    4. javascript startet nicht mehr
      Thomas Braun Most Active @rtwl last edited by
      @rtwl
      npm ERR! invalid: @types/node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
      npm ERR! invalid: jsonata@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata
      npm ERR! invalid: jszip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip
      npm ERR! invalid: moment@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/moment
      npm ERR! invalid: node-inspect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect
      npm ERR! invalid: node-schedule@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule
      npm ERR! invalid: request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/request
      npm ERR! invalid: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver
      Spiel dein Backup ein.
      rtwl 2 Replies Last reply Reply Quote 0
      • rtwl
        rtwl @Thomas Braun last edited by
        Hab jetzt mal deinen ersten Vorschlag gemacht und den Javascript Adapter neu installiert - sieht so aus, als ob das funktioniert hat.
        Im Log tauchen seitdem keine Fehlermeldungen mehr auf.
        • rtwl
          soll ich trotzdem das Update einspielen? oder erstmal weiter beobachten?
          rtwl 1 Reply Last reply Reply Quote 0
          • rtwl
            rtwl @rtwl last edited by
            Ich hab doch einen Fehler, aber was bedeutet das?
            javascript.0 2024-04-07 21:38:54.596	error	deprecated request@2.88.2: request has been deprecated, see http ://github.com/request/request/issues/3142
            javascript.0 2024-04-07 21:38:54.591	error	npm WARN
            javascript.0 2024-04-07 21:38:54.480	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
            javascript.0 2024-04-07 21:38:54.477	error	npm
            javascript.0 2024-04-07 21:38:54.373	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
            javascript.0 2024-04-07 21:38:54.372	error	npm
            javascript.0 2024-04-07 21:38:54.150	error	npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              @rtwl
              Nee, das sind nur 'Warnings'.
              Die vier Module werden nicht mehr richtig unterstützt und sollten nach Möglichkeit durch anderes ersetzt werden.
              • rtwl
                okay danke. das beruhigt.
                kannst du hier in der aktuellen langfassung von iob diag erkennen, ob es noch weitere Baustellen gibt? Es tauchen nämlich noch ein paar "npm errors" auf:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                 Static hostname: smarthome
                       Icon name: computer
                          Kernel: Linux 6.6.20+rpt-rpi-v8
                    Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.4
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : arm64
                Systemuptime and Load:
                 21:50:13 up 10:01,  2 users,  load average: 0.69, 0.84, 1.03
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Sun 2024-04-07 21:50:14 CEST
                           Universal time: Sun 2024-04-07 19:50:14 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                rtwl
                /home/rtwl
                rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            4.0G        2.5G        1.1G        1.2M        533M        1.5G
                Swap:           104M          0B        104M
                Total:          4.1G        2.5G        1.2G
                         3792 M total memory
                         2356 M used memory
                         2349 M active memory
                          307 M inactive memory
                         1003 M free memory
                           70 M buffer memory
                          438 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                udev           devtmpfs  1.6G     0  1.6G   0% /dev
                tmpfs          tmpfs     380M  1.2M  379M   1% /run
                /dev/mmcblk0p2 ext4       15G  7.7G  5.8G  58% /
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
                tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                [Sun Apr  7 11:48:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=baa0be65-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sun Apr  7 11:48:30 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
                [Sun Apr  7 11:48:32 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
                TARGET           SOURCE         FSTYPE OPTIONS
                /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                609M    /var/
                203M    /var/cache
                197M    /var/cache/apt
                164M    /var/lib
                141M    /var/log/journal/347b9e5236b042cab12c17eb2f4c9517
                Archived and active journals take up 140.1M in the file system.
