    4. ioBroker friert ein: "Request actual repository...".....
      Thomas Braun Most Active @Lollo_C last edited by
      @lollo_c
      Gibt mal von allen Kisten die Langfassung von
      iob diag
      bekannt.
        Lollo_C @Thomas Braun last edited by
        @thomas-braun Hier zunächst vom Master:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: RasPi4
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi8-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         21:15:15 up  1:01,  2 users,  load average: 0.99, 0.63, 0.50
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2024-03-27 21:15:15 CET
                   Universal time: Wed 2024-03-27 20:15:15 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            4.0G        2.4G        333M        1.2M        1.2G        1.6G
        Swap:           104M          0B        104M
        Total:          4.1G        2.4G        438M
                 3792 M total memory
                 2250 M used memory
                 2836 M active memory
                  500 M inactive memory
                  317 M free memory
                   93 M buffer memory
                 1058 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.2M  379M   1% /run
        /dev/sda2      ext4      110G  9.7G   96G  10% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Wed Mar 27 20:13:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A6:44:D3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a45a8ca6-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Wed Mar 27 20:13:58 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Mar 27 20:13:59 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET           SOURCE    FSTYPE OPTIONS
        /                /dev/sda2 ext4   rw,noatime
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.0G    /var/
        4.0G    /var/log/journal/e4b3faf7370f4262b1b9aded77288404
        4.0G    /var/log
        539M    /var/cache
        Archived and active journals take up 3.9G in the file system.
        /opt/iobroker/backups:
        75M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        641M    /opt/iobroker/iobroker-data/
        519M    /opt/iobroker/iobroker-data/files
        164M    /opt/iobroker/iobroker-data/files/vis-2
        92M     /opt/iobroker/iobroker-data/backup-objects
        81M     /opt/iobroker/iobroker-data/files/vis-2/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        24M     /opt/iobroker/iobroker-data/objects.jsonl
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.20.0-1nodesource1
          Version table:
             18.20.0-1nodesource1 1001
         *** 18.19.1-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u1 500
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : RasPi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : RasPi4                                   -  enabled
          system.adapter.cloud.0                  : cloud                 : RasPi4                                   - disabled
          system.adapter.devices.0                : devices               : RasPi4                                   - disabled
        + system.adapter.discovery.0              : discovery             : RasPi4                                   -  enabled
          system.adapter.dwd.0                    : dwd                   : RasPi3                                   -  enabled
          system.adapter.flot.0                   : flot                  : RasPi4                                   - disabled
        + system.adapter.hm-rega.1                : hm-rega               : RasPi4                                   -  enabled
        + system.adapter.hm-rpc.2                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
        + system.adapter.hmip.0                   : hmip                  : RasPi4                                   -  enabled
          system.adapter.ical.0                   : ical                  : RasPi3                                   -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : RasPi4                                   - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RasPi4                                   - disabled
        + system.adapter.influxdb.0               : influxdb              : RasPi4                                   -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : RasPi4                                   -  enabled, port: 8086
        + system.adapter.influxdb.2               : influxdb              : RasPi4                                   -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : RasPi4                                   -  enabled
          system.adapter.luftdaten.0              : luftdaten             : RasPi3                                   -  enabled
          system.adapter.luftdaten.1              : luftdaten             : RasPi3                                   -  enabled
          system.adapter.luftdaten.2              : luftdaten             : RasPi3                                   -  enabled
          system.adapter.mobile.0                 : mobile                : RasPi4                                   - disabled
        + system.adapter.modbus.0                 : modbus                : RasPi4                                   -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : RasPi4                                   -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.nut.0                    : nut                   : RasPi4                                   -  enabled
          system.adapter.openweathermap.0         : openweathermap        : RasPi3                                   -  enabled
        + system.adapter.owfs.0                   : owfs                  : RasPi3                                   -  enabled, port: 4304
        + system.adapter.ping.0                   : ping                  : RasPi4                                   -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : RasPi3                                   -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : RasPi4                                   -  enabled
