    4. Support Adapter Energiefluss-erweitert v0.7.7
    • SKB
      SKB Developer Most Active @Aiouh last edited by
      @aiouh Kannst Du den Inhalt des Datenpunkt "configuration" hier einmal Einstellen?
      • Alex1808
        Alex1808 last edited by Alex1808
        @SKB Hi, kann Mann ein Bild nach wertzustand (Boolen, Zahl) ändern? (Ähnlich wie bei vis Bulb on/off)
        • SKB
          SKB Developer Most Active @Alex1808 last edited by
          @alex1808 aktuell noch nicht. Nehme ich mit auf die Liste.
          Alex1808 1 Reply Last reply Reply Quote 0
            Aiouh @SKB last edited by
            @skb Ja, gerne
              "basic": {
                "enable_grid": true,
                "enable_animation": false,
                "enable_area_catch": true,
                "enable_config_icon": true,
                "enable_last_id": false,
                "enable_icon_proxy": true,
                "enable_low_performance": false,
                "height": 608,
                "width": 800,
                "styles": "",
                "font": {
                  "family": "\"Arial\", sans-serif",
                  "size": "20",
                  "color": "",
                  "fill": "",
                  "align": "middle"
                "rect": {
                  "height": 100,
                  "width": 100,
                  "corners": 10
                "circle": {
                  "radius": 50
                "elm": {
                  "stroke_width": 5,
                  "color": "",
                  "fill": "",
                  "pos_x": 700,
                  "pos_y": 50
                "icon": {
                  "height": 30,
                  "width": 30,
                  "color": ""
              "calculation": {
                "battery": {
                  "dod": 0,
                  "capacity": 0,
                  "percent": -1,
                  "charge": -1,
                  "charge_prop": false,
                  "charge_kw": false,
                  "discharge": -1,
                  "discharge_prop": false,
                  "discharge_kw": false
                "consumption": {
                  "production": [
                    "1"
                  "production_kw": false,
                  "gridFeed": 0,
                  "gridFeed_kw": false,
                  "gridFeed_prop": true,
                  "gridConsume": -1,
                  "gridConsume_kw": false,
                  "gridConsume_prop": false,
                  "batteryCharge": 3,
                  "batteryCharge_kw": false,
                  "batteryCharge_prop": false,
                  "batteryDischarge": null,
                  "batteryDischarge_kw": false,
                  "batteryDischarge_prop": false
              "animation": {
                "stroke": "#ffce4a",
                "stroke_dasharray": "10 17 10 17 10  72",
                "stroke_width": "6",
                "animation_duration": "2000",
                "stroke_linecap": "round",
                "animation_timing_function": "linear"
              "animation_configuration": {
                "dots": "3",
                "distance": "17",
                "length": "10"
              "line": {
                "stroke_width": "8",
                "stroke": "#000000"
              "elements": {
                "2": {
                  "position": 28,
                  "type": "text",
                  "subType": "datasource",
                  "id": 2,
                  "pos_x": 346,
                  "pos_y": 322,
                  "color": "none",
                  "fill": "rgb(0, 0, 0)",
                  "font_family": "Arial, sans-serif",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 2",
                  "unit": "kW",
                  "source": 1,
                  "source_option": -1,
                  "source_display": "value",
                  "shadow": "",
                  "threshold": 0,
                  "calculate_kw": "calc",
                  "counter_animation": false,
                  "convert": false,
                  "decimal_places": 1,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "5": {
                  "position": 12,
                  "type": "rect",
                  "id": 5,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 296,
                  "pos_y": 266,
                  "fill": "none",
                  "color": "rgb(255, 206, 74)",
                  "stroke": 2,
                  "shadow": "rgba(0, 0, 0, 0.7)",
                  "frame": "_overlay",
                  "fill_type": "percent",
                  "fill_direction": 90,
                  "border_type": -1,
                  "border_direction": "cw",
                  "border_style": "round",
                  "border_reverse": false,
                  "border_start": null,
                  "source": -1,
                  "threshold": 0
                "6": {
                  "position": 13,
                  "type": "icon",
                  "id": "6",
                  "icon": "mdi:solar-panel",
                  "width": 24,
                  "height": 24,
                  "color": "rgba(0, 0, 0, 0.7)",
                  "pos_x": "334",