                /opt/iobroker/backups:
                1.6G    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                1.4G    /opt/iobroker/iobroker-data/
                968M    /opt/iobroker/iobroker-data/history
                233M    /opt/iobroker/iobroker-data/files
                99M     /opt/iobroker/iobroker-data/backup-objects
                58M     /opt/iobroker/iobroker-data/files/javascript.admin
                38M     /opt/iobroker/iobroker-data/states.jsonl
                38M     /opt/iobroker/iobroker-data/objects.jsonl
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                USB-Devices by-id:
                /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.20.1
                /usr/bin/node           v18.20.1
                /usr/bin/npm            10.5.0
                /usr/bin/npx            10.5.0
                /usr/bin/corepack       0.25.2
                nodejs:
                  Installed: 18.20.1-1nodesource1
                  Candidate: 18.20.1-1nodesource1
                  Version table:
                 *** 18.20.1-1nodesource1 500
                        100 /var/lib/dpkg/status
                     18.20.0-1nodesource1 500
                     18.19.1-1nodesource1 500
                     18.19.0+dfsg-6~deb12u1 500
                     18.19.0-1nodesource1 500
                     18.18.2-1nodesource1 500
                     18.18.1-1nodesource1 500
                     18.18.0-1nodesource1 500
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0+dfsg1-1 500
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                No problems detected
                Errors in npm tree:
                npm ERR! code ELSPROBLEMS
                npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                npm ERR! extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                npm ERR! extraneous: detect-libc@2.0.2 /opt/iobroker/node_modules/detect-libc
                npm ERR! extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/node-addon-api
                npm ERR! extraneous: node-gyp-build@4.7.1 /opt/iobroker/node_modules/node-gyp-build
                npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
                npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
                npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
                npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/agent-base
                npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/debug
                npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/https-proxy-agent
                npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/ms
                npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                npm ERR! invalid: form-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
                npm ERR! A complete log of this run can be found in: /home/rtwl/.npm/_logs/2024-04-07T19_50_23_555Z-debug-0.log
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.19
                admin:          6.13.16
                javascript:     8.0.0
                Adapters from github:   3
                Adapter State
                + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : smarthome                                -  enabled
                + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : smarthome                                - disabled
                + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
                + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
                + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
                  system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
                  system.adapter.discovery.0              : discovery             : smarthome                                - disabled
                  system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
                  system.adapter.flot.0                   : flot                  : smarthome                                - disabled
                + system.adapter.fronius.0                : fronius               : smarthome                                -  enabled
                + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
                + system.adapter.history.0                : history               : smarthome                                -  enabled
                  system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
                  system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
                + system.adapter.iot.0                    : iot                   : smarthome                                -  enabled
                + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
                + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
                + system.adapter.operating-hours.0        : operating-hours       : smarthome                                -  enabled
                + system.adapter.pi-hole.0                : pi-hole               : smarthome                                -  enabled
                + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
                + system.adapter.pvforecast.0             : pvforecast            : smarthome                                -  enabled
                + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
                + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
                + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
                  system.adapter.uv-protect.0             : uv-protect            : smarthome                                -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                - disabled
                  system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
                + system.adapter.weather-warnings.0       : weather-warnings      : smarthome                                -  enabled
                + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
                Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                Adapter    "bring"        : 1.8.4    , installed 1.8.4
                Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                Adapter    "harmony"      : 1.3.0    , installed 1.3.0
                Adapter    "ical"         : 1.14.3   , installed 1.14.3
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "javascript"   : 7.8.0    , installed 8.0.0
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                Adapter    "operating-hours": 1.0.6  , installed 1.0.6
                Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                Adapter    "uv-protect"   : 0.6.0    , installed 0.6.0
                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
                Adapter    "web"          : 6.2.3    , installed 6.2.3
                Adapter    "ws"           : 2.5.11   , installed 2.5.11
                Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                Objects and States
                Objects:        12395
                States:         10907
                Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5797       693/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7347       906/io.mqtt.0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4798       686/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6218       686/iobroker.js-con
                tcp6       0      0 :::61991                :::*                    LISTEN      1001       6664       1154/io.harmony.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          5799       693/sshd: /usr/sbin
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8001       1296/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6282       778/io.admin.0
                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       6665       1154/io.harmony.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4690       532/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7519       976/io.shelly.0
                udp        0      0 0.0.0.0:32832           0.0.0.0:*                           104        4692       532/avahi-daemon: r
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       7435       943/io.radar2.0
                udp6       0      0 :::5353                 :::*                                104        4691       532/avahi-daemon: r
                udp6       0      0 :::60874                :::*                                104        4693       532/avahi-daemon: r
                2024-04-07 21:39:13.968  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Geräte entkalken: Prüfungsergebnis: Fällig seit 12 Tagen
                2024-04-07 21:39:13.972  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Wasserfilter spülen: Script wurde neu gestartet. Ein Timer-Startdatum ist vorhanden, also wird nur aktualisiert.
                2024-04-07 21:39:13.973  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Wasserfilter spülen: Prüfungsergebnis: Fällig seit 71 Tagen
                2024-04-07 21:39:13.978  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Fusselfilter Waschmaschine: Script wurde neu gestartet. Ein Timer-Startdatum ist vorhanden, also wird nur aktualisiert.
