    4. javascript startet nicht mehr
    • rtwl
      rtwl @Codierknecht last edited by
      @codierknecht sagte in javascript startet nicht mehr:
      Zeig mal die Langfassung von iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: smarthome
             Icon name: computer
                Kernel: Linux 6.6.20+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       21:23:45 up  9:35,  2 users,  load average: 0.11, 0.24, 0.31
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-04-07 21:23:45 CEST
                 Universal time: Sun 2024-04-07 19:23:45 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      rtwl
      /home/rtwl
      rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        2.2G        1.4G        1.2M        495M        1.8G
      Swap:           104M          0B        104M
      Total:          4.1G        2.2G        1.5G
               3792 M total memory
               2058 M used memory
               2101 M active memory
                242 M inactive memory
               1332 M free memory
                 51 M buffer memory
                421 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       15G  7.4G  6.0G  56% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sun Apr  7 11:48:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=baa0be65-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Apr  7 11:48:30 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
      [Sun Apr  7 11:48:32 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      609M    /var/
      203M    /var/cache
      197M    /var/cache/apt
      164M    /var/lib
      141M    /var/log/journal/347b9e5236b042cab12c17eb2f4c9517
      Archived and active journals take up 140.1M in the file system.
      /opt/iobroker/backups:
      1.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      968M    /opt/iobroker/iobroker-data/history
      233M    /opt/iobroker/iobroker-data/files
      99M     /opt/iobroker/iobroker-data/backup-objects
      58M     /opt/iobroker/iobroker-data/files/javascript.admin
      39M     /opt/iobroker/iobroker-data/states.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.1
      /usr/bin/node           v18.20.1
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.1-1nodesource1
        Candidate: 18.20.1-1nodesource1
        Version table:
       *** 18.20.1-1nodesource1 500
              100 /var/lib/dpkg/status
           18.20.0-1nodesource1 500
           18.19.1-1nodesource1 500
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Langfassung leider zu lang (zu viele Zeichen) hier der erste Teil.
      Jetzt kommt noch der Fehlerauszug vom Teil: Errors in npm tree:
      rtwl 1 Reply Last reply Reply Quote 0
      • rtwl
        rtwl @rtwl last edited by
        auch der "Errors in npm tree" hat mehr als 100.000 Zeichen.
        hier die txt Datei.
        iob diag.txt
          Thomas Braun Most Active @rtwl last edited by
          @rtwl
          npm ERR! invalid: @types/node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
          npm ERR! invalid: jsonata@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata
          npm ERR! invalid: jszip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip
          npm ERR! invalid: moment@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/moment
          npm ERR! invalid: node-inspect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect
          npm ERR! invalid: node-schedule@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule
          npm ERR! invalid: request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/request
          npm ERR! invalid: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver
          Spiel dein Backup ein.
          rtwl 2 Replies Last reply Reply Quote 0
          • rtwl
            rtwl @Thomas Braun last edited by
            Hab jetzt mal deinen ersten Vorschlag gemacht und den Javascript Adapter neu installiert - sieht so aus, als ob das funktioniert hat.
            Im Log tauchen seitdem keine Fehlermeldungen mehr auf.
            • rtwl
              soll ich trotzdem das Update einspielen? oder erstmal weiter beobachten?
              • rtwl
                Ich hab doch einen Fehler, aber was bedeutet das?
                javascript.0 2024-04-07 21:38:54.596	error	deprecated request@2.88.2: request has been deprecated, see http ://github.com/request/request/issues/3142
                javascript.0 2024-04-07 21:38:54.591	error	npm WARN
                javascript.0 2024-04-07 21:38:54.480	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                javascript.0 2024-04-07 21:38:54.477	error	npm
                javascript.0 2024-04-07 21:38:54.373	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                javascript.0 2024-04-07 21:38:54.372	error	npm
                javascript.0 2024-04-07 21:38:54.150	error	npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  @rtwl
                  Nee, das sind nur 'Warnings'.