                  "pos_y": "277",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "7": {
                  "position": 11,
                  "type": "rect",
                  "id": 7,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 468,
                  "pos_y": 336,
                  "fill": "none",
                  "color": "rgb(0, 181, 221)",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "9": {
                  "position": 27,
                  "type": "text",
                  "id": 9,
                  "pos_x": 518,
                  "pos_y": 389,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 9",
                  "unit": "kW",
                  "source": 10,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "decimal_places": 2,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "10": {
                  "position": 26,
                  "type": "text",
                  "id": 10,
                  "pos_x": 346,
                  "pos_y": 346,
                  "color": "none",
                  "fill": "rgba(0, 0, 0, 0.7)",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Produktion",
                  "shadow": "",
                  "frame": "_overlay"
                "11": {
                  "position": 25,
                  "type": "text",
                  "id": 11,
                  "pos_x": 518,
                  "pos_y": 414,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Verbrauch",
                  "shadow": "",
                  "frame": "_overlay"
                "12": {
                  "position": 12,
                  "type": "icon",
                  "id": "12",
                  "icon": "mdi:house-city",
                  "width": 24,
                  "height": 24,
                  "pos_x": "506",
                  "pos_y": "344",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "13": {
                  "position": 10,
                  "type": "rect",
                  "id": 13,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 23,
                  "pos_y": 482,
                  "fill": "none",
                  "color": "rgb(7, 150, 5)",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "14": {
                  "position": 9,
                  "type": "rect",
                  "id": 14,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 296,
                  "pos_y": 483,
                  "fill": "none",
                  "color": "rgba(97, 104, 122, 0.7)",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "15": {
                  "position": 24,
                  "type": "text",
                  "id": 15,
                  "pos_x": 96,
                  "pos_y": 505,
                  "color": "none",
                  "font_size": 15,
                  "align": "middle",
                  "text": "LG",
                  "shadow": "",
                  "frame": "_overlay"
                "16": {
                  "position": 23,
                  "type": "text",
                  "id": 16,
                  "pos_x": 75,
                  "pos_y": 535,
                  "color": "none",
                  "font_size": 20,
                  "align": "middle",
                  "text": "ID 16",
                  "unit": "kW",
                  "source": 26,
                  "shadow": "",
                  "threshold": 0,
                  "convert": true,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "18": {
                  "position": 22,
                  "type": "text",
                  "id": 18,
                  "pos_x": 71,
                  "pos_y": 566,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 18",
                  "unit": "%",
                  "source": 5,
                  "shadow": "",
                  "threshold": 0,
                  "calculate_kw": "none",
                  "convert": false,
                  "decimal_places": 0,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "19": {
                  "position": 21,
                  "type": "text",
                  "id": 19,
                  "pos_x": 346,
                  "pos_y": 542,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 19",
                  "unit": "kW",
                  "source": 0,
                  "shadow": "",
                  "threshold": 0,
                  "convert": true,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "20": {
                  "position": 11,
                  "type": "icon",
                  "id": "20",
                  "icon": "mdi:electricity-from-grid",
                  "width": 30,
                  "height": 30,
                  "pos_x": "335",
                  "pos_y": "490",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "22": {
                  "position": 8,
                  "type": "rect",
                  "id": 22,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 468,
                  "pos_y": 483,
                  "fill": "none",
                  "color": "rgb(197, 144, 46)",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "23": {
                  "position": 10,
                  "type": "icon",
                  "id": "23",
                  "icon": "material-symbols:electric-car",
                  "width": 30,