        + system.adapter.rpi2.1                   : rpi2                  : RasPi3                                   -  enabled
        + system.adapter.scenes.0                 : scenes                : RasPi4                                   -  enabled
        + system.adapter.shelly.0                 : shelly                : RasPi4                                   -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : RasPi4                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : RasPi3                                   -  enabled
        + system.adapter.socketio.0               : socketio              : RasPi4                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonos.0                  : sonos                 : RasPi4                                   -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : RasPi3                                   -  enabled
        + system.adapter.telegram.0               : telegram              : RasPi4                                   -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : RasPi4                                   -  enabled
          system.adapter.vis-2.0                  : vis-2                 : RasPi4                                   - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : RasPi4                                   - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : RasPi4                                   -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RasPi4                                   - disabled
          system.adapter.vis-material.0           : vis-material          : RasPi4                                   - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi4                                   - disabled
          system.adapter.vis-metro.0              : vis-metro             : RasPi4                                   -  enabled
          system.adapter.vis-players.0            : vis-players           : RasPi4                                   - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : RasPi4                                   - disabled
          system.adapter.vis-weather.0            : vis-weather           : RasPi4                                   - disabled
          system.adapter.vis.0                    : vis                   : RasPi4                                   -  enabled
        + system.adapter.web.0                    : web                   : RasPi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.ws.0                     : ws                    : RasPi4                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : RasPi4                                   -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
        + instance is alive
        ioBroker-Repositories
        stable        : http://repo.iobroker.live/sources-dist.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "discovery"    : 4.4.0    , installed 4.2.0  [Updatable]
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "hmip"         : 1.22.0   , installed 1.22.0
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "owfs"         : 0.7.0    , installed 0.7.0
        Adapter    "shelly"       : 6.8.0    , installed 6.6.1  [Updatable]
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        11601
        States:         9592
        Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:2 https://repos.influxdata.com/debian stable InRelease
        Hit:3 http://deb.debian.org/debian bookworm InRelease
        Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 7
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      106        16717      704/redis-server 0.
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16706      718/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16835      775/influxd
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16909      851/iobroker.js-con
        tcp        0      0 192.168.2.210:42010     0.0.0.0:*               LISTEN      1001       16262      1067/io.hm-rpc.2
        tcp        0      0 192.168.2.210:42001     0.0.0.0:*               LISTEN      1001       19700      1082/io.hm-rpc.3
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       20925      1231/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        13640      723/mosquitto
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16708      718/sshd: /usr/sbin
        tcp6       0      0 :::3000                 :::*                    LISTEN      108        13753      850/grafana
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       20286      1272/io.sonos.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        13722      775/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23008      1363/io.simple-api.
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21380      1303/io.socketio.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22965      1352/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13780      889/io.admin.0
        tcp6       0      0 :::1883                 :::*                    LISTEN      107        13641      723/mosquitto
        udp        0      0 0.0.0.0:54748           0.0.0.0:*                           104        13537      549/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13535      549/avahi-daemon: r
        udp6       0      0 fe80::5635:5d6e:3e1:546 :::*                                0          13245      661/NetworkManager
        udp6       0      0 :::60556                :::*                                104        13538      549/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        13536      549/avahi-daemon: r
        2024-03-27 20:47:56.672  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1711568876576,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711568876576}
        2024-03-27 20:47:56.773  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1711568876676,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711568876676}
        2024-03-27 20:51:37.377  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1711569097373,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569097373}