                  Die vier Module werden nicht mehr richtig unterstützt und sollten nach Möglichkeit durch anderes ersetzt werden.
                  • rtwl
                    okay danke. das beruhigt.
                    kannst du hier in der aktuellen langfassung von iob diag erkennen, ob es noch weitere Baustellen gibt? Es tauchen nämlich noch ein paar "npm errors" auf:
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     21:50:13 up 10:01,  2 users,  load average: 0.69, 0.84, 1.03
                    CPU threads: 4
                    Current issues:
                                   Local time: Sun 2024-04-07 21:50:14 CEST
                               Universal time: Sun 2024-04-07 19:50:14 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    rtwl
                    /home/rtwl
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.0G        2.5G        1.1G        1.2M        533M        1.5G
                    Swap:           104M          0B        104M
                    Total:          4.1G        2.5G        1.2G
                             3792 M total memory
                             2356 M used memory
                             2349 M active memory
                              307 M inactive memory
                             1003 M free memory
                               70 M buffer memory
                              438 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/mmcblk0p2 ext4       15G  7.7G  5.8G  58% /
                    /var:
                    609M    /var/
                    203M    /var/cache
                    197M    /var/cache/apt
                    164M    /var/lib
                    38M     /opt/iobroker/iobroker-data/states.jsonl
                    38M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                    npm ERR! extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                    npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                    npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                    npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                    npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                    npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                    npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                    npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                    npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                    npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                    npm ERR! extraneous: detect-libc@2.0.2 /opt/iobroker/node_modules/detect-libc
                    npm ERR! extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                    npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                    npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/node-addon-api
                    npm ERR! extraneous: node-gyp-build@4.7.1 /opt/iobroker/node_modules/node-gyp-build
                    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                    npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                    npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                    npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                    npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
                    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                    npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
                    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
                    npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/agent-base
                    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/debug
                    npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/https-proxy-agent
                    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/ms
                    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                    npm ERR! invalid: form-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
                    npm ERR! A complete log of this run can be found in: /home/rtwl/.npm/_logs/2024-04-07T19_50_23_555Z-debug-0.log
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.19
                    admin:          6.13.16
                    javascript:     8.0.0
                    Adapters from github:   3
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : smarthome                                -  enabled
                    + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : smarthome                                - disabled
                    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
                    + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
                    + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
                      system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
                      system.adapter.discovery.0              : discovery             : smarthome                                - disabled
                      system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
                      system.adapter.flot.0                   : flot                  : smarthome                                - disabled
                    + system.adapter.fronius.0                : fronius               : smarthome                                -  enabled
                    + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
                    + system.adapter.history.0                : history               : smarthome                                -  enabled
                      system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
                      system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
                    + system.adapter.iot.0                    : iot                   : smarthome                                -  enabled
                    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
                    + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
                    + system.adapter.operating-hours.0        : operating-hours       : smarthome                                -  enabled
                    + system.adapter.pi-hole.0                : pi-hole               : smarthome                                -  enabled
                    + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
                    + system.adapter.pvforecast.0             : pvforecast            : smarthome                                -  enabled
                    + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
                    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
                      system.adapter.uv-protect.0             : uv-protect            : smarthome                                -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                - disabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                - disabled
                      system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
                    + system.adapter.weather-warnings.0       : weather-warnings      : smarthome                                -  enabled
                    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
                    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                    Adapter    "bring"        : 1.8.4    , installed 1.8.4
                    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
                    Adapter    "ical"         : 1.14.3   , installed 1.14.3
                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                    Adapter    "javascript"   : 7.8.0    , installed 8.0.0
                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                    Adapter    "operating-hours": 1.0.6  , installed 1.0.6
                    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                    Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                    Adapter    "uv-protect"   : 0.6.0    , installed 0.6.0
                    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                    Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                    Adapter    "ws"           : 2.5.11   , installed 2.5.11
                    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                    Objects and States
                    Objects:        12395
                    States:         10907
                    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5797       693/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7347       906/io.mqtt.0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4798       686/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6218       686/iobroker.js-con
                    tcp6       0      0 :::61991                :::*                    LISTEN      1001       6664       1154/io.harmony.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          5799       693/sshd: /usr/sbin
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8001       1296/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6282       778/io.admin.0
                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       6665       1154/io.harmony.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4690       532/avahi-daemon: r
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7519       976/io.shelly.0
                    udp        0      0 0.0.0.0:32832           0.0.0.0:*                           104        4692       532/avahi-daemon: r
                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       7435       943/io.radar2.0
                    udp6       0      0 :::5353                 :::*                                104        4691       532/avahi-daemon: r
                    udp6       0      0 :::60874                :::*                                104        4693       532/avahi-daemon: r
                    2024-04-07 21:39:13.968  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Geräte entkalken: Prüfungsergebnis: Fällig seit 12 Tagen
                    2024-04-07 21:39:13.972  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Wasserfilter spülen: Script wurde neu gestartet. Ein Timer-Startdatum ist vorhanden, also wird nur aktualisiert.
