    4. Daten aus der Fritzbox visualisieren
    • Ro75
      Ro75 @Dr.Pie last edited by Ro75
      @dr-pie sagte in Daten aus der Fritzbox visualisieren:
      leider gibt der Adapter von AVM (tr064) die erforderlichen Daten nicht preis
      das stimmt so definitiv nicht. Der tr-64 Adapter kann dir alles liefern. Es ist immer nur die Frage wie. Versuche es mal so:
      const NewByteReceiveRate    = '0_userdata.0.FritzBox.NewByteReceiveRate';
      const NewByteSendRate       = '0_userdata.0.FritzBox.NewByteSendRate';
      const L1DownMaxRate         = '0_userdata.0.FritzBox.Layer1DownstreamMaxBitRate';
      const L1UpMaxRate           = '0_userdata.0.FritzBox.Layer1UpstreamMaxBitRate';
      const ReceiveR              = '0_userdata.0.FritzBox.Charts.Receive';
      const SendR                 = '0_userdata.0.FritzBox.Charts.Send';
      createState(NewByteReceiveRate, 0, {type: 'number', read: true, write: true});
      createState(NewByteSendRate, 0, {type: 'number', read: true, write: true});
      createState(L1DownMaxRate, 0, {type: 'number', read: true, write: true});
      createState(L1UpMaxRate, 0, {type: 'number', read: true, write: true});
      createState(ReceiveR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
      createState(SendR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
      schedule('*/6 * * * * *', function Aktualisierung() {
          setState('tr-064.0.states.command', '{"service": "urn:dslforum-org:service:WANCommonInterfaceConfig:1","action": "X_AVM-DE_GetOnlineMonitor","params": {"NewSyncGroupIndex": 0}}');
          var value=getState('tr-064.0.states.commandResult').val;
          if (value.indexOf('NewTotalNumber') == 2) {
              var obj = JSON.parse(value);
              var DownStream = obj.Newds_current_bps;
              var UpStream = obj.Newus_current_bps;
              var ds = DownStream.split(",");
              var us = UpStream.split(",");
              var wds    =  ds[0];
              var wus    =  us[0];
              setState(NewByteReceiveRate, wds*1);
              setState(NewByteSendRate, wus*1);
              setState(ReceiveR, Math.round((wds*0.000008)*100)/100);
              setState(SendR, Math.round((wus*0.000008)*100)/100);
              setState(L1DownMaxRate, obj.Newmax_ds*8);
              setState(L1UpMaxRate, obj.Newmax_us*8);
      Damit hat man einmal die "Basisdaten". Mit einigen weiteren Codezeilen kann man auch erfahren wie groß der Traffic ist (down / up). Mit bissel Spielerei kann man so den Traffic für den Tag, die Woche, den Monat errechnen, speichern und visualisieren.
      Alles über den TR-64 Adapter.
      Ro75.
      haselchen Dr.Pie G B K 6 Replies Last reply Reply Quote 2
      • haselchen
        haselchen Most Active @Ro75 last edited by
        @ro75
        Klingt spannend und bringt mich zu einer Frage.
        Die FB7590 läuft ja auch an Glasfaser Anschlüssen.
        Der Up und Download wie bei DSL wird da ja nicht angezeigt .
        Liefert Dein Code eventuell die Daten?
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          Ro75 @haselchen last edited by
          @haselchen sagte in Daten aus der Fritzbox visualisieren:
          Probiere einfach den Code aus. Bei einer 7490 geht es zu 100%.
          Ro75.
          • haselchen
            @ro75
            An was für einem Anschluss ?
            • Ro75
              Was meinst du damit genau?
              Ro75.
              • Dr.Pie
                Dr.Pie @Ro75 last edited by
                @ro75 sagte in Daten aus der Fritzbox visualisieren:
                Ro75.
                Magst du die Visualisierung zur Verfügung stellen ?
                • haselchen
                  @ro75
                  Naja, DSL oder Glasfaser
                  • Ro75
                    Ro75 last edited by Ro75
                    @haselchen Dann ist es DSL.
                    Ro75.
                    EDIT: In der Dokumentation von AVM finde ich jetzt nicht eine expliziete Unterscheidung zwischen DSL und Glasfaser.
                    Probiere den Code einfach aus und dann berichte mal.