        2024-03-27 20:51:38.377  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state with {"val":"stop","ack":false,"ts":1711569098373,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569098373}
        2024-03-27 20:51:38.380  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":false,"ack":false,"ts":1711569098373,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569098373}
        2024-03-27 21:05:22.330  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_45","ack":false,"ts":1711569922324,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569922324}
        2024-03-27 21:05:22.372  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1711569922324,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569922324}
        2024-03-27 21:05:22.428  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1711569922425,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569922425}
        2024-03-27 21:05:28.709  - info: zigbee.0 (1261) Device '0x842e14fffea79363' announced itself
        2024-03-27 21:06:47.202  - info: zigbee.0 (1261) State value to set for "zigbee.0.14b457fffe3358c5.brightness" has to be type "number" but received type "boolean"
        2024-03-27 21:06:47.522  - info: zigbee.0 (1261) Device '0x00158d00045845e9' announced itself
        2024-03-27 21:06:47.664  - info: zigbee.0 (1261) Device '0x00158d00045850c7' announced itself
        2024-03-27 21:06:47.683  - info: zigbee.0 (1261) Device '0x00158d00045832aa' announced itself
        2024-03-27 21:06:53.254  - error: zigbee.0 (1261) Send command to 0x7cb03eaa0a0c57e5 failed with no error code (Timeout - 40202 - 3 - 120 - 6 - 11 after 10000ms)
        2024-03-27 21:06:53.537  - info: zigbee.0 (1261) Device '0x842e14fffea79363' announced itself
        2024-03-27 21:08:56.112  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.coordinator with {"val":"192_168_2_45","ack":false,"ts":1711570136107,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711564306935}
        2024-03-27 21:08:57.133  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state with {"val":"stop","ack":false,"ts":1711570137109,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570137109}
        2024-03-27 21:08:57.137  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state_simple with {"val":false,"ack":false,"ts":1711570137109,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570137109}
        2024-03-27 21:10:03.205  - warn: zigbee.0 (1261) unread state change for group members ["0x00158d00045845e9","0x00158d00045850c7"]
        2024-03-27 21:10:26.257  - warn: zigbee.0 (1261) unread brightness change for group members ["0x00158d00045832aa","0x00158d00045845e9","0x00158d00045850c7"]
        2024-03-27 21:10:49.329  - warn: zigbee.0 (1261) unread colortemp change for group members ["0x00158d00045832aa","0x00158d00045845e9","0x00158d00045850c7"]
        2024-03-27 21:12:28.657  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.coordinator with {"val":"192_168_2_27","ack":false,"ts":1711570348654,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570348654}
        2024-03-27 21:12:28.699  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state with {"val":"play","ack":false,"ts":1711570348654,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570348654}
        2024-03-27 21:12:28.702  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state_simple with {"val":true,"ack":false,"ts":1711570348654,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570348654}
        2024-03-27 21:12:50.821  - info: admin.0 (889) ==> Connected system.user.admin from ::ffff:192.168.2.74
        und hier der Slave:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
          Static hostname: RasPi3
                Icon name: computer
         Operating System: Raspbian GNU/Linux 10 (buster)
                   Kernel: Linux 5.10.103-v7+
             Architecture: arm
        Model           : Raspberry Pi 3 Model B Plus Rev 1.3
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        21:18:30 up 12:22,  1 user,  load average: 0.54, 0.46, 0.45
        CPU threads: 4
        Current issues:
        ~ Under-voltage has occurred
                      Local time: Wed 2024-03-27 21:18:30 CET
                  Universal time: Wed 2024-03-27 20:18:30 UTC
                        RTC time: n/a
                     NTP service: active
                 RTC in local TZ: no
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           923M        501M        152M        6.0M        269M        450M
        Swap:           99M          0B         99M
        Total:         1.0G        501M        252M
                 923 M total memory
                 501 M used memory
                 160 M active memory
                 555 M inactive memory
                 152 M free memory
                  62 M buffer memory
                 206 M swap cache
                  99 M total swap
                   0 M used swap
                  99 M free swap
        Raspberry only:
        oom events: 0
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       15G  5.5G  8.2G  41% /
        devtmpfs       devtmpfs  430M     0  430M   0% /dev
        tmpfs          tmpfs     462M     0  462M   0% /dev/shm
        tmpfs          tmpfs     462M  6.3M  456M   2% /run
        tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
        [Wed Mar 27 08:56:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Wed Mar 27 08:56:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Mar 27 08:56:26 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Mar 27 08:56:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        /             /dev/mmcblk0p2 ext4      rw,noatime
        |-/sys/fs/bpf none           bpf       rw,nosuid,nodev,noexec,relatime,mode=700
        |-/run/owfs   OWFS           fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/boot       /dev/mmcblk0p1 vfat      rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.6G    /var/
        2.3G    /var/cache/apt/archives
        2.3G    /var/cache/apt
        2.3G    /var/cache
        137M    /var/lib
        Archived and active journals take up 5.7M in the file system.