                    2024-04-07 21:39:13.973  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Wasserfilter spülen: Prüfungsergebnis: Fällig seit 71 Tagen
                    2024-04-07 21:39:13.978  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Fusselfilter Waschmaschine: Script wurde neu gestartet. Ein Timer-Startdatum ist vorhanden, also wird nur aktualisiert.
                    2024-04-07 21:39:13.980  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Fusselfilter Waschmaschine: Prüfungsergebnis: Fällig seit 12 Tagen
                    2024-04-07 21:39:14.015  - info: javascript.0 (75060) script.js.LMair.test_marker_abrufen: 0
                    2024-04-07 21:39:14.081  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Strom.kWh_Erzeugung
                    2024-04-07 21:39:14.133  - info: javascript.0 (75060) script.js.Haussteuerung.Strom.kWh_Erzeugung: registered 0 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-04-07 21:39:14.134  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Strom.kWh_Gesamtverbrauch
                    2024-04-07 21:39:14.206  - info: javascript.0 (75060) script.js.Haussteuerung.Strom.kWh_Gesamtverbrauch: registered 0 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-04-07 21:39:14.350  - info: javascript.0 (75060) script.js.LMair.marker1: 200
                    2024-04-07 21:39:14.482  - info: javascript.0 (75060) Start javascript script.js.LMair.marker
                    2024-04-07 21:39:14.494  - info: javascript.0 (75060) script.js.LMair.marker: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    2024-04-07 21:39:14.495  - info: javascript.0 (75060) Start javascript script.js.LMair.weather_json
                    2024-04-07 21:39:14.502  - info: javascript.0 (75060) script.js.LMair.weather_json: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    2024-04-07 21:39:14.627  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Fernseher.ambilight
                    2024-04-07 21:39:14.634  - info: javascript.0 (75060) script.js.Haussteuerung.Fernseher.ambilight: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    2024-04-07 21:39:15.404  - info: javascript.0 (75060) script.js.Haussteuerung.Lüftungsempfehlungs.Lüftungsempfehlung: Subscriptions angelegt: 20
                    2024-04-07 21:39:16.067  - error: javascript.0 (75060) script.js.LMair.marker1: timeout of 2000ms exceeded
                    2024-04-07 21:39:16.067  - info: javascript.0 (75060) script.js.LMair.marker1: undefined
                    2024-04-07 21:40:00.352  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
                    2024-04-07 21:40:00.393  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
                    2024-04-07 21:40:00.426  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
                    2024-04-07 21:40:01.653  - info: javascript.0 (75060) script.js.Haussteuerung.Lüftungsempfehlungs.Liste_Lueftungsempfehlung: Badezimmer
                    2024-04-07 21:50:24.476  - warn: zigbee.0 (1038) DeviceAvailability:Stopping to ping 0x000b57fffe2a31ca TRADFRI bulb E27 WS�opal 980lm after 4 ping attempts
                      @rtwl sagte in javascript startet nicht mehr:
                      Der klemmt noch. Ist das ein Zusätzliches Modul im Adapter?