                2024-04-07 21:39:13.980  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Fusselfilter Waschmaschine: Prüfungsergebnis: Fällig seit 12 Tagen
                2024-04-07 21:39:14.015  - info: javascript.0 (75060) script.js.LMair.test_marker_abrufen: 0
                2024-04-07 21:39:14.081  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Strom.kWh_Erzeugung
                2024-04-07 21:39:14.133  - info: javascript.0 (75060) script.js.Haussteuerung.Strom.kWh_Erzeugung: registered 0 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
                2024-04-07 21:39:14.134  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Strom.kWh_Gesamtverbrauch
                2024-04-07 21:39:14.206  - info: javascript.0 (75060) script.js.Haussteuerung.Strom.kWh_Gesamtverbrauch: registered 0 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
                2024-04-07 21:39:14.350  - info: javascript.0 (75060) script.js.LMair.marker1: 200
                2024-04-07 21:39:14.482  - info: javascript.0 (75060) Start javascript script.js.LMair.marker
                2024-04-07 21:39:14.494  - info: javascript.0 (75060) script.js.LMair.marker: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                2024-04-07 21:39:14.495  - info: javascript.0 (75060) Start javascript script.js.LMair.weather_json
                2024-04-07 21:39:14.502  - info: javascript.0 (75060) script.js.LMair.weather_json: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                2024-04-07 21:39:14.627  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Fernseher.ambilight
                2024-04-07 21:39:14.634  - info: javascript.0 (75060) script.js.Haussteuerung.Fernseher.ambilight: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                2024-04-07 21:39:15.404  - info: javascript.0 (75060) script.js.Haussteuerung.Lüftungsempfehlungs.Lüftungsempfehlung: Subscriptions angelegt: 20
                2024-04-07 21:39:16.067  - error: javascript.0 (75060) script.js.LMair.marker1: timeout of 2000ms exceeded
                2024-04-07 21:39:16.067  - info: javascript.0 (75060) script.js.LMair.marker1: undefined
                2024-04-07 21:40:00.352  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
                2024-04-07 21:40:00.393  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
                2024-04-07 21:40:00.426  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
                2024-04-07 21:40:01.653  - info: javascript.0 (75060) script.js.Haussteuerung.Lüftungsempfehlungs.Liste_Lueftungsempfehlung: Badezimmer
                2024-04-07 21:50:24.476  - warn: zigbee.0 (1038) DeviceAvailability:Stopping to ping 0x000b57fffe2a31ca TRADFRI bulb E27 WS�opal 980lm after 4 ping attempts
                  @rtwl sagte in javascript startet nicht mehr:
                  Der klemmt noch. Ist das ein Zusätzliches Modul im Adapter?
                  • rtwl
                    Ehrlichgesagt, keine Ahnung was das ist.
                    Als ich soeben keine Blocklys mehr speichern konnte dachte ich mir es würde
                    iob stop
                    sudo reboot
                    helfen. Doch leider bin ich jetzt wieder am Anfang. Der Javascript Adapter bleibt Rot. 😥
                    Auch die Log Meldungen (siehe erster Post) sind wieder alle 30 Sek vorhanden.
                    Hast du noch eine Idee, oder bleibt es mir nicht erspart neu aufzusetzen?
                      Backup?
                      • rtwl
                        hab mich für die neue Installation auf einer neuen SD Karte entschieden. Dort kommt dann das Backup drauf. Somit sollte ich dann auf der sicheren Seite sein. Nicht, dass dann doch noch irgendwo Fehler auftauchen - hab ja den Raspi heute morgen einfach Stromlos gemacht.
                        Danke wiedermal für deine Hilfe 👍
                        • rtwl
                          rtwl last edited by
                          der iobroker (Raspberry/SD Karte) war zwar per Ping ansprechbar. aber weder der iobroker konnte geöffnet werden auch per ssh hatte ich keinen Zugriff mehr.
                          3 Tage später mit dem frisch installiertem iobroker wieder das gleiche Problem...
                          Ping erfolgreich - per ssh aber keinen Zugriff mehr - es kommt keine Passwortanforderung nach der ssh Eingabe.
                          Kann ich außer innerlich durchdrehen noch irgendwas tun?