        169M    /opt/iobroker/backups/
        42M     /opt/iobroker/iobroker-data/
        15M     /opt/iobroker/iobroker-data/backup-objects
        8.0M    /opt/iobroker/iobroker-data/files/vis
        7.9M    /opt/iobroker/iobroker-data/files/web
        2.0M    /opt/iobroker/iobroker-data/objects.json.migrated
        2.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        636K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-20_objects.json.gz
        632K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-28_objects.json.gz
        632K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-25_objects.json.gz
        USB-Devices by-id:
        /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DK0EJEOL-if00-port0
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        nodejs:
         Candidate: 18.19.1-1nodesource1
         Version table:
        *** 18.19.1-1nodesource1 600
               500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            18.19.0-1nodesource1 600
            18.18.2-1nodesource1 600
            18.18.1-1nodesource1 600
            18.18.0-1nodesource1 600
            18.17.1-1nodesource1 600
            18.17.0-1nodesource1 600
            18.16.1-1nodesource1 600
            18.16.0-1nodesource1 600
            18.15.0-1nodesource1 600
            18.14.2-1nodesource1 600
            18.14.1-1nodesource1 600
            18.14.0-1nodesource1 600
            18.13.0-1nodesource1 600
            18.12.0-1nodesource1 600
            18.11.0-1nodesource1 600
            18.10.0-1nodesource1 600
            18.9.1-1nodesource1 600
            18.9.0-1nodesource1 600
            18.8.0-1nodesource1 600
            18.7.0-1nodesource1 600
            18.6.0-1nodesource1 600
            18.5.0-1nodesource1 600
            18.4.0-1nodesource1 600
            18.3.0-1nodesource1 600
            18.2.0-1nodesource1 600
            18.1.0-1nodesource1 600
            18.0.0-1nodesource1 600
            10.24.0~dfsg-1~deb10u3 500
        Errors in npm tree:
        ioBroker Status
        At least one iobroker host is running.
        Objects type: jsonl
        States  type: redis
        admin:          6.13.16
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
        + instance is alive
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Objects and States
        Objects:        11601
        States:         9592
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 http://phoscon.de/apt/deconz buster InRelease
        Get:4 https://repos.influxdata.com/debian buster InRelease [12.8 kB]
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Err:4 https://repos.influxdata.com/debian buster InRelease
        Fetched 12.8 kB in 7s (1740 B/s)
        Pending Updates: 12
        tcp        0      0 0.0.0.0:2120            0.0.0.0:*               LISTEN      109        14864      328/owftpd
        tcp        0      0 0.0.0.0:2121            0.0.0.0:*               LISTEN      109        15672      464/owhttpd
        tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          16981      636/node
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16900      641/sshd
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16742      389/influxd
        tcp6       0      0 :::3500                 :::*                    LISTEN      0          18468      636/node
        tcp6       0      0 :::4304                 :::*                    LISTEN      0          10977      1/init
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        18566      389/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16902      641/sshd
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14047      634/dhcpcd
        udp        0      0 0.0.0.0:37004           0.0.0.0:*                           108        14888      334/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14886      334/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14887      334/avahi-daemon: r
        udp6       0      0 :::35598                :::*                                108        14889      334/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14081      634/dhcpcd
        2024-03-27 21:15:20.223  - info: host.RasPi3 instance system.adapter.openweathermap.0 started with pid 10740
        2024-03-27 21:15:25.157  - info: host.RasPi3 instance system.adapter.luftdaten.2 terminated with code 0 (NO_ERROR)
        2024-03-27 21:15:26.618  - info: openweathermap.0 (10740) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.1, js-controller: 5.0.19
        2024-03-27 21:15:36.480  - info: openweathermap.0 (10740) Terminated (NO_ERROR): Without reason
        2024-03-27 21:15:37.049  - info: host.RasPi3 instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
        2024-03-27 21:16:00.049  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 10962
        2024-03-27 21:16:16.929  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-03-27 21:17:00.051  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11131
        2024-03-27 21:17:16.438  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-03-27 21:18:00.047  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11339
        2024-03-27 21:18:09.117  - info: smartmeter.0 (895) Received 66 values, 2 updated
        2024-03-27 21:18:18.027  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-03-27 21:19:00.028  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11728
        2024-03-27 21:19:18.695  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-03-27 21:20:00.112  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11998
        2024-03-27 21:20:04.129  - info: host.RasPi3 instance system.adapter.luftdaten.2 started with pid 12009
        2024-03-27 21:20:08.178  - info: host.RasPi3 instance system.adapter.luftdaten.1 started with pid 12196
        2024-03-27 21:20:12.194  - info: host.RasPi3 instance system.adapter.luftdaten.0 started with pid 12267
        2024-03-27 21:20:12.528  - info: host.RasPi3 instance system.adapter.luftdaten.2 terminated with code 0 (NO_ERROR)
        2024-03-27 21:20:16.212  - info: host.RasPi3 instance system.adapter.dwd.0 started with pid 12282
        2024-03-27 21:20:17.632  - info: host.RasPi3 instance system.adapter.luftdaten.1 terminated with code 0 (NO_ERROR)
        2024-03-27 21:20:22.010  - info: dwd.0 (12282) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.1, js-controller: 5.0.19
        2024-03-27 21:20:22.217  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-03-27 21:20:22.516  - info: host.RasPi3 instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2024-03-27 21:20:24.749  - info: host.RasPi3 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          @lollo_c
          Der Master muss mal aktualisiert werden. Inkl. anschließendem Reboot, weil Kernel-Update.