                    Ro75.
                      ludino @Dr.Pie last edited by ludino
                      @Ro75
                      Hi Habe mir dein Script mal installiert, und es klappt super. Leider weiß ich nicht wie du die Vis gemacht hast besonders intressiert mich die darstellung der letzten 10 tage und der letzten 12 Monaten.
                      Würde du es mir verraten?
                      Ludino
                        Galen @Ro75 last edited by
                        @ro75 Vielen Dank!
                        Könntest du noch den Codeteil posten, der das genutzte Datenvolumen berechnet und speichert?
                        Könnte man evtl. noch die derzeitige IP und den Status der Leitung (Verbunden oder getrennt) aus den Daten auslesen?
                        Dr.Pie 1 Reply Last reply Reply Quote 0
                        • Dr.Pie
                          Dr.Pie @Galen last edited by
                          bei mir scheint nicht zu funktionieren:
                            emil70 @Dr.Pie last edited by
                            @dr-pie
                            Hast du den Adapter tr-064 drauf?
                            • Dr.Pie
                              Dr.Pie @emil70 last edited by
                              @emil70 ja ... 2 Instanzen
                              • Ro75
                                @dr-pie Was steht denn im DP "tr-064.0.states.commandResult"?
                                Ro75.
                                Dr.Pie D 2 Replies Last reply Reply Quote 0
                                • Dr.Pie
                                  @ro75 Ich habe das Script und die DP's mal gelöscht und wieder neu installiert ... nun scheint es zu funktionieren.
                                  Ich hatte das schon mal das ich erst etwas wieder deinstallieren musste und neu installiert habe dann funktionierte es..
                                  Komisch
                                    babl @Ro75 last edited by
                                    @ro75 Dein Script funktioniert gut, nur es haut mir die Protokolle voll mit den Ergebnissen der Abfragen, wie kann ich das denn in diesem Java Script ausschalten, sorry Javascript ist nicht meine Hauptsprache mache alles über blockly.
                                    Ro75 Homoran 2 Replies Last reply Reply Quote 0
                                    • Ro75
                                      Ro75 @babl last edited by
                                      @babl das Skript selbst enthält keinerlei LOG-Ausgaben. Eventuell musst du bei dem JS-Adapter die LOG-Stufe ändern. Ggfs. von Info auf Error.
                                      Ro75.
                                        Homoran Global Moderator Administrators @babl last edited by
                                        @babl sagte in Daten aus der Fritzbox visualisieren:
                                        dann zeig mal was genau im log steht
                                          babl @Homoran last edited by
                                          @homoran @Ro75
                                          2024-05-26 10:05:06.055 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052,638,1041","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876,795,850","Newprio_realtime_bps":"4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313,194,142","Newprio_high_bps":"238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106,68,48","Newprio_default_bps":"810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457,533,660","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                          2024-05-26 10:05:12.114 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876","Newprio_realtime_bps":"295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313","Newprio_high_bps":"48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106","Newprio_default_bps":"669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                          2024-05-26 10:05:18.054 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091","Newprio_realtime_bps":"377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490","Newprio_high_bps":"137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53","Newprio_default_bps":"557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                          2024-05-26 10:05:24.097 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321","Newprio_realtime_bps":"408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553","Newprio_high_bps":"15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63","Newprio_default_bps":"622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                          2024-05-26 10:05:30.136 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728","Newprio_realtime_bps":"100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228","Newprio_high_bps":"46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46","Newprio_default_bps":"665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                          2024-05-26 10:05:34.307 - info: admin.0 (3910344) ==> Connected system.user.admin from ::ffff:192.168.157.20
                                          2024-05-26 10:05:36.080 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1081,1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"842,811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801","Newprio_realtime_bps":"193,100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501","Newprio_high_bps":"98,46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70","Newprio_default_bps":"551,665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                          2024-05-26 10:05:38.586 - info: javascript.0 (3935439) Stopping script script.js.common.FritzBox.Datenmenge
                                            babl last edited by
                                            @Ro75 @Homoran Auch wenn ich die Logstufe von Info zu Error ändere kommen die gleichen Infos im Log an.
                                            Habe gestern das System upgedatet auch den Java Script Adapter auf die 8.3.1
                                            Vielleicht ist es ein "Bug"
                                            Node.js: v18.20.3
                                            NPM: 10.7.0
                                            Ro75 DJMarc75 2 Replies Last reply Reply Quote 0
                                            112
                                            10879
