinten das Gleiche.
                                          Gruss, Jürgen
                                          • Klarie
                                            Klarie @Asgothian last edited by Klarie
                                            (Zeile 75 aus meinem Logfile)
                                            USB-Devices by-id:        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0
                                            Die Links sind identisch. Habt ihr eine Idee, warum der Stick, bzw. der Treiber dazu dann nicht gefunden wird?
                                            zigbee cc2531
                                            1988