          Und
          wozu braucht man drei Instanzen influxdb, die aber auf die gleiche Datenbank zugreifen?
          Der Slave muss komplett in die Gegenwart geholt werden, Raspbian 10 'Buster' ist abgekündigt. Neuinstallation von Raspberry OS 12 'Bookworm'.
            @thomas-braun Mit "Master aktualisieren" meinst Du sudo apt-get update und sudo apt full-upgrade, oder?
            Die 3 Instanzen influxDB_v1.8 habe ich, weil ich unterschiedliche Vorhaltezeiten habe.
            Zum Slave: Ich war bis gerade der Meinung, Bookworm gibt es nur als 64 bit Variante. Da muss ich mich jetzt mal näher mit beschäftigen, wie ich den hochgezogen bekomme. Ist es nicht dann viel besser, für den Slave auch einen 64 bit Raspi zu nehmen?
            Ich hatte damals (vor 5 Jahren) mit dem Raspi3 gestartet. Der hat noch ein Homematik Funkmodul drin. Gibt es irgendwo einen "Fahrplan", wie ich ein Master-Slave System komplett neu aufsetzen kann?
              @lollo_c
              Der Rpi3 kann auch mit 64bit umghehen. Die letzen Versionen definitiv.
                A Former User @Lollo_C last edited by
                @lollo_c
                Wenn Dein iobroker neu startet, wirft das Log unter anderem diesen Fehler aus.
                2024-03-14 17:31:31.746 - error: host.RasPi4 iobroker npm-install: host.RasPi4 Unknown packetName vis-material-webfont. Please install packages from outside the repository using npm!
                Wenn dieser Adapter schräg rumhängt, kann ich mir vorstellen, dass er just immer dann einfriert, wenn er Adapter raten und das Repo abgleichen will.
                Kannst Du den nicht "irgendwie" bereinigen und löschen?
                  Lollo_C @Guest last edited by
                  @rscsb Die Meldung kam bis zum 14.03.24 Danach habe ich die Instanz und den Adapter gelöscht. Seitdem kam die Meldung nicht mehr.
                    Lollo_C @Lollo_C last edited by
                    @lollo_c sagte in ioBroker friert ein: "Request actual repository...".....:
                    Ich habe im Admin-Adapter den Zeitraum für die Überprüfung der Updates erst einmal von "täglich" auf "alle 2 Wochen" gestellt.
                    Hallo Zusammen,
                    was soll ich sagen: 14 Tage sind rum, der ioBroker wollte mal wieder nach Hause telefonieren....
                    2024-04-10 22:16:16.995 - info: admin.0 (94686) Request actual repository...
                    2024-04-10 22:16:20.263 - info: host.RasPi4 Updating repository "stable" under "http://repo.iobroker.live/sources-dist.json"
                    ...und prompt ist der RasPi wieder eingefroren. Für mich besteht da ein Zusammenhang.
                    Wie dem auch sei: Ich bin gerade dabei mit aktueller Hardware ein neues System aufzubauen. Dann habe ich hoffentlich Ruhe.
                      @lollo_c
                      Hattest du die Langfassung von
                      iob diag
                      gepostet?
                        @thomas-braun Ja, hatte ich in dem Beitrag https://forum.iobroker.net/post/1144851 gepostet.
                          Clyde @Lollo_C last edited by
                          @lollo_c Bist du schon schlauer geworden? Habe seit Februar genau die gleichen sporadischen Abstüzte mit genau den gleichen letzten Meldungen und völlig ratlos
                          Thomas Braun L 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @Clyde last edited by
                            @clyde
                            Und hast du auch die Langfassung von
                            iob diag
                            gepostet?
