    4. Installation iobroker.systeminfo über NPM geht nicht
      Thomas Braun Most Active @ich77 last edited by
      @ich77
      iob update
      iob repo show
      sagt?
      • I
        ich77 @Thomas Braun last edited by
        Leider dieses...
        pi@raspberrypi:~ $ iob update
        Error: Object "system.repositories" not found
        pi@raspberrypi:~ $ iob repo show
        List is empty
          @ich77
          Da ist irgendwas total krumm....
          iob repo add stabil http://download.iobroker.net/sources-dist.json
          iob repo set stabil
          iob repo show
          I haus-automatisierung 2 Replies Last reply Reply Quote 0
          • I
            Weiß zwar nicht warum, aber jetzt funktioniert alles wieder und ich kann den Adapter installieren!
            Vielen Dank!
              @ich77
              Dann zeig jetzt mal die Ausgaben von
              iob repo show
              iob update
              • I
                So sieht es jetzt aus:
                stabil        : http://download.iobroker.net/sources-dist.json
                Active repo(s): stable, stabil
                Used repositories: stable, stabil
                Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                Adapter    "deconz"       : 1.4.0    , installed 1.4.0
                Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                Adapter    "ical"         : 1.14.3   , installed 1.14.3
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                Adapter    "material"     : 1.3.1    , installed 1.3.1
                Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
                Adapter    "parser"       : 2.1.0    , installed 2.1.0
                Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                Adapter    "ring"         : 5.0.10   , installed 5.0.10
                Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                Adapter    "web"          : 6.2.3    , installed 6.2.3
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                Adapter    "ws"           : 2.5.11   , installed 2.5.11
                Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                pi@raspberrypi:~ $
                • haus-automatisierung
                  haus-automatisierung Developer Most Active @Thomas Braun last edited by
                  @thomas-braun sagte in Installation iobroker.systeminfo über NPM geht nicht:
                  Vor kurzem hatten wir hier schonmal so ein Fall, wo das ganze Objekt system.repositories weg war. Das scheint dann zu komischen Seiteneffekten zu führen. Die Frage ist, wie das Objekt gelöscht werden kann.
                    @ich77
                    Dann
                    iob repo unset stable
                    um Doubletten zu vermeiden. Das kann auch für Trouble sorgen.
                    mcm1957 I 2 Replies Last reply Reply Quote 0
                    • mcm1957
                      mcm1957 @Thomas Braun last edited by
                      Vorsicht
                      stable ist richtig
                      STABIL ist zumindest ungewöhnlich. Ich vermute mal hat sich Thomas vertippt.
                      stable und beta sind die richtigen Namen.
                      Wenn du nicht 150% eindeutschen willst, deaktiviere / lösche STABIL
                        Thomas Braun Most Active @mcm1957 last edited by
                        @mcm57 sagte in Installation iobroker.systeminfo über NPM geht nicht:
                        Nee, das ist absichtlich so, weil stable
                        wohl noch irgendwo im System klebte:
                        Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
                        Man könnte versuchen jetzt wieder aus stabil ein stable zu machen.
                        • mcm1957
                          OK - dann misch ich mich nicht weiter ein 🙂
                          DANKE für deine Hilfe.
                          • I
                            ich77 @haus-automatisierung last edited by
                            Wenn ich helfen kann (Daten sammeln oder schicken), wenn jemand an dem "Fehler" suchen möchtet, sagt gerne Bescheid!
                            • I
                              @thomas-braun Vielen herzlichen Dank für Deine Unterstützung!
                              npm npm error install systeminfo adapter
                              1232