                  "height": 30,
                  "pos_x": "503",
                  "pos_y": "489",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "27": {
                  "position": 20,
                  "type": "text",
                  "id": 27,
                  "pos_x": 518,
                  "pos_y": 572,
                  "color": "none",
                  "fill": "rgb(197, 144, 46)",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 27",
                  "unit": "%",
                  "source": 9,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "33": {
                  "position": 7,
                  "type": "rect",
                  "id": 33,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 165,
                  "pos_y": 484,
                  "fill": "none",
                  "color": "rgb(38, 98, 211)",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "37": {
                  "position": 19,
                  "type": "text",
                  "id": 37,
                  "pos_x": 215,
                  "pos_y": 566,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 37",
                  "unit": "%",
                  "source": 6,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "38": {
                  "position": 18,
                  "type": "text",
                  "id": 38,
                  "pos_x": 215,
                  "pos_y": 535,
                  "color": "none",
                  "font_size": 20,
                  "align": "middle",
                  "text": "ID 38",
                  "unit": "kW",
                  "source": 2,
                  "shadow": "",
                  "threshold": 0,
                  "convert": true,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "39": {
                  "position": 17,
                  "type": "text",
                  "id": 39,
                  "pos_x": 237,
                  "pos_y": 505,
                  "color": "none",
                  "font_size": 15,
                  "align": "middle",
                  "text": "Pylont.",
                  "shadow": "",
                  "frame": "_overlay"
                "40": {
                  "position": 6,
                  "type": "rect",
                  "id": 40,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 23,
                  "pos_y": 34,
                  "fill": "none",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "41": {
                  "position": 16,
                  "type": "text",
                  "id": 41,
                  "pos_x": 73,
                  "pos_y": 111,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Balkon",
                  "shadow": "",
                  "frame": "_overlay"
                "42": {
                  "position": 15,
                  "type": "text",
                  "id": 42,
                  "pos_x": 73,
                  "pos_y": 84,
                  "color": "none",
                  "fill": "rgb(6, 5, 2)",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 42",
                  "unit": "kW",
                  "source": 11,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "43": {
                  "position": 9,
                  "type": "icon",
                  "id": "43",
                  "width": 24,
                  "height": 24,
                  "pos_x": "61",
                  "pos_y": "46",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "44": {
                  "position": 5,
                  "type": "rect",
                  "id": 44,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 165,
                  "pos_y": 34,
                  "fill": "none",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "45": {
                  "position": 14,
                  "type": "text",
                  "id": 45,
                  "pos_x": 215,
                  "pos_y": 85,
                  "color": "none",
                  "fill": "rgb(14, 11, 4)",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 45",
                  "unit": "kW",
                  "source": 13,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "46": {
                  "position": 13,
                  "type": "text",
                  "id": 46,
                  "pos_x": 215,
                  "pos_y": 111,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Laube",
                  "shadow": "",
                  "frame": "_overlay"
                "47": {
                  "position": 8,
                  "type": "icon",
                  "id": "47",
                  "width": 24,
                  "height": 24,
                  "pos_x": "203",
                  "pos_y": "46",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "49": {
                  "position": 4,
                  "type": "rect",
                  "id": 49,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 363,
                  "pos_y": 34,
                  "fill": "none",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "50": {
                  "position": 12,
                  "type": "text",
                  "id": 50,
                  "pos_x": 412,
                  "pos_y": 111,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Pergola",
