    4. Meldungen beim/nach Upgrade
      pi@iobroker-VM03:~$ cd /opt/iobroker
      pi@iobroker-VM03:/opt/iobroker$ npm ls buffer
      [sudo] Passwort für pi:
      iobroker.inst@3.0.0 /opt/iobroker
      ├─┬ iobroker.modbus@6.1.0
      │ └─┬ crc@4.3.2
      │ └── buffer@6.0.3
      ├─┬ iobroker.pollenflug@1.0.6
      │ └─┬ shelly-iot@1.1.2
      │ └─┬ coap@0.26.0
      │ └─┬ bl@5.0.0
      │ └── buffer@6.0.3 deduped
      └─┬ iobroker.rflink@2.1.6
      └─┬ serialport@8.0.8
      └─┬ @serialport/bindings@8.0.8
      └─┬ prebuild-install@5.3.6
      └─┬ tar-fs@2.1.1
      └─┬ tar-stream@2.2.0
      └─┬ bl@4.1.0
      └── buffer@5.7.1
        Homoran Global Moderator Administrators @Homoran last edited by Homoran
        sieht jetzt besser aus
        │ └─┬ crc@4.3.2
        │   └── buffer@6.0.3
        │   └─┬ coap@0.26.0
        │     └─┬ bl@5.0.0
                └─┬ tar-fs@2.1.1
                    └─┬ bl@4.1.0
                      └── buffer@5.7.1
          die beiden module gelöscht und neu eingetragen
          i@iobroker-VM03:/opt/iobroker$ npm ls fs
          └─┬ iobroker.javascript@7.8.0
            └── fs@0.0.1-security
          pi@iobroker-VM03:/opt/iobroker$ npm ls dewpoint
            └── dewpoint@1.0.0
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: iobroker-VM03
                     Icon name: computer-vm
                       Chassis: vm
                Virtualization: kvm
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 5.10.0-28-amd64
                  Architecture: x86-64
            model name      : Common KVM processor
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             17:20:13 up  3:01,  1 user,  load average: 0.07, 0.40, 0.71
            CPU threads: 8
            *** Time and Time Zones ***
                           Local time: Thu 2024-04-11 17:20:13 CEST
                       Universal time: Thu 2024-04-11 15:20:13 UTC
                             RTC time: Thu 2024-04-11 15:20:14
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi cdrom floppy sudo audio dip video plugdev netdev iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            5.9G        3.7G        1.4G        0.0K        831M        2.0G
            Swap:           974M        614M        360M
            Total:          6.9G        4.3G        1.8G
                     5928 M total memory
                     3654 M used memory
                     1166 M active memory
                     2926 M inactive memory
                     1443 M free memory
                      193 M buffer memory
                      638 M swap cache
                      974 M total swap
                      614 M used swap
                      360 M free swap
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  2.9G     0  2.9G   0% /dev
            tmpfs          tmpfs     593M  468K  593M   1% /run
            /dev/sda1      ext4       62G   54G  5.3G  92% /
            tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
            [Thu Apr 11 14:18:40 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Apr 11 14:18:40 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            TARGET SOURCE    FSTYPE OPTIONS
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            2.7G    /var/
            2.3G    /var/log
            817M    /var/log/journal/14d81482e1a64d47a4613cdb6a71c2c7
            288M    /var/cache
            Archived and active journals take up 32.0M in the file system.
            /opt/iobroker/backups:
            4.0K    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            47G     /opt/iobroker/iobroker-data/
            46G     /opt/iobroker/iobroker-data/history
            384M    /opt/iobroker/iobroker-data/files
            347M    /opt/iobroker/iobroker-data/backup-objects
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            74M     /opt/iobroker/iobroker-data/states.jsonl
            36M     /opt/iobroker/iobroker-data/objects.jsonl
            25M     /opt/iobroker/iobroker-data/objects.json.migrated
            25M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.20.2
            /usr/bin/node           v18.20.2
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            /usr/bin/corepack       0.25.2
            nodejs:
              Installed: 18.20.2-1nodesource1
              Candidate: 18.20.2-1nodesource1
              Version table:
             *** 18.20.2-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 18.20.1-1nodesource1 1001
                 18.20.0-1nodesource1 1001
                 18.19.1-1nodesource1 1001
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.19
            admin:          6.13.16
            javascript:     7.8.0
            Adapters from github:   2
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker-VM03                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : iobroker-VM03                            -  enabled
              system.adapter.cloud.0                  : cloud                 : iobroker-VM03                            - disabled
              system.adapter.daikin.0                 : daikin                : iobroker-VM03                            - disabled
              system.adapter.daikin.1                 : daikin                : iobroker-VM03                            - disabled
              system.adapter.daikin.2                 : daikin                : iobroker-VM03                            - disabled
              system.adapter.daikin.3                 : daikin                : iobroker-VM03                            - disabled
            + system.adapter.denon.0                  : denon                 : iobroker-VM03                            -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker-VM03                            -  enabled
              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-VM03                            - disabled
            + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker-VM03                            -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : iobroker-VM03                            -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker-VM03                            -  enabled
              system.adapter.flot.0                   : flot                  : iobroker-VM03                            - disabled
            + system.adapter.fritzbox.0               : fritzbox              : iobroker-VM03                            -  enabled
            + system.adapter.go-e.0                   : go-e                  : iobroker-VM03                            -  enabled
            + system.adapter.harmony.0                : harmony               : iobroker-VM03                            -  enabled
            + system.adapter.history.0                : history               : iobroker-VM03                            -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker-VM03                            -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-VM03                            -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-VM03                            -  enabled, port: 0
            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-VM03                            -  enabled, port: 0
              system.adapter.ical.0                   : ical                  : iobroker-VM03                            - disabled