                              Clyde @Thomas Braun last edited by
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                 Static hostname: raspberrypi
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 6.1.64-v8+
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                               15:57:44 up 1 day, 21:51,  2 users,  load average: 0.93, 1.07, 1.00
                              CPU threads: 4
                              Current issues:
                                             Local time: Mon 2024-04-22 15:57:44 CEST
                                         Universal time: Mon 2024-04-22 13:57:44 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            1.8G        1.1G        263M        0.0K        477M        673M
                              Swap:            99M         23M         76M
                              Total:          1.9G        1.1G        340M
                                       1847 M total memory
                                       1106 M used memory
                                        966 M active memory
                                        453 M inactive memory
                                        263 M free memory
                                         46 M buffer memory
                                        431 M swap cache
                                         99 M total swap
                                         23 M used swap
                                         76 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /dev/root      ext4       59G   36G   21G  64% /
                              devtmpfs       devtmpfs  666M     0  666M   0% /dev
                              tmpfs          tmpfs     924M     0  924M   0% /dev/shm
                              tmpfs          tmpfs     370M  1.1M  369M   1% /run
                              /dev/sda1      vfat      253M   60M  193M  24% /boot
                              tmpfs          tmpfs     185M  4.0K  185M   1% /run/user/1000
                              [Sat Apr 20 18:06:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enab                   le_hdmi=0  smsc95xx.macaddr=E4:5F:01:A3:D6:28 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=811c5af8-02 rootfstype=ext4 fsck.repai                   r=yes rootwait
                              [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                              [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): write access will be enabled during recovery
                              [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
                              [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): 1 orphan inode deleted
                              [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): recovery complete
                              [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Sat Apr 20 18:06:24 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                              [Sat Apr 20 18:06:26 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                              `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                              /var:
                              802M    /var/
                              543M    /var/cache
                              538M    /var/cache/apt
                              473M    /var/cache/apt/archives
                              101M    /var/lib
                              Archived and active journals take up 55.0M in the file system.
                              84M     /opt/iobroker/backups/
                              31G     /opt/iobroker/iobroker-data/history
                              324M    /opt/iobroker/iobroker-data/files
                              99M     /opt/iobroker/iobroker-data/history/20230624
                              98M     /opt/iobroker/iobroker-data/history/20230702
                              31M     /opt/iobroker/iobroker-data/objects.jsonl
                              27M     /opt/iobroker/iobroker-data/states.jsonl
                              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                              19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                              USB-Devices by-id:
                              /usr/bin/nodejs         v18.20.2
                              /usr/bin/node           v18.20.2
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              /usr/bin/corepack       0.25.2
                              nodejs:
                                Installed: 18.20.2-1nodesource1
                                Candidate: 18.20.2-1nodesource1
                                Version table:
                               *** 18.20.2-1nodesource1 500
                                   18.20.1-1nodesource1 500
                                   18.20.0-1nodesource1 500
                                   18.19.1-1nodesource1 500
                                   18.19.0-1nodesource1 500
                                   18.18.2-1nodesource1 500
                                   18.18.1-1nodesource1 500
                                   18.18.0-1nodesource1 500
                                   18.17.1-1nodesource1 500
                                   18.17.0-1nodesource1 500
                                   18.16.1-1nodesource1 500
                                   18.16.0-1nodesource1 500
                                   18.15.0-1nodesource1 500
                                   18.14.2-1nodesource1 500
                                   18.14.1-1nodesource1 500
                                   18.14.0-1nodesource1 500
                                   18.13.0-1nodesource1 500
                                   18.12.0-1nodesource1 500
                                   18.11.0-1nodesource1 500
                                   18.10.0-1nodesource1 500
                                   18.9.1-1nodesource1 500
                                   18.9.0-1nodesource1 500
                                   18.8.0-1nodesource1 500
                                   18.7.0-1nodesource1 500
                                   18.6.0-1nodesource1 500
                                   18.5.0-1nodesource1 500
                                   18.4.0-1nodesource1 500
                                   18.3.0-1nodesource1 500
                                   18.2.0-1nodesource1 500
                                   18.1.0-1nodesource1 500
                                   18.0.0-1nodesource1 500
                                   12.22.12~dfsg-1~deb11u4 500
                                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     7.8.0
                              Adapters from github:   2
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.1.204, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                              + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
                              + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
                              + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
                              + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                              + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                              + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