                  "shadow": "",
                  "frame": "_overlay"
                "51": {
                  "position": 11,
                  "type": "text",
                  "id": 51,
                  "pos_x": 414,
                  "pos_y": 85,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 51",
                  "unit": "kW",
                  "source": 14,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "52": {
                  "position": 7,
                  "type": "icon",
                  "id": "52",
                  "width": 24,
                  "height": 24,
                  "pos_x": "400",
                  "pos_y": "46",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "53": {
                  "position": 3,
                  "type": "rect",
                  "id": 53,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 519,
                  "pos_y": 34,
                  "fill": "none",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "54": {
                  "position": 10,
                  "type": "text",
                  "id": 54,
                  "pos_x": 572,
                  "pos_y": 85,
                  "color": "none",
                  "fill": "rgb(11, 9, 3)",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 54",
                  "unit": "kW",
                  "source": 12,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "55": {
                  "position": 9,
                  "type": "text",
                  "id": 55,
                  "pos_x": 567,
                  "pos_y": 111,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Carport",
                  "shadow": "",
                  "frame": "_overlay"
                "56": {
                  "position": 6,
                  "type": "icon",
                  "id": "56",
                  "width": 24,
                  "height": 24,
                  "pos_x": "558",
                  "pos_y": "46",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "57": {
                  "position": 5,
                  "type": "icon",
                  "id": "57",
                  "icon": "solar:sun-linear",
                  "width": 60,
                  "height": 60,
                  "color": "rgb(74, 209, 123)",
                  "pos_x": "282",
                  "pos_y": "38",
                  "shadow": "",
                  "source": 15,
                  "threshold": 0,
                  "action": "none"
                "58": {
                  "position": 8,
                  "type": "text",
                  "id": 58,
                  "pos_x": 312,
                  "pos_y": 106,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 58",
                  "unit": "kW",
                  "source": 15,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "59": {
                  "position": 7,
                  "type": "text",
                  "id": 59,
                  "pos_x": 518,
                  "pos_y": 527,
                  "color": "none",
                  "fill": "rgb(1, 7, 3)",
                  "font_size": 20,
                  "align": "middle",
                  "text": "ID 59",
                  "unit": "kW",
                  "source": 24,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "60": {
                  "position": 6,
                  "type": "text",
                  "id": 60,
                  "pos_x": 346,
                  "pos_y": 560,
                  "color": "none",
                  "font_size": 15,
                  "align": "middle",
                  "text": "Grid",
                  "shadow": "",
                  "frame": "_overlay"
                "61": {
                  "position": 5,
                  "type": "text",
                  "id": 61,
                  "pos_x": 518,
                  "pos_y": 550,
                  "color": "none",
                  "font_size": 20,
                  "align": "middle",
                  "text": "ID 61",
                  "unit": "km",
                  "source": 25,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "63": {
                  "position": 4,
                  "type": "icon",
                  "id": "63",
                  "icon": "mingcute:battery-2-line",
                  "width": 40,
                  "height": 40,
                  "color": "rgb(161, 211, 67)",
                  "pos_x": "36",
                  "pos_y": "485",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "65": {
                  "position": 3,
                  "type": "icon",
                  "id": "65",
                  "icon": "mingcute:battery-3-line",
                  "width": 40,
                  "height": 40,
                  "color": "rgb(82, 30, 246)",
                  "pos_x": "171",
                  "pos_y": "485",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
                "66": {
                  "position": 2,
                  "type": "rect",
                  "id": 66,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 654,
                  "pos_y": 434,
                  "fill": "none",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "67": {
                  "position": 4,
                  "type": "text",