                      • rtwl
                        Ehrlichgesagt, keine Ahnung was das ist.
                        Als ich soeben keine Blocklys mehr speichern konnte dachte ich mir es würde
                        iob stop
                        sudo reboot
                        helfen. Doch leider bin ich jetzt wieder am Anfang. Der Javascript Adapter bleibt Rot. 😥
                        Auch die Log Meldungen (siehe erster Post) sind wieder alle 30 Sek vorhanden.
                        Hast du noch eine Idee, oder bleibt es mir nicht erspart neu aufzusetzen?
                          Backup?
                          • rtwl
                            hab mich für die neue Installation auf einer neuen SD Karte entschieden. Dort kommt dann das Backup drauf. Somit sollte ich dann auf der sicheren Seite sein. Nicht, dass dann doch noch irgendwo Fehler auftauchen - hab ja den Raspi heute morgen einfach Stromlos gemacht.
                            Danke wiedermal für deine Hilfe 👍
                            • rtwl
                              rtwl last edited by
                              der iobroker (Raspberry/SD Karte) war zwar per Ping ansprechbar. aber weder der iobroker konnte geöffnet werden auch per ssh hatte ich keinen Zugriff mehr.
                              3 Tage später mit dem frisch installiertem iobroker wieder das gleiche Problem...
                              Ping erfolgreich - per ssh aber keinen Zugriff mehr - es kommt keine Passwortanforderung nach der ssh Eingabe.
                              Kann ich außer innerlich durchdrehen noch irgendwas tun?
                              Warum passiert das immer so unvorhergesehen?
                                iob diag
                                anschauen.
                                • rtwl
                                  @thomas-braun soweit komm ich ja gar nicht. Hab keinen Zugriff per ssh. Der iobroker ist ja "abgestürzt"
                                  • rtwl
                                    es gibt nicht zufällig einen http request den ich an die ip-adresse des Raspberry schicken kann um iobroker neu zu starten oder sowas in der Art?
                                      @rtwl
                                      Du kommst ja wohl nicht drauf.
                                      Mit lokal angeklemmter Tastatur:
                                      https://wiki.ubuntuusers.de/Magic_SysRQ/
                                      • rtwl
                                        leider hab ich keinen mini-hdmi adapter für den Raspi.
                                        aber meinst du es würde funktionieren eine Tastatur anzuschließen und dann
                                        Zitat der Website: "hierfür wird die ganze Zeit Alt + Druck gedrückt gehalten und nacheinander die Tasten R + E + I + S + U + B betätigt."?
                                          Thomas Braun Most Active @rtwl last edited by Thomas Braun
                                          @rtwl
                                          Das hängt von der Tastatur ab. Viele moderne Spar-Tastaturen haben die Taste nicht (mehr direkt), manche auch gar nicht.
                                          Ich weiß auch ehrlich gesagt gar nicht, ob Raspberry OS die Funktion nicht auch abgestellt hat. Ich musste die bei mir noch nie verwenden. Das Ding läuft einfach.
                                          Auf meinem Arch Linux geht es nämlich nicht:
                                          [Do, 11. Apr 2024, 00:02:24] sysrq: This sysrq operation is disabled.
                                          [Do, 11. Apr 2024, 00:02:25] sysrq: This sysrq operation is disabled.
                                          [Do, 11. Apr 2024, 00:02:26] sysrq: This sysrq operation is disabled.
                                          [Do, 11. Apr 2024, 00:02:27] sysrq: Emergency Sync
                                          [Do, 11. Apr 2024, 00:02:27] Emergency Sync complete
                                          [Do, 11. Apr 2024, 00:02:28] sysrq: This sysrq operation is disabled.
                                          [Do, 11. Apr 2024, 00:02:29] sysrq: This sysrq operation is disabled.
                                          • rtwl
                                            @thomas-braun wow, das hat tatsächlich funktioniert 👍
                                            iob diag für dich zur Kontrolle. Bitte Danke.