                          Warum passiert das immer so unvorhergesehen?
                            iob diag
                            anschauen.
                            • rtwl
                              @thomas-braun soweit komm ich ja gar nicht. Hab keinen Zugriff per ssh. Der iobroker ist ja "abgestürzt"
                              • rtwl
                                es gibt nicht zufällig einen http request den ich an die ip-adresse des Raspberry schicken kann um iobroker neu zu starten oder sowas in der Art?
                                  @rtwl
                                  Du kommst ja wohl nicht drauf.
                                  Mit lokal angeklemmter Tastatur:
                                  https://wiki.ubuntuusers.de/Magic_SysRQ/
                                  • rtwl
                                    leider hab ich keinen mini-hdmi adapter für den Raspi.
                                    aber meinst du es würde funktionieren eine Tastatur anzuschließen und dann
                                    Zitat der Website: "hierfür wird die ganze Zeit Alt + Druck gedrückt gehalten und nacheinander die Tasten R + E + I + S + U + B betätigt."?
                                      Thomas Braun Most Active @rtwl last edited by Thomas Braun
                                      @rtwl
                                      Das hängt von der Tastatur ab. Viele moderne Spar-Tastaturen haben die Taste nicht (mehr direkt), manche auch gar nicht.
                                      Ich weiß auch ehrlich gesagt gar nicht, ob Raspberry OS die Funktion nicht auch abgestellt hat. Ich musste die bei mir noch nie verwenden. Das Ding läuft einfach.
                                      Auf meinem Arch Linux geht es nämlich nicht:
                                      [Do, 11. Apr 2024, 00:02:24] sysrq: This sysrq operation is disabled.
                                      [Do, 11. Apr 2024, 00:02:25] sysrq: This sysrq operation is disabled.
                                      [Do, 11. Apr 2024, 00:02:26] sysrq: This sysrq operation is disabled.
                                      [Do, 11. Apr 2024, 00:02:27] sysrq: Emergency Sync
                                      [Do, 11. Apr 2024, 00:02:27] Emergency Sync complete
                                      [Do, 11. Apr 2024, 00:02:28] sysrq: This sysrq operation is disabled.
                                      [Do, 11. Apr 2024, 00:02:29] sysrq: This sysrq operation is disabled.
                                      • rtwl
                                        @thomas-braun wow, das hat tatsächlich funktioniert 👍
                                        iob diag für dich zur Kontrolle. Bitte Danke.
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : arm64
                                         23:58:26 up 1 min,  2 users,  load average: 3.98, 1.25, 0.44
                                        CPU threads: 4
                                        Current issues:
                                        ~ Under-voltage has occurred
                                                       Local time: Wed 2024-04-10 23:58:26 CEST
                                                   Universal time: Wed 2024-04-10 21:58:26 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        rtwl
                                        /home/rtwl
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            4.0G        1.6G        2.2G        1.2M        329M        2.4G
                                        Swap:           104M          0B        104M
                                        Total:          4.1G        1.6G        2.3G
                                                 3792 M total memory
                                                 1478 M used memory
                                                 1477 M active memory
                                                  156 M inactive memory
                                                 2066 M free memory
                                                   31 M buffer memory
                                                  283 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/mmcblk0p2 ext4       15G  5.7G  7.8G  43% /
                                        [Wed Apr 10 23:56:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c17d14e5-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Wed Apr 10 23:56:41 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                                        [Wed Apr 10 23:56:44 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                                        /var:
                                        513M    /var/
                                        203M    /var/cache
                                        197M    /var/cache/apt
                                        161M    /var/lib
                                        133M    /var/lib/apt/lists
                                        Archived and active journals take up 48.0M in the file system.
