    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      Tenjo78 @SKB last edited by
      @skb Alles klar. Im Java-Adapter. Erledigt. LÄUFT!
      Danke!
        Tenjo78 last edited by
        und was bedeutet das?
        No overload matches this call.
          The last overload gave the following error.
            Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.(2769)
        javascript.d.ts(1527, 11): The last overload is declared here.
          cyqx13 last edited by
          habe auch den Speedtest Adapter installiert, über ssh werden auch korrekte Ergebnisse geliefert.
          Dann habe ich das js Skript importiert, Pfad angepasst und bekomme folgende Fehlermeldung:
          2024-01-17 22:23:50.140 - error: javascript.0 (32246) script.js.common.Speedtest: SyntaxError: Unexpected end of JSON input
          2024-01-17 22:23:50.141 - error: javascript.0 (32246) at JSON.parse ()
          2024-01-17 22:23:50.142 - error: javascript.0 (32246) at generiere_array (script.js.common.Speedtest:181:18)
          2024-01-17 22:23:50.142 - error: javascript.0 (32246) at script.js.common.Speedtest:229:28
          2024-01-17 22:23:50.142 - error: javascript.0 (32246) at ChildProcess.exithandler (node:child_process:414:7)
          2024-01-17 22:23:50.143 - error: javascript.0 (32246) at ChildProcess.emit (node:events:517:28)
          2024-01-17 22:23:50.143 - error: javascript.0 (32246) at ChildProcess.emit (node:domain:489:12)
          2024-01-17 22:23:50.143 - error: javascript.0 (32246) at maybeClose (node:internal/child_process:1098:16)
          2024-01-17 22:23:50.143 - error: javascript.0 (32246) at Process.ChildProcess._handle.onexit (node:internal/child_process:303:5)
          Kann mir da jemand helfen?
            Thomas Braun Most Active @cyqx13 last edited by
            @cyqx13
            sudo apt update
            apt policy speedtest
            sagt?
              cyqx13 @Thomas Braun last edited by Negalein
              pi@iobroker:~ $ sudo apt update
              OK:1 http://archive.raspberrypi.org/debian buster InRelease
              Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
              OK:3 https://repos.influxdata.com/debian stable InRelease
              OK:4 https://packages.grafana.com/oss/deb stable InRelease
              OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Ign:6 https://packagecloud.io/ookla/speedtest-cli/raspbian buster InRelease
              Fehl:7 https://packagecloud.io/ookla/speedtest-cli/raspbian buster Release
                404  Not Found [IP: 2600:1f1c:2e5:6900:e12:7a5d:4cf3:3662 443]
              E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/raspbian buster Release« enthält keine Release-Datei.
              N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
              N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
              pi@iobroker:~ $ apt policy speedtest-cli
              speedtest-cli:
                Installiert:           2.0.2-1+deb10u2
                Installationskandidat: 2.0.2-1+deb10u2
                Versionstabelle:
               *** 2.0.2-1+deb10u2 500
                      100 /var/lib/dpkg/status
                Thomas Braun Most Active @cyqx13 last edited by Thomas Braun
                @cyqx13
                Da haben wir den Fehler auch schon.
                Falsches Paket und dein Betriebssystem ist auch tot...
                Installier da was lebendiges. Debian 12 'Bookworm' bzw. Raspberry OS 12 'Bookworm'. In der 64Bit Lite-Version.
                Funktionierend sähe das so aus:
                echad@chet:~ $ apt policy speedtest*
                speedtest:
                  Installed: 1.2.0.84-1.ea6b6773cf
                  Candidate: 1.2.0.84-1.ea6b6773cf
                  Version table:
                 *** 1.2.0.84-1.ea6b6773cf 500
                        500 https://packagecloud.io/ookla/speedtest-cli/debian trixie/main arm64 Packages
                speedtest-cli:
                  Installed: (none)
                  Candidate: 2.1.3-2
                  Version table:
                     2.1.3-2 500
                        500 http://deb.debian.org/debian testing/main arm64 Packages
                        500 http://deb.debian.org/debian testing/main armhf Packages
                  ok danke, Betriebssystem mache ich mal die Tage, steht auf meiner ToDo Liste, aber wieso falsches Paket? Müsste doch trotzdem zu installieren sein?
                  Bei sudo apt install speedtest
                  funktioniert auch nur speedtest-cli
                    @cyqx13 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                    Weil das Paket 'speedtest' heißt (und aus dem extra dafür angelegten Repo kommt) und nicht 'speedtest-cli'.
                    Deswegen steht auch im ersten Posting:
                    Zunächst den falschen Kram deinstallieren:
                    sudo apt remove speedtest-cli speedtest
                      Logisch. Das richtige Repo wird für dein totes OS ja nicht mehr angeboten. Daher: OS frisch neuinstallieren.