                                            Skript v.2023-10-10
                                            *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                            Docker          : false
                                            Kernel          : aarch64
                                            Userland        : arm64
                                             23:58:26 up 1 min,  2 users,  load average: 3.98, 1.25, 0.44
                                            CPU threads: 4
                                            Current issues:
                                            ~ Under-voltage has occurred
                                                           Local time: Wed 2024-04-10 23:58:26 CEST
                                                       Universal time: Wed 2024-04-10 21:58:26 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            rtwl
                                            /home/rtwl
                                            X-Server:       false
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            4.0G        1.6G        2.2G        1.2M        329M        2.4G
                                            Swap:           104M          0B        104M
                                            Total:          4.1G        1.6G        2.3G
                                                     3792 M total memory
                                                     1478 M used memory
                                                     1477 M active memory
                                                      156 M inactive memory
                                                     2066 M free memory
                                                       31 M buffer memory
                                                      283 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            Raspberry only:
                                            oom events: 0
                                            *** FILESYSTEM ***
                                            /dev/mmcblk0p2 ext4       15G  5.7G  7.8G  43% /
                                            [Wed Apr 10 23:56:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c17d14e5-02 rootfstype=ext4 fsck.repair=yes rootwait
                                            [Wed Apr 10 23:56:41 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                                            [Wed Apr 10 23:56:44 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                                            /var:
                                            513M    /var/
                                            203M    /var/cache
                                            197M    /var/cache/apt
                                            161M    /var/lib
                                            133M    /var/lib/apt/lists
                                            Archived and active journals take up 48.0M in the file system.
                                            191M    /opt/iobroker/backups/
                                            974M    /opt/iobroker/iobroker-data/history
                                            249M    /opt/iobroker/iobroker-data/files
                                            98M     /opt/iobroker/iobroker-data/backup-objects
                                            75M     /opt/iobroker/iobroker-data/files/javascript.admin
                                            23M     /opt/iobroker/iobroker-data/states.jsonl
                                            USB-Devices by-id:
                                            /usr/bin/npm            10.5.0
                                            /usr/bin/npx            10.5.0
                                            nodejs:
                                              Version table:
                                             *** 18.20.1-1nodesource1 1001
                                                 18.20.0-1nodesource1 1001
                                                 18.19.1-1nodesource1 1001
                                                 18.19.0-1nodesource1 1001
                                                 18.18.2-1nodesource1 1001
                                                 18.18.1-1nodesource1 1001
                                                 18.18.0-1nodesource1 1001
                                                 18.17.1-1nodesource1 1001
                                                 18.17.0-1nodesource1 1001
                                                 18.16.1-1nodesource1 1001
                                                 18.16.0-1nodesource1 1001
                                                 18.15.0-1nodesource1 1001
                                                 18.14.2-1nodesource1 1001
                                                 18.14.1-1nodesource1 1001
                                                 18.14.0-1nodesource1 1001
                                                 18.13.0+dfsg1-1 500
                                                 18.13.0-1nodesource1 1001
                                                 18.12.0-1nodesource1 1001
                                                 18.11.0-1nodesource1 1001
                                                 18.10.0-1nodesource1 1001
                                                 18.9.1-1nodesource1 1001
                                                 18.9.0-1nodesource1 1001
                                                 18.8.0-1nodesource1 1001
                                                 18.7.0-1nodesource1 1001
                                                 18.6.0-1nodesource1 1001
                                                 18.5.0-1nodesource1 1001
                                                 18.4.0-1nodesource1 1001
                                                 18.3.0-1nodesource1 1001
                                                 18.2.0-1nodesource1 1001
                                                 18.1.0-1nodesource1 1001
                                                 18.0.0-1nodesource1 1001
                                            Errors in npm tree:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            admin:          6.13.16
                                            javascript:     8.0.2
                                            Adapter State
                                            + system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