                  "id": 67,
                  "pos_x": 704,
                  "pos_y": 507,
                  "color": "none",
                  "font_size": 15,
                  "align": "middle",
                  "text": "Entfeuchter\nWerkstatt",
                  "shadow": "",
                  "frame": "_overlay"
                "68": {
                  "position": 3,
                  "type": "text",
                  "id": 68,
                  "pos_x": 704,
                  "pos_y": 486,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 68",
                  "unit": "kW",
                  "source": "",
                  "shadow": "",
                  "threshold": 0,
                  "convert": true,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "69": {
                  "position": 2,
                  "type": "icon",
                  "id": "69",
                  "icon": "mdi:fan",
                  "width": 30,
                  "height": 30,
                  "pos_x": "693",
                  "pos_y": "437",
                  "shadow": "",
                  "source": 20,
                  "threshold": 0,
                  "action": "none"
                "70": {
                  "position": 1,
                  "type": "rect",
                  "id": 70,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 653,
                  "pos_y": 316,
                  "fill": "none",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "71": {
                  "position": 2,
                  "type": "text",
                  "id": 71,
                  "pos_x": 704,
                  "pos_y": 369,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 71",
                  "unit": "kW",
                  "source": 21,
                  "shadow": "",
                  "threshold": 0,
                  "convert": true,
                  "action": "none",
                  "subtract": [
                    -1
                  "add": [
                    -1
                  "frame": "_overlay"
                "72": {
                  "position": 1,
                  "type": "icon",
                  "id": "72",
                  "icon": "ph:fan-fill",
                  "width": 30,
                  "height": 30,
                  "pos_x": "692",
                  "pos_y": "319",
                  "shadow": "",
                  "source": 20,
                  "threshold": 0,
                  "action": "none"
                "73": {
                  "position": 1,
                  "type": "text",
                  "id": 73,
                  "pos_x": 703,
                  "pos_y": 388,
                  "color": "none",
                  "font_size": 15,
                  "align": "middle",
                  "text": "Entfeuchter\nTechnik",
                  "shadow": "",
                  "frame": "_overlay"
                "74": {
                  "position": 0,
                  "type": "rect",
                  "id": 74,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 653,
                  "pos_y": 197,
                  "fill": "none",
                  "stroke": 2,
                  "border_type": -1,
                  "source": -1,
                  "threshold": 0
                "75": {
                  "position": 0,
                  "type": "text",
                  "id": 75,
                  "pos_x": 704,
                  "pos_y": 269,
                  "color": "none",
                  "font_size": 15,
                  "align": "middle",
                  "text": "Wohnung\n1.OG",
                  "shadow": "",
                  "frame": "_overlay"
                "77": {
                  "position": 0,
                  "type": "icon",
                  "id": "77",
                  "width": 30,
                  "height": 30,
                  "pos_x": "707",
                  "pos_y": "334",
                  "shadow": "",
                  "source": 20,
                  "threshold": 0,
                  "action": "none"
              "defs": {
                "path_5_13": {
                  "type": "def",
                  "id": "path_5_13",
                  "d": "M295 316  H 250.6   H 88 A 15 15 0 0 0 73 331  V 481",
                  "startSlot": "left",
                  "endSlot": "top"
                "path_5_14": {
                  "type": "def",
                  "id": "path_5_14",
                  "d": "M346 367  V 482",
                  "startSlot": "bottom",
                  "endSlot": "top"
                "path_5_33": {
                  "type": "def",
                  "id": "path_5_33",
                  "d": "M326 367  V 390.2 A 15 15 0 0 1 311 405.2  H 230 A 15 15 0 0 0 215 420.2  V 483",
                  "startSlot": "bottom_left",
                  "endSlot": "top"
                "path_40_5": {
                  "type": "def",
                  "id": "path_40_5",
                  "d": "M73 135  V 167.2   V 281 A 15 15 0 0 0 88 296  H 295",
                  "endSlot": "left_top"
                "path_44_5": {
                  "type": "def",
                  "id": "path_44_5",
                  "d": "M215 135  V 161 A 15 15 0 0 0 230 176  H 311 A 15 15 0 0 1 326 191  V 265",