                              + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                              + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
                              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                              + system.adapter.viessmann.0              : viessmann             : raspberrypi                              -  enabled, port: 3002
                                system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                                system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                                system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
                                system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                              + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                              Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
                              Adapter    "fronius"      : 2.0.2    , installed 1.1.6  [Updatable]
                              Adapter    "go-e"         : 1.0.29   , installed 1.0.29
                              Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
                              Adapter    "hue"          : 3.10.2   , installed 3.10.2
                              Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                              Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                              Adapter    "telegram"     : 3.2.1    , installed 3.1.0  [Updatable]
                              Adapter    "text2command" : 3.0.3    , installed 3.0.3
                              Adapter    "viessmann"    : 1.4.7    , installed 1.4.7
                              Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
                              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                              Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
                              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                              Adapter    "ws"           : 2.5.11   , installed 2.5.11
                              Objects and States
                              Objects:        12641
                              States:         14186
                              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Pending Updates: 0
                              tcp        0      0 192.168.1.204:18701     0.0.0.0:*               LISTEN      1001       3132060    32457/io.hm-rpc.0
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3131143    32322/iobroker.js-c
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3128867    32322/iobroker.js-c
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3129144    32517/io.shelly.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3132545    32547/io.sonoff.0
                              tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      0          3693       542/vcontrold
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15542      533/sshd: /usr/sbin
                              tcp        0      0 192.168.1.204:8081      0.0.0.0:*               LISTEN      1001       3128918    32343/io.admin.0
                              tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        15578      506/redis-server 12
                              tcp        0      0 192.168.1.204:12010     0.0.0.0:*               LISTEN      1001       3132463    32487/io.hm-rpc.2
                              tcp        0      0 192.168.1.204:12001     0.0.0.0:*               LISTEN      1001       3132423    32472/io.hm-rpc.1
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3138863    1257/io.web.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          15552      533/sshd: /usr/sbin
                              tcp6       0      0 ::1:6379                :::*                    LISTEN      109        15579      506/redis-server 12
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14644      711/dhcpcd
                              udp        0      0 0.0.0.0:53397           0.0.0.0:*                           108        12267      392/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12265      392/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        12266      392/avahi-daemon: r
                              udp6       0      0 :::41461                :::*                                108        12268      392/avahi-daemon: r
                              2024-04-22 15:46:57.720  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 adapter for vis-material-advanced
                              2024-04-22 15:46:58.251  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 states (system.adapter.vis-material-advanced.*) from states
                              2024-04-22 15:47:03.233  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced deleted
                              2024-04-22 15:47:03.316  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced.html deleted
                              2024-04-22 15:47:03.415  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
                              2024-04-22 15:47:03.486  - info: host.raspberrypi iobroker host.raspberrypi file vis-material-advanced.admin deleted
                              2024-04-22 15:47:03.514  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced deleted
                              2024-04-22 15:47:03.576  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced.admin deletedhost.raspberrypi Deleting 3 object(s).
                              2024-04-22 15:47:03.726  - info: host.raspberrypi object deleted system.adapter.vis-material-advanced.0
                              2024-04-22 15:47:03.731  - info: host.raspberrypi iobroker host.raspberrypi Deleting 1 state(s).
                              2024-04-22 15:47:08.787  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
                              2024-04-22 15:47:08.824  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 vis.0
                              2024-04-22 15:47:08.827  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
                              2024-04-22 15:47:11.243  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
                              2024-04-22 15:47:12.265  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
                              2024-04-22 15:47:19.819  - info: vis.0 (1239) Uploaded. 0
                              2024-04-22 15:47:20.142  - info: host.raspberrypi iobroker removed 1 package in 15s266 packages are looking for funding  run `npm fund` for details
                              2024-04-22 15:47:20.273  - info: host.raspberrypi "system.adapter.vis.0" disabled
                              2024-04-22 15:47:20.274  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                              2024-04-22 15:47:20.302  - info: host.raspberrypi "system.adapter.vis.0" enabled
                              2024-04-22 15:47:20.302  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                              2024-04-22 15:47:20.307  - info: host.raspberrypi iobroker Adapter "system.adapter.vis.0" restarted.