              system.adapter.ical.1                   : ical                  : iobroker-VM03                            -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-VM03                            - disabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-VM03                            - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker-VM03                            - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker-VM03                            - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-VM03                            -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-VM03                            - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-VM03                            - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-VM03                            - disabled
              system.adapter.info.0                   : info                  : iobroker-VM03                            - disabled
            + system.adapter.javascript.0             : javascript            : iobroker-VM03                            -  enabled
            + system.adapter.javascript.1             : javascript            : iobroker-VM03                            -  enabled
              system.adapter.luftdaten.0              : luftdaten             : iobroker-VM03                            -  enabled
            + system.adapter.modbus.0                 : modbus                : tinkerboard                              -  enabled
            + system.adapter.modbus.1                 : modbus                : iobroker-VM03                            -  enabled
            + system.adapter.modbus.2                 : modbus                : tinkerboard                              -  enabled
              system.adapter.modbus.3                 : modbus                : tinkerboard                              - disabled
              system.adapter.modbus.4                 : modbus                : tinkerboard                              - disabled
            + system.adapter.mqtt.0                   : mqtt                  : tinkerboard                              -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.nut.0                    : nut                   : iobroker-VM03                            - disabled
              system.adapter.nut.1                    : nut                   : iobroker-VM03                            - disabled
              system.adapter.onkyo.0                  : onkyo                 : iobroker-VM03                            - disabled
            + system.adapter.opi.0                    : opi                   : tinkerboard                              -  enabled
            + system.adapter.parser.0                 : parser                : iobroker-VM03                            -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : iobroker-VM03                            -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker-VM03                            -  enabled, port: 8006
              system.adapter.renault.0                : renault               : iobroker-VM03                            - disabled
              system.adapter.rflink.0                 : rflink                : iobroker-VM03                            - disabled
              system.adapter.sayit.0                  : sayit                 : iobroker-VM03                            - disabled, port: 0
              system.adapter.scenes.0                 : scenes                : iobroker-VM03                            - disabled
            + system.adapter.sensebox.0               : sensebox              : iobroker-VM03                            -  enabled
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-VM03                            -  enabled
              system.adapter.simple-api.0             : simple-api            : iobroker-VM03                            - disabled, port: 8087, bind: 192.168.138.91, run as: admin
            + system.adapter.smartmeter.0             : smartmeter            : tinkerboard                              -  enabled
            + system.adapter.snmp.0                   : snmp                  : iobroker-VM03                            -  enabled
              system.adapter.socketio.0               : socketio              : iobroker-VM03                            - disabled, port: 8084, bind: 0.0.0.0, run as: admin
              system.adapter.sonos.0                  : sonos                 : iobroker-VM03                            - disabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-VM03                            -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-VM03                            -  enabled
            + system.adapter.tradfri.0                : tradfri               : iobroker-VM03                            -  enabled
              system.adapter.tradfri.1                : tradfri               : iobroker-VM03                            - disabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker-VM03                            -  enabled
              system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker-VM03                            -  enabled
              system.adapter.vedirect.0               : vedirect              : tinkerboard                              - disabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker-VM03                            - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-VM03                            - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-VM03                            - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-VM03                            - disabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-VM03                            -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker-VM03                            - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-VM03                            - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-VM03                            - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker-VM03                            - disabled
              system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-VM03                            - disabled
              system.adapter.vis-lcars.0              : vis-lcars             : iobroker-VM03                            - disabled
              system.adapter.vis-map.0                : vis-map               : iobroker-VM03                            - disabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker-VM03                            - disabled
              system.adapter.vis-players.0            : vis-players           : iobroker-VM03                            - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker-VM03                            - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-VM03                            - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-VM03                            - disabled
              system.adapter.vis.0                    : vis                   : iobroker-VM03                            -  enabled
            + system.adapter.web.0                    : web                   : iobroker-VM03                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wiffi-wz.0               : wiffi-wz              : iobroker-VM03                            -  enabled