                  "endSlot": "top_left"
                "path_49_5": {
                  "type": "def",
                  "id": "path_49_5",
                  "d": "M413 135  V 161 A 15 15 0 0 1 398 176  H 381 A 15 15 0 0 0 366 191  V 265",
                  "endSlot": "top_right"
                "path_53_5": {
                  "type": "def",
                  "id": "path_53_5",
                  "d": "M569 135  V 167.2   V 281 A 15 15 0 0 1 554 296  H 397",
                  "endSlot": "right_top"
                "path_5_7": {
                  "type": "def",
                  "id": "path_5_7",
                  "d": "M397 336  H 411 A 15 15 0 0 1 426 351  V 351 A 15 15 0 0 0 441 366  H 467",
                  "startSlot": "right_bottom",
                "path_7_22": {
                  "type": "def",
                  "id": "path_7_22",
                  "d": "M518 437  V 482",
                  "endSlot": "top"
                "path_7_66": {
                  "type": "def",
                  "id": "path_7_66",
                  "d": "M569 406  H 585.8 A 15 15 0 0 1 600.8 421  V 489 A 15 15 0 0 0 615.8 504  H 653",
                  "endSlot": "left_bottom"
                "path_7_70": {
                  "type": "def",
                  "id": "path_7_70",
                  "d": "M569 386  H 652",
                  "startSlot": "right",
              "lines": {
                "line_path_5_13": {
                  "type": "line",
                  "id": "line_path_5_13",
                  "href": "#path_5_13",
                  "color": "rgb(0, 0, 0)",
                  "shadow": ""
                "line_path_5_14": {
                  "type": "line",
                  "id": "line_path_5_14",
                  "href": "#path_5_14",
                  "shadow": ""
                "line_path_5_33": {
                  "type": "line",
                  "id": "line_path_5_33",
                  "href": "#path_5_33",
                  "shadow": ""
                "line_path_40_5": {
                  "type": "line",
                  "id": "line_path_40_5",
                  "href": "#path_40_5",
                  "shadow": ""
                "line_path_44_5": {
                  "type": "line",
                  "id": "line_path_44_5",
                  "href": "#path_44_5",
                  "shadow": ""
                "line_path_49_5": {
                  "type": "line",
                  "id": "line_path_49_5",
                  "href": "#path_49_5",
                  "shadow": ""
                "line_path_53_5": {
                  "type": "line",
                  "id": "line_path_53_5",
                  "href": "#path_53_5",
                  "shadow": ""
                "line_path_5_7": {
                  "type": "line",
                  "id": "line_path_5_7",
                  "href": "#path_5_7",
                  "shadow": ""
                "line_path_7_22": {
                  "type": "line",
                  "id": "line_path_7_22",
                  "href": "#path_7_22",
                  "shadow": ""
                "line_path_7_66": {
                  "type": "line",
                  "id": "line_path_7_66",
                  "href": "#path_7_66",
                  "shadow": ""
                "line_path_7_70": {
                  "type": "line",
                  "id": "line_path_7_70",
                  "href": "#path_7_70",
                  "shadow": ""
              "animations": {
                "anim_path_5_13": {
                  "type": "animation",
                  "id": "anim_path_5_13",
                  "source": 26,
                  "threshold": 50,
                  "animation_properties": "positive",
                  "animation_option": true,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                  "animation_type": -1
                "anim_path_5_14": {
                  "id": "anim_path_5_14",
                  "source": 0,
                  "threshold": 80,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_5_33": {
                  "id": "anim_path_5_33",
                  "source": 2,
                  "threshold": 50,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_40_5": {
                  "id": "anim_path_40_5",
                  "source": 11,
                  "threshold": 0,
                  "animation_option": false,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_44_5": {
                  "id": "anim_path_44_5",
                  "source": 13,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_49_5": {
                  "id": "anim_path_49_5",
                  "source": 14,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_53_5": {
                  "id": "anim_path_53_5",
                  "source": 12,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_5_7": {
                  "id": "anim_path_5_7",
                  "source": 10,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_7_22": {
                  "id": "anim_path_7_22",
                  "source": 24,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_7_66": {
                  "id": "anim_path_7_66",
                  "source": 20,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                "anim_path_7_70": {