                                              system.adapter.pi-hole.0                : pi-hole               : smarthome                                - disabled
                                              system.adapter.uv-protect.0             : uv-protect            : smarthome                                - disabled
                                            + instance is alive
                                            Adapter    "javascript"   : 7.8.0    , installed 8.0.2
                                            Objects and States
                                            Objects:        12474
                                            States:         10977
                                            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            Pending Updates: 2
                                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7443       1215/io.mqtt.0
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6394       717/sshd: /usr/sbin
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5898       710/iobroker.js-con
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5891       710/iobroker.js-con
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5037       943/io.admin.0
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11032      1916/io.web.0
                                            tcp6       0      0 :::61991                :::*                    LISTEN      1001       11375      1693/io.harmony.0
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          6396       717/sshd: /usr/sbin
                                            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11376      1693/io.harmony.0
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        729        559/avahi-daemon: r
                                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       10659      1485/io.shelly.0
                                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       6973       1366/io.radar2.0
                                            udp        0      0 0.0.0.0:41284           0.0.0.0:*                           104        731        559/avahi-daemon: r
                                            udp6       0      0 :::5353                 :::*                                104        730        559/avahi-daemon: r
                                            udp6       0      0 :::42826                :::*                                104        732        559/avahi-daemon: r
                                            2024-04-11 00:00:16.802  - info: weather-warnings.0 (1887) Refresh Interval: 10 minutes
                                            2024-04-11 00:00:16.940  - info: weather-warnings.0 (1887) [pushover] Create notification service pushover adapter: pushover.0.
                                            2024-04-11 00:00:16.941  - info: weather-warnings.0 (1887) ZAMG activated. Retrieve data.
                                            2024-04-11 00:00:20.464  - error: daswetter.0 (1193) force terminate
                                            2024-04-11 00:00:20.512  - warn: daswetter.0 (1193) Terminated (UNKNOWN_ERROR): Without reason
                                            2024-04-11 00:00:21.112  - error: daswetter.0 (1193) exception in await insertIntoList [Error: DB closed]
                                            2024-04-11 00:00:21.125  - error: daswetter.0 (1193) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_3.Hour_23.rain_value": Connection is closed.
                                            2024-04-11 00:00:21.309  - error: host.smarthome instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                                            2024-04-11 00:00:23.262  - info: pvforecast.0 (1827) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
                                            2024-04-11 00:00:33.382  - warn: javascript.0 (1031) You are assigning a number to the state "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                                            2024-04-11 00:00:33.820  - warn: javascript.0 (1031)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
                                            2024-04-11 00:00:33.824  - warn: javascript.0 (1031)     at Object.<anonymous> (script.js.VIS.Wetter.Wetterwarnung_Popup:7:3)
                                            2024-04-11 00:00:33.825  - warn: javascript.0 (1031)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1350:38)
                                            2024-04-11 00:00:33.826  - warn: javascript.0 (1031)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:640:29)
                                            2024-04-11 00:00:33.826  - warn: javascript.0 (1031)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
                                            2024-04-11 00:00:33.827  - warn: javascript.0 (1031)     at processImmediate (node:internal/timers:476:21)
                                            2024-04-11 00:00:34.123  - info: javascript.0 (1031) State value to set for "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" has to be type "string" but received type "number"
                                            2024-04-11 00:00:34.178  - warn: javascript.0 (1031) You are assigning a number to the state "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                                            2024-04-11 00:00:34.181  - warn: javascript.0 (1031)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
                                            2024-04-11 00:00:34.181  - warn: javascript.0 (1031)     at Object.<anonymous> (script.js.VIS.Wetter.Wetterwarnung_Popup:7:3)
                                            2024-04-11 00:00:34.182  - warn: javascript.0 (1031)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1350:38)
                                            2024-04-11 00:00:34.182  - warn: javascript.0 (1031)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:640:29)
                                            2024-04-11 00:00:34.183  - warn: javascript.0 (1031)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
                                            2024-04-11 00:00:34.183  - warn: javascript.0 (1031)     at processImmediate (node:internal/timers:476:21)
                                            2024-04-11 00:00:34.590  - info: javascript.0 (1031) State value to set for "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" has to be type "string" but received type "number"
                                            1028