                                        191M    /opt/iobroker/backups/
                                        974M    /opt/iobroker/iobroker-data/history
                                        249M    /opt/iobroker/iobroker-data/files
                                        98M     /opt/iobroker/iobroker-data/backup-objects
                                        75M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        30M     /opt/iobroker/iobroker-data/objects.jsonl
                                        23M     /opt/iobroker/iobroker-data/states.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.5.0
                                        /usr/bin/npx            10.5.0
                                        nodejs:
                                          Version table:
                                         *** 18.20.1-1nodesource1 1001
                                             18.20.0-1nodesource1 1001
                                             18.19.1-1nodesource1 1001
                                             18.19.0-1nodesource1 1001
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0+dfsg1-1 500
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.13.16
                                        javascript:     8.0.2
                                        Adapter State
                                        + system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
                                          system.adapter.pi-hole.0                : pi-hole               : smarthome                                - disabled
                                          system.adapter.uv-protect.0             : uv-protect            : smarthome                                - disabled
                                        + instance is alive
                                        Adapter    "javascript"   : 7.8.0    , installed 8.0.2
                                        Objects and States
                                        Objects:        12474
                                        States:         10977
                                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Pending Updates: 2
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7443       1215/io.mqtt.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6394       717/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5898       710/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5891       710/iobroker.js-con
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5037       943/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11032      1916/io.web.0
                                        tcp6       0      0 :::61991                :::*                    LISTEN      1001       11375      1693/io.harmony.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6396       717/sshd: /usr/sbin
                                        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11376      1693/io.harmony.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        729        559/avahi-daemon: r
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       10659      1485/io.shelly.0
                                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       6973       1366/io.radar2.0
                                        udp        0      0 0.0.0.0:41284           0.0.0.0:*                           104        731        559/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                104        730        559/avahi-daemon: r
                                        udp6       0      0 :::42826                :::*                                104        732        559/avahi-daemon: r
                                        2024-04-11 00:00:16.802  - info: weather-warnings.0 (1887) Refresh Interval: 10 minutes
                                        2024-04-11 00:00:16.940  - info: weather-warnings.0 (1887) [pushover] Create notification service pushover adapter: pushover.0.
                                        2024-04-11 00:00:16.941  - info: weather-warnings.0 (1887) ZAMG activated. Retrieve data.
                                        2024-04-11 00:00:20.464  - error: daswetter.0 (1193) force terminate
                                        2024-04-11 00:00:20.512  - warn: daswetter.0 (1193) Terminated (UNKNOWN_ERROR): Without reason
                                        2024-04-11 00:00:21.112  - error: daswetter.0 (1193) exception in await insertIntoList [Error: DB closed]
                                        2024-04-11 00:00:21.125  - error: daswetter.0 (1193) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_3.Hour_23.rain_value": Connection is closed.
                                        2024-04-11 00:00:21.309  - error: host.smarthome instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                                        2024-04-11 00:00:23.262  - info: pvforecast.0 (1827) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
                                        2024-04-11 00:00:33.382  - warn: javascript.0 (1031) You are assigning a number to the state "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                                        2024-04-11 00:00:33.820  - warn: javascript.0 (1031)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
                                        2024-04-11 00:00:33.824  - warn: javascript.0 (1031)     at Object.<anonymous> (script.js.VIS.Wetter.Wetterwarnung_Popup:7:3)
                                        2024-04-11 00:00:33.825  - warn: javascript.0 (1031)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1350:38)
                                        2024-04-11 00:00:33.826  - warn: javascript.0 (1031)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:640:29)
                                        2024-04-11 00:00:33.826  - warn: javascript.0 (1031)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
                                        2024-04-11 00:00:33.827  - warn: javascript.0 (1031)     at processImmediate (node:internal/timers:476:21)
                                        2024-04-11 00:00:34.123  - info: javascript.0 (1031) State value to set for "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" has to be type "string" but received type "number"
                                        2024-04-11 00:00:34.178  - warn: javascript.0 (1031) You are assigning a number to the state "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                                        2024-04-11 00:00:34.181  - warn: javascript.0 (1031)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
                                        2024-04-11 00:00:34.181  - warn: javascript.0 (1031)     at Object.<anonymous> (script.js.VIS.Wetter.Wetterwarnung_Popup:7:3)
                                        2024-04-11 00:00:34.182  - warn: javascript.0 (1031)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1350:38)
                                        2024-04-11 00:00:34.182  - warn: javascript.0 (1031)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:640:29)
                                        2024-04-11 00:00:34.183  - warn: javascript.0 (1031)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
                                        2024-04-11 00:00:34.183  - warn: javascript.0 (1031)     at processImmediate (node:internal/timers:476:21)
                                        2024-04-11 00:00:34.590  - info: javascript.0 (1031) State value to set for "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" has to be type "string" but received type "number"
                                          Das würde ich mir anschauen. Besseres NETZteil besorgen. Kein Handy-Ladegerät oder sowas.
                                          • rtwl
                                            @thomas-braun Vielen Dank, das werde ich probieren 👍
                                            1028