                  "id": "anim_path_7_70",
                  "source": 21,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
              "datasources": {
                "0": {
                  "source": "alias.0.Consumption.Grid",
                  "alias": "Grid",
                  "factor": 1
                "1": {
                  "source": "alias.0.Consumption.PV_total_power",
                  "alias": "PV total",
                  "factor": 1
                "2": {
                  "source": "alias.0.Pylontech.Power",
                  "alias": "Pylontech power",
                  "factor": 1
                "3": {
                  "source": "alias.0.LG.batterie_ladung",
                  "alias": "LG charge",
                  "factor": 1
                "5": {
                  "source": "alias.0.LG.SoC",
                  "alias": "LG SoC",
                  "factor": 1
                "6": {
                  "source": "alias.0.Pylontech.SoC",
                  "alias": "Pylontech SoC",
                  "factor": 1
                "7": {
                  "source": "0_userdata.0.PV.LG_discharge_neg",
                  "alias": "LG Discharge",
                  "factor": 1
                "9": {
                  "source": "bluelink.0.KNAJ3811FL7003622.vehicleStatus.battery.soc",
                  "alias": "EV SoC",
                  "factor": 1
                "10": {
                  "source": "alias.0.Consumption.Verbrauch_netto",
                  "alias": "Gesamtverbrauch",
                  "factor": 1
                "11": {
                  "source": "alias.0.PV.PV_Balkon",
                  "alias": "PV-Balkon",
                  "factor": 1
                "12": {
                  "source": "alias.0.PV.PV_Carport",
                  "alias": "PV-Carport",
                  "factor": 1
                "13": {
                  "source": "alias.0.PV.PV_Laube",
                  "alias": "PV-Laube",
                  "factor": 1
                "14": {
                  "source": "alias.0.PV.PV_Pergola",
                  "alias": "PV-Pergola",
                  "factor": 1
                "15": {
                  "source": "alias.0.PV.Solarstrahlung",
                  "alias": "Solarstrahlung",
                  "factor": 1
                "16": {
                  "source": "alias.0.Consumption.1OG",
                  "alias": "1OG",
                  "factor": 1
                "17": {
                  "source": "alias.0.Consumption.Drainage Aussen",
                  "alias": "Drainage Aussen",
                  "factor": 1
                "18": {
                  "source": "alias.0.Consumption.Drainage Innen",
                  "alias": "Drainage Innen",
                  "factor": 1
                "19": {
                  "source": "alias.0.Consumption.Hauswasserwerk",
                  "alias": "Hauswasserwerk",
                  "factor": 1
                "20": {
                  "source": "alias.0.Consumption.Luftentfeuchter gross",
                  "alias": "Luftentfeuchter gross",
                  "factor": 1
                "21": {
                  "source": "alias.0.Consumption.Luftentfeuchter klein",
                  "alias": "Luftentfeuchter klein",
                  "factor": 1
                "22": {
                  "source": "alias.0.Consumption.Palme",
                  "alias": "Palme",
                  "factor": 1
                "23": {
                  "source": "alias.0.Consumption.TV / HiFi",
                  "alias": "TV / HiFi",
                  "factor": 1
                "24": {
                  "source": "alias.0.EV.EV Ladeleistung",
                  "alias": "EV Ladeleistung",
                  "factor": 1
                "25": {
                  "source": "alias.0.EV.EV Range",
                  "alias": "EV range",
                  "factor": 1
                "26": {
                  "source": "alias.0.LG.LG_power",
                  "alias": "LG Power",
                  "factor": 1
            • Alex1808
              Alex1808 @SKB last edited by
              @skb Danke! 👍
              • SKB
                @aiouh Du kannst den Adapter nochmal via Github Link installieren. Habe den Fehler abgefangen - so kann der Adapter starten. In einem Element fehlte bei dir eine Datenquelle - dadurch wurde dieser Fehler verursacht!
                  @skb Läuft 👍 Verrätst Du mir noch wie ich das hätte selbst im Config file finden können ?
                  In jedem Fall gibts nochmal ein paar Tassen Kaffee per PayPal, toller Einsatz.
                  DANKE !!!
                  SKB 1 Reply Last reply Reply Quote 1
                  • SKB
                    @aiouh in der config nach "source" suchen - dann wäre irgendwann ein Treffer gekommen, wo es leer ist 😉
                    Freue mich auf den Kaffee 😉
                    U66 1 Reply Last reply Reply Quote 1
                    • U66
                      U66 @SKB last edited by
                      @skb
                      Hallo
                      Ein User aus einem anderen Board hatte mich gefragt, ob es eine Möglichkeit gibt einer Texteingabe, also ein Input, z.B: mit wieviel Ampere soll das eAuto geladen werden? ....