              system.adapter.yr.0                     : yr                    : iobroker-VM03                            -  enabled
              system.adapter.zoe2.0                   : zoe2                  : iobroker-VM03                            -  enabled
            + instance is alive
            ioBroker-Repositories
            Beta          : http://download.iobroker.net/sources-dist-latest.json
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "backitup"     : 2.10.11  , installed 2.10.11
            Adapter    "daikin"       : 1.4.2    , installed 1.4.2
            Adapter    "denon"        : 1.15.5   , installed 1.15.5
            Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
            Adapter    "energiefluss-erweitert": 0.3.0, installed 0.3.0
            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
            Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
            Adapter    "go-e"         : 1.0.29   , installed 1.0.29
            Adapter    "harmony"      : 1.3.0    , installed 1.3.0
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
            Adapter    "ical"         : 1.14.3   , installed 1.14.3
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
            Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
            Adapter    "modbus"       : 6.1.0    , installed 6.1.0
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
            Adapter    "parser"       : 2.1.0    , installed 2.1.0
            Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
            Adapter    "renault"      : 0.0.15   , installed 0.0.15
            Adapter    "rflink"       : 2.1.6    , installed 2.1.6
            Adapter    "sayit"        : 3.0.5    , installed 3.0.5
            Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "snmp"         : 3.1.0    , installed 3.1.0
            Adapter    "socketio"     : 6.6.1    , installed 6.6.1
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
            Adapter    "trashschedule": 3.2.0    , installed 3.2.0
            Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
            Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
            Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
            Adapter    "ws"           : 2.5.11   , installed 2.5.11
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Objects and States
            Objects:        19291
            States:         18826
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.138.91:8181     0.0.0.0:*               LISTEN      1001       41614      7463/io.wiffi-wz.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2631       438/sshd: /usr/sbin
            tcp        0      0 192.168.138.91:42010    0.0.0.0:*               LISTEN      1001       41243      7046/io.hm-rpc.1
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       40265      6820/iobroker.js-co
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       39878      6820/iobroker.js-co
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12373      1/init
            tcp        0      0 192.168.138.91:42000    0.0.0.0:*               LISTEN      1001       42281      7069/io.hm-rpc.2
            tcp        0      0 192.168.138.91:42001    0.0.0.0:*               LISTEN      1001       38493      7012/io.hm-rpc.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          2642       438/sshd: /usr/sbin
            tcp6       0      0 :::61991                :::*                    LISTEN      1001       45057      7661/io.harmony.0
            tcp6       0      0 :::10123                :::*                    LISTEN      1001       40934      7584/io.energieflus
            tcp6       0      0 :::111                  :::*                    LISTEN      0          2301       1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41111      6841/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41568      7448/io.web.0
            udp        0      0 0.0.0.0:51460           0.0.0.0:*                           1001       38689      7292/io.snmp.0
            udp        0      0 0.0.0.0:43811           0.0.0.0:*                           1001       42740      7418/io.tradfri.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14333      340/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11341      1/init
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       45058      7661/io.harmony.0
            udp6       0      0 :::111                  :::*                                0          12378      1/init
            2024-04-11 17:15:53.729  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Lueftungsscript: Subscriptions angelegt: 36
            2024-04-11 17:15:54.139  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_co2: 81, common: [object Object]
            2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_temp: 20.9, common: [object Object]
            2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_feuchte: 57.7, common: [object Object]
            2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_taupunkt: 12.2, common: [object Object]
            2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_feuchte_abs: 10.5, common: [object Object]
            2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_baro: 1027.26, common: [object Object]
            2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_luftdrucktrend: stabil, common: [object Object]
            2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_lux: 2.5, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_motion_left: false, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_motion_right: false, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.: false, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_noise: false, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_elevation: 27.7, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_azimut: 247, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_buzzer: false, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.MAC-Adresse: 4b:87:d:7f:cf:5c, common: [object Object]
            2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.ip_Homematic_CCU: 192.168.138.91, common: [object Object]
            2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.WLAN_ssid: Funkwelle, common: [object Object]
            2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.WLAN_Signal_dBm: -59, common: [object Object]
            2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.millis_seit_reset: 155063439, common: [object Object]
            2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.wiffizeit:  5 17:15, common: [object Object]
            2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.firmware: wiffi_wz_106, common: [object Object]
            2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: WIFFI Datenpunkte angelegt/aktualisiert
              ich bekomme die Daten als User nicht auf den Pi5
              pi@ioBrokerpi5:~ $ groups
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              pi@ioBrokerpi5:~ $ ls -la /media/usbplatte/backups
              total 77732
              drwxr-xr-x 2 iobroker iobroker    4096 Apr 11 04:22 .
              drwxr-xr-x 4 root     root        4096 Dec 25 13:08 ..