                              2024-04-22 15:47:20.335  - info: vis.0 (1239) Terminated (NO_ERROR): Without reason
                              2024-04-22 15:47:20.983  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                              2024-04-22 15:47:21.349  - info: host.raspberrypi iobroker exit 0
                              ============ Mark until here for C&P =============```
                                Lollo_C @Clyde last edited by Lollo_C
                                @clyde sagte in ioBroker friert ein: "Request actual repository...".....:
                                Wie ich weiter oben angekündigt hatte, habe ich den Fehler genutzt und meine Hardware umgestellt. Der Master läuft nun auf einem Raspberry Pi 5 mit 8 GB und der Slave auf einem Raspberry Pi 4 mit 4 GB.
                                Das System läuft nun seit über einer Woche ohne Probleme, obwohl jeden Tag auf Updates überprüft wird.
                                Das "alte" System läuft noch leer nebenher und ich denke mal, dass er in 2 Tagen wieder einfrieren wird. Dann sind die 14 Tage um und er wird wieder nach Updates suchen wollen.
                                  @clyde
                                  Stell es auf ein reines 64Bit 'Bookworm' um.
                                  Und 2GB RAM sind für einen 'normalen' Betrieb unterdimensioniert.
                                  Dann hast du Einschläge auf dem Dateisystem:
                                  Bei den ioBroker-Adaptern herrscht Update-Stau.
                                    Clyde @Thomas Braun last edited by Clyde
                                    @thomas-braun lief über Jahre mit den 2 GB.
                                    Wie stelle ich auf Bookworm um?
                                    Vor zwei Wochen alles geupdadet, aber ja, müsste ich mal wieder machen.
                                    Was bedeutet das mit den Einschlägen? 18:06 am 20. April war übrigens direkt zum Reboot nach dem letzten Hänger. Also beim Hochfahren nach dem Fehler und dementsprechend eher nicht ursächlich.
                                      Das ist immer so. Irgendwann läuft es eben nicht mehr.
                                      Komplette Neuinstallation, weil du da im Userland auf 32Bit hängst.
                                      Dann machst du es deutlich zu selten. Die 8 Updates sind doch nicht alle aus den letzten zwei Wochen? Nicht im Stable-Repo...
                                      Das bedeutet, dass nach deiner Exekution durch Stromentzug das System einige Dateien nicht wieder reanimieren konnte und die beerdigt/gelöscht hat.
                                      Nö, vielleicht nicht, aber da hat es die nächsten Rumms im Dateisystem gegeben, trägt alles nicht zu einem stabilen System bei. Im Gegenteil.
                                        Alle zwei Wochen ist zu selten? Dachte eigentlich, dass iobroker für mich arbeitet und nicht umgekehrt. Bis auf den Fronius-Adapter war vor zwei Wochen alles aktuell. Bei dem gibt es wohl ein größere Update mit Objektänderungen, was ich mal irgendwann mache, wenn ich mehr Zeit habe.
                                        Vermutlich dann im Zuge der 64-Bit-Umstellung.
                                        Der "Einschlag" war wie gesagt nach dem harten Reset; vermutlich einfach dem geschuldet. Was bleibt: "wir haben keine Ahnung, also Neuinstallation." Ärgerlich aber nach ein paar Jahren ohne Probleme wohl mal verschmerzbar.
                                        Thomas Braun Homoran Codierknecht 3 Replies Last reply Reply Quote 0
                                          Ich habe genug Ahnung und ich sage dir, das eine Umstellung des Userlands von 32Bit auf 64Bit nicht per Upgrade sondern nur per kompletter Neuinstallation geht.
                                          Und meine Ahnung lässt mich auch wissen, das gelöschte Inodes halt gelöscht sind und nicht wiederhergestellt werden konnten. Auch das bekommst du nur durch eine Neuinstallation und Einspielen eines hoffentlich vorhandenen Backups geheilt.
                                            Homoran Global Moderator Administrators @Clyde last edited by
                                            dann ist gut,
                                            @thomas-braun sagte in ioBroker friert ein: "Request actual repository...".....:
                                            ich habe im stable keine 8 updates in den letzten 2 Wochen gehabt, höchstens 3.
                                            nicht ernst gemeint, oder doch?
                                            81
                                            5110