                      Ist so etwas machbar
                      SKB BananaJoe 2 Replies Last reply Reply Quote 0
                      • SKB
                        SKB Developer Most Active @U66 last edited by
                        @u66 Ist nicht vorgesehen. Es ist und bleibt eine View und keine VIS!
                        • U66
                          @skb
                          ok Das geb ich so weiter.
                          • BananaJoe
                            BananaJoe Most Active @U66 last edited by
                            @u66 sagte in Test Adapter Energiefluss-erweitert v0.3.x GitHub/Latest:
                            @skb
                            Hallo
                            Naja, du kannst das "drumherum" bauen, mit eben anderen VIS-Elementen wenn du es in einer VIS einbettest. Du kannst es sogar darüber legen (Z-Index).
                              ps1304 last edited by ps1304
                              @SKB wenn ich ein Bild als img einfüge und das Bild quasi als Hintergrund nutze (Größe gleich Größe der View), dann verschwindet die Animation der Verbindungen wohl in den Hintergrund, selbst wenn ich das Bild ganz nach hinten und die Animation ganz nach vorne schiebe.
                              ohne Hintergrund Bild:
                              mitHintergrund Bild:
                              wobei mir noch nicht ganz klar ist wie ich die Größe des Bildes auf die Größe der View anpassen kann. Setting des Bildes:
                              Wäre es möglich auch ein Bild als Hintergrund anzugeben (Feature Request?) oder soll ich das in Github dokumentieren?
                              Gruß Peter
                              PS: Kaffee ist verschickt :-))
                              • SKB
                                SKB Developer Most Active @ps1304 last edited by SKB
                                @ps1304 Das hat damit zu tun, das alle Elemente nach den Linien gerendert werden. Somit liegen die Elemente immer über den Linien. Damit wird verhindert, das die Linie auf einem Element andockt und den Rahmen "beschädigt".
                                Hintergrundbilder kannst Du selbst im CSS angeben.
                                Die Syntax dazu findest Du z.B. hier:
                                https://www.w3schools.com/cssref/pr_background-image.php
                                Vielen Dank für den Kaffee!
                                  ps1304 @SKB last edited by
                                  @skb 👍
                                  • Merlin123
                                    Merlin123 last edited by
                                    Vielleicht steht es hier schon irgendwo, aber hab es nicht gesehen...
                                    Kann man irgendwie die Farbe der Animation je nach Richtung ändern?
                                    z.B. Bei Netzbezug rot vom Netz zum Haus und bei Einspeisung ins Netz grün?
                                    • SKB
                                      SKB Developer Most Active @Merlin123 last edited by
                                      @merlin123 Ja, das geht.
                                      Ist hier beschrieben:
                                      https://forum.iobroker.net/post/1132453
                                      Werde ich aber noch als Beitrag ins Wiki aufnehmen.
                                      Merlin123 1 Reply Last reply Reply Quote 1
                                      • Merlin123
                                        Merlin123 @SKB last edited by
                                        @skb Dank Dir! Schau ich mir mal an 🙂
                                        • SKB
                                          SKB Developer Most Active @Merlin123 last edited by SKB
                                          @merlin123 Gerne. Falls Probleme mit der Syntax sind, einfach Bescheid geben.
                                          Habe den Artikel im Wiki mal ergänzt:
                                          https://github.com/SKB-CGN/ioBroker.energiefluss-erweitert/wiki/Custom-Overrides-for-elements#beispiel-für-animationslinien
                                          • Merlin123
                                            @skb Funktioniert 🙂
                                            Gleich noch eine Frage:
                                            Eine Verbindung soll folgendes machen:
                                            • Immer animiert
                                            • Immer in die gleiche Richtung animiert
                                            • Wenn Wert >0 Farbe 1, sonst Farbe 2
                                            Ich finde aber jetzt nichts, das er immer animiert
                                            81.1k
                                            vis
                                            191
                                            4352
                                            5664468