                      • Nashra
                        Hallo, seit einigen Tagen stimmen die Werte vom Speedtest nicht mehr.
                        Hatte immer 400 Down- und 200 Upload, nun nur noch zw. 80 und 90.
                        Auch der Aufruf im Cli bringt nur noch diese niedrigen Werte. Was mir aber
                        aufgefallen ist, ein Error bei Aufruf von speedtest.
                        jack@ioBroker:~$ speedtest
                           Speedtest by Ookla
                        [error] Error: [0] Cannot read from socket:
                              Server: ITbyHF / Alec H. - Dusseldorf (id: 51708)
                                 ISP: Deutsche Glasfaser
                        Idle Latency:     4.43 ms   (jitter: 2.24ms, low: 3.06ms, high: 7.70ms)
                            Download:    91.01 Mbps (data used: 46.7 MB)
                                         63.97 ms   (jitter: 23.70ms, low: 9.63ms, high: 434.04ms)
                              Upload:    92.77 Mbps (data used: 90.1 MB)
                                         12.29 ms   (jitter: 2.20ms, low: 10.01ms, high: 48.52ms)
                         Packet Loss:     0.0%
                          Result URL: https://www.speedtest.net/result/c/e0acc694-c4a3-41b6-88b2-35a3d5dd7086
                        • Negalein
                          Negalein Global Moderator @Nashra last edited by
                          @nashra sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                          hast du mal einen anderen Server versucht?
                          Bei mir passt alles.
                          • Nashra
                            Nashra Most Active Forum Testing @Negalein last edited by
                            @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                            Ja habe ich. Wenn ich im Browser Ookla direkt aufrufe und starte, dann kommen die richtigen Werte.
                            Komme nicht dahinter warum das auf einmal so ist.
                            • Nashra
                              Nashra Most Active Forum Testing last edited by Nashra
                              Erledigt, Fehler gefunden bzw. hätte ich direkt nachsehen sollen. Switch im Netzwerk wars 🤦‍♂️
                              Und der Error beim Aufruf im CLI ist auch weg.
                              • matze55
                                matze55 last edited by
                                Hallo....ich frage zwar dort beim Scriptersteller wie man das Datum konvertieren könnte. Im Script wird ja:
                                let monat = '0' +(datum.getMonth() +1);
                                der Monat definiert mit einer 0 in der Monatszahl. Aber es muss doch möglich sein den Monatsnamen zu konvertieren. Ich habe im Netz viele ansätze gesucht aber dan haut es mir in das Script Fehler rein bis auf ein Stop
                                mein Gedanke war her daher:
                                let monat = [
                                    "Januar",
                                    "Februar",
                                    "März",
                                    "April",
                                    "Mai",
                                    "Juni",
                                    "Juli",
                                    "August",
                                    "September",
                                    "Oktober",
                                    "November",
                                    "Dezember"
                                nur die Ausgabe....furchtbar...
                                Hat da einer Idee den ich und Javascript ist wie ein Bäcker muß ein Auto verkaufen, also no Ahnung
                                matze55 1 Reply Last reply Reply Quote 0
                                • matze55
                                  matze55 @matze55 last edited by matze55
                                  @matze55 Problem gelösst es klappt. wer Interresse hat poste ich das Script mit Anzeige des Monatsnamenanzeige und Anzeige des Wochentages...erst mal danke an den Sriptersteller
                                  Das Bild wird mit dialogpopup geöffnet...und mit CSS definiert.
                                  Anzeige Wochentag und Monat ...selbst erklärend--man sieht es. Ich nutze die VIS von SIGGI der tolle Sachen macht..hut ab.
                                  • matze55
                                    @matze55 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                    Ich habe noch die Wochentage hinzugefügt>>>>Thanks für den Denkanstoss--Stephan
                                    Dr.Pie 1 Reply Last reply Reply Quote 0
                                    • Dr.Pie
                                      Dr.Pie @matze55 last edited by
                                      Hallo
                                      das Script liefert mir diese Meldung:
                                      javascript.0	10:07:07.928	error	script.js.common.D_U: exec is not available. Please enable "Enable Exec" option in instance settings
                                      javascript.0	10:07:07.928	error	script.js.common.D_U: Speedtest konnte nicht ausgeführt werden! exec is not available. Please enable "Enable Exec" option in instance settings
                                      Homoran T 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @Dr.Pie last edited by
                                        @dr-pie sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                        nein!
                                        Die Instanz
                                        javascript.0
                                        liefert diese Meldung!
                                        Tu einfach was da steht
                                        • Dr.Pie
                                          Dr.Pie @Homoran last edited by
                                          Wo finde ich diese Einstellung ?
                                            Homoran Global Moderator Administrators @Dr.Pie last edited by Homoran
                                            391
                                            73773