              -rw-r--r-- 1 iobroker iobroker 4680106 Mar 16 01:36 homematic_2024_03_16-01_36_12_3.71.12_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Mar 19 01:36 homematic_2024_03_19-01_36_12_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Mar 22 01:36 homematic_2024_03_22-01_36_12_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Mar 25 01:36 homematic_2024_03_25-01_36_11_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Mar 28 01:36 homematic_2024_03_28-01_36_11_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Mar 31 01:36 homematic_2024_03_31-01_36_11_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Apr  1 01:36 homematic_2024_04_01-01_36_11_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Apr  4 01:36 homematic_2024_04_04-01_36_11_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Apr  7 01:36 homematic_2024_04_07-01_36_11_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 4813226 Apr 10 01:36 homematic_2024_04_10-01_36_11_3.73.9_backupiobroker.tar.sbk
              -rw-r--r-- 1 iobroker iobroker 3148949 Apr  2 04:22 iobroker_2024_04_02-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3154652 Apr  3 04:22 iobroker_2024_04_03-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3154705 Apr  4 04:22 iobroker_2024_04_04-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3155077 Apr  5 04:22 iobroker_2024_04_05-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3153078 Apr  6 04:22 iobroker_2024_04_06-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3152355 Apr  7 04:22 iobroker_2024_04_07-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3153662 Apr  8 04:22 iobroker_2024_04_08-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3153630 Apr  9 04:22 iobroker_2024_04_09-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3157581 Apr 10 04:22 iobroker_2024_04_10-04_22_10_backupiobroker.tar.gz
              -rw-r--r-- 1 iobroker iobroker 3157378 Apr 11 04:22 iobroker_2024_04_11-04_22_10_backupiobroker.tar.gz
              pi@ioBrokerpi5:~ $
              Thomas Braun S 2 Replies Last reply Reply Quote 0
                Verwendest du nicht den Backitup-Adapter?
                Der macht da eigentlich alles richtig.
                  @thomas-braun sagte in Meldungen beim/nach Upgrade:
                  doch, das funktioniert ja auch.
                  jetzt will ich aber das Backup vom Nuc auf den pi5 bringen.
                  wenn ich das dort via backitup hochlade landet es local und nicht in der gemounteten SSD
                    Thomas Braun Most Active @Homoran last edited by Thomas Braun
                    @homoran sagte in Meldungen beim/nach Upgrade:
                    Verstehe ich nicht.
                    zeigt doch ein gemountetes, externes Medium.
                      richtig!
                      aber wenn ich im backitup Reiter trotz aktivierter copy/nas option ein Backup hochlade landet es nur in /opt/iobroker/backups. nicht im mount
                      und wenn ich via filezilla auf /media/usbplatte/backups als user pi schieben will, bekomme ich einen permission error obwohl pi in der Gruppe iobroker ist.
                      die Rechte liegen nur auf 755, was wohl nicht das Screiben durch Gruppenmitglueder zulässt.
                        Der User iobroker darf lesen und schreiben, die Gruppe ioboroker und der Rest darf nur lesen. Damit darf der user pi da nix schreiben.
                        Mit welchen Optionen mountest du denn?
                          ??Bahnhof??
                          das Laufwerk ist einfach mit sudo mount sda1 /media/usbplatte gemountet, ohne weitere Parameter.
                          davon hör ich gerade zum ersten mal 😳
                            Man kann/muss da noch Optionen mitgeben. Meine FritzNAS mounte ich (ist aber eine CIFS-Freigabe) z. B. so:
                            //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,cache=loose,noauto,rw,uid=iobroker,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                            Wichtig ist hier
                            uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777
                            Dateien werden also mit vollen Rechten (Lesen/Schreiben/Ausführen) für den user iobroker wie für die Gruppe iobroker gemountet. (Gut, das Ausführen-Bit könnte man auch weglassen, zumindest für Dateien)
                            Die Optionen unterscheiden sich je nach Dateisystem, das gemountet wird, die Rechte sind aber alle ähnlich zu vergeben.
                              Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                              Dann werde ich mir später mal diese Lektion anlernen.
                              im Moment schiebe ich die aktuellen Backups dann eben in lokal
                              die mountplatte kommt dann irgendwann
                              der Befehl wäre dann sudo mount /dev/sda1 /media/usbplatte,uid=iobroker gid=iobroker,file_mode=0775,dir_mode=0775?
                              in der fstab ist er eh noch nicht drin
                                Ich würde hier mal reinschauen:
                                https://wiki.ubuntuusers.de/mount/
                                  @thomas-braun Danke!
                                  dann wären das hier dchon ein paar Optionen
                                  /dev/sda1 on /media/usbplatte type ext4 (rw,relatime) zuzüglich uid, gid und den modes
                                  412
